[U-Boot] [PATCH 1/3] net: Implement random ethaddr fallback in eth.c
Implement the random ethaddr fallback in eth.c so it is in a common place and not reimplemented in each board or driver that wants this behavior.
Signed-off-by: Joe Hershberger joe.hershberger@ni.com --- To function properly in the driver-model case, this patch requires that https://patchwork.ozlabs.org/patch/467418/ be applied.
README | 3 ++- doc/README.enetaddr | 2 ++ net/Kconfig | 8 ++++++++ net/eth.c | 12 ++++++++++++ 4 files changed, 24 insertions(+), 1 deletion(-)
diff --git a/README b/README index ee65fdb..9e90c4b 100644 --- a/README +++ b/README @@ -5629,7 +5629,8 @@ o If both the SROM and the environment contain a MAC address, and the warning is printed.
o If neither SROM nor the environment contain a MAC address, an error - is raised. + is raised. If CONFIG_NET_RANDOM_ETHADDR is defined, then in this case + a random, locally-assigned MAC is used.
If Ethernet drivers implement the 'write_hwaddr' function, valid MAC addresses will be programmed into hardware as part of the initialization process. This diff --git a/doc/README.enetaddr b/doc/README.enetaddr index 0fafd2c..82c9cd5 100644 --- a/doc/README.enetaddr +++ b/doc/README.enetaddr @@ -37,6 +37,8 @@ Correct flow of setting up the MAC address (summarized): environment variable will be used unchanged. If the environment variable is not set, it will be initialized from eth_device->enetaddr, and a warning will be printed. + If both are invalid and CONFIG_NET_RANDOM_ETHADDR is defined, a random, + locally-assigned MAC is written to eth_device->enetaddr. 4. Program the address into hardware if the following conditions are met: a) The relevant driver has a 'write_addr' function b) The user hasn't set an 'ethmacskip' environment variable diff --git a/net/Kconfig b/net/Kconfig index 22b9eaa..a2bd4fe 100644 --- a/net/Kconfig +++ b/net/Kconfig @@ -7,4 +7,12 @@ menuconfig NET
if NET
+config NET_RANDOM_ETHADDR + bool "Random ethaddr if unset" + help + Selecting this will allow the Ethernet interface to function + even when the ethaddr variable for that interface is unset. + A new MAC address will be generated on every boot and it will + not be added to the environment. + endif # if NET diff --git a/net/eth.c b/net/eth.c index 8e6acfe..c4e0878 100644 --- a/net/eth.c +++ b/net/eth.c @@ -529,9 +529,15 @@ static int eth_post_probe(struct udevice *dev) printf("\nWarning: %s using MAC address from ROM\n", dev->name); } else if (is_zero_ethaddr(pdata->enetaddr)) { +#ifdef CONFIG_NET_RANDOM_ETHADDR + net_random_ethaddr(pdata->enetaddr); + printf("\nWarning: %s (eth%d) using random MAC address - %pM\n", + dev->name, dev->seq, pdata->enetaddr); +#else printf("\nError: %s address not set.\n", dev->name); return -EINVAL; +#endif }
return 0; @@ -657,9 +663,15 @@ int eth_write_hwaddr(struct eth_device *dev, const char *base_name, printf("\nWarning: %s using MAC address from net device\n", dev->name); } else if (is_zero_ethaddr(dev->enetaddr)) { +#ifdef CONFIG_NET_RANDOM_ETHADDR + net_random_ethaddr(dev->enetaddr); + printf("\nWarning: %s (eth%d) using random MAC address - %pM\n", + dev->name, eth_number, dev->enetaddr); +#else printf("\nError: %s address not set.\n", dev->name); return -EINVAL; +#endif }
if (dev->write_hwaddr && !eth_mac_skip(eth_number)) {
We really don't want boards defining fixed MAC addresses in their config so we just remove the option to set it in a fixed way. If you must have a MAC address that was not provisioned, then use the random MAC address functionality.
README | 16 ++-------------- doc/README.enetaddr | 2 +- drivers/net/greth.c | 10 +++------- drivers/net/lan91c96.c | 7 ------- examples/standalone/README.smc91111_eeprom | 23 ----------------------- include/configs/M5208EVBE.h | 2 -- include/configs/M5235EVB.h | 2 -- include/configs/M5272C3.h | 2 -- include/configs/M5282EVB.h | 2 -- include/configs/M53017EVB.h | 3 --- include/configs/M5329EVB.h | 2 -- include/configs/M5373EVB.h | 2 -- include/configs/M54418TWR.h | 3 --- include/configs/M54451EVB.h | 2 -- include/configs/M54455EVB.h | 3 --- include/configs/M5475EVB.h | 5 ----- include/configs/M5485EVB.h | 3 --- include/configs/MPC8536DS.h | 4 ---- include/configs/MPC8540ADS.h | 5 +---- include/configs/MPC8541CDS.h | 3 --- include/configs/MPC8544DS.h | 2 -- include/configs/MPC8548CDS.h | 6 ------ include/configs/MPC8555CDS.h | 5 ----- include/configs/MPC8560ADS.h | 8 +------- include/configs/MPC8568MDS.h | 4 ---- include/configs/MPC8572DS.h | 6 ------ include/configs/MPC8610HPCD.h | 1 - include/configs/MPC8641HPCN.h | 10 +--------- include/configs/a4m072.h | 1 - include/configs/bct-brettl2.h | 2 -- include/configs/bf518f-ezbrd.h | 2 -- include/configs/bf526-ezbrd.h | 2 -- include/configs/bf527-ezkit.h | 2 -- include/configs/bf533-ezkit.h | 2 -- include/configs/bf533-stamp.h | 2 -- include/configs/bf537-minotaur.h | 2 -- include/configs/bf537-pnav.h | 2 -- include/configs/bf537-srv1.h | 2 -- include/configs/bf537-stamp.h | 2 -- include/configs/bf538f-ezkit.h | 2 -- include/configs/bf548-ezkit.h | 2 -- include/configs/bf561-acvilon.h | 3 --- include/configs/bf561-ezkit.h | 2 -- include/configs/blackstamp.h | 3 --- include/configs/blackvme.h | 3 --- include/configs/br4.h | 3 --- include/configs/cm-bf527.h | 2 -- include/configs/cm-bf533.h | 2 -- include/configs/cm-bf537e.h | 2 -- include/configs/cm-bf537u.h | 2 -- include/configs/cm-bf548.h | 2 -- include/configs/cm-bf561.h | 2 -- include/configs/cobra5272.h | 1 - include/configs/dbau1x00.h | 2 -- include/configs/ea20.h | 3 +-- include/configs/gr_cpci_ax2000.h | 1 - include/configs/gr_ep2s60.h | 10 ---------- include/configs/gr_xc3s_1500.h | 9 --------- include/configs/grsim.h | 11 ----------- include/configs/grsim_leon2.h | 11 ----------- include/configs/ibf-dsp561.h | 2 -- include/configs/inka4x0.h | 3 --- include/configs/microblaze-generic.h | 1 - include/configs/motionpro.h | 2 -- include/configs/omap3_cairo.h | 1 - include/configs/pb1x00.h | 2 -- include/configs/pr1.h | 2 -- include/configs/sbc405.h | 1 - include/configs/sbc8548.h | 4 ---- include/configs/sbc8641d.h | 10 +--------- include/configs/scb9328.h | 1 - include/configs/sequoia.h | 9 --------- include/configs/stxgp3.h | 6 +----- include/configs/stxssa.h | 6 +----- include/configs/tcm-bf518.h | 2 -- include/configs/tcm-bf537.h | 2 -- include/configs/uniphier.h | 1 - include/configs/v38b.h | 1 - include/configs/work_92105.h | 11 ----------- include/configs/xaeniax.h | 1 - include/configs/zeus.h | 2 -- include/env_default.h | 18 ------------------ 82 files changed, 13 insertions(+), 317 deletions(-)
diff --git a/README b/README index 9e90c4b..fccc394 100644 --- a/README +++ b/README @@ -2113,18 +2113,6 @@ CBFS (Coreboot Filesystem) support Some PHY like Intel LXT971A need extra delay after command issued before MII status register can be read
-- Ethernet address: - CONFIG_ETHADDR - CONFIG_ETH1ADDR - CONFIG_ETH2ADDR - CONFIG_ETH3ADDR - CONFIG_ETH4ADDR - CONFIG_ETH5ADDR - - Define a default value for Ethernet address to use - for the respective Ethernet interface, in case this - is not determined automatically. - - IP address: CONFIG_IPADDR
@@ -2879,8 +2867,8 @@ CBFS (Coreboot Filesystem) support completely disabled. Anybody can change or delete these parameters.
- Alternatively, if you #define _both_ CONFIG_ETHADDR - _and_ CONFIG_OVERWRITE_ETHADDR_ONCE, a default + Alternatively, if you define _both_ an ethaddr in the + default env _and_ CONFIG_OVERWRITE_ETHADDR_ONCE, a default Ethernet address is installed in the environment, which can be changed exactly ONCE by the user. [The serial# is unaffected by this, i. e. it remains diff --git a/doc/README.enetaddr b/doc/README.enetaddr index 82c9cd5..50e4899 100644 --- a/doc/README.enetaddr +++ b/doc/README.enetaddr @@ -15,7 +15,7 @@ Here are the places where MAC addresses might be stored: - board-specific location (eeprom, dedicated flash, ...) Note: only used when mandatory due to hardware design etc...
