[U-Boot] [PATCH] ARM: mvebu: db-88f6820-amc: enable SPI_FLASH_BAR
This board uses Micron N25Q256A SPI flash. Enable SPI_FLASH_BAR to allow us to access the whole chip.
Signed-off-by: Chris Packham judge.packham@gmail.com Cc: Vignesh R vigneshr@ti.com ---
configs/db-88f6820-amc_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/db-88f6820-amc_defconfig b/configs/db-88f6820-amc_defconfig index f5d35229d11c..319d9dbd9c3f 100644 --- a/configs/db-88f6820-amc_defconfig +++ b/configs/db-88f6820-amc_defconfig @@ -53,6 +53,7 @@ CONFIG_SYS_I2C_MVTWSI=y CONFIG_NAND=y CONFIG_NAND_PXA3XX=y CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHY_MARVELL=y
Could add imply SPI_FLASH_BAR to KIRKWOOD_SPI instead? So that we don't have to fix every defconfig that using kirkwood_spi.c.
Looks like kernel driver does support 3/4 byte addressing, but U-Boot version of the driver doesn't.
Hi Chris, Hi Vignesh,
Did you use BAR before the newly introduced SPI NOR restructuring? If not, then I would rather oppose to using it now, since option should only be used by those platforms that used it earlier as well. BAR mode is not supported by Linux and an U-Boot special.
Could you please double check, if and how addressing of the whole 32MiB was done before? And perhaps its possible to enhance the SPI driver to support 3 and 4 byte addressing instead.
Thanks, Stefan
Hi Stefan,
configs/db-88f6820-amc_defconfig did use SPI_FLASH_BAR before SPI NOR re-work
It would be great if driver could be modified to support 3 and 4 byte addressing modes.
Hi Vignesh,
On 02.03.19 11:50, Vignesh Raghavendra wrote:
Hi Stefan,
I see. Thanks for checking.
I fail to see, what really is needed to make the SPI driver support 3 and 4 byte addressing modes. I recently added the MT7688 SPI driver (mt7621_spi.c) which supports 3 and 4 byte mode and I remember no driver specials that I needed to implement for this feature. Its address mode agnostic AFAICT and just xfers a buffer of data to and from the SPI device.
Could you please let me know, what exactly is missing for this 4 byte mode?
Thanks, Stefan
On 02-Mar-19 5:02 PM, Stefan Roese wrote: [...]
Certain SPI controllers have special HW support to support SPI flashes and therefore need knowledge of flash specific information such as opcode, no. of address bytes etc. More details in this blog[1] Such controllers should ideally use spi-mem interface like [2] I see this line in kirkwood_spi.c[3] which seems to hard code address bytes to 3? Can't really be sure w/o looking at the datasheet of SPI controllers.
[1] https://bootlin.com/blog/spi-mem-bringing-some-consistency-to-the-spi-memory... [2] https://patchwork.ozlabs.org/patch/1039718/ [3] https://elixir.bootlin.com/u-boot/latest/source/drivers/spi/kirkwood_spi.c#L...
Thanks, Stefan
I remember working on the Marvell SPI controller for Armada XP a few years ago. This 3BYTE mode is only for the special "direct mode", that is also supported by this controller. AFAIR, we don't use this direct mode in U-Boot at all. So setting this register to 3BYTE mode should be a "no-op" right now.
Thanks, Stefan
Thanks, Stefan
Applied to u-boot-marvell/master.
Thanks, Stefan
Chris Packham
Stefan Roese
Vignesh Raghavendra
