[U-Boot] [PATCH] smc91111_eeprom: fix linking error
Building for a bf533-stamp ends up with this error: smc91111_eeprom.o: In function `smc91111_eeprom': examples/standalone/smc91111_eeprom.c:58: undefined reference to `memset' make[2]: *** [smc91111_eeprom] Error 1
The new eth_struct definition means gcc has to zero out the structure on the stack, and some gcc versions optimize this with an implicit call to memset. So tweak the structure style to avoid that gcc feature.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- examples/standalone/smc91111_eeprom.c | 5 ++--- 1 files changed, 2 insertions(+), 3 deletions(-)
diff --git a/examples/standalone/smc91111_eeprom.c b/examples/standalone/smc91111_eeprom.c index 9145763..b91f34c 100644 --- a/examples/standalone/smc91111_eeprom.c +++ b/examples/standalone/smc91111_eeprom.c @@ -53,9 +53,8 @@ int smc91111_eeprom (int argc, char *argv[]) int c, i, j, done, line, reg, value, start, what; char input[50];
- struct eth_device dev = { - .iobase = CONFIG_SMC91111_BASE - }; + struct eth_device dev; + dev.iobase = CONFIG_SMC91111_BASE;
/* Print the ABI version */ app_startup (argv);
Mike,
Applied to net repo.
thanks, Ben
Ben Warren
Mike Frysinger