- - environment ("ethaddr", "eth1addr", ...) (see CONFIG_ETHADDR) + - environment ("ethaddr", "eth1addr", ...) Note: this is the preferred way to permanently store MAC addresses
- ethernet data (struct eth_device -> enetaddr) diff --git a/drivers/net/greth.c b/drivers/net/greth.c index a93b37a..9bc8a8d 100644 --- a/drivers/net/greth.c +++ b/drivers/net/greth.c @@ -12,6 +12,7 @@
#include <common.h> #include <command.h> +#include <errno.h> #include <net.h> #include <netdev.h> #include <malloc.h> @@ -653,13 +654,8 @@ int greth_initialize(bd_t * bis) } } } else { - /* HW Address not found in environment, Set default HW address */ - addr[0] = GRETH_HWADDR_0; /* MSB */ - addr[1] = GRETH_HWADDR_1; - addr[2] = GRETH_HWADDR_2; - addr[3] = GRETH_HWADDR_3; - addr[4] = GRETH_HWADDR_4; - addr[5] = GRETH_HWADDR_5; /* LSB */ + /* No ethaddr set */ + return -EINVAL; }
/* set and remember MAC address */ diff --git a/drivers/net/lan91c96.c b/drivers/net/lan91c96.c index 495c088..c4dd01e 100644 --- a/drivers/net/lan91c96.c +++ b/drivers/net/lan91c96.c @@ -725,12 +725,6 @@ static int smc_get_ethaddr(bd_t *bd, struct eth_device *dev)
static int get_rom_mac(struct eth_device *dev, unsigned char *v_rom_mac) { -#ifdef HARDCODE_MAC /* used for testing or to supress run time warnings */ - char hw_mac_addr[] = { 0x02, 0x80, 0xad, 0x20, 0x31, 0xb8 }; - - memcpy (v_rom_mac, hw_mac_addr, 6); - return (1); -#else int i; SMC_SELECT_BANK(dev, 1); for (i=0; i<6; i++) @@ -738,7 +732,6 @@ static int get_rom_mac(struct eth_device *dev, unsigned char *v_rom_mac) v_rom_mac[i] = SMC_inb(dev, LAN91C96_IA0 + i); } return (1); -#endif }
/* Structure to detect the device IDs */ diff --git a/examples/standalone/README.smc91111_eeprom b/examples/standalone/README.smc91111_eeprom index a2d52e7..f73a8d3 100644 --- a/examples/standalone/README.smc91111_eeprom +++ b/examples/standalone/README.smc91111_eeprom @@ -27,29 +27,6 @@ To find out who has a MAC address, or to purchase MAC addresses, goto the IEEE, at: http://standards.ieee.org/regauth/oui/index.shtml
-To change your MAC address, there can not be a MAC address predefined in -U-Boot. To ensure that this does not occur, check your -include/configs/<board_name>.h file, and check to see that the following -settings are _not_ or commented out there. - -#define HARDCODE_MAC 1 -#define CONFIG_ETHADDR 02:80:ad:20:31:b8 - -The purpose of HARDCODE_MAC is to hardcode the MAC address in software, -(not what we want), or to preset it to 02:80:ad:20:31:b8 (not what we -want either). - -You can check this in a running U-Boot, by doing a power cycle, then -before U-Boot tries to do any networking, running the 'printenv' command - - BOOT> printenv - - ethaddr=02:80:ad:20:31:b8 - -If you see the 'ethaddr' variable show up, like the above, you need to -recompile U-Boot, with the above settings commented out of the -include/configs/<board_name>.h file. - 2. Running the smc91111_eeprom program ---------------------------------------------------------------------
diff --git a/include/configs/M5208EVBE.h b/include/configs/M5208EVBE.h index 7eac03b..d0f4d75 100644 --- a/include/configs/M5208EVBE.h +++ b/include/configs/M5208EVBE.h @@ -74,12 +74,10 @@ #define CONFIG_UDP_CHECKSUM
#ifdef CONFIG_MCFFEC -# define CONFIG_ETHADDR 00:e0:0c:bc:e5:60 # define CONFIG_IPADDR 192.162.1.2 # define CONFIG_NETMASK 255.255.255.0 # define CONFIG_SERVERIP 192.162.1.1 # define CONFIG_GATEWAYIP 192.162.1.1 -# define CONFIG_OVERWRITE_ETHADDR_ONCE #endif /* CONFIG_MCFFEC */
#define CONFIG_HOSTNAME M5208EVBe diff --git a/include/configs/M5235EVB.h b/include/configs/M5235EVB.h index 4bba815..a766324 100644 --- a/include/configs/M5235EVB.h +++ b/include/configs/M5235EVB.h @@ -95,12 +95,10 @@ #define CONFIG_BOOTDELAY 1 /* autoboot after 5 seconds */ #define CONFIG_BOOTFILE "u-boot.bin" #ifdef CONFIG_MCFFEC -# define CONFIG_ETHADDR 00:e0:0c:bc:e5:60 # define CONFIG_IPADDR 192.162.1.2 # define CONFIG_NETMASK 255.255.255.0 # define CONFIG_SERVERIP 192.162.1.1 # define CONFIG_GATEWAYIP 192.162.1.1 -# define CONFIG_OVERWRITE_ETHADDR_ONCE #endif /* FEC_ENET */
#define CONFIG_HOSTNAME M5235EVB diff --git a/include/configs/M5272C3.h b/include/configs/M5272C3.h index 159d2f8..9946108 100644 --- a/include/configs/M5272C3.h +++ b/include/configs/M5272C3.h @@ -94,12 +94,10 @@ #endif
#define CONFIG_HOSTNAME M5272C3 diff --git a/include/configs/M5282EVB.h b/include/configs/M5282EVB.h index bc740ae..4d3390b 100644 --- a/include/configs/M5282EVB.h +++ b/include/configs/M5282EVB.h @@ -80,12 +80,10 @@
#define CONFIG_BOOTDELAY 5 #ifdef CONFIG_MCFFEC -# define CONFIG_ETHADDR 00:e0:0c:bc:e5:60 # define CONFIG_IPADDR 192.162.1.2 # define CONFIG_NETMASK 255.255.255.0 # define CONFIG_SERVERIP 192.162.1.1 # define CONFIG_GATEWAYIP 192.162.1.1 -# define CONFIG_OVERWRITE_ETHADDR_ONCE #endif /* CONFIG_MCFFEC */
#define CONFIG_HOSTNAME M5282EVB diff --git a/include/configs/M53017EVB.h b/include/configs/M53017EVB.h index 0829708..e2dd8e5 100644 --- a/include/configs/M53017EVB.h +++ b/include/configs/M53017EVB.h @@ -94,13 +94,10 @@ #define CONFIG_UDP_CHECKSUM
#ifdef CONFIG_MCFFEC -# define CONFIG_ETHADDR 00:e0:0c:bc:e5:60 -# define CONFIG_ETH1ADDR 00:e0:0c:bc:e5:61 # define CONFIG_IPADDR 192.162.1.2 # define CONFIG_NETMASK 255.255.255.0 # define CONFIG_SERVERIP 192.162.1.1 # define CONFIG_GATEWAYIP 192.162.1.1 -# define CONFIG_OVERWRITE_ETHADDR_ONCE #endif /* FEC_ENET */
#define CONFIG_HOSTNAME M53017 diff --git a/include/configs/M5329EVB.h b/include/configs/M5329EVB.h index a42b5f6..5a7597c 100644 --- a/include/configs/M5329EVB.h +++ b/include/configs/M5329EVB.h @@ -88,12 +88,10 @@ #define CONFIG_UDP_CHECKSUM
#define CONFIG_HOSTNAME M5329EVB diff --git a/include/configs/M5373EVB.h b/include/configs/M5373EVB.h index c142dfb..7550c57 100644 --- a/include/configs/M5373EVB.h +++ b/include/configs/M5373EVB.h @@ -88,12 +88,10 @@ #define CONFIG_UDP_CHECKSUM
#define CONFIG_HOSTNAME M5373EVB diff --git a/include/configs/M54418TWR.h b/include/configs/M54418TWR.h index 3a6e981..25b3cda 100644 --- a/include/configs/M54418TWR.h +++ b/include/configs/M54418TWR.h @@ -113,15 +113,12 @@ "::eth0:off:rw console=ttyS0,115200" #endif
-#define CONFIG_ETHADDR 00:e0:0c:bc:e5:60 -#define CONFIG_ETH1ADDR 00:e0:0c:bc:e5:61 #define CONFIG_ETHPRIME "FEC0" #define CONFIG_IPADDR 192.168.1.2 #define CONFIG_NETMASK 255.255.255.0 #define CONFIG_SERVERIP 192.168.1.1 #define CONFIG_GATEWAYIP 192.168.1.1
-#define CONFIG_OVERWRITE_ETHADDR_ONCE #define CONFIG_SYS_FEC_BUF_USE_SRAM /* If CONFIG_SYS_DISCOVER_PHY is not defined - hardcoded */ #ifndef CONFIG_SYS_DISCOVER_PHY diff --git a/include/configs/M54451EVB.h b/include/configs/M54451EVB.h index 1b3598a..f3cade3 100644 --- a/include/configs/M54451EVB.h +++ b/include/configs/M54451EVB.h @@ -77,13 +77,11 @@
# define CONFIG_BOOTDELAY 1 /* autoboot after 5 seconds */ # define CONFIG_BOOTARGS "root=/dev/mtdblock1 rw rootfstype=jffs2 ip=none mtdparts=physmap-flash.0:2M(kernel)ro,-(jffs2)" -# define CONFIG_ETHADDR 00:e0:0c:bc:e5:60 # define CONFIG_ETHPRIME "FEC0" # define CONFIG_IPADDR 192.162.1.2 # define CONFIG_NETMASK 255.255.255.0 # define CONFIG_SERVERIP 192.162.1.1 # define CONFIG_GATEWAYIP 192.162.1.1 -# define CONFIG_OVERWRITE_ETHADDR_ONCE
/* If CONFIG_SYS_DISCOVER_PHY is not defined - hardcoded */ # ifndef CONFIG_SYS_DISCOVER_PHY diff --git a/include/configs/M54455EVB.h b/include/configs/M54455EVB.h index 2288bff..b708001 100644 --- a/include/configs/M54455EVB.h +++ b/include/configs/M54455EVB.h @@ -83,14 +83,11 @@
# define CONFIG_BOOTDELAY 1 /* autoboot after 5 seconds */ # define CONFIG_BOOTARGS "root=/dev/mtdblock1 rw rootfstype=jffs2 ip=none mtdparts=physmap-flash.0:5M(kernel)ro,-(jffs2)" -# define CONFIG_ETHADDR 00:e0:0c:bc:e5:60 -# define CONFIG_ETH1ADDR 00:e0:0c:bc:e5:61 # define CONFIG_ETHPRIME "FEC0" # define CONFIG_IPADDR 192.162.1.2 # define CONFIG_NETMASK 255.255.255.0 # define CONFIG_SERVERIP 192.162.1.1 # define CONFIG_GATEWAYIP 192.162.1.1 -# define CONFIG_OVERWRITE_ETHADDR_ONCE
/* If CONFIG_SYS_DISCOVER_PHY is not defined - hardcoded */ # ifndef CONFIG_SYS_DISCOVER_PHY diff --git a/include/configs/M5475EVB.h b/include/configs/M5475EVB.h index 91d6a1a..658c170 100644 --- a/include/configs/M5475EVB.h +++ b/include/configs/M5475EVB.h @@ -75,13 +75,10 @@ # endif # endif /* CONFIG_SYS_DISCOVER_PHY */
#endif
@@ -135,12 +132,10 @@ #define CONFIG_UDP_CHECKSUM
#define CONFIG_HOSTNAME M547xEVB diff --git a/include/configs/M5485EVB.h b/include/configs/M5485EVB.h index ce9f3b0..efb64a1 100644 --- a/include/configs/M5485EVB.h +++ b/include/configs/M5485EVB.h @@ -75,13 +75,10 @@ # endif # endif /* CONFIG_SYS_DISCOVER_PHY */
#endif
diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index dc09b1f..d41eeb5 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -720,13 +720,9 @@ /* The mac addresses for all ethernet interface */ #if defined(CONFIG_TSEC_ENET) #define CONFIG_HAS_ETH0 -#define CONFIG_ETHADDR 00:E0:0C:02:00:FD #define CONFIG_HAS_ETH1 -#define CONFIG_ETH1ADDR 00:E0:0C:02:01:FD #define CONFIG_HAS_ETH2 -#define CONFIG_ETH2ADDR 00:E0:0C:02:02:FD #define CONFIG_HAS_ETH3 -#define CONFIG_ETH3ADDR 00:E0:0C:02:03:FD #endif
