[PATCH] mips: fix change_k0_cca()
The intention of change_k0_cca() is to read the C0.Config register into register $t0, update $t0 with the new cache coherency mode passed in $a0 and write back $t0 to C0.Config. With MIPS32 R2 or later instruction sets, this can be achieved with a single instruction with INS. The source and destination register of the INS instruction is passed as first parameter. In case of change_k0_cca() it is register $t0. But for writing back the updated value to C0.Config, the incorrect $a0 register is used. This is only correct in the MIPS32 R1 code path.
Fix the `mtc0` instruction to write back the value of the $t0 register. Fix the MIPS32 R1 code path to also store the updated value in $t0.
Reported by user ddqxy138 on Github. https://github.com/u-boot/u-boot/commit/b838586086af3278bcaead3720c7a18813cf...
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
arch/mips/lib/cache_init.S | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/mips/lib/cache_init.S b/arch/mips/lib/cache_init.S index 602741c65d..d64209d76a 100644 --- a/arch/mips/lib/cache_init.S +++ b/arch/mips/lib/cache_init.S @@ -431,9 +431,9 @@ LEAF(change_k0_cca) #else xor a0, a0, t0 andi a0, a0, CONF_CM_CMASK - xor a0, a0, t0 + xor t0, a0, t0 #endif - mtc0 a0, CP0_CONFIG + mtc0 t0, CP0_CONFIG
jr.hb ra END(change_k0_cca)
Daniel Schwierzeck
