[U-Boot] [PATCH 0/1] ARM: mvebu: Armada-38x DDR training update
Hi All,
I had a faulty board to debug at $dayjob. Part of that involved trying the latest DDR training code from Marvell. That didn't fix by problem (I suspect a manufacturing issue with that board).
Since I've done the work anyway I figured I'd send this out. Most of the delta is code movement and tidy up. There's very little behavioural change for A38X. This may however be useful if/when someone starts looking at the newer Armada-3700/3900 SoCs.
Chris Packham (1): ARM: mvebu: a38x: sync ddr training code with mv_ddr-armada-18.09
board/CZ.NIC/turris_omnia/turris_omnia.c | 4 +- board/Marvell/db-88f6820-amc/db-88f6820-amc.c | 2 +- board/Marvell/db-88f6820-gp/db-88f6820-gp.c | 2 +- board/gdsys/a38x/controlcenterdc.c | 2 +- board/kobol/helios4/helios4.c | 2 +- board/solidrun/clearfog/clearfog.c | 2 +- drivers/ddr/marvell/a38x/ddr3_debug.c | 414 +-------------- drivers/ddr/marvell/a38x/ddr3_init.c | 91 +--- drivers/ddr/marvell/a38x/ddr3_init.h | 43 +- drivers/ddr/marvell/a38x/ddr3_topology_def.h | 78 --- drivers/ddr/marvell/a38x/ddr3_training.c | 484 +++++++++--------- drivers/ddr/marvell/a38x/ddr3_training_bist.c | 1 + .../a38x/ddr3_training_centralization.c | 3 + drivers/ddr/marvell/a38x/ddr3_training_db.c | 172 ++++--- .../ddr/marvell/a38x/ddr3_training_hw_algo.c | 1 + drivers/ddr/marvell/a38x/ddr3_training_ip.h | 38 -- .../ddr/marvell/a38x/ddr3_training_ip_def.h | 31 -- .../marvell/a38x/ddr3_training_ip_engine.c | 2 + .../marvell/a38x/ddr3_training_ip_engine.h | 1 + .../ddr/marvell/a38x/ddr3_training_ip_flow.h | 91 +--- .../marvell/a38x/ddr3_training_ip_prv_if.h | 10 +- .../ddr/marvell/a38x/ddr3_training_leveling.c | 75 +-- .../ddr/marvell/a38x/ddr3_training_leveling.h | 1 - drivers/ddr/marvell/a38x/ddr3_training_pbs.c | 7 +- drivers/ddr/marvell/a38x/ddr_topology_def.h | 107 +++- drivers/ddr/marvell/a38x/ddr_training_ip_db.h | 2 - drivers/ddr/marvell/a38x/dram_if.h | 13 + .../ddr/marvell/a38x/mv_ddr_build_message.c | 2 +- drivers/ddr/marvell/a38x/mv_ddr_common.h | 38 +- drivers/ddr/marvell/a38x/mv_ddr_plat.c | 181 ++++--- drivers/ddr/marvell/a38x/mv_ddr_plat.h | 12 +- drivers/ddr/marvell/a38x/mv_ddr_regs.h | 19 + drivers/ddr/marvell/a38x/mv_ddr_spd.c | 16 +- drivers/ddr/marvell/a38x/mv_ddr_topology.c | 215 ++++++-- drivers/ddr/marvell/a38x/mv_ddr_topology.h | 214 +++++++- drivers/ddr/marvell/a38x/mv_ddr_training_db.h | 40 ++ drivers/ddr/marvell/a38x/xor.c | 8 +- 37 files changed, 1163 insertions(+), 1261 deletions(-) delete mode 100644 drivers/ddr/marvell/a38x/ddr3_topology_def.h create mode 100644 drivers/ddr/marvell/a38x/dram_if.h create mode 100644 drivers/ddr/marvell/a38x/mv_ddr_training_db.h
This syncs drivers/ddr/marvell/a38x/ with the mv_ddr-armada-18.09 branch of https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell.git.
The upstream code is incorporated omitting the portions not relevant to Armada-38x and DDR3. After that a semi-automated step is used to drop unused features with unifdef
find drivers/ddr/marvell/a38x/ -name '*.[ch]' | \ xargs unifdef -m -UMV_DDR -UMV_DDR_ATF -UCONFIG_DDR4 \ -UCONFIG_APN806 -UCONFIG_MC_STATIC \ -UCONFIG_MC_STATIC_PRINT -UCONFIG_PHY_STATIC \ -UCONFIG_64BIT -UCONFIG_A3700 -UA3900 -UA80X0 \ -UA70X0
Signed-off-by: Chris Packham judge.packham@gmail.com --- I've tested this on the db-88f6820-amc and build tested the other affected boards.
diff --git a/board/CZ.NIC/turris_omnia/turris_omnia.c b/board/CZ.NIC/turris_omnia/turris_omnia.c index 160d30cd795a..1f7650cb3610 100644 --- a/board/CZ.NIC/turris_omnia/turris_omnia.c +++ b/board/CZ.NIC/turris_omnia/turris_omnia.c @@ -212,7 +212,7 @@ static struct mv_ddr_topology_map board_topology_map_1g = { SPEED_BIN_DDR_1600K, /* speed_bin */ MV_DDR_DEV_WIDTH_16BIT, /* memory_width */ MV_DDR_DIE_CAP_4GBIT, /* mem_size */ - DDR_FREQ_800, /* frequency */ + MV_DDR_FREQ_800, /* frequency */ 0, 0, /* cas_wl cas_l */ MV_DDR_TEMP_NORMAL, /* temperature */ MV_DDR_TIM_2T} }, /* timing */ @@ -234,7 +234,7 @@ static struct mv_ddr_topology_map board_topology_map_2g = { SPEED_BIN_DDR_1600K, /* speed_bin */ MV_DDR_DEV_WIDTH_16BIT, /* memory_width */ MV_DDR_DIE_CAP_8GBIT, /* mem_size */ - DDR_FREQ_800, /* frequency */ + MV_DDR_FREQ_800, /* frequency */ 0, 0, /* cas_wl cas_l */ MV_DDR_TEMP_NORMAL, /* temperature */ MV_DDR_TIM_2T} }, /* timing */ diff --git a/board/Marvell/db-88f6820-amc/db-88f6820-amc.c b/board/Marvell/db-88f6820-amc/db-88f6820-amc.c index 92d7ae77f07e..bc18fe6ddf4a 100644 --- a/board/Marvell/db-88f6820-amc/db-88f6820-amc.c +++ b/board/Marvell/db-88f6820-amc/db-88f6820-amc.c @@ -67,7 +67,7 @@ static struct mv_ddr_topology_map board_topology_map = { SPEED_BIN_DDR_1866L, /* speed_bin */ MV_DDR_DEV_WIDTH_8BIT, /* memory_width */ MV_DDR_DIE_CAP_2GBIT, /* mem_size */ - DDR_FREQ_800, /* frequency */ + MV_DDR_FREQ_800, /* frequency */ 0, 0, /* cas_wl cas_l */ MV_DDR_TEMP_LOW, /* temperature */ MV_DDR_TIM_DEFAULT} }, /* timing */ diff --git a/board/Marvell/db-88f6820-gp/db-88f6820-gp.c b/board/Marvell/db-88f6820-gp/db-88f6820-gp.c index a8cfe8af0a88..9368bce26cee 100644 --- a/board/Marvell/db-88f6820-gp/db-88f6820-gp.c +++ b/board/Marvell/db-88f6820-gp/db-88f6820-gp.c @@ -88,7 +88,7 @@ static struct mv_ddr_topology_map board_topology_map = { SPEED_BIN_DDR_1866L, /* speed_bin */ MV_DDR_DEV_WIDTH_8BIT, /* memory_width */ MV_DDR_DIE_CAP_4GBIT, /* mem_size */ - DDR_FREQ_800, /* frequency */ + MV_DDR_FREQ_800, /* frequency */ 0, 0, /* cas_wl cas_l */ MV_DDR_TEMP_LOW, /* temperature */ MV_DDR_TIM_DEFAULT} }, /* timing */ diff --git a/board/gdsys/a38x/controlcenterdc.c b/board/gdsys/a38x/controlcenterdc.c index 824a08f12af8..9cbb33ff668d 100644 --- a/board/gdsys/a38x/controlcenterdc.c +++ b/board/gdsys/a38x/controlcenterdc.c @@ -51,7 +51,7 @@ static struct mv_ddr_topology_map ddr_topology_map = { SPEED_BIN_DDR_1600K, /* speed_bin */ MV_DDR_DEV_WIDTH_16BIT, /* memory_width */ MV_DDR_DIE_CAP_4GBIT, /* mem_size */ - DDR_FREQ_533, /* frequency */ + MV_DDR_FREQ_533, /* frequency */ 0, 0, /* cas_wl cas_l */ MV_DDR_TEMP_LOW, /* temperature */ MV_DDR_TIM_DEFAULT} }, /* timing */ diff --git a/board/kobol/helios4/helios4.c b/board/kobol/helios4/helios4.c index 341678319a46..15e78dee944b 100644 --- a/board/kobol/helios4/helios4.c +++ b/board/kobol/helios4/helios4.c @@ -78,7 +78,7 @@ static struct mv_ddr_topology_map board_topology_map = { SPEED_BIN_DDR_1600K, /* speed_bin */ MV_DDR_DEV_WIDTH_16BIT, /* memory_width */ MV_DDR_DIE_CAP_8GBIT, /* mem_size */ - DDR_FREQ_800, /* frequency */ + MV_DDR_FREQ_800, /* frequency */ 0, 0, /* cas_wl cas_l */ MV_DDR_TEMP_LOW, /* temperature */ MV_DDR_TIM_DEFAULT} }, /* timing */ diff --git a/board/solidrun/clearfog/clearfog.c b/board/solidrun/clearfog/clearfog.c index 4e1386c8a223..1742aa8921c9 100644 --- a/board/solidrun/clearfog/clearfog.c +++ b/board/solidrun/clearfog/clearfog.c @@ -65,7 +65,7 @@ static struct mv_ddr_topology_map board_topology_map = { SPEED_BIN_DDR_1600K, /* speed_bin */ MV_DDR_DEV_WIDTH_16BIT, /* memory_width */ MV_DDR_DIE_CAP_4GBIT, /* mem_size */ - DDR_FREQ_800, /* frequency */ + MV_DDR_FREQ_800, /* frequency */ 0, 0, /* cas_wl cas_l */ MV_DDR_TEMP_LOW, /* temperature */ MV_DDR_TIM_DEFAULT} }, /* timing */ diff --git a/drivers/ddr/marvell/a38x/ddr3_debug.c b/drivers/ddr/marvell/a38x/ddr3_debug.c index 1eac0bcd2b2d..f5fc964d6f87 100644 --- a/drivers/ddr/marvell/a38x/ddr3_debug.c +++ b/drivers/ddr/marvell/a38x/ddr3_debug.c @@ -4,6 +4,8 @@ */
#include "ddr3_init.h" +#include "mv_ddr_training_db.h" +#include "mv_ddr_regs.h"
u8 is_reg_dump = 0; u8 debug_pbs = DEBUG_LEVEL_ERROR; @@ -83,7 +85,7 @@ void ddr3_hws_set_log_level(enum ddr_lib_debug_block block, u8 level) #endif /* SILENT_LIB */
#if defined(DDR_VIEWER_TOOL) -static char *convert_freq(enum hws_ddr_freq freq); +static char *convert_freq(enum mv_ddr_freq freq); #if defined(EXCLUDE_SWITCH_DEBUG) u32 ctrl_sweepres[ADLL_LENGTH][MAX_INTERFACE_NUM][MAX_BUS_NUM]; u32 ctrl_adll[MAX_CS_NUM * MAX_INTERFACE_NUM * MAX_BUS_NUM]; @@ -176,23 +178,6 @@ int ddr3_tip_init_config_func(u32 dev_num, return MV_OK; }
-/* - * Read training result table - */ -int hws_ddr3_tip_read_training_result( - u32 dev_num, enum hws_result result[MAX_STAGE_LIMIT][MAX_INTERFACE_NUM]) -{ - if (result == NULL) - return MV_BAD_PARAM; - - memcpy(result, training_result, - sizeof(enum hws_result) * - MAX_STAGE_LIMIT * - MAX_INTERFACE_NUM); - - return MV_OK; -} - /* * Get training result info pointer */ @@ -218,50 +203,50 @@ int ddr3_tip_get_device_info(u32 dev_num, struct ddr3_device_info *info_ptr) /* * Convert freq to character string */ -static char *convert_freq(enum hws_ddr_freq freq) +static char *convert_freq(enum mv_ddr_freq freq) { switch (freq) { - case DDR_FREQ_LOW_FREQ: - return "DDR_FREQ_LOW_FREQ"; + case MV_DDR_FREQ_LOW_FREQ: + return "MV_DDR_FREQ_LOW_FREQ";
- case DDR_FREQ_400: + case MV_DDR_FREQ_400: return "400";
- case DDR_FREQ_533: + case MV_DDR_FREQ_533: return "533";
- case DDR_FREQ_667: + case MV_DDR_FREQ_667: return "667";
- case DDR_FREQ_800: + case MV_DDR_FREQ_800: return "800";
- case DDR_FREQ_933: + case MV_DDR_FREQ_933: return "933";
- case DDR_FREQ_1066: + case MV_DDR_FREQ_1066: return "1066";
- case DDR_FREQ_311: + case MV_DDR_FREQ_311: return "311";
- case DDR_FREQ_333: + case MV_DDR_FREQ_333: return "333";
- case DDR_FREQ_467: + case MV_DDR_FREQ_467: return "467";
- case DDR_FREQ_850: + case MV_DDR_FREQ_850: return "850";
- case DDR_FREQ_900: + case MV_DDR_FREQ_900: return "900";
- case DDR_FREQ_360: - return "DDR_FREQ_360"; + case MV_DDR_FREQ_360: + return "MV_DDR_FREQ_360";
- case DDR_FREQ_1000: - return "DDR_FREQ_1000"; + case MV_DDR_FREQ_1000: + return "MV_DDR_FREQ_1000";
default: return "Unknown Frequency"; @@ -364,7 +349,7 @@ int ddr3_tip_print_log(u32 dev_num, u32 mem_addr) if ((is_validate_window_per_if != 0) || (is_validate_window_per_pup != 0)) { u32 is_pup_log = 0; - enum hws_ddr_freq freq; + enum mv_ddr_freq freq;
freq = tm->interface_params[first_active_if].memory_freq;
@@ -528,7 +513,7 @@ int ddr3_tip_print_stability_log(u32 dev_num) u8 if_id = 0, csindex = 0, bus_id = 0, idx = 0; u32 reg_data; u32 read_data[MAX_INTERFACE_NUM]; - u32 max_cs = ddr3_tip_max_cs_get(dev_num); + unsigned int max_cs = mv_ddr_cs_num_get(); struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get();
/* Title print */ @@ -844,8 +829,6 @@ u32 xsb_test_table[][8] = { 0xffffffff, 0xffffffff} };
-static int ddr3_tip_access_atr(u32 dev_num, u32 flag_id, u32 value, u32 **ptr); - int ddr3_tip_print_adll(void) { u32 bus_cnt = 0, if_id, data_p1, data_p2, ui_data3, dev_num = 0; @@ -877,353 +860,6 @@ int ddr3_tip_print_adll(void) return MV_OK; }
-/* - * Set attribute value - */ -int ddr3_tip_set_atr(u32 dev_num, u32 flag_id, u32 value) -{ - int ret; - u32 *ptr_flag = NULL; - - ret = ddr3_tip_access_atr(dev_num, flag_id, value, &ptr_flag); - if (ptr_flag != NULL) { - printf("ddr3_tip_set_atr Flag ID 0x%x value is set to 0x%x (was 0x%x)\n", - flag_id, value, *ptr_flag); - *ptr_flag = value; - } else { - printf("ddr3_tip_set_atr Flag ID 0x%x value is set to 0x%x\n", - flag_id, value); - } - - return ret; -} - -/* - * Access attribute - */ -static int ddr3_tip_access_atr(u32 dev_num, u32 flag_id, u32 value, u32 **ptr) -{ - u32 tmp_val = 0, if_id = 0, pup_id = 0; - struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); - - *ptr = NULL; - - switch (flag_id) { - case 0: - *ptr = (u32 *)&(tm->if_act_mask); - break; - - case 0x1: - *ptr = (u32 *)&mask_tune_func; - break; - - case 0x2: - low_freq = (enum hws_ddr_freq)value; - break; - - case 0x3: - medium_freq = (enum hws_ddr_freq)value; - break; - - case 0x4: - *ptr = (u32 *)&generic_init_controller; - break; - - case 0x8: - *ptr = (u32 *)&start_xsb_offset; - break; - - case 0x20: - *ptr = (u32 *)&is_rl_old; - break; - - case 0x21: - *ptr = (u32 *)&is_freq_old; - break; - - case 0x23: - *ptr = (u32 *)&is_dfs_disabled; - break; - - case 0x24: - *ptr = (u32 *)&is_pll_before_init; - break; - - case 0x25: - *ptr = (u32 *)&is_adll_calib_before_init; - break; - case 0x28: - *ptr = (u32 *)&is_tune_result; - break; - - case 0x29: - *ptr = (u32 *)&is_validate_window_per_if; - break; - - case 0x2a: - *ptr = (u32 *)&is_validate_window_per_pup; - break; - - case 0x30: - *ptr = (u32 *)&sweep_cnt; - break; - - case 0x31: - *ptr = (u32 *)&is_bist_reset_bit; - break; - - case 0x32: - *ptr = (u32 *)&is_dfs_in_init; - break; - - case 0x33: - *ptr = (u32 *)&g_zpodt_data; - break; - - case 0x34: - *ptr = (u32 *)&g_znodt_data; - break; - - case 0x35: - break; - - case 0x36: - *ptr = (u32 *)&(freq_val[DDR_FREQ_LOW_FREQ]); - break; - - case 0x37: - *ptr = (u32 *)&start_pattern; - break; - - case 0x38: - *ptr = (u32 *)&end_pattern; - break; - - case 0x39: - *ptr = (u32 *)&phy_reg0_val; - break; - - case 0x4a: - *ptr = (u32 *)&phy_reg1_val; - break; - - case 0x4b: - *ptr = (u32 *)&phy_reg2_val; - break; - - case 0x4c: - *ptr = (u32 *)&phy_reg3_val; - break; - - case 0x4e: - sweep_pattern = (enum hws_pattern)value; - break; - - case 0x51: - *ptr = (u32 *)&g_znri_data; - break; - - case 0x52: - *ptr = (u32 *)&g_zpri_data; - break; - - case 0x53: - *ptr = (u32 *)&finger_test; - break; - - case 0x54: - *ptr = (u32 *)&n_finger_start; - break; - - case 0x55: - *ptr = (u32 *)&n_finger_end; - break; - - case 0x56: - *ptr = (u32 *)&p_finger_start; - break; - - case 0x57: - *ptr = (u32 *)&p_finger_end; - break; - - case 0x58: - *ptr = (u32 *)&p_finger_step; - break; - - case 0x59: - *ptr = (u32 *)&n_finger_step; - break; - - case 0x5a: - *ptr = (u32 *)&g_znri_ctrl; - break; - - case 0x5b: - *ptr = (u32 *)&g_zpri_ctrl; - break; - - case 0x5c: - *ptr = (u32 *)&is_reg_dump; - break; - - case 0x5d: - *ptr = (u32 *)&vref_init_val; - break; - - case 0x5e: - *ptr = (u32 *)&mode_2t; - break; - - case 0x5f: - *ptr = (u32 *)&xsb_validate_type; - break; - - case 0x60: - *ptr = (u32 *)&xsb_validation_base_address; - break; - - case 0x67: - *ptr = (u32 *)&activate_select_before_run_alg; - break; - - case 0x68: - *ptr = (u32 *)&activate_deselect_after_run_alg; - break; - - case 0x69: - *ptr = (u32 *)&odt_additional; - break; - - case 0x70: - *ptr = (u32 *)&debug_mode; - break; - - case 0x71: - pbs_pattern = (enum hws_pattern)value; - break; - - case 0x72: - *ptr = (u32 *)&delay_enable; - break; - - case 0x73: - *ptr = (u32 *)&ck_delay; - break; - - case 0x75: - *ptr = (u32 *)&ca_delay; - break; - - case 0x100: - *ptr = (u32 *)&debug_dunit; - break; - - case 0x101: - debug_acc = (int)value; - break; - - case 0x102: - debug_training = (u8)value; - break; - - case 0x103: - debug_training_bist = (u8)value; - break; - - case 0x104: - debug_centralization = (u8)value; - break; - - case 0x105: - debug_training_ip = (u8)value; - break; - - case 0x106: - debug_leveling = (u8)value; - break; - - case 0x107: - debug_pbs = (u8)value; - break; - - case 0x108: - debug_training_static = (u8)value; - break; - - case 0x109: - debug_training_access = (u8)value; - break; - - - case 0x112: - *ptr = &start_pattern; - break; - - case 0x113: - *ptr = &end_pattern; - break; - - default: - if ((flag_id >= 0x200) && (flag_id < 0x210)) { - if_id = flag_id - 0x200; - *ptr = (u32 *)&(tm->interface_params - [if_id].memory_freq); - } else if ((flag_id >= 0x210) && (flag_id < 0x220)) { - if_id = flag_id - 0x210; - *ptr = (u32 *)&(tm->interface_params - [if_id].speed_bin_index); - } else if ((flag_id >= 0x220) && (flag_id < 0x230)) { - if_id = flag_id - 0x220; - *ptr = (u32 *)&(tm->interface_params - [if_id].bus_width); - } else if ((flag_id >= 0x230) && (flag_id < 0x240)) { - if_id = flag_id - 0x230; - *ptr = (u32 *)&(tm->interface_params - [if_id].memory_size); - } else if ((flag_id >= 0x240) && (flag_id < 0x250)) { - if_id = flag_id - 0x240; - *ptr = (u32 *)&(tm->interface_params - [if_id].cas_l); - } else if ((flag_id >= 0x250) && (flag_id < 0x260)) { - if_id = flag_id - 0x250; - *ptr = (u32 *)&(tm->interface_params - [if_id].cas_wl); - } else if ((flag_id >= 0x270) && (flag_id < 0x2cf)) { - if_id = (flag_id - 0x270) / MAX_BUS_NUM; - pup_id = (flag_id - 0x270) % MAX_BUS_NUM; - *ptr = (u32 *)&(tm->interface_params[if_id]. - as_bus_params[pup_id].is_ck_swap); - } else if ((flag_id >= 0x2d0) && (flag_id < 0x32f)) { - if_id = (flag_id - 0x2d0) / MAX_BUS_NUM; - pup_id = (flag_id - 0x2d0) % MAX_BUS_NUM; - *ptr = (u32 *)&(tm->interface_params[if_id]. - as_bus_params[pup_id].is_dqs_swap); - } else if ((flag_id >= 0x330) && (flag_id < 0x38f)) { - if_id = (flag_id - 0x330) / MAX_BUS_NUM; - pup_id = (flag_id - 0x330) % MAX_BUS_NUM; - *ptr = (u32 *)&(tm->interface_params[if_id]. - as_bus_params[pup_id].cs_bitmask); - } else if ((flag_id >= 0x390) && (flag_id < 0x3ef)) { - if_id = (flag_id - 0x390) / MAX_BUS_NUM; - pup_id = (flag_id - 0x390) % MAX_BUS_NUM; - *ptr = (u32 *)&(tm->interface_params - [if_id].as_bus_params - [pup_id].mirror_enable_bitmask); - } else if ((flag_id >= 0x500) && (flag_id <= 0x50f)) { - tmp_val = flag_id - 0x320; - *ptr = (u32 *)&(clamp_tbl[tmp_val]); - } else { - DEBUG_TRAINING_IP(DEBUG_LEVEL_ERROR, - ("flag_id out of boundary %d\n", - flag_id)); - return MV_BAD_PARAM; - } - } - - return MV_OK; -} - #endif /* EXCLUDE_SWITCH_DEBUG */