#define CONFIG_IPADDR 192.168.1.254 diff --git a/include/configs/MPC8540ADS.h b/include/configs/MPC8540ADS.h index 37c2b94..b388168 100644 --- a/include/configs/MPC8540ADS.h +++ b/include/configs/MPC8540ADS.h @@ -12,7 +12,7 @@ * Please refer to doc/README.mpc85xx for more info. * * Make sure you change the MAC address and other network params first, - * search for CONFIG_ETHADDR, CONFIG_SERVERIP, etc in this file. + * search for CONFIG_SERVERIP, etc in this file. */
#ifndef __CONFIG_H @@ -406,11 +406,8 @@ /* The mac addresses for all ethernet interface */ #if defined(CONFIG_TSEC_ENET) #define CONFIG_HAS_ETH0 -#define CONFIG_ETHADDR 00:E0:0C:00:00:FD #define CONFIG_HAS_ETH1 -#define CONFIG_ETH1ADDR 00:E0:0C:00:01:FD #define CONFIG_HAS_ETH2 -#define CONFIG_ETH2ADDR 00:E0:0C:00:02:FD #endif
#define CONFIG_IPADDR 192.168.1.253 diff --git a/include/configs/MPC8541CDS.h b/include/configs/MPC8541CDS.h index 5d229a0..609c5bb 100644 --- a/include/configs/MPC8541CDS.h +++ b/include/configs/MPC8541CDS.h @@ -418,11 +418,8 @@ extern unsigned long get_clock_freq(void); /* The mac addresses for all ethernet interface */ #if defined(CONFIG_TSEC_ENET) #define CONFIG_HAS_ETH0 -#define CONFIG_ETHADDR 00:E0:0C:00:00:FD #define CONFIG_HAS_ETH1 -#define CONFIG_ETH1ADDR 00:E0:0C:00:01:FD #define CONFIG_HAS_ETH2 -#define CONFIG_ETH2ADDR 00:E0:0C:00:02:FD #endif
#define CONFIG_IPADDR 192.168.1.253 diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index dade6d3..479589e 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -449,9 +449,7 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); /* The mac addresses for all ethernet interface */ #if defined(CONFIG_TSEC_ENET) #define CONFIG_HAS_ETH0 -#define CONFIG_ETHADDR 00:E0:0C:02:00:FD #define CONFIG_HAS_ETH1 -#define CONFIG_ETH1ADDR 00:E0:0C:02:01:FD #endif
#define CONFIG_IPADDR 192.168.1.251 diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index 190c668..fb28512 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -539,17 +539,11 @@ extern unsigned long get_clock_freq(void); /* * Environment Configuration */ - -/* The mac addresses for all ethernet interface */ #if defined(CONFIG_TSEC_ENET) #define CONFIG_HAS_ETH0 -#define CONFIG_ETHADDR 00:E0:0C:00:00:FD #define CONFIG_HAS_ETH1 -#define CONFIG_ETH1ADDR 00:E0:0C:00:01:FD #define CONFIG_HAS_ETH2 -#define CONFIG_ETH2ADDR 00:E0:0C:00:02:FD #define CONFIG_HAS_ETH3 -#define CONFIG_ETH3ADDR 00:E0:0C:00:03:FD #endif
#define CONFIG_IPADDR 192.168.1.253 diff --git a/include/configs/MPC8555CDS.h b/include/configs/MPC8555CDS.h index 5263ffc..48b55b5 100644 --- a/include/configs/MPC8555CDS.h +++ b/include/configs/MPC8555CDS.h @@ -412,15 +412,10 @@ extern unsigned long get_clock_freq(void); /* * Environment Configuration */ - -/* The mac addresses for all ethernet interface */ #if defined(CONFIG_TSEC_ENET) #define CONFIG_HAS_ETH0 -#define CONFIG_ETHADDR 00:E0:0C:00:00:FD #define CONFIG_HAS_ETH1 -#define CONFIG_ETH1ADDR 00:E0:0C:00:01:FD #define CONFIG_HAS_ETH2 -#define CONFIG_ETH2ADDR 00:E0:0C:00:02:FD #endif
#define CONFIG_IPADDR 192.168.1.253 diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h index ac78d48..92f0b7f 100644 --- a/include/configs/MPC8560ADS.h +++ b/include/configs/MPC8560ADS.h @@ -12,7 +12,7 @@ * Please refer to doc/README.mpc85xx for more info. * * Make sure you change the MAC address and other network params first, - * search for CONFIG_ETHADDR, CONFIG_SERVERIP, etc in this file. + * search for CONFIG_SERVERIP, etc. in this file. */
#ifndef __CONFIG_H @@ -443,17 +443,11 @@ /* * Environment Configuration */ - -/* The mac addresses for all ethernet interface */ #if defined(CONFIG_TSEC_ENET) || defined(CONFIG_ETHER_ON_FCC) #define CONFIG_HAS_ETH0 -#define CONFIG_ETHADDR 00:E0:0C:00:00:FD #define CONFIG_HAS_ETH1 -#define CONFIG_ETH1ADDR 00:E0:0C:00:01:FD #define CONFIG_HAS_ETH2 -#define CONFIG_ETH2ADDR 00:E0:0C:00:02:FD #define CONFIG_HAS_ETH3 -#define CONFIG_ETH3ADDR 00:E0:0C:00:03:FD #endif
#define CONFIG_IPADDR 192.168.1.253 diff --git a/include/configs/MPC8568MDS.h b/include/configs/MPC8568MDS.h index 02a5acf..57fc37b 100644 --- a/include/configs/MPC8568MDS.h +++ b/include/configs/MPC8568MDS.h @@ -438,13 +438,9 @@ extern unsigned long get_clock_freq(void); /* The mac addresses for all ethernet interface */ #if defined(CONFIG_TSEC_ENET) || defined(CONFIG_UEC_ETH) #define CONFIG_HAS_ETH0 -#define CONFIG_ETHADDR 00:E0:0C:00:00:FD #define CONFIG_HAS_ETH1 -#define CONFIG_ETH1ADDR 00:E0:0C:00:01:FD #define CONFIG_HAS_ETH2 -#define CONFIG_ETH2ADDR 00:E0:0C:00:02:FD #define CONFIG_HAS_ETH3 -#define CONFIG_ETH3ADDR 00:E0:0C:00:03:FD #endif
#define CONFIG_IPADDR 192.168.1.253 diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index 5e7bc49..7b3ddba 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -658,17 +658,11 @@ /* * Environment Configuration */ - -/* The mac addresses for all ethernet interface */ #if defined(CONFIG_TSEC_ENET) #define CONFIG_HAS_ETH0 -#define CONFIG_ETHADDR 00:E0:0C:02:00:FD #define CONFIG_HAS_ETH1 -#define CONFIG_ETH1ADDR 00:E0:0C:02:01:FD #define CONFIG_HAS_ETH2 -#define CONFIG_ETH2ADDR 00:E0:0C:02:02:FD #define CONFIG_HAS_ETH3 -#define CONFIG_ETH3ADDR 00:E0:0C:02:03:FD #endif
#define CONFIG_IPADDR 192.168.1.254 diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index e6d570a..cae133b 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -300,7 +300,6 @@
#define CONFIG_ULI526X #ifdef CONFIG_ULI526X -#define CONFIG_ETHADDR 00:E0:0C:00:00:01 #endif
/************************************************************ diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index 9f755e5..938874f 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -10,7 +10,7 @@ * MPC8641HPCN board configuration file * * Make sure you change the MAC address and other network params first, - * search for CONFIG_ETHADDR, CONFIG_SERVERIP, etc in this file. + * search for CONFIG_SERVERIP, etc. in this file. */
#ifndef __CONFIG_H @@ -679,14 +679,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); * Environment Configuration */
-/* The mac addresses for all ethernet interface */ -#if defined(CONFIG_TSEC_ENET) -#define CONFIG_ETHADDR 00:E0:0C:00:00:01 -#define CONFIG_ETH1ADDR 00:E0:0C:00:01:FD -#define CONFIG_ETH2ADDR 00:E0:0C:00:02:FD -#define CONFIG_ETH3ADDR 00:E0:0C:00:03:FD -#endif - #define CONFIG_HAS_ETH0 1 #define CONFIG_HAS_ETH1 1 #define CONFIG_HAS_ETH2 1 diff --git a/include/configs/a4m072.h b/include/configs/a4m072.h index 3c67655..00589b7 100644 --- a/include/configs/a4m072.h +++ b/include/configs/a4m072.h @@ -165,7 +165,6 @@ "setenv bootargs ${bootargs} no_ethaddr;" \ "fi\0" \ "hostname=CPUP0\0" \ - "ethaddr=00:00:00:00:00:00\0" \ "netdev=eth0\0" \ "bootcmd=run bootcmd_nor\0" \ "" diff --git a/include/configs/bct-brettl2.h b/include/configs/bct-brettl2.h index 2e0e922..0d9fe57 100644 --- a/include/configs/bct-brettl2.h +++ b/include/configs/bct-brettl2.h @@ -73,8 +73,6 @@ #define CONFIG_GATEWAYIP 192.168.233.1 #define CONFIG_SERVERIP 192.168.233.53 #define CONFIG_ROOTPATH "/romfs/brettl2" -/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 02:80:ad:20:31:e8 */ #define CONFIG_LIB_RAND #endif
diff --git a/include/configs/bf518f-ezbrd.h b/include/configs/bf518f-ezbrd.h index 50e85ca..dcd19e4 100644 --- a/include/configs/bf518f-ezbrd.h +++ b/include/configs/bf518f-ezbrd.h @@ -87,8 +87,6 @@ #endif #define CONFIG_HOSTNAME bf518f-ezbrd #define CONFIG_PHY_ADDR 3 -/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 02:80:ad:20:31:e8 */ #define CONFIG_LIB_RAND
/* diff --git a/include/configs/bf526-ezbrd.h b/include/configs/bf526-ezbrd.h index 7fc882a..ad5fa53 100644 --- a/include/configs/bf526-ezbrd.h +++ b/include/configs/bf526-ezbrd.h @@ -85,8 +85,6 @@ #define CONFIG_NETCONSOLE 1 #endif #define CONFIG_HOSTNAME bf526-ezbrd -/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 02:80:ad:20:31:e8 */ #define CONFIG_LIB_RAND
/* diff --git a/include/configs/bf527-ezkit.h b/include/configs/bf527-ezkit.h index 79e440a..b23a250 100644 --- a/include/configs/bf527-ezkit.h +++ b/include/configs/bf527-ezkit.h @@ -83,8 +83,6 @@ #define CONFIG_NETCONSOLE 1 #endif #define CONFIG_HOSTNAME bf527-ezkit -/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 02:80:ad:20:31:e8 */ #define CONFIG_LIB_RAND
/* diff --git a/include/configs/bf533-ezkit.h b/include/configs/bf533-ezkit.h index 0fda967..1b7290e 100644 --- a/include/configs/bf533-ezkit.h +++ b/include/configs/bf533-ezkit.h @@ -75,8 +75,6 @@ SSYNC(); \ } while (0) #define CONFIG_HOSTNAME bf533-ezkit -/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 02:80:ad:20:31:e8 */
/* diff --git a/include/configs/bf533-stamp.h b/include/configs/bf533-stamp.h index ae4d83a..322705d 100644 --- a/include/configs/bf533-stamp.h +++ b/include/configs/bf533-stamp.h @@ -68,8 +68,6 @@ SSYNC(); \ } while (0) #define CONFIG_HOSTNAME bf533-stamp -/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 02:80:ad:20:31:b8 */
