[U-Boot] [PATCH 1/4] powerpc/t4qds: Add T4QDS board
The T4240QDS is a high-performance computing evaluation, development and test platform supporting the T4240 QorIQ Power Architecture™ processor.
SERDES Connections 32 lanes grouped into four 8-lane banks Two “front side” banks dedicated to Ethernet Two “back side” banks dedicated to other protocols DDR Controllers Three independant 64-bit DDR3 controllers Supports rates up to 2133 MHz data-rate Supports two DDR3/DDR3LP UDIMM/RDIMMs per controller QIXIS System Logic FPGA
Each DDR controller has two DIMM slots. The first slot of each controller has up to 4 chip selects to support single-, dual- and quad-rank DIMMs. The second slot has only 2 chip selects to support single- and dual-rank DIMMs. At any given time, up to total 4 chip selects can be used.
Detail information can be found in doc/README.t4qds
Signed-off-by: York Sun yorksun@freescale.com Signed-off-by: Andy Fleming afleming@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com Signed-off-by: Roy Zang tie-fei.zang@freescale.com --- board/freescale/t4qds/Makefile | 54 ++ board/freescale/t4qds/ddr.c | 186 +++++++ board/freescale/t4qds/eth.c | 495 ++++++++++++++++++ board/freescale/t4qds/law.c | 47 ++ board/freescale/t4qds/pci.c | 39 ++ board/freescale/t4qds/t4240qds_qixis.h | 56 ++ board/freescale/t4qds/t4qds.c | 395 ++++++++++++++ board/freescale/t4qds/t4qds.h | 37 ++ board/freescale/t4qds/tlb.c | 136 +++++ boards.cfg | 3 + doc/README.t4240qds | 98 ++++ include/configs/T4240QDS.h | 35 ++ include/configs/t4qds.h | 875 ++++++++++++++++++++++++++++++++ 13 files changed, 2456 insertions(+) create mode 100644 board/freescale/t4qds/Makefile create mode 100644 board/freescale/t4qds/ddr.c create mode 100644 board/freescale/t4qds/eth.c create mode 100644 board/freescale/t4qds/law.c create mode 100644 board/freescale/t4qds/pci.c create mode 100644 board/freescale/t4qds/t4240qds_qixis.h create mode 100644 board/freescale/t4qds/t4qds.c create mode 100644 board/freescale/t4qds/t4qds.h create mode 100644 board/freescale/t4qds/tlb.c create mode 100644 doc/README.t4240qds create mode 100644 include/configs/T4240QDS.h create mode 100644 include/configs/t4qds.h
diff --git a/board/freescale/t4qds/Makefile b/board/freescale/t4qds/Makefile new file mode 100644 index 0000000..ff09ffa --- /dev/null +++ b/board/freescale/t4qds/Makefile @@ -0,0 +1,54 @@ +# +# Copyright 2012 Freescale Semiconductor, Inc. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += $(BOARD).o +COBJS-y += ddr.o +COBJS-$(CONFIG_T4240QDS)+= eth.o +COBJS-$(CONFIG_PCI) += pci.o +COBJS-y += law.o +COBJS-y += tlb.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS)) + +clean: + rm -f $(OBJS) $(SOBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/freescale/t4qds/ddr.c b/board/freescale/t4qds/ddr.c new file mode 100644 index 0000000..692616a --- /dev/null +++ b/board/freescale/t4qds/ddr.c @@ -0,0 +1,186 @@ +/* + * Copyright 2012 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * Version 2 or later as published by the Free Software Foundation. + */ + +#include <common.h> +#include <i2c.h> +#include <hwconfig.h> +#include <asm/mmu.h> +#include <asm/fsl_ddr_sdram.h> +#include <asm/fsl_ddr_dimm_params.h> +#include <asm/fsl_law.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct board_specific_parameters { + u32 n_ranks; + u32 datarate_mhz_high; + u32 clk_adjust; + u32 wrlvl_start; + u32 wrlvl_ctl_2; + u32 wrlvl_ctl_3; + u32 cpo; + u32 write_data_delay; + u32 force_2T; +}; + +/* + * This table contains all valid speeds we want to override with board + * specific parameters. datarate_mhz_high values need to be in ascending order + * for each n_ranks group. + */ +static const struct board_specific_parameters udimm0[] = { + /* + * memory controller 0 + * num| hi| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T + * ranks| mhz|adjst| start | ctl2 | ctl3 | |delay | + */ + {2, 1350, 5, 7, 0x0809090b, 0x0c0c0d09, 0xff, 2, 0}, + {2, 1666, 5, 8, 0x080a0a0c, 0x0c0d0e0a, 0xff, 2, 0}, + {2, 2140, 5, 8, 0x090a0b0c, 0x0e0f100b, 0xff, 2, 0}, + {1, 1350, 5, 8, 0x0809090b, 0x0c0c0d0a, 0xff, 2, 0}, + {1, 1700, 5, 8, 0x080a0a0c, 0x0c0d0e0a, 0xff, 2, 0}, + {1, 1900, 4, 8, 0x080a0a0c, 0x0e0e0f0a, 0xff, 2, 0}, + {1, 2140, 4, 8, 0x090a0b0c, 0x0e0f100b, 0xff, 2, 0}, + {} +}; + +/* + * The three slots have slightly different timing. The center values are good + * for all slots. We use identical speed tables for them. In future use, if + * DIMMs require separated tables, make more entries as needed. + */ +static const struct board_specific_parameters *udimms[] = { + udimm0, +}; + +static const struct board_specific_parameters rdimm0[] = { + /* + * memory controller 0 + * num| hi| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T + * ranks| mhz|adjst| start | ctl2 | ctl3 | |delay | + */ + {4, 1350, 5, 9, 0x08070605, 0x07080805, 0xff, 2, 0}, + {4, 1666, 5, 8, 0x08070605, 0x07080805, 0xff, 2, 0}, + {4, 2140, 5, 8, 0x08070605, 0x07081805, 0xff, 2, 0}, + {2, 1350, 5, 7, 0x0809090b, 0x0c0c0d09, 0xff, 2, 0}, + {2, 1666, 5, 8, 0x080a0a0c, 0x0c0d0e0a, 0xff, 2, 0}, + {2, 2140, 5, 8, 0x090a0b0c, 0x0e0f100b, 0xff, 2, 0}, + {1, 1350, 5, 8, 0x0809090b, 0x0c0c0d0a, 0xff, 2, 0}, + {1, 1700, 5, 8, 0x080a0a0c, 0x0c0d0e0a, 0xff, 2, 0}, + {1, 1900, 4, 8, 0x080a0a0c, 0x0e0e0f0a, 0xff, 2, 0}, + {1, 2140, 4, 8, 0x090a0b0c, 0x0e0f100b, 0xff, 2, 0}, + {} +}; + +/* + * The three slots have slightly different timing. See comments above. + */ +static const struct board_specific_parameters *rdimms[] = { + rdimm0, +}; + +void fsl_ddr_board_options(memctl_options_t *popts, + dimm_params_t *pdimm, + unsigned int ctrl_num) +{ + const struct board_specific_parameters *pbsp, *pbsp_highest = NULL; + ulong ddr_freq; + + if (ctrl_num > 2) { + printf("Not supported controller number %d\n", ctrl_num); + return; + } + if (!pdimm->n_ranks) + return; + + /* + * we use identical timing for all slots. If needed, change the code + * to pbsp = rdimms[ctrl_num] or pbsp = udimms[ctrl_num]; + */ + if (popts->registered_dimm_en) + pbsp = rdimms[0]; + else + pbsp = udimms[0]; + + + /* Get clk_adjust, cpo, write_data_delay,2T, according to the board ddr + * freqency and n_banks specified in board_specific_parameters table. + */ + ddr_freq = get_ddr_freq(0) / 1000000; + while (pbsp->datarate_mhz_high) { + if (pbsp->n_ranks == pdimm->n_ranks) { + if (ddr_freq <= pbsp->datarate_mhz_high) { + popts->cpo_override = pbsp->cpo; + popts->write_data_delay = + pbsp->write_data_delay; + popts->clk_adjust = pbsp->clk_adjust; + popts->wrlvl_start = pbsp->wrlvl_start; + popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; + popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; + popts->twoT_en = pbsp->force_2T; + goto found; + } + pbsp_highest = pbsp; + } + pbsp++; + } + + if (pbsp_highest) { + printf("Error: board specific timing not found " + "for data rate %lu MT/s\n" + "Trying to use the highest speed (%u) parameters\n", + ddr_freq, pbsp_highest->datarate_mhz_high); + popts->cpo_override = pbsp_highest->cpo; + popts->write_data_delay = pbsp_highest->write_data_delay; + popts->clk_adjust = pbsp_highest->clk_adjust; + popts->wrlvl_start = pbsp_highest->wrlvl_start; + popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; + popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; + popts->twoT_en = pbsp_highest->force_2T; + } else { + panic("DIMM is not supported by this board"); + } +found: + /* + * Factors to consider for half-strength driver enable: + * - number of DIMMs installed + */ + popts->half_strength_driver_enable = 0; + /* + * Write leveling override + */ + popts->wrlvl_override = 1; + popts->wrlvl_sample = 0xf; + + /* + * Rtt and Rtt_WR override + */ + popts->rtt_override = 0; + + /* Enable ZQ calibration */ + popts->zq_en = 1; + + /* DHC_EN =1, ODT = 75 Ohm */ + popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_75ohm); + popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_75ohm); +} + +phys_size_t initdram(int board_type) +{ + phys_size_t dram_size; + + puts("Initializing....using SPD\n"); + + dram_size = fsl_ddr_sdram(); + + dram_size = setup_ddr_tlbs(dram_size / 0x100000); + dram_size *= 0x100000; + + puts(" DDR: "); + return dram_size; +} diff --git a/board/freescale/t4qds/eth.c b/board/freescale/t4qds/eth.c new file mode 100644 index 0000000..a49c7d4 --- /dev/null +++ b/board/freescale/t4qds/eth.c @@ -0,0 +1,495 @@ +/* + * Copyright 2012 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <netdev.h> +#include <asm/mmu.h> +#include <asm/processor.h> +#include <asm/cache.