#if defined(DDR_VIEWER_TOOL) @@ -1315,7 +951,7 @@ int ddr3_tip_run_sweep_test(int dev_num, u32 repeat_num, u32 direction, u32 reg; enum hws_access_type pup_access; u32 cs; - u32 max_cs = ddr3_tip_max_cs_get(dev_num); + unsigned int max_cs = mv_ddr_cs_num_get(); u32 octets_per_if_num = ddr3_tip_dev_attr_get(dev_num, MV_ATTR_OCTET_PER_INTERFACE); struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get();
@@ -1462,7 +1098,7 @@ int ddr3_tip_run_leveling_sweep_test(int dev_num, u32 repeat_num, u32 reg; enum hws_access_type pup_access; u32 cs; - u32 max_cs = ddr3_tip_max_cs_get(dev_num); + unsigned int max_cs = mv_ddr_cs_num_get(); u32 octets_per_if_num = ddr3_tip_dev_attr_get(dev_num, MV_ATTR_OCTET_PER_INTERFACE); struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get();
diff --git a/drivers/ddr/marvell/a38x/ddr3_init.c b/drivers/ddr/marvell/a38x/ddr3_init.c index 27dbf4f44b98..22c8f9ca54e5 100644 --- a/drivers/ddr/marvell/a38x/ddr3_init.c +++ b/drivers/ddr/marvell/a38x/ddr3_init.c @@ -6,18 +6,6 @@ #include "ddr3_init.h" #include "mv_ddr_common.h"
-/* - * Translates topology map definitions to real memory size in bits - * (per values in ddr3_training_ip_def.h) - */ -u32 mem_size[] = { - ADDR_SIZE_512MB, - ADDR_SIZE_1GB, - ADDR_SIZE_2GB, - ADDR_SIZE_4GB, - ADDR_SIZE_8GB -}; - static char *ddr_type = "DDR3";
/* @@ -37,8 +25,6 @@ static int mv_ddr_training_params_set(u8 dev_num); */ int ddr3_init(void) { - struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); - u32 octets_per_if_num; int status; int is_manual_cal_done;
@@ -55,7 +41,7 @@ int ddr3_init(void)
mv_ddr_early_init();
- if (mv_ddr_topology_map_update() == NULL) { + if (mv_ddr_topology_map_update()) { printf("mv_ddr: failed to update topology\n"); return MV_FAIL; } @@ -68,7 +54,6 @@ int ddr3_init(void) if (MV_OK != status) return status;
- mv_ddr_mc_config();
is_manual_cal_done = mv_ddr_manual_cal_do(); @@ -101,76 +86,14 @@ int ddr3_init(void)
mv_ddr_post_training_fixup();
- octets_per_if_num = ddr3_tip_dev_attr_get(0, MV_ATTR_OCTET_PER_INTERFACE); - if (ddr3_if_ecc_enabled()) { - if (MV_DDR_IS_64BIT_DRAM_MODE(tm->bus_act_mask) || - MV_DDR_IS_32BIT_IN_64BIT_DRAM_MODE(tm->bus_act_mask, octets_per_if_num)) - mv_ddr_mem_scrubbing(); - else - ddr3_new_tip_ecc_scrub(); - } + if (mv_ddr_is_ecc_ena()) + mv_ddr_mem_scrubbing();
printf("mv_ddr: completed successfully\n");
return MV_OK; }
-uint64_t mv_ddr_get_memory_size_per_cs_in_bits(void) -{ - uint64_t memory_size_per_cs; - - u32 bus_cnt, num_of_active_bus = 0; - u32 num_of_sub_phys_per_ddr_unit = 0; - - struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); - - u32 octets_per_if_num = ddr3_tip_dev_attr_get(DEV_NUM_0, MV_ATTR_OCTET_PER_INTERFACE); - - /* count the number of active bus */ - for (bus_cnt = 0; bus_cnt < octets_per_if_num - 1/* ignore ecc octet */; bus_cnt++) { - VALIDATE_BUS_ACTIVE(tm->bus_act_mask, bus_cnt); - num_of_active_bus++; - } - - /* calculate number of sub-phys per ddr unit */ - if (tm->interface_params[0].bus_width/* supports only single interface */ == MV_DDR_DEV_WIDTH_16BIT) - num_of_sub_phys_per_ddr_unit = TWO_SUB_PHYS; - if (tm->interface_params[0].bus_width/* supports only single interface */ == MV_DDR_DEV_WIDTH_8BIT) - num_of_sub_phys_per_ddr_unit = SINGLE_SUB_PHY; - - /* calculate dram size per cs */ - memory_size_per_cs = (uint64_t)mem_size[tm->interface_params[0].memory_size] * (uint64_t)num_of_active_bus - / (uint64_t)num_of_sub_phys_per_ddr_unit * (uint64_t)MV_DDR_NUM_BITS_IN_BYTE; - - return memory_size_per_cs; -} - -uint64_t mv_ddr_get_total_memory_size_in_bits(void) -{ - uint64_t total_memory_size = 0; - uint64_t memory_size_per_cs = 0; - - /* get the number of cs */ - u32 max_cs = ddr3_tip_max_cs_get(DEV_NUM_0); - - memory_size_per_cs = mv_ddr_get_memory_size_per_cs_in_bits(); - total_memory_size = (uint64_t)max_cs * memory_size_per_cs; - - return total_memory_size; -} - -int ddr3_if_ecc_enabled(void) -{ - struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); - - if (DDR3_IS_ECC_PUP4_MODE(tm->bus_act_mask) || - DDR3_IS_ECC_PUP3_MODE(tm->bus_act_mask) || - DDR3_IS_ECC_PUP8_MODE(tm->bus_act_mask)) - return 1; - else - return 0; -} - /* * Name: mv_ddr_training_params_set * Desc: @@ -182,15 +105,9 @@ static int mv_ddr_training_params_set(u8 dev_num) { struct tune_train_params params; int status; - struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); - u32 if_id; u32 cs_num;
- CHECK_STATUS(ddr3_tip_get_first_active_if - (dev_num, tm->if_act_mask, - &if_id)); - - CHECK_STATUS(calc_cs_num(dev_num, if_id, &cs_num)); + cs_num = mv_ddr_cs_num_get();
/* NOTE: do not remove any field initilization */ params.ck_delay = TUNE_TRAINING_PARAMS_CK_DELAY; diff --git a/drivers/ddr/marvell/a38x/ddr3_init.h b/drivers/ddr/marvell/a38x/ddr3_init.h index 382bd922f213..055516b67e9c 100644 --- a/drivers/ddr/marvell/a38x/ddr3_init.h +++ b/drivers/ddr/marvell/a38x/ddr3_init.h @@ -7,9 +7,7 @@ #define _DDR3_INIT_H
#include "ddr_ml_wrapper.h" -#if defined(CONFIG_ARMADA_38X) || defined(CONFIG_ARMADA_39X) #include "mv_ddr_plat.h" -#endif
#include "seq_exec.h" #include "ddr3_logging_def.h" @@ -32,14 +30,8 @@ return status; \ }
-#define GET_MAX_VALUE(x, y) \ - ((x) > (y)) ? (x) : (y) - #define SUB_VERSION 0
-/* max number of devices supported by driver */ -#define MAX_DEVICE_NUM 1 - enum log_level { MV_LOG_LEVEL_0, MV_LOG_LEVEL_1, @@ -47,24 +39,26 @@ enum log_level { MV_LOG_LEVEL_3 };
+/* TODO: consider to move to misl phy driver */ +#define MISL_PHY_DRV_P_OFFS 0x7 +#define MISL_PHY_DRV_N_OFFS 0x0 +#define MISL_PHY_ODT_P_OFFS 0x6 +#define MISL_PHY_ODT_N_OFFS 0x0 + /* Globals */ extern u8 debug_training, debug_calibration, debug_ddr4_centralization, debug_tap_tuning, debug_dm_tuning; extern u8 is_reg_dump; extern u8 generic_init_controller; -/* list of allowed frequency listed in order of enum hws_ddr_freq */ -extern u32 freq_val[DDR_FREQ_LAST]; +/* list of allowed frequency listed in order of enum mv_ddr_freq */ extern u32 is_pll_old; -extern struct cl_val_per_freq cas_latency_table[]; extern struct pattern_info pattern_table[]; -extern struct cl_val_per_freq cas_write_latency_table[]; extern u8 debug_centralization, debug_training_ip, debug_training_bist, debug_pbs, debug_training_static, debug_leveling; extern struct hws_tip_config_func_db config_func_info[]; extern u8 twr_mask_table[]; extern u8 cl_mask_table[]; extern u8 cwl_mask_table[]; -extern u16 rfc_table[]; extern u32 speed_bin_table_t_rc[]; extern u32 speed_bin_table_t_rcd_t_rp[];
@@ -90,10 +84,10 @@ extern u32 mask_tune_func; extern u32 rl_version; extern int rl_mid_freq_wa; extern u8 calibration_update_control; /* 2 external only, 1 is internal only */ -extern enum hws_ddr_freq medium_freq; +extern enum mv_ddr_freq medium_freq;
extern enum hws_result training_result[MAX_STAGE_LIMIT][MAX_INTERFACE_NUM]; -extern enum hws_ddr_freq low_freq; +extern enum mv_ddr_freq low_freq; extern enum auto_tune_stage training_stage; extern u32 is_pll_before_init; extern u32 is_adll_calib_before_init; @@ -120,7 +114,7 @@ extern u32 odt_additional; extern u32 debug_mode; extern u32 debug_dunit; extern u32 clamp_tbl[]; -extern u32 freq_mask[MAX_DEVICE_NUM][DDR_FREQ_LAST]; +extern u32 freq_mask[MAX_DEVICE_NUM][MV_DDR_FREQ_LAST];
extern u32 maxt_poll_tries; extern u32 is_bist_reset_bit; @@ -139,7 +133,6 @@ extern u16 mask_results_dq_reg_map[];
extern u32 target_freq; extern u32 dfs_low_freq; -extern u32 mem_size[];
extern u32 nominal_avs; extern u32 extension_avs; @@ -154,13 +147,8 @@ int mv_ddr_early_init(void); int mv_ddr_early_init2(void); int ddr3_silicon_post_init(void); int ddr3_post_run_alg(void); -int ddr3_if_ecc_enabled(void); void ddr3_new_tip_ecc_scrub(void);
-void mv_ddr_ver_print(void); -struct mv_ddr_topology_map *mv_ddr_topology_map_get(void); - -int ddr3_if_ecc_enabled(void); int ddr3_tip_reg_write(u32 dev_num, u32 reg_addr, u32 data); int ddr3_tip_reg_read(u32 dev_num, u32 reg_addr, u32 *data, u32 reg_mask); int ddr3_silicon_get_ddr_target_freq(u32 *ddr_freq); @@ -185,15 +173,20 @@ void get_target_freq(u32 freq_mode, u32 *ddr_freq, u32 *hclk_ps); void ddr3_fast_path_static_cs_size_config(u32 cs_ena); u32 mv_board_id_index_get(u32 board_id); void ddr3_set_log_level(u32 n_log_level); -int calc_cs_num(u32 dev_num, u32 if_id, u32 *cs_num);
int hws_ddr3_cs_base_adr_calc(u32 if_id, u32 cs, u32 *cs_base_addr);
int ddr3_tip_print_pbs_result(u32 dev_num, u32 cs_num, enum pbs_dir pbs_mode); int ddr3_tip_clean_pbs_result(u32 dev_num, enum pbs_dir pbs_mode); - -u32 mv_ddr_init_freq_get(void); void mv_ddr_mc_config(void); int mv_ddr_mc_init(void); void mv_ddr_set_calib_controller(void); +/* TODO: consider to move to misl phy driver */ +unsigned int mv_ddr_misl_phy_drv_data_p_get(void); +unsigned int mv_ddr_misl_phy_drv_data_n_get(void); +unsigned int mv_ddr_misl_phy_drv_ctrl_p_get(void); +unsigned int mv_ddr_misl_phy_drv_ctrl_n_get(void); +unsigned int mv_ddr_misl_phy_odt_p_get(void); +unsigned int mv_ddr_misl_phy_odt_n_get(void); + #endif /* _DDR3_INIT_H */ diff --git a/drivers/ddr/marvell/a38x/ddr3_topology_def.h b/drivers/ddr/marvell/a38x/ddr3_topology_def.h deleted file mode 100644 index 1963bae3e62f..000000000000 --- a/drivers/ddr/marvell/a38x/ddr3_topology_def.h +++ /dev/null @@ -1,78 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (C) Marvell International Ltd. and its affiliates - */ - -#ifndef _DDR3_TOPOLOGY_DEF_H -#define _DDR3_TOPOLOGY_DEF_H - -#define DEV_NUM_0 0 - -/* TOPOLOGY */ -enum hws_speed_bin { - SPEED_BIN_DDR_800D, - SPEED_BIN_DDR_800E, - SPEED_BIN_DDR_1066E, - SPEED_BIN_DDR_1066F, - SPEED_BIN_DDR_1066G, - SPEED_BIN_DDR_1333F, - SPEED_BIN_DDR_1333G, - SPEED_BIN_DDR_1333H, - SPEED_BIN_DDR_1333J, - SPEED_BIN_DDR_1600G, - SPEED_BIN_DDR_1600H, - SPEED_BIN_DDR_1600J, - SPEED_BIN_DDR_1600K, - SPEED_BIN_DDR_1866J, - SPEED_BIN_DDR_1866K, - SPEED_BIN_DDR_1866L, - SPEED_BIN_DDR_1866M, - SPEED_BIN_DDR_2133K, - SPEED_BIN_DDR_2133L, - SPEED_BIN_DDR_2133M, - SPEED_BIN_DDR_2133N, - - SPEED_BIN_DDR_1333H_EXT, - SPEED_BIN_DDR_1600K_EXT, - SPEED_BIN_DDR_1866M_EXT -}; - -enum hws_ddr_freq { - DDR_FREQ_LOW_FREQ, - DDR_FREQ_400, - DDR_FREQ_533, - DDR_FREQ_667, - DDR_FREQ_800, - DDR_FREQ_933, - DDR_FREQ_1066, - DDR_FREQ_311, - DDR_FREQ_333, - DDR_FREQ_467, - DDR_FREQ_850, - DDR_FREQ_600, - DDR_FREQ_300, - DDR_FREQ_900, - DDR_FREQ_360, - DDR_FREQ_1000, - DDR_FREQ_LAST, - DDR_FREQ_SAR -}; - -enum speed_bin_table_elements { - SPEED_BIN_TRCD, - SPEED_BIN_TRP, - SPEED_BIN_TRAS, - SPEED_BIN_TRC, - SPEED_BIN_TRRD1K, - SPEED_BIN_TRRD2K, - SPEED_BIN_TPD, - SPEED_BIN_TFAW1K, - SPEED_BIN_TFAW2K, - SPEED_BIN_TWTR, - SPEED_BIN_TRTP, - SPEED_BIN_TWR, - SPEED_BIN_TMOD, - SPEED_BIN_TXPDLL -}; - -#endif /* _DDR3_TOPOLOGY_DEF_H */ diff --git a/drivers/ddr/marvell/a38x/ddr3_training.c b/drivers/ddr/marvell/a38x/ddr3_training.c index 799c5ba089a0..c7be700d641f 100644 --- a/drivers/ddr/marvell/a38x/ddr3_training.c +++ b/drivers/ddr/marvell/a38x/ddr3_training.c @@ -5,6 +5,8 @@
#include "ddr3_init.h" #include "mv_ddr_common.h" +#include "mv_ddr_training_db.h" +#include "mv_ddr_regs.h"
#define GET_CS_FROM_MASK(mask) (cs_mask2_num[mask]) #define CS_CBE_VALUE(cs_num) (cs_cbe_reg[cs_num]) @@ -14,8 +16,8 @@ u32 phy_reg0_val = 0; u32 phy_reg1_val = 8; u32 phy_reg2_val = 0; u32 phy_reg3_val = PARAM_UNDEFINED; -enum hws_ddr_freq low_freq = DDR_FREQ_LOW_FREQ; -enum hws_ddr_freq medium_freq; +enum mv_ddr_freq low_freq = MV_DDR_FREQ_LOW_FREQ; +enum mv_ddr_freq medium_freq; u32 debug_dunit = 0; u32 odt_additional = 1; u32 *dq_map_table = NULL; @@ -97,36 +99,9 @@ static int odt_test(u32 dev_num, enum hws_algo_type algo_type); #endif
int adll_calibration(u32 dev_num, enum hws_access_type access_type, - u32 if_id, enum hws_ddr_freq frequency); + u32 if_id, enum mv_ddr_freq frequency); static int ddr3_tip_set_timing(u32 dev_num, enum hws_access_type access_type, - u32 if_id, enum hws_ddr_freq frequency); - -static struct page_element page_tbl[] = { - /* - * 8bits 16 bits - * page-size(K) page-size(K) mask - */ - { 1, 2, 2}, - /* 512M */ - { 1, 2, 3}, - /* 1G */ - { 1, 2, 0}, - /* 2G */ - { 1, 2, 4}, - /* 4G */ - { 2, 2, 5}, - /* 8G */ - {0, 0, 0}, /* TODO: placeholder for 16-Mbit die capacity */ - {0, 0, 0}, /* TODO: placeholder for 32-Mbit die capacity */ - {0, 0, 0}, /* TODO: placeholder for 12-Mbit die capacity */ - {0, 0, 0} /* TODO: placeholder for 24-Mbit die capacity */ - -}; - -struct page_element *mv_ddr_page_tbl_get(void) -{ - return &page_tbl[0]; -} + u32 if_id, enum mv_ddr_freq frequency);
static u8 mem_size_config[MV_DDR_DIE_CAP_LAST] = { 0x2, /* 512Mbit */ @@ -204,7 +179,52 @@ struct mv_ddr_mr_data mr_data[] = { {MRS3_CMD, MR3_REG} };
-static int ddr3_tip_pad_inv(u32 dev_num, u32 if_id); +/* inverse pads */ +static int ddr3_tip_pad_inv(void) +{ + u32 sphy, data; + u32 sphy_max = ddr3_tip_dev_attr_get(0, MV_ATTR_OCTET_PER_INTERFACE); + u32 ck_swap_ctrl_sphy; + struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); + + for (sphy = 0; sphy < sphy_max; sphy++) { + VALIDATE_BUS_ACTIVE(tm->bus_act_mask, sphy); + if (tm->interface_params[0]. + as_bus_params[sphy].is_dqs_swap == 1) { + data = (INVERT_PAD << INV_PAD4_OFFS | + INVERT_PAD << INV_PAD5_OFFS); + /* dqs swap */ + ddr3_tip_bus_read_modify_write(0, ACCESS_TYPE_UNICAST, + 0, sphy, + DDR_PHY_DATA, + PHY_CTRL_PHY_REG, + data, data); + } + + if (tm->interface_params[0].as_bus_params[sphy]. + is_ck_swap == 1 && sphy == 0) { +/* TODO: move this code to per platform one */ +#if defined(CONFIG_ARMADA_38X) || defined(CONFIG_ARMADA_39X) + /* clock swap for both cs0 and cs1 */ + data = (INVERT_PAD << INV_PAD2_OFFS | + INVERT_PAD << INV_PAD6_OFFS | + INVERT_PAD << INV_PAD4_OFFS | + INVERT_PAD << INV_PAD5_OFFS); + ck_swap_ctrl_sphy = CK_SWAP_CTRL_PHY_NUM; + ddr3_tip_bus_read_modify_write(0, ACCESS_TYPE_UNICAST, + 0, ck_swap_ctrl_sphy, + DDR_PHY_CONTROL, + PHY_CTRL_PHY_REG, + data, data); +#else /* !CONFIG_ARMADA_38X && !CONFIG_ARMADA_39X && !A70X0 && !A80X0 && !A3900 */ +#pragma message "unknown platform to configure ddr clock swap" +#endif + } + } + + return MV_OK; +} + static int ddr3_tip_rank_control(u32 dev_num, u32 if_id);
/* @@ -244,6 +264,7 @@ int ddr3_tip_tune_training_params(u32 dev_num, if (params->g_rtt_park != PARAM_UNDEFINED) g_rtt_park = params->g_rtt_park;
+ DEBUG_TRAINING_IP(DEBUG_LEVEL_INFO, ("DGL parameters: 0x%X 0x%X 0x%X 0x%X 0x%X 0x%X 0x%X 0x%X 0x%X 0x%X 0x%X 0x%X\n", g_zpri_data, g_znri_data, g_zpri_ctrl, g_znri_ctrl, g_zpodt_data, g_znodt_data, @@ -308,44 +329,6 @@ int ddr3_tip_configure_cs(u32 dev_num, u32 if_id, u32 cs_num, u32 enable) return MV_OK; }
-/* - * Calculate number of CS - */ -int calc_cs_num(u32 dev_num, u32 if_id, u32 *cs_num) -{ - u32 cs; - u32 bus_cnt; - u32 cs_count; - u32 cs_bitmask; - u32 curr_cs_num = 0; - u32 octets_per_if_num = ddr3_tip_dev_attr_get(dev_num, MV_ATTR_OCTET_PER_INTERFACE); - struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); - - for (bus_cnt = 0; bus_cnt < octets_per_if_num; bus_cnt++) { - VALIDATE_BUS_ACTIVE(tm->bus_act_mask, bus_cnt); - cs_count = 0; - cs_bitmask = tm->interface_params[if_id]. - as_bus_params[bus_cnt].cs_bitmask; - for (cs = 0; cs < MAX_CS_NUM; cs++) { - if ((cs_bitmask >> cs) & 1) - cs_count++; - } - - if (curr_cs_num == 0) { - curr_cs_num = cs_count; - } else if (cs_count != curr_cs_num) { - DEBUG_TRAINING_IP(DEBUG_LEVEL_ERROR, - ("CS number is different per bus (IF %d BUS %d cs_num %d curr_cs_num %d)\n", - if_id, bus_cnt, cs_count, - curr_cs_num)); - return MV_NOT_SUPPORTED; - } - } - *cs_num = curr_cs_num; - - return MV_OK; -} - /* * Init Controller Flow */ @@ -356,7 +339,7 @@ int hws_ddr3_tip_init_controller(u32 dev_num, struct init_cntr_param *init_cntr_ u32 t_ckclk = 0, t_wr = 0, t2t = 0; u32 data_value = 0, cs_cnt = 0, mem_mask = 0, bus_index = 0; - enum hws_speed_bin speed_bin_index = SPEED_BIN_DDR_2133N; + enum mv_ddr_speed_bin speed_bin_index = SPEED_BIN_DDR_2133N; u32 cs_mask = 0; u32 cl_value = 0, cwl_val = 0; u32 bus_cnt = 0, adll_tap = 0; @@ -364,8 +347,8 @@ int hws_ddr3_tip_init_controller(u32 dev_num, struct init_cntr_param *init_cntr_ u32 data_read[MAX_INTERFACE_NUM]; u32 octets_per_if_num = ddr3_tip_dev_attr_get(dev_num, MV_ATTR_OCTET_PER_INTERFACE); struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); - enum hws_ddr_freq freq = tm->interface_params[0].memory_freq; enum mv_ddr_timing timing; + enum mv_ddr_freq freq = tm->interface_params[0].memory_freq;
