[U-Boot] [PATCH 01/09] powerpc/mpc85xx: Few updates for B4860 cpu changes
- Added some more serdes1 and serdes2 combinations serdes1= 0x2c, 0x2d, 0x2e serdes2= 0x7a, 0x8d, 0x98 - Updated Number of DDR controllers to 2. - Added FMAN file for B4860, drivers/net/fm/b4860.c
Signed-off-by: York Sun yorksun@freescale.com Signed-off-by: Shaveta Leekha shaveta@freescale.com Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com Signed-off-by: Sandeep Singh Sandeep@freescale.com Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com --- Changes in v2: Added Shaveta's, York's, Sandeep's and Prabhakar's signoff. arch/powerpc/cpu/mpc85xx/b4860_serdes.c | 15 ++++++ arch/powerpc/include/asm/config_mpc85xx.h | 2 +- drivers/net/fm/b4860.c | 79 +++++++++++++++++++++++++++++ 3 files changed, 95 insertions(+), 1 deletions(-) create mode 100644 drivers/net/fm/b4860.c
diff --git a/arch/powerpc/cpu/mpc85xx/b4860_serdes.c b/arch/powerpc/cpu/mpc85xx/b4860_serdes.c index 9990202..0028280 100644 --- a/arch/powerpc/cpu/mpc85xx/b4860_serdes.c +++ b/arch/powerpc/cpu/mpc85xx/b4860_serdes.c @@ -41,6 +41,12 @@ static struct serdes_config serdes1_cfg_tbl[] = { CPRI4, CPRI3, CPRI2, CPRI1}}, {0x2a, {SGMII_FM1_DTSEC5, SGMII_FM1_DTSEC6, CPRI6, CPRI5, CPRI4, CPRI3, CPRI2, CPRI1}}, + {0x2C, {SGMII_FM1_DTSEC5, SGMII_FM1_DTSEC6, + CPRI6, CPRI5, CPRI4, CPRI3, CPRI2, CPRI1}}, + {0x2D, {SGMII_FM1_DTSEC5, SGMII_FM1_DTSEC6, + CPRI6, CPRI5, CPRI4, CPRI3, CPRI2, CPRI1}}, + {0x2E, {SGMII_FM1_DTSEC5, SGMII_FM1_DTSEC6, + CPRI6, CPRI5, CPRI4, CPRI3, CPRI2, CPRI1}}, {0x30, {AURORA, AURORA, SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, CPRI4, CPRI3, CPRI2, CPRI1}}, @@ -84,6 +90,8 @@ static struct serdes_config serdes2_cfg_tbl[] = { {0x4E, {SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC3, AURORA, SRIO1, SRIO1, SRIO1, SRIO1}}, + {0x7A, {SRIO2, SRIO2, SRIO2, SRIO2, + SRIO1, SRIO1, SRIO1, SRIO1}}, {0x84, {SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, SRIO2, SRIO2, AURORA, AURORA, XFI_FM1_MAC9, XFI_FM1_MAC10}}, @@ -94,6 +102,9 @@ static struct serdes_config serdes2_cfg_tbl[] = { SRIO2, SRIO2, SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, XFI_FM1_MAC9, XFI_FM1_MAC10}}, + {0x8D, {SRIO2, SRIO2, SRIO2, SRIO2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, + XFI_FM1_MAC9, XFI_FM1_MAC10}}, {0x93, {SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, XAUI_FM1_MAC10, XAUI_FM1_MAC10, @@ -111,6 +122,10 @@ static struct serdes_config serdes2_cfg_tbl[] = { {0xC3, {XAUI_FM1_MAC9, XAUI_FM1_MAC9, XAUI_FM1_MAC9, XAUI_FM1_MAC9, SRIO1, SRIO1, SRIO1, SRIO1}}, + {0x98, {XAUI_FM1_MAC9, XAUI_FM1_MAC9, + XAUI_FM1_MAC9, XAUI_FM1_MAC9, + XAUI_FM1_MAC10, XAUI_FM1_MAC10, + XAUI_FM1_MAC10, XAUI_FM1_MAC10}}, {} }; static struct serdes_config *serdes_cfg_tbl[] = { diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 0b9638b..856ae95 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -537,7 +537,7 @@ #define CONFIG_SYS_NUM_FMAN 1 #define CONFIG_SYS_NUM_FM1_DTSEC 6 #define CONFIG_SYS_NUM_FM1_10GEC 2 -#define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_NUM_DDR_CONTROLLERS 2 #define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_7 #define CONFIG_SYS_FMAN_V3 #define CONFIG_SYS_FM_MURAM_SIZE 0x60000 diff --git a/drivers/net/fm/b4860.c b/drivers/net/fm/b4860.c new file mode 100644 index 0000000..8cde7af --- /dev/null +++ b/drivers/net/fm/b4860.c @@ -0,0 +1,79 @@ +/* + * Copyright 2012 Freescale Semiconductor, Inc. + * Roy Zang tie-fei.zang@freescale.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <phy.h> +#include <fm_eth.h> +#include <asm/io.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_serdes.h> + +u32 port_to_devdisr[] = { + [FM1_DTSEC1] = FSL_CORENET_DEVDISR2_DTSEC1_1, + [FM1_DTSEC2] = FSL_CORENET_DEVDISR2_DTSEC1_2, + [FM1_DTSEC3] = FSL_CORENET_DEVDISR2_DTSEC1_3, + [FM1_DTSEC4] = FSL_CORENET_DEVDISR2_DTSEC1_4, + [FM1_DTSEC5] = FSL_CORENET_DEVDISR2_DTSEC1_5, + [FM1_DTSEC6] = FSL_CORENET_DEVDISR2_DTSEC1_6, + [FM1_10GEC1] = FSL_CORENET_DEVDISR2_10GEC1_1, + [FM1_10GEC2] = FSL_CORENET_DEVDISR2_10GEC1_2, +}; + +static int is_device_disabled(enum fm_port port) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 devdisr2 = in_be32(&gur->devdisr2); + + return port_to_devdisr[port] & devdisr2; +} + +void fman_disable_port(enum fm_port port) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + + setbits_be32(&gur->devdisr2, port_to_devdisr[port]); +} + +phy_interface_t fman_port_enet_if(enum fm_port port) +{ + if (is_device_disabled(port)) + return PHY_INTERFACE_MODE_NONE; + + if ((port == FM1_10GEC1 || port == FM1_10GEC2) + && (is_serdes_configured(XAUI_FM1))) + return PHY_INTERFACE_MODE_XGMII; + + /* Fix me need to handle RGMII here first */ + + switch (port) { + case FM1_DTSEC1: + case FM1_DTSEC2: + case FM1_DTSEC3: + case FM1_DTSEC4: + case FM1_DTSEC5: + case FM1_DTSEC6: + if (is_serdes_configured(SGMII_FM1_DTSEC1 + port - FM1_DTSEC1)) + return PHY_INTERFACE_MODE_SGMII; + break; + default: + return PHY_INTERFACE_MODE_NONE; + } + + return PHY_INTERFACE_MODE_NONE; +}
Poonam Aggrwal
