[U-Boot] [PATCH] arm: ls102xa: fixed a bus frequency setting error
The bus frequency in SOC node should be clock frequency of platform. That is not true if it is devided by 2.
Signed-off-by: Tang Yuantian Yuantian.Tang@freescale.com --- arch/arm/cpu/armv7/ls102xa/fdt.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/ls102xa/fdt.c b/arch/arm/cpu/armv7/ls102xa/fdt.c index 4ce3808..989780d 100644 --- a/arch/arm/cpu/armv7/ls102xa/fdt.c +++ b/arch/arm/cpu/armv7/ls102xa/fdt.c @@ -91,7 +91,7 @@ void ft_cpu_setup(void *blob, bd_t *bd) }
do_fixup_by_prop_u32(blob, "device_type", "soc", - 4, "bus-frequency", busclk / 2, 1); + 4, "bus-frequency", busclk, 1);
ft_fixup_enet_phy_connect_type(blob);
Applied to u-boot-fsl-qoriq master, awaiting upstream.
York
York Sun
Yuantian.Tangļ¼ freescale.com