DEBUG_TRAINING_IP(DEBUG_LEVEL_TRACE, ("Init_controller, do_mrs_phy=%d, is_ctrl64_bit=%d\n", @@ -403,7 +386,7 @@ int hws_ddr3_tip_init_controller(u32 dev_num, struct init_cntr_param *init_cntr_ speed_bin_index;
/* t_ckclk is external clock */ - t_ckclk = (MEGA / freq_val[freq]); + t_ckclk = (MEGA / mv_ddr_freq_get(freq));
if (MV_DDR_IS_HALF_BUS_DRAM_MODE(tm->bus_act_mask, octets_per_if_num)) data_value = (0x4000 | 0 | 0x1000000) & ~(1 << 26); @@ -508,7 +491,7 @@ int hws_ddr3_tip_init_controller(u32 dev_num, struct init_cntr_param *init_cntr_ * configure them both: The Bust_width it\92s the * Memory Bus width \96 x8 or x16 */ - for (cs_cnt = 0; cs_cnt < NUM_OF_CS; cs_cnt++) { + for (cs_cnt = 0; cs_cnt < MAX_CS_NUM; cs_cnt++) { ddr3_tip_configure_cs(dev_num, if_id, cs_cnt, ((cs_mask & (1 << cs_cnt)) ? 1 : 0)); @@ -534,7 +517,7 @@ int hws_ddr3_tip_init_controller(u32 dev_num, struct init_cntr_param *init_cntr_ ("cl_value 0x%x cwl_val 0x%x\n", cl_value, cwl_val));
- t_wr = time_to_nclk(speed_bin_table + t_wr = time_to_nclk(mv_ddr_speed_bin_timing_get (speed_bin_index, SPEED_BIN_TWR), t_ckclk);
@@ -612,8 +595,7 @@ int hws_ddr3_tip_init_controller(u32 dev_num, struct init_cntr_param *init_cntr_ t2t = (timing == MV_DDR_TIM_2T) ? 1 : 0; } else { /* calculate number of CS (per interface) */ - CHECK_STATUS(calc_cs_num - (dev_num, if_id, &cs_num)); + cs_num = mv_ddr_cs_num_get(); t2t = (cs_num == 1) ? 0 : 1; }
@@ -666,9 +648,8 @@ int hws_ddr3_tip_init_controller(u32 dev_num, struct init_cntr_param *init_cntr_ VALIDATE_IF_ACTIVE(tm->if_act_mask, if_id); CHECK_STATUS(ddr3_tip_rank_control(dev_num, if_id));
- if (init_cntr_prm->do_mrs_phy) { - CHECK_STATUS(ddr3_tip_pad_inv(dev_num, if_id)); - } + if (init_cntr_prm->do_mrs_phy) + ddr3_tip_pad_inv();
/* Pad calibration control - disable */ CHECK_STATUS(ddr3_tip_if_write @@ -682,7 +663,7 @@ int hws_ddr3_tip_init_controller(u32 dev_num, struct init_cntr_param *init_cntr_
if (delay_enable != 0) { - adll_tap = MEGA / (freq_val[freq] * 64); + adll_tap = MEGA / (mv_ddr_freq_get(freq) * 64); ddr3_tip_cmd_addr_init_delay(dev_num, adll_tap); }
@@ -787,48 +768,6 @@ static int ddr3_tip_rank_control(u32 dev_num, u32 if_id) return ddr3_tip_rev3_rank_control(dev_num, if_id); }
-/* - * PAD Inverse Flow - */ -static int ddr3_tip_pad_inv(u32 dev_num, u32 if_id) -{ - u32 bus_cnt, data_value, ck_swap_pup_ctrl; - u32 octets_per_if_num = ddr3_tip_dev_attr_get(dev_num, MV_ATTR_OCTET_PER_INTERFACE); - struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); - - for (bus_cnt = 0; bus_cnt < octets_per_if_num; bus_cnt++) { - VALIDATE_BUS_ACTIVE(tm->bus_act_mask, bus_cnt); - if (tm->interface_params[if_id]. - as_bus_params[bus_cnt].is_dqs_swap == 1) { - /* dqs swap */ - ddr3_tip_bus_read_modify_write(dev_num, ACCESS_TYPE_UNICAST, - if_id, bus_cnt, - DDR_PHY_DATA, - PHY_CTRL_PHY_REG, 0xc0, - 0xc0); - } - - if (tm->interface_params[if_id]. - as_bus_params[bus_cnt].is_ck_swap == 1) { - if (bus_cnt <= 1) - data_value = 0x5 << 2; - else - data_value = 0xa << 2; - - /* mask equals data */ - /* ck swap pup is only control pup #0 ! */ - ck_swap_pup_ctrl = 0; - ddr3_tip_bus_read_modify_write(dev_num, ACCESS_TYPE_UNICAST, - if_id, ck_swap_pup_ctrl, - DDR_PHY_CONTROL, - PHY_CTRL_PHY_REG, - data_value, data_value); - } - } - - return MV_OK; -} - /* * Algorithm Parameters Validation */ @@ -1182,7 +1121,7 @@ int ddr3_tip_bus_read_modify_write(u32 dev_num, enum hws_access_type access_type * ADLL Calibration */ int adll_calibration(u32 dev_num, enum hws_access_type access_type, - u32 if_id, enum hws_ddr_freq frequency) + u32 if_id, enum mv_ddr_freq frequency) { struct hws_tip_freq_config_info freq_config_info; u32 bus_cnt = 0; @@ -1229,7 +1168,7 @@ int adll_calibration(u32 dev_num, enum hws_access_type access_type, CHECK_STATUS(ddr3_tip_if_write (dev_num, access_type, if_id, DRAM_PHY_CFG_REG, 0, (0x80000000 | 0x40000000))); - mdelay(100 / (freq_val[frequency] / freq_val[DDR_FREQ_LOW_FREQ])); + mdelay(100 / (mv_ddr_freq_get(frequency)) / mv_ddr_freq_get(MV_DDR_FREQ_LOW_FREQ)); CHECK_STATUS(ddr3_tip_if_write (dev_num, access_type, if_id, DRAM_PHY_CFG_REG, (0x80000000 | 0x40000000), (0x80000000 | 0x40000000))); @@ -1255,7 +1194,7 @@ int adll_calibration(u32 dev_num, enum hws_access_type access_type, }
int ddr3_tip_freq_set(u32 dev_num, enum hws_access_type access_type, - u32 if_id, enum hws_ddr_freq frequency) + u32 if_id, enum mv_ddr_freq frequency) { u32 cl_value = 0, cwl_value = 0, mem_mask = 0, val = 0, bus_cnt = 0, t_wr = 0, t_ckclk = 0, @@ -1263,7 +1202,7 @@ int ddr3_tip_freq_set(u32 dev_num, enum hws_access_type access_type, u32 end_if, start_if; u32 bus_index = 0; int is_dll_off = 0; - enum hws_speed_bin speed_bin_index = 0; + enum mv_ddr_speed_bin speed_bin_index = 0; struct hws_tip_freq_config_info freq_config_info; enum hws_result *flow_result = training_result[training_stage]; u32 adll_tap = 0; @@ -1274,12 +1213,13 @@ int ddr3_tip_freq_set(u32 dev_num, enum hws_access_type access_type, struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); unsigned int tclk; enum mv_ddr_timing timing = tm->interface_params[if_id].timing; + u32 freq = mv_ddr_freq_get(frequency);
DEBUG_TRAINING_IP(DEBUG_LEVEL_TRACE, ("dev %d access %d IF %d freq %d\n", dev_num, access_type, if_id, frequency));
- if (frequency == DDR_FREQ_LOW_FREQ) + if (frequency == MV_DDR_FREQ_LOW_FREQ) is_dll_off = 1; if (access_type == ACCESS_TYPE_MULTICAST) { start_if = 0; @@ -1318,7 +1258,7 @@ int ddr3_tip_freq_set(u32 dev_num, enum hws_access_type access_type, cwl_value = tm->interface_params[if_id].cas_wl; } else if (tm->cfg_src == MV_DDR_CFG_SPD) { - tclk = 1000000 / freq_val[frequency]; + tclk = 1000000 / freq; cl_value = mv_ddr_cl_calc(tm->timing_data[MV_DDR_TAA_MIN], tclk); if (cl_value == 0) { printf("mv_ddr: unsupported cas latency value found\n"); @@ -1330,11 +1270,8 @@ int ddr3_tip_freq_set(u32 dev_num, enum hws_access_type access_type, return MV_FAIL; } } else { - cl_value = - cas_latency_table[speed_bin_index].cl_val[frequency]; - cwl_value = - cas_write_latency_table[speed_bin_index]. - cl_val[frequency]; + cl_value = mv_ddr_cl_val_get(speed_bin_index, frequency); + cwl_value = mv_ddr_cwl_val_get(speed_bin_index, frequency); }
DEBUG_TRAINING_IP(DEBUG_LEVEL_TRACE, @@ -1342,11 +1279,9 @@ int ddr3_tip_freq_set(u32 dev_num, enum hws_access_type access_type, dev_num, access_type, if_id, frequency, speed_bin_index));
- for (cnt_id = 0; cnt_id < DDR_FREQ_LAST; cnt_id++) { + for (cnt_id = 0; cnt_id < MV_DDR_FREQ_LAST; cnt_id++) { DEBUG_TRAINING_IP(DEBUG_LEVEL_TRACE, - ("%d ", - cas_latency_table[speed_bin_index]. - cl_val[cnt_id])); + ("%d ", mv_ddr_cl_val_get(speed_bin_index, cnt_id))); }
DEBUG_TRAINING_IP(DEBUG_LEVEL_TRACE, ("\n")); @@ -1420,7 +1355,7 @@ int ddr3_tip_freq_set(u32 dev_num, enum hws_access_type access_type, t2t = (timing == MV_DDR_TIM_2T) ? 1 : 0; } else { /* Calculate number of CS per interface */ - CHECK_STATUS(calc_cs_num(dev_num, if_id, &cs_num)); + cs_num = mv_ddr_cs_num_get(); t2t = (cs_num == 1) ? 0 : 1; }
@@ -1455,8 +1390,8 @@ int ddr3_tip_freq_set(u32 dev_num, enum hws_access_type access_type, (dev_num, access_type, if_id, DFS_REG, (cwl_mask_table[cwl_value] << 12), 0x7000));
- t_ckclk = (MEGA / freq_val[frequency]); - t_wr = time_to_nclk(speed_bin_table + t_ckclk = (MEGA / freq); + t_wr = time_to_nclk(mv_ddr_speed_bin_timing_get (speed_bin_index, SPEED_BIN_TWR), t_ckclk);
@@ -1517,7 +1452,7 @@ int ddr3_tip_freq_set(u32 dev_num, enum hws_access_type access_type, (dev_num, access_type, if_id, DRAM_PHY_CFG_REG, 0, (0x80000000 | 0x40000000))); - mdelay(100 / (freq_val[frequency] / freq_val[DDR_FREQ_LOW_FREQ])); + mdelay(100 / (freq / mv_ddr_freq_get(MV_DDR_FREQ_LOW_FREQ))); CHECK_STATUS(ddr3_tip_if_write (dev_num, access_type, if_id, DRAM_PHY_CFG_REG, (0x80000000 | 0x40000000), @@ -1544,7 +1479,7 @@ int ddr3_tip_freq_set(u32 dev_num, enum hws_access_type access_type, /* Set proper timing params before existing Self-Refresh */ ddr3_tip_set_timing(dev_num, access_type, if_id, frequency); if (delay_enable != 0) { - adll_tap = (is_dll_off == 1) ? 1000 : (MEGA / (freq_val[frequency] * 64)); + adll_tap = (is_dll_off == 1) ? 1000 : (MEGA / (freq * 64)); ddr3_tip_cmd_addr_init_delay(dev_num, adll_tap); }
@@ -1682,7 +1617,7 @@ static int ddr3_tip_write_odt(u32 dev_num, enum hws_access_type access_type, * Set Timing values for training */ static int ddr3_tip_set_timing(u32 dev_num, enum hws_access_type access_type, - u32 if_id, enum hws_ddr_freq frequency) + u32 if_id, enum mv_ddr_freq frequency) { u32 t_ckclk = 0, t_ras = 0; u32 t_rcd = 0, t_rp = 0, t_wr = 0, t_wtr = 0, t_rrd = 0, t_rtp = 0, @@ -1690,66 +1625,63 @@ static int ddr3_tip_set_timing(u32 dev_num, enum hws_access_type access_type, t_r2w_w2r = 0x3, t_r2w_w2r_high = 0x1, t_w2w = 0x3; u32 refresh_interval_cnt, t_hclk, t_refi, t_faw, t_pd, t_xpdll; u32 val = 0, page_size = 0, mask = 0; - enum hws_speed_bin speed_bin_index; + enum mv_ddr_speed_bin speed_bin_index; enum mv_ddr_die_capacity memory_size = MV_DDR_DIE_CAP_2GBIT; struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); - struct page_element *page_param = mv_ddr_page_tbl_get(); + u32 freq = mv_ddr_freq_get(frequency);
speed_bin_index = tm->interface_params[if_id].speed_bin_index; memory_size = tm->interface_params[if_id].memory_size; - page_size = - (tm->interface_params[if_id].bus_width == - MV_DDR_DEV_WIDTH_8BIT) ? page_param[memory_size]. - page_size_8bit : page_param[memory_size].page_size_16bit; - t_ckclk = (MEGA / freq_val[frequency]); + page_size = mv_ddr_page_size_get(tm->interface_params[if_id].bus_width, memory_size); + t_ckclk = (MEGA / freq); /* HCLK in[ps] */ - t_hclk = MEGA / (freq_val[frequency] / config_func_info[dev_num].tip_get_clock_ratio(frequency)); + t_hclk = MEGA / (freq / config_func_info[dev_num].tip_get_clock_ratio(frequency));
t_refi = (tm->interface_params[if_id].interface_temp == MV_DDR_TEMP_HIGH) ? TREFI_HIGH : TREFI_LOW; t_refi *= 1000; /* psec */ refresh_interval_cnt = t_refi / t_hclk; /* no units */
if (page_size == 1) { - t_faw = speed_bin_table(speed_bin_index, SPEED_BIN_TFAW1K); + t_faw = mv_ddr_speed_bin_timing_get(speed_bin_index, SPEED_BIN_TFAW1K); t_faw = time_to_nclk(t_faw, t_ckclk); t_faw = GET_MAX_VALUE(20, t_faw); } else { /* page size =2, we do not support page size 0.5k */ - t_faw = speed_bin_table(speed_bin_index, SPEED_BIN_TFAW2K); + t_faw = mv_ddr_speed_bin_timing_get(speed_bin_index, SPEED_BIN_TFAW2K); t_faw = time_to_nclk(t_faw, t_ckclk); t_faw = GET_MAX_VALUE(28, t_faw); }
- t_pd = GET_MAX_VALUE(t_ckclk * 3, speed_bin_table(speed_bin_index, SPEED_BIN_TPD)); + t_pd = GET_MAX_VALUE(t_ckclk * 3, mv_ddr_speed_bin_timing_get(speed_bin_index, SPEED_BIN_TPD)); t_pd = time_to_nclk(t_pd, t_ckclk);
- t_xpdll = GET_MAX_VALUE(t_ckclk * 10, speed_bin_table(speed_bin_index, SPEED_BIN_TXPDLL)); + t_xpdll = GET_MAX_VALUE(t_ckclk * 10, mv_ddr_speed_bin_timing_get(speed_bin_index, SPEED_BIN_TXPDLL)); t_xpdll = time_to_nclk(t_xpdll, t_ckclk);
- t_rrd = (page_size == 1) ? speed_bin_table(speed_bin_index, + t_rrd = (page_size == 1) ? mv_ddr_speed_bin_timing_get(speed_bin_index, SPEED_BIN_TRRD1K) : - speed_bin_table(speed_bin_index, SPEED_BIN_TRRD2K); + mv_ddr_speed_bin_timing_get(speed_bin_index, SPEED_BIN_TRRD2K); t_rrd = GET_MAX_VALUE(t_ckclk * 4, t_rrd); - t_rtp = GET_MAX_VALUE(t_ckclk * 4, speed_bin_table(speed_bin_index, + t_rtp = GET_MAX_VALUE(t_ckclk * 4, mv_ddr_speed_bin_timing_get(speed_bin_index, SPEED_BIN_TRTP)); t_mod = GET_MAX_VALUE(t_ckclk * 12, 15000); - t_wtr = GET_MAX_VALUE(t_ckclk * 4, speed_bin_table(speed_bin_index, + t_wtr = GET_MAX_VALUE(t_ckclk * 4, mv_ddr_speed_bin_timing_get(speed_bin_index, SPEED_BIN_TWTR)); - t_ras = time_to_nclk(speed_bin_table(speed_bin_index, + t_ras = time_to_nclk(mv_ddr_speed_bin_timing_get(speed_bin_index, SPEED_BIN_TRAS), t_ckclk); - t_rcd = time_to_nclk(speed_bin_table(speed_bin_index, + t_rcd = time_to_nclk(mv_ddr_speed_bin_timing_get(speed_bin_index, SPEED_BIN_TRCD), t_ckclk); - t_rp = time_to_nclk(speed_bin_table(speed_bin_index, + t_rp = time_to_nclk(mv_ddr_speed_bin_timing_get(speed_bin_index, SPEED_BIN_TRP), t_ckclk); - t_wr = time_to_nclk(speed_bin_table(speed_bin_index, + t_wr = time_to_nclk(mv_ddr_speed_bin_timing_get(speed_bin_index, SPEED_BIN_TWR), t_ckclk); t_wtr = time_to_nclk(t_wtr, t_ckclk); t_rrd = time_to_nclk(t_rrd, t_ckclk); t_rtp = time_to_nclk(t_rtp, t_ckclk); - t_rfc = time_to_nclk(rfc_table[memory_size] * 1000, t_ckclk); + t_rfc = time_to_nclk(mv_ddr_rfc_get(memory_size) * 1000, t_ckclk); t_mod = time_to_nclk(t_mod, t_ckclk);
/* SDRAM Timing Low */ @@ -1826,68 +1758,6 @@ static int ddr3_tip_set_timing(u32 dev_num, enum hws_access_type access_type, }
-/* - * Mode Read - */ -int hws_ddr3_tip_mode_read(u32 dev_num, struct mode_info *mode_info) -{ - u32 ret; - - ret = ddr3_tip_if_read(dev_num, ACCESS_TYPE_MULTICAST, PARAM_NOT_CARE, - MR0_REG, mode_info->reg_mr0, MASK_ALL_BITS); - if (ret != MV_OK) - return ret; - - ret = ddr3_tip_if_read(dev_num, ACCESS_TYPE_MULTICAST, PARAM_NOT_CARE, - MR1_REG, mode_info->reg_mr1, MASK_ALL_BITS); - if (ret != MV_OK) - return ret; - - ret = ddr3_tip_if_read(dev_num, ACCESS_TYPE_MULTICAST, PARAM_NOT_CARE, - MR2_REG, mode_info->reg_mr2, MASK_ALL_BITS); - if (ret != MV_OK) - return ret; - - ret = ddr3_tip_if_read(dev_num, ACCESS_TYPE_MULTICAST, PARAM_NOT_CARE, - MR3_REG, mode_info->reg_mr2, MASK_ALL_BITS); - if (ret != MV_OK) - return ret; - - ret = ddr3_tip_if_read(dev_num, ACCESS_TYPE_MULTICAST, PARAM_NOT_CARE, - RD_DATA_SMPL_DLYS_REG, mode_info->read_data_sample, - MASK_ALL_BITS); - if (ret != MV_OK) - return ret; - - ret = ddr3_tip_if_read(dev_num, ACCESS_TYPE_MULTICAST, PARAM_NOT_CARE, - RD_DATA_RDY_DLYS_REG, mode_info->read_data_ready, - MASK_ALL_BITS); - if (ret != MV_OK) - return ret; - - return MV_OK; -} - -/* - * Get first active IF - */ -int ddr3_tip_get_first_active_if(u8 dev_num, u32 interface_mask, - u32 *interface_id) -{ - u32 if_id; - struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); - - for (if_id = 0; if_id <= MAX_INTERFACE_NUM - 1; if_id++) { - VALIDATE_IF_ACTIVE(tm->if_act_mask, if_id); - if (interface_mask & (1 << if_id)) { - *interface_id = if_id; - break; - } - } - - return MV_OK; -} - /* * Write CS Result */ @@ -2139,9 +2009,10 @@ static int ddr3_tip_ddr3_training_main_flow(u32 dev_num) int ret = MV_OK; int adll_bypass_flag = 0; u32 if_id; - u32 max_cs = ddr3_tip_max_cs_get(dev_num); + unsigned int max_cs = mv_ddr_cs_num_get(); struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); - enum hws_ddr_freq freq = tm->interface_params[0].memory_freq; + enum mv_ddr_freq freq = tm->interface_params[0].memory_freq; + unsigned int *freq_tbl = mv_ddr_freq_tbl_get();
#ifdef DDR_VIEWER_TOOL if (debug_training == DEBUG_LEVEL_TRACE) { @@ -2157,7 +2028,7 @@ static int ddr3_tip_ddr3_training_main_flow(u32 dev_num) /* Set to 0 after each loop to avoid illegal value may be used */ effective_cs = 0;
- freq_val[DDR_FREQ_LOW_FREQ] = dfs_low_freq; + freq_tbl[MV_DDR_FREQ_LOW_FREQ] = dfs_low_freq;
if (is_pll_before_init != 0) { for (if_id = 0; if_id < MAX_INTERFACE_NUM; if_id++) { @@ -2220,7 +2091,7 @@ static int ddr3_tip_ddr3_training_main_flow(u32 dev_num)
DEBUG_TRAINING_IP(DEBUG_LEVEL_INFO, ("SET_LOW_FREQ_MASK_BIT %d\n", - freq_val[low_freq])); + freq_tbl[low_freq])); ret = ddr3_tip_freq_set(dev_num, ACCESS_TYPE_MULTICAST, PARAM_NOT_CARE, low_freq); if (is_reg_dump != 0) @@ -2281,7 +2152,7 @@ static int ddr3_tip_ddr3_training_main_flow(u32 dev_num) training_stage = SET_MEDIUM_FREQ; DEBUG_TRAINING_IP(DEBUG_LEVEL_INFO, ("SET_MEDIUM_FREQ_MASK_BIT %d\n", - freq_val[medium_freq])); + freq_tbl[medium_freq])); ret = ddr3_tip_freq_set(dev_num, ACCESS_TYPE_MULTICAST, PARAM_NOT_CARE, medium_freq); @@ -2299,7 +2170,7 @@ static int ddr3_tip_ddr3_training_main_flow(u32 dev_num) training_stage = WRITE_LEVELING; DEBUG_TRAINING_IP(DEBUG_LEVEL_INFO, ("WRITE_LEVELING_MASK_BIT\n")); - if ((rl_mid_freq_wa == 0) || (freq_val[medium_freq] == 533)) { + if ((rl_mid_freq_wa == 0) || (freq_tbl[medium_freq] == 533)) { ret = ddr3_tip_dynamic_write_leveling(dev_num, 0); } else { /* Use old WL */ @@ -2341,7 +2212,7 @@ static int ddr3_tip_ddr3_training_main_flow(u32 dev_num) training_stage = READ_LEVELING; DEBUG_TRAINING_IP(DEBUG_LEVEL_INFO, ("READ_LEVELING_MASK_BIT\n")); - if ((rl_mid_freq_wa == 0) || (freq_val[medium_freq] == 533)) { + if ((rl_mid_freq_wa == 0) || (freq_tbl[medium_freq] == 533)) { ret = ddr3_tip_dynamic_read_leveling(dev_num, medium_freq); } else { /* Use old RL */ @@ -2417,19 +2288,13 @@ static int ddr3_tip_ddr3_training_main_flow(u32 dev_num) training_stage = SET_TARGET_FREQ; DEBUG_TRAINING_IP(DEBUG_LEVEL_INFO, ("SET_TARGET_FREQ_MASK_BIT %d\n", - freq_val[tm-> + freq_tbl[tm-> interface_params[first_active_if]. memory_freq])); ret = ddr3_tip_freq_set(dev_num, ACCESS_TYPE_MULTICAST, PARAM_NOT_CARE, tm->interface_params[first_active_if]. memory_freq); -#if defined(A70X0) || defined(A80X0) - if (apn806_rev_id_get() == APN806_REV_ID_A0) { - reg_write(0x6f812c, extension_avs); - reg_write(0x6f8130, nominal_avs); - } -#endif /* #if defined(A70X0) || defined(A80X0) */ if (is_reg_dump != 0) ddr3_tip_reg_dump(dev_num); if (ret != MV_OK) { @@ -2892,3 +2757,140 @@ int hws_ddr3_cs_base_adr_calc(u32 if_id, u32 cs, u32 *cs_base_addr)
return MV_OK; } + +/* TODO: consider to move to misl phy driver */ +enum { + MISL_PHY_DRV_OHM_30 = 0xf, + MISL_PHY_DRV_OHM_48 = 0xa, + MISL_PHY_DRV_OHM_80 = 0x6, + MISL_PHY_DRV_OHM_120 = 0x4 +}; + +enum { + MISL_PHY_ODT_OHM_60 = 0x8, + MISL_PHY_ODT_OHM_80 = 0x6, + MISL_PHY_ODT_OHM_120 = 0x4, + MISL_PHY_ODT_OHM_240 = 0x2 +}; + +static unsigned int mv_ddr_misl_phy_drv_calc(unsigned int cfg) +{ + unsigned int val; + + switch (cfg) { + case MV_DDR_OHM_30: + val = MISL_PHY_DRV_OHM_30; + break; + case MV_DDR_OHM_48: + val = MISL_PHY_DRV_OHM_48; + break; + case MV_DDR_OHM_80: + val = MISL_PHY_DRV_OHM_80; + break; + case MV_DDR_OHM_120: + val = MISL_PHY_DRV_OHM_120; + break; + default: + val = PARAM_UNDEFINED; + } + + return val; +} + +static unsigned int mv_ddr_misl_phy_odt_calc(unsigned int cfg) +{ + unsigned int val; + + switch (cfg) { + case MV_DDR_OHM_60: + val = MISL_PHY_ODT_OHM_60; + break; + case MV_DDR_OHM_80: + val = MISL_PHY_ODT_OHM_80; + break; + case MV_DDR_OHM_120: + val = MISL_PHY_ODT_OHM_120; + break; + case MV_DDR_OHM_240: + val = MISL_PHY_ODT_OHM_240; + break; + default: + val = PARAM_UNDEFINED; + } + + return val; +} + +unsigned int mv_ddr_misl_phy_drv_data_p_get(void) +{ + struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); + unsigned int drv_data_p = mv_ddr_misl_phy_drv_calc(tm->edata.phy_edata.drv_data_p); + + if (drv_data_p == PARAM_UNDEFINED) + printf("error: %s: unsupported drv_data_p parameter found\n", __func__); + + return drv_data_p; +} + +unsigned int mv_ddr_misl_phy_drv_data_n_get(void) +{ + struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); + unsigned int drv_data_n = mv_ddr_misl_phy_drv_calc(tm->edata.phy_edata.drv_data_n); + + if (drv_data_n == PARAM_UNDEFINED) + printf("error: %s: unsupported drv_data_n parameter found\n", __func__); + + return drv_data_n; +} + +unsigned int mv_ddr_misl_phy_drv_ctrl_p_get(void) +{ + struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); + unsigned int drv_ctrl_p = mv_ddr_misl_phy_drv_calc(tm->edata.phy_edata.drv_ctrl_p); + + if (drv_ctrl_p == PARAM_UNDEFINED) + printf("error: %s: unsupported drv_ctrl_p parameter found\n", __func__); + + return drv_ctrl_p; +} + +unsigned int mv_ddr_misl_phy_drv_ctrl_n_get(void) +{ + struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); + unsigned int drv_ctrl_n = mv_ddr_misl_phy_drv_calc(tm->edata.phy_edata.drv_ctrl_n); + + if (drv_ctrl_n == PARAM_UNDEFINED) + printf("error: %s: unsupported drv_ctrl_n parameter found\n", __func__); + + return drv_ctrl_n; +} + +unsigned int mv_ddr_misl_phy_odt_p_get(void) +{ + struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); + unsigned int cs_num = mv_ddr_cs_num_get(); + unsigned int odt_p = PARAM_UNDEFINED; + + if (cs_num > 0 && cs_num <= MAX_CS_NUM) + odt_p = mv_ddr_misl_phy_odt_calc(tm->edata.phy_edata.odt_p[cs_num - 1]); + + if (odt_p == PARAM_UNDEFINED) + printf("error: %s: unsupported odt_p parameter found\n", __func__); + + return odt_p; +} + +unsigned int mv_ddr_misl_phy_odt_n_get(void) +{ + struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); + unsigned int cs_num = mv_ddr_cs_num_get(); + unsigned int odt_n = PARAM_UNDEFINED; + + if (cs_num > 0 && cs_num <= MAX_CS_NUM) + odt_n = mv_ddr_misl_phy_odt_calc(tm->edata.phy_edata.odt_n[cs_num - 1]); + + if (odt_n == PARAM_UNDEFINED) + printf("error: %s: unsupported odt_n parameter found\n", __func__); + + return odt_n; +} diff --git a/drivers/ddr/marvell/a38x/ddr3_training_bist.c b/drivers/ddr/marvell/a38x/ddr3_training_bist.c index e29b1713f9a0..d388a172918f 100644 --- a/drivers/ddr/marvell/a38x/ddr3_training_bist.c +++ b/drivers/ddr/marvell/a38x/ddr3_training_bist.c @@ -4,6 +4,7 @@ */
#include "ddr3_init.h" +#include "mv_ddr_regs.h"
static u32 bist_offset = 32; enum hws_pattern sweep_pattern = PATTERN_KILLER_DQ0; diff --git a/drivers/ddr/marvell/a38x/ddr3_training_centralization.c b/drivers/ddr/marvell/a38x/ddr3_training_centralization.c index 03e5c9fdcea3..648b37ef6f79 100644 --- a/drivers/ddr/marvell/a38x/ddr3_training_centralization.c +++ b/drivers/ddr/marvell/a38x/ddr3_training_centralization.c @@ -4,6 +4,7 @@ */
#define VALIDATE_WIN_LENGTH(e1, e2, maxsize) \ (((e2) + 1 > (e1) + (u8)MIN_WINDOW_SIZE) && \ @@ -698,6 +699,8 @@ int ddr3_tip_print_centralization_result(u32 dev_num) u32 octets_per_if_num = ddr3_tip_dev_attr_get(dev_num, MV_ATTR_OCTET_PER_INTERFACE); struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get();
+ dev_num = dev_num; + printf("Centralization Results\n"); printf("I/F0 Result[0 - success 1-fail 2 - state_2 3 - state_3] ...\n"); for (if_id = 0; if_id <= MAX_INTERFACE_NUM - 1; if_id++) { diff --git a/drivers/ddr/marvell/a38x/ddr3_training_db.c b/drivers/ddr/marvell/a38x/ddr3_training_db.c index c0089f67f271..111a8586c6e3 100644 --- a/drivers/ddr/marvell/a38x/ddr3_training_db.c +++ b/drivers/ddr/marvell/a38x/ddr3_training_db.c @@ -3,11 +3,16 @@ * Copyright (C) Marvell International Ltd. and its affiliates */
-#include "ddr3_init.h" +#include "ddr_ml_wrapper.h" + +#include "ddr3_training_ip_flow.h" +#include "mv_ddr_topology.h" +#include "mv_ddr_training_db.h" +#include "ddr3_training_ip_db.h"
/* Device attributes structures */ -enum mv_ddr_dev_attribute ddr_dev_attributes[MAX_DEVICE_NUM][MV_ATTR_LAST]; -int ddr_dev_attr_init_done[MAX_DEVICE_NUM] = { 0 }; +enum mv_ddr_dev_attribute ddr_dev_attributes[MV_ATTR_LAST]; +int ddr_dev_attr_init_done = 0;
static inline u32 pattern_table_get_killer_word16(u8 dqs, u8 index); static inline u32 pattern_table_get_sso_word(u8 sso, u8 index); @@ -20,28 +25,38 @@ static inline u32 pattern_table_get_sso_xtalk_free_word16(u8 bit, u8 index); static inline u32 pattern_table_get_isi_word(u8 index); static inline u32 pattern_table_get_isi_word16(u8 index);
-/* List of allowed frequency listed in order of enum hws_ddr_freq */ -u32 freq_val[DDR_FREQ_LAST] = { - 0, /*DDR_FREQ_LOW_FREQ */ - 400, /*DDR_FREQ_400, */ - 533, /*DDR_FREQ_533, */ - 666, /*DDR_FREQ_667, */ - 800, /*DDR_FREQ_800, */ - 933, /*DDR_FREQ_933, */ - 1066, /*DDR_FREQ_1066, */ - 311, /*DDR_FREQ_311, */ - 333, /*DDR_FREQ_333, */ - 467, /*DDR_FREQ_467, */ - 850, /*DDR_FREQ_850, */ - 600, /*DDR_FREQ_600 */ - 300, /*DDR_FREQ_300 */ - 900, /*DDR_FREQ_900 */ - 360, /*DDR_FREQ_360 */ - 1000 /*DDR_FREQ_1000 */ +/* List of allowed frequency listed in order of enum mv_ddr_freq */ +static unsigned int freq_val[MV_DDR_FREQ_LAST] = { + 0, /*MV_DDR_FREQ_LOW_FREQ */ + 400, /*MV_DDR_FREQ_400, */ + 533, /*MV_DDR_FREQ_533, */ + 666, /*MV_DDR_FREQ_667, */ + 800, /*MV_DDR_FREQ_800, */ + 933, /*MV_DDR_FREQ_933, */ + 1066, /*MV_DDR_FREQ_1066, */ + 311, /*MV_DDR_FREQ_311, */ + 333, /*MV_DDR_FREQ_333, */ + 467, /*MV_DDR_FREQ_467, */ + 850, /*MV_DDR_FREQ_850, */ + 600, /*MV_DDR_FREQ_600 */ + 300, /*MV_DDR_FREQ_300 */ + 900, /*MV_DDR_FREQ_900 */ + 360, /*MV_DDR_FREQ_360 */ + 1000 /*MV_DDR_FREQ_1000 */ };
-/* Table for CL values per frequency for each speed bin index */ -struct cl_val_per_freq cas_latency_table[] = { +unsigned int *mv_ddr_freq_tbl_get(void) +{ + return &freq_val[0]; +} + +u32 mv_ddr_freq_get(enum mv_ddr_freq freq) +{ + return freq_val[freq]; +} + +/* cas latency values per frequency for each speed bin index */ +static struct mv_ddr_cl_val_per_freq cl_table[] = { /* * 400M 667M 933M 311M 467M 600M 360 * 100M 533M 800M 1066M 333M 850M 900 @@ -97,8 +112,13 @@ struct cl_val_per_freq cas_latency_table[] = { { {6, 6, 7, 9, 11, 13, 0, 6, 6, 7, 13, 9, 6, 13, 6, 13} }, };
-/* Table for CWL values per speedbin index */ -struct cl_val_per_freq cas_write_latency_table[] = { +u32 mv_ddr_cl_val_get(u32 index, u32 freq) +{ + return cl_table[index].cl_val[freq]; +} + +/* cas write latency values per frequency for each speed bin index */ +static struct mv_ddr_cl_val_per_freq cwl_table[] = { /* * 400M 667M 933M 311M 467M 600M 360 * 100M 533M 800M 1066M 333M 850M 900 @@ -154,6 +174,11 @@ struct cl_val_per_freq cas_write_latency_table[] = { { {5, 5, 6, 7, 8, 9, 0, 5, 5, 6, 9, 7, 5, 9, 5, 9} }, };
+u32 mv_ddr_cwl_val_get(u32 index, u32 freq) +{ + return cwl_table[index].cl_val[freq]; +} + u8 twr_mask_table[] = { 10, 10, @@ -213,18 +238,23 @@ u8 cwl_mask_table[] = { };
/* RFC values (in ns) */ -u16 rfc_table[] = { - 90, /* 512M */ - 110, /* 1G */ - 160, /* 2G */ - 260, /* 4G */ - 350, /* 8G */ - 0, /* TODO: placeholder for 16-Mbit dev width */ - 0, /* TODO: placeholder for 32-Mbit dev width */ - 0, /* TODO: placeholder for 12-Mbit dev width */ - 0 /* TODO: placeholder for 24-Mbit dev width */ +static unsigned int rfc_table[] = { + 90, /* 512M */ + 110, /* 1G */ + 160, /* 2G */ + 260, /* 4G */ + 350, /* 8G */ + 0, /* TODO: placeholder for 16-Mbit dev width */ + 0, /* TODO: placeholder for 32-Mbit dev width */ + 0, /* TODO: placeholder for 12-Mbit dev width */ + 0 /* TODO: placeholder for 24-Mbit dev width */ };
+u32 mv_ddr_rfc_get(u32 mem) +{ + return rfc_table[mem]; +} + u32 speed_bin_table_t_rc[] = { 50000, 52500, @@ -358,8 +388,29 @@ static u8 pattern_vref_pattern_table_map[] = { 0xfe };
+static struct mv_ddr_page_element page_tbl[] = { + /* 8-bit, 16-bit page size */ + {MV_DDR_PAGE_SIZE_1K, MV_DDR_PAGE_SIZE_2K}, /* 512M */ + {MV_DDR_PAGE_SIZE_1K, MV_DDR_PAGE_SIZE_2K}, /* 1G */ + {MV_DDR_PAGE_SIZE_1K, MV_DDR_PAGE_SIZE_2K}, /* 2G */ + {MV_DDR_PAGE_SIZE_1K, MV_DDR_PAGE_SIZE_2K}, /* 4G */ + {MV_DDR_PAGE_SIZE_2K, MV_DDR_PAGE_SIZE_2K}, /* 8G */ + {0, 0}, /* TODO: placeholder for 16-Mbit die capacity */ + {0, 0}, /* TODO: placeholder for 32-Mbit die capacity */ + {0, 0}, /* TODO: placeholder for 12-Mbit die capacity */ + {0, 0} /* TODO: placeholder for 24-Mbit die capacity */ +}; + +u32 mv_ddr_page_size_get(enum mv_ddr_dev_width bus_width, enum mv_ddr_die_capacity mem_size) +{ + if (bus_width == MV_DDR_DEV_WIDTH_8BIT) + return page_tbl[mem_size].page_size_8bit; + else + return page_tbl[mem_size].page_size_16bit; +} + /* Return speed Bin value for selected index and t* element */ -u32 speed_bin_table(u8 index, enum speed_bin_table_elements element) +unsigned int mv_ddr_speed_bin_timing_get(enum mv_ddr_speed_bin index, enum mv_ddr_speed_bin_timing element) { u32 result = 0;
@@ -384,19 +435,19 @@ u32 speed_bin_table(u8 index, enum speed_bin_table_elements element) result = speed_bin_table_t_rc[index]; break; case SPEED_BIN_TRRD1K: - if (index < SPEED_BIN_DDR_800E) + if (index <= SPEED_BIN_DDR_800E) result = 10000; - else if (index < SPEED_BIN_DDR_1066G) + else if (index <= SPEED_BIN_DDR_1066G) result = 7500; - else if (index < SPEED_BIN_DDR_1600K) + else if (index <= SPEED_BIN_DDR_1600K) result = 6000; else result = 5000; break; case SPEED_BIN_TRRD2K: - if (index < SPEED_BIN_DDR_1066G) + if (index <= SPEED_BIN_DDR_1066G) result = 10000; - else if (index < SPEED_BIN_DDR_1600K) + else if (index <= SPEED_BIN_DDR_1600K) result = 7500; else result = 6000; @@ -410,23 +461,23 @@ u32 speed_bin_table(u8 index, enum speed_bin_table_elements element) result = 5000; break; case SPEED_BIN_TFAW1K: - if (index < SPEED_BIN_DDR_800E) + if (index <= SPEED_BIN_DDR_800E) result = 40000; - else if (index < SPEED_BIN_DDR_1066G) + else if (index <= SPEED_BIN_DDR_1066G) result = 37500; - else if (index < SPEED_BIN_DDR_1600K) + else if (index <= SPEED_BIN_DDR_1600K) result = 30000; - else if (index < SPEED_BIN_DDR_1866M) + else if (index <= SPEED_BIN_DDR_1866M) result = 27000; else result = 25000; break; case SPEED_BIN_TFAW2K: - if (index < SPEED_BIN_DDR_1066G) + if (index <= SPEED_BIN_DDR_1066G) result = 50000; - else if (index < SPEED_BIN_DDR_1333J) + else if (index <= SPEED_BIN_DDR_1333J) result = 45000; - else if (index < SPEED_BIN_DDR_1600K) + else if (index <= SPEED_BIN_DDR_1600K) result = 40000; else result = 35000; @@ -446,6 +497,9 @@ u32 speed_bin_table(u8 index, enum speed_bin_table_elements element) case SPEED_BIN_TXPDLL: result = 24000; break; + case SPEED_BIN_TXSDLL: + result = 512; + break; default: break; } @@ -608,7 +662,7 @@ static inline u32 pattern_table_get_static_pbs_word(u8 index)
u32 pattern_table_get_word(u32 dev_num, enum hws_pattern type, u8 index) { - u32 pattern; + u32 pattern = 0; struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get();
if (DDR3_IS_16BIT_DRAM_MODE(tm->bus_act_mask) == 0) { @@ -696,8 +750,8 @@ u32 pattern_table_get_word(u32 dev_num, enum hws_pattern type, u8 index) pattern = pattern_table_get_isi_word(index); break; default: - DEBUG_TRAINING_IP(DEBUG_LEVEL_ERROR, ("Error: %s: pattern type [%d] not supported\n", - __func__, (int)type)); + printf("error: %s: unsupported pattern type [%d] found\n", + __func__, (int)type); pattern = 0; break; } @@ -779,8 +833,8 @@ u32 pattern_table_get_word(u32 dev_num, enum hws_pattern type, u8 index) pattern = pattern_table_get_isi_word16(index); break; default: - DEBUG_TRAINING_IP(DEBUG_LEVEL_ERROR, ("Error: %s: pattern type [%d] not supported\n", - __func__, (int)type)); + printf("error: %s: unsupported pattern type [%d] found\n", + __func__, (int)type); pattern = 0; break; } @@ -795,23 +849,23 @@ void ddr3_tip_dev_attr_init(u32 dev_num) u32 attr_id;
for (attr_id = 0; attr_id < MV_ATTR_LAST; attr_id++) - ddr_dev_attributes[dev_num][attr_id] = 0xFF; + ddr_dev_attributes[attr_id] = 0xFF;
- ddr_dev_attr_init_done[dev_num] = 1; + ddr_dev_attr_init_done = 1; }
u32 ddr3_tip_dev_attr_get(u32 dev_num, enum mv_ddr_dev_attribute attr_id) { - if (ddr_dev_attr_init_done[dev_num] == 0) + if (ddr_dev_attr_init_done == 0) ddr3_tip_dev_attr_init(dev_num);
- return ddr_dev_attributes[dev_num][attr_id]; + return ddr_dev_attributes[attr_id]; }
void ddr3_tip_dev_attr_set(u32 dev_num, enum mv_ddr_dev_attribute attr_id, u32 value) { - if (ddr_dev_attr_init_done[dev_num] == 0) + if (ddr_dev_attr_init_done == 0) ddr3_tip_dev_attr_init(dev_num);
- ddr_dev_attributes[dev_num][attr_id] = value; + ddr_dev_attributes[attr_id] = value; } diff --git a/drivers/ddr/marvell/a38x/ddr3_training_hw_algo.c b/drivers/ddr/marvell/a38x/ddr3_training_hw_algo.c index 6b8aae83d759..db0f8ad7fb55 100644 --- a/drivers/ddr/marvell/a38x/ddr3_training_hw_algo.c +++ b/drivers/ddr/marvell/a38x/ddr3_training_hw_algo.c @@ -4,6 +4,7 @@ */
#define VREF_INITIAL_STEP 3 #define VREF_SECOND_STEP 1 diff --git a/drivers/ddr/marvell/a38x/ddr3_training_ip.h b/drivers/ddr/marvell/a38x/ddr3_training_ip.h index 531103c1abd5..056c21497c85 100644 --- a/drivers/ddr/marvell/a38x/ddr3_training_ip.h +++ b/drivers/ddr/marvell/a38x/ddr3_training_ip.h @@ -6,12 +6,8 @@ #ifndef _DDR3_TRAINING_IP_H_ #define _DDR3_TRAINING_IP_H_
-#include "ddr3_training_ip_def.h" #include "ddr_topology_def.h" -#include "ddr_training_ip_db.h"
-#define MAX_CS_NUM 4 -#define MAX_TOTAL_BUS_NUM (MAX_INTERFACE_NUM * MAX_BUS_NUM) #define TIP_ENG_LOCK 0x02000000 #define TIP_TX_DLL_RANGE_MAX 64
