[PATCH u-boot-marvell 0/7] Changes for Turris MOX
Hello Stefan,
Here are some changes for Turris MOX: - dts changes - more config options enabled - rescue mode support added
If it is possible, since this touches only our device, we would like this to be also merged for v2021.07 (once reviewed by you and Pali).
(The last patch touches common armada-37xx.dtsi, but it only changes name of a U-Boot's dts node to follow Linux' dts. No board code seems to depend on this name.)
Marek
Marek Behún (7): arm: mvebu: dts: turris_mox: add button and LED nodes arm: mvebu: turris_mox: add support for board rescue mode arm: mvebu: turris_mox: start blinking PHY LEDs when entering rescue arm: mvebu: configs: turris_mox: add fdtfile default env variable arm: mvebu: dts: turris_mox: add nodes for SPI NOR partitions arm: mvebu: turris_mox: enable options for Turris network boot arm64: a37xx: dts: rename internal-regs node
arch/arm/dts/armada-3720-turris-mox.dts | 55 ++++++++++++ arch/arm/dts/armada-37xx.dtsi | 2 +- board/CZ.NIC/turris_mox/turris_mox.c | 106 ++++++++++++++++++++++++ configs/turris_mox_defconfig | 14 ++++ include/configs/turris_mox.h | 10 +++ 5 files changed, 186 insertions(+), 1 deletion(-)
Add nodes for indicator LED and reset button so that board code can implement board factory reset mechanism.
Signed-off-by: Marek Behún marek.behun@nic.cz --- arch/arm/dts/armada-3720-turris-mox.dts | 24 ++++++++++++++++++++++++ 1 file changed, 24 insertions(+)
diff --git a/arch/arm/dts/armada-3720-turris-mox.dts b/arch/arm/dts/armada-3720-turris-mox.dts index 8e0ebf508d..741b0eeeee 100644 --- a/arch/arm/dts/armada-3720-turris-mox.dts +++ b/arch/arm/dts/armada-3720-turris-mox.dts @@ -11,6 +11,8 @@ /dts-v1/;
#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/leds/common.h> #include "armada-372x.dtsi"
/ { @@ -34,6 +36,28 @@ reg = <0x00000000 0x00000000 0x00000000 0x20000000>; };
+ leds { + compatible = "gpio-leds"; + + led { + gpios = <&gpiosb 21 GPIO_ACTIVE_LOW>; + color = <LED_COLOR_ID_RED>; + function = LED_FUNCTION_ACTIVITY; + }; + }; + + gpio-keys { + compatible = "gpio-keys"; + + reset { + compatible = "gpio-keys"; + label = "reset"; + linux,code = <KEY_RESTART>; + gpios = <&gpiosb 20 GPIO_ACTIVE_LOW>; + debounce-interval = <60>; + }; + }; + reg_usb3_vbus: usb3_vbus@0 { compatible = "regulator-fixed"; regulator-name = "usb3-vbus";
Add necessary config options and board code to support board factory reset / rescue mode on Turris MOX.
In order to also support invoking rescue mode from U-Boot console, without having to press the factory reset button, put the rescue command into `bootcmd_rescue` default environment variable. When factory reset button is pressed, invoke rescue mode via distroboot by setting `boot_targets` to `rescue`.
