[U-Boot] [PATCH v4 0/5] Devres (Managed Device Resource) for U-Boot
This is version 4 of Devres series.
Simon, Albert and I discussed whether we need (want) to get this framework in.
Looks like our agreement is that we can add Devres, but keeping it optional. The DM core part still sticks to the manual malloc() and free().
With CONFIG_DEVRES disabled, devres APIs fall back to normal memory allocators, so there is no overhead.
Masahiro Yamada (5): dm: add DM_FLAG_BOUND flag devres: introduce Devres (Managed Device Resource) framework devres: add devm_kmalloc() and friends (managed memory allocators) devres: make Devres optional with CONFIG_DEVRES devres: add debug command to dump device resources
drivers/core/Kconfig | 24 ++++ drivers/core/Makefile | 1 + drivers/core/device-remove.c | 8 ++ drivers/core/device.c | 7 ++ drivers/core/devres.c | 259 +++++++++++++++++++++++++++++++++++++++++ include/dm/device-internal.h | 32 +++++ include/dm/device.h | 269 +++++++++++++++++++++++++++++++++++++++++++ include/dm/util.h | 9 ++ test/dm/cmd_dm.c | 12 +- 9 files changed, 620 insertions(+), 1 deletion(-) create mode 100644 drivers/core/devres.c
Currently, we only have DM_FLAG_ACTIVATED to indicate the device status, but we still cannot know in which stage is in progress, binding or probing.
This commit introduces a new flag, DM_FLAG_BOUND, which is set when the device is really bound, and cleared when it is unbound.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Acked-by: Simon Glass sjg@chromium.org ---
Changes in v4: None Changes in v3: None Changes in v2: None
drivers/core/device-remove.c | 3 +++ drivers/core/device.c | 2 ++ include/dm/device.h | 3 +++ 3 files changed, 8 insertions(+)
diff --git a/drivers/core/device-remove.c b/drivers/core/device-remove.c index 6b87f86..45d6543 100644 --- a/drivers/core/device-remove.c +++ b/drivers/core/device-remove.c @@ -61,6 +61,9 @@ int device_unbind(struct udevice *dev) if (dev->flags & DM_FLAG_ACTIVATED) return -EINVAL;
+ if (!(dev->flags & DM_FLAG_BOUND)) + return -EINVAL; + drv = dev->driver; assert(drv);
diff --git a/drivers/core/device.c b/drivers/core/device.c index 51b1b44..0333889 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -132,6 +132,8 @@ int device_bind(struct udevice *parent, const struct driver *drv, dm_dbg("Bound device %s to %s\n", dev->name, parent->name); *devp = dev;
+ dev->flags |= DM_FLAG_BOUND; + return 0;
fail_child_post_bind: diff --git a/include/dm/device.h b/include/dm/device.h index 9fa0048..43004ac 100644 --- a/include/dm/device.h +++ b/include/dm/device.h @@ -36,6 +36,9 @@ struct driver_info; /* Allocate driver private data on a DMA boundary */ #define DM_FLAG_ALLOC_PRIV_DMA (1 << 5)
+/* Device is bound */ +#define DM_FLAG_BOUND (1 << 6) + /** * struct udevice - An instance of a driver *
On 25 July 2015 at 06:52, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Applied to u-boot-dm, thanks!
In U-Boot's driver model, memory is basically allocated and freed in the core framework. So, low level drivers generally only have to specify the size of needed memory with .priv_auto_alloc_size, .platdata_auto_alloc_size, etc. Nevertheless, some drivers still need to allocate/free memory on their own in case they cannot statically know the necessary memory size. So, I believe it is reasonable enough to port Devres into U-boot.
Devres, which originates in Linux, manages device resources for each device and automatically releases them on driver detach. With devres, device resources are guaranteed to be freed whether initialization fails half-way or the device gets detached.
The basic idea is totally the same to that of Linux, but I tweaked it a bit so that it fits in U-Boot's driver model.
In U-Boot, drivers are activated in two steps: binding and probing. Binding puts a driver and a device together. It is just data manipulation on the system memory, so nothing has happened on the hardware device at this moment. When the device is really used, it is probed. Probing initializes the real hardware device to make it really ready for use.
So, the resources acquired during the probing process must be freed when the device is removed. Likewise, what has been allocated in binding should be released when the device is unbound. The struct devres has a member "probe" to remember when the resource was allocated.
