Re: [U-Boot] mmc: disable UHS modes if Vcc cannot be switched on and off
Hi Jean-Jacques,
after commit "mmc: disable UHS modes if Vcc cannot be switched on and off" (04a2ea248f) we got MMC broken on several (at least two) platforms with DesignWare MMC controller.
The error log (with debug enabled in drivers/mmc/mmc.c and drivers/mmc/dw_mmc.c) is next: --------------->8------------- MMC: Synopsys Mobile storage: 0 Buswidth = 0, clock: 400000 selecting mode MMC legacy (freq : 0 MHz) Buswidth = 1, clock: 400000 Buswidth = 1, clock: 400000 Sending CMD0 dwmci_send_cmd: Timeout. mmc_init: -110, time 19 ** Bad device mmc 0 ** --------------->8-------------
Any ideas how to fix this?
Thanks.
On 01/23/2018 03:38 AM, Eugeniy Paltsev wrote:
Hi Jean-Jacques,
Could you share which git repository you use?
Best Regards, Jaehoon Chung
Thanks.
Hi Jean-Jacques,
I use u-boot master branch from git://git.denx.de/u-boot.git
last commits: --------------->8------------- 485c13c Merge git://git.denx.de/u-boot-dm b79221a lib: fdtdec: Fix some style violations 2e38662 lib: fdtdec: Fix whitespace style violations 29d11b8 core: Make device_is_compatible live-tree compatible 147c607 core: Add {ofnode, dev}_translate_address functions --------------->8-------------
Thanks.
Hi Jean-Jacques,
I guess that this issue has already been fixed.
http://patchwork.ozlabs.org/patch/862160/ http://patchwork.ozlabs.org/patch/864607/
Thanks.
Hi Jean-Jacques,
Yep, this patch solves the problem.
Tested-by: Eugeniy Paltsev Eugeniy.Paltsev@synopsys.com
Thanks.
Thanks.
Eugeniy Paltsev
Jaehoon Chung