Rescue boot from console can be invoked by running run bootcmd_rescue
Signed-off-by: Marek Behún marek.behun@nic.cz --- board/CZ.NIC/turris_mox/turris_mox.c | 71 ++++++++++++++++++++++++++++ configs/turris_mox_defconfig | 6 +++ include/configs/turris_mox.h | 9 ++++ 3 files changed, 86 insertions(+)
diff --git a/board/CZ.NIC/turris_mox/turris_mox.c b/board/CZ.NIC/turris_mox/turris_mox.c index 15cbf92550..a78f33661e 100644 --- a/board/CZ.NIC/turris_mox/turris_mox.c +++ b/board/CZ.NIC/turris_mox/turris_mox.c @@ -10,11 +10,13 @@ #include <asm/global_data.h> #include <asm/io.h> #include <asm/gpio.h> +#include <button.h> #include <clk.h> #include <dm.h> #include <env.h> #include <fdt_support.h> #include <init.h> +#include <led.h> #include <linux/delay.h> #include <linux/libfdt.h> #include <linux/string.h> @@ -44,6 +46,8 @@ #define SFP_GPIO_PATH "/soc/internal-regs@d0000000/spi@10600/moxtet@1/gpio@0" #define PCIE_PATH "/soc/pcie@d0070000" #define SFP_PATH "/sfp" +#define LED_PATH "/leds/led" +#define BUTTON_PATH "/gpio-keys/reset"
DECLARE_GLOBAL_DATA_PTR;
@@ -373,6 +377,71 @@ int misc_init_r(void) return 0; }
+static bool read_reset_button(void) +{ + struct udevice *button, *led; + int i; + + if (device_get_global_by_ofnode(ofnode_path(BUTTON_PATH), &button)) { + printf("Cannot find reset button!\n"); + return false; + } + + if (device_get_global_by_ofnode(ofnode_path(LED_PATH), &led)) { + printf("Cannot find status LED!\n"); + return false; + } + + led_set_state(led, LEDST_ON); + + for (i = 0; i < 21; ++i) { + if (button_get_state(button) != BUTTON_ON) + return false; + if (i < 20) + mdelay(50); + } + + led_set_state(led, LEDST_OFF); + + return true; +} + +static void handle_reset_button(void) +{ + if (read_reset_button()) { + const char * const vars[3] = { + "bootcmd", + "bootcmd_rescue", + "distro_bootcmd", + }; + + /* + * Set the above envs to their default values, in case the user + * managed to break them. + */ + env_set_default_vars(3, (char * const *)vars, 0); + + /* Ensure bootcmd_rescue is used by distroboot */ + env_set("boot_targets", "rescue"); + + printf("RESET button was pressed, overwriting boot_targets!\n"); + } else { + /* + * In case the user somehow managed to save environment with + * boot_targets=rescue, reset boot_targets to default value. + * This could happen in subsequent commands if bootcmd_rescue + * failed. + */ + if (!strcmp(env_get("boot_targets"), "rescue")) { + const char * const vars[1] = { + "boot_targets", + }; + + env_set_default_vars(1, (char * const *)vars, 0); + } + } +} + static void mox_print_info(void) { int ret, board_version, ram_size; @@ -543,6 +612,8 @@ int last_stage_init(void)
printf("\n");
+ handle_reset_button(); + return 0; }
diff --git a/configs/turris_mox_defconfig b/configs/turris_mox_defconfig index 75524babbc..d6d37a3d7d 100644 --- a/configs/turris_mox_defconfig +++ b/configs/turris_mox_defconfig @@ -23,10 +23,14 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_EARLY_INIT_R=y CONFIG_MISC_INIT_R=y +CONFIG_BUTTON=y +CONFIG_BUTTON_GPIO=y +CONFIG_CMD_BUTTON=y CONFIG_CMD_CLK=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y +CONFIG_CMD_LED=y CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y CONFIG_CMD_SPI=y @@ -46,6 +50,8 @@ CONFIG_CLK=y CONFIG_CLK_MVEBU=y # CONFIG_MVEBU_GPIO is not set CONFIG_DM_I2C=y +CONFIG_LED=y +CONFIG_LED_GPIO=y CONFIG_MISC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y diff --git a/include/configs/turris_mox.h b/include/configs/turris_mox.h index 51445ec60a..6b2b6b3bd4 100644 --- a/include/configs/turris_mox.h +++ b/include/configs/turris_mox.h @@ -75,12 +75,21 @@
#include <config_distro_bootcmd.h>
+#define TURRIS_MOX_BOOTCMD_RESCUE \ + "setenv bootargs "console=ttyMV0,115200 " \ + "earlycon=ar3700_uart,0xd0012000" && " \ + "sf probe && " \ + "sf read ${kernel_addr_r} 0x190000 && " \ + "lzmadec ${kernel_addr_r} ${ramdisk_addr_r} && " \ + "bootm ${ramdisk_addr_r}" + #define CONFIG_EXTRA_ENV_SETTINGS \ "scriptaddr=0x4d00000\0" \ "pxefile_addr_r=0x4e00000\0" \ "fdt_addr_r=0x4f00000\0" \ "kernel_addr_r=0x5000000\0" \ "ramdisk_addr_r=0x8000000\0" \ + "bootcmd_rescue=" TURRIS_MOX_BOOTCMD_RESCUE "\0" \ BOOTENV
#endif /* _CONFIG_TURRIS_MOX_H */
- "setenv bootargs "console=ttyMV0,115200 " \
"earlycon=ar3700_uart,0xd0012000\" && " \
- "sf probe && " \
- "sf read ${kernel_addr_r} 0x190000 && " \
- "lzmadec ${kernel_addr_r} ${ramdisk_addr_r} && " \
- "bootm ${ramdisk_addr_r}"
OMG, we should use constants for addresses here instead of ${kernel_addr_r} and ${ramdisk_addr_r}, in case user changes or removed this variables.