@@ -112,40 +108,11 @@ struct pattern_info { u8 pattern_len; };
-/* CL value for each frequency */ -struct cl_val_per_freq { - u8 cl_val[DDR_FREQ_LAST]; -}; - struct cs_element { u8 cs_num; u8 num_of_cs; };
-struct mode_info { - /* 32 bits representing MRS bits */ - u32 reg_mr0[MAX_INTERFACE_NUM]; - u32 reg_mr1[MAX_INTERFACE_NUM]; - u32 reg_mr2[MAX_INTERFACE_NUM]; - u32 reg_m_r3[MAX_INTERFACE_NUM]; - /* - * Each element in array represent read_data_sample register delay for - * a specific interface. - * Each register, 4 bits[0+CS*8 to 4+CS*8] represent Number of DDR - * cycles from read command until data is ready to be fetched from - * the PHY, when accessing CS. - */ - u32 read_data_sample[MAX_INTERFACE_NUM]; - /* - * Each element in array represent read_data_sample register delay for - * a specific interface. - * Each register, 4 bits[0+CS*8 to 4+CS*8] represent the total delay - * from read command until opening the read mask, when accessing CS. - * This field defines the delay in DDR cycles granularity. - */ - u32 read_data_ready[MAX_INTERFACE_NUM]; -}; - struct hws_tip_freq_config_info { u8 is_supported; u8 bw_per_freq; @@ -173,12 +140,7 @@ int hws_ddr3_tip_init_controller(u32 dev_num, int hws_ddr3_tip_load_topology_map(u32 dev_num, struct mv_ddr_topology_map *topology); int hws_ddr3_tip_run_alg(u32 dev_num, enum hws_algo_type algo_type); -int hws_ddr3_tip_mode_read(u32 dev_num, struct mode_info *mode_info); -int hws_ddr3_tip_read_training_result(u32 dev_num, - enum hws_result result[MAX_STAGE_LIMIT][MAX_INTERFACE_NUM]); int ddr3_tip_is_pup_lock(u32 *pup_buf, enum hws_training_result read_mode); u8 ddr3_tip_get_buf_min(u8 *buf_ptr); u8 ddr3_tip_get_buf_max(u8 *buf_ptr); -uint64_t mv_ddr_get_memory_size_per_cs_in_bits(void); -uint64_t mv_ddr_get_total_memory_size_in_bits(void); #endif /* _DDR3_TRAINING_IP_H_ */ diff --git a/drivers/ddr/marvell/a38x/ddr3_training_ip_def.h b/drivers/ddr/marvell/a38x/ddr3_training_ip_def.h index 2318ceba2920..2a68669f36c0 100644 --- a/drivers/ddr/marvell/a38x/ddr3_training_ip_def.h +++ b/drivers/ddr/marvell/a38x/ddr3_training_ip_def.h @@ -75,32 +75,6 @@ #define GET_RESULT_STATE(res) (res) #define SET_RESULT_STATE(res, state) (res = state)
-#define _1K 0x00000400 -#define _4K 0x00001000 -#define _8K 0x00002000 -#define _16K 0x00004000 -#define _32K 0x00008000 -#define _64K 0x00010000 -#define _128K 0x00020000 -#define _256K 0x00040000 -#define _512K 0x00080000 - -#define _1M 0x00100000 -#define _2M 0x00200000 -#define _4M 0x00400000 -#define _8M 0x00800000 -#define _16M 0x01000000 -#define _32M 0x02000000 -#define _64M 0x04000000 -#define _128M 0x08000000 -#define _256M 0x10000000 -#define _512M 0x20000000 - -#define _1G 0x40000000 -#define _2G 0x80000000 -#define _4G 0x100000000 -#define _8G 0x200000000 - #define ADDR_SIZE_512MB 0x04000000 #define ADDR_SIZE_1GB 0x08000000 #define ADDR_SIZE_2GB 0x10000000 @@ -126,11 +100,6 @@ enum hws_search_dir { HWS_SEARCH_DIR_LIMIT };
-enum hws_page_size { - PAGE_SIZE_1K, - PAGE_SIZE_2K -}; - enum hws_operation { OPERATION_READ = 0, OPERATION_WRITE = 1 diff --git a/drivers/ddr/marvell/a38x/ddr3_training_ip_engine.c b/drivers/ddr/marvell/a38x/ddr3_training_ip_engine.c index 334c2906fdbf..74417d61b4c5 100644 --- a/drivers/ddr/marvell/a38x/ddr3_training_ip_engine.c +++ b/drivers/ddr/marvell/a38x/ddr3_training_ip_engine.c @@ -4,6 +4,8 @@ */
#include "ddr3_init.h" +#include "mv_ddr_regs.h" +#include "ddr_training_ip_db.h"
#define PATTERN_1 0x55555555 #define PATTERN_2 0xaaaaaaaa diff --git a/drivers/ddr/marvell/a38x/ddr3_training_ip_engine.h b/drivers/ddr/marvell/a38x/ddr3_training_ip_engine.h index 8fbcff50bb26..2d40e68db861 100644 --- a/drivers/ddr/marvell/a38x/ddr3_training_ip_engine.h +++ b/drivers/ddr/marvell/a38x/ddr3_training_ip_engine.h @@ -8,6 +8,7 @@
#include "ddr3_training_ip_def.h" #include "ddr3_training_ip_flow.h" +#include "ddr3_training_ip_pbs.h"
#define EDGE_1 0 #define EDGE_2 1 diff --git a/drivers/ddr/marvell/a38x/ddr3_training_ip_flow.h b/drivers/ddr/marvell/a38x/ddr3_training_ip_flow.h index 6a9ef35f6433..ab152cb455e9 100644 --- a/drivers/ddr/marvell/a38x/ddr3_training_ip_flow.h +++ b/drivers/ddr/marvell/a38x/ddr3_training_ip_flow.h @@ -7,71 +7,17 @@ #define _DDR3_TRAINING_IP_FLOW_H_
#include "ddr3_training_ip.h" -#include "ddr3_training_ip_pbs.h" -#include "mv_ddr_regs.h" +#include "ddr3_training_ip_db.h"
#define KILLER_PATTERN_LENGTH 32 #define EXT_ACCESS_BURST_LENGTH 8
-#define IS_ACTIVE(mask, id) \ - ((mask) & (1 << (id))) - -#define VALIDATE_ACTIVE(mask, id) \ - { \ - if (IS_ACTIVE(mask, id) == 0) \ - continue; \ - } - -#define IS_IF_ACTIVE(if_mask, if_id) \ - ((if_mask) & (1 << (if_id))) - -#define VALIDATE_IF_ACTIVE(mask, id) \ - { \ - if (IS_IF_ACTIVE(mask, id) == 0) \ - continue; \ - } - -#define IS_BUS_ACTIVE(if_mask , if_id) \ - (((if_mask) >> (if_id)) & 1) - -#define VALIDATE_BUS_ACTIVE(mask, id) \ - { \ - if (IS_BUS_ACTIVE(mask, id) == 0) \ - continue; \ - } - -#define DDR3_IS_ECC_PUP3_MODE(if_mask) \ - (((if_mask) == BUS_MASK_16BIT_ECC_PUP3) ? 1 : 0) - -#define DDR3_IS_ECC_PUP4_MODE(if_mask) \ - ((if_mask == BUS_MASK_32BIT_ECC || if_mask == BUS_MASK_16BIT_ECC) ? 1 : 0) - -#define DDR3_IS_16BIT_DRAM_MODE(mask) \ - ((mask == BUS_MASK_16BIT || mask == BUS_MASK_16BIT_ECC || mask == BUS_MASK_16BIT_ECC_PUP3) ? 1 : 0) - -#define DDR3_IS_ECC_PUP8_MODE(if_mask) \ - ((if_mask == MV_DDR_32BIT_ECC_PUP8_BUS_MASK || if_mask == MV_DDR_64BIT_ECC_PUP8_BUS_MASK) ? 1 : 0) - -#define MV_DDR_IS_64BIT_DRAM_MODE(mask) \ - ((((mask) & MV_DDR_64BIT_BUS_MASK) == MV_DDR_64BIT_BUS_MASK) || \ - (((mask) & MV_DDR_64BIT_ECC_PUP8_BUS_MASK) == MV_DDR_64BIT_ECC_PUP8_BUS_MASK) ? 1 : 0) - -#define MV_DDR_IS_32BIT_IN_64BIT_DRAM_MODE(mask, octets_per_if_num/* FIXME: get from ATF */) \ - ((octets_per_if_num == 9/* FIXME: get from ATF */) && \ - ((mask == BUS_MASK_32BIT) || \ - (mask == MV_DDR_32BIT_ECC_PUP8_BUS_MASK)) ? 1 : 0) - -#define MV_DDR_IS_HALF_BUS_DRAM_MODE(mask, octets_per_if_num/* FIXME: get from ATF */) \ - (MV_DDR_IS_32BIT_IN_64BIT_DRAM_MODE(mask, octets_per_if_num) || DDR3_IS_16BIT_DRAM_MODE(mask)) - #define ECC_READ_BUS_0 0 #define ECC_PHY_ACCESS_3 3 #define ECC_PHY_ACCESS_4 4 #define ECC_PHY_ACCESS_8 8 -#define MEGA 1000000 #define BUS_WIDTH_IN_BITS 8 #define MAX_POLLING_ITERATIONS 1000000 -#define NUM_OF_CS 4 #define ADLL_LENGTH 32
#define GP_RSVD0_REG 0x182e0 @@ -92,8 +38,6 @@ */
/* nsec */ -#define TREFI_LOW 7800 -#define TREFI_HIGH 3900 #define AUTO_ZQC_TIMING 15384
enum mr_number { @@ -114,20 +58,11 @@ struct write_supp_result { int is_pup_fail; };
-struct page_element { - enum hws_page_size page_size_8bit; - /* page size in 8 bits bus width */ - enum hws_page_size page_size_16bit; - /* page size in 16 bits bus width */ - u32 ui_page_mask; - /* Mask used in register */ -}; - int ddr3_tip_write_leveling_static_config(u32 dev_num, u32 if_id, - enum hws_ddr_freq frequency, + enum mv_ddr_freq frequency, u32 *round_trip_delay_arr); int ddr3_tip_read_leveling_static_config(u32 dev_num, u32 if_id, - enum hws_ddr_freq frequency, + enum mv_ddr_freq frequency, u32 *total_round_trip_delay_arr); int ddr3_tip_if_write(u32 dev_num, enum hws_access_type interface_access, u32 if_id, u32 reg_addr, u32 data_value, u32 mask); @@ -149,7 +84,7 @@ int ddr3_tip_bus_write(u32 dev_num, enum hws_access_type e_interface_access, enum hws_ddr_phy e_phy_type, u32 reg_addr, u32 data_value); int ddr3_tip_freq_set(u32 dev_num, enum hws_access_type e_access, u32 if_id, - enum hws_ddr_freq memory_freq); + enum mv_ddr_freq memory_freq); int ddr3_tip_adjust_dqs(u32 dev_num); int ddr3_tip_init_controller(u32 dev_num); int ddr3_tip_ext_read(u32 dev_num, u32 if_id, u32 reg_addr, @@ -174,22 +109,12 @@ int ddr3_tip_configure_odpg(u32 dev_num, enum hws_access_type access_type, u32 tx_burst_size, u32 rx_phases, u32 delay_between_burst, u32 rd_mode, u32 cs_num, u32 addr_stress_jump, u32 single_pattern); -int ddr3_tip_set_atr(u32 dev_num, u32 flag_id, u32 value); int ddr3_tip_write_mrs_cmd(u32 dev_num, u32 *cs_mask_arr, enum mr_number mr_num, u32 data, u32 mask); int ddr3_tip_write_cs_result(u32 dev_num, u32 offset); -int ddr3_tip_get_first_active_if(u8 dev_num, u32 interface_mask, u32 *if_id); int ddr3_tip_reset_fifo_ptr(u32 dev_num); -int ddr3_tip_read_pup_value(u32 dev_num, - u32 pup_values[MAX_INTERFACE_NUM * MAX_BUS_NUM], - int reg_addr, u32 mask); -int ddr3_tip_read_adll_value(u32 dev_num, - u32 pup_values[MAX_INTERFACE_NUM * MAX_BUS_NUM], - u32 reg_addr, u32 mask); -int ddr3_tip_write_adll_value(u32 dev_num, - u32 pup_values[MAX_INTERFACE_NUM * MAX_BUS_NUM], - u32 reg_addr); -int ddr3_tip_tune_training_params(u32 dev_num, - struct tune_train_params *params); -struct page_element *mv_ddr_page_tbl_get(void); +int ddr3_tip_read_pup_value(u32 dev_num, u32 pup_values[], int reg_addr, u32 mask); +int ddr3_tip_read_adll_value(u32 dev_num, u32 pup_values[], u32 reg_addr, u32 mask); +int ddr3_tip_write_adll_value(u32 dev_num, u32 pup_values[], u32 reg_addr); +int ddr3_tip_tune_training_params(u32 dev_num, struct tune_train_params *params);
#endif /* _DDR3_TRAINING_IP_FLOW_H_ */ diff --git a/drivers/ddr/marvell/a38x/ddr3_training_ip_prv_if.h b/drivers/ddr/marvell/a38x/ddr3_training_ip_prv_if.h index f614d688c915..2df592e1b02d 100644 --- a/drivers/ddr/marvell/a38x/ddr3_training_ip_prv_if.h +++ b/drivers/ddr/marvell/a38x/ddr3_training_ip_prv_if.h @@ -28,15 +28,15 @@ typedef int (*HWS_TIP_DUNIT_REG_WRITE_FUNC_PTR)( u8 dev_num, enum hws_access_type interface_access, u32 if_id, u32 offset, u32 data, u32 mask); typedef int (*HWS_TIP_GET_FREQ_CONFIG_INFO)( - u8 dev_num, enum hws_ddr_freq freq, + u8 dev_num, enum mv_ddr_freq freq, struct hws_tip_freq_config_info *freq_config_info); typedef int (*HWS_TIP_GET_DEVICE_INFO)( u8 dev_num, struct ddr3_device_info *info_ptr); typedef int (*HWS_GET_CS_CONFIG_FUNC_PTR)( u8 dev_num, u32 cs_mask, struct hws_cs_config_info *cs_info); typedef int (*HWS_SET_FREQ_DIVIDER_FUNC_PTR)( - u8 dev_num, u32 if_id, enum hws_ddr_freq freq); -typedef int (*HWS_GET_INIT_FREQ)(u8 dev_num, enum hws_ddr_freq *freq); + u8 dev_num, u32 if_id, enum mv_ddr_freq freq); +typedef int (*HWS_GET_INIT_FREQ)(u8 dev_num, enum mv_ddr_freq *freq); typedef int (*HWS_TRAINING_IP_IF_WRITE_FUNC_PTR)( u32 dev_num, enum hws_access_type access_type, u32 dunit_id, u32 reg_addr, u32 data, u32 mask); @@ -54,7 +54,7 @@ typedef int (*HWS_TRAINING_IP_ALGO_RUN_FUNC_PTR)( u32 dev_num, enum hws_algo_type algo_type); typedef int (*HWS_TRAINING_IP_SET_FREQ_FUNC_PTR)( u32 dev_num, enum hws_access_type access_type, u32 if_id, - enum hws_ddr_freq frequency); + enum mv_ddr_freq frequency); typedef int (*HWS_TRAINING_IP_INIT_CONTROLLER_FUNC_PTR)( u32 dev_num, struct init_cntr_param *init_cntr_prm); typedef int (*HWS_TRAINING_IP_PBS_RX_FUNC_PTR)(u32 dev_num); @@ -64,7 +64,7 @@ typedef int (*HWS_TRAINING_IP_SELECT_CONTROLLER_FUNC_PTR)( typedef int (*HWS_TRAINING_IP_TOPOLOGY_MAP_LOAD_FUNC_PTR)( u32 dev_num, struct mv_ddr_topology_map *tm); typedef int (*HWS_TRAINING_IP_STATIC_CONFIG_FUNC_PTR)( - u32 dev_num, enum hws_ddr_freq frequency, + u32 dev_num, enum mv_ddr_freq frequency, enum hws_static_config_type static_config_type, u32 if_id); typedef int (*HWS_TRAINING_IP_EXTERNAL_READ_PTR)( u32 dev_num, u32 if_id, u32 ddr_addr, u32 num_bursts, u32 *data); diff --git a/drivers/ddr/marvell/a38x/ddr3_training_leveling.c b/drivers/ddr/marvell/a38x/ddr3_training_leveling.c index 6248ffc3fb33..7f7df6794a95 100644 --- a/drivers/ddr/marvell/a38x/ddr3_training_leveling.c +++ b/drivers/ddr/marvell/a38x/ddr3_training_leveling.c @@ -4,6 +4,9 @@ */
#include "ddr3_init.h" +#include "mv_ddr_training_db.h" +#include "ddr_training_ip_db.h" +#include "mv_ddr_regs.h"
#define WL_ITERATION_NUM 10
@@ -24,33 +27,6 @@ static int ddr3_tip_wl_supp_align_phase_shift(u32 dev_num, u32 if_id, static int ddr3_tip_xsb_compare_test(u32 dev_num, u32 if_id, u32 bus_id, u32 edge_offset);
-u32 ddr3_tip_max_cs_get(u32 dev_num) -{ - u32 c_cs, if_id, bus_id; - static u32 max_cs; - struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); - u32 octets_per_if_num = ddr3_tip_dev_attr_get(dev_num, MV_ATTR_OCTET_PER_INTERFACE); - - if (!max_cs) { - CHECK_STATUS(ddr3_tip_get_first_active_if((u8)dev_num, - tm->if_act_mask, - &if_id)); - for (bus_id = 0; bus_id < octets_per_if_num; bus_id++) { - VALIDATE_BUS_ACTIVE(tm->bus_act_mask, bus_id); - break; - } - - for (c_cs = 0; c_cs < NUM_OF_CS; c_cs++) { - VALIDATE_ACTIVE(tm-> - interface_params[if_id].as_bus_params[bus_id]. - cs_bitmask, c_cs); - max_cs++; - } - } - - return max_cs; -} - enum { PASS, FAIL @@ -61,20 +37,20 @@ Dynamic read leveling int ddr3_tip_dynamic_read_leveling(u32 dev_num, u32 freq) { u32 data, mask; - u32 max_cs = ddr3_tip_max_cs_get(dev_num); + unsigned int max_cs = mv_ddr_cs_num_get(); u32 bus_num, if_id, cl_val; - enum hws_speed_bin speed_bin_index; + enum mv_ddr_speed_bin speed_bin_index; /* save current CS value */ u32 cs_enable_reg_val[MAX_INTERFACE_NUM] = { 0 }; int is_any_pup_fail = 0; u32 data_read[MAX_INTERFACE_NUM + 1] = { 0 }; - u8 rl_values[NUM_OF_CS][MAX_BUS_NUM][MAX_INTERFACE_NUM]; + u8 rl_values[MAX_CS_NUM][MAX_BUS_NUM][MAX_INTERFACE_NUM]; struct pattern_info *pattern_table = ddr3_tip_get_pattern_table(); u16 *mask_results_pup_reg_map = ddr3_tip_get_mask_results_pup_reg_map(); u32 octets_per_if_num = ddr3_tip_dev_attr_get(dev_num, MV_ATTR_OCTET_PER_INTERFACE); struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get();
- for (effective_cs = 0; effective_cs < NUM_OF_CS; effective_cs++) + for (effective_cs = 0; effective_cs < MAX_CS_NUM; effective_cs++) for (bus_num = 0; bus_num < MAX_BUS_NUM; bus_num++) for (if_id = 0; if_id <= MAX_INTERFACE_NUM - 1; if_id++) rl_values[effective_cs][bus_num][if_id] = 0; @@ -143,8 +119,7 @@ int ddr3_tip_dynamic_read_leveling(u32 dev_num, u32 freq) VALIDATE_IF_ACTIVE(tm->if_act_mask, if_id); speed_bin_index = tm->interface_params[if_id].speed_bin_index; - cl_val = - cas_latency_table[speed_bin_index].cl_val[freq]; + cl_val = mv_ddr_cl_val_get(speed_bin_index, freq); data = (cl_val << 17) | (0x3 << 25); mask = (0xff << 9) | (0x1f << 17) | (0x3 << 25); CHECK_STATUS(ddr3_tip_if_write @@ -340,7 +315,7 @@ int ddr3_tip_dynamic_read_leveling(u32 dev_num, u32 freq) int ddr3_tip_legacy_dynamic_write_leveling(u32 dev_num) { u32 c_cs, if_id, cs_mask = 0; - u32 max_cs = ddr3_tip_max_cs_get(dev_num); + unsigned int max_cs = mv_ddr_cs_num_get(); struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get();
/* @@ -381,7 +356,7 @@ int ddr3_tip_legacy_dynamic_write_leveling(u32 dev_num) int ddr3_tip_legacy_dynamic_read_leveling(u32 dev_num) { u32 c_cs, if_id, cs_mask = 0; - u32 max_cs = ddr3_tip_max_cs_get(dev_num); + unsigned int max_cs = mv_ddr_cs_num_get(); struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get();
/* @@ -426,7 +401,7 @@ int ddr3_tip_dynamic_per_bit_read_leveling(u32 dev_num, u32 freq) u32 curr_numb, curr_min_delay; int adll_array[3] = { 0, -0xa, 0x14 }; u32 phyreg3_arr[MAX_INTERFACE_NUM][MAX_BUS_NUM]; - enum hws_speed_bin speed_bin_index; + enum mv_ddr_speed_bin speed_bin_index; int is_any_pup_fail = 0; int break_loop = 0; u32 cs_enable_reg_val[MAX_INTERFACE_NUM]; /* save current CS value */ @@ -516,8 +491,7 @@ int ddr3_tip_dynamic_per_bit_read_leveling(u32 dev_num, u32 freq) VALIDATE_IF_ACTIVE(tm->if_act_mask, if_id); speed_bin_index = tm->interface_params[if_id].speed_bin_index; - cl_val = - cas_latency_table[speed_bin_index].cl_val[freq]; + cl_val = mv_ddr_cl_val_get(speed_bin_index, freq); data = (cl_val << 17) | (0x3 << 25); mask = (0xff << 9) | (0x1f << 17) | (0x3 << 25); CHECK_STATUS(ddr3_tip_if_write @@ -839,10 +813,10 @@ int ddr3_tip_dynamic_write_leveling(u32 dev_num, int phase_remove) u32 res_values[MAX_INTERFACE_NUM * MAX_BUS_NUM] = { 0 }; u32 test_res = 0; /* 0 - success for all pup */ u32 data_read[MAX_INTERFACE_NUM]; - u8 wl_values[NUM_OF_CS][MAX_BUS_NUM][MAX_INTERFACE_NUM]; + u8 wl_values[MAX_CS_NUM][MAX_BUS_NUM][MAX_INTERFACE_NUM]; u16 *mask_results_pup_reg_map = ddr3_tip_get_mask_results_pup_reg_map(); u32 cs_mask0[MAX_INTERFACE_NUM] = { 0 }; - u32 max_cs = ddr3_tip_max_cs_get(dev_num); + unsigned int max_cs = mv_ddr_cs_num_get(); u32 octets_per_if_num = ddr3_tip_dev_attr_get(dev_num, MV_ATTR_OCTET_PER_INTERFACE); struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get();