CONFIG_DEBUG_DEVRES is also supported for easier debugging. If enabled, debug messages are printed each time a resource is allocated/freed.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
Changes in v4: - Comment struct devres
Changes in v3: - Update git-description. Do not mention about the DM core part.
Changes in v2: - Add more APIs: _free, _find, _get, _remove, _destroy, _release - Move devres_release_probe() and devres_release_all() decrlarations to dm/device-internal.h - Move comments to headers
drivers/core/Kconfig | 10 +++ drivers/core/Makefile | 2 +- drivers/core/device-remove.c | 5 ++ drivers/core/device.c | 3 + drivers/core/devres.c | 196 +++++++++++++++++++++++++++++++++++++++++++ include/dm/device-internal.h | 19 +++++ include/dm/device.h | 140 +++++++++++++++++++++++++++++++ 7 files changed, 374 insertions(+), 1 deletion(-) create mode 100644 drivers/core/devres.c
diff --git a/drivers/core/Kconfig b/drivers/core/Kconfig index e40372d..6889025 100644 --- a/drivers/core/Kconfig +++ b/drivers/core/Kconfig @@ -59,3 +59,13 @@ config DM_SEQ_ALIAS Most boards will have a '/aliases' node containing the path to numbered devices (e.g. serial0 = &serial0). This feature can be disabled if it is not required, to save code space in SPL. + +config DEBUG_DEVRES + bool "Managed device resources verbose debug messages" + depends on DM + help + If this option is enabled, devres debug messages are printed. + Select this if you are having a problem with devres or want to + debug resource management for a managed device. + + If you are unsure about this, Say N here. diff --git a/drivers/core/Makefile b/drivers/core/Makefile index 5c2ead8..d2cf2ea 100644 --- a/drivers/core/Makefile +++ b/drivers/core/Makefile @@ -4,7 +4,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y += device.o lists.o root.o uclass.o util.o +obj-y += device.o lists.o root.o uclass.o util.o devres.o ifndef CONFIG_SPL_BUILD obj-$(CONFIG_OF_CONTROL) += simple-bus.o endif diff --git a/drivers/core/device-remove.c b/drivers/core/device-remove.c index 45d6543..bd6d406 100644 --- a/drivers/core/device-remove.c +++ b/drivers/core/device-remove.c @@ -95,6 +95,9 @@ int device_unbind(struct udevice *dev)
if (dev->parent) list_del(&dev->sibling_node); + + devres_release_all(dev); + free(dev);
return 0; @@ -128,6 +131,8 @@ void device_free(struct udevice *dev) dev->parent_priv = NULL; } } + + devres_release_probe(dev); }
int device_remove(struct udevice *dev) diff --git a/drivers/core/device.c b/drivers/core/device.c index 0333889..a2e384c 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -47,6 +47,7 @@ int device_bind(struct udevice *parent, const struct driver *drv, INIT_LIST_HEAD(&dev->sibling_node); INIT_LIST_HEAD(&dev->child_head); INIT_LIST_HEAD(&dev->uclass_node); + INIT_LIST_HEAD(&dev->devres_head); dev->platdata = platdata; dev->name = name; dev->of_offset = of_offset; @@ -170,6 +171,8 @@ fail_alloc2: dev->platdata = NULL; } fail_alloc1: + devres_release_all(dev); + free(dev);
return ret; diff --git a/drivers/core/devres.c b/drivers/core/devres.c new file mode 100644 index 0000000..49c270c --- /dev/null +++ b/drivers/core/devres.c @@ -0,0 +1,196 @@ +/* + * Copyright (C) 2015 Masahiro Yamada yamada.masahiro@socionext.com + * + * Based on the original work in Linux by + * Copyright (c) 2006 SUSE Linux Products GmbH + * Copyright (c) 2006 Tejun Heo teheo@suse.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <linux/compat.h> +#include <linux/kernel.h> +#include <linux/list.h> +#include <dm/device.h> + +/** + * struct devres - Bookkeeping info for managed device resource + * @entry: List to associate this structure with a device + * @release: Callback invoked when this resource is released + * @probe: Flag to show when this resource was allocated + (true = probe, false = bind) + * @name: Name of release function + * @size: Size of resource data + * @data: Resource data + */ +struct devres { + struct list_head entry; + dr_release_t release; + bool probe; +#ifdef CONFIG_DEBUG_DEVRES + const char *name; + size_t size; +#endif + unsigned long long data[]; +}; + +#ifdef CONFIG_DEBUG_DEVRES +static void set_node_dbginfo(struct devres *dr, const char *name, size_t size) +{ + dr->name = name; + dr->size = size; +} + +static void devres_log(struct udevice *dev, struct devres *dr, + const char *op) +{ + printf("%s: DEVRES %3s %p %s (%lu bytes)\n", + dev->name, op, dr, dr->name, (unsigned long)dr->size); +} +#else /* CONFIG_DEBUG_DEVRES */ +#define set_node_dbginfo(dr, n, s) do {} while (0) +#define devres_log(dev, dr, op) do {} while (0) +#endif + +#if CONFIG_DEBUG_DEVRES +void *__devres_alloc(dr_release_t release, size_t size, gfp_t gfp, + const char *name) +#else +void *_devres_alloc(dr_release_t release, size_t size, gfp_t gfp) +#endif +{ + size_t tot_size = sizeof(struct devres) + size; + struct devres *dr; + + dr = kmalloc(tot_size, gfp); + if (unlikely(!dr)) + return NULL; + + INIT_LIST_HEAD(&dr->entry); + dr->release = release; + set_node_dbginfo(dr, name, size); + + return dr->data; +} + +void devres_free(void *res) +{ + if (res) { + struct devres *dr = container_of(res, struct devres, data); + + BUG_ON(!list_empty(&dr->entry)); + kfree(dr); + } +} + +void devres_add(struct udevice *dev, void *res) +{ + struct devres *dr = container_of(res, struct devres, data); + + devres_log(dev, dr, "ADD"); + BUG_ON(!list_empty(&dr->entry)); + dr->probe = dev->flags & DM_FLAG_BOUND ? true : false; + list_add_tail(&dr->entry, &dev->devres_head); +} + +void *devres_find(struct udevice *dev, dr_release_t release, + dr_match_t match, void *match_data) +{ + struct devres *dr; + + list_for_each_entry_reverse(dr, &dev->devres_head, entry) { + if (dr->release != release) + continue; + if (match && !match(dev, dr->data, match_data)) + continue; + return dr->data; + } + + return NULL; +} + +void *devres_get(struct udevice *dev, void *new_res, + dr_match_t match, void *match_data) +{ + struct devres *new_dr = container_of(new_res, struct devres, data); + void *res; + + res = devres_find(dev, new_dr->release, match, match_data); + if (!res) { + devres_add(dev, new_res); + res = new_res; + new_res = NULL; + } + devres_free(new_res); + + return res; +} + +void *devres_remove(struct udevice *dev, dr_release_t release, + dr_match_t match, void *match_data) +{ + void *res; + + res = devres_find(dev, release, match, match_data); + if (res) { + struct devres *dr = container_of(res, struct devres, data); + + list_del_init(&dr->entry); + devres_log(dev, dr, "REM"); + } + + return res; +} + +int devres_destroy(struct udevice *dev, dr_release_t release, + dr_match_t match, void *match_data) +{ + void *res; + + res = devres_remove(dev, release, match, match_data); + if (unlikely(!res)) + return -ENOENT; + + devres_free(res); + return 0; +} + +int devres_release(struct udevice *dev, dr_release_t release, + dr_match_t match, void *match_data) +{ + void *res; + + res = devres_remove(dev, release, match, match_data); + if (unlikely(!res)) + return -ENOENT; + + (*release)(dev, res); + devres_free(res); + return 0; +} + +static void release_nodes(struct udevice *dev, struct list_head *head, + bool probe_only) +{ + struct devres *dr, *tmp; + + list_for_each_entry_safe_reverse(dr, tmp, head, entry) { + if (probe_only && !dr->probe) + break; + devres_log(dev, dr, "REL"); + dr->release(dev, dr->data); + list_del(&dr->entry); + kfree(dr); + } +} + +void devres_release_probe(struct udevice *dev) +{ + release_nodes(dev, &dev->devres_head, true); +} + +void devres_release_all(struct udevice *dev) +{ + release_nodes(dev, &dev->devres_head, false); +} diff --git a/include/dm/device-internal.h b/include/dm/device-internal.h index 402304f..ee3b00d 100644 --- a/include/dm/device-internal.h +++ b/include/dm/device-internal.h @@ -143,4 +143,23 @@ static inline void device_free(struct udevice *dev) {} #define DM_ROOT_NON_CONST (((gd_t *)gd)->dm_root) #define DM_UCLASS_ROOT_NON_CONST (((gd_t *)gd)->uclass_root)
+/* device resource management */ +/** + * devres_release_probe - Release managed resources allocated after probing + * @dev: Device to release resources for + * + * Release all resources allocated for @dev when it was probed or later. + * This function is called on driver removal. + */ +void devres_release_probe(struct udevice *dev); + +/** + * devres_release_all - Release all managed resources + * @dev: Device to release resources for + * + * Release all resources associated with @dev. This function is + * called on driver unbinding. + */ +void devres_release_all(struct udevice *dev); + #endif diff --git a/include/dm/device.h b/include/dm/device.h index 43004ac..b909b9a 100644 --- a/include/dm/device.h +++ b/include/dm/device.h @@ -96,6 +96,7 @@ struct udevice { uint32_t flags; int req_seq; int seq; + struct list_head devres_head; };
