[PATCH v4] driver: spi: add bcm iproc qspi support.
From: Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com
IPROC qspi driver supports both BSPI and MSPI modes.
Signed-off-by: Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com Signed-off-by: Bharat Gooty bharat.gooty@broadcom.com Acked-by: Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com
Signed-off-by: Roman Bacik roman.bacik@broadcom.com ---
Changes in v4: - move iproc_qspi.c from spi to mtd/spi - remove iproc_qspi.h - rename IPROC_QSPI to SPI_FLASH_IPROC
Changes in v3: - fix warning by including linux/delay.h - change ofdata_to_platdata to of_to_plat - change priv_auto_alloc_size to priv_auto
Changes in v2: - remove include spi-nor.h - define and use named BITs for writing register values - remove bspi_set_4byte_mode() method
drivers/mtd/spi/Kconfig | 6 + drivers/mtd/spi/Makefile | 1 + drivers/mtd/spi/iproc_qspi.c | 718 +++++++++++++++++++++++++++++++++++ 3 files changed, 725 insertions(+) create mode 100644 drivers/mtd/spi/iproc_qspi.c
diff --git a/drivers/mtd/spi/Kconfig b/drivers/mtd/spi/Kconfig index 408a53f86178..53f9f271431e 100644 --- a/drivers/mtd/spi/Kconfig +++ b/drivers/mtd/spi/Kconfig @@ -16,6 +16,12 @@ config DM_SPI_FLASH enabled together (it is not possible to use driver model for one and not the other).
+config SPI_FLASH_IPROC + bool "QSPI driver for BCM iProc QSPI Controller" + help + This selects the BCM iProc QSPI controller. + This driver support spi flash single, quad and memory reads. + config SPI_FLASH_SANDBOX bool "Support sandbox SPI flash device" depends on SANDBOX && DM_SPI_FLASH diff --git a/drivers/mtd/spi/Makefile b/drivers/mtd/spi/Makefile index 99cc41855223..0ea1a69a7919 100644 --- a/drivers/mtd/spi/Makefile +++ b/drivers/mtd/spi/Makefile @@ -19,5 +19,6 @@ endif
obj-$(CONFIG_SPI_FLASH) += spi-nor.o obj-$(CONFIG_SPI_FLASH_DATAFLASH) += sf_dataflash.o +obj-$(CONFIG_SPI_FLASH_IPROC) += iproc_qspi.o obj-$(CONFIG_$(SPL_TPL_)SPI_FLASH_MTD) += sf_mtd.o obj-$(CONFIG_SPI_FLASH_SANDBOX) += sandbox.o diff --git a/drivers/mtd/spi/iproc_qspi.c b/drivers/mtd/spi/iproc_qspi.c new file mode 100644 index 000000000000..e05c48d1082c --- /dev/null +++ b/drivers/mtd/spi/iproc_qspi.c @@ -0,0 +1,718 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2020-2021 Broadcom + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <malloc.h> +#include <spi.h> +#include <asm/io.h> +#include <linux/delay.h> +#include <linux/err.h> +#include <linux/mtd/spi-nor.h> + +/* 175MHz */ +#define QSPI_AXI_CLK 175000000 +#define QSPI_DEF_SCK_FREQ 50000000 +#define QSPI_WAIT_TIMEOUT_MS 200U +#define DWORD_ALIGNED(a) (!