[U-Boot] [PATCH] ARC: HSDK: add tool and make target to generate bsp
HSDK board has preloader that reads SPI flash pages and searches special image header to fetch and load binary.
Add tool, make target (bsp-generate) to generate update script and u-boot binary image with header for preloader.
Also add script to default environment to apply updates.
Signed-off-by: Eugeniy Paltsev Eugeniy.Paltsev@synopsys.com --- board/synopsys/hsdk/config.mk | 11 +++ board/synopsys/hsdk/headerize-hsdk.py | 147 ++++++++++++++++++++++++++++++++++ include/configs/hsdk.h | 6 ++ 3 files changed, 164 insertions(+) create mode 100644 board/synopsys/hsdk/config.mk create mode 100644 board/synopsys/hsdk/headerize-hsdk.py
diff --git a/board/synopsys/hsdk/config.mk b/board/synopsys/hsdk/config.mk new file mode 100644 index 0000000000..7a0ed3ca36 --- /dev/null +++ b/board/synopsys/hsdk/config.mk @@ -0,0 +1,11 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2018 Synopsys, Inc. All rights reserved. + +bsp-generate: u-boot u-boot.bin + $(Q)python3 $(srctree)/board/$(BOARDDIR)/headerize-hsdk.py \ + --arc-id 0x52 --image $(srctree)/u-boot.bin \ + --elf $(srctree)/u-boot + $(Q)mkimage -T script -C none -n 'uboot update script' \ + -d $(srctree)/u-boot-update.txt \ + $(srctree)/u-boot-update.img &> /dev/null diff --git a/board/synopsys/hsdk/headerize-hsdk.py b/board/synopsys/hsdk/headerize-hsdk.py new file mode 100644 index 0000000000..97510474c4 --- /dev/null +++ b/board/synopsys/hsdk/headerize-hsdk.py @@ -0,0 +1,147 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2018 Synopsys, Inc. All rights reserved. +# Author: Eugeniy Paltsev Eugeniy.Paltsev@synopsys.com + +import os, getopt, sys, zlib +from elftools.elf.elffile import ELFFile + + +def usage(exit_code): + print("usage:") + print(sys.argv[0] + " --arc-id 0x52 --image u-boot.bin --elf u-boot") + sys.exit(exit_code) + + +def elf_get_entry(filename): + with open(filename, 'rb') as f: + elffile = ELFFile(f) + return elffile.header['e_entry'] + + +def calc_check_sum(filename): + # u-boot.head check_sum for preloader - it is sum of all u-boot binary bytes + with open(filename, "rb") as file: + ba = bytearray(file.read()) + return sum(ba) & 0xFF + + +def arg_verify(uboot_bin_filename, uboot_elf_filename, arc_id): + if arc_id not in [0x52, 0x53]: + print("unknown ARC ID: " + hex(arc_id)) + sys.exit(2) + + if not os.path.isfile(uboot_bin_filename): + print("uboot bin file not exists: " + uboot_bin_filename) + sys.exit(2) + + if not os.path.isfile(uboot_elf_filename): + print("uboot elf file not exists: " + uboot_elf_filename) + sys.exit(2) + + +def main(): + try: + opts, args = getopt.getopt(sys.argv[1:], + "ha:i:l:e:", ["help", "arc-id=", "image=", "elf="]) + except getopt.GetoptError as err: + print(err) + usage(2) + + # default filenames + uboot_elf_filename = "u-boot" + uboot_bin_filename = "u-boot.bin" + headerised_filename = "u-boot.head" + uboot_scrypt_file = "u-boot-update.txt" + + # initial header values + arc_id = 0x52 # 0x52 for first HSDK release + image_copy_adr = 0x81000000 # place where preloader will store u-boot binary + # initial constant header values, do not change these values + magic1 = 0xdeadbeafaf # big endian byte order + flash_address = 0x0 + flash_type = 0x0 # 0 - SPI flash, 1 - NOR flash + magic2 = [ # big endian byte order + 0x20202a2020202020202020202a20202020207c5c2e20202020202e2f7c20202020207c2d, + 0x2e5c2020202f2e2d7c20202020205c2020602d2d2d6020202f20202020202f205f202020, + 0x205f20205c20202020207c205f60712070205f207c2020202020272e5f3d2f205c3d5f2e, + 