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_law.h> +#include <asm/fsl_ddr_sdram.h> +#include <asm/fsl_serdes.h> +#include <asm/fsl_portals.h> +#include <asm/fsl_liodn.h> +#include <malloc.h> +#include <fm_eth.h> +#include <fsl_mdio.h> +#include <miiphy.h> +#include <phy.h> +#include <asm/fsl_dtsec.h> +#include <asm/fsl_serdes.h> +#include "../common/qixis.h" +#include "../common/fman.h" + +#include "t4240qds_qixis.h" + +#define EMI_NONE 0xFFFFFFFF +#define EMI1_RGMII 0 +#define EMI1_SLOT1 1 +#define EMI1_SLOT2 2 +#define EMI1_SLOT3 3 +#define EMI1_SLOT4 4 +#define EMI1_SLOT5 5 +#define EMI1_SLOT7 7 +#define EMI2 8 /* tmp, FIXME */ +/* Slot6 and Slot8 do not have EMI connections */ + +static int mdio_mux[NUM_FM_PORTS]; + +static const char *mdio_names[] = { + "T4240QDS_MDIO0", + "T4240QDS_MDIO1", + "T4240QDS_MDIO2", + "T4240QDS_MDIO3", + "T4240QDS_MDIO4", + "T4240QDS_MDIO5", + "NULL", + "T4240QDS_MDIO7", + "T4240QDS_10GC", +}; + +static u8 lane_to_slot_fsm1[] = {1, 1, 1, 1, 2, 2, 2, 2}; +static u8 lane_to_slot_fsm2[] = {3, 3, 3, 3, 4, 4, 4, 4}; + +static const char *t4240qds_mdio_name_for_muxval(u8 muxval) +{ + return mdio_names[muxval]; +} + +struct mii_dev *mii_dev_for_muxval(u8 muxval) +{ + struct mii_dev *bus; + const char *name = t4240qds_mdio_name_for_muxval(muxval); + + if (!name) { + printf("No bus for muxval %x\n", muxval); + return NULL; + } + + bus = miiphy_get_dev_by_name(name); + + if (!bus) { + printf("No bus by name %s\n", name); + return NULL; + } + + return bus; +} + +struct t4240qds_mdio { + u8 muxval; + struct mii_dev *realbus; +}; + +static void t4240qds_mux_mdio(u8 muxval) +{ + u8 brdcfg4; + if ((muxval < 6) || (muxval == 7)) { + brdcfg4 = QIXIS_READ(brdcfg[4]); + brdcfg4 &= ~BRDCFG4_EMISEL_MASK; + brdcfg4 |= (muxval << BRDCFG4_EMISEL_SHIFT); + QIXIS_WRITE(brdcfg[4], brdcfg4); + } +} + +static int t4240qds_mdio_read(struct mii_dev *bus, int addr, int devad, + int regnum) +{ + struct t4240qds_mdio *priv = bus->priv; + + t4240qds_mux_mdio(priv->muxval); + + return priv->realbus->read(priv->realbus, addr, devad, regnum); +} + +static int t4240qds_mdio_write(struct mii_dev *bus, int addr, int devad, + int regnum, u16 value) +{ + struct t4240qds_mdio *priv = bus->priv; + + t4240qds_mux_mdio(priv->muxval); + + return priv->realbus->write(priv->realbus, addr, devad, regnum, value); +} + +static int t4240qds_mdio_reset(struct mii_dev *bus) +{ + struct t4240qds_mdio *priv = bus->priv; + + return priv->realbus->reset(priv->realbus); +} + +static int t4240qds_mdio_init(char *realbusname, u8 muxval) +{ + struct t4240qds_mdio *pmdio; + struct mii_dev *bus = mdio_alloc(); + + if (!bus) { + printf("Failed to allocate T4240QDS MDIO bus\n"); + return -1; + } + + pmdio = malloc(sizeof(*pmdio)); + if (!pmdio) { + printf("Failed to allocate T4240QDS private data\n"); + free(bus); + return -1; + } + + bus->read = t4240qds_mdio_read; + bus->write = t4240qds_mdio_write; + bus->reset = t4240qds_mdio_reset; + sprintf(bus->name, t4240qds_mdio_name_for_muxval(muxval)); + + pmdio->realbus = miiphy_get_dev_by_name(realbusname); + + if (!pmdio->realbus) { + printf("No bus with name %s\n", realbusname); + free(bus); + free(pmdio); + return -1; + } + + pmdio->muxval = muxval; + bus->priv = pmdio; + + return mdio_register(bus); +} + +void board_ft_fman_fixup_port(void *blob, char * prop, phys_addr_t pa, + enum fm_port port, int offset) +{ + if (mdio_mux[port] == EMI1_RGMII) + fdt_set_phy_handle(blob, prop, pa, "phy_rgmii"); + + /* TODO: will do with dts */ +} + +void fdt_fixup_board_enet(void *fdt) +{ + /* TODO: will do with dts */ +} + +int board_eth_init(bd_t *bis) +{ +#if defined(CONFIG_FMAN_ENET) + int i; + struct memac_mdio_info dtsec_mdio_info; + struct memac_mdio_info tgec_mdio_info; + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 srds_prtcl_s1, srds_prtcl_s2; + + srds_prtcl_s1 = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS1_PRTCL; + srds_prtcl_s1 >>= FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT; + srds_prtcl_s2 = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS2_PRTCL; + srds_prtcl_s2 >>= FSL_CORENET2_RCWSR4_SRDS2_PRTCL_SHIFT; + + /* Initialize the mdio_mux array so we can recognize empty elements */ + for (i = 0; i < NUM_FM_PORTS; i++) + mdio_mux[i] = EMI_NONE; + + dtsec_mdio_info.regs = + (struct memac_mdio_controller *)CONFIG_SYS_FM2_DTSEC_MDIO_ADDR; + + dtsec_mdio_info.name = DEFAULT_FM_MDIO_NAME; + + /* Register the 1G MDIO bus */ + fm_memac_mdio_init(bis, &dtsec_mdio_info); + + tgec_mdio_info.regs = + (struct memac_mdio_controller *)CONFIG_SYS_FM2_TGEC_MDIO_ADDR; + tgec_mdio_info.name = DEFAULT_FM_TGEC_MDIO_NAME; + + /* Register the 10G MDIO bus */ + fm_memac_mdio_init(bis, &tgec_mdio_info); + + /* Register the muxing front-ends to the MDIO buses */ + t4240qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_RGMII); + t4240qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT1); + t4240qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT2); + t4240qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT3); + t4240qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT4); + t4240qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT5); + t4240qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT7); + t4240qds_mdio_init(DEFAULT_FM_TGEC_MDIO_NAME, EMI2); + + + switch (srds_prtcl_s1) { + case 1: + case 2: + case 4: + /* XAUI/HiGig in Slot1 and Slot2 */ + fm_info_set_phy_address(FM1_10GEC1, FM1_10GEC1_PHY_ADDR); + fm_info_set_phy_address(FM1_10GEC2, FM1_10GEC2_PHY_ADDR); + break; + case 28: + case 36: + /* SGMII in Slot1 and Slot2 */ + fm_info_set_phy_address(FM1_DTSEC1, SGMII_CARD_PORT1_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC2, SGMII_CARD_PORT2_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC3, SGMII_CARD_PORT3_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC4, SGMII_CARD_PORT4_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC5, SGMII_CARD_PORT1_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC6, SGMII_CARD_PORT2_PHY_ADDR); + if ((srds_prtcl_s2 != 56) && (srds_prtcl_s2 != 57)) { + fm_info_set_phy_address(FM1_DTSEC9, + SGMII_CARD_PORT4_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC10, + SGMII_CARD_PORT3_PHY_ADDR); + } + break; + case 38: + fm_info_set_phy_address(FM1_DTSEC5, QSGMII_CARD_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC6, QSGMII_CARD_PHY_ADDR); + if ((srds_prtcl_s2 != 56) && (srds_prtcl_s2 != 57)) { + fm_info_set_phy_address(FM1_DTSEC9, + QSGMII_CARD_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC10, + QSGMII_CARD_PHY_ADDR); + } + break; + case 40: + case 46: + case 48: + fm_info_set_phy_address(FM1_DTSEC5, SGMII_CARD_PORT1_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC6, SGMII_CARD_PORT2_PHY_ADDR); + if ((srds_prtcl_s2 != 56) && (srds_prtcl_s2 != 57)) { + fm_info_set_phy_address(FM1_DTSEC10, + SGMII_CARD_PORT3_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC9, + SGMII_CARD_PORT4_PHY_ADDR); + } + fm_info_set_phy_address(FM1_DTSEC1, QSGMII_CARD_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC2, QSGMII_CARD_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC3, QSGMII_CARD_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC4, QSGMII_CARD_PHY_ADDR); + break; + default: + puts("Invalid SerDes1 protocol for T4240QDS\n"); + break; + } + + for (i = FM1_DTSEC1; i < FM1_DTSEC1 + CONFIG_SYS_NUM_FM1_DTSEC; i++) { + int idx = i - FM1_DTSEC1, lane, slot; + switch (fm_info_get_enet_if(i)) { + case PHY_INTERFACE_MODE_SGMII: + lane = serdes_get_first_lane(FSL_SRDS_1, + SGMII_FM1_DTSEC1 + idx); + if (lane < 0) + break; + slot = lane_to_slot_fsm1[lane]; + debug("FM1@DTSEC%u expects SGMII in slot %u\n", + idx + 1, slot); + if (QIXIS_READ(present2) & (1 << (slot - 1))) + fm_disable_port(i); + switch (slot) { + case 1: + mdio_mux[i] = EMI1_SLOT1; + fm_info_set_mdio(i, + mii_dev_for_muxval(mdio_mux[i])); + break; + case 2: + mdio_mux[i] = EMI1_SLOT2; + fm_info_set_mdio(i, + mii_dev_for_muxval(mdio_mux[i])); + break; + }; + break; + case PHY_INTERFACE_MODE_RGMII: + /* FM1 DTSEC5 routes to RGMII with EC2 */ + debug("FM1@DTSEC%u is RGMII at address %u\n", + idx + 1, 2); + if (i == FM1_DTSEC5) + fm_info_set_phy_address(i, 2); + mdio_mux[i] = EMI1_RGMII; + fm_info_set_mdio(i, + mii_dev_for_muxval(mdio_mux[i])); + break; + default: + break; + } + } + + for (i = FM1_10GEC1; i < FM1_10GEC1 + CONFIG_SYS_NUM_FM1_10GEC; i++) { + switch (fm_info_get_enet_if(i)) { + case PHY_INTERFACE_MODE_XGMII: + mdio_mux[i] = EMI2; + fm_info_set_mdio(i, mii_dev_for_muxval(mdio_mux[i])); + break; + default: + break; + } + } + + +#if (CONFIG_SYS_NUM_FMAN == 2) + switch (srds_prtcl_s2) { + case 1: + case 2: + case 4: + /* XAUI/HiGig in Slot3 and Slot4 */ + fm_info_set_phy_address(FM2_10GEC1, FM2_10GEC1_PHY_ADDR); + fm_info_set_phy_address(FM2_10GEC2, FM2_10GEC2_PHY_ADDR); + break; + case 7: + case 13: + case 14: + case 16: + case 22: + case 23: + case 25: + case 26: + /* XAUI/HiGig in Slot3, SGMII in Slot4 */ + fm_info_set_phy_address(FM2_10GEC1, FM2_10GEC1_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC1, SGMII_CARD_PORT1_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC2, SGMII_CARD_PORT2_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC3, SGMII_CARD_PORT3_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC4, SGMII_CARD_PORT4_PHY_ADDR); + break; + case 28: + case 36: + /* SGMII in Slot3 and Slot4 */ + fm_info_set_phy_address(FM2_DTSEC1, SGMII_CARD_PORT1_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC2, SGMII_CARD_PORT2_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC3, SGMII_CARD_PORT3_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC4, SGMII_CARD_PORT4_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC5, SGMII_CARD_PORT1_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC6, SGMII_CARD_PORT2_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC9, SGMII_CARD_PORT4_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC10, SGMII_CARD_PORT3_PHY_ADDR); + break; + case 38: + /* QSGMII in Slot3 and Slot4 */ + fm_info_set_phy_address(FM2_DTSEC1, QSGMII_CARD_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC2, QSGMII_CARD_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC3, QSGMII_CARD_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC4, QSGMII_CARD_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC5, QSGMII_CARD_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC6, QSGMII_CARD_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC9, QSGMII_CARD_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC10, QSGMII_CARD_PHY_ADDR); + break; + case 40: + case 46: + case 48: + /* SGMII in Slot3 */ + fm_info_set_phy_address(FM2_DTSEC5, SGMII_CARD_PORT1_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC6, SGMII_CARD_PORT2_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC9, SGMII_CARD_PORT4_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC10, SGMII_CARD_PORT3_PHY_ADDR); + /* QSGMII in Slot4 */ + fm_info_set_phy_address(FM2_DTSEC1, QSGMII_CARD_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC2, QSGMII_CARD_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC3, QSGMII_CARD_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC4, QSGMII_CARD_PHY_ADDR); + break; + case 50: + case 52: + case 54: + fm_info_set_phy_address(FM2_10GEC1, FM2_10GEC1_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC1, QSGMII_CARD_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC2, QSGMII_CARD_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC3, QSGMII_CARD_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC4, QSGMII_CARD_PHY_ADDR); + break; + case 56: + case 57: + /* XFI in Slot3, SGMII in Slot4 */ + fm_info_set_phy_address(FM1_10GEC1, XFI_CARD_PORT1_PHY_ADDR); + fm_info_set_phy_address(FM1_10GEC2, XFI_CARD_PORT2_PHY_ADDR); + fm_info_set_phy_address(FM2_10GEC2, XFI_CARD_PORT3_PHY_ADDR); + fm_info_set_phy_address(FM2_10GEC1, XFI_CARD_PORT4_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC1, SGMII_CARD_PORT1_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC2, SGMII_CARD_PORT2_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC3, SGMII_CARD_PORT3_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC4, SGMII_CARD_PORT4_PHY_ADDR); + break; + default: + puts("Invalid SerDes2 protocol for T4240QDS\n"); + break; + } + + for (i = FM2_DTSEC1; i < FM2_DTSEC1 + CONFIG_SYS_NUM_FM2_DTSEC; i++) { + int idx = i - FM2_DTSEC1, lane, slot; + switch (fm_info_get_enet_if(i)) { + case PHY_INTERFACE_MODE_SGMII: + lane = serdes_get_first_lane(FSL_SRDS_2, + SGMII_FM2_DTSEC1 + idx); + if (lane < 0) + break; + slot = lane_to_slot_fsm2[lane]; + debug("FM2@DTSEC%u expects SGMII in slot %u\n", + idx + 1, slot); + if (QIXIS_READ(present2) & (1 << (slot - 1))) + fm_disable_port(i); + switch (slot) { + case 3: + mdio_mux[i] = EMI1_SLOT3; + fm_info_set_mdio(i, + mii_dev_for_muxval(mdio_mux[i])); + break; + case 4: + mdio_mux[i] = EMI1_SLOT4; + fm_info_set_mdio(i, + mii_dev_for_muxval(mdio_mux[i])); + break; + }; + break; + case PHY_INTERFACE_MODE_RGMII: + /* + * If DTSEC5 is RGMII, then it's routed via via EC1 to + * the first on-board RGMII port. If DTSEC6 is RGMII, + * then it's routed via via EC2 to the second on-board + * RGMII port. + */ + debug("FM2@DTSEC%u is RGMII at address %u\n", + idx + 1, i == FM2_DTSEC5 ? 1 : 2); + fm_info_set_phy_address(i, i == FM2_DTSEC5 ? 1 : 2); + mdio_mux[i] = EMI1_RGMII; + fm_info_set_mdio(i, mii_dev_for_muxval(mdio_mux[i])); + break; + default: + break; + } + } + + for (i = FM2_10GEC1; i < FM2_10GEC1 + CONFIG_SYS_NUM_FM2_10GEC; i++) { + switch (fm_info_get_enet_if(i)) { + case PHY_INTERFACE_MODE_XGMII: + mdio_mux[i] = EMI2; + fm_info_set_mdio(i, mii_dev_for_muxval(mdio_mux[i])); + break; + default: + break; + } + } +#endif /* CONFIG_SYS_NUM_FMAN */ + + cpu_eth_init(bis); +#endif /* CONFIG_FMAN_ENET */ + + return pci_eth_init(bis); +} diff --git a/board/freescale/t4qds/law.c b/board/freescale/t4qds/law.c new file mode 100644 index 0000000..5debcf6 --- /dev/null +++ b/board/freescale/t4qds/law.c @@ -0,0 +1,47 @@ +/* + * Copyright 2008-2012 Freescale Semiconductor, Inc. + * + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_law.h> +#include <asm/mmu.h> + +struct law_entry law_table[] = { + SET_LAW(CONFIG_SYS_FLASH_BASE_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_IFC), +#ifdef CONFIG_SYS_BMAN_MEM_PHYS + SET_LAW(CONFIG_SYS_BMAN_MEM_PHYS, LAW_SIZE_32M, LAW_TRGT_IF_BMAN), +#endif +#ifdef CONFIG_SYS_QMAN_MEM_PHYS + SET_LAW(CONFIG_SYS_QMAN_MEM_PHYS, LAW_SIZE_32M, LAW_TRGT_IF_QMAN), +#endif + SET_LAW(QIXIS_BASE_PHYS, LAW_SIZE_4K, LAW_TRGT_IF_IFC), +#ifdef CONFIG_SYS_DCSRBAR_PHYS + SET_LAW(CONFIG_SYS_DCSRBAR_PHYS, LAW_SIZE_4M, LAW_TRGT_IF_DCSR), +#endif +#ifdef CONFIG_SYS_NAND_BASE_PHYS + SET_LAW(CONFIG_SYS_NAND_BASE_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_IFC), +#endif +}; + +int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/freescale/t4qds/pci.c b/board/freescale/t4qds/pci.c new file mode 100644 index 0000000..fc00b4a --- /dev/null +++ b/board/freescale/t4qds/pci.c @@ -0,0 +1,39 @@ +/* + * Copyright 2007-2012 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <pci.h> +#include <asm/fsl_pci.h> +#include <libfdt.h> +#include <fdt_support.h> +#include <asm/fsl_serdes.h> + +void pci_init_board(void) +{ + fsl_pcie_init_board(0); +} + +void pci_of_setup(void *blob, bd_t *bd) +{ + FT_FSL_PCI_SETUP; +} diff --git a/board/freescale/t4qds/t4240qds_qixis.h b/board/freescale/t4qds/t4240qds_qixis.h new file mode 100644 index 0000000..efb718d --- /dev/null +++ b/board/freescale/t4qds/t4240qds_qixis.h @@ -0,0 +1,56 @@ +/* + * Copyright 2012 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __T4020QDS_QIXIS_H__ +#define __T4020QDS_QIXIS_H__ + +/* Definitions of QIXIS Registers for T4020QDS */ + +/* BRDCFG4[4:7]] select EC1 and EC2 as a pair */ +#define BRDCFG4_EMISEL_MASK 0xE0 +#define BRDCFG4_EMISEL_SHIFT 5 + +/* SYSCLK */ +#define QIXIS_SYSCLK_66 0x0 +#define QIXIS_SYSCLK_83 0x1 +#define QIXIS_SYSCLK_100 0x2 +#define QIXIS_SYSCLK_125 0x3 +#define QIXIS_SYSCLK_133 0x4 +#define QIXIS_SYSCLK_150 0x5 +#define QIXIS_SYSCLK_160 0x6 +#define QIXIS_SYSCLK_166 0x7 + +/* DDRCLK */ +#define QIXIS_DDRCLK_66 0x0 +#define QIXIS_DDRCLK_100 0x1 +#define QIXIS_DDRCLK_125 0x2 +#define QIXIS_DDRCLK_133 0x3 + +#define BRDCFG5_RESET 0x00 + +#define BRDCFG12_SD3EN_MASK 0x20 +#define BRDCFG12_SD3MX_MASK 0x08 +#define BRDCFG12_SD3MX_SLOT5 0x08 +#define BRDCFG12_SD3MX_SLOT6 0x00 +#define BRDCFG12_SD4EN_MASK 0x04 +#define BRDCFG12_SD4MX_MASK 0x03 +#define BRDCFG12_SD4MX_SLOT7 0x02 +#define BRDCFG12_SD4MX_SLOT8 0x01 +#define BRDCFG12_SD4MX_AURO_SATA 0x00 +#endif diff --git a/board/freescale/t4qds/t4qds.c b/board/freescale/t4qds/t4qds.c new file mode 100644 index 0000000..88b8ced --- /dev/null +++ b/board/freescale/t4qds/t4qds.c @@ -0,0 +1,395 @@ +/* + * Copyright 2009-2012 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <i2c.h> +#include <netdev.h> +#include <linux/compiler.h> +#include <asm/mmu.h> +#include <asm/processor.h> +#include <asm/cache.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_law.h> +#include <asm/fsl_serdes.h> +#include <asm/fsl_portals.h> +#include <asm/fsl_liodn.h> +#include <fm_eth.h> + +#include "../common/qixis.h" +#include "../common/vsc3316_3308.h" +#include "t4qds.h" +#include "t4240qds_qixis.h" + +DECLARE_GLOBAL_DATA_PTR; + +int checkboard(void) +{ + u8 sw; + struct cpu_type *cpu = gd->cpu; + ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; + unsigned int i; + + printf("Board: %sQDS, ", cpu->name); + printf("Sys ID: 0x%02x, Sys Ver: 0x%02x, FPGA Ver: 0x%02x, ", + QIXIS_READ(id), QIXIS_READ(arch), QIXIS_READ(scver)); + + sw = QIXIS_READ(brdcfg[0]); + sw = (sw & QIXIS_LBMAP_MASK) >> QIXIS_LBMAP_SHIFT; + + if (sw < 0x8) + printf("vBank: %d\n", sw); + else if (sw == 0x8) + puts("Promjet\n"); + else if (sw == 0x9) + puts("NAND\n"); + else + printf("invalid setting of SW%u\n", QIXIS_LBMAP_SWITCH); + + /* Display the RCW, so that no one gets confused as to what RCW + * we're actually using for this boot. + */ + puts("Reset Configuration Word (RCW):"); + for (i = 0; i < ARRAY_SIZE(gur->rcwsr); i++) { + u32 rcw = in_be32(&gur->rcwsr[i]); + + if ((i % 4) == 0) + printf("\n %08x:", i * 4); + printf(" %08x", rcw); + } + puts("\n"); + + /* + * Display the actual SERDES reference clocks as configured by the + * dip switches on the board. Note that the SWx registers could + * technically be set to force the reference clocks to match the + * values that the SERDES expects (or vice versa). For now, however, + * we just display both values and hope the user notices when they + * don't match. + */ + puts("SERDES Reference Clocks: "); + sw = QIXIS_READ(brdcfg[2]); + for (i = 0; i < MAX_SERDES; i++) { + static const char *freq[] = { + "100", "125", "156.25", "161.1328125"}; + unsigned int clock = (sw >> (2 * i)) & 3; + + printf("SERDES%u=%sMHz ", i+1, freq[clock]); + } + puts("\n"); + + return 0; +} + +int select_i2c_ch_pca9547(u8 ch) +{ + int ret; + + ret = i2c_write(I2C_MUX_PCA_ADDR_PRI, 0, 1, &ch, 1); + if (ret) { + puts("PCA: failed to select proper channel\n"); + return ret; + } + + return 0; +} + +/* Configure Crossbar switches for Front-Side SerDes Ports */ +int config_frontside_crossbar_vsc3316(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 srds_prtcl_s1, srds_prtcl_s2; + int ret; + + ret = select_i2c_ch_pca9547(I2C_MUX_CH_VSC3316_FS); + if (ret) + return ret; + + srds_prtcl_s1 = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS1_PRTCL; + srds_prtcl_s1 >>= FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT; + if (srds_prtcl_s1) { + ret = vsc3316_config(VSC3316_FSM_TX_ADDR, vsc3316_fsm1_tx, 8); + if (ret) + return ret; + ret = vsc3316_config(VSC3316_FSM_RX_ADDR, vsc3316_fsm1_rx, 8); + if (ret) + return ret; + } + + srds_prtcl_s2 = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS2_PRTCL; + srds_prtcl_s2 >>= FSL_CORENET2_RCWSR4_SRDS2_PRTCL_SHIFT; + if (srds_prtcl_s2) { + ret = vsc3316_config(VSC3316_FSM_TX_ADDR, vsc3316_fsm2_tx, 8); + if (ret) + return ret; + ret = vsc3316_config(VSC3316_FSM_RX_ADDR, vsc3316_fsm2_rx, 8); + if (ret) + return ret; + } + + return 0; +} + +int config_backside_crossbar_mux(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 srds_prtcl_s3, srds_prtcl_s4; + u8 brdcfg; + + srds_prtcl_s3 = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS3_PRTCL; + srds_prtcl_s3 >>= FSL_CORENET2_RCWSR4_SRDS3_PRTCL_SHIFT; + switch (srds_prtcl_s3) { + case 0: + /* SerDes3 is not enabled */ + break; + case 2: + case 9: + case 10: + /* SD3(0:7) => SLOT5(0:7) */ + brdcfg = QIXIS_READ(brdcfg[12]); + brdcfg &= ~BRDCFG12_SD3MX_MASK; + brdcfg |= BRDCFG12_SD3MX_SLOT5; + QIXIS_WRITE(brdcfg[12], brdcfg); + break; + case 4: + case 6: + case 8: + case 12: + case 14: + case 16: + case 17: + case 19: + case 20: + /* SD3(4:7) => SLOT6(0:3) */ + brdcfg = QIXIS_READ(brdcfg[12]); + brdcfg &= ~BRDCFG12_SD3MX_MASK; + brdcfg |= BRDCFG12_SD3MX_SLOT6; + QIXIS_WRITE(brdcfg[12], brdcfg); + break; + default: + printf("WARNING: unsupported for SerDes3 Protocol %d\n", + srds_prtcl_s3); + return -1; + } + + srds_prtcl_s4 = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS4_PRTCL; + srds_prtcl_s4 >>= FSL_CORENET2_RCWSR4_SRDS4_PRTCL_SHIFT; + switch (srds_prtcl_s4) { + case 0: + /* SerDes4 is not enabled */ + break; + case 2: + /* 10b, SD4(0:7) => SLOT7(0:7) */ + brdcfg = QIXIS_READ(brdcfg[12]); + brdcfg &= ~BRDCFG12_SD4MX_MASK; + brdcfg |= BRDCFG12_SD4MX_SLOT7; + QIXIS_WRITE(brdcfg[12], brdcfg); + break; + case 4: + case 6: + case 8: + /* x1b, SD4(4:7) => SLOT8(0:3) */ + brdcfg = QIXIS_READ(brdcfg[12]); + brdcfg &= ~BRDCFG12_SD4MX_MASK; + brdcfg |= BRDCFG12_SD4MX_SLOT8; + QIXIS_WRITE(brdcfg[12], brdcfg); + break; + case 10: + case 12: + case 14: + case 16: + case 18: + /* 00b, SD4(4:5) => AURORA, SD4(6:7) => SATA */ + brdcfg = QIXIS_READ(brdcfg[12]); + brdcfg &= ~BRDCFG12_SD4MX_MASK; + brdcfg |= BRDCFG12_SD4MX_AURO_SATA; + QIXIS_WRITE(brdcfg[12], brdcfg); + break; + default: + printf("WARNING: unsupported for SerDes4 Protocol %d\n", + srds_prtcl_s4); + return -1; + } + + return 0; +} + +int board_early_init_r(void) +{ + const unsigned int flashbase = CONFIG_SYS_FLASH_BASE; + const u8 flash_esel = find_tlb_idx((void *)flashbase, 1); + + /* + * Remap Boot flash + PROMJET region to caching-inhibited + * so that flash can be erased properly. + */ + + /* Flush d-cache and invalidate i-cache of any FLASH data */ + flush_dcache(); + invalidate_icache(); + + /* invalidate existing TLB entry for flash + promjet */ + disable_tlb(flash_esel); + + set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, flash_esel, BOOKE_PAGESZ_256M, 1); + + set_liodns(); +#ifdef CONFIG_SYS_DPAA_QBMAN + setup_portals(); +#endif + + /* Disable remote I2C connectoin */ + QIXIS_WRITE(brdcfg[5], BRDCFG5_RESET); + + /* Configure board SERDES ports crossbar */ + config_frontside_crossbar_vsc3316(); + config_backside_crossbar_mux(); + select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); + + return 0; +} + +unsigned long get_board_sys_clk(void) +{ + u8 sysclk_conf = QIXIS_READ(brdcfg[1]); + + switch (sysclk_conf & 0x0F) { + case QIXIS_SYSCLK_83: + return 83333333; + case QIXIS_SYSCLK_100: + return 100000000; + case QIXIS_SYSCLK_125: + return 125000000; + case QIXIS_SYSCLK_133: + return 133333333; + case QIXIS_SYSCLK_150: + return 150000000; + case QIXIS_SYSCLK_160: + return 160000000; + case QIXIS_SYSCLK_166: + return 166666666; + } + return 66666666; +} + +unsigned long get_board_ddr_clk(void) +{ + u8 ddrclk_conf = QIXIS_READ(brdcfg[1]); + + switch ((ddrclk_conf & 0x30) >> 4) { + case QIXIS_DDRCLK_100: + return 100000000; + case QIXIS_DDRCLK_125: + return 125000000; + case QIXIS_DDRCLK_133: + return 133333333; + } + return 66666666; +} + +static const char *serdes_clock_to_string(u32 clock) +{ + switch (clock) { + case SRDS_PLLCR0_RFCK_SEL_100: + return "100"; + case SRDS_PLLCR0_RFCK_SEL_125: + return "125"; + case SRDS_PLLCR0_RFCK_SEL_156_25: + return "156.25"; + case SRDS_PLLCR0_RFCK_SEL_161_13: + return "161.1328125"; + default: + return "???"; + } +} + +int misc_init_r(void) +{ + u8 sw; + serdes_corenet_t *srds_regs = + (void *)CONFIG_SYS_FSL_CORENET_SERDES_ADDR; + u32 actual[MAX_SERDES]; + unsigned int i; + + sw = QIXIS_READ(brdcfg[2]); + for (i = 0; i < MAX_SERDES; i++) { + unsigned int clock = (sw >> (2 * i)) & 3; + switch (clock) { + case 0: + actual[i] = SRDS_PLLCR0_RFCK_SEL_100; + break; + case 1: + actual[i] = SRDS_PLLCR0_RFCK_SEL_125; + break; + case 2: + actual[i] = SRDS_PLLCR0_RFCK_SEL_156_25; + break; + case 3: + actual[i] = SRDS_PLLCR0_RFCK_SEL_161_13; + break; + } + } + + for (i = 0; i < MAX_SERDES; i++) { + u32 pllcr0 = srds_regs->bank[i].pllcr0; + u32 expected = pllcr0 & SRDS_PLLCR0_RFCK_SEL_MASK; + if (expected != actual[i]) { + printf("Warning: SERDES%u expects reference clock" + " %sMHz, but actual is %sMHz\n", i + 1, + serdes_clock_to_string(expected), + serdes_clock_to_string(actual[i])); + } + } + + return 0; +} + +void ft_board_setup(void *blob, bd_t *bd) +{ + phys_addr_t base; + phys_size_t size; + + ft_cpu_setup(blob, bd); + + base = getenv_bootm_low(); + size = getenv_bootm_size(); + + fdt_fixup_memory(blob, (u64)base, (u64)size); + +#ifdef CONFIG_PCI + pci_of_setup(blob, bd); +#endif + + fdt_fixup_liodn(blob); + fdt_fixup_dr_usb(blob, bd); + +#ifdef CONFIG_SYS_DPAA_FMAN + fdt_fixup_fman_ethernet(blob); + fdt_fixup_board_enet(blob); +#endif +} diff --git a/board/freescale/t4qds/t4qds.h b/board/freescale/t4qds/t4qds.h new file mode 100644 index 0000000..c6a3492 --- /dev/null +++ b/board/freescale/t4qds/t4qds.h @@ -0,0 +1,37 @@ +/* + * Copyright 2011-2012 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CORENET_DS_H__ +#define __CORENET_DS_H__ + +void fdt_fixup_board_enet(void *blob); +void pci_of_setup(void *blob, bd_t *bd); + +static const int8_t vsc3316_fsm1_tx[8][2] = { {0, 0}, {1, 1}, {6, 6}, {7, 7}, + {8, 8}, {9, 9}, {14, 14}, {15, 15} }; + +static const int8_t vsc3316_fsm2_tx[8][2] = { {2, 2}, {3, 3}, {4, 4}, {5, 5}, + {10, 10}, {11, 11}, {12, 12}, {13, 13} }; + +static const int8_t vsc3316_fsm1_rx[8][2] = { {2, 12}, {3, 13}, {4, 5}, {5, 4}, + {10, 11}, {11, 10}, {12, 2}, {13, 3} }; + +static const int8_t vsc3316_fsm2_rx[8][2] = { {0, 15}, {1, 14}, {6, 7}, {7, 6}, + {8, 9}, {9, 8}, {14, 1}, {15, 0} }; +#endif diff --git a/board/freescale/t4qds/tlb.c b/board/freescale/t4qds/tlb.c new file mode 100644 index 0000000..078a6e4 --- /dev/null +++ b/board/freescale/t4qds/tlb.c @@ -0,0 +1,136 @@ +/* + * Copyright 2008-2012 Freescale Semiconductor, Inc. + * + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/mmu.h> + +struct fsl_e_tlb_entry tlb_table[] = { + /* TLB 0 - for temp stack in cache */ + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, + CONFIG_SYS_INIT_RAM_ADDR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 4 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 8 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 12 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + + /* TLB 1 */ + /* *I*** - Covers boot page */ +#if defined(CONFIG_SYS_RAMBOOT) && defined(CONFIG_SYS_INIT_L3_ADDR) + /* + * *I*G - L3SRAM. When L3 is used as 1M SRAM, the address of the + * SRAM is at 0xfff00000, it covered the 0xfffff000. + */ + SET_TLB_ENTRY(1, CONFIG_SYS_INIT_L3_ADDR, CONFIG_SYS_INIT_L3_ADDR, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 0, BOOKE_PAGESZ_1M, 1), +#else + SET_TLB_ENTRY(1, 0xfffff000, 0xfffff000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 0, BOOKE_PAGESZ_4K, 1), +#endif + + /* *I*G* - CCSRBAR */ + SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 1, BOOKE_PAGESZ_16M, 1), + + /* *I*G* - Flash, localbus */ + /* This will be changed to *I*G* after relocation to RAM. */ + SET_TLB_ENTRY(1, CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE_PHYS, + MAS3_SX|MAS3_SR, MAS2_W|MAS2_G, + 0, 