/* Maximum sequence number supported */ @@ -463,4 +464,143 @@ bool device_has_active_children(struct udevice *dev); */ bool device_is_last_sibling(struct udevice *dev);
+/* device resource management */ +typedef void (*dr_release_t)(struct udevice *dev, void *res); +typedef int (*dr_match_t)(struct udevice *dev, void *res, void *match_data); + +#ifdef CONFIG_DEBUG_DEVRES +void *__devres_alloc(dr_release_t release, size_t size, gfp_t gfp, + const char *name); +#define _devres_alloc(release, size, gfp) \ + __devres_alloc(release, size, gfp, #release) +#else +void *_devres_alloc(dr_release_t release, size_t size, gfp_t gfp); +#endif + +/** + * devres_alloc - Allocate device resource data + * @release: Release function devres will be associated with + * @size: Allocation size + * @gfp: Allocation flags + * + * Allocate devres of @size bytes. The allocated area is associated + * with @release. The returned pointer can be passed to + * other devres_*() functions. + * + * RETURNS: + * Pointer to allocated devres on success, NULL on failure. + */ +#define devres_alloc(release, size, gfp) \ + _devres_alloc(release, size, gfp | __GFP_ZERO) + +/** + * devres_free - Free device resource data + * @res: Pointer to devres data to free + * + * Free devres created with devres_alloc(). + */ +void devres_free(void *res); + +/** + * devres_add - Register device resource + * @dev: Device to add resource to + * @res: Resource to register + * + * Register devres @res to @dev. @res should have been allocated + * using devres_alloc(). On driver detach, the associated release + * function will be invoked and devres will be freed automatically. + */ +void devres_add(struct udevice *dev, void *res); + +/** + * devres_find - Find device resource + * @dev: Device to lookup resource from + * @release: Look for resources associated with this release function + * @match: Match function (optional) + * @match_data: Data for the match function + * + * Find the latest devres of @dev which is associated with @release + * and for which @match returns 1. If @match is NULL, it's considered + * to match all. + * + * RETURNS: + * Pointer to found devres, NULL if not found. + */ +void *devres_find(struct udevice *dev, dr_release_t release, + dr_match_t match, void *match_data); + +/** + * devres_get - Find devres, if non-existent, add one atomically + * @dev: Device to lookup or add devres for + * @new_res: Pointer to new initialized devres to add if not found + * @match: Match function (optional) + * @match_data: Data for the match function + * + * Find the latest devres of @dev which has the same release function + * as @new_res and for which @match return 1. If found, @new_res is + * freed; otherwise, @new_res is added atomically. + * + * RETURNS: + * Pointer to found or added devres. + */ +void *devres_get(struct udevice *dev, void *new_res, + dr_match_t match, void *match_data); + +/** + * devres_remove - Find a device resource and remove it + * @dev: Device to find resource from + * @release: Look for resources associated with this release function + * @match: Match function (optional) + * @match_data: Data for the match function + * + * Find the latest devres of @dev associated with @release and for + * which @match returns 1. If @match is NULL, it's considered to + * match all. If found, the resource is removed atomically and + * returned. + * + * RETURNS: + * Pointer to removed devres on success, NULL if not found. + */ +void *devres_remove(struct udevice *dev, dr_release_t release, + dr_match_t match, void *match_data); + +/** + * devres_destroy - Find a device resource and destroy it + * @dev: Device to find resource from + * @release: Look for resources associated with this release function + * @match: Match function (optional) + * @match_data: Data for the match function + * + * Find the latest devres of @dev associated with @release and for + * which @match returns 1. If @match is NULL, it's considered to + * match all. If found, the resource is removed atomically and freed. + * + * Note that the release function for the resource will not be called, + * only the devres-allocated data will be freed. The caller becomes + * responsible for