[U-Boot] [PATCH] mmc: fsl_esdhc: Check the result from malloc()
malloc can fail, so we should better check its return value before using it.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- drivers/mmc/fsl_esdhc.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index f87e647..a7170b4 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -518,6 +518,8 @@ int fsl_esdhc_initialize(bd_t *bis, struct fsl_esdhc_cfg *cfg) return -1;
mmc = malloc(sizeof(struct mmc)); + if (!mmc) + return -ENOMEM;
sprintf(mmc->name, "FSL_SDHC"); regs = (struct fsl_esdhc *)cfg->esdhc_base;
Applied to u-boot-imx, thanks!
Best regards, Stefano Babic
Fabio Estevam
Stefano Babic