2, BOOKE_PAGESZ_256M, 1), + + /* *I*G* - PCI */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_MEM_VIRT, CONFIG_SYS_PCIE1_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 3, BOOKE_PAGESZ_1G, 1), + + /* *I*G* - PCI */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_MEM_VIRT + 0x40000000, + CONFIG_SYS_PCIE1_MEM_PHYS + 0x40000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 4, BOOKE_PAGESZ_256M, 1), + + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_MEM_VIRT + 0x50000000, + CONFIG_SYS_PCIE1_MEM_PHYS + 0x50000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 5, BOOKE_PAGESZ_256M, 1), + + /* *I*G* - PCI I/O */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_IO_VIRT, CONFIG_SYS_PCIE1_IO_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 6, BOOKE_PAGESZ_256K, 1), + + /* Bman/Qman */ +#ifdef CONFIG_SYS_BMAN_MEM_PHYS + SET_TLB_ENTRY(1, CONFIG_SYS_BMAN_MEM_BASE, CONFIG_SYS_BMAN_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 9, BOOKE_PAGESZ_16M, 1), + SET_TLB_ENTRY(1, CONFIG_SYS_BMAN_MEM_BASE + 0x01000000, + CONFIG_SYS_BMAN_MEM_PHYS + 0x01000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 10, BOOKE_PAGESZ_16M, 1), +#endif +#ifdef CONFIG_SYS_QMAN_MEM_PHYS + SET_TLB_ENTRY(1, CONFIG_SYS_QMAN_MEM_BASE, CONFIG_SYS_QMAN_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 11, BOOKE_PAGESZ_16M, 1), + SET_TLB_ENTRY(1, CONFIG_SYS_QMAN_MEM_BASE + 0x01000000, + CONFIG_SYS_QMAN_MEM_PHYS + 0x01000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 12, BOOKE_PAGESZ_16M, 1), +#endif +#ifdef CONFIG_SYS_DCSRBAR_PHYS + SET_TLB_ENTRY(1, CONFIG_SYS_DCSRBAR, CONFIG_SYS_DCSRBAR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 13, BOOKE_PAGESZ_4M, 1), +#endif +#ifdef CONFIG_SYS_NAND_BASE + /* + * *I*G - NAND + * entry 14 and 15 has been used hard coded, they will be disabled + * in cpu_init_f, so we use entry 16 for nand. + */ + SET_TLB_ENTRY(1, CONFIG_SYS_NAND_BASE, CONFIG_SYS_NAND_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 16, BOOKE_PAGESZ_1M, 1), +#endif + SET_TLB_ENTRY(1, QIXIS_BASE, QIXIS_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 17, BOOKE_PAGESZ_4K, 1), + +}; + +int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/boards.cfg b/boards.cfg index f789539..06b0ec3 100644 --- a/boards.cfg +++ b/boards.cfg @@ -831,6 +831,9 @@ BSC9131RDB_SPIFLASH powerpc mpc85xx bsc9131rdb freesca stxgp3 powerpc mpc85xx stxgp3 stx stxssa powerpc mpc85xx stxssa stx - stxssa stxssa_4M powerpc mpc85xx stxssa stx - stxssa:STXSSA_4M +T4240QDS powerpc mpc85xx t4qds freescale +T4240QDS_SDCARD powerpc mpc85xx t4qds freescale - T4240QDS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 +T4240QDS_SPIFLASH powerpc mpc85xx t4qds freescale - T4240QDS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 TQM8540 powerpc mpc85xx tqm85xx tqc - TQM85xx:MPC8540,TQM8540=y,HOSTNAME=tqm8540,BOARDNAME="TQM8540" TQM8541 powerpc mpc85xx tqm85xx tqc - TQM85xx:MPC8541,TQM8541=y,HOSTNAME=tqm8541,BOARDNAME="TQM8541" TQM8548 powerpc mpc85xx tqm85xx tqc - TQM85xx:MPC8548,TQM8548=y,HOSTNAME=tqm8548,BOARDNAME="TQM8548" diff --git a/doc/README.t4240qds b/doc/README.t4240qds new file mode 100644 index 0000000..677d120 --- /dev/null +++ b/doc/README.t4240qds @@ -0,0 +1,98 @@ +Overview +-------- +The T4240QDS is a high-performance computing evaluation, development and test +platform supporting the T4240 QorIQ™ Power Architecture™ processor. T4240QDS is +optimized to support the high-bandwidth DDR3 memory ports, as well as the +highly-configurable SerDes ports. The system is lead-free and RoHS-compliant. + +Board Features + SERDES Connections + 32 lanes grouped into four 8-lane banks + Two “front side” banks dedicated to Ethernet + - High-speed crosspoint switch fabric on selected lanes + - Two PCI Express slots with side-band connector supporting + - SGMII + - XAUI + - HiGig + - I-pass connectors allow board-to-board and loopback support + Two “back side” banks dedicated to other protocols + - High-speed crosspoint switch fabric on all lanes + - Four PCI Express slots with side-band connector supporting + - PCI Express 3.0 + - SATA 2.0 + - SRIO 2.0 + - Supports 4X Aurora debug with two connectors + DDR Controllers + Three independant 64-bit DDR3 controllers + Supports rates of 1866 up to 2133 MHz data-rate + Supports two DDR3/DDR3LP UDIMM/RDIMMs per controller + DDR power supplies 1.5V to all devices with automatic tracking of VTT. + Power software-switchable to 1.35V if software detects all DDR3LP devices. + MT9JSF25672AZ-2G1KZESZF has been tested at 1333, 1600, 1867, 2000 and + 2133MT/s speeds. For 1867MT/s and above, read-to-write turnaround time + increases by 1 clock. + + IFC/Local Bus + NAND flash: 8-bit, async or sync, up to 2GB. + NOR: 16-bit, Address/Data Multiplexed (ADM), up to 128 MB + NOR: 8-bit or 16-bit, non-multiplexed, up to 512MB + - NOR devices support 16 virtual banks + GASIC: Minimal target within Qixis FPGA + PromJET rapid memory download support + Address demultiplexing handled within FPGA. + - Flexible demux allows 8 or 16 bit evaluation. + IFC Debug/Development card + - Support for 32-bit devices + Ethernet + Support two on-board RGMII 10/100/1G ethernet ports. + SGMII and XAUI support via SERDES block (see above). + 1588 support via Symmetricom board. + QIXIS System Logic FPGA + Manages system power and reset sequencing + Manages DUT, board, clock, etc. configuration for dynamic shmoo + Collects V-I-T data in background for code/power profiling. + Supports legacy TMT test features (POSt, IRS, SYSCLK-synchronous assertion) + General fault monitoring and logging + Runs from ATX “hot” power rails allowing operation while system is off. + Clocks + System and DDR clock (SYSCLK, “DDRCLK”) + - Switch selectable to one of 16 common settings in the interval 33MHz-166MHz. + - Software selectable in 1MHz increments from 1-200MHz. + SERDES clocks + - Provides clocks to all SerDes blocks and slots + - 100, 125 and 156.25 MHz + Power Supplies + Dedicated regulators for VDD + - Adjustable from (0.7V to 1.3V at 80A + - Regulators can be controlled by VID and/or software + Dedicated regulator for GVDD_PL: 1.35/1.5V at 22A + - VTT/MVREF automatically track operating voltage + Dedicated regulators/filters for AVDD supplies + Dedicated regulators for other supplies: OVDD, BVDD, DVDD, LVDD, POVDD, etc. + USB + Supports two USB 2.0 ports with integrated PHYs + - One type A, one type micro-AB with 1.0A power per port. + Other IO + eSDHC/MMC + - SDHC card slot + eSPI port + - High-speed serial flash + Two Serial port + Four I2C ports + +Memory map +---------- +The addresses in brackets are physical addresses. + +0x0_0000_0000 (0x0_0000_0000) - 0x0_7fff_ffff 2GB DDR (more than 2GB is initialized but not mapped under with TLB) +0x0_8000_0000 (0xc_0000_0000) - 0x0_dfff_ffff 1.5GB PCIE memory +0x0_f000_0000 (0xf_0000_0000) - 0x0_f03f_ffff 4MB DCSR +0x0_f400_0000 (0xf_f400_0000) - 0x0_f5ff_ffff 32MB BMan +0x0_f600_0000 (0xf_f600_0000) - 0x0_f7ff_ffff 32MB QMan +0x0_f800_0000 (0xf_f800_0000) - 0x0_f803_ffff 256KB PCIE IO +0x0_e000_0000 (0xf_e000_0000) - 0x0_efff_ffff 256MB NOR flash +0x0_fe00_0000 (0xf_fe00_0000) - 0x0_feff_ffff 16MB CCSR +0x0_ffdf_0000 (0xf_ffdf_0000) - 0x0_ffdf_03ff 4KB QIXIS +0x0_ffff_f000 (0x0_7fff_fff0) - 0x0_ffff_ffff 4KB Boot page translation for secondary cores + +The physical address of the last (boot page translation) varies with the actual DDR size. diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h new file mode 100644 index 0000000..76b3ca6 --- /dev/null +++ b/include/configs/T4240QDS.h @@ -0,0 +1,35 @@ +/* + * Copyright 2011-2012 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * T4240 QDS board configuration file + */ +#define CONFIG_T4240QDS +#define CONFIG_PHYS_64BIT +#define CONFIG_PPC_T4240 + +#define CONFIG_FSL_SATA_V2 +#define CONFIG_PCIE4 + +#define CONFIG_ICS307_REFCLK_HZ 25000000 /* ICS307 ref clk freq */ + +#include "t4qds.h" diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h new file mode 100644 index 0000000..499ed12 --- /dev/null +++ b/include/configs/t4qds.h @@ -0,0 +1,875 @@ +/* + * Copyright 2011-2012 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Corenet DS style board configuration file + */ +#ifndef __CONFIG_H +#define __CONFIG_H + +#ifdef CONFIG_RAMBOOT_PBL +#define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE +#define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc +#endif + +#define CONFIG_CMD_REGINFO + +/* High Level Configuration Options */ +#define CONFIG_BOOKE +#define CONFIG_E6500 +#define CONFIG_E500 /* BOOKE e500 family */ +#define CONFIG_E500MC /* BOOKE e500mc family */ +#define CONFIG_SYS_BOOK3E_HV /* Category E.HV supported */ +#define CONFIG_MPC85xx /* MPC85xx/PQ3 platform */ +#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ +#define CONFIG_MP /* support multiple processors */ + +#ifndef CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_TEXT_BASE 0xeff80000 +#endif + +#ifndef CONFIG_RESET_VECTOR_ADDRESS +#define CONFIG_RESET_VECTOR_ADDRESS 0xeffffffc +#endif + +#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ +#define