(((ulong)(a)) & 3)) + +/*SPI configuration enable*/ +#define IPROC_QSPI_BUS 0 +#define IPROC_QSPI_CS 0 +#define IPROC_BSPI_READ_DUMMY_CYCLES 0x08 + +/* Chip attributes */ +#define SPBR_MIN 8U +#define SPBR_MAX 255U +#define NUM_CDRAM 16U + +#define CDRAM_PCS0 2 +#define CDRAM_CONT BIT(7) +#define CDRAM_BITS_EN BIT(6) +#define CDRAM_QUAD_MODE BIT(8) +#define CDRAM_RBIT_INPUT BIT(10) +#define MSPI_SPE BIT(6) +#define MSPI_CONT_AFTER_CMD BIT(7) + +/* Register fields */ +#define MSPI_SPCR0_MSB_BITS_8 0x00000020 +#define BSPI_RAF_CONTROL_START_MASK 0x00000001 +#define BSPI_RAF_STATUS_SESSION_BUSY_MASK 0x00000001 +#define BSPI_RAF_STATUS_FIFO_EMPTY_MASK 0x00000002 +#define BSPI_BITS_PER_PHASE_ADDR_MARK 0x00010000 +#define BSPI_BITS_PER_CYCLE_DATA_SHIFT 0 +#define BSPI_BITS_PER_CYCLE_ADDR_SHIFT 16 +#define BSPI_STRAP_OVERRIDE_DATA_QUAD_SHIFT 3 +#define BSPI_STRAP_OVERRIDE_DATA_DUAL_SHIFT 1 +#define BSPI_STRAP_OVERRIDE_SHIFT 0 + +/* MSPI registers */ +#define MSPI_SPCR0_LSB_REG 0x000 +#define MSPI_SPCR0_MSB_REG 0x004 +#define MSPI_SPCR1_LSB_REG 0x008 +#define MSPI_SPCR1_MSB_REG 0x00c +#define MSPI_NEWQP_REG 0x010 +#define MSPI_ENDQP_REG 0x014 +#define MSPI_SPCR2_REG 0x018 +#define MSPI_STATUS_REG 0x020 +#define MSPI_CPTQP_REG 0x024 +#define MSPI_TXRAM_REG 0x040 +#define MSPI_RXRAM_REG 0x0c0 +#define MSPI_CDRAM_REG 0x140 +#define MSPI_WRITE_LOCK_REG 0x180 +#define MSPI_DISABLE_FLUSH_GEN_REG 0x184 + +/* BSPI registers */ +#define BSPI_REVISION_ID_REG 0x000 +#define BSPI_SCRATCH_REG 0x004 +#define BSPI_MAST_N_BOOT_CTRL_REG 0x008 +#define BSPI_BUSY_STATUS_REG 0x00c +#define BSPI_INTR_STATUS_REG 0x010 +#define BSPI_B0_STATUS_REG 0x014 +#define BSPI_B0_CTRL_REG 0x018 +#define BSPI_B1_STATUS_REG 0x01c +#define BSPI_B1_CTRL_REG 0x020 +#define BSPI_STRAP_OVERRIDE_CTRL_REG 0x024 +#define BSPI_FLEX_MODE_ENABLE_REG 0x028 +#define BSPI_BITS_PER_CYCLE_REG 0x02C +#define BSPI_BITS_PER_PHASE_REG 0x030 +#define BSPI_CMD_AND_MODE_BYTE_REG 0x034 +#define BSPI_FLASH_UPPER_ADDR_BYTE_REG 0x038 +#define BSPI_XOR_VALUE_REG 0x03C +#define BSPI_XOR_ENABLE_REG 0x040 +#define BSPI_PIO_MODE_ENABLE_REG 0x044 +#define BSPI_PIO_IODIR_REG 0x048 +#define BSPI_PIO_DATA_REG 0x04C + +/* RAF registers */ +#define BSPI_RAF_START_ADDRESS_REG 0x00 +#define BSPI_RAF_NUM_WORDS_REG 0x04 +#define BSPI_RAF_CTRL_REG 0x08 +#define BSPI_RAF_FULLNESS_REG 0x0C +#define BSPI_RAF_WATERMARK_REG 0x10 +#define BSPI_RAF_STATUS_REG 0x14 +#define BSPI_RAF_READ_DATA_REG 0x18 +#define BSPI_RAF_WORD_CNT_REG 0x1C +#define BSPI_RAF_CURR_ADDR_REG 0x20 + +#define XFER_DUAL BIT(30) +#define XFER_QUAD BIT(31) + +#define FLASH_BIT BIT(0) +#define MAST_N_BOOT_BIT BIT(0) +#define FLEX_MODE_ENABLE_BIT BIT(0) +#define WRITE_LOCK_BIT BIT(0) + +/* state */ +enum bcm_qspi_state { + QSPI_STATE_DISABLED, + QSPI_STATE_MSPI, + QSPI_STATE_BSPI +}; + +/** + * struct bcmspi_priv - qspi private structure + * + * @max_hz: device transfer speed + * @spi_mode: spi mode (SPI_... flags) + * @frequency: spi max frequency + * @state: device state (MSPI/BSPI) + * @bspi_addr: bspi read address + * @mspi_16bit: mspi transfer mode + * @use_bspi: flag to indicate BSPI use for read operation + * @mspi: mspi registers block address + * @bspi: bspi registers block address + * @bspi_raf: bspi raf registers block address + */ +struct bcmspi_priv { + uint max_hz; + uint spi_mode; + s32 frequency; + enum bcm_qspi_state state; + u32 bspi_addr; + int mspi_16bit; + int mode_4byte; + int use_bspi; + void __iomem *mspi; + void __iomem *bspi; + void __iomem *bspi_raf; +}; + +static void bspi_flush_prefetch_buffers(struct bcmspi_priv *priv) +{ + writel(0, priv->bspi + BSPI_B0_CTRL_REG); + writel(0, priv->bspi + BSPI_B1_CTRL_REG); + writel(FLASH_BIT, priv->bspi + BSPI_B0_CTRL_REG); + writel(FLASH_BIT, priv->bspi + BSPI_B1_CTRL_REG); +} + +static int bcmspi_enable_bspi(struct bcmspi_priv *priv) +{ + if (priv->state == QSPI_STATE_BSPI) + return 0; + + /* Disable write lock */ + writel(0, priv->mspi + MSPI_WRITE_LOCK_REG); + /* Flush prefetch buffers */ + bspi_flush_prefetch_buffers(priv); + /* Switch to BSPI */ + writel(0, priv->bspi + BSPI_MAST_N_BOOT_CTRL_REG); + /* Update state */ + priv->state = QSPI_STATE_BSPI; + + return 0; +} + +static int bcmspi_disable_bspi(struct bcmspi_priv *priv) +{ + if (priv->state == QSPI_STATE_MSPI) + return 0; + + /* Switch to MSPI if not yet */ + if ((readl(priv->bspi + BSPI_MAST_N_BOOT_CTRL_REG) & 1) == 0) { + ulong start = get_timer(0); + + while (get_timer(start) < + QSPI_WAIT_TIMEOUT_MS * CONFIG_SYS_HZ / 1000) { + if ((readl(priv->bspi + BSPI_BUSY_STATUS_REG) & 1) + == 0) { + writel(MAST_N_BOOT_BIT, priv->bspi + + BSPI_MAST_N_BOOT_CTRL_REG); + udelay(1); + break; + } + udelay(1); + } + if ((readl(priv->bspi + BSPI_MAST_N_BOOT_CTRL_REG) & 1) != 1) + return -1; + } + + /* Update state */ + priv->state = QSPI_STATE_MSPI; + + return 0; +} + +static void bspi_read_via_raf(struct bcmspi_priv *priv, u8 *rx, uint bytes) +{ + u32 status; + uint words; + int aligned; + + /* Flush data from the previous session (unlikely) */ + for (;;) { + status = readl(priv->bspi_raf + BSPI_RAF_STATUS_REG); + if (!(status & BSPI_RAF_STATUS_FIFO_EMPTY_MASK)) { + readl(priv->bspi_raf + BSPI_RAF_READ_DATA_REG); + continue; + } + if (!(status & BSPI_RAF_STATUS_SESSION_BUSY_MASK)) + break; + } + + /* Transfer is in words */ + words = (bytes + 3) / 4; + + /* Setup hardware */ + if (priv->mode_4byte) { + u32 val = priv->bspi_addr & 0xFF000000; + + if (val != readl(priv->bspi + BSPI_FLASH_UPPER_ADDR_BYTE_REG)) { + writel(val, + priv->bspi + BSPI_FLASH_UPPER_ADDR_BYTE_REG); + bspi_flush_prefetch_buffers(priv); + } + } + writel(priv->bspi_addr & 0x00FFFFFF, + priv->bspi_raf + BSPI_RAF_START_ADDRESS_REG); + writel(words, priv->bspi_raf + BSPI_RAF_NUM_WORDS_REG); + writel(0, priv->bspi_raf + BSPI_RAF_WATERMARK_REG); + + /* Kick off */ + writel(BSPI_RAF_CONTROL_START_MASK, priv->bspi_raf + BSPI_RAF_CTRL_REG); + + /* Reading the data */ + aligned = DWORD_ALIGNED(rx); + while (bytes) { + status = readl(priv->bspi_raf + BSPI_RAF_STATUS_REG); + if (!