I will update this in v2.
- "bootcmd_rescue=" TURRIS_MOX_BOOTCMD_RESCUE "\0" \ BOOTENV
Configure blinking on ethernet PHY LEDs on the MOX A board when entering rescue mode via reset button.
Signed-off-by: Marek Behún marek.behun@nic.cz --- board/CZ.NIC/turris_mox/turris_mox.c | 35 ++++++++++++++++++++++++++++ 1 file changed, 35 insertions(+)
diff --git a/board/CZ.NIC/turris_mox/turris_mox.c b/board/CZ.NIC/turris_mox/turris_mox.c index a78f33661e..44c272c7cb 100644 --- a/board/CZ.NIC/turris_mox/turris_mox.c +++ b/board/CZ.NIC/turris_mox/turris_mox.c @@ -377,6 +377,38 @@ int misc_init_r(void) return 0; }
+static void mox_phy_modify(struct phy_device *phydev, int page, int reg, + u16 mask, u16 set) +{ + int val; + + val = phydev->drv->readext(phydev, MDIO_DEVAD_NONE, page, reg); + val &= ~mask; + val |= set; + phydev->drv->writeext(phydev, MDIO_DEVAD_NONE, page, reg, val); +} + +static void mox_phy_leds_start_blinking(void) +{ + struct phy_device *phydev; + struct mii_dev *bus; + + bus = miiphy_get_dev_by_name("neta@30000"); + if (!bus) { + printf("Cannot get MDIO bus device!\n"); + return; + } + + phydev = phy_find_by_mask(bus, BIT(1), PHY_INTERFACE_MODE_RGMII); + if (!phydev) { + printf("Cannot get ethernet PHY!\n"); + return; + } + + mox_phy_modify(phydev, 3, 0x12, 0x700, 0x400); + mox_phy_modify(phydev, 3, 0x10, 0xff, 0xbb); +} + static bool read_reset_button(void) { struct udevice *button, *led; @@ -424,6 +456,9 @@ static void handle_reset_button(void) /* Ensure bootcmd_rescue is used by distroboot */ env_set("boot_targets", "rescue");
+ /* start blinking PHY LEDs */ + mox_phy_leds_start_blinking(); + printf("RESET button was pressed, overwriting boot_targets!\n"); } else { /*
Add default fdtfile environment variable with value marvell/armada-3720-turris-mox.dtb.
This can be useful for some boot scenarios.
Signed-off-by: Marek Behún marek.behun@nic.cz --- include/configs/turris_mox.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/turris_mox.h b/include/configs/turris_mox.h index 6b2b6b3bd4..2b28cf0901 100644 --- a/include/configs/turris_mox.h +++ b/include/configs/turris_mox.h @@ -89,6 +89,7 @@ "fdt_addr_r=0x4f00000\0" \ "kernel_addr_r=0x5000000\0" \ "ramdisk_addr_r=0x8000000\0" \ + "fdtfile=marvell/" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ "bootcmd_rescue=" TURRIS_MOX_BOOTCMD_RESCUE "\0" \ BOOTENV
Add nodes for SPI NOR partitions to the device tree of Turris MOX, as are in Linux' device tree.
Signed-off-by: Marek Behún marek.behun@nic.cz --- arch/arm/dts/armada-3720-turris-mox.dts | 31 +++++++++++++++++++++++++ 1 file changed, 31 insertions(+)
diff --git a/arch/arm/dts/armada-3720-turris-mox.dts b/arch/arm/dts/armada-3720-turris-mox.dts index 741b0eeeee..f47ced05c5 100644 --- a/arch/arm/dts/armada-3720-turris-mox.dts +++ b/arch/arm/dts/armada-3720-turris-mox.dts @@ -164,6 +164,37 @@ reg = <0>; spi-max-frequency = <20000000>; m25p,fast-read; + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "secure-firmware"; + reg = <0x0 0x20000>; + }; + + partition@20000 { + label = "a53-firmware"; + reg = <0x20000 0x160000>; + }; + + partition@180000 { + label = "u-boot-env"; + reg = <0x180000 0x10000>; + }; + + partition@190000 { + label = "Rescue system"; + reg = <0x190000 0x660000>; + }; + + partition@7f0000 { + label = "dtb"; + reg = <0x7f0000 0x10000>; + }; + }; };
moxtet@1 {
Enable configuration options to support Turris network boot. This includes FIT support and some crypto commands.
Signed-off-by: Marek Behún marek.behun@nic.cz --- configs/turris_mox_defconfig | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/configs/turris_mox_defconfig b/configs/turris_mox_defconfig index d6d37a3d7d..f93be912c9 100644 --- a/configs/turris_mox_defconfig +++ b/configs/turris_mox_defconfig @@ -25,14 +25,17 @@ CONFIG_ARCH_EARLY_INIT_R=y CONFIG_MISC_INIT_R=y CONFIG_BUTTON=y CONFIG_BUTTON_GPIO=y +CONFIG_CMD_AES=y CONFIG_CMD_BUTTON=y CONFIG_CMD_CLK=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_HASH=y CONFIG_CMD_I2C=y CONFIG_CMD_LED=y CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y +CONFIG_CMD_SHA1SUM=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_WDT=y @@ -46,6 +49,11 @@ CONFIG_MAC_PARTITION=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_FIT=y +CONFIG_FIT_ENABLE_SHA256_SUPPORT=y +# CONFIG_FIT_SIGNATURE is not set +CONFIG_FIT_VERBOSE=y +# CONFIG_FIT_BEST_MATCH is not set CONFIG_CLK=y CONFIG_CLK_MVEBU=y # CONFIG_MVEBU_GPIO is not set
The node `internal-regs` is called `internal-regs@d0000000` in Linux' device tree. Rename this in U-Boot also.
No in-tree code depends on this name, so this should be safe.
Signed-off-by: Marek Behún marek.behun@nic.cz --- arch/arm/dts/armada-37xx.dtsi | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/armada-37xx.dtsi b/arch/arm/dts/armada-37xx.dtsi index a1052add0c..ad86bf5c1d 100644 --- a/arch/arm/dts/armada-37xx.dtsi +++ b/arch/arm/dts/armada-37xx.dtsi @@ -93,7 +93,7 @@ #size-cells = <2>; ranges;
- internal-regs { + internal-regs@d0000000 { #address-cells = <1>; #size-cells = <1>; compatible = "simple-bus";
internal-regs {
On second thought we can ignore this patch for now. We can update the whole DTS to kernel's DTS once all drivers are updated to support kernel bindings.