CONFIG_SYS_NUM_CPC CONFIG_NUM_DDR_CONTROLLERS +#define CONFIG_FSL_IFC /* Enable IFC Support */ +#define CONFIG_PCI /* Enable PCI/PCIE */ +#define CONFIG_PCIE1 /* PCIE controler 1 */ +#define CONFIG_PCIE2 /* PCIE controler 2 */ +#define CONFIG_PCIE3 /* PCIE controler 3 */ +#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ +#define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */ + +#define CONFIG_SYS_SRIO +#define CONFIG_SRIO1 /* SRIO port 1 */ +#define CONFIG_SRIO2 /* SRIO port 2 */ + +#define CONFIG_FSL_LAW /* Use common FSL init code */ + +#define CONFIG_ENV_OVERWRITE + +#ifdef CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_IS_NOWHERE +#else +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE +#endif + +#ifndef CONFIG_SYS_NO_FLASH +#if defined(CONFIG_SPIFLASH) +#define CONFIG_SYS_EXTRA_ENV_RELOC +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SPI_BUS 0 +#define CONFIG_ENV_SPI_CS 0 +#define CONFIG_ENV_SPI_MAX_HZ 10000000 +#define CONFIG_ENV_SPI_MODE 0 +#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ +#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ +#define CONFIG_ENV_SECT_SIZE 0x10000 +#elif defined(CONFIG_SDCARD) +#define CONFIG_SYS_EXTRA_ENV_RELOC +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_OFFSET (512 * 1097) +#elif defined(CONFIG_NAND) +#define CONFIG_SYS_EXTRA_ENV_RELOC +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE +#define CONFIG_ENV_OFFSET (5 * CONFIG_SYS_NAND_BLOCK_SIZE) +#else +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ +#endif +#else /* CONFIG_SYS_NO_FLASH */ +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ +#endif + + + +#define CONFIG_SYS_CLK_FREQ get_board_sys_clk() +#define CONFIG_DDR_CLK_FREQ get_board_ddr_clk() + +#ifndef __ASSEMBLY__ +unsigned long get_board_sys_clk(void); +unsigned long get_board_ddr_clk(void); +#endif + +/* + * These can be toggled for performance analysis, otherwise use default. + */ +#define CONFIG_SYS_CACHE_STASHING +#define CONFIG_BTB /* toggle branch predition */ +#define CONFIG_DDR_ECC +#ifdef CONFIG_DDR_ECC +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER +#define CONFIG_MEM_INIT_VALUE 0xdeadbeef +#endif + +#define CONFIG_ENABLE_36BIT_PHYS + +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_ADDR_MAP +#define CONFIG_SYS_NUM_ADDR_MAP 64 /* number of TLB1 entries */ +#endif + +#if 0 +#define CONFIG_POST CONFIG_SYS_POST_MEMORY /* test POST memory test */ +#endif +#define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0x00400000 +#define CONFIG_SYS_ALT_MEMTEST +#define CONFIG_PANIC_HANG /* do not reset board on panic */ + +/* + * Config the L3 Cache as L3 SRAM + */ +#define CONFIG_SYS_INIT_L3_ADDR CONFIG_RAMBOOT_TEXT_BASE + +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_DCSRBAR 0xf0000000 +#define CONFIG_SYS_DCSRBAR_PHYS 0xf00000000ull +#endif + +/* EEPROM */ +#define CONFIG_ID_EEPROM +#define CONFIG_SYS_I2C_EEPROM_NXID +#define CONFIG_SYS_EEPROM_BUS_NUM 0 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x57 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 + +/* + * DDR Setup + */ +#define CONFIG_VERY_BIG_RAM +#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE + +/* CONFIG_NUM_DDR_CONTROLLERS is defined in include/asm/config_mpc85xx.h */ +#define CONFIG_DIMM_SLOTS_PER_CTLR 2 +#define CONFIG_CHIP_SELECTS_PER_CTRL 4 +#define CONFIG_FSL_DDR_FIRST_SLOT_QUAD_CAPABLE + +#define CONFIG_DDR_SPD +#define CONFIG_FSL_DDR3 + +#define CONFIG_SYS_SPD_BUS_NUM 0 +#define SPD_EEPROM_ADDRESS1 0x51 +#define SPD_EEPROM_ADDRESS2 0x52 +#define SPD_EEPROM_ADDRESS3 0x53 +#define SPD_EEPROM_ADDRESS4 0x54 +#define SPD_EEPROM_ADDRESS5 0x55 +#define SPD_EEPROM_ADDRESS6 0x56 +#define SPD_EEPROM_ADDRESS SPD_EEPROM_ADDRESS1 /* for p3041/p5010 */ +#define CONFIG_SYS_SDRAM_SIZE 4096 /* for fixed parameter use */ + +/* + * IFC Definitions + */ +#define CONFIG_SYS_FLASH_BASE 0xe0000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_FLASH_BASE_PHYS (0xf00000000ull | CONFIG_SYS_FLASH_BASE) +#else +#define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE +#endif + +#define CONFIG_SYS_NOR0_CSPR_EXT (0xf) +#define CONFIG_SYS_NOR0_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS \ + + 0x8000000) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR1_CSPR_EXT (0xf) +#define CONFIG_SYS_NOR1_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR_AMASK IFC_AMASK(128*1024*1024) +/* NOR Flash Timing Params */ +#define CONFIG_SYS_NOR_CSOR CSOR_NAND_TRHZ_80 + +#define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x01) | \ + FTIM0_NOR_TEADC(0x01) | \ + FTIM0_NOR_TEAHC(0x20)) +#define CONFIG_SYS_NOR_FTIM1 (FTIM1_NOR_TACO(0x35) | \ + FTIM1_NOR_TRAD_NOR(0x1A) |\ + FTIM1_NOR_TSEQRAD_NOR(0x13)) +#define CONFIG_SYS_NOR_FTIM2 (FTIM2_NOR_TCS(0x01) | \ + FTIM2_NOR_TCH(0x0E) | \ + FTIM2_NOR_TWPH(0x0E) | \ + FTIM2_NOR_TWP(0x1c)) +#define CONFIG_SYS_NOR_FTIM3 0x0 + +#define CONFIG_SYS_FLASH_QUIET_TEST +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ + +#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS \ + + 0x8000000, CONFIG_SYS_FLASH_BASE_PHYS} + +#define CONFIG_FSL_QIXIS /* use common QIXIS code */ +#define QIXIS_BASE 0xffdf0000 +#define QIXIS_LBMAP_SWITCH 6 +#define QIXIS_LBMAP_MASK 0x0f +#define QIXIS_LBMAP_SHIFT 0 +#define QIXIS_LBMAP_DFLTBANK 0x00 +#define QIXIS_LBMAP_ALTBANK 0x04 +#define QIXIS_RST_CTL_RESET 0x83 +#define QIXIS_RCFG_CTL_RECONFIG_IDLE 0x20 +#define QIXIS_RCFG_CTL_RECONFIG_START 0x21 +#define QIXIS_RCFG_CTL_WATCHDOG_ENBLE 0x08 +#ifdef CONFIG_PHYS_64BIT +#define QIXIS_BASE_PHYS (0xf00000000ull | QIXIS_BASE) +#else +#define QIXIS_BASE_PHYS QIXIS_BASE +#endif + +#define CONFIG_SYS_CSPR3_EXT (0xf) +#define CONFIG_SYS_CSPR3 (CSPR_PHYS_ADDR(QIXIS_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 \ + | CSPR_MSEL_GPCM \ + | CSPR_V) +#define CONFIG_SYS_AMASK3 IFC_AMASK(64*1024) +#define CONFIG_SYS_CSOR3 0x0 +/* QIXIS Timing parameters for IFC CS3 */ +#define CONFIG_SYS_CS3_FTIM0 (FTIM0_GPCM_TACSE(0x0e) | \ + FTIM0_GPCM_TEADC(0x0e) | \ + FTIM0_GPCM_TEAHC(0x0e)) +#define CONFIG_SYS_CS3_FTIM1 (FTIM1_GPCM_TACO(0xff) | \ + FTIM1_GPCM_TRAD(0x3f)) +#define CONFIG_SYS_CS3_FTIM2 (FTIM2_GPCM_TCS(0x0e) | \ + FTIM2_GPCM_TCH(0x0) | \ + FTIM2_GPCM_TWP(0x1f)) +#define CONFIG_SYS_CS3_FTIM3 0x0 + +/* NAND Flash on IFC */ +#define CONFIG_NAND_FSL_IFC +#define CONFIG_SYS_NAND_BASE 0xff800000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_NAND_BASE_PHYS (0xf00000000ull | CONFIG_SYS_NAND_BASE) +#else +#define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE +#endif + +#define CONFIG_SYS_NAND_CSPR_EXT (0xf) +#define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 /* Port Size = 8 bit */ \ + | CSPR_MSEL_NAND /* MSEL = NAND */ \ + | CSPR_V) +#define CONFIG_SYS_NAND_AMASK IFC_AMASK(64*1024) + +#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ + | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ + | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \ + | CSOR_NAND_RAL_3 /* RAL = 2Byes */ \ + | CSOR_NAND_PGS_2K /* Page Size = 2K */ \ + | CSOR_NAND_SPRZ_64/* Spare size = 64 */ \ + | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/ + +#define CONFIG_SYS_NAND_ONFI_DETECTION + +/* ONFI NAND Flash mode0 Timing Params */ +#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07) | \ + FTIM0_NAND_TWP(0x18) | \ + FTIM0_NAND_TWCHT(0x07) | \ + FTIM0_NAND_TWH(0x0a)) +#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x32) | \ + FTIM1_NAND_TWBE(0x39) | \ + FTIM1_NAND_TRR(0x0e) | \ + FTIM1_NAND_TRP(0x18)) +#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0x0f) | \ + FTIM2_NAND_TREH(0x0a) | \ + FTIM2_NAND_TWHRE(0x1e)) +#define CONFIG_SYS_NAND_FTIM3 0x0 + +#define CONFIG_SYS_NAND_DDR_LAW 11 + +#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_MTD_NAND_VERIFY_WRITE +#define CONFIG_CMD_NAND + +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) + +#if defined(CONFIG_NAND) +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3 +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK2 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NOR_FTIM3 +#else +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK2 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NAND_FTIM3 +#endif +#define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NOR1_CSPR_EXT +#define CONFIG_SYS_CSPR1 CONFIG_SYS_NOR1_CSPR +#define CONFIG_SYS_AMASK1 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR1 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NOR_FTIM3 + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE + +#if defined(CONFIG_RAMBOOT_PBL) +#define CONFIG_SYS_RAMBOOT +#endif + +#define CONFIG_BOARD_EARLY_INIT_R /* call board_early_init_r function */ +#define CONFIG_MISC_INIT_R + +#define CONFIG_HWCONFIG + +/* define to use L1 as initial stack */ +#define CONFIG_L1_INIT_RAM +#define CONFIG_SYS_INIT_RAM_LOCK +#define CONFIG_SYS_INIT_RAM_ADDR 0xfdd00000 /* Initial L1 address */ +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0xf +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW 0xfe0ec000 +/* The assembler doesn't like typecast */ +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS \ + ((CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH * 1ull << 32) | \ + CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW) +#else +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS 0xfe0ec000 /* Initial L1 address */ +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0 +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW CONFIG_SYS_INIT_RAM_ADDR_PHYS +#endif +#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 + +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +#define CONFIG_SYS_MONITOR_LEN (512 * 1024) +#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) + +/* Serial Port - controlled on board with jumper J8 + * open - index 2 + * shorted - index 1 + */ +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) + +#define CONFIG_SYS_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200} + +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x11C500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x11C600) +#define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) +#define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600) + +/* Use the HUSH parser */ +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT +#define CONFIG_OF_BOARD_SETUP +#define CONFIG_OF_STDOUT_VIA_ALIAS + +/* new uImage format support */ +#define CONFIG_FIT +#define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ + +/* I2C */ +#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ +#define CONFIG_HARD_I2C /* I2C with hardware support */ +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_I2C_CMD_TREE +#define CONFIG_SYS_I2C_SPEED 100000 /* I2C speed */ +#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_OFFSET 0x118000 +#define CONFIG_SYS_I2C2_OFFSET 0x118100 +#define I2C_MUX_PCA_ADDR_PRI 0x77 /* I2C bus multiplexer,primary */ +#define I2C_MUX_PCA_ADDR_SEC 0x76 /* I2C bus multiplexer,secondary */ + +/* VSC Crossbar switches */ +#define CONFIG_VSC_CROSSBAR +#define I2C_MUX_CH_DEFAULT 0x8 +#define I2C_MUX_CH_VSC3316_FS 0xc +#define I2C_MUX_CH_VSC3316_BS 0xd +#define VSC3316_FSM_TX_ADDR 0x70 +#define VSC3316_FSM_RX_ADDR 0x71 + +/* + * RapidIO + */ +#define CONFIG_SYS_SRIO1_MEM_VIRT 0xa0000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_SRIO1_MEM_PHYS 0xc20000000ull +#else +#define CONFIG_SYS_SRIO1_MEM_PHYS 0xa0000000 +#endif +#define CONFIG_SYS_SRIO1_MEM_SIZE 0x10000000 /* 256M */ + +#define CONFIG_SYS_SRIO2_MEM_VIRT 0xb0000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_SRIO2_MEM_PHYS 0xc30000000ull +#else +#define CONFIG_SYS_SRIO2_MEM_PHYS 0xb0000000 +#endif +#define CONFIG_SYS_SRIO2_MEM_SIZE 0x10000000 /* 256M */ + +/* + * for slave u-boot IMAGE instored in master memory space, + * PHYS must be aligned based on the SIZE + */ +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_PHYS 0xfef080000ull +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS1 0xfff80000ull +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_SIZE 0x80000 /* 512K */ +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS2 0x3fff80000ull +/* + * for slave UCODE and ENV instored in master memory space, + * PHYS must be aligned based on the SIZE + */ +#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_PHYS 0xfef040000ull +#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_BUS 0x3ffe00000ull +#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_SIZE 0x40000 /* 256K */ + +/* slave core release by master*/ +#define CONFIG_SRIO_PCIE_BOOT_BRR_OFFSET 0xe00e4 +#define CONFIG_SRIO_PCIE_BOOT_RELEASE_MASK 0x00000001 /* release core 0 */ + +/* + * SRIO_PCIE_BOOT - SLAVE + */ +#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE +#define CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR 0xFFE00000 +#define CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR_PHYS \ + (0x300000000ull | CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR) +#endif +/* + * eSPI - Enhanced SPI + */ +#define CONFIG_FSL_ESPI +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_SPANSION +#define CONFIG_CMD_SF +#define CONFIG_SF_DEFAULT_SPEED 10000000 +#define CONFIG_SF_DEFAULT_MODE 0 + +/* + * General PCI + * Memory space is mapped 1-1, but I/O space must start from 0. + */ + +/* controller 1, direct to uli, tgtid 3, Base address 20000 */ +#define CONFIG_SYS_PCIE1_MEM_VIRT 0x80000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE1_MEM_PHYS 0xc00000000ull +#else +#define CONFIG_SYS_PCIE1_MEM_BUS 0x80000000 +#define CONFIG_SYS_PCIE1_MEM_PHYS 0x80000000 +#endif +#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE1_IO_VIRT 0xf8000000 +#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PCIE1_IO_PHYS 0xff8000000ull +#else +#define CONFIG_SYS_PCIE1_IO_PHYS 0xf8000000 +#endif +#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ + +/* controller 2, Slot 2, tgtid 2, Base address 201000 */ +#define CONFIG_SYS_PCIE2_MEM_VIRT 0xa0000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE2_MEM_PHYS 0xc20000000ull +#else +#define CONFIG_SYS_PCIE2_MEM_BUS 0xa0000000 +#define CONFIG_SYS_PCIE2_MEM_PHYS 0xa0000000 +#endif +#define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE2_IO_VIRT 0xf8010000 +#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PCIE2_IO_PHYS 0xff8010000ull +#else +#define CONFIG_SYS_PCIE2_IO_PHYS 0xf8010000 +#endif +#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ + +/* controller 3, Slot 1, tgtid 1, Base address 202000 */ +#define CONFIG_SYS_PCIE3_MEM_VIRT 0xc0000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE3_MEM_PHYS 0xc40000000ull +#else +#define CONFIG_SYS_PCIE3_MEM_BUS 0xc0000000 +#define CONFIG_SYS_PCIE3_MEM_PHYS 0xc0000000 +#endif +#define CONFIG_SYS_PCIE3_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE3_IO_VIRT 0xf8020000 +#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PCIE3_IO_PHYS 0xff8020000ull +#else +#define CONFIG_SYS_PCIE3_IO_PHYS 0xf8020000 +#endif +#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ + +/* controller 4, Base address 203000 */ +#define CONFIG_SYS_PCIE4_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE4_MEM_PHYS 0xc60000000ull +#define CONFIG_SYS_PCIE4_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE4_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE4_IO_PHYS 0xff8030000ull +#define CONFIG_SYS_PCIE4_IO_SIZE 0x00010000 /* 64k */ + +/* Qman/Bman */ +#ifndef CONFIG_NOBQFMAN +#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ +#define CONFIG_SYS_BMAN_NUM_PORTALS 50 +#define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull +#else +#define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE +#endif +#define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_QMAN_NUM_PORTALS 50 +#define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull +#else +#define CONFIG_SYS_QMAN_MEM_PHYS CONFIG_SYS_QMAN_MEM_BASE +#endif +#define CONFIG_SYS_QMAN_MEM_SIZE 0x02000000 + +#define CONFIG_SYS_DPAA_FMAN +#define CONFIG_SYS_DPAA_PME +#define CONFIG_SYS_PMAN +#define CONFIG_SYS_DPAA_DCE +#define CONFIG_SYS_INTERLAKEN + +/* Default address of microcode for the Linux Fman driver */ +#if defined(CONFIG_SPIFLASH) +/* + * env is stored at 0x100000, sector size is 0x10000, ucode is stored after + * env, so we got 0x110000. + */ +#define CONFIG_SYS_QE_FW_IN_SPIFLASH +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 +#elif defined(CONFIG_SDCARD) +/* + * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is + * about 545KB (1089 blocks), Env is stored after the image, and the env size is + * 0x2000 (16 blocks), 8 + 1089 + 16 = 1113, enlarge it to 1130. + */ +#define CONFIG_SYS_QE_FMAN_FW_IN_MMC +#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1130) +#elif defined(CONFIG_NAND) +#define CONFIG_SYS_QE_FMAN_FW_IN_NAND +#define CONFIG_SYS_QE_FMAN_FW_ADDR (6 * CONFIG_SYS_NAND_BLOCK_SIZE) +#else +#define CONFIG_SYS_QE_FMAN_FW_IN_NOR +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF40000 +#endif +#define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 +#define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) +#endif /* CONFIG_NOBQFMAN */ + +#ifdef CONFIG_SYS_DPAA_FMAN +#define CONFIG_FMAN_ENET +#define CONFIG_PHYLIB_10G +#define CONFIG_PHY_VITESSE +#define CONFIG_PHY_TERANETICS +#define SGMII_CARD_PORT1_PHY_ADDR 0x1C +#define SGMII_CARD_PORT2_PHY_ADDR 0x1D +#define SGMII_CARD_PORT3_PHY_ADDR 0x1E +#define SGMII_CARD_PORT4_PHY_ADDR 0x1F +#define XFI_CARD_PORT1_PHY_ADDR 0x1 /* tmp, FIXME below addr */ +#define XFI_CARD_PORT2_PHY_ADDR 0x2 +#define XFI_CARD_PORT3_PHY_ADDR 0x3 +#define XFI_CARD_PORT4_PHY_ADDR 0x4 +#define QSGMII_CARD_PHY_ADDR 0x5 +#define FM1_10GEC1_PHY_ADDR 0x6 +#define FM1_10GEC2_PHY_ADDR 0x7 +#define FM2_10GEC1_PHY_ADDR 0x8 +#define FM2_10GEC2_PHY_ADDR 0x9 +#endif + +#ifdef CONFIG_PCI +#define CONFIG_NET_MULTI +#define CONFIG_PCI_PNP /* do pci plug-and-play */ +#define CONFIG_E1000 + +#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ +#define CONFIG_DOS_PARTITION +#endif /* CONFIG_PCI */ + +/* SATA */ +#ifdef CONFIG_FSL_SATA_V2 +#define CONFIG_LIBATA +#define CONFIG_FSL_SATA + +#define CONFIG_SYS_SATA_MAX_DEVICE 2 +#define CONFIG_SATA1 +#define CONFIG_SYS_SATA1 CONFIG_SYS_MPC85xx_SATA1_ADDR +#define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA +#define CONFIG_SATA2 +#define CONFIG_SYS_SATA2 CONFIG_SYS_MPC85xx_SATA2_ADDR +#define CONFIG_SYS_SATA2_FLAGS FLAGS_DMA + +#define CONFIG_LBA48 +#define CONFIG_CMD_SATA +#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_EXT2 +#endif + +#ifdef CONFIG_FMAN_ENET +#define CONFIG_MII /* MII PHY management */ +#define CONFIG_ETHPRIME "FM1@DTSEC1" +#define CONFIG_PHY_GIGE /* Include GbE speed/duplex detection */ +#endif + +/* + * Environment + */ +#define CONFIG_LOADS_ECHO /* echo on for serial download */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ELF +#define CONFIG_CMD_ERRATA +#define CONFIG_CMD_GREPENV +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_SETEXPR + +#ifdef CONFIG_PCI +#define CONFIG_CMD_PCI +#define CONFIG_CMD_NET +#endif + +/* +* USB +*/ +#define CONFIG_CMD_USB +#define CONFIG_USB_STORAGE +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_FSL +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET +#define CONFIG_CMD_EXT2 +#define CONFIG_HAS_FSL_DR_USB + +#define CONFIG_MMC + +#ifdef CONFIG_MMC +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR +#define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION +#endif + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_CMDLINE_EDITING /* Command-line editing */ +#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#ifdef CONFIG_CMD_KGDB +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE/* Boot Argument Buffer Size */ +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks*/ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 64 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (64 << 20) /* Initial map for Linux*/ +#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */ + +#ifdef CONFIG_CMD_KGDB +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * Environment Configuration + */ +#define CONFIG_ROOTPATH "/opt/nfsroot" +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_UBOOTPATH "u-boot.bin" /* U-Boot image on TFTP server*/ + +/* default location for tftp and bootm */ +#define CONFIG_LOADADDR 1000000 + +#define CONFIG_BOOTDELAY 10 /* -1 disables auto-boot */ + +#define CONFIG_BAUDRATE 115200 + +#define __USB_PHY_TYPE utmi + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:ctlr_intlv=3way_4KB," \ + "bank_intlv=auto;" \ + "usb1:dr_mode=host,phy_type=" MK_STR(__USB_PHY_TYPE) "\0"\ + "netdev=eth0\0" \ + "uboot=" MK_STR(CONFIG_UBOOTPATH) "\0" \ + "ubootaddr=" MK_STR(CONFIG_SYS_TEXT_BASE) "\0" \ + "tftpflash=tftpboot $loadaddr $uboot && " \ + "protect off $ubootaddr +$filesize && " \ + "erase $ubootaddr +$filesize && " \ + "cp.b $loadaddr $ubootaddr $filesize && " \ + "protect on $ubootaddr +$filesize && " \ + "cmp.b $loadaddr $ubootaddr $filesize\0" \ + "consoledev=ttyS0\0" \ + "ramdiskaddr=2000000\0" \ + "ramdiskfile=t4240qds/ramdisk.uboot\0" \ + "fdtaddr=c00000\0" \ + "fdtfile=t4240qds/t4240qds.dtb\0" \ + "bdev=sda3\0" \ + "c=ffe\0" + +/* For emulation this causes u-boot to jump to the start of the proof point + app code automatically */ +#define CONFIG_PROOF_POINTS \ + "setenv bootargs root=/dev/$bdev rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "cpu 1 release 0x29000000 - - -;" \ + "cpu 2 release 0x29000000 - - -;" \ + "cpu 3 release 0x29000000 - - -;" \ + "cpu 4 release 0x29000000 - - -;" \ + "cpu 5 release 0x29000000 - - -;" \ + "cpu 6 release 0x29000000 - - -;" \ + "cpu 7 release 0x29000000 - - -;" \ + "go 0x29000000" + +#define CONFIG_HVBOOT \ + "setenv bootargs config-addr=0x60000000; " \ + "bootm 0x01000000 - 0x00f00000" + +#define CONFIG_ALU \ + "setenv bootargs root=/dev/$bdev rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "cpu 1 release 0x01000000 - - -;" \ + "cpu 2 release 0x01000000 - - -;" \ + "cpu 3 release 0x01000000 - - -;" \ + "cpu 4 release 0x01000000 - - -;" \ + "cpu 5 release 0x01000000 - - -;" \ + "cpu 6 release 0x01000000 - - -;" \ + "cpu 7 release 0x01000000 - - -;" \ + "go 0x01000000" + +#define CONFIG_LINUX \ + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "setenv ramdiskaddr 0x02000000;" \ + "setenv fdtaddr 0x00c00000;" \ + "setenv loadaddr 0x1000000;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr" + +#define CONFIG_HDBOOT \ + "setenv bootargs root=/dev/$bdev rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr - $fdtaddr" + +#define CONFIG_NFSBOOTCOMMAND \ + "setenv bootargs root=/dev/nfs rw " \ + "nfsroot=$serverip:$rootpath " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr - $fdtaddr" + +#define CONFIG_RAMBOOTCOMMAND \ + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $ramdiskaddr $ramdiskfile;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr" + +#define CONFIG_BOOTCOMMAND CONFIG_LINUX + +#ifdef CONFIG_SECURE_BOOT +#include <asm/fsl_secure_boot.h> +#endif + +#endif /* __CONFIG_H */
Because QMan3.0 and BMan2.1 used ip_cfg in ip_rev_2 register to differ the total portal number, buffer pool number etc, we can use this info to limit those resources in kernel driver.
Signed-off-by: Haiying Wang Haiying.Wang@freescale.com --- arch/powerpc/cpu/mpc85xx/portals.c | 13 +++++++++++-- 1 file changed, 11 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/portals.c b/arch/powerpc/cpu/mpc85xx/portals.c index 6199633..b59ef69 100644 --- a/arch/powerpc/cpu/mpc85xx/portals.c +++ b/arch/powerpc/cpu/mpc85xx/portals.c @@ -182,14 +182,18 @@ void fdt_fixup_qportals(void *blob) { int off, err; unsigned int maj, min; + unsigned int ip_cfg; u32 rev_1 = in_be32(&qman->ip_rev_1); + u32 rev_2 = in_be32(&qman->ip_rev_2); char compat[64]; int compat_len;
maj = (rev_1 >> 8) & 0xff; min = rev_1 & 0xff; + ip_cfg = rev_2 & 0xff;
- compat_len = sprintf(compat, "fsl,qman-portal-%u.%u", maj, min) + 1; + compat_len = sprintf(compat, "fsl,qman-portal-%u.%u.%u", + maj, min, ip_cfg) + 1; compat_len += sprintf(compat + compat_len, "fsl,qman-portal") + 1;
off = fdt_node_offset_by_compatible(blob, -1, "fsl,qman-portal"); @@ -267,14 +271,19 @@ void fdt_fixup_bportals(void *blob) { int off, err; unsigned int maj, min; + unsigned int ip_cfg; u32 rev_1 = in_be32(&bman->ip_rev_1); + u32 rev_2 = in_be32(&bman->ip_rev_2); char compat[64]; int compat_len;
- compat_len = sprintf(compat, "fsl,bman-portal-%u.%u", maj, min) + 1; + ip_cfg = rev_2 & 0xff; + + compat_len = sprintf(compat, "fsl,bman-portal-%u.%u.%u", + maj, min, ip_cfg) + 1; compat_len += sprintf(compat + compat_len, "fsl,bman-portal") + 1;
off = fdt_node_offset_by_compatible(blob, -1, "fsl,bman-portal");
Starting from QMan3.0, the QMan clock cycle needs be exposed so that the kernel driver can use it to calculate the shaper prescaler and rate.
Signed-off-by: Haiying Wang Haiying.Wang@freescale.com --- arch/powerpc/cpu/mpc85xx/cpu.c | 4 ++++ arch/powerpc/cpu/mpc85xx/fdt.c | 5 +++++ arch/powerpc/cpu/mpc85xx/speed.c | 4 ++++ include/e500.h | 3 +++ 4 files changed, 16 insertions(+)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu.c b/arch/powerpc/cpu/mpc85xx/cpu.c index 24a572c..149040d 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu.c +++ b/arch/powerpc/cpu/mpc85xx/cpu.c @@ -217,6 +217,10 @@ int checkcpu (void) } #endif
+#ifdef CONFIG_SYS_DPAA_QBMAN + printf(" QMAN: %s MHz\n", strmhz(buf1, sysinfo.freqQMAN)); +#endif + #ifdef CONFIG_SYS_DPAA_PME printf(" PME: %s MHz\n", strmhz(buf1, sysinfo.freqPME)); #endif diff --git a/arch/powerpc/cpu/mpc85xx/fdt.c b/arch/powerpc/cpu/mpc85xx/fdt.c index a364ef2..ab09330 100644 --- a/arch/powerpc/cpu/mpc85xx/fdt.c +++ b/arch/powerpc/cpu/mpc85xx/fdt.c @@ -411,6 +411,11 @@ static void ft_fixup_dpaa_clks(void *blob) #endif #endif
+#ifdef CONFIG_SYS_DPAA_QBMAN + do_fixup_by_compat_u32(blob, "fsl,qman", + "clock-frequency", sysinfo.freqQMAN, 1); +#endif + #ifdef CONFIG_SYS_DPAA_PME do_fixup_by_compat_u32(blob, "fsl,pme", "clock-frequency", sysinfo.freqPME, 1); diff --git a/arch/powerpc/cpu/mpc85xx/speed.c b/arch/powerpc/cpu/mpc85xx/speed.c index 8bbf0bc..c55f1d3 100644 --- a/arch/powerpc/cpu/mpc85xx/speed.c +++ b/arch/powerpc/cpu/mpc85xx/speed.c @@ -167,6 +167,10 @@ void get_sys_info (sys_info_t * sysInfo) } #endif
+#ifdef CONFIG_SYS_DPAA_QBMAN + sysInfo->freqQMAN = sysInfo->freqSystemBus / 2; +#endif + #ifdef CONFIG_SYS_DPAA_FMAN switch ((rcw_tmp & FM1_CLK_SEL) >> FM1_CLK_SHIFT) { case 1: diff --git a/include/e500.h b/include/e500.h index e1708b9..0ff8e89 100644 --- a/include/e500.h +++ b/include/e500.h @@ -18,6 +18,9 @@ typedef struct #ifdef CONFIG_SYS_DPAA_FMAN unsigned long freqFMan[CONFIG_SYS_NUM_FMAN]; #endif +#ifdef CONFIG_SYS_DPAA_QBMAN + unsigned long freqQMAN; +#endif #ifdef CONFIG_SYS_DPAA_PME unsigned long freqPME; #endif
B4860QDS is a high-performance computing evaluation, development and test platform supporting the B4860 QorIQ Power Architecture™ processor.
VSC3316 is 11.5Gbps 16x16 Asynchronous cross-point switch and VSC3308 is 11.5Gbps 8x8 Asynchronous cross-point switch, these crosspoint switches commute SerDes lanes to different destinations depending upon their programming in accordance with SerDes protocol
1) Add defines for VSC3316/3308 crosspoint switches 2) Add define for PCA-I2C bus multiplexer 3) Add support in b4