[U-Boot] [Patch v3] armv8: fsl-layerscape: Set env_loc to ENVL_NOWHERE with CONFIG_ENV_IS_NOWHERE.
ENVL_NOWHERE is dependent on CONFIG_ENV_IS_NOWHERE and not on CONFIG_CHAIN_OF_TRUST so return ENVL_NOWHERE when CONFIG_ENV_IS_NOWHERE is enabled
Signed-off-by: Udit Agarwal udit.agarwal@nxp.com --- Changes in V3: Correct checkpatch warnings.
arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 11 ++--------- 1 file changed, 2 insertions(+), 9 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index 54ea6b3de0..d26305ce2f 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -799,12 +799,8 @@ enum env_location env_get_location(enum env_operation op, int prio) if (prio) return ENVL_UNKNOWN;
-#ifdef CONFIG_CHAIN_OF_TRUST - /* Check Boot Mode - * If Boot Mode is Secure, return ENVL_NOWHERE - */ - if (fsl_check_boot_mode_secure() == 1) - goto done; +#ifdef CONFIG_ENV_IS_NOWHERE + return env_loc; #endif
switch (src) { @@ -834,9 +830,6 @@ enum env_location env_get_location(enum env_operation op, int prio) break; }
-#ifdef CONFIG_CHAIN_OF_TRUST -done: -#endif return env_loc; } #endif /* CONFIG_TFABOOT */
-----Original Message----- From: Udit Agarwal Sent: Tuesday, April 23, 2019 11:36 AM To: u-boot@lists.denx.de Cc: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com; Udit Agarwal udit.agarwal@nxp.com Subject: [Patch v3] armv8: fsl-layerscape: Set env_loc to ENVL_NOWHERE with CONFIG_ENV_IS_NOWHERE.
This patch has been applied to fsl-qoriq master, awaiting upstream.
--pk
Prabhakar Kushwaha
Udit Agarwal