Hello Stefan,
Here are some changes for Turris MOX (v2): - dts changes - more config options enabled - rescue mode support added
Changes since v1: - use constant addresses instead of ${kernel_addr_r} and ${ramdisk_addr_r} in bootcmd_rescue, so that this command won't fail if those addresses are changed - dropped last patch changing internal-regs node name in dts. We don't need this now, let's do this in the future once we will be aligning U-Boot's DTS with kernel's DTS
Marek Behún (6): arm: mvebu: dts: turris_mox: add button and LED nodes arm: mvebu: turris_mox: add support for board rescue mode arm: mvebu: turris_mox: start blinking PHY LEDs when entering rescue arm: mvebu: configs: turris_mox: add fdtfile default env variable arm: mvebu: dts: turris_mox: add nodes for SPI NOR partitions arm: mvebu: turris_mox: enable options for Turris network boot
arch/arm/dts/armada-3720-turris-mox.dts | 55 ++++++++++++ board/CZ.NIC/turris_mox/turris_mox.c | 106 ++++++++++++++++++++++++ configs/turris_mox_defconfig | 14 ++++ include/configs/turris_mox.h | 10 +++ 4 files changed, 185 insertions(+)
Reviewed-by: Pali Rohár pali@kernel.org
- leds {
led {
- gpio-keys {
reset {
label = "reset";
- reg_usb3_vbus: usb3_vbus@0 { compatible = "regulator-fixed"; regulator-name = "usb3-vbus";
-- 2.31.1
Thanks, Stefan
- leds {
led {
- gpio-keys {
reset {
label = "reset";
Viele Grüße, Stefan
printf("\n");
diff --git a/configs/turris_mox_defconfig b/configs/turris_mox_defconfig index 75524babbc..d6d37a3d7d 100644 --- a/configs/turris_mox_defconfig +++ b/configs/turris_mox_defconfig @@ -23,10 +23,14 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_EARLY_INIT_R=y CONFIG_MISC_INIT_R=y +CONFIG_BUTTON=y +CONFIG_BUTTON_GPIO=y +CONFIG_CMD_BUTTON=y CONFIG_CMD_CLK=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y +CONFIG_CMD_LED=y CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y CONFIG_CMD_SPI=y @@ -46,6 +50,8 @@ CONFIG_CLK=y CONFIG_CLK_MVEBU=y # CONFIG_MVEBU_GPIO is not set CONFIG_DM_I2C=y +CONFIG_LED=y +CONFIG_LED_GPIO=y CONFIG_MISC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y diff --git a/include/configs/turris_mox.h b/include/configs/turris_mox.h index 51445ec60a..b148b1621a 100644 --- a/include/configs/turris_mox.h +++ b/include/configs/turris_mox.h @@ -75,12 +75,21 @@
+#define TURRIS_MOX_BOOTCMD_RESCUE \ + "setenv bootargs "console=ttyMV0,115200 " \ + "earlycon=ar3700_uart,0xd0012000" && " \ + "sf probe && " \ + "sf read 0x5000000 0x190000 && " \ + "lzmadec 0x5000000 0x5800000 && " \ + "bootm 0x5800000" + #define CONFIG_EXTRA_ENV_SETTINGS \ "scriptaddr=0x4d00000\0" \ "pxefile_addr_r=0x4e00000\0" \ "fdt_addr_r=0x4f00000\0" \ "kernel_addr_r=0x5000000\0" \ "ramdisk_addr_r=0x8000000\0" \ + "bootcmd_rescue=" TURRIS_MOX_BOOTCMD_RESCUE "\0" \ BOOTENV
- struct udevice *button, *led;
- int i;
- if (device_get_global_by_ofnode(ofnode_path(BUTTON_PATH), &button)) {
return false;
- if (device_get_global_by_ofnode(ofnode_path(LED_PATH), &led)) {
return false;
- led_set_state(led, LEDST_ON);
- for (i = 0; i < 21; ++i) {
return false;
if (i < 20)
mdelay(50);
- led_set_state(led, LEDST_OFF);
- return true;
- if (read_reset_button()) {
"bootcmd",
"bootcmd_rescue",
"distro_bootcmd",
- } else {
* failed.
"boot_targets",
printf("\n");
- handle_reset_button();
- "sf probe && " \
- "sf read 0x5000000 0x190000 && " \
- "lzmadec 0x5000000 0x5800000 && " \
- "bootm 0x5800000"
2.31.1
Thanks, Stefan
- int i;
return false;
return false;
return false;
if (i < 20)
mdelay(50);
- return true;
"bootcmd",
"bootcmd_rescue",
"distro_bootcmd",
- } else {
* failed.