/* I2C */ diff --git a/include/configs/bf537-minotaur.h b/include/configs/bf537-minotaur.h index 6df89af..6092f24 100644 --- a/include/configs/bf537-minotaur.h +++ b/include/configs/bf537-minotaur.h @@ -86,8 +86,6 @@
#define CONFIG_SYS_AUTOLOAD "no" #define CONFIG_ROOTPATH "/romfs" -/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 02:80:ad:20:31:42 */
diff --git a/include/configs/bf537-pnav.h b/include/configs/bf537-pnav.h index 4f2b2cb..e853b7d 100644 --- a/include/configs/bf537-pnav.h +++ b/include/configs/bf537-pnav.h @@ -65,8 +65,6 @@ #define CONFIG_RMII #endif #define CONFIG_HOSTNAME bf537-pnav -/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 02:80:ad:24:21:18 */ #define CONFIG_LIB_RAND
/* diff --git a/include/configs/bf537-srv1.h b/include/configs/bf537-srv1.h index d01d88f..ba2ea2a 100644 --- a/include/configs/bf537-srv1.h +++ b/include/configs/bf537-srv1.h @@ -86,8 +86,6 @@
#define CONFIG_SYS_AUTOLOAD "no" #define CONFIG_ROOTPATH "/romfs" -/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 02:80:ad:20:31:42 */ #define CONFIG_LIB_RAND
/* diff --git a/include/configs/bf537-stamp.h b/include/configs/bf537-stamp.h index 7b5a5a7..41f1b1f 100644 --- a/include/configs/bf537-stamp.h +++ b/include/configs/bf537-stamp.h @@ -65,8 +65,6 @@ #define CONFIG_NETCONSOLE 1 #endif #define CONFIG_HOSTNAME bf537-stamp -/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 02:80:ad:20:31:e8 */ #define CONFIG_LIB_RAND
/* diff --git a/include/configs/bf538f-ezkit.h b/include/configs/bf538f-ezkit.h index e60558e..3c82bf2 100644 --- a/include/configs/bf538f-ezkit.h +++ b/include/configs/bf538f-ezkit.h @@ -63,8 +63,6 @@ #define CONFIG_SMC91111 1 #define CONFIG_SMC91111_BASE 0x20310300 #define CONFIG_HOSTNAME bf538f-ezkit -/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 02:80:ad:20:31:e8 */
/* diff --git a/include/configs/bf548-ezkit.h b/include/configs/bf548-ezkit.h index e71e6d3..53f6558 100644 --- a/include/configs/bf548-ezkit.h +++ b/include/configs/bf548-ezkit.h @@ -73,8 +73,6 @@ #define CONFIG_SMC911X_BASE 0x24000000 #define CONFIG_SMC911X_16_BIT #define CONFIG_HOSTNAME bf548-ezkit -/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 02:80:ad:20:31:e8 */
/* diff --git a/include/configs/bf561-acvilon.h b/include/configs/bf561-acvilon.h index 6871d8c..03f3cec 100644 --- a/include/configs/bf561-acvilon.h +++ b/include/configs/bf561-acvilon.h @@ -92,9 +92,6 @@
#define CONFIG_HOSTNAME bf561-acvilon
-/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 02:80:ad:20:31:e8 */ -
/* * Flash Settings diff --git a/include/configs/bf561-ezkit.h b/include/configs/bf561-ezkit.h index fb6f948..efbc6c2 100644 --- a/include/configs/bf561-ezkit.h +++ b/include/configs/bf561-ezkit.h @@ -64,8 +64,6 @@ #define CONFIG_SMC91111_BASE 0x2C010300 #define CONFIG_SMC_USE_32_BIT 1 #define CONFIG_HOSTNAME bf561-ezkit -/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 02:80:ad:20:31:e8 */
/* diff --git a/include/configs/blackstamp.h b/include/configs/blackstamp.h index 7de4253..28bc653 100644 --- a/include/configs/blackstamp.h +++ b/include/configs/blackstamp.h @@ -76,9 +76,6 @@ #define CONFIG_HOSTNAME blackstamp #define CONFIG_ROOTPATH "/checkout/uClinux-dist/romfs" #define CONFIG_SYS_AUTOLOAD "no" - -/* To remove hardcoding and enable MAC storage in EEPROM */ -/* #define CONFIG_ETHADDR 02:80:ad:20:31:b8 */ #endif
#define CONFIG_ENV_IS_IN_SPI_FLASH diff --git a/include/configs/blackvme.h b/include/configs/blackvme.h index 6e5774c..27dccf6 100644 --- a/include/configs/blackvme.h +++ b/include/configs/blackvme.h @@ -85,9 +85,6 @@ #define CFG_AUTOLOAD "no" #define CONFIG_CMD_DHCP #define CONFIG_CMD_PING -#define CONFIG_ENV_OVERWRITE 1 /* enable changing MAC at runtime */ -/* Comment out hardcoded MAC to enable MAC storage in EEPROM */ -/* # define CONFIG_ETHADDR ff:ee:dd:cc:bb:aa */
/* * SDRAM settings & memory map diff --git a/include/configs/br4.h b/include/configs/br4.h index 48cf184..a44c18c 100644 --- a/include/configs/br4.h +++ b/include/configs/br4.h @@ -69,9 +69,6 @@ #endif #define CONFIG_HOSTNAME br4 #define CONFIG_TFTP_BLOCKSIZE 4404 -/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 5c:38:1a:80:a7:00 */ -
/* * Flash Settings diff --git a/include/configs/cm-bf527.h b/include/configs/cm-bf527.h index 643c837..387f1cb 100644 --- a/include/configs/cm-bf527.h +++ b/include/configs/cm-bf527.h @@ -83,8 +83,6 @@ #define CONFIG_NETCONSOLE 1 #endif #define CONFIG_HOSTNAME cm-bf527 -/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 02:80:ad:20:31:e8 */ #define CONFIG_LIB_RAND
/* diff --git a/include/configs/cm-bf533.h b/include/configs/cm-bf533.h index 485f01a..a464785 100644 --- a/include/configs/cm-bf533.h +++ b/include/configs/cm-bf533.h @@ -66,8 +66,6 @@ #define CONFIG_SMC91111 1 #define CONFIG_SMC91111_BASE 0x20200300 #define CONFIG_HOSTNAME cm-bf533 -/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 02:80:ad:20:31:e8 */
/* diff --git a/include/configs/cm-bf537e.h b/include/configs/cm-bf537e.h index e059568..95afd51 100644 --- a/include/configs/cm-bf537e.h +++ b/include/configs/cm-bf537e.h @@ -71,8 +71,6 @@ #define CONFIG_NETCONSOLE 1 #endif #define CONFIG_HOSTNAME cm-bf537e -/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 02:80:ad:20:31:e8 */ #define CONFIG_LIB_RAND
/* diff --git a/include/configs/cm-bf537u.h b/include/configs/cm-bf537u.h index 1f26457..4df4a05 100644 --- a/include/configs/cm-bf537u.h +++ b/include/configs/cm-bf537u.h @@ -69,8 +69,6 @@ #define CONFIG_NETCONSOLE 1 #endif #define CONFIG_HOSTNAME cm-bf537u -/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 02:80:ad:20:31:e8 */ #define CONFIG_LIB_RAND
/* diff --git a/include/configs/cm-bf548.h b/include/configs/cm-bf548.h index 72eafc5..cde23ad 100644 --- a/include/configs/cm-bf548.h +++ b/include/configs/cm-bf548.h @@ -76,8 +76,6 @@ #define CONFIG_SMC911X_BASE 0x24000000 #define CONFIG_SMC911X_16_BIT #define CONFIG_HOSTNAME cm-bf548 -/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 02:80:ad:24:31:91 */
/* diff --git a/include/configs/cm-bf561.h b/include/configs/cm-bf561.h index 96910a7..9d8a2c6 100644 --- a/include/configs/cm-bf561.h +++ b/include/configs/cm-bf561.h @@ -67,8 +67,6 @@ #define CONFIG_SMC911X_BASE 0x24008000 /* AMS1 */ #define CONFIG_SMC911X_16_BIT #define CONFIG_HOSTNAME cm-bf561 -/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 02:80:ad:20:31:cf */
/* diff --git a/include/configs/cobra5272.h b/include/configs/cobra5272.h index 38fcc40..11dd4d7 100644 --- a/include/configs/cobra5272.h +++ b/include/configs/cobra5272.h @@ -177,7 +177,6 @@ considered during boot */
/* User network settings */
-#define CONFIG_ETHADDR 00:00:00:00:00:09 /* default ethernet MAC addr. */ #define CONFIG_IPADDR 192.168.100.2 /* default board IP address */ #define CONFIG_SERVERIP 192.168.100.1 /* default tftp server IP address */
diff --git a/include/configs/dbau1x00.h b/include/configs/dbau1x00.h index 56317ef..70aa699 100644 --- a/include/configs/dbau1x00.h +++ b/include/configs/dbau1x00.h @@ -37,8 +37,6 @@ #endif #endif
-#define CONFIG_ETHADDR DE:AD:BE:EF:01:01 /* Ethernet address */ - #define CONFIG_BOOTDELAY 2 /* autoboot after 2 seconds */
#define CONFIG_BAUDRATE 115200 diff --git a/include/configs/ea20.h b/include/configs/ea20.h index ae89368..fc02b30 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -242,7 +242,6 @@ "rootpath=/opt/eldk/arm\0" \ "splashpos=230,180\0" \ "testrfspath=/opt/eldk/test_arm\0" \ - "tempmac=setenv ethaddr 02:ea:20:ff:ff:ff\0" \ "nandargs=setenv bootargs rootfstype=ubifs ro chk_data_crc " \ "ubi.mtd=${as} root=ubi0:rootfs\0" \ "nandrwargs=setenv bootargs rootfstype=ubifs rw chk_data_crc " \ @@ -315,6 +314,6 @@ "fi;" \ "else echo U-Boot not downloaded..exiting;fi\0" \ "ubootupd_nand=echo run load_magic,run load_nand,run upd;\0" \ - "bootcmd=run tempmac;run net_testrfs\0" + "bootcmd=run net_testrfs\0"
#endif /* __CONFIG_H */ diff --git a/include/configs/gr_cpci_ax2000.h b/include/configs/gr_cpci_ax2000.h index 854807d..5d28d8b 100644 --- a/include/configs/gr_cpci_ax2000.h +++ b/include/configs/gr_cpci_ax2000.h @@ -280,7 +280,6 @@ /*#define CONFIG_SHOW_ACTIVITY*/ #define CONFIG_NET_RETRY_COUNT 10 /* # of retries */
-#define CONFIG_ETHADDR 00:00:7a:cc:00:13 #define CONFIG_PHY_ADDR 0x00
/* diff --git a/include/configs/gr_ep2s60.h b/include/configs/gr_ep2s60.h index ed2dd2a..7c320ee 100644 --- a/include/configs/gr_ep2s60.h +++ b/include/configs/gr_ep2s60.h @@ -260,16 +260,6 @@ /* USE GRETH Ethernet Driver */ #define CONFIG_GRETH 1
-/* Default GRETH Ethernet HARDWARE address */ -#define GRETH_HWADDR_0 0x00 -#define GRETH_HWADDR_1 0x00 -#define GRETH_HWADDR_2 0x7a -#define GRETH_HWADDR_3 0xcc -#define GRETH_HWADDR_4 0x00 -#define GRETH_HWADDR_5 0x13 -#endif - -#define CONFIG_ETHADDR 00:00:7a:cc:00:13 #define CONFIG_PHY_ADDR 0x00
/* diff --git a/include/configs/gr_xc3s_1500.h b/include/configs/gr_xc3s_1500.h index e3cbb6f..fdd0aa5 100644 --- a/include/configs/gr_xc3s_1500.h +++ b/include/configs/gr_xc3s_1500.h @@ -220,15 +220,6 @@ */ #define CONFIG_GRETH 1
-/* Default GRETH Ethernet HARDWARE address */ -#define GRETH_HWADDR_0 0x00 -#define GRETH_HWADDR_1 0x00 -#define GRETH_HWADDR_2 0x7a -#define GRETH_HWADDR_3 0xcc -#define GRETH_HWADDR_4 0x00 -#define GRETH_HWADDR_5 0x12 - -#define CONFIG_ETHADDR 00:00:7a:cc:00:12 #define CONFIG_PHY_ADDR 0x00
/* diff --git a/include/configs/grsim.h b/include/configs/grsim.h index 1e089a9..21b4f5e 100644 --- a/include/configs/grsim.h +++ b/include/configs/grsim.h @@ -94,7 +94,6 @@ "rootpath=/export/roofs\0" \ "scratch=40000000\0" \ "getkernel=tftpboot $(scratch) $(bootfile)\0" \ - "ethaddr=00:00:7A:CC:00:12\0" \ "bootargs=console=ttyS0,38400" \ "" #define CONFIG_NETMASK 255.255.255.0 @@ -243,16 +242,6 @@ */ #define CONFIG_GRETH 1
-/* Default HARDWARE address */ -#define GRETH_HWADDR_0 0x00 -#define GRETH_HWADDR_1 0x00 -#define GRETH_HWADDR_2 0x7A -#define GRETH_HWADDR_3 0xcc -#define GRETH_HWADDR_4 0x00 -#define GRETH_HWADDR_5 0x12 - -#define CONFIG_ETHADDR 00:00:7a:cc:00:12 - /* * Define CONFIG_GRETH_10MBIT to force GRETH at 10Mb/s */ diff --git a/include/configs/grsim_leon2.h b/include/configs/grsim_leon2.h index 66194a8..f050754 100644 --- a/include/configs/grsim_leon2.h +++ b/include/configs/grsim_leon2.h @@ -91,7 +91,6 @@ "rootpath=/export/roofs\0" \ "scratch=40000000\0" \ "getkernel=tftpboot $(scratch) $(bootfile)\0" \ - "ethaddr=00:00:7A:CC:00:12\0" \ "bootargs=console=ttyS0,38400" \ "" #define CONFIG_NETMASK 255.255.255.0 @@ -241,16 +240,6 @@ */ /*#define CONFIG_GRETH 1*/
-/* Default HARDWARE address */ -#define GRETH_HWADDR_0 0x00 -#define GRETH_HWADDR_1 0x00 -#define GRETH_HWADDR_2 0x7A -#define GRETH_HWADDR_3 0xcc -#define GRETH_HWADDR_4 0x00 -#define GRETH_HWADDR_5 0x12 - -#define CONFIG_ETHADDR 00:00:7a:cc:00:12 - /* * Define CONFIG_GRETH_10MBIT to force GRETH at 10Mb/s */ diff --git a/include/configs/ibf-dsp561.h b/include/configs/ibf-dsp561.h index 2a937c6..4757929 100644 --- a/include/configs/ibf-dsp561.h +++ b/include/configs/ibf-dsp561.h @@ -64,8 +64,6 @@ #define CONFIG_DRIVER_AX88180 1 #define AX88180_BASE 0x2c000000 #define CONFIG_HOSTNAME ibf-dsp561 -/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 02:80:ad:20:31:e8 */
/* diff --git a/include/configs/inka4x0.h b/include/configs/inka4x0.h index f321975..9258734 100644 --- a/include/configs/inka4x0.h +++ b/include/configs/inka4x0.h @@ -110,9 +110,6 @@
#undef CONFIG_BOOTARGS
-#define CONFIG_ETHADDR 00:a0:a4:03:00:00 -#define CONFIG_OVERWRITE_ETHADDR_ONCE - #define CONFIG_IPADDR 192.168.100.2 #define CONFIG_SERVERIP 192.168.100.1 #define CONFIG_NETMASK 255.255.255.0 diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index 166ab4f..b84eead 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -350,7 +350,6 @@ #define CONFIG_IPADDR 192.168.0.3 #define CONFIG_SERVERIP 192.168.0.5 #define CONFIG_GATEWAYIP 192.168.0.1 -#define CONFIG_ETHADDR 00:E0:0C:00:00:FD
/* architecture dependent code */ #define CONFIG_SYS_USR_EXCEP /* user exception */ diff --git a/include/configs/motionpro.h b/include/configs/motionpro.h index e8b0593..4d648c8 100644 --- a/include/configs/motionpro.h +++ b/include/configs/motionpro.h @@ -85,8 +85,6 @@ #define CONFIG_SYS_HUSH_PARSER 1 /* use "hush" command parser */ #define CONFIG_SYS_PROMPT_HUSH_PS2 "> "
-#define CONFIG_ETHADDR 00:50:C2:40:10:00 -#define CONFIG_OVERWRITE_ETHADDR_ONCE 1 #define CONFIG_VERSION_VARIABLE 1 /* include version env variable */
/* diff --git a/include/configs/omap3_cairo.h b/include/configs/omap3_cairo.h index 3030054..2082679 100644 --- a/include/configs/omap3_cairo.h +++ b/include/configs/omap3_cairo.h @@ -90,7 +90,6 @@ "machid=ffffffff\0" \ "fdt_high=0x87000000\0" \ "baudrate=115200\0" \ - "ethaddr=00:50:C2:7E:90:F0\0" \ "fec_addr=00:50:C2:7E:90:F0\0" \ "netmask=255.255.255.0\0" \ "ipaddr=192.168.2.9\0" \ diff --git a/include/configs/pb1x00.h b/include/configs/pb1x00.h index a1926bb..2508702 100644 --- a/include/configs/pb1x00.h +++ b/include/configs/pb1x00.h @@ -31,8 +31,6 @@ #endif #endif
#define CONFIG_BAUDRATE 115200 diff --git a/include/configs/pr1.h b/include/configs/pr1.h index 13fb675..b9253b9 100644 --- a/include/configs/pr1.h +++ b/include/configs/pr1.h @@ -69,8 +69,6 @@ #endif #define CONFIG_HOSTNAME pr1 #define CONFIG_TFTP_BLOCKSIZE 4404 -/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 02:80:ad:20:31:e8 */
/* diff --git a/include/configs/sbc405.h b/include/configs/sbc405.h index 69dc210..11bf504 100644 --- a/include/configs/sbc405.h +++ b/include/configs/sbc405.h @@ -102,7 +102,6 @@
#define CONFIG_SDRAM_BANK0 1 /* init onboard SDRAM bank 0 */
-#define CONFIG_ETHADDR DE:AD:BE:EF:01:01 /* Ethernet address */ #define CONFIG_IPADDR 192.168.193.102 #define CONFIG_NETMASK 255.255.255.224 #define CONFIG_SERVERIP 192.168.193.119 diff --git a/include/configs/sbc8548.h b/include/configs/sbc8548.h index aee0d9e..5b373cb 100644 --- a/include/configs/sbc8548.h +++ b/include/configs/sbc8548.h @@ -581,13 +581,9 @@ /* * Environment Configuration */ - -/* The mac addresses for all ethernet interface */ #if defined(CONFIG_TSEC_ENET) #define CONFIG_HAS_ETH0 -#define CONFIG_ETHADDR 02:E0:0C:00:00:FD #define CONFIG_HAS_ETH1 -#define CONFIG_ETH1ADDR 02:E0:0C:00:01:FD #endif
#define CONFIG_IPADDR 192.168.0.55 diff --git a/include/configs/sbc8641d.h b/include/configs/sbc8641d.h index 8eb7276..021da50 100644 --- a/include/configs/sbc8641d.h +++ b/include/configs/sbc8641d.h @@ -14,7 +14,7 @@ * SBC8641D board configuration file * * Make sure you change the MAC address and other network params first, - * search for CONFIG_ETHADDR, CONFIG_SERVERIP, etc in this file. + * search for CONFIG_SERVERIP, etc in this file. */
#ifndef __CONFIG_H @@ -528,14 +528,6 @@ * Environment Configuration */
-/* The mac addresses for all ethernet interface */ -#if defined(CONFIG_TSEC_ENET) -#define CONFIG_ETHADDR 02:E0:0C:00:00:01 -#define CONFIG_ETH1ADDR 02:E0:0C:00:01:FD -#define CONFIG_ETH2ADDR 02:E0:0C:00:02:FD -#define CONFIG_ETH3ADDR 02:E0:0C:00:03:FD -#endif - #define CONFIG_HAS_ETH0 1 #define CONFIG_HAS_ETH1 1 #define CONFIG_HAS_ETH2 1 diff --git a/include/configs/scb9328.h b/include/configs/scb9328.h index f4a40bb..6cac99e 100644 --- a/include/configs/scb9328.h +++ b/include/configs/scb9328.h @@ -50,7 +50,6 @@ #define CONFIG_BOOTARGS "console=ttySMX0,115200n8 root=/dev/mtdblock3 rootfstype=jffs2 mtdparts=scb9328_flash:128k(U-boot)ro,128k(U-boot_env),1m(kernel),4m(root),4m(fs) eval_board=evk9328" #define CONFIG_BOOTCOMMAND "bootm 10040000" #define CONFIG_SHOW_BOOT_PROGRESS -#define CONFIG_ETHADDR 80:81:82:83:84:85 #define CONFIG_NETMASK 255.255.255.0 #define CONFIG_IPADDR 10.10.10.9 #define CONFIG_SERVERIP 10.10.10.10 diff --git a/include/configs/sequoia.h b/include/configs/sequoia.h index b6a5e6a..623be7d 100644 --- a/include/configs/sequoia.h +++ b/include/configs/sequoia.h @@ -100,15 +100,6 @@ #if defined(CONFIG_SYS_RAMBOOT) #define CONFIG_ENV_IS_NOWHERE /* Store env in memory only */ #define CONFIG_ENV_SIZE (8 << 10) -/* - * In RAM-booting version, we have no environment storage. So we need to - * provide at least preliminary MAC addresses for the 4xx EMAC driver to - * register the interfaces. Those two addresses are generated via the - * tools/gen_eth_addr tool and should only be used in a closed laboratory - * environment. - */ -#define CONFIG_ETHADDR 4a:56:49:22:3e:43 -#define CONFIG_ETH1ADDR 02:93:53:d5:06:98 #else #define CONFIG_ENV_IS_IN_FLASH /* use FLASH for environ vars */ #endif diff --git a/include/configs/stxgp3.h b/include/configs/stxgp3.h index 5fb40eb..a0817a0 100644 --- a/include/configs/stxgp3.h +++ b/include/configs/stxgp3.h @@ -13,7 +13,7 @@ /* mpc8560ads board configuration file */ /* please refer to doc/README.mpc85xx for more info */ /* make sure you change the MAC address and other network params first, - * search for CONFIG_ETHADDR,CONFIG_SERVERIP,etc in this file + * search for CONFIG_SERVERIP, etc. in this file */
#ifndef __CONFIG_H @@ -342,14 +342,10 @@ #define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ #endif
-/*Note: change below for your network setting!!! */ #if defined(CONFIG_TSEC_ENET) || defined(CONFIG_ETHER_ON_FCC) #define CONFIG_HAS_ETH0 -#define CONFIG_ETHADDR 00:e0:0c:07:9b:8a #define CONFIG_HAS_ETH1 -#define CONFIG_ETH1ADDR 00:e0:0c:07:9b:8b #define CONFIG_HAS_ETH2 -#define CONFIG_ETH2ADDR 00:e0:0c:07:9b:8c #endif
#define CONFIG_SERVERIP 192.168.85.1 diff --git a/include/configs/stxssa.h b/include/configs/stxssa.h index 914d821..78ac080 100644 --- a/include/configs/stxssa.h +++ b/include/configs/stxssa.h @@ -13,7 +13,7 @@ /* mpc8560ads board configuration file */ /* please refer to doc/README.mpc85xx for more info */ /* make sure you change the MAC address and other network params first, - * search for CONFIG_ETHADDR,CONFIG_SERVERIP,etc in this file + * search for CONFIG_SERVERIP, etc. in this file */
#ifndef __CONFIG_H @@ -377,14 +377,10 @@ #define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ #endif
/* diff --git a/include/configs/tcm-bf518.h b/include/configs/tcm-bf518.h index e96a742..d4c89b6 100644 --- a/include/configs/tcm-bf518.h +++ b/include/configs/tcm-bf518.h @@ -66,8 +66,6 @@ #define CONFIG_NETCONSOLE 1 #endif #define CONFIG_HOSTNAME tcm-bf518 -/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 02:80:ad:20:31:e8 */ #define CONFIG_LIB_RAND
/* diff --git a/include/configs/tcm-bf537.h b/include/configs/tcm-bf537.h index 42129fb..3326580 100644 --- a/include/configs/tcm-bf537.h +++ b/include/configs/tcm-bf537.h @@ -71,8 +71,6 @@ #define CONFIG_NETCONSOLE 1 #endif #define CONFIG_HOSTNAME tcm-bf537 -/* Uncomment next line to use fixed MAC address */ -/* #define CONFIG_ETHADDR 02:80:ad:20:31:e8 */ #define CONFIG_LIB_RAND
/* diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index d4688c5..331df62 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -209,7 +209,6 @@ /* * Network Configuration */ -#define CONFIG_ETHADDR 00:21:83:24:00:00 #define CONFIG_SERVERIP 192.168.11.1 #define CONFIG_IPADDR 192.168.11.10 #define CONFIG_GATEWAYIP 192.168.11.1 diff --git a/include/configs/v38b.h b/include/configs/v38b.h index 7f6b0c7..688d60e 100644 --- a/include/configs/v38b.h +++ b/include/configs/v38b.h @@ -148,7 +148,6 @@ "netmask=255.255.0.0\0" \ "ipaddr=192.168.160.18\0" \ "serverip=192.168.1.1\0" \ - "ethaddr=00:e0:ee:00:05:2e\0" \ "bootfile=/tftpboot/v38b/uImage\0" \ "u-boot=/tftpboot/v38b/u-boot.bin\0" \ "" diff --git a/include/configs/work_92105.h b/include/configs/work_92105.h index dc8e99f..4725fc3 100644 --- a/include/configs/work_92105.h +++ b/include/configs/work_92105.h @@ -177,17 +177,6 @@ #define CONFIG_ENV_ADDR 0x80000100
/* - * Provide default ethernet address - * - * THIS IS NORMALLY NOT DONE. HERE WE KEEP WHAT WAS IN THE PORTED - * BOARD CONFIG IN CASE SOME PROVISIONING PROCESS OUT THERE EXPECTS - * THIS MAC ADDRESS WHEN THE DEVICE HAS STILL ITS DEFAULT CONFIG. - */ - -#define CONFIG_ETHADDR 00:12:B4:00:AF:FE -#define CONFIG_OVERWRITE_ETHADDR_ONCE - -/* * U-Boot Commands */ #include <config_cmd_default.h> diff --git a/include/configs/xaeniax.h b/include/configs/xaeniax.h index 2999d1b..fcb76a2 100644 --- a/include/configs/xaeniax.h +++ b/include/configs/xaeniax.h @@ -70,7 +70,6 @@ #undef CONFIG_CMD_DTT
-#define CONFIG_ETHADDR 08:00:3e:26:0a:5b #define CONFIG_NETMASK 255.255.255.0 #define CONFIG_IPADDR 192.168.68.201 #define CONFIG_SERVERIP 192.168.68.62 diff --git a/include/configs/zeus.h b/include/configs/zeus.h index 4d7a7fc..9ac4a0f 100644 --- a/include/configs/zeus.h +++ b/include/configs/zeus.h @@ -296,8 +296,6 @@ #define CONFIG_IPADDR 192.168.1.10 #define CONFIG_SERVERIP 192.168.1.100 #define CONFIG_GATEWAYIP 192.168.1.100 -#define CONFIG_ETHADDR 50:00:00:00:06:00 -#define CONFIG_ETH1ADDR 50:00:00:00:06:01 #if 0 #define CONFIG_BOOTDELAY -1 /* autoboot disabled */ #else diff --git a/include/env_default.h b/include/env_default.h index 90431be..3096576 100644 --- a/include/env_default.h +++ b/include/env_default.h @@ -49,24 +49,6 @@ const uchar default_environment[] = { #ifdef CONFIG_LOADS_ECHO "loads_echo=" __stringify(CONFIG_LOADS_ECHO) "\0" #endif -#ifdef CONFIG_ETHADDR - "ethaddr=" __stringify(CONFIG_ETHADDR) "\0" -#endif -#ifdef CONFIG_ETH1ADDR - "eth1addr=" __stringify(CONFIG_ETH1ADDR) "\0" -#endif -#ifdef CONFIG_ETH2ADDR - "eth2addr=" __stringify(CONFIG_ETH2ADDR) "\0" -#endif -#ifdef CONFIG_ETH3ADDR - "eth3addr=" __stringify(CONFIG_ETH3ADDR) "\0" -#endif -#ifdef CONFIG_ETH4ADDR - "eth4addr=" __stringify(CONFIG_ETH4ADDR) "\0" -#endif -#ifdef CONFIG_ETH5ADDR - "eth5addr=" __stringify(CONFIG_ETH5ADDR) "\0" -#endif #ifdef CONFIG_ETHPRIME "ethprime=" CONFIG_ETHPRIME "\0" #endif
Bonjour Simon,
As much as I support the idea that one should not hard-code MAC addresses, I also support the idea that changes should not break previous behavior.
And regarding the WORK board which I submitted, its configuration header file had this address encoded in the in-house U-Boot which the customer was using before; removing this address might lead to the customer provisioning scripts failing.
Cordialement, Albert ARIBAUD 3ADEV
Hi Albert,
On 5 May 2015 at 01:17, Albert ARIBAUD albert.aribaud@3adev.fr wrote:
Bonjour Simon,
Shouldn't this be done with either MAC address or CONFIG_BOOTP_VCI_STRING or similar?
Hi Albert,
On Tue, May 5, 2015 at 2:17 AM, Albert ARIBAUD albert.aribaud@3adev.fr wrote:
Bonjour Simon,
What is broken?
Please give details about these scripts? Where are they in the source tree so I can make sure they still work?
Thanks, -Joe
On Tue, May 05, 2015 at 09:17:33AM +0200, Albert ARIBAUD wrote:
Bonjour Simon,
Wait, no. The policy for a long long time has been that you don't hard-code mac addresses into the environment, at least in mainline. "Factory" programming or provisioning or whatever it wants to be called always ends up needing to do something crazy. I'm all in favor of documenting best practices and maybe even non-default configurations that show how to do this, but the normal build for a given board needs to be otherwise sane.
On Mon, May 4, 2015 at 2:55 PM, Joe Hershberger joe.hershberger@ni.com wrote:
Applied to u-boot-net/next.
Remove the calls to net_random_ethaddr() that some boards and some drivers are calling. This is now implemented inside of net/eth.c
Enable the feature for all boards that previously enabled it.
Signed-off-by: Joe Hershberger joe.hershberger@ni.com --- There are a few seemingly unrelated changes to the defconfig files in this patch. These result from actually running savedefconfig to generate the defconfig instead of editing them manually.
board/bct-brettl2/bct-brettl2.c | 13 ------------ board/bf518f-ezbrd/bf518f-ezbrd.c | 28 ++++++------------------ board/bf526-ezbrd/bf526-ezbrd.c | 28 ++++++------------------ board/bf527-ezkit/bf527-ezkit.c | 9 +------- board/bf537-minotaur/bf537-minotaur.c | 18 ---------------- board/bf537-pnav/bf537-pnav.c | 18 ---------------- board/bf537-srv1/bf537-srv1.c | 19 ----------------- board/bf537-stamp/bf537-stamp.c | 28 ++++++------------------ board/buffalo/lsxl/lsxl.c | 10 --------- board/cm-bf527/cm-bf527.c | 11 +--------- board/cm-bf537e/cm-bf537e.c | 15 ------------- board/cm-bf537u/cm-bf537u.c | 15 ------------- board/dnp5370/dnp5370.c | 28 ++++++------------------ board/ip04/ip04.c | 12 ----------- board/tcm-bf518/tcm-bf518.c | 40 ----------------------------------- board/tcm-bf537/tcm-bf537.c | 15 ------------- configs/bct-brettl2_defconfig | 3 ++- configs/bf518f-ezbrd_defconfig | 2 ++ configs/bf526-ezbrd_defconfig | 2 ++ configs/bf527-ezkit_defconfig | 2 ++ configs/bf537-minotaur_defconfig | 2 ++ configs/bf537-pnav_defconfig | 2 ++ configs/bf537-srv1_defconfig | 2 ++ configs/bf537-stamp_defconfig | 2 ++ configs/cm-bf527_defconfig | 2 ++ configs/cm-bf537e_defconfig | 2 ++ configs/cm-bf537u_defconfig | 2 ++ configs/dnp5370_defconfig | 2 ++ configs/ip04_defconfig | 2 ++ configs/lschlv2_defconfig | 4 +++- configs/lsxhl_defconfig | 4 +++- configs/tcm-bf518_defconfig | 2 ++ configs/tcm-bf537_defconfig | 2 ++ drivers/net/dm9000x.c | 6 ------ drivers/net/ftmac110.c | 3 --- include/configs/lsxl.h | 1 - 36 files changed, 66 insertions(+), 290 deletions(-)
diff --git a/board/bct-brettl2/bct-brettl2.c b/board/bct-brettl2/bct-brettl2.c index 1f0dfb4..bf7cd62 100644 --- a/board/bct-brettl2/bct-brettl2.c +++ b/board/bct-brettl2/bct-brettl2.c @@ -29,13 +29,6 @@ int checkboard(void) }
#ifdef CONFIG_BFIN_MAC -static void board_init_enetaddr(uchar *mac_addr) -{ - puts("Warning: Generating 'random' MAC address\n"); - net_random_ethaddr(mac_addr); - eth_setenv_enetaddr("ethaddr", mac_addr); -} - int board_eth_init(bd_t *bis) { int retry = 3; @@ -107,12 +100,6 @@ static void turn_leds_off(void) /* miscellaneous platform dependent initialisations */ int misc_init_r(void) { -#ifdef CONFIG_BFIN_MAC - uchar enetaddr[6]; - if (!eth_getenv_enetaddr("ethaddr", enetaddr)) - board_init_enetaddr(enetaddr); -#endif - gpio_cfi_flash_init(); init_tlv320aic31(); init_mute_pin(); diff --git a/board/bf518f-ezbrd/bf518f-ezbrd.c b/board/bf518f-ezbrd/bf518f-ezbrd.c index 8ecfbb2..bf4a7db 100644 --- a/board/bf518f-ezbrd/bf518f-ezbrd.c +++ b/board/bf518f-ezbrd/bf518f-ezbrd.c @@ -29,28 +29,14 @@ int checkboard(void) #if defined(CONFIG_BFIN_MAC) static void board_init_enetaddr(uchar *mac_addr) { -#ifdef CONFIG_SYS_NO_FLASH -# define USE_MAC_IN_FLASH 0 -#else -# define USE_MAC_IN_FLASH 1 -#endif - bool valid_mac = false; - - if (USE_MAC_IN_FLASH) { - /* we cram the MAC in the last flash sector */ - uchar *board_mac_addr = (uchar *)0x203F0096; - if (is_valid_ethaddr(board_mac_addr)) { - memcpy(mac_addr, board_mac_addr, 6); - valid_mac = true; - } - } - - if (!valid_mac) { - puts("Warning: Generating 'random' MAC address\n"); - net_random_ethaddr(mac_addr); +#ifndef CONFIG_SYS_NO_FLASH + /* we cram the MAC in the last flash sector */ + uchar *board_mac_addr = (uchar *)0x203F0096; + if (is_valid_ethaddr(board_mac_addr)) { + memcpy(mac_addr, board_mac_addr, 6); + eth_setenv_enetaddr("ethaddr", mac_addr); } - - eth_setenv_enetaddr("ethaddr", mac_addr); +#endif }
