[U-Boot] [PATCH] common: spl_fit: Allow firmware image if no loadables
If CONFIG_SPL_OS_BOOT and FIT_IMAGE_TINY are enabled, the os will not be set to anything and therefore will remain as IH_OS_INVALID. What's needed here is to have IH_OS_U_BOOT as default. And since using the mkimage oneline command (that is, no its file), the loadables can't be specified, so we allow firmware as a fallback.
Signed-off-by: Abel Vesa abel.vesa@nxp.com --- common/spl/spl_fit.c | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index db43626..d5aa792 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -478,11 +478,14 @@ int spl_load_simple_fit(struct spl_image_info *spl_image,
/* Now check if there are more images for us to load */ for (; ; index++) { - uint8_t os_type = IH_OS_INVALID; + uint8_t os_type = IH_OS_U_BOOT;
node = spl_fit_get_image_node(fit, images, "loadables", index); if (node < 0) - break; + node = spl_fit_get_image_node(fit, images, + "firmware", index); + if (node < 0) + break;
ret = spl_load_fit_image(info, sector, fit, base_offset, node, &image_info);
Hi Abel,
This patch causes the following build warning:
CC spl/common/spl/spl_fit.o common/spl/spl_fit.c: In function ‘spl_load_simple_fit’: common/spl/spl_fit.c:484:3: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation] if (node < 0) ^~ common/spl/spl_fit.c:487:4: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’ if (node < 0) ^~
This fixes the boot on mx6sabresd. With the build warning fixed you can add:
Tested-by: Fabio Estevam festevam@gmail.com
Abel Vesa
Fabio Estevam
