[U-Boot] [PATCH 4/5] odroid: clean up checkpatch issues
This patch will fix these checkpatch issues.
+static const char *mmc_regulators[] = {
CHECK: Blank lines aren't necessary before a close brace '}' + +}
Signed-off-by: Minkyu Kang mk7.kang@samsung.com --- board/samsung/odroid/odroid.c | 15 +++++++-------- 1 file changed, 7 insertions(+), 8 deletions(-)
diff --git a/board/samsung/odroid/odroid.c b/board/samsung/odroid/odroid.c index 32155f1..36d493d 100644 --- a/board/samsung/odroid/odroid.c +++ b/board/samsung/odroid/odroid.c @@ -33,13 +33,6 @@ enum { ODROID_TYPES, };
-static const char *mmc_regulators[] = { - "VDDQ_EMMC_1.8V", - "VDDQ_EMMC_2.8V", - "TFLASH_2.8V", - NULL, -}; - void set_board_type(void) { /* Set GPA1 pin 1 to HI - enable XCL205 output */ @@ -428,6 +421,13 @@ int exynos_init(void)
int exynos_power_init(void) { + const char *mmc_regulators[] = { + "VDDQ_EMMC_1.8V", + "VDDQ_EMMC_2.8V", + "TFLASH_2.8V", + NULL, + }; + if (regulator_list_autoset(mmc_regulators, NULL, true)) error("Unable to init all mmc regulators");
@@ -450,7 +450,6 @@ static int s5pc210_phy_control(int on) return regulator_set_mode(dev, OPMODE_ON); else return regulator_set_mode(dev, OPMODE_LPM); - }
struct s3c_plat_otg_data s5pc210_otg_data = {
applied to u-boot-samsung.
Thanks, Minkyu Kang.
Minkyu Kang