@@ -1694,9 +1668,11 @@ enum rl_dqs_burst_state { RL_INSIDE, RL_BEHIND }; + + int mv_ddr_rl_dqs_burst(u32 dev_num, u32 if_id, u32 freq) { - enum rl_dqs_burst_state rl_state[NUM_OF_CS][MAX_BUS_NUM][MAX_INTERFACE_NUM] = { { {0} } }; + enum rl_dqs_burst_state rl_state[MAX_CS_NUM][MAX_BUS_NUM][MAX_INTERFACE_NUM] = { { {0} } }; enum hws_ddr_phy subphy_type = DDR_PHY_DATA; struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); int cl_val = tm->interface_params[0].cas_l; @@ -1707,17 +1683,18 @@ int mv_ddr_rl_dqs_burst(u32 dev_num, u32 if_id, u32 freq) int init_pass_lock_num; int phase_delta; int min_phase, max_phase; - u32 max_cs = ddr3_tip_max_cs_get(dev_num); - u32 rl_values[NUM_OF_CS][MAX_BUS_NUM][MAX_INTERFACE_NUM] = { { {0} } }; - u32 rl_min_values[NUM_OF_CS][MAX_BUS_NUM][MAX_INTERFACE_NUM] = { { {0} } }; - u32 rl_max_values[NUM_OF_CS][MAX_BUS_NUM][MAX_INTERFACE_NUM] = { { {0} } }; - u32 rl_val, rl_min_val[NUM_OF_CS], rl_max_val[NUM_OF_CS]; + unsigned int max_cs = mv_ddr_cs_num_get(); + u32 rl_values[MAX_CS_NUM][MAX_BUS_NUM][MAX_INTERFACE_NUM] = { { {0} } }; + u32 rl_min_values[MAX_CS_NUM][MAX_BUS_NUM][MAX_INTERFACE_NUM] = { { {0} } }; + u32 rl_max_values[MAX_CS_NUM][MAX_BUS_NUM][MAX_INTERFACE_NUM] = { { {0} } }; + u32 rl_val, rl_min_val[MAX_CS_NUM], rl_max_val[MAX_CS_NUM]; u32 reg_val_low, reg_val_high; - u32 reg_val, reg_mask; + u32 reg_val, reg_mask; uintptr_t test_addr = TEST_ADDR;
+ /* initialization */ - if (ddr3_if_ecc_enabled()) { + if (mv_ddr_is_ecc_ena()) { ddr3_tip_if_read(dev_num, ACCESS_TYPE_UNICAST, if_id, TRAINING_SW_2_REG, ®_val, MASK_ALL_BITS); reg_mask = (TRAINING_ECC_MUX_MASK << TRAINING_ECC_MUX_OFFS) | @@ -1753,6 +1730,7 @@ int mv_ddr_rl_dqs_burst(u32 dev_num, u32 if_id, u32 freq) /* search for dqs edges per subphy */ if_id = 0; for (effective_cs = 0; effective_cs < max_cs; effective_cs++) { + pass_lock_num = init_pass_lock_num; ddr3_tip_if_write(0, ACCESS_TYPE_MULTICAST, PARAM_NOT_CARE, ODPG_DATA_CTRL_REG, effective_cs << ODPG_DATA_CS_OFFS, @@ -1972,6 +1950,7 @@ int mv_ddr_rl_dqs_burst(u32 dev_num, u32 if_id, u32 freq) CHECK_STATUS(ddr3_tip_write_additional_odt_setting(dev_num, if_id)); }
+ /* reset read fifo assertion */ ddr3_tip_if_write(dev_num, ACCESS_TYPE_MULTICAST, if_id, SDRAM_CFG_REG, DATA_PUP_RD_RESET_ENA << DATA_PUP_RD_RESET_OFFS, diff --git a/drivers/ddr/marvell/a38x/ddr3_training_leveling.h b/drivers/ddr/marvell/a38x/ddr3_training_leveling.h index 96d945a33d6e..6719fb83f518 100644 --- a/drivers/ddr/marvell/a38x/ddr3_training_leveling.h +++ b/drivers/ddr/marvell/a38x/ddr3_training_leveling.h @@ -11,6 +11,5 @@ int ddr3_tip_print_wl_supp_result(u32 dev_num); int ddr3_tip_calc_cs_mask(u32 dev_num, u32 if_id, u32 effective_cs, u32 *cs_mask); -u32 ddr3_tip_max_cs_get(u32 dev_num);
#endif /* _DDR3_TRAINING_LEVELING_H_ */ diff --git a/drivers/ddr/marvell/a38x/ddr3_training_pbs.c b/drivers/ddr/marvell/a38x/ddr3_training_pbs.c index 0511026afbe2..b7dfebd93cc4 100644 --- a/drivers/ddr/marvell/a38x/ddr3_training_pbs.c +++ b/drivers/ddr/marvell/a38x/ddr3_training_pbs.c @@ -4,6 +4,9 @@ */
#include "ddr3_init.h" +#include "mv_ddr_training_db.h" +#include "mv_ddr_common.h" +#include "mv_ddr_regs.h"
#define TYPICAL_PBS_VALUE 12
@@ -33,7 +36,7 @@ static u8 pup_state[MAX_INTERFACE_NUM][MAX_BUS_NUM]; int ddr3_tip_pbs(u32 dev_num, enum pbs_dir pbs_mode) { u32 res0[MAX_INTERFACE_NUM]; - int adll_tap = MEGA / freq_val[medium_freq] / 64; + int adll_tap = MEGA / mv_ddr_freq_get(medium_freq) / 64; int pad_num = 0; enum hws_search_dir search_dir = (pbs_mode == PBS_RX_MODE) ? HWS_HIGH2LOW : HWS_LOW2HIGH; @@ -921,7 +924,7 @@ int ddr3_tip_pbs_tx(u32 uidev_num) int ddr3_tip_print_all_pbs_result(u32 dev_num) { u32 curr_cs; - u32 max_cs = ddr3_tip_max_cs_get(dev_num); + unsigned int max_cs = mv_ddr_cs_num_get();
for (curr_cs = 0; curr_cs < max_cs; curr_cs++) { ddr3_tip_print_pbs_result(dev_num, curr_cs, PBS_RX_MODE); diff --git a/drivers/ddr/marvell/a38x/ddr_topology_def.h b/drivers/ddr/marvell/a38x/ddr_topology_def.h index 812224909ae4..e6fe8a04289b 100644 --- a/drivers/ddr/marvell/a38x/ddr_topology_def.h +++ b/drivers/ddr/marvell/a38x/ddr_topology_def.h @@ -7,16 +7,13 @@ #define _DDR_TOPOLOGY_DEF_H
#include "ddr3_training_ip_def.h" -#include "ddr3_topology_def.h" - -#if defined(CONFIG_ARMADA_38X) || defined(CONFIG_ARMADA_39X) -#include "mv_ddr_plat.h" -#endif - #include "mv_ddr_topology.h" #include "mv_ddr_spd.h" #include "ddr3_logging_def.h"
+#define MV_DDR_MAX_BUS_NUM 9 +#define MV_DDR_MAX_IFACE_NUM 1 + struct bus_params { /* Chip Select (CS) bitmask (bits 0-CS0, bit 1- CS1 ...) */ u8 cs_bitmask; @@ -36,10 +33,10 @@ struct bus_params {
struct if_params { /* bus configuration */ - struct bus_params as_bus_params[MAX_BUS_NUM]; + struct bus_params as_bus_params[MV_DDR_MAX_BUS_NUM];
/* Speed Bin Table */ - enum hws_speed_bin speed_bin_index; + enum mv_ddr_speed_bin speed_bin_index;
/* sdram device width */ enum mv_ddr_dev_width bus_width; @@ -48,7 +45,7 @@ struct if_params { enum mv_ddr_die_capacity memory_size;
/* The DDR frequency for each interfaces */ - enum hws_ddr_freq memory_freq; + enum mv_ddr_freq memory_freq;
/* * delay CAS Write Latency @@ -69,6 +66,37 @@ struct if_params { enum mv_ddr_timing timing; };
+/* memory electrical configuration */ +struct mv_ddr_mem_edata { + enum mv_ddr_rtt_nom_park_evalue rtt_nom; + enum mv_ddr_rtt_nom_park_evalue rtt_park[MAX_CS_NUM]; + enum mv_ddr_rtt_wr_evalue rtt_wr[MAX_CS_NUM]; + enum mv_ddr_dic_evalue dic; +}; + +/* phy electrical configuration */ +struct mv_ddr_phy_edata { + enum mv_ddr_ohm_evalue drv_data_p; + enum mv_ddr_ohm_evalue drv_data_n; + enum mv_ddr_ohm_evalue drv_ctrl_p; + enum mv_ddr_ohm_evalue drv_ctrl_n; + enum mv_ddr_ohm_evalue odt_p[MAX_CS_NUM]; + enum mv_ddr_ohm_evalue odt_n[MAX_CS_NUM]; +}; + +/* mac electrical configuration */ +struct mv_ddr_mac_edata { + enum mv_ddr_odt_cfg_evalue odt_cfg_pat; + enum mv_ddr_odt_cfg_evalue odt_cfg_wr; + enum mv_ddr_odt_cfg_evalue odt_cfg_rd; +}; + +struct mv_ddr_edata { + struct mv_ddr_mem_edata mem_edata; + struct mv_ddr_phy_edata phy_edata; + struct mv_ddr_mac_edata mac_edata; +}; + struct mv_ddr_topology_map { /* debug level configuration */ enum mv_ddr_debug_level debug_level; @@ -77,7 +105,7 @@ struct mv_ddr_topology_map { u8 if_act_mask;
/* Controller configuration per interface */ - struct if_params interface_params[MAX_INTERFACE_NUM]; + struct if_params interface_params[MV_DDR_MAX_IFACE_NUM];
/* Bit mask for active buses */ u16 bus_act_mask; @@ -90,8 +118,67 @@ struct mv_ddr_topology_map {
/* timing parameters */ unsigned int timing_data[MV_DDR_TDATA_LAST]; + + /* electrical configuration */ + struct mv_ddr_edata edata; + + /* electrical parameters */ + unsigned int electrical_data[MV_DDR_EDATA_LAST]; +}; + +enum mv_ddr_iface_mode { + MV_DDR_RAR_ENA, + MV_DDR_RAR_DIS, };
+enum mv_ddr_iface_state { + MV_DDR_IFACE_NRDY, /* not ready */ + MV_DDR_IFACE_INIT, /* init'd */ + MV_DDR_IFACE_RDY, /* ready */ + MV_DDR_IFACE_DNE /* does not exist */ +}; + +enum mv_ddr_validation { + MV_DDR_VAL_DIS, + MV_DDR_VAL_RX, + MV_DDR_VAL_TX, + MV_DDR_VAL_RX_TX +}; + +struct mv_ddr_iface { + /* base addr of ap ddr interface belongs to */ + unsigned int ap_base; + + /* ddr interface id */ + unsigned int id; + + /* ddr interface state */ + enum mv_ddr_iface_state state; + + /* ddr interface mode (rar enabled/disabled) */ + enum mv_ddr_iface_mode iface_mode; + + /* ddr interface base address */ + unsigned long long iface_base_addr; + + /* ddr interface size - ddr flow will update this parameter */ + unsigned long long iface_byte_size; + + /* ddr i2c spd data address */ + unsigned int spd_data_addr; + + /* ddr i2c spd page 0 select address */ + unsigned int spd_page_sel_addr; + + /* ddr interface validation mode */ + enum mv_ddr_validation validation; + + /* ddr interface topology map */ + struct mv_ddr_topology_map tm; +}; + +struct mv_ddr_iface *mv_ddr_iface_get(void); + /* DDR3 training global configuration parameters */ struct tune_train_params { u32 ck_delay; diff --git a/drivers/ddr/marvell/a38x/ddr_training_ip_db.h b/drivers/ddr/marvell/a38x/ddr_training_ip_db.h index e7de5aef0ca7..f1b4d8efc0e1 100644 --- a/drivers/ddr/marvell/a38x/ddr_training_ip_db.h +++ b/drivers/ddr/marvell/a38x/ddr_training_ip_db.h @@ -6,10 +6,8 @@ #ifndef _DDR_TRAINING_IP_DB_H_ #define _DDR_TRAINING_IP_DB_H_
-#include "ddr_topology_def.h" #include "ddr3_training_ip_db.h"
-u32 speed_bin_table(u8 index, enum speed_bin_table_elements element); u32 pattern_table_get_word(u32 dev_num, enum hws_pattern type, u8 index);
#endif /* _DDR3_TRAINING_IP_DB_H_ */ diff --git a/drivers/ddr/marvell/a38x/dram_if.h b/drivers/ddr/marvell/a38x/dram_if.h new file mode 100644 index 000000000000..4d0846489b90 --- /dev/null +++ b/drivers/ddr/marvell/a38x/dram_if.h @@ -0,0 +1,13 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2016 Marvell International Ltd. + */ + +#ifndef _DRAM_IF_H_ +#define _DRAM_IF_H_ + +/* TODO: update atf to this new prototype */ +int dram_init(void); +void dram_mmap_config(void); +unsigned long long dram_iface_mem_sz_get(void); +#endif /* _DRAM_IF_H_ */ diff --git a/drivers/ddr/marvell/a38x/mv_ddr_build_message.c b/drivers/ddr/marvell/a38x/mv_ddr_build_message.c index 2b49b77f7306..cc6234fd406c 100644 --- a/drivers/ddr/marvell/a38x/mv_ddr_build_message.c +++ b/drivers/ddr/marvell/a38x/mv_ddr_build_message.c @@ -1,3 +1,3 @@ // SPDX-License-Identifier: GPL-2.0 const char mv_ddr_build_message[] = ""; -const char mv_ddr_version_string[] = "mv_ddr: mv_ddr-armada-17.10.4"; +const char mv_ddr_version_string[] = "mv_ddr: mv_ddr-armada-18.09.2"; diff --git a/drivers/ddr/marvell/a38x/mv_ddr_common.h b/drivers/ddr/marvell/a38x/mv_ddr_common.h index c71ff442edd3..321a390c0d30 100644 --- a/drivers/ddr/marvell/a38x/mv_ddr_common.h +++ b/drivers/ddr/marvell/a38x/mv_ddr_common.h @@ -9,10 +9,44 @@ extern const char mv_ddr_build_message[]; extern const char mv_ddr_version_string[];
-#define MV_DDR_NUM_BITS_IN_BYTE 8 -#define MV_DDR_MEGA_BITS (1024 * 1024) +#define _1K 0x00000400 +#define _4K 0x00001000 +#define _8K 0x00002000 +#define _16K 0x00004000 +#define _32K 0x00008000 +#define _64K 0x00010000 +#define _128K 0x00020000 +#define _256K 0x00040000 +#define _512K 0x00080000 + +#define _1M 0x00100000 +#define _2M 0x00200000 +#define _4M 0x00400000 +#define _8M 0x00800000 +#define _16M 0x01000000 +#define _32M 0x02000000 +#define _64M 0x04000000 +#define _128M 0x08000000 +#define _256M 0x10000000 +#define _512M 0x20000000 + +#define _1G 0x40000000 +#define _2G 0x80000000 +#define _4G 0x100000000 +#define _8G 0x200000000 +#define _16G 0x400000000 +#define _32G 0x800000000 +#define _64G 0x1000000000 +#define _128G 0x2000000000 + +#define MEGA 1000000 +#define MV_DDR_MEGABYTE (1024 * 1024) #define MV_DDR_32_BITS_MASK 0xffffffff
+#define GET_MAX_VALUE(x, y) \ + (((x) > (y)) ? (x) : (y)) + +void mv_ddr_ver_print(void); unsigned int ceil_div(unsigned int x, unsigned int y); unsigned int time_to_nclk(unsigned int t, unsigned int tclk); int round_div(unsigned int dividend, unsigned int divisor, unsigned int *quotient); diff --git a/drivers/ddr/marvell/a38x/mv_ddr_plat.c b/drivers/ddr/marvell/a38x/mv_ddr_plat.c index 2f318cb9ea7b..19e95d275abd 100644 --- a/drivers/ddr/marvell/a38x/mv_ddr_plat.c +++ b/drivers/ddr/marvell/a38x/mv_ddr_plat.c @@ -1,10 +1,7 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Copyright (C) Marvell International Ltd. and its affiliates - */
#include "ddr3_init.h" - +#include "mv_ddr_training_db.h" +#include "mv_ddr_regs.h" #include "mv_ddr_sys_env_lib.h"
#define DDR_INTERFACES_NUM 1 @@ -58,42 +55,42 @@ static struct dlb_config *sys_env_dlb_config_ptr_get(void) return &ddr3_dlb_config_table[0]; }
-static u8 a38x_bw_per_freq[DDR_FREQ_LAST] = { - 0x3, /* DDR_FREQ_100 */ - 0x4, /* DDR_FREQ_400 */ - 0x4, /* DDR_FREQ_533 */ - 0x5, /* DDR_FREQ_667 */ - 0x5, /* DDR_FREQ_800 */ - 0x5, /* DDR_FREQ_933 */ - 0x5, /* DDR_FREQ_1066 */ - 0x3, /* DDR_FREQ_311 */ - 0x3, /* DDR_FREQ_333 */ - 0x4, /* DDR_FREQ_467 */ - 0x5, /* DDR_FREQ_850 */ - 0x5, /* DDR_FREQ_600 */ - 0x3, /* DDR_FREQ_300 */ - 0x5, /* DDR_FREQ_900 */ - 0x3, /* DDR_FREQ_360 */ - 0x5 /* DDR_FREQ_1000 */ +static u8 a38x_bw_per_freq[MV_DDR_FREQ_LAST] = { + 0x3, /* MV_DDR_FREQ_100 */ + 0x4, /* MV_DDR_FREQ_400 */ + 0x4, /* MV_DDR_FREQ_533 */ + 0x5, /* MV_DDR_FREQ_667 */ + 0x5, /* MV_DDR_FREQ_800 */ + 0x5, /* MV_DDR_FREQ_933 */ + 0x5, /* MV_DDR_FREQ_1066 */ + 0x3, /* MV_DDR_FREQ_311 */ + 0x3, /* MV_DDR_FREQ_333 */ + 0x4, /* MV_DDR_FREQ_467 */ + 0x5, /* MV_DDR_FREQ_850 */ + 0x5, /* MV_DDR_FREQ_600 */ + 0x3, /* MV_DDR_FREQ_300 */ + 0x5, /* MV_DDR_FREQ_900 */ + 0x3, /* MV_DDR_FREQ_360 */ + 0x5 /* MV_DDR_FREQ_1000 */ };
-static u8 a38x_rate_per_freq[DDR_FREQ_LAST] = { - 0x1, /* DDR_FREQ_100 */ - 0x2, /* DDR_FREQ_400 */ - 0x2, /* DDR_FREQ_533 */ - 0x2, /* DDR_FREQ_667 */ - 0x2, /* DDR_FREQ_800 */ - 0x3, /* DDR_FREQ_933 */ - 0x3, /* DDR_FREQ_1066 */ - 0x1, /* DDR_FREQ_311 */ - 0x1, /* DDR_FREQ_333 */ - 0x2, /* DDR_FREQ_467 */ - 0x2, /* DDR_FREQ_850 */ - 0x2, /* DDR_FREQ_600 */ - 0x1, /* DDR_FREQ_300 */ - 0x2, /* DDR_FREQ_900 */ - 0x1, /* DDR_FREQ_360 */ - 0x2 /* DDR_FREQ_1000 */ +static u8 a38x_rate_per_freq[MV_DDR_FREQ_LAST] = { + 0x1, /* MV_DDR_FREQ_100 */ + 0x2, /* MV_DDR_FREQ_400 */ + 0x2, /* MV_DDR_FREQ_533 */ + 0x2, /* MV_DDR_FREQ_667 */ + 0x2, /* MV_DDR_FREQ_800 */ + 0x3, /* MV_DDR_FREQ_933 */ + 0x3, /* MV_DDR_FREQ_1066 */ + 0x1, /* MV_DDR_FREQ_311 */ + 0x1, /* MV_DDR_FREQ_333 */ + 0x2, /* MV_DDR_FREQ_467 */ + 0x2, /* MV_DDR_FREQ_850 */ + 0x2, /* MV_DDR_FREQ_600 */ + 0x1, /* MV_DDR_FREQ_300 */ + 0x2, /* MV_DDR_FREQ_900 */ + 0x1, /* MV_DDR_FREQ_360 */ + 0x2 /* MV_DDR_FREQ_1000 */ };
static u16 a38x_vco_freq_per_sar_ref_clk_25_mhz[] = { @@ -177,10 +174,11 @@ static u32 dq_bit_map_2_phy_pin[] = {
void mv_ddr_mem_scrubbing(void) { + ddr3_new_tip_ecc_scrub(); }
static int ddr3_tip_a38x_set_divider(u8 dev_num, u32 if_id, - enum hws_ddr_freq freq); + enum mv_ddr_freq freq);
/* * Read temperature TJ value @@ -219,7 +217,7 @@ static u32 ddr3_ctrl_get_junc_temp(u8 dev_num) * Notes: * Returns: MV_OK if success, other error code if fail. */ -static int ddr3_tip_a38x_get_freq_config(u8 dev_num, enum hws_ddr_freq freq, +static int ddr3_tip_a38x_get_freq_config(u8 dev_num, enum mv_ddr_freq freq, struct hws_tip_freq_config_info *freq_config_info) { @@ -377,13 +375,13 @@ static int ddr3_tip_a38x_select_ddr_controller(u8 dev_num, int enable)
static u8 ddr3_tip_clock_mode(u32 frequency) { - if ((frequency == DDR_FREQ_LOW_FREQ) || (freq_val[frequency] <= 400)) + if ((frequency == MV_DDR_FREQ_LOW_FREQ) || (mv_ddr_freq_get(frequency) <= 400)) return 1;
return 2; }
-static int mv_ddr_sar_freq_get(int dev_num, enum hws_ddr_freq *freq) +static int mv_ddr_sar_freq_get(int dev_num, enum mv_ddr_freq *freq) { u32 reg, ref_clk_satr;
@@ -402,7 +400,7 @@ static int mv_ddr_sar_freq_get(int dev_num, enum hws_ddr_freq *freq) reg)); /* fallthrough */ case 0x0: - *freq = DDR_FREQ_333; + *freq = MV_DDR_FREQ_333; break; case 0x3: DEBUG_TRAINING_ACCESS(DEBUG_LEVEL_ERROR, @@ -410,7 +408,7 @@ static int mv_ddr_sar_freq_get(int dev_num, enum hws_ddr_freq *freq) reg)); /* fallthrough */ case 0x2: - *freq = DDR_FREQ_400; + *freq = MV_DDR_FREQ_400; break; case 0xd: DEBUG_TRAINING_ACCESS(DEBUG_LEVEL_ERROR, @@ -418,10 +416,10 @@ static int mv_ddr_sar_freq_get(int dev_num, enum hws_ddr_freq *freq) reg)); /* fallthrough */ case 0x4: - *freq = DDR_FREQ_533; + *freq = MV_DDR_FREQ_533; break; case 0x6: - *freq = DDR_FREQ_600; + *freq = MV_DDR_FREQ_600; break; case 0x11: case 0x14: @@ -430,7 +428,7 @@ static int mv_ddr_sar_freq_get(int dev_num, enum hws_ddr_freq *freq) reg)); /* fallthrough */ case 0x8: - *freq = DDR_FREQ_667; + *freq = MV_DDR_FREQ_667; break; case 0x15: case 0x1b: @@ -439,16 +437,16 @@ static int mv_ddr_sar_freq_get(int dev_num, enum hws_ddr_freq *freq) reg)); /* fallthrough */ case 0xc: - *freq = DDR_FREQ_800; + *freq = MV_DDR_FREQ_800; break; case 0x10: - *freq = DDR_FREQ_933; + *freq = MV_DDR_FREQ_933; break; case 0x12: - *freq = DDR_FREQ_900; + *freq = MV_DDR_FREQ_900; break; case 0x13: - *freq = DDR_FREQ_933; + *freq = MV_DDR_FREQ_933; break; default: *freq = 0; @@ -457,16 +455,16 @@ static int mv_ddr_sar_freq_get(int dev_num, enum hws_ddr_freq *freq) } else { /* REFCLK 40MHz case */ switch (reg) { case 0x3: - *freq = DDR_FREQ_400; + *freq = MV_DDR_FREQ_400; break; case 0x5: - *freq = DDR_FREQ_533; + *freq = MV_DDR_FREQ_533; break; case 0xb: - *freq = DDR_FREQ_800; + *freq = MV_DDR_FREQ_800; break; case 0x1e: - *freq = DDR_FREQ_900; + *freq = MV_DDR_FREQ_900; break; default: *freq = 0; @@ -477,7 +475,7 @@ static int mv_ddr_sar_freq_get(int dev_num, enum hws_ddr_freq *freq) return MV_OK; }