0x272020202020202020605c202f60202020202020202020202020206f2020202020202020] + + for opt, arg in opts: + if opt in ('-h', "--help"): usage(0) + if opt in ('-a', "--arc-id"): arc_id = int(arg, 16) + if opt in ('-i', "--image"): uboot_bin_filename = arg + if opt in ('-e', "--elf"): uboot_elf_filename = arg + + arg_verify(uboot_bin_filename, uboot_elf_filename, arc_id) + + uboot_img_size = os.path.getsize(uboot_bin_filename) + jump_address = elf_get_entry(uboot_elf_filename) + check_sum = calc_check_sum(uboot_bin_filename) + + # write header to file + with open(headerised_filename, "wb") as file: + file.write(arc_id.to_bytes(2, byteorder='little')) + file.write(uboot_img_size.to_bytes(4, byteorder='little')) + file.write(check_sum.to_bytes(1, byteorder='little')) + file.write(image_copy_adr.to_bytes(4, byteorder='little')) + file.write(magic1.to_bytes(5, byteorder='big')) + file.write(jump_address.to_bytes(4, byteorder='little')) + for i in range(12): file.write(0xFF.to_bytes(1, byteorder='little')) + for byte in magic2: file.write(byte.to_bytes(36, byteorder='big')) + for i in range(208 - len(magic2) * 36): + file.write(0xFF.to_bytes(1, byteorder='little')) + file.write(flash_address.to_bytes(4, byteorder='little')) + for i in range(11): file.write(0xFF.to_bytes(1, byteorder='little')) + file.write(flash_type.to_bytes(1, byteorder='little')) + + # append u-boot image to header + with open(headerised_filename, "ab") as fo: + with open(uboot_bin_filename,'rb') as fi: + fo.write(fi.read()) + + # calc u-boot headerized image CRC32 (will be used by uboot update + # command for check) + headerised_image_crc = "" + with open(headerised_filename, "rb") as fi: + headerised_image_crc = hex(zlib.crc32(fi.read()) & 0xffffffff) + + load_addr = 0x81000000 + crc_store_adr = load_addr - 0x8 + crc_calc_adr = crc_store_adr - 0x4 + load_size = os.path.getsize(headerised_filename) + crc_calc_cmd = \ + "crc32 " + hex(load_addr) + " " + hex(load_size) + " " + hex(crc_calc_adr) + crc_check_cmd = \ + "mw.l " + hex(crc_store_adr) + " " + headerised_image_crc + " && " + \ + crc_calc_cmd + " && " + \ + "cmp.l " + hex(crc_store_adr) + " " + hex(crc_calc_adr) + " 1" + + # make errase size to be allighned by 64K + if load_size & 0xFFFF == 0: + errase_size = load_size + else: + errase_size = load_size - (load_size & 0xFFFF) + 0x10000 + + # u-bood CMD to load u-bood with header to SPI flash + sf_load_image_cmd = \ + "fatload mmc 0:1 " + hex(load_addr) + " " + headerised_filename + " && " + \ + "sf probe 0:0 && " + \ + crc_check_cmd + " && " + \ + "sf protect unlock 0x0 " + hex(errase_size) + " && " + \ + "sf erase 0x0 " + hex(errase_size) + " && " + \ + "sf write " + hex(load_addr) + " 0x0 " + hex(load_size) + " && " + \ + "sf protect lock 0x0 " + hex(errase_size) + + update_uboot_cmd = sf_load_image_cmd + " && echo "u-boot update: OK"" + + with open(uboot_scrypt_file, "wb") as fo: + fo.write(update_uboot_cmd.encode('ascii')) + + +if __name__ == "__main__": + try: + main() + except Exception as err: + print(err) + sys.exit(2) diff --git a/include/configs/hsdk.h b/include/configs/hsdk.h index 3684f4d6d6..b561ae4e17 100644 --- a/include/configs/hsdk.h +++ b/include/configs/hsdk.h @@ -62,6 +62,12 @@ #define CONFIG_ENV_SIZE SZ_16K
#define CONFIG_EXTRA_ENV_SETTINGS \ + "upgrade=if mmc rescan && " \ + "fatload mmc 0:1 ${loadaddr} u-boot-update.img && " \ + "iminfo ${loadaddr} && source ${loadaddr}; then; else echo " \ + ""Fail to upgrade.\n" \ + "Do you have u-boot-update.img and u-boot.head on first (FAT) SD card partition?"" \ + "; fi\0" \ "core_dccm_0=0x10\0" \ "core_dccm_1=0x6\0" \ "core_dccm_2=0x10\0" \
Eugeniy Paltsev