(status & BSPI_RAF_STATUS_FIFO_EMPTY_MASK)) { + u32 data = le32_to_cpu(readl(priv->bspi_raf + + BSPI_RAF_READ_DATA_REG)); + + /* Check if we can use the whole word */ + if (aligned && bytes >= 4) { + /* + * RAF is LE only, + * convert data to host endianness + */ + *(u32 *)rx = le32_to_cpu(data); + rx += 4; + bytes -= 4; + } else { + uint chunk = min(bytes, 4U); + + /* Read out bytes one by one */ + while (chunk) { + *rx++ = (u8)data; + data >>= 8; + chunk--; + bytes--; + } + } + + continue; + } + if (!(status & BSPI_RAF_STATUS_SESSION_BUSY_MASK)) { + /* FIFO is empty and the session is done */ + break; + } + } +} + +static int bspi_read(struct bcmspi_priv *priv, const u8 *tx, u8 *rx, + uint bytes, ulong flags) +{ + int idx = priv->mode_4byte ? 2 : 1; + /* Check the address */ + if (flags & SPI_XFER_BEGIN) { + u32 addr; + + /* Drop if the first transfer doesn't contain full address */ + if (bytes < idx + 3 + 1) + return -1; + + /* Flash offset - lower 24 bits */ + addr = (tx[idx] << 16) | (tx[idx + 1] << 8) | tx[idx + 2]; + + /* Flash offset - upper 8 bits */ + if (priv->mode_4byte) + addr |= tx[1] << 24; + + /* Remaining length for data (excluding one dummy cycle) */ + bytes -= idx + 3 + 1; + if (rx) + rx += idx + 3 + 1; + + /* non-aligned transfers are handled by MSPI */ + if (!DWORD_ALIGNED(addr)) + return -1; + + bcmspi_enable_bspi(priv); + /* Record BSPI status */ + priv->bspi_addr = addr; + } + + /* Transfer data if any */ + while (bytes && rx) { + /* Special handing since RAF cannot go across 16MB boundary */ + uint trans = bytes; + + /* + * Divide into multiple transfers if it goes + * across the boundary + */ + if (priv->mode_4byte && + (priv->bspi_addr >> 24) != + ((priv->bspi_addr + bytes) >> 24)) { + /* + * Limit this transfer to not go beyond + * 16MB boundary + */ + trans = 0x1000000 - (priv->bspi_addr & 0xFFFFFF); + } + bspi_read_via_raf(priv, rx, trans); + priv->bspi_addr += trans; + rx += trans; + bytes -= trans; + } + + /* Flush prefetch buffers at the end */ + if (flags & SPI_XFER_END) + bspi_flush_prefetch_buffers(priv); + + return 0; +} + +static int bspi_xfer(struct bcmspi_priv *priv, const u8 *tx, u8 *rx, + uint bytes, ulong flags) +{ + /* Check if we can make use of BSPI */ + if (flags & SPI_XFER_BEGIN) { + if (bytes) { + if (bspi_read(priv, tx, rx, bytes, flags) == 0) + return 0; + } + } else if (priv->state == QSPI_STATE_BSPI) { + if (bspi_read(priv, tx, rx, bytes, flags) == 0) + return 0; + } + + /* continue in mspi mode */ + return 1; +} + +static int mspi_xfer(struct bcmspi_priv *priv, uint bytes, + const u8 *tx, u8 *rx, ulong flags) +{ + u32 cdr = CDRAM_PCS0; + + if (flags & XFER_QUAD) { + cdr |= CDRAM_QUAD_MODE; + + if (!tx) + cdr |= CDRAM_RBIT_INPUT; + } + + if (bytes & 1) { + /* Use 8-bit queue for odd-bytes transfer */ + if (priv->mspi_16bit) { + setbits_le32(priv->mspi + MSPI_SPCR0_MSB_REG, + MSPI_SPCR0_MSB_BITS_8); + priv->mspi_16bit = 0; + } + } else { + /* Use 16-bit queue for even-bytes transfer */ + if (!priv->mspi_16bit) { + clrbits_le32(priv->mspi + MSPI_SPCR0_MSB_REG, + MSPI_SPCR0_MSB_BITS_8); + priv->mspi_16bit = 1; + } + } + + while (bytes) { + uint chunk; + uint queues; + ulong start; + uint i; + + /* Separate code for 16bit and 8bit transfers for performance */ + if (priv->mspi_16bit) { + /* Determine how many bytes to process this time */ + chunk = min(bytes, NUM_CDRAM * 2); + queues = (chunk - 1) / 2 + 1; + bytes -= chunk; + + /* Fill CDRAMs */ + for (i = 0; i < queues; i++) + writel(cdr | CDRAM_CONT | CDRAM_BITS_EN, + priv->mspi + MSPI_CDRAM_REG + (i << 2)); + + /* Fill TXRAMs */ + for (i = 0; i < chunk; i++) + writel(tx ? tx[i] : 0xff, + priv->mspi + MSPI_TXRAM_REG + (i << 2)); + } else { + /* Determine how many bytes to process this time */ + chunk = min(bytes, NUM_CDRAM); + queues = chunk; + bytes -= chunk; + + /* Fill CDRAMs and TXRAMS */ + for (i = 0; i < chunk; i++) { + writel(cdr | CDRAM_CONT, + priv->mspi + MSPI_CDRAM_REG + (i << 2)); + writel(tx ? tx[i] : 0xff, + priv->mspi + MSPI_TXRAM_REG + (i << 3)); + } + } + + /* Setup queue pointers */ + writel(0, priv->mspi + MSPI_NEWQP_REG); + writel(queues - 1, priv->mspi + MSPI_ENDQP_REG); + + /* Deassert CS if requested and it's the last transfer */ + if (bytes == 0 && (flags & SPI_XFER_END)) + clrbits_le32(priv->mspi + MSPI_CDRAM_REG + + ((queues - 1) << 2), CDRAM_CONT); + + /* Kick off */ + writel(0, priv->mspi + MSPI_STATUS_REG); + if (bytes == 0 && (flags & SPI_XFER_END)) + writel(MSPI_SPE, priv->mspi + MSPI_SPCR2_REG); + else + writel(MSPI_SPE | MSPI_CONT_AFTER_CMD, + priv->mspi + MSPI_SPCR2_REG); + + /* Wait for completion */ + start = get_timer(0); + while (get_timer(start) < + QSPI_WAIT_TIMEOUT_MS * CONFIG_SYS_HZ / 1000) { + if (readl(priv->mspi + MSPI_STATUS_REG) & 1) + break; + } + if ((readl(priv->mspi + MSPI_STATUS_REG) & 1) == 0) + return -1; + + /* Read data out */ + if (rx) { + if (priv->mspi_16bit) { + for (i = 0; i < chunk; i++) { + rx[i] = readl(priv->mspi + + MSPI_RXRAM_REG + + (i << 2)) & 0xff; + } + } else { + for (i = 0; i < chunk; i++) { + rx[i] = readl(priv->mspi + + MSPI_RXRAM_REG + + (((i << 1) + 1) << 2)) + & 0xff; + } + } + } + + /* Advance pointers */ + if (tx) + tx += chunk; + if (rx) + rx += chunk; + } + + return 0; +} + +static int iproc_qspi_set_speed(struct udevice *bus, uint speed) +{ + struct bcmspi_priv *priv = dev_get_priv(bus); + uint spbr; + + priv->max_hz = speed; + + /* MSPI: SCK configuration */ + spbr = (QSPI_AXI_CLK - 1) / (2 * priv->max_hz) + 1; + writel(max(min(spbr, SPBR_MAX), SPBR_MIN), + priv->mspi + MSPI_SPCR0_LSB_REG); + + return 0; +} + +static int iproc_qspi_set_mode(struct udevice *bus, uint mode) +{ + struct bcmspi_priv *priv = dev_get_priv(bus); + u32 data_lanes; + + priv->spi_mode = mode; + + if (mode & SPI_RX_QUAD) + data_lanes = 4; + else if (mode & SPI_RX_DUAL) + data_lanes = 2; + else + data_lanes = 1; + + if (data_lanes != 1) { + /* BSPI: configure for dual/quad mode */ + writel(0, priv->bspi + BSPI_BITS_PER_CYCLE_REG); + writel(0, priv->bspi + BSPI_FLEX_MODE_ENABLE_REG); + /* Dummy cycles */ + setbits_le32(priv->bspi + BSPI_BITS_PER_PHASE_REG, + IPROC_BSPI_READ_DUMMY_CYCLES); + /* Override the strap settings */ + setbits_le32(priv->bspi + BSPI_STRAP_OVERRIDE_CTRL_REG, + 1 << BSPI_STRAP_OVERRIDE_SHIFT); + /* + * Configure following based on QUAD/DUAL mode + * - data_quad or data_dual_n_sgl + * - data_bpc select + * - bspi_cmd_byte + */ + if (data_lanes == 4) { + setbits_le32(priv->bspi + BSPI_STRAP_OVERRIDE_CTRL_REG, + 1 << BSPI_STRAP_OVERRIDE_DATA_QUAD_SHIFT); + clrbits_le32(priv->bspi + BSPI_STRAP_OVERRIDE_CTRL_REG, + 1 << BSPI_STRAP_OVERRIDE_DATA_DUAL_SHIFT); + setbits_le32(priv->bspi + BSPI_BITS_PER_CYCLE_REG, + 2 << BSPI_BITS_PER_CYCLE_DATA_SHIFT); + writel(SPINOR_OP_READ_1_1_4, + priv->bspi + BSPI_CMD_AND_MODE_BYTE_REG); + } else if (data_lanes == 2) { + clrbits_le32(priv->bspi + BSPI_STRAP_OVERRIDE_CTRL_REG, + 1 << BSPI_STRAP_OVERRIDE_DATA_QUAD_SHIFT); + setbits_le32(priv->bspi + BSPI_STRAP_OVERRIDE_CTRL_REG, + 1 << BSPI_STRAP_OVERRIDE_DATA_DUAL_SHIFT); + setbits_le32(priv->bspi + BSPI_BITS_PER_CYCLE_REG, + 1 << BSPI_BITS_PER_CYCLE_DATA_SHIFT); + writel(SPINOR_OP_READ_1_1_2, + priv->bspi + BSPI_CMD_AND_MODE_BYTE_REG); + } + /* Enable flex mode to take effect */ + writel(FLEX_MODE_ENABLE_BIT, priv->bspi + + BSPI_FLEX_MODE_ENABLE_REG); + } else { + /* configure BSPI for single mode */ + writel(0, priv->bspi + BSPI_FLEX_MODE_ENABLE_REG); + writel(0, priv->bspi + BSPI_BITS_PER_CYCLE_REG); + /* Dummy cycles */ + setbits_le32(priv->bspi + BSPI_BITS_PER_PHASE_REG, + IPROC_BSPI_READ_DUMMY_CYCLES); + /* clear strap override, data_dual_n_sgl and data_quad bits */ + clrbits_le32(priv->bspi + BSPI_STRAP_OVERRIDE_CTRL_REG, + 1 << BSPI_STRAP_OVERRIDE_SHIFT); + clrbits_le32(priv->bspi + BSPI_STRAP_OVERRIDE_CTRL_REG, + 1 << BSPI_STRAP_OVERRIDE_DATA_QUAD_SHIFT); + clrbits_le32(priv->bspi + BSPI_STRAP_OVERRIDE_CTRL_REG, + 1 << BSPI_STRAP_OVERRIDE_DATA_DUAL_SHIFT); + writel(SPINOR_OP_READ_FAST, + priv->bspi + BSPI_CMD_AND_MODE_BYTE_REG); + } + + /* + * MSPI: Mode configuration (8 bits by default) + * MSPI supports only single mode. + */ + priv->mspi_16bit = 0; + writel(0x80 | /* Master */ + (8 << 2) | /* 8 bits per word */ + (priv->spi_mode & 3), /* mode: CPOL / CPHA */ + priv->mspi + MSPI_SPCR0_MSB_REG); + + return 0; +} + +static int iproc_qspi_claim_bus(struct udevice *dev) +{ + /* nothing to do */ + return 0; +} + +static int iproc_qspi_release_bus(struct udevice *dev) +{ + struct udevice *bus = dev->parent; + struct bcmspi_priv *priv = dev_get_priv(bus); + + /* Make sure no operation is in progress */ + writel(0, priv->mspi + MSPI_SPCR2_REG); + udelay(1); + + return 0; +} + +static int iproc_qspi_xfer(struct udevice *dev, uint bitlen, + const void *dout, void *din, ulong flags) +{ + struct udevice *bus = dev->parent; + struct bcmspi_priv *priv = dev_get_priv(bus); + const u8 *tx = dout; + u8 *rx = din; + uint bytes = bitlen / 8; + int ret = 0; + + /* we can only do 8 bit transfers */ + if (bitlen % 8) + return -1; + + if (priv->use_bspi) { + ret = bspi_xfer(priv, tx, rx, bytes, flags); + if (ret <= 0) + return ret; + } + + /* MSPI: Enable write lock at the beginning */ + if (flags & SPI_XFER_BEGIN) { + /* Switch to MSPI if not yet */ + if (bcmspi_disable_bspi(priv) != 0) + return -1; + + writel(WRITE_LOCK_BIT, priv->mspi + MSPI_WRITE_LOCK_REG); + } + + /* MSPI: Transfer it */ + if (bytes) + ret = mspi_xfer(priv, bytes, tx, rx, flags); + + /* MSPI: Disable write lock if it's done */ + if (flags & SPI_XFER_END) { + writel(0, priv->mspi + MSPI_WRITE_LOCK_REG); + /* Switch back to BSPI */ + if (priv->use_bspi) + writel(0, priv->bspi + BSPI_MAST_N_BOOT_CTRL_REG); + } + + return ret; +} + +static int iproc_qspi_ofdata_to_platdata(struct udevice *bus) +{ + struct bcmspi_priv *priv = dev_get_priv(bus); + ofnode subnode; + + priv->bspi = (void __iomem *)dev_read_addr_name(bus, "bspi"); + if (IS_ERR(priv->bspi)) { + debug("%s: Failed to get bspi base address\n", __func__); + return PTR_ERR(priv->bspi); + } + + priv->bspi_raf = (void __iomem *)dev_read_addr_name(bus, "bspi_raf"); + if (IS_ERR(priv->bspi_raf)) { + debug("%s: Failed to get bspi_raf base address\n", __func__); + return PTR_ERR(priv->bspi_raf); + } + + priv->mspi = (void __iomem *)dev_read_addr_name(bus, "mspi"); + if (IS_ERR(priv->mspi)) { + debug("%s: Failed to get mspi base address\n", __func__); + return PTR_ERR(priv->mspi); + } + + subnode = dev_read_first_subnode(bus); + if (ofnode_valid(subnode)) + priv->frequency = ofnode_read_u32_default(subnode, + "spi-max-frequency", + QSPI_DEF_SCK_FREQ); + else + priv->frequency = QSPI_DEF_SCK_FREQ; + + priv->use_bspi = dev_read_u32_default(bus, "use-bspi", 0); + + return 0; +} + +static int iproc_qspi_probe(struct udevice *bus) +{ + struct bcmspi_priv *priv = dev_get_priv(bus); + + priv->mode_4byte = 0; + /* MSPI: Basic hardware initialization */ + writel(0, priv->mspi + MSPI_SPCR1_LSB_REG); + writel(0, priv->mspi + MSPI_SPCR1_MSB_REG); + writel(0, priv->mspi + MSPI_NEWQP_REG); + writel(0, priv->mspi + MSPI_ENDQP_REG); + writel(0, priv->mspi + MSPI_SPCR2_REG); + + if (priv->use_bspi) { + bcmspi_enable_bspi(priv); + } else { + if (bcmspi_disable_bspi(priv)) { + printf("Failed to set in MSPI mode\n"); + return -1; + } + } + + return 0; +} + +static const struct dm_spi_ops iproc_qspi_ops = { + .claim_bus = iproc_qspi_claim_bus, + .release_bus = iproc_qspi_release_bus, + .xfer = iproc_qspi_xfer, + .set_speed = iproc_qspi_set_speed, + .set_mode = iproc_qspi_set_mode, +}; + +static const struct udevice_id iproc_qspi_ids[] = { + { .compatible = "brcm,iproc-qspi" }, + { } +}; + +U_BOOT_DRIVER(iproc_qspi) = { + .name = "iproc_qspi", + .id = UCLASS_SPI, + .of_match = iproc_qspi_ids, + .ops = &iproc_qspi_ops, + .of_to_plat = iproc_qspi_ofdata_to_platdata, + .priv_auto = sizeof(struct bcmspi_priv), + .probe = iproc_qspi_probe, +};
Changes in v4:
Changes in v3:
Changes in v2:
Look like you confused what I've mentioned before, your driver is flash specific so add a driver in UCLASS_SPI_FLASH. drivers with UCLASS_SPI to be in drivers/spi/
Jagan.
Hi Jagan,
Changes in v4:
Changes in v3:
Changes in v2:
Jagan.
This is a controller driver and it is currently meant to be used as follows:
qspi: spi@370000 { compatible = "brcm,iproc-qspi"; reg = <0x00370000 0x100>, <0x00370100 0x100>, <0x00370200 0x200>; reg-names = "bspi", "bspi_raf", "mspi"; flash-iomap-addr = /bits/ 64 <0x70000000>; #address-cells = <1>; #size-cells = <0>; spi_nor_flash: spi_flash@0 { compatible = "jedec,spi-nor"; reg = <0>; spi-max-frequency = <12500000>; spi-cpol; spi-cpha; spi-tx-bus-width = <1>; spi-rx-bus-width = <4>; }; };
Can you please provide more details or point us to an example we can use as a reference when asking us to switch from UCLASS_SPI to UCLASS_SPI_FLASH? What will the new device tree look like? Do we need to add read/write/erase methods (likely around our existing xfer method), which are currently not needed or is there a way around it by reusing existing code base? Thanks,
Roman
On Tue, Nov 2, 2021 at 4:57 AM Roman Bacik roman.bacik@broadcom.com wrote:
Hi Jagan,
Changes in v4:
Changes in v3:
Changes in v2:
Jagan.
Does this binding is from Linux? if yes please share Linux driver.
Jagan.
Hi Jagan,
-----Original Message----- From: Jagan Teki jagan@amarulasolutions.com Sent: Monday, November 1, 2021 10:07 PM To: Roman Bacik roman.bacik@broadcom.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com; Bharat Gooty bharat.gooty@broadcom.com; Vignesh R vigneshr@ti.com Subject: Re: [PATCH v4] driver: spi: add bcm iproc qspi support.
Hi Jagan,
Changes in v4:
Changes in v3:
Changes in v2:
Jagan.
Jagan.
Here is Linux binding document: https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/Docu...
And here is Linux driver: https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/driv...
Thanks,
Roman
Jagan Teki
Roman Bacik
