[rockchip] broken SPI on RockPro64 and other RK3399 targets
I wanted to update U-Boot on my RockPro64 board from some random build of 2020.07-rc with out of tree patches to official one. Built, flashed and then got this:
Loading Environment from SPI Flash... Invalid bus 0 (err=-19) *** Warning - spi_flash_probe_bus_cs() failed, using default environment
According to Peter Robinson it happens also on other RK3399 boards.
As I had a bit of time I started bisecting and found reason:
16:43 (7s) hrw@puchatek:u-boot$ git bisect good c4cea2bbf995764f325a907061c22ecd6768cf7b is the first bad commit commit c4cea2bbf995764f325a907061c22ecd6768cf7b Author: Simon Glass sjg@chromium.org Date: Sun Jul 19 13:55:58 2020 -0600
rockchip: Enable building a SPI ROM image on bob
Add a simple binman config and enable CONFIG_HAS_ROM so that U-Boot produces a ROM for bob.
Signed-off-by: Simon Glass sjg@chromium.org
arch/arm/dts/rk3399-gru-u-boot.dtsi | 4 ++++ arch/arm/dts/rk3399-gru.dtsi | 2 +- arch/arm/dts/rk3399-u-boot.dtsi | 27 +++++++++++++++++++++++++++ arch/arm/mach-rockchip/rk3399/Kconfig | 2 ++ 4 files changed, 34 insertions(+), 1 deletion(-)
Then I checked out HEAD of master branch, reverted that patch and SPI flash got detected properly.
Not looked yet on how it should be fixed.
FYI: SPI flash commands work for me on rk3399-gru-kevin after just adding the JEDEC ID things for its chip (with CONFIG_SF_DEFAULT_BUS=1) but I haven't tried loading environment from it yet (doing weird out-of-tree things to run U-Boot anyway).
rockchip: Enable building a SPI ROM image on bob Add a simple binman config and enable CONFIG_HAS_ROM so that U-Boot produces a ROM for bob. Signed-off-by: Simon Glass <sjg@chromium.org>
I suspect this change in that commit (rk3399-u-boot.dtsi):
/ { aliases { mmc0 = &sdhci; mmc1 = &sdmmc; pci0 = &pcie0;
spi1 = &spi1; };
Can you test adding spi0 = &spi0; above that in the list?
W dniu 05.11.2020 o 17:49, Alper Nebi Yasak pisze:
spi1 = &spi1; };
Helps ;D
=> sf probe SF: Detected gd25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
spi1 = &spi1; };
Helps ;D
I looked around a bit more and saw rk3399-<board>-u-boot.dtsi files (including rockpro64) defining a "spi0 = &spi1;" alias, so I guess what I suggested would be overridden by that and is actually a no-op?
Maybe two aliases pointing to the same bus is what's really causing the problem?
Something else you can test: - Remove the aliases block from rk3399-rockpro64-u-boot.dtsi - Add "spi[0-5] = &spi[0-5];" aliases to rk3399-u-boot.dtsi - Add CONFIG_SF_DEFAULT_BUS=1 to configs/rockpro64-rk3399_defconfig
I guess that's the proper solution if it works.
Alper Nebi Yasak alpernebiyasak@gmail.com writes:
This fixed for me the same issue on my Pinebook Pro, turning
Loading Environment from SPIFlash... Invalid bus 0 (err=-19) *** Warning - spi_flash_probe_bus_cs() failed, using default environment
into
Loading Environment from SPIFlash... SF: Detected gd25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
Patch attached, for clarity.
Alper Nebi Yasak
Marcin Juszkiewicz
Simon South