/* Only the first run of boards had a KSZ switch */ diff --git a/board/bf526-ezbrd/bf526-ezbrd.c b/board/bf526-ezbrd/bf526-ezbrd.c index 0a88491..db1ee28 100644 --- a/board/bf526-ezbrd/bf526-ezbrd.c +++ b/board/bf526-ezbrd/bf526-ezbrd.c @@ -26,28 +26,14 @@ int checkboard(void) #ifdef CONFIG_BFIN_MAC static void board_init_enetaddr(uchar *mac_addr) { -#ifdef CONFIG_SYS_NO_FLASH -# define USE_MAC_IN_FLASH 0 -#else -# define USE_MAC_IN_FLASH 1 -#endif - bool valid_mac = false; - - if (USE_MAC_IN_FLASH) { - /* we cram the MAC in the last flash sector */ - uchar *board_mac_addr = (uchar *)0x203F0096; - if (is_valid_ethaddr(board_mac_addr)) { - memcpy(mac_addr, board_mac_addr, 6); - valid_mac = true; - } - } - - if (!valid_mac) { - puts("Warning: Generating 'random' MAC address\n"); - net_random_ethaddr(mac_addr); +#ifndef CONFIG_SYS_NO_FLASH + /* we cram the MAC in the last flash sector */ + uchar *board_mac_addr = (uchar *)0x203F0096; + if (is_valid_ethaddr(board_mac_addr)) { + memcpy(mac_addr, board_mac_addr, 6); + eth_setenv_enetaddr("ethaddr", mac_addr); } - - eth_setenv_enetaddr("ethaddr", mac_addr); +#endif }
int board_eth_init(bd_t *bis) diff --git a/board/bf527-ezkit/bf527-ezkit.c b/board/bf527-ezkit/bf527-ezkit.c index 257775f..d3e660d 100644 --- a/board/bf527-ezkit/bf527-ezkit.c +++ b/board/bf527-ezkit/bf527-ezkit.c @@ -41,15 +41,8 @@ static void board_init_enetaddr(uchar *mac_addr) mac_addr[ret] = otp_mac_p[5 - ret];
if (is_valid_ethaddr(mac_addr)) - valid_mac = true; + eth_setenv_enetaddr("ethaddr", mac_addr); } - - if (!valid_mac) { - puts("Warning: Generating 'random' MAC address\n"); - net_random_ethaddr(mac_addr); - } - - eth_setenv_enetaddr("ethaddr", mac_addr); }
int board_eth_init(bd_t *bis) diff --git a/board/bf537-minotaur/bf537-minotaur.c b/board/bf537-minotaur/bf537-minotaur.c index 71b4293..9312216 100644 --- a/board/bf537-minotaur/bf537-minotaur.c +++ b/board/bf537-minotaur/bf537-minotaur.c @@ -23,26 +23,8 @@ int checkboard(void) }
#ifdef CONFIG_BFIN_MAC -static void board_init_enetaddr(uchar *mac_addr) -{ - puts("Warning: Generating 'random' MAC address\n"); - net_random_ethaddr(mac_addr); - eth_setenv_enetaddr("ethaddr", mac_addr); -} - int board_eth_init(bd_t *bis) { return bfin_EMAC_initialize(bis); } #endif - -int misc_init_r(void) -{ -#ifdef CONFIG_BFIN_MAC - uchar enetaddr[6]; - if (!eth_getenv_enetaddr("ethaddr", enetaddr)) - board_init_enetaddr(enetaddr); -#endif - - return 0; -} diff --git a/board/bf537-pnav/bf537-pnav.c b/board/bf537-pnav/bf537-pnav.c index 93522df..6739fe1 100644 --- a/board/bf537-pnav/bf537-pnav.c +++ b/board/bf537-pnav/bf537-pnav.c @@ -23,26 +23,8 @@ int checkboard(void) }
#ifdef CONFIG_BFIN_MAC -static void board_init_enetaddr(uchar *mac_addr) -{ - puts("Warning: Generating 'random' MAC address\n"); - net_random_ethaddr(mac_addr); - eth_setenv_enetaddr("ethaddr", mac_addr); -} - int board_eth_init(bd_t *bis) { return bfin_EMAC_initialize(bis); } #endif - -int misc_init_r(void) -{ -#ifdef CONFIG_BFIN_MAC - uchar enetaddr[6]; - if (!eth_getenv_enetaddr("ethaddr", enetaddr)) - board_init_enetaddr(enetaddr); -#endif - - return 0; -} diff --git a/board/bf537-srv1/bf537-srv1.c b/board/bf537-srv1/bf537-srv1.c index 6581028..f0de7ff 100644 --- a/board/bf537-srv1/bf537-srv1.c +++ b/board/bf537-srv1/bf537-srv1.c @@ -22,27 +22,8 @@ int checkboard(void) return 0; }
-#ifdef CONFIG_BFIN_MAC -static void board_init_enetaddr(uchar *mac_addr) -{ - puts("Warning: Generating 'random' MAC address\n"); - net_random_ethaddr(mac_addr); - eth_setenv_enetaddr("ethaddr", mac_addr); -} - int board_eth_init(bd_t *bis) { return bfin_EMAC_initialize(bis); } #endif - -int misc_init_r(void) -{ -#ifdef CONFIG_BFIN_MAC - uchar enetaddr[6]; - if (!eth_getenv_enetaddr("ethaddr", enetaddr)) - board_init_enetaddr(enetaddr); -#endif - - return 0; -} diff --git a/board/bf537-stamp/bf537-stamp.c b/board/bf537-stamp/bf537-stamp.c index 66e5492..85d41d0 100644 --- a/board/bf537-stamp/bf537-stamp.c +++ b/board/bf537-stamp/bf537-stamp.c @@ -29,28 +29,14 @@ int checkboard(void) #ifdef CONFIG_BFIN_MAC static void board_init_enetaddr(uchar *mac_addr) { -#ifdef CONFIG_SYS_NO_FLASH -# define USE_MAC_IN_FLASH 0 -#else -# define USE_MAC_IN_FLASH 1 -#endif - bool valid_mac = false; - - if (USE_MAC_IN_FLASH) { - /* we cram the MAC in the last flash sector */ - uchar *board_mac_addr = (uchar *)0x203F0000; - if (is_valid_ethaddr(board_mac_addr)) { - memcpy(mac_addr, board_mac_addr, 6); - valid_mac = true; - } - } - - if (!valid_mac) { - puts("Warning: Generating 'random' MAC address\n"); - net_random_ethaddr(mac_addr); +#ifndef CONFIG_SYS_NO_FLASH + /* we cram the MAC in the last flash sector */ + uchar *board_mac_addr = (uchar *)0x203F0000; + if (is_valid_ethaddr(board_mac_addr)) { + memcpy(mac_addr, board_mac_addr, 6); + eth_setenv_enetaddr("ethaddr", mac_addr); } - - eth_setenv_enetaddr("ethaddr", mac_addr); +#endif }
int board_eth_init(bd_t *bis) diff --git a/board/buffalo/lsxl/lsxl.c b/board/buffalo/lsxl/lsxl.c index 487875c..45dd788 100644 --- a/board/buffalo/lsxl/lsxl.c +++ b/board/buffalo/lsxl/lsxl.c @@ -230,16 +230,6 @@ static void rescue_mode(void) uchar enetaddr[6];
printf("Entering rescue mode..\n"); -#ifdef CONFIG_RANDOM_MACADDR - if (!eth_getenv_enetaddr("ethaddr", enetaddr)) { - net_random_ethaddr(enetaddr); - if (eth_setenv_enetaddr("ethaddr", enetaddr)) { - printf("Failed to set ethernet address\n"); - set_led(LED_ALARM_BLINKING); - return; - } - } -#endif setenv("bootsource", "rescue"); }
diff --git a/board/cm-bf527/cm-bf527.c b/board/cm-bf527/cm-bf527.c index 2871fa2..3186c67 100644 --- a/board/cm-bf527/cm-bf527.c +++ b/board/cm-bf527/cm-bf527.c @@ -26,8 +26,6 @@ int checkboard(void) #ifdef CONFIG_BFIN_MAC static void board_init_enetaddr(uchar *mac_addr) { - bool valid_mac = false; - /* the MAC is stored in OTP memory page 0xDF */ uint32_t ret; uint64_t otp_mac; @@ -40,15 +38,8 @@ static void board_init_enetaddr(uchar *mac_addr) mac_addr[ret] = otp_mac_p[5 - ret];
if (is_valid_ethaddr(mac_addr)) - valid_mac = true; - } - - if (!valid_mac) { - puts("Warning: Generating 'random' MAC address\n"); - net_random_ethaddr(mac_addr); + eth_setenv_enetaddr("ethaddr", mac_addr); } - - eth_setenv_enetaddr("ethaddr", mac_addr); }
int board_eth_init(bd_t *bis) diff --git a/board/cm-bf537e/cm-bf537e.c b/board/cm-bf537e/cm-bf537e.c index 902611e..57c72a2 100644 --- a/board/cm-bf537e/cm-bf537e.c +++ b/board/cm-bf537e/cm-bf537e.c @@ -23,18 +23,6 @@ int checkboard(void) return 0; }
-static void board_init_enetaddr(char *var) -{ - uchar enetaddr[6]; - - if (eth_getenv_enetaddr(var, enetaddr)) - return; - - printf("Warning: %s: generating 'random' MAC address\n", var); - net_random_ethaddr(enetaddr); - eth_setenv_enetaddr(var, enetaddr); -} - #ifndef CONFIG_BFIN_MAC # define bfin_EMAC_initialize(x) 1 #endif @@ -50,9 +38,6 @@ int board_eth_init(bd_t *bis)
int misc_init_r(void) { - board_init_enetaddr("ethaddr"); - board_init_enetaddr("eth1addr"); - gpio_cfi_flash_init();
return 0; diff --git a/board/cm-bf537u/cm-bf537u.c b/board/cm-bf537u/cm-bf537u.c index 69bffd7..f365cdb 100644 --- a/board/cm-bf537u/cm-bf537u.c +++ b/board/cm-bf537u/cm-bf537u.c @@ -23,18 +23,6 @@ int checkboard(void) return 0; }
return 0; diff --git a/board/dnp5370/dnp5370.c b/board/dnp5370/dnp5370.c index 655fcac..ae9ba84 100644 --- a/board/dnp5370/dnp5370.c +++ b/board/dnp5370/dnp5370.c @@ -36,28 +36,14 @@ int checkboard(void) #ifdef CONFIG_BFIN_MAC static void board_init_enetaddr(uchar *mac_addr) { -#ifdef CONFIG_SYS_NO_FLASH -# define USE_MAC_IN_FLASH 0 -#else -# define USE_MAC_IN_FLASH 1 -#endif - bool valid_mac = false; - - if (USE_MAC_IN_FLASH) { - /* we cram the MAC in the last flash sector */ - uchar *board_mac_addr = (uchar *)0x202F0000; - if (is_valid_ethaddr(board_mac_addr)) { - memcpy(mac_addr, board_mac_addr, 6); - valid_mac = true; - } - } - - if (!valid_mac) { - puts("Warning: Generating 'random' MAC address\n"); - net_random_ethaddr(mac_addr); +#ifndef CONFIG_SYS_NO_FLASH + /* we cram the MAC in the last flash sector */ + uchar *board_mac_addr = (uchar *)0x202F0000; + if (is_valid_ethaddr(board_mac_addr)) { + memcpy(mac_addr, board_mac_addr, 6); + eth_setenv_enetaddr("ethaddr", mac_addr); } - - eth_setenv_enetaddr("ethaddr", mac_addr); +#endif }
int board_eth_init(bd_t *bis) diff --git a/board/ip04/ip04.c b/board/ip04/ip04.c index d20500f..70765bc 100644 --- a/board/ip04/ip04.c +++ b/board/ip04/ip04.c @@ -26,16 +26,4 @@ int board_eth_init(bd_t *bis) { return dm9000_initialize(bis); } - -int misc_init_r(void) -{ - uchar enetaddr[6]; - if (!eth_getenv_enetaddr("ethaddr", enetaddr)) { - puts("Warning: Generating 'random' MAC address\n"); - net_random_ethaddr(enetaddr); - eth_setenv_enetaddr("ethaddr", enetaddr); - } - - return 0; -} #endif diff --git a/board/tcm-bf518/tcm-bf518.c b/board/tcm-bf518/tcm-bf518.c index 3fa7d97..4348678 100644 --- a/board/tcm-bf518/tcm-bf518.c +++ b/board/tcm-bf518/tcm-bf518.c @@ -23,52 +23,12 @@ int checkboard(void) }