freeing any other data. + * + * RETURNS: + * 0 if devres is found and freed, -ENOENT if not found. + */ +int devres_destroy(struct udevice *dev, dr_release_t release, + dr_match_t match, void *match_data); + +/** + * devres_release - Find a device resource and destroy it, calling release + * @dev: Device to find resource from + * @release: Look for resources associated with this release function + * @match: Match function (optional) + * @match_data: Data for the match function + * + * Find the latest devres of @dev associated with @release and for + * which @match returns 1. If @match is NULL, it's considered to + * match all. If found, the resource is removed atomically, the + * release function called and the resource freed. + * + * RETURNS: + * 0 if devres is found and freed, -ENOENT if not found. + */ +int devres_release(struct udevice *dev, dr_release_t release, + dr_match_t match, void *match_data); + #endif
Changes in v4:
Changes in v3:
Changes in v2:
Changes in v4:
Changes in v3:
Changes in v2:
devm_kmalloc() is identical to kmalloc() except that the memory allocated with it is managed and will be automatically released when the device is removed/unbound.
Likewise for the other variants.
Changes in v4: None Changes in v3: None Changes in v2: - Rip off "extern" from the func declarations - Add comments in headers - Add devm_kfree() - Do not force devm_kmalloc() zero-filling
drivers/core/devres.c | 34 ++++++++++++++++++++++++++++++++++ include/dm/device.h | 44 ++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 78 insertions(+)
diff --git a/drivers/core/devres.c b/drivers/core/devres.c index 49c270c..f235c1b 100644 --- a/drivers/core/devres.c +++ b/drivers/core/devres.c @@ -194,3 +194,37 @@ void devres_release_all(struct udevice *dev) { release_nodes(dev, &dev->devres_head, false); } + +/* + * Managed kmalloc/kfree + */ +static void devm_kmalloc_release(struct udevice *dev, void *res) +{ + /* noop */ +} + +static int devm_kmalloc_match(struct udevice *dev, void *res, void *data) +{ + return res == data; +} + +void *devm_kmalloc(struct udevice *dev, size_t size, gfp_t gfp) +{ + void *data; + + data = _devres_alloc(devm_kmalloc_release, size, gfp); + if (unlikely(!data)) + return NULL; + + devres_add(dev, data); + + return data; +} + +void devm_kfree(struct udevice *dev, void *p) +{ + int rc; + + rc = devres_destroy(dev, devm_kmalloc_release, devm_kmalloc_match, p); + WARN_ON(rc); +} diff --git a/include/dm/device.h b/include/dm/device.h index b909b9a..7fddacd 100644 --- a/include/dm/device.h +++ b/include/dm/device.h @@ -14,6 +14,8 @@ #include <dm/uclass-id.h> #include <fdtdec.h> #include <linker_lists.h> +#include <linux/compat.h> +#include <linux/kernel.h> #include <linux/list.h>
struct driver_info; @@ -603,4 +605,46 @@ int devres_destroy(struct udevice *dev, dr_release_t release, int devres_release(struct udevice *dev, dr_release_t release, dr_match_t match, void *match_data);
+/* managed devm_k.alloc/kfree for device drivers */ +/** + * devm_kmalloc - Resource-managed kmalloc + * @dev: Device to allocate memory for + * @size: Allocation size + * @gfp: Allocation gfp flags + * + * Managed kmalloc. Memory allocated with this function is + * automatically freed on driver detach. Like all other devres + * resources, guaranteed alignment is unsigned long long. + * + * RETURNS: + * Pointer to allocated memory on success, NULL on failure. + */ +void *devm_kmalloc(struct udevice *dev, size_t size, gfp_t gfp); +static inline void *devm_kzalloc(struct udevice *dev, size_t size, gfp_t gfp) +{ + return devm_kmalloc(dev, size, gfp | __GFP_ZERO); +} +static inline void *devm_kmalloc_array(struct udevice *dev, + size_t n, size_t size, gfp_t flags) +{ + if (size != 0 && n > SIZE_MAX / size) + return NULL; + return devm_kmalloc(dev, n * size, flags); +} +static inline void *devm_kcalloc(struct udevice *dev, + size_t n, size_t size, gfp_t flags) +{ + return devm_kmalloc_array(dev, n, size, flags | __GFP_ZERO); +} + +/** + * devm_kfree - Resource-managed kfree + * @dev: Device this memory belongs to + * @p: Memory to free + * + * Free memory allocated with devm_kmalloc(). + */ +void devm_kfree(struct udevice *dev, void *p); + + #endif
- Add devm_kfree()
Currently, Devres requires additional 16 byte for each allocation, which is not so insignificant in some cases.