-static int ddr3_tip_a38x_get_medium_freq(int dev_num, enum hws_ddr_freq *freq) +static int ddr3_tip_a38x_get_medium_freq(int dev_num, enum mv_ddr_freq *freq) { u32 reg, ref_clk_satr;
@@ -493,37 +491,37 @@ static int ddr3_tip_a38x_get_medium_freq(int dev_num, enum hws_ddr_freq *freq) case 0x0: case 0x1: /* Medium is same as TF to run PBS in this freq */ - *freq = DDR_FREQ_333; + *freq = MV_DDR_FREQ_333; break; case 0x2: case 0x3: /* Medium is same as TF to run PBS in this freq */ - *freq = DDR_FREQ_400; + *freq = MV_DDR_FREQ_400; break; case 0x4: case 0xd: /* Medium is same as TF to run PBS in this freq */ - *freq = DDR_FREQ_533; + *freq = MV_DDR_FREQ_533; break; case 0x8: case 0x10: case 0x11: case 0x14: - *freq = DDR_FREQ_333; + *freq = MV_DDR_FREQ_333; break; case 0xc: case 0x15: case 0x1b: - *freq = DDR_FREQ_400; + *freq = MV_DDR_FREQ_400; break; case 0x6: - *freq = DDR_FREQ_300; + *freq = MV_DDR_FREQ_300; break; case 0x12: - *freq = DDR_FREQ_360; + *freq = MV_DDR_FREQ_360; break; case 0x13: - *freq = DDR_FREQ_400; + *freq = MV_DDR_FREQ_400; break; default: *freq = 0; @@ -533,17 +531,17 @@ static int ddr3_tip_a38x_get_medium_freq(int dev_num, enum hws_ddr_freq *freq) switch (reg) { case 0x3: /* Medium is same as TF to run PBS in this freq */ - *freq = DDR_FREQ_400; + *freq = MV_DDR_FREQ_400; break; case 0x5: /* Medium is same as TF to run PBS in this freq */ - *freq = DDR_FREQ_533; + *freq = MV_DDR_FREQ_533; break; case 0xb: - *freq = DDR_FREQ_400; + *freq = MV_DDR_FREQ_400; break; case 0x1e: - *freq = DDR_FREQ_360; + *freq = MV_DDR_FREQ_360; break; default: *freq = 0; @@ -682,7 +680,7 @@ static int mv_ddr_sw_db_init(u32 dev_num, u32 board_id) static int mv_ddr_training_mask_set(void) { struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); - enum hws_ddr_freq ddr_freq = tm->interface_params[0].memory_freq; + enum mv_ddr_freq ddr_freq = tm->interface_params[0].memory_freq;
mask_tune_func = (SET_LOW_FREQ_MASK_BIT | LOAD_PATTERN_MASK_BIT | @@ -699,7 +697,7 @@ static int mv_ddr_training_mask_set(void) CENTRALIZATION_TX_MASK_BIT); rl_mid_freq_wa = 1;
- if ((ddr_freq == DDR_FREQ_333) || (ddr_freq == DDR_FREQ_400)) { + if ((ddr_freq == MV_DDR_FREQ_333) || (ddr_freq == MV_DDR_FREQ_400)) { mask_tune_func = (WRITE_LEVELING_MASK_BIT | LOAD_PATTERN_2_MASK_BIT | WRITE_LEVELING_SUPP_MASK_BIT | @@ -712,7 +710,7 @@ static int mv_ddr_training_mask_set(void) }
/* Supplementary not supported for ECC modes */ - if (1 == ddr3_if_ecc_enabled()) { + if (mv_ddr_is_ecc_ena()) { mask_tune_func &= ~WRITE_LEVELING_SUPP_TF_MASK_BIT; mask_tune_func &= ~WRITE_LEVELING_SUPP_MASK_BIT; mask_tune_func &= ~PBS_TX_MASK_BIT; @@ -734,11 +732,12 @@ void mv_ddr_set_calib_controller(void) }
static int ddr3_tip_a38x_set_divider(u8 dev_num, u32 if_id, - enum hws_ddr_freq frequency) + enum mv_ddr_freq frequency) { u32 divider = 0; u32 sar_val, ref_clk_satr; u32 async_val; + u32 freq = mv_ddr_freq_get(frequency);
if (if_id != 0) { DEBUG_TRAINING_ACCESS(DEBUG_LEVEL_ERROR, @@ -755,11 +754,11 @@ static int ddr3_tip_a38x_set_divider(u8 dev_num, u32 if_id, ref_clk_satr = reg_read(DEVICE_SAMPLE_AT_RESET2_REG); if (((ref_clk_satr >> DEVICE_SAMPLE_AT_RESET2_REG_REFCLK_OFFSET) & 0x1) == DEVICE_SAMPLE_AT_RESET2_REG_REFCLK_25MHZ) - divider = a38x_vco_freq_per_sar_ref_clk_25_mhz[sar_val] / freq_val[frequency]; + divider = a38x_vco_freq_per_sar_ref_clk_25_mhz[sar_val] / freq; else - divider = a38x_vco_freq_per_sar_ref_clk_40_mhz[sar_val] / freq_val[frequency]; + divider = a38x_vco_freq_per_sar_ref_clk_40_mhz[sar_val] / freq;
- if ((async_mode_at_tf == 1) && (freq_val[frequency] > 400)) { + if ((async_mode_at_tf == 1) && (freq > 400)) { /* Set async mode */ dunit_write(0x20220, 0x1000, 0x1000); dunit_write(0xe42f4, 0x200, 0x200); @@ -769,42 +768,38 @@ static int ddr3_tip_a38x_set_divider(u8 dev_num, u32 if_id,
/* Set KNL values */ switch (frequency) { -#ifdef CONFIG_DDR3 - case DDR_FREQ_467: + case MV_DDR_FREQ_467: async_val = 0x806f012; break; - case DDR_FREQ_533: + case MV_DDR_FREQ_533: async_val = 0x807f012; break; - case DDR_FREQ_600: + case MV_DDR_FREQ_600: async_val = 0x805f00a; break; -#endif - case DDR_FREQ_667: + case MV_DDR_FREQ_667: async_val = 0x809f012; break; - case DDR_FREQ_800: + case MV_DDR_FREQ_800: async_val = 0x807f00a; break; -#ifdef CONFIG_DDR3 - case DDR_FREQ_850: + case MV_DDR_FREQ_850: async_val = 0x80cb012; break; -#endif - case DDR_FREQ_900: + case MV_DDR_FREQ_900: async_val = 0x80d7012; break; - case DDR_FREQ_933: + case MV_DDR_FREQ_933: async_val = 0x80df012; break; - case DDR_FREQ_1000: + case MV_DDR_FREQ_1000: async_val = 0x80ef012; break; - case DDR_FREQ_1066: + case MV_DDR_FREQ_1066: async_val = 0x80ff012; break; default: - /* set DDR_FREQ_667 as default */ + /* set MV_DDR_FREQ_667 as default */ async_val = 0x809f012; } dunit_write(0xe42f0, 0xffffffff, async_val); @@ -890,7 +885,7 @@ int mv_ddr_early_init(void)
mv_ddr_sw_db_init(0, 0);
- if (tm->interface_params[0].memory_freq != DDR_FREQ_SAR) + if (tm->interface_params[0].memory_freq != MV_DDR_FREQ_SAR) async_mode_at_tf = 1;
return MV_OK; @@ -934,7 +929,7 @@ int ddr3_silicon_post_init(void)
u32 mv_ddr_init_freq_get(void) { - enum hws_ddr_freq freq; + enum mv_ddr_freq freq;
mv_ddr_sar_freq_get(0, &freq);
diff --git a/drivers/ddr/marvell/a38x/mv_ddr_plat.h b/drivers/ddr/marvell/a38x/mv_ddr_plat.h index 9c5fdecd9341..a307b679766e 100644 --- a/drivers/ddr/marvell/a38x/mv_ddr_plat.h +++ b/drivers/ddr/marvell/a38x/mv_ddr_plat.h @@ -1,11 +1,7 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (C) Marvell International Ltd. and its affiliates - */ - #ifndef _MV_DDR_PLAT_H #define _MV_DDR_PLAT_H
+#define MAX_DEVICE_NUM 1 #define MAX_INTERFACE_NUM 1 #define MAX_BUS_NUM 5 #define DDR_IF_CTRL_SUBPHYS_NUM 3 @@ -121,6 +117,9 @@ #define DLB_QUEUE_MAP_REG 0x1784 #define DLB_SPLIT_REG 0x1788
+/* ck swap control subphy number */ +#define CK_SWAP_CTRL_PHY_NUM 2 + /* Subphy result control per byte registers */ #define RESULT_CONTROL_BYTE_PUP_0_REG 0x1830 #define RESULT_CONTROL_BYTE_PUP_1_REG 0x1834 @@ -221,7 +220,7 @@ extern u16 odt_intercept[]; int mv_ddr_pre_training_soc_config(const char *ddr_type); int mv_ddr_post_training_soc_config(const char *ddr_type); void mv_ddr_mem_scrubbing(void); - +u32 mv_ddr_init_freq_get(void); void mv_ddr_odpg_enable(void); void mv_ddr_odpg_disable(void); void mv_ddr_odpg_done_clr(void); @@ -233,4 +232,5 @@ int mv_ddr_pre_training_fixup(void); int mv_ddr_post_training_fixup(void); int mv_ddr_manual_cal_do(void); int ddr3_calc_mem_cs_size(u32 cs, uint64_t *cs_size); + #endif /* _MV_DDR_PLAT_H */ diff --git a/drivers/ddr/marvell/a38x/mv_ddr_regs.h b/drivers/ddr/marvell/a38x/mv_ddr_regs.h index ceda204a4985..cf2a6c92e80b 100644 --- a/drivers/ddr/marvell/a38x/mv_ddr_regs.h +++ b/drivers/ddr/marvell/a38x/mv_ddr_regs.h @@ -134,6 +134,7 @@ #define SDRAM_OP_CMD_CS_BASE 8 #define SDRAM_OP_CMD_CS_OFFS(cs) (SDRAM_OP_CMD_CS_BASE + (cs)) #define SDRAM_OP_CMD_CS_MASK 0x1 +#define SDRAM_OP_CMD_ALL_CS_MASK 0xf enum { CMD_NORMAL, CMD_PRECHARGE, @@ -270,6 +271,10 @@ enum { #define ZQC_CFG_REG 0x15e4 #define DRAM_PHY_CFG_REG 0x15ec #define ODPG_CTRL_CTRL_REG 0x1600 +#define ODPG_CTRL_AUTO_REFRESH_OFFS 21 +#define ODPG_CTRL_AUTO_REFRESH_MASK 0x1 +#define ODPG_CTRL_AUTO_REFRESH_DIS 1 +#define ODPG_CTRL_AUTO_REFRESH_ENA 0
#define ODPG_DATA_CTRL_REG 0x1630 #define ODPG_WRBUF_WR_CTRL_OFFS 0 @@ -406,6 +411,20 @@ enum { #define CRX_PHY_REG(cs) (CRX_PHY_BASE + (cs) * 0x4)
#define PHY_CTRL_PHY_REG 0x90 +#define INV_PAD0_OFFS 2 +#define INV_PAD1_OFFS 3 +#define INV_PAD2_OFFS 4 +#define INV_PAD3_OFFS 5 +#define INV_PAD4_OFFS 6 +#define INV_PAD5_OFFS 7 +#define INV_PAD6_OFFS 8 +#define INV_PAD7_OFFS 9 +#define INV_PAD8_OFFS 10 +#define INV_PAD9_OFFS 11 +#define INV_PAD10_OFFS 12 +#define INV_PAD_MASK 0x1 +#define INVERT_PAD 1 + #define ADLL_CFG0_PHY_REG 0x92 #define ADLL_CFG1_PHY_REG 0x93 #define ADLL_CFG2_PHY_REG 0x94 diff --git a/drivers/ddr/marvell/a38x/mv_ddr_spd.c b/drivers/ddr/marvell/a38x/mv_ddr_spd.c index e9e7f18098b9..04dbfe94d668 100644 --- a/drivers/ddr/marvell/a38x/mv_ddr_spd.c +++ b/drivers/ddr/marvell/a38x/mv_ddr_spd.c @@ -81,9 +81,6 @@ int mv_ddr_spd_timing_calc(union mv_ddr_spd_data *spd_data, unsigned int timing_ timing_data[MV_DDR_TWR_MIN] = (spd_data->byte_fields.byte_42 + (spd_data->byte_fields.byte_41.bit_fields.t_wr_min_msn << MV_DDR_SPD_MSB_OFFS)) * MV_DDR_SPD_DATA_MTB; - /* FIXME: wa: set twr to a default value, if it's unset on spd */ - if (timing_data[MV_DDR_TWR_MIN] == 0) - timing_data[MV_DDR_TWR_MIN] = 15000;
/* t rcd min, ps */ calc_val = spd_data->byte_fields.byte_25 * MV_DDR_SPD_DATA_MTB + @@ -127,6 +124,13 @@ int mv_ddr_spd_timing_calc(union mv_ddr_spd_data *spd_data, unsigned int timing_ return 1; timing_data[MV_DDR_TRRD_L_MIN] = calc_val;
+ /* t ccd l min, ps */ + calc_val = spd_data->byte_fields.byte_40 * MV_DDR_SPD_DATA_MTB + + (signed char)spd_data->byte_fields.byte_117 * MV_DDR_SPD_DATA_FTB; + if (calc_val < 0) + return 1; + timing_data[MV_DDR_TCCD_L_MIN] = calc_val; + /* t faw min, ps */ timing_data[MV_DDR_TFAW_MIN] = (spd_data->byte_fields.byte_37 + (spd_data->byte_fields.byte_36.bit_fields.t_faw_min_msn << MV_DDR_SPD_MSB_OFFS)) * @@ -136,17 +140,11 @@ int mv_ddr_spd_timing_calc(union mv_ddr_spd_data *spd_data, unsigned int timing_ timing_data[MV_DDR_TWTR_S_MIN] = (spd_data->byte_fields.byte_44 + (spd_data->byte_fields.byte_43.bit_fields.t_wtr_s_min_msn << MV_DDR_SPD_MSB_OFFS)) * MV_DDR_SPD_DATA_MTB; - /* FIXME: wa: set twtr_s to a default value, if it's unset on spd */ - if (timing_data[MV_DDR_TWTR_S_MIN] == 0) - timing_data[MV_DDR_TWTR_S_MIN] = 2500;
/* t wtr l min, ps */ timing_data[MV_DDR_TWTR_L_MIN] = (spd_data->byte_fields.byte_45 + (spd_data->byte_fields.byte_43.bit_fields.t_wtr_l_min_msn << MV_DDR_SPD_MSB_OFFS)) * MV_DDR_SPD_DATA_MTB; - /* FIXME: wa: set twtr_l to a default value, if it's unset on spd */ - if (timing_data[MV_DDR_TWTR_L_MIN] == 0) - timing_data[MV_DDR_TWTR_L_MIN] = 7500;
return 0; } diff --git a/drivers/ddr/marvell/a38x/mv_ddr_topology.c b/drivers/ddr/marvell/a38x/mv_ddr_topology.c index f56ce0677074..ef3b658a7899 100644 --- a/drivers/ddr/marvell/a38x/mv_ddr_topology.c +++ b/drivers/ddr/marvell/a38x/mv_ddr_topology.c @@ -2,15 +2,16 @@ /* * Copyright (C) Marvell International Ltd. and its affiliates */ +#include "ddr_ml_wrapper.h" +#include "mv_ddr_plat.h"
#include "mv_ddr_topology.h" #include "mv_ddr_common.h" #include "mv_ddr_spd.h" -#include "ddr3_init.h" #include "ddr_topology_def.h" #include "ddr3_training_ip_db.h" #include "ddr3_training_ip.h" - +#include "mv_ddr_training_db.h"
unsigned int mv_ddr_cl_calc(unsigned int taa_min, unsigned int tclk) { @@ -32,54 +33,57 @@ unsigned int mv_ddr_cwl_calc(unsigned int tclk) cwl = 11; else if (tclk >= 833) cwl = 12; + else if (tclk >= 750) + cwl = 14; + else if (tclk >= 625) + cwl = 16; else cwl = 0;
return cwl; }
-struct mv_ddr_topology_map *mv_ddr_topology_map_update(void) +int mv_ddr_topology_map_update(void) { struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); + struct if_params *iface_params = &(tm->interface_params[0]); unsigned int octets_per_if_num = ddr3_tip_dev_attr_get(0, MV_ATTR_OCTET_PER_INTERFACE); - enum hws_speed_bin speed_bin_index; - enum hws_ddr_freq freq = DDR_FREQ_LAST; + enum mv_ddr_speed_bin speed_bin_index; + enum mv_ddr_freq freq = MV_DDR_FREQ_LAST; unsigned int tclk; unsigned char val = 0; int i;
- - if (tm->interface_params[0].memory_freq == DDR_FREQ_SAR) - tm->interface_params[0].memory_freq = mv_ddr_init_freq_get(); + if (iface_params->memory_freq == MV_DDR_FREQ_SAR) + iface_params->memory_freq = mv_ddr_init_freq_get();
if (tm->cfg_src == MV_DDR_CFG_SPD) { /* check dram device type */ val = mv_ddr_spd_dev_type_get(&tm->spd_data); if (val != MV_DDR_SPD_DEV_TYPE_DDR4) { printf("mv_ddr: unsupported dram device type found\n"); - return NULL; + return -1; }
/* update topology map with timing data */ if (mv_ddr_spd_timing_calc(&tm->spd_data, tm->timing_data) > 0) { printf("mv_ddr: negative timing data found\n"); - return NULL; + return -1; }
/* update device width in topology map */ - tm->interface_params[0].bus_width = mv_ddr_spd_dev_width_get(&tm->spd_data); + iface_params->bus_width = mv_ddr_spd_dev_width_get(&tm->spd_data);
/* update die capacity in topology map */ - tm->interface_params[0].memory_size = mv_ddr_spd_die_capacity_get(&tm->spd_data); + iface_params->memory_size = mv_ddr_spd_die_capacity_get(&tm->spd_data);
/* update bus bit mask in topology map */ tm->bus_act_mask = mv_ddr_bus_bit_mask_get();
/* update cs bit mask in topology map */ val = mv_ddr_spd_cs_bit_mask_get(&tm->spd_data); - for (i = 0; i < octets_per_if_num; i++) { - tm->interface_params[0].as_bus_params[i].cs_bitmask = val; - } + for (i = 0; i < octets_per_if_num; i++) + iface_params->as_bus_params[i].cs_bitmask = val;
/* check dram module type */ val = mv_ddr_spd_module_type_get(&tm->spd_data); @@ -93,48 +97,44 @@ struct mv_ddr_topology_map *mv_ddr_topology_map_update(void) break; default: printf("mv_ddr: unsupported dram module type found\n"); - return NULL; + return -1; }
/* update mirror bit mask in topology map */ val = mv_ddr_spd_mem_mirror_get(&tm->spd_data); - for (i = 0; i < octets_per_if_num; i++) { - tm->interface_params[0].as_bus_params[i].mirror_enable_bitmask = val << 1; - } + for (i = 0; i < octets_per_if_num; i++) + iface_params->as_bus_params[i].mirror_enable_bitmask = val << 1;
- tclk = 1000000 / freq_val[tm->interface_params[0].memory_freq]; + tclk = 1000000 / mv_ddr_freq_get(iface_params->memory_freq); /* update cas write latency (cwl) */ val = mv_ddr_cwl_calc(tclk); if (val == 0) { printf("mv_ddr: unsupported cas write latency value found\n"); - return NULL; + return -1; } - tm->interface_params[0].cas_wl = val; + iface_params->cas_wl = val;
/* update cas latency (cl) */ mv_ddr_spd_supported_cls_calc(&tm->spd_data); val = mv_ddr_cl_calc(tm->timing_data[MV_DDR_TAA_MIN], tclk); if (val == 0) { printf("mv_ddr: unsupported cas latency value found\n"); - return NULL; + return -1; } - tm->interface_params[0].cas_l = val; + iface_params->cas_l = val; } else if (tm->cfg_src == MV_DDR_CFG_DEFAULT) { /* set cas and cas-write latencies per speed bin, if they unset */ - speed_bin_index = tm->interface_params[0].speed_bin_index; - freq = tm->interface_params[0].memory_freq; + speed_bin_index = iface_params->speed_bin_index; + freq = iface_params->memory_freq;
- if (tm->interface_params[0].cas_l == 0) - tm->interface_params[0].cas_l = - cas_latency_table[speed_bin_index].cl_val[freq]; + if (iface_params->cas_l == 0) + iface_params->cas_l = mv_ddr_cl_val_get(speed_bin_index, freq);
- if (tm->interface_params[0].cas_wl == 0) - tm->interface_params[0].cas_wl = - cas_write_latency_table[speed_bin_index].cl_val[freq]; + if (iface_params->cas_wl == 0) + iface_params->cas_wl = mv_ddr_cwl_val_get(speed_bin_index, freq); }
- - return tm; + return 0; }
unsigned short mv_ddr_bus_bit_mask_get(void) @@ -195,3 +195,150 @@ unsigned int mv_ddr_if_bus_width_get(void)