#if defined(CONFIG_BFIN_MAC) -static void board_init_enetaddr(uchar *mac_addr) -{ - bool valid_mac = false; - -#if 0 - /* the MAC is stored in OTP memory page 0xDF */ - uint32_t ret; - uint64_t otp_mac; - - ret = bfrom_OtpRead(0xDF, OTP_LOWER_HALF, &otp_mac); - if (!(ret & OTP_MASTER_ERROR)) { - uchar *otp_mac_p = (uchar *)&otp_mac; - - for (ret = 0; ret < 6; ++ret) - mac_addr[ret] = otp_mac_p[5 - ret]; - - if (is_valid_ethaddr(mac_addr)) - valid_mac = true; - } -#endif - - if (!valid_mac) { - puts("Warning: Generating 'random' MAC address\n"); - net_random_ethaddr(mac_addr); - } - - eth_setenv_enetaddr("ethaddr", mac_addr); -} - int board_eth_init(bd_t *bis) { return bfin_EMAC_initialize(bis); } #endif
-int misc_init_r(void) -{ -#ifdef CONFIG_BFIN_MAC - uchar enetaddr[6]; - if (!eth_getenv_enetaddr("ethaddr", enetaddr)) - board_init_enetaddr(enetaddr); -#endif - - return 0; -} - #ifdef CONFIG_BFIN_SDH int board_mmc_init(bd_t *bis) { diff --git a/board/tcm-bf537/tcm-bf537.c b/board/tcm-bf537/tcm-bf537.c index 2531a44..2cf70ca 100644 --- a/board/tcm-bf537/tcm-bf537.c +++ b/board/tcm-bf537/tcm-bf537.c @@ -23,18 +23,6 @@ int checkboard(void) return 0; }
return 0; diff --git a/configs/bct-brettl2_defconfig b/configs/bct-brettl2_defconfig index 26b145d..84eb1fe 100644 --- a/configs/bct-brettl2_defconfig +++ b/configs/bct-brettl2_defconfig @@ -1,3 +1,4 @@ CONFIG_BLACKFIN=y -CONFIG_TARGET_BCT_BRETTL2=y +CONFIG_NET=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/bf518f-ezbrd_defconfig b/configs/bf518f-ezbrd_defconfig index fb35ad0..cee1469 100644 --- a/configs/bf518f-ezbrd_defconfig +++ b/configs/bf518f-ezbrd_defconfig @@ -1,3 +1,5 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF518F_EZBRD=y +CONFIG_NET=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/bf526-ezbrd_defconfig b/configs/bf526-ezbrd_defconfig index da06d3a..d02751a 100644 --- a/configs/bf526-ezbrd_defconfig +++ b/configs/bf526-ezbrd_defconfig @@ -1,3 +1,5 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF526_EZBRD=y +CONFIG_NET=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/bf527-ezkit_defconfig b/configs/bf527-ezkit_defconfig index 69f6ef7..0e7e2d2 100644 --- a/configs/bf527-ezkit_defconfig +++ b/configs/bf527-ezkit_defconfig @@ -1,3 +1,5 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF527_EZKIT=y +CONFIG_NET=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/bf537-minotaur_defconfig b/configs/bf537-minotaur_defconfig index e76118f..7f38081 100644 --- a/configs/bf537-minotaur_defconfig +++ b/configs/bf537-minotaur_defconfig @@ -1,2 +1,4 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF537_MINOTAUR=y +CONFIG_NET=y +CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/bf537-pnav_defconfig b/configs/bf537-pnav_defconfig index ba5eaaa..76afb03 100644 --- a/configs/bf537-pnav_defconfig +++ b/configs/bf537-pnav_defconfig @@ -1,2 +1,4 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF537_PNAV=y +CONFIG_NET=y +CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/bf537-srv1_defconfig b/configs/bf537-srv1_defconfig index 61ac0e7..45bb79e 100644 --- a/configs/bf537-srv1_defconfig +++ b/configs/bf537-srv1_defconfig @@ -1,2 +1,4 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF537_SRV1=y +CONFIG_NET=y +CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/bf537-stamp_defconfig b/configs/bf537-stamp_defconfig index 9b9a92f..2e1da22 100644 --- a/configs/bf537-stamp_defconfig +++ b/configs/bf537-stamp_defconfig @@ -1,3 +1,5 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF537_STAMP=y +CONFIG_NET=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/cm-bf527_defconfig b/configs/cm-bf527_defconfig index a6830b5..92c0bc9 100644 --- a/configs/cm-bf527_defconfig +++ b/configs/cm-bf527_defconfig @@ -1,3 +1,5 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF527=y +CONFIG_NET=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/cm-bf537e_defconfig b/configs/cm-bf537e_defconfig index a44eab7..eaa2475 100644 --- a/configs/cm-bf537e_defconfig +++ b/configs/cm-bf537e_defconfig @@ -1,3 +1,5 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF537E=y +CONFIG_NET=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/cm-bf537u_defconfig b/configs/cm-bf537u_defconfig index 29c33b9..186ae51 100644 --- a/configs/cm-bf537u_defconfig +++ b/configs/cm-bf537u_defconfig @@ -1,3 +1,5 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF537U=y +CONFIG_NET=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/dnp5370_defconfig b/configs/dnp5370_defconfig index 0c00087..93e3eeb 100644 --- a/configs/dnp5370_defconfig +++ b/configs/dnp5370_defconfig @@ -1,2 +1,4 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_DNP5370=y +CONFIG_NET=y +CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/ip04_defconfig b/configs/ip04_defconfig index ba737ae..1afee74 100644 --- a/configs/ip04_defconfig +++ b/configs/ip04_defconfig @@ -1,3 +1,5 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_IP04=y +CONFIG_NET=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index 8c02fb3..31452a3 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -1,4 +1,6 @@ -CONFIG_SYS_EXTRA_OPTIONS="LSCHLV2" CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_LSXL=y +CONFIG_NET=y +CONFIG_SYS_EXTRA_OPTIONS="LSCHLV2" +CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index 86845d1..00f48bc 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -1,4 +1,6 @@ -CONFIG_SYS_EXTRA_OPTIONS="LSXHL" CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_LSXL=y +CONFIG_NET=y +CONFIG_SYS_EXTRA_OPTIONS="LSXHL" +CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/tcm-bf518_defconfig b/configs/tcm-bf518_defconfig index 0c9ae4d..2a3f9fa 100644 --- a/configs/tcm-bf518_defconfig +++ b/configs/tcm-bf518_defconfig @@ -1,3 +1,5 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_TCM_BF518=y +CONFIG_NET=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/tcm-bf537_defconfig b/configs/tcm-bf537_defconfig index 6d604b6..7ff0f9d 100644 --- a/configs/tcm-bf537_defconfig +++ b/configs/tcm-bf537_defconfig @@ -1,3 +1,5 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_TCM_BF537=y +CONFIG_NET=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/drivers/net/dm9000x.c b/drivers/net/dm9000x.c index ccd2131..3c41cec 100644 --- a/drivers/net/dm9000x.c +++ b/drivers/net/dm9000x.c @@ -343,13 +343,7 @@ static int dm9000_init(struct eth_device *dev, bd_t *bd)
printf("MAC: %pM\n", dev->enetaddr); if (!is_valid_ethaddr(dev->enetaddr)) { -#ifdef CONFIG_RANDOM_MACADDR - printf("Bad MAC address (uninitialized EEPROM?), randomizing\n"); - net_random_ethaddr(dev->enetaddr); - printf("MAC: %pM\n", dev->enetaddr); -#else printf("WARNING: Bad MAC address (uninitialized EEPROM?)\n"); -#endif }
/* fill device MAC address registers */ diff --git a/drivers/net/ftmac110.c b/drivers/net/ftmac110.c index 4bae9ad..4f17015 100644 --- a/drivers/net/ftmac110.c +++ b/drivers/net/ftmac110.c @@ -424,9 +424,6 @@ int ftmac110_initialize(bd_t *bis) dev->send = ftmac110_send; dev->recv = ftmac110_recv;
- if (!eth_getenv_enetaddr_by_index("eth", card_nr, dev->enetaddr)) - net_random_ethaddr(dev->enetaddr); - /* allocate tx descriptors (it must be 16 bytes aligned) */ chip->txd = dma_alloc_coherent( sizeof(struct ftmac110_desc) * CFG_TXDES_NUM, &chip->txd_dma); diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index c354c29..490f84e 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -37,7 +37,6 @@ #define CONFIG_MISC_INIT_R #define CONFIG_SHOW_BOOT_PROGRESS
-#define CONFIG_RANDOM_MACADDR #define CONFIG_LIB_RAND #define CONFIG_KIRKWOOD_GPIO #define CONFIG_OF_LIBFDT
Hi Joe,
Am 2015-05-04 21:55, schrieb Joe Hershberger:
return;
NAK.
You removed the "set_led(LED_ALARM_BLINKING)". (Mh, I've just discovered, that there is an indentation error). This is very important for this board, because there is no other feedback to the user than the LED. Remember, there is no serial console by default for this board. Please provide some kind of callback where you can move the sed_led() call to.
-michael
Hi Michael,
On Tue, May 5, 2015 at 3:25 AM, Michael Walle michael@walle.cc wrote:
Hi Joe,
return;
NAK.
The reason I removed it is because the only condition that was being checked for failure no longer happens at all. It only checked that the address could be written to the env. The policy is that the random address is not written to the env, but simply used for that boot. As such, there is nothing to fail.
Cheers, -Joe
Hi Joe,
Am 2015-05-05 19:36, schrieb Joe Hershberger:
Oh, sorry.
Yes this can then be removed. The check I had in mind was the one in check_enetaddr(). But i guess this will still work with the changes.
Again, sorry for the noise :(
Acked-By: Michael Walle michael@walle.cc (for the lsxl board part)
-michael
Implement the random ethaddr fallback in eth.c so it is in a common place and not reimplemented in each board or driver that wants this behavior.
To function properly in the driver-model case, this patch requires that https://patchwork.ozlabs.org/patch/467418/ be applied.
README | 3 ++- doc/README.enetaddr | 2 ++ net/Kconfig | 8 ++++++++ net/eth.c | 12 ++++++++++++ 4 files changed, 24 insertions(+), 1 deletion(-)
participants (6)
Albert ARIBAUD
Joe Hershberger
Joe Hershberger
Michael Walle