Add CONFIG_DEVRES to make this framework optional. If the option is disabled, devres functions fall back to non-managed variants. For example, devres_alloc() to kzalloc(), devm_kmalloc() to kmalloc(), etc.
Because devres_head is also surrounded by an ifdef conditional, there is no memory overhead when CONFIG_DEVRES is disabled.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Suggested-by: Simon Glass sjg@chromium.org Acked-by: Simon Glass sjg@chromium.org ---
Changes in v4: - drop a comment that does not make sense
Changes in v3: - Introduce CONFIG_DEVRES - Surround devres_head member with ifdef CONFIG_DEVRES
Changes in v2: None
drivers/core/Kconfig | 15 +++++++- drivers/core/Makefile | 3 +- drivers/core/device.c | 2 ++ include/dm/device-internal.h | 13 +++++++ include/dm/device.h | 82 ++++++++++++++++++++++++++++++++++++++++++++ 5 files changed, 113 insertions(+), 2 deletions(-)
diff --git a/drivers/core/Kconfig b/drivers/core/Kconfig index 6889025..db2ec1c 100644 --- a/drivers/core/Kconfig +++ b/drivers/core/Kconfig @@ -60,9 +60,22 @@ config DM_SEQ_ALIAS numbered devices (e.g. serial0 = &serial0). This feature can be disabled if it is not required, to save code space in SPL.
+config DEVRES + bool "Managed device resources" + depends on DM + help + This option enables the Managed device resources core support. + Device resources managed by the devres framework are automatically + released whether initialization fails half-way or the device gets + detached. + + If this option is disabled, devres functions fall back to + non-managed variants. For example, devres_alloc() to kzalloc(), + devm_kmalloc() to kmalloc(), etc. + config DEBUG_DEVRES bool "Managed device resources verbose debug messages" - depends on DM + depends on DEVRES help If this option is enabled, devres debug messages are printed. Select this if you are having a problem with devres or want to diff --git a/drivers/core/Makefile b/drivers/core/Makefile index d2cf2ea..d3cd968 100644 --- a/drivers/core/Makefile +++ b/drivers/core/Makefile @@ -4,7 +4,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y += device.o lists.o root.o uclass.o util.o devres.o +obj-y += device.o lists.o root.o uclass.o util.o +obj-$(CONFIG_DEVRES) += devres.o ifndef CONFIG_SPL_BUILD obj-$(CONFIG_OF_CONTROL) += simple-bus.o endif diff --git a/drivers/core/device.c b/drivers/core/device.c index a2e384c..b479be7 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -47,7 +47,9 @@ int device_bind(struct udevice *parent, const struct driver *drv, INIT_LIST_HEAD(&dev->sibling_node); INIT_LIST_HEAD(&dev->child_head); INIT_LIST_HEAD(&dev->uclass_node); +#ifdef CONFIG_DEVRES INIT_LIST_HEAD(&dev->devres_head); +#endif dev->platdata = platdata; dev->name = name; dev->of_offset = of_offset; diff --git a/include/dm/device-internal.h b/include/dm/device-internal.h index ee3b00d..7da4216 100644 --- a/include/dm/device-internal.h +++ b/include/dm/device-internal.h @@ -144,6 +144,8 @@ static inline void device_free(struct udevice *dev) {} #define DM_UCLASS_ROOT_NON_CONST (((gd_t *)gd)->uclass_root)
/* device resource management */ +#ifdef CONFIG_DEVRES + /** * devres_release_probe - Release managed resources allocated after probing * @dev: Device to release resources for @@ -162,4 +164,15 @@ void devres_release_probe(struct udevice *dev); */ void devres_release_all(struct udevice *dev);
+#else /* ! CONFIG_DEVRES */ + +static inline void devres_release_probe(struct udevice *dev) +{ +} + +static inline void devres_release_all(struct udevice *dev) +{ +} + +#endif /* ! CONFIG_DEVRES */ #endif diff --git a/include/dm/device.h b/include/dm/device.h index 7fddacd..38e23f8 100644 --- a/include/dm/device.h +++ b/include/dm/device.h @@ -98,7 +98,9 @@ struct udevice { uint32_t flags; int req_seq; int seq; +#ifdef CONFIG_DEVRES struct list_head devres_head; +#endif };
/* Maximum sequence number supported */ @@ -470,6 +472,8 @@ bool device_is_last_sibling(struct udevice *dev); typedef void (*dr_release_t)(struct udevice *dev, void *res); typedef int (*dr_match_t)(struct udevice *dev, void *res, void *match_data);
+#ifdef CONFIG_DEVRES + #ifdef CONFIG_DEBUG_DEVRES void *__devres_alloc(dr_release_t release, size_t size, gfp_t gfp, const char *name); @@ -646,5 +650,83 @@ static inline void *devm_kcalloc(struct udevice *dev, */ void devm_kfree(struct udevice *dev, void *p);
+#else /* ! CONFIG_DEVRES */ + +static inline void *devres_alloc(dr_release_t release, size_t size, gfp_t gfp) +{ + return kzalloc(size, gfp); +} + +static inline void devres_free(void *res) +{ + kfree(res); +} + +static inline void devres_add(struct udevice *dev, void *res) +{ +} + +static inline void *devres_find(struct udevice *dev, dr_release_t release, + dr_match_t match, void *match_data) +{ + return NULL; +} + +static inline void *devres_get(struct udevice *dev, void *new_res, + dr_match_t match, void *match_data) +{ + return NULL; +} + +static inline void *devres_remove(struct udevice *dev, dr_release_t release, + dr_match_t match, void *match_data) +{ + return NULL; +} + +static inline int devres_destroy(struct udevice *dev, dr_release_t release, + dr_match_t match, void *match_data) +{ + return 0; +} + +static inline int devres_release(struct udevice *dev, dr_release_t release, + dr_match_t match, void *match_data) +{ + return 0; +} + +static inline void *devm_kmalloc(struct udevice *dev, size_t size, gfp_t gfp) +{ + return kmalloc(size, gfp); +} + +static inline void *devm_kzalloc(struct udevice *dev, size_t size, gfp_t gfp) +{ + return kzalloc(size, gfp); +} + +static inline void *devm_kmaloc_array(struct udevice *dev, + size_t n, size_t size, gfp_t flags) +{ + /* TODO: add kmalloc_array() to linux/compat.h */ + if (size != 0 && n > SIZE_MAX / size) + return NULL; + return kmalloc(n * size, flags); +} + +static inline void *devm_kcalloc(struct udevice *dev, + size_t n, size_t size, gfp_t flags) +{ + /* TODO: add kcalloc() to linux/compat.h */ + return kmalloc(n * size, flags | __GFP_ZERO); +} + +static inline void devm_kfree(struct udevice *dev, void *p) +{ + kfree(p); +} + +#endif /* ! CONFIG_DEVRES */
#endif
Changes in v4:
Changes in v3:
Changes in v2: None
This new command can dump all device resources associated to each device. The fields in every line shows: - The address of the resource - The size of the resource - The name of the release function - The stage in which the resource has been acquired (BIND/PROBE)
Currently, there is no driver using devres, but if such drivers are implemented, the output of this command should look like this:
=> dm devres - root_driver - soc - extbus - serial@54006800 bfb541e8 (8 byte) devm_kmalloc_release BIND bfb54440 (4 byte) devm_kmalloc_release PROBE bfb54460 (4 byte) devm_kmalloc_release PROBE - serial@54006900 bfb54270 (8 byte) devm_kmalloc_release BIND - gpio@55000000 - i2c@58780000 bfb5bce8 (12 byte) devm_kmalloc_release PROBE bfb5bd10 (4 byte) devm_kmalloc_release PROBE - eeprom bfb54418 (12 byte) devm_kmalloc_release BIND
Changes in v4: - Drop "0x" from the devres address in the dump commend - Change the command name "devres" to "dm devres" - Update git-description.