return bus_width; } + +unsigned int mv_ddr_cs_num_get(void) +{ + unsigned int cs_num = 0; + unsigned int cs, sphy; + struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); + struct if_params *iface_params = &(tm->interface_params[0]); + unsigned int sphy_max = ddr3_tip_dev_attr_get(0, MV_ATTR_OCTET_PER_INTERFACE); + + for (sphy = 0; sphy < sphy_max; sphy++) { + VALIDATE_BUS_ACTIVE(tm->bus_act_mask, sphy); + break; + } + + for (cs = 0; cs < MAX_CS_NUM; cs++) { + VALIDATE_ACTIVE(iface_params->as_bus_params[sphy].cs_bitmask, cs); + cs_num++; + } + + return cs_num; +} + +int mv_ddr_is_ecc_ena(void) +{ + struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); + + if (DDR3_IS_ECC_PUP4_MODE(tm->bus_act_mask) || + DDR3_IS_ECC_PUP3_MODE(tm->bus_act_mask) || + DDR3_IS_ECC_PUP8_MODE(tm->bus_act_mask)) + return 1; + else + return 0; +} + +/* translate topology map definition to real memory size in bits */ +static unsigned int mem_size[] = { + ADDR_SIZE_512MB, + ADDR_SIZE_1GB, + ADDR_SIZE_2GB, + ADDR_SIZE_4GB, + ADDR_SIZE_8GB + /* TODO: add capacity up to 256GB */ +}; + +unsigned long long mv_ddr_mem_sz_per_cs_get(void) +{ + unsigned long long mem_sz_per_cs; + unsigned int i, sphys, sphys_per_dunit; + unsigned int sphy_max = ddr3_tip_dev_attr_get(0, MV_ATTR_OCTET_PER_INTERFACE); + struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); + struct if_params *iface_params = &(tm->interface_params[0]); + + /* calc number of active subphys excl. ecc one */ + for (i = 0, sphys = 0; i < sphy_max - 1; i++) { + VALIDATE_BUS_ACTIVE(tm->bus_act_mask, i); + sphys++; + } + + /* calc number of subphys per ddr unit */ + if (iface_params->bus_width == MV_DDR_DEV_WIDTH_8BIT) + sphys_per_dunit = MV_DDR_ONE_SPHY_PER_DUNIT; + else if (iface_params->bus_width == MV_DDR_DEV_WIDTH_16BIT) + sphys_per_dunit = MV_DDR_TWO_SPHY_PER_DUNIT; + else { + printf("mv_ddr: unsupported bus width type found\n"); + return 0; + } + + /* calc dram size per cs */ + mem_sz_per_cs = (unsigned long long)mem_size[iface_params->memory_size] * + (unsigned long long)sphys / + (unsigned long long)sphys_per_dunit; + + return mem_sz_per_cs; +} + +unsigned long long mv_ddr_mem_sz_get(void) +{ + unsigned long long tot_mem_sz = 0; + unsigned long long mem_sz_per_cs = 0; + unsigned long long max_cs = mv_ddr_cs_num_get(); + + mem_sz_per_cs = mv_ddr_mem_sz_per_cs_get(); + tot_mem_sz = max_cs * mem_sz_per_cs; + + return tot_mem_sz; +} + +unsigned int mv_ddr_rtt_nom_get(void) +{ + struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); + unsigned int rtt_nom = tm->edata.mem_edata.rtt_nom; + + if (rtt_nom >= MV_DDR_RTT_NOM_PARK_RZQ_LAST) { + printf("error: %s: unsupported rtt_nom parameter found\n", __func__); + rtt_nom = PARAM_UNDEFINED; + } + + return rtt_nom; +} + +unsigned int mv_ddr_rtt_park_get(void) +{ + struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); + unsigned int cs_num = mv_ddr_cs_num_get(); + unsigned int rtt_park = MV_DDR_RTT_NOM_PARK_RZQ_LAST; + + if (cs_num > 0 && cs_num <= MAX_CS_NUM) + rtt_park = tm->edata.mem_edata.rtt_park[cs_num - 1]; + + if (rtt_park >= MV_DDR_RTT_NOM_PARK_RZQ_LAST) { + printf("error: %s: unsupported rtt_park parameter found\n", __func__); + rtt_park = PARAM_UNDEFINED; + } + + return rtt_park; +} + +unsigned int mv_ddr_rtt_wr_get(void) +{ + struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); + unsigned int cs_num = mv_ddr_cs_num_get(); + unsigned int rtt_wr = MV_DDR_RTT_WR_RZQ_LAST; + + if (cs_num > 0 && cs_num <= MAX_CS_NUM) + rtt_wr = tm->edata.mem_edata.rtt_wr[cs_num - 1]; + + if (rtt_wr >= MV_DDR_RTT_WR_RZQ_LAST) { + printf("error: %s: unsupported rtt_wr parameter found\n", __func__); + rtt_wr = PARAM_UNDEFINED; + } + + return rtt_wr; +} + +unsigned int mv_ddr_dic_get(void) +{ + struct mv_ddr_topology_map *tm = mv_ddr_topology_map_get(); + unsigned int dic = tm->edata.mem_edata.dic; + + if (dic >= MV_DDR_DIC_RZQ_LAST) { + printf("error: %s: unsupported dic parameter found\n", __func__); + dic = PARAM_UNDEFINED; + } + + return dic; +} diff --git a/drivers/ddr/marvell/a38x/mv_ddr_topology.h b/drivers/ddr/marvell/a38x/mv_ddr_topology.h index 7bef2d1e0e87..766f25db5733 100644 --- a/drivers/ddr/marvell/a38x/mv_ddr_topology.h +++ b/drivers/ddr/marvell/a38x/mv_ddr_topology.h @@ -6,6 +6,75 @@ #ifndef _MV_DDR_TOPOLOGY_H #define _MV_DDR_TOPOLOGY_H
+#define MAX_CS_NUM 4 + +enum mv_ddr_speed_bin { + SPEED_BIN_DDR_800D, + SPEED_BIN_DDR_800E, + SPEED_BIN_DDR_1066E, + SPEED_BIN_DDR_1066F, + SPEED_BIN_DDR_1066G, + SPEED_BIN_DDR_1333F, + SPEED_BIN_DDR_1333G, + SPEED_BIN_DDR_1333H, + SPEED_BIN_DDR_1333J, + SPEED_BIN_DDR_1600G, + SPEED_BIN_DDR_1600H, + SPEED_BIN_DDR_1600J, + SPEED_BIN_DDR_1600K, + SPEED_BIN_DDR_1866J, + SPEED_BIN_DDR_1866K, + SPEED_BIN_DDR_1866L, + SPEED_BIN_DDR_1866M, + SPEED_BIN_DDR_2133K, + SPEED_BIN_DDR_2133L, + SPEED_BIN_DDR_2133M, + SPEED_BIN_DDR_2133N, + + SPEED_BIN_DDR_1333H_EXT, + SPEED_BIN_DDR_1600K_EXT, + SPEED_BIN_DDR_1866M_EXT +}; + +enum mv_ddr_freq { + MV_DDR_FREQ_LOW_FREQ, + MV_DDR_FREQ_400, + MV_DDR_FREQ_533, + MV_DDR_FREQ_667, + MV_DDR_FREQ_800, + MV_DDR_FREQ_933, + MV_DDR_FREQ_1066, + MV_DDR_FREQ_311, + MV_DDR_FREQ_333, + MV_DDR_FREQ_467, + MV_DDR_FREQ_850, + MV_DDR_FREQ_600, + MV_DDR_FREQ_300, + MV_DDR_FREQ_900, + MV_DDR_FREQ_360, + MV_DDR_FREQ_1000, + MV_DDR_FREQ_LAST, + MV_DDR_FREQ_SAR +}; + +enum mv_ddr_speed_bin_timing { + SPEED_BIN_TRCD, + SPEED_BIN_TRP, + SPEED_BIN_TRAS, + SPEED_BIN_TRC, + SPEED_BIN_TRRD1K, + SPEED_BIN_TRRD2K, + SPEED_BIN_TPD, + SPEED_BIN_TFAW1K, + SPEED_BIN_TFAW2K, + SPEED_BIN_TWTR, + SPEED_BIN_TRTP, + SPEED_BIN_TWR, + SPEED_BIN_TMOD, + SPEED_BIN_TXPDLL, + SPEED_BIN_TXSDLL +}; + /* ddr bus masks */ #define BUS_MASK_32BIT 0xf #define BUS_MASK_32BIT_ECC 0x1f @@ -16,6 +85,12 @@ #define MV_DDR_64BIT_ECC_PUP8_BUS_MASK 0x1ff #define MV_DDR_32BIT_ECC_PUP8_BUS_MASK 0x10f
+#define MV_DDR_CS_BITMASK_1CS 0x1 +#define MV_DDR_CS_BITMASK_2CS 0x3 + +#define MV_DDR_ONE_SPHY_PER_DUNIT 1 +#define MV_DDR_TWO_SPHY_PER_DUNIT 2 + /* source of ddr configuration data */ enum mv_ddr_cfg_src { MV_DDR_CFG_DEFAULT, /* based on data in mv_ddr_topology_map structure */ @@ -25,11 +100,6 @@ enum mv_ddr_cfg_src { MV_DDR_CFG_LAST };
-enum mv_ddr_num_of_sub_phys_per_ddr_unit { - SINGLE_SUB_PHY = 1, - TWO_SUB_PHYS = 2 -}; - enum mv_ddr_temperature { MV_DDR_TEMP_LOW, MV_DDR_TEMP_NORMAL, @@ -53,12 +123,78 @@ enum mv_ddr_timing_data { MV_DDR_TRAS_MIN, /* min active to precharge delay time (t ras min) */ MV_DDR_TRRD_S_MIN, /* min activate to activate delay time (t rrd_s min), diff bank group */ MV_DDR_TRRD_L_MIN, /* min activate to activate delay time (t rrd_l min), same bank group */ + MV_DDR_TCCD_L_MIN, /* min cas to cas delay time (t ccd_l min), same bank group */ MV_DDR_TFAW_MIN, /* min four activate window delay time (t faw min) */ MV_DDR_TWTR_S_MIN, /* min write to read time (t wtr s min), diff bank group */ MV_DDR_TWTR_L_MIN, /* min write to read time (t wtr l min), same bank group */ MV_DDR_TDATA_LAST };
+enum mv_ddr_electrical_data { + MV_DDR_CK_DLY, + MV_DDR_PHY_REG3, + MV_DDR_ZPRI_DATA, + MV_DDR_ZNRI_DATA, + MV_DDR_ZPRI_CTRL, + MV_DDR_ZNRI_CTRL, + MV_DDR_ZPODT_DATA, + MV_DDR_ZNODT_DATA, + MV_DDR_ZPODT_CTRL, + MV_DDR_ZNODT_CTRL, + MV_DDR_DIC, + MV_DDR_ODT_CFG, + MV_DDR_RTT_NOM, + MV_DDR_RTT_WR, + MV_DDR_RTT_PARK, + MV_DDR_EDATA_LAST +}; + +/* memory electrical configuration values */ +enum mv_ddr_rtt_nom_park_evalue { + MV_DDR_RTT_NOM_PARK_RZQ_DISABLE, + MV_DDR_RTT_NOM_PARK_RZQ_DIV4, /* 60-Ohm; RZQ = 240-Ohm */ + MV_DDR_RTT_NOM_PARK_RZQ_DIV2, /* 120-Ohm; RZQ = 240-Ohm */ + MV_DDR_RTT_NOM_PARK_RZQ_DIV6, /* 40-Ohm; RZQ = 240-Ohm */ + MV_DDR_RTT_NOM_PARK_RZQ_DIV1, /* 240-Ohm; RZQ = 240-Ohm */ + MV_DDR_RTT_NOM_PARK_RZQ_DIV5, /* 48-Ohm; RZQ = 240-Ohm */ + MV_DDR_RTT_NOM_PARK_RZQ_DIV3, /* 80-Ohm; RZQ = 240-Ohm */ + MV_DDR_RTT_NOM_PARK_RZQ_DIV7, /* 34-Ohm; RZQ = 240-Ohm */ + MV_DDR_RTT_NOM_PARK_RZQ_LAST +}; + +enum mv_ddr_rtt_wr_evalue { + MV_DDR_RTT_WR_DYN_ODT_OFF, + MV_DDR_RTT_WR_RZQ_DIV2, /* 120-Ohm; RZQ = 240-Ohm */ + MV_DDR_RTT_WR_RZQ_DIV1, /* 240-Ohm; RZQ = 240-Ohm */ + MV_DDR_RTT_WR_HIZ, + MV_DDR_RTT_WR_RZQ_DIV3, /* 80-Ohm; RZQ = 240-Ohm */ + MV_DDR_RTT_WR_RZQ_LAST +}; + +enum mv_ddr_dic_evalue { + MV_DDR_DIC_RZQ_DIV7, /* 34-Ohm; RZQ = 240-Ohm */ + MV_DDR_DIC_RZQ_DIV5, /* 48-Ohm; RZQ = 240-Ohm */ + MV_DDR_DIC_RZQ_LAST +}; + +/* phy electrical configuration values */ +enum mv_ddr_ohm_evalue { + MV_DDR_OHM_30 = 30, + MV_DDR_OHM_48 = 48, + MV_DDR_OHM_60 = 60, + MV_DDR_OHM_80 = 80, + MV_DDR_OHM_120 = 120, + MV_DDR_OHM_240 = 240, + MV_DDR_OHM_LAST +}; + +/* mac electrical configuration values */ +enum mv_ddr_odt_cfg_evalue { + MV_DDR_ODT_CFG_NORMAL, + MV_DDR_ODT_CFG_ALWAYS_ON, + MV_DDR_ODT_CFG_LAST +}; + enum mv_ddr_dev_width { /* sdram device width */ MV_DDR_DEV_WIDTH_4BIT, MV_DDR_DEV_WIDTH_8BIT, @@ -119,11 +255,75 @@ enum mv_ddr_die_count { MV_DDR_DIE_CNT_LAST };
+#define IS_ACTIVE(mask, id) \ + ((mask) & (1 << (id))) + +#define VALIDATE_ACTIVE(mask, id) \ + { \ + if (IS_ACTIVE(mask, id) == 0) \ + continue; \ + } + +#define IS_IF_ACTIVE(if_mask, if_id) \ + ((if_mask) & (1 << (if_id))) + +#define VALIDATE_IF_ACTIVE(mask, id) \ + { \ + if (IS_IF_ACTIVE(mask, id) == 0) \ + continue; \ + } + +#define IS_BUS_ACTIVE(if_mask , if_id) \ + (((if_mask) >> (if_id)) & 1) + +#define VALIDATE_BUS_ACTIVE(mask, id) \ + { \ + if (IS_BUS_ACTIVE(mask, id) == 0) \ + continue; \ + } + +#define DDR3_IS_ECC_PUP3_MODE(if_mask) \ + (((if_mask) == BUS_MASK_16BIT_ECC_PUP3) ? 1 : 0) + +#define DDR3_IS_ECC_PUP4_MODE(if_mask) \ + (((if_mask) == BUS_MASK_32BIT_ECC || \ + (if_mask) == BUS_MASK_16BIT_ECC) ? 1 : 0) + +#define DDR3_IS_16BIT_DRAM_MODE(mask) \ + (((mask) == BUS_MASK_16BIT || \ + (mask) == BUS_MASK_16BIT_ECC || \ + (mask) == BUS_MASK_16BIT_ECC_PUP3) ? 1 : 0) + +#define DDR3_IS_ECC_PUP8_MODE(if_mask) \ + (((if_mask) == MV_DDR_32BIT_ECC_PUP8_BUS_MASK || \ + (if_mask) == MV_DDR_64BIT_ECC_PUP8_BUS_MASK) ? 1 : 0) + +#define MV_DDR_IS_64BIT_DRAM_MODE(mask) \ + ((((mask) & MV_DDR_64BIT_BUS_MASK) == MV_DDR_64BIT_BUS_MASK) || \ + (((mask) & MV_DDR_64BIT_ECC_PUP8_BUS_MASK) == MV_DDR_64BIT_ECC_PUP8_BUS_MASK) ? 1 : 0) + +#define MV_DDR_IS_32BIT_IN_64BIT_DRAM_MODE(mask, sphys) \ + (((sphys) == 9) && \ + (((mask) == BUS_MASK_32BIT) || \ + ((mask) == MV_DDR_32BIT_ECC_PUP8_BUS_MASK)) ? 1 : 0) + +#define MV_DDR_IS_HALF_BUS_DRAM_MODE(mask, sphys) \ + (MV_DDR_IS_32BIT_IN_64BIT_DRAM_MODE(mask, sphys) || \ + DDR3_IS_16BIT_DRAM_MODE(mask)) + +struct mv_ddr_topology_map *mv_ddr_topology_map_get(void); unsigned int mv_ddr_cl_calc(unsigned int taa_min, unsigned int tclk); unsigned int mv_ddr_cwl_calc(unsigned int tclk); -struct mv_ddr_topology_map *mv_ddr_topology_map_update(void); -struct dram_config *mv_ddr_dram_config_update(void); +int mv_ddr_topology_map_update(void); unsigned short mv_ddr_bus_bit_mask_get(void); unsigned int mv_ddr_if_bus_width_get(void); +unsigned int mv_ddr_cs_num_get(void); +int mv_ddr_is_ecc_ena(void); +unsigned long long mv_ddr_mem_sz_per_cs_get(void); +unsigned long long mv_ddr_mem_sz_get(void); +unsigned int mv_ddr_rtt_nom_get(void); +unsigned int mv_ddr_rtt_park_get(void); +unsigned int mv_ddr_rtt_wr_get(void); +unsigned int mv_ddr_dic_get(void);
#endif /* _MV_DDR_TOPOLOGY_H */ diff --git a/drivers/ddr/marvell/a38x/mv_ddr_training_db.h b/drivers/ddr/marvell/a38x/mv_ddr_training_db.h new file mode 100644 index 000000000000..838be4574d94 --- /dev/null +++ b/drivers/ddr/marvell/a38x/mv_ddr_training_db.h @@ -0,0 +1,40 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#ifndef _MV_DDR_TRAINING_DB_H +#define _MV_DDR_TRAINING_DB_H + +#include "mv_ddr_topology.h" + +/* in ns */ +#define TREFI_LOW 7800 +#define TREFI_HIGH 3900 + +enum mv_ddr_page_size { + MV_DDR_PAGE_SIZE_1K = 1, + MV_DDR_PAGE_SIZE_2K +}; + +struct mv_ddr_page_element { + /* 8-bit bus width page size */ + enum mv_ddr_page_size page_size_8bit; + /* 16-bit bus width page size */ + enum mv_ddr_page_size page_size_16bit; +}; + +/* cas latency value per frequency */ +struct mv_ddr_cl_val_per_freq { + unsigned int cl_val[MV_DDR_FREQ_LAST]; +}; + +u32 mv_ddr_rfc_get(u32 mem); +unsigned int *mv_ddr_freq_tbl_get(void); +u32 mv_ddr_freq_get(enum mv_ddr_freq freq); +u32 mv_ddr_page_size_get(enum mv_ddr_dev_width bus_width, enum mv_ddr_die_capacity mem_size); +unsigned int mv_ddr_speed_bin_timing_get(enum mv_ddr_speed_bin index, enum mv_ddr_speed_bin_timing element); +u32 mv_ddr_cl_val_get(u32 index, u32 freq); +u32 mv_ddr_cwl_val_get(u32 index, u32 freq); + +#endif /* _MV_DDR_TRAINING_DB_H */ diff --git a/drivers/ddr/marvell/a38x/xor.c b/drivers/ddr/marvell/a38x/xor.c index f859596d8953..5fb9e216d38b 100644 --- a/drivers/ddr/marvell/a38x/xor.c +++ b/drivers/ddr/marvell/a38x/xor.c @@ -4,6 +4,7 @@ */
#include "ddr3_init.h" +#include "mv_ddr_common.h" #include "xor_regs.h"
/* defines */ @@ -339,16 +340,17 @@ void ddr3_new_tip_ecc_scrub(void) { u32 cs_c, max_cs; u32 cs_ena = 0; - u32 dev_num = 0; uint64_t total_mem_size, cs_mem_size = 0;
printf("DDR Training Sequence - Start scrubbing\n"); - max_cs = ddr3_tip_max_cs_get(dev_num); + max_cs = mv_ddr_cs_num_get(); for (cs_c = 0; cs_c < max_cs; cs_c++) cs_ena |= 1 << cs_c;
- /* assume that all CS have same size */ +#if defined(CONFIG_ARMADA_38X) || defined(CONFIG_ARMADA_39X) + /* all chip-selects are of same size */ ddr3_calc_mem_cs_size(0, &cs_mem_size); +#endif
mv_sys_xor_init(max_cs, cs_ena, cs_mem_size, 0); total_mem_size = max_cs * cs_mem_size;
Hi Chris,
On 29.11.18 04:16, Chris Packham wrote:
I had a faulty board to debug at $dayjob. Part of that involved trying the latest DDR training code from Marvell. That didn't fix by problem (I suspect a manufacturing issue with that board).
Since I've done the work anyway I figured I'd send this out. Most of the delta is code movement and tidy up. There's very little behavioural change for A38X.
Thank you very much for sync'ing with the Marvell source again. Would it be possible to include the Marvell U-Boot version (Git ID) with such a sync? And perhaps also add a short summary of the changes to tha last sync'ed version (patch list)?
This may however be useful if/when someone starts looking at the newer Armada-3700/3900 SoCs.
How so? Are these SoCs now supported by this DDR setup code as well?
Thanks, Stefan
Chris Packham (1): ARM: mvebu: a38x: sync ddr training code with mv_ddr-armada-18.09
board/CZ.NIC/turris_omnia/turris_omnia.c | 4 +- board/Marvell/db-88f6820-amc/db-88f6820-amc.c | 2 +- board/Marvell/db-88f6820-gp/db-88f6820-gp.c | 2 +- board/gdsys/a38x/controlcenterdc.c | 2 +- board/kobol/helios4/helios4.c | 2 +- board/solidrun/clearfog/clearfog.c | 2 +- drivers/ddr/marvell/a38x/ddr3_debug.c | 414 +-------------- drivers/ddr/marvell/a38x/ddr3_init.c | 91 +--- drivers/ddr/marvell/a38x/ddr3_init.h | 43 +- drivers/ddr/marvell/a38x/ddr3_topology_def.h | 78 --- drivers/ddr/marvell/a38x/ddr3_training.c | 484 +++++++++--------- drivers/ddr/marvell/a38x/ddr3_training_bist.c | 1 + .../a38x/ddr3_training_centralization.c | 3 + drivers/ddr/marvell/a38x/ddr3_training_db.c | 172 ++++--- .../ddr/marvell/a38x/ddr3_training_hw_algo.c | 1 + drivers/ddr/marvell/a38x/ddr3_training_ip.h | 38 -- .../ddr/marvell/a38x/ddr3_training_ip_def.h | 31 -- .../marvell/a38x/ddr3_training_ip_engine.c | 2 + .../marvell/a38x/ddr3_training_ip_engine.h | 1 + .../ddr/marvell/a38x/ddr3_training_ip_flow.h | 91 +--- .../marvell/a38x/ddr3_training_ip_prv_if.h | 10 +- .../ddr/marvell/a38x/ddr3_training_leveling.c | 75 +-- .../ddr/marvell/a38x/ddr3_training_leveling.h | 1 - drivers/ddr/marvell/a38x/ddr3_training_pbs.c | 7 +- drivers/ddr/marvell/a38x/ddr_topology_def.h | 107 +++- drivers/ddr/marvell/a38x/ddr_training_ip_db.h | 2 - drivers/ddr/marvell/a38x/dram_if.h | 13 + .../ddr/marvell/a38x/mv_ddr_build_message.c | 2 +- drivers/ddr/marvell/a38x/mv_ddr_common.h | 38 +- drivers/ddr/marvell/a38x/mv_ddr_plat.c | 181 ++++--- drivers/ddr/marvell/a38x/mv_ddr_plat.h | 12 +- drivers/ddr/marvell/a38x/mv_ddr_regs.h | 19 + drivers/ddr/marvell/a38x/mv_ddr_spd.c | 16 +- drivers/ddr/marvell/a38x/mv_ddr_topology.c | 215 ++++++-- drivers/ddr/marvell/a38x/mv_ddr_topology.h | 214 +++++++- drivers/ddr/marvell/a38x/mv_ddr_training_db.h | 40 ++ drivers/ddr/marvell/a38x/xor.c | 8 +- 37 files changed, 1163 insertions(+), 1261 deletions(-) delete mode 100644 drivers/ddr/marvell/a38x/ddr3_topology_def.h create mode 100644 drivers/ddr/marvell/a38x/dram_if.h create mode 100644 drivers/ddr/marvell/a38x/mv_ddr_training_db.h
Viele Grüße, Stefan
Hi Stefan,
Gmail seems to have started marking some u-boot email as spam so I didn't see this earlier.
On Thu, Nov 29, 2018 at 11:35 PM Stefan Roese sr@denx.de wrote:
Hi Chris,
Can do. The specific sync point armada-18.09.2 is pretty easy to identify (even though they don't use tags) but adding a sha1 won't hurt.
I almost did this patch-by-patch but there was a bit too much noise to signal in that. I'll try and come up with a coherent summary for v2, as I say the A38X stuff is mostly cosmetic.
There is code for the Armada-3700/3900 although the Makefile seems to only support building it for ATF. For now I'm omitting it to keep the patch size down.
One thing that would need to change is the code layout in u-boot since the Marvell version has sub-directories for the IP blocks (e.g. a38x, a3700) with the generic stuff at the top level.
Thanks, Stefan
Viele Grüße, Stefan
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-51 Fax: (+49)-8142-66989-80 Email: sr@denx.de
Chris Packham
Stefan Roese