"boot_targets",
- static void mox_print_info(void) { int ret, board_version, ram_size;
printf("\n");
- return 0; }
"sf probe && " \
"bootm 0x5800000"
Viele Grüße, Stefan
u16 mask, u16 set)
- int val;
- val = phydev->drv->readext(phydev, MDIO_DEVAD_NONE, page, reg);
- val &= ~mask;
- val |= set;
- phydev->drv->writeext(phydev, MDIO_DEVAD_NONE, page, reg, val);
- struct phy_device *phydev;
- struct mii_dev *bus;
- bus = miiphy_get_dev_by_name("neta@30000");
- if (!bus) {
return;
- phydev = phy_find_by_mask(bus, BIT(1), PHY_INTERFACE_MODE_RGMII);
- if (!phydev) {
return;
- mox_phy_modify(phydev, 3, 0x12, 0x700, 0x400);
- mox_phy_modify(phydev, 3, 0x10, 0xff, 0xbb);
- printf("RESET button was pressed, overwriting boot_targets!\n"); } else { /*
-- 2.31.1
Thanks, Stefan
u16 mask, u16 set)
- int val;
- val &= ~mask;
- val |= set;
- if (!bus) {
return;
- if (!phydev) {
return;
- static bool read_reset_button(void) { struct udevice *button, *led;
Viele Grüße, Stefan
diff --git a/include/configs/turris_mox.h b/include/configs/turris_mox.h index b148b1621a..9c021a1ef9 100644 --- a/include/configs/turris_mox.h +++ b/include/configs/turris_mox.h @@ -89,6 +89,7 @@ "fdt_addr_r=0x4f00000\0" \ "kernel_addr_r=0x5000000\0" \ "ramdisk_addr_r=0x8000000\0" \ + "fdtfile=marvell/" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ "bootcmd_rescue=" TURRIS_MOX_BOOTCMD_RESCUE "\0" \ BOOTENV
- "fdtfile=marvell/" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ "bootcmd_rescue=" TURRIS_MOX_BOOTCMD_RESCUE "\0" \ BOOTENV
-- 2.31.1
Thanks, Stefan
Viele Grüße, Stefan
moxtet@1 {
This patch is not needed (for now) as U-Boot cannot parse SPI NOR partitions from DT yet. U-Boot for SPI NOR currently supports specifying partitions only via CONFIG_MTDPARTS_DEFAULT compile option.
partitions {
#size-cells = <1>;
partition@0 {
partition@20000 {
partition@180000 {
partition@190000 {
partition@7f0000 {
label = "dtb";
moxtet@1 {
-- 2.31.1
Hi Pali,
But do you agree that this patch "does not hurt"? I'm asking to check, if I should include this patch in a potential pull request.
Thanks, Stefan
partitions {
#size-cells = <1>;
partition@0 {
partition@20000 {
partition@180000 {
partition@190000 {
partition@7f0000 {
label = "dtb";
moxtet@1 {
-- 2.31.1
Viele Grüße, Stefan
On Thursday 10 June 2021 07:12:53 Stefan Roese wrote:
Hi Pali,
Yes. This does not hurt and currently does nothing. And after patches for SPI NOR parsing are merged then this patch can be useful.
So if you are fine with merging which which currently does noting and in future is useful then there is no problem with it.
Thanks, Stefan
partitions {
#size-cells = <1>;
partition@0 {
partition@20000 {
partition@180000 {
partition@190000 {
partition@7f0000 {
label = "dtb";
}; moxtet@1 {};
-- 2.31.1
Viele Grüße, Stefan
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-51 Fax: (+49)-8142-66989-80 Email: sr@denx.de
Hi Pali,
Moreover this definition is also in kernel's DTS. I am going to try to work on the U-Boot's A3720 comphy driver so that we can completely align U-Boot's A3720 DTS files with kernel's.
Marek
Hi Pali,
It should be available in mainline now.
Perfect. Thanks for working on this.
Thanks, Stefan
Thanks, Stefan
partitions {
#size-cells = <1>;
partition@0 {
partition@20000 {
partition@180000 {
partition@190000 {
partition@7f0000 {
label = "dtb";
moxtet@1 {
Viele Grüße, Stefan
2.31.1
Thanks, Stefan
Viele Grüße, Stefan
Hello Stefan,
- dts changes
Done. ;)
Applied to u-boot-marvell/master
Thanks, Stefan
Changes since v1:
Viele Grüße, Stefan
Marek Behun
Marek Behún
Pali Rohár
Stefan Roese