Changes in v3: None Changes in v2: - add static to dump_resources()
drivers/core/Kconfig | 3 ++- drivers/core/devres.c | 29 +++++++++++++++++++++++++++++ include/dm/util.h | 9 +++++++++ test/dm/cmd_dm.c | 12 +++++++++++- 4 files changed, 51 insertions(+), 2 deletions(-)
diff --git a/drivers/core/Kconfig b/drivers/core/Kconfig index db2ec1c..c153b3f 100644 --- a/drivers/core/Kconfig +++ b/drivers/core/Kconfig @@ -74,10 +74,11 @@ config DEVRES devm_kmalloc() to kmalloc(), etc.
config DEBUG_DEVRES - bool "Managed device resources verbose debug messages" + bool "Managed device resources debugging functions" depends on DEVRES help If this option is enabled, devres debug messages are printed. + Also, a function is available to dump a list of device resources. Select this if you are having a problem with devres or want to debug resource management for a managed device.
diff --git a/drivers/core/devres.c b/drivers/core/devres.c index f235c1b..605295b 100644 --- a/drivers/core/devres.c +++ b/drivers/core/devres.c @@ -13,6 +13,8 @@ #include <linux/kernel.h> #include <linux/list.h> #include <dm/device.h> +#include <dm/root.h> +#include <dm/util.h>
/** * struct devres - Bookkeeping info for managed device resource @@ -195,6 +197,33 @@ void devres_release_all(struct udevice *dev) release_nodes(dev, &dev->devres_head, false); }
+#ifdef CONFIG_DEBUG_DEVRES +static void dump_resources(struct udevice *dev, int depth) +{ + struct devres *dr; + struct udevice *child; + + printf("- %s\n", dev->name); + + list_for_each_entry(dr, &dev->devres_head, entry) + printf(" %p (%lu byte) %s %s\n", dr, + (unsigned long)dr->size, dr->name, + dr->probe ? "PROBE" : "BIND"); + + list_for_each_entry(child, &dev->child_head, sibling_node) + dump_resources(child, depth + 1); +} + +void dm_dump_devres(void) +{ + struct udevice *root; + + root = dm_root(); + if (root) + dump_resources(root, 0); +} +#endif + /* * Managed kmalloc/kfree */ diff --git a/include/dm/util.h b/include/dm/util.h index 7dbed67..15daa3d 100644 --- a/include/dm/util.h +++ b/include/dm/util.h @@ -39,4 +39,13 @@ void dm_dump_all(void); /* Dump out a list of uclasses and their devices */ void dm_dump_uclass(void);
+#ifdef CONFIG_DEBUG_DEVRES +/* Dump out a list of device resources */ +void dm_dump_devres(void); +#else +static inline void dm_dump_devres(void) +{ +} +#endif + #endif diff --git a/test/dm/cmd_dm.c b/test/dm/cmd_dm.c index 5c501ec..caff49a 100644 --- a/test/dm/cmd_dm.c +++ b/test/dm/cmd_dm.c @@ -32,9 +32,18 @@ static int do_dm_dump_uclass(cmd_tbl_t *cmdtp, int flag, int argc, return 0; }
+static int do_dm_dump_devres(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + dm_dump_devres(); + + return 0; +} + static cmd_tbl_t test_commands[] = { U_BOOT_CMD_MKENT(tree, 0, 1, do_dm_dump_all, "", ""), U_BOOT_CMD_MKENT(uclass, 1, 1, do_dm_dump_uclass, "", ""), + U_BOOT_CMD_MKENT(devres, 1, 1, do_dm_dump_devres, "", ""), };
static int do_dm(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) @@ -60,5 +69,6 @@ U_BOOT_CMD( dm, 3, 1, do_dm, "Driver model low level access", "tree Dump driver model tree ('*' = activated)\n" - "dm uclass Dump list of instances for each uclass" + "dm uclass Dump list of instances for each uclass\n" + "dm devres Dump list of device resources for each device" );
=> dm devres
- root_driver
- soc
- extbus
- gpio@55000000
Changes in v4:
=> dm devres
- root_driver
- soc
- extbus
- gpio@55000000
Changes in v4:
Masahiro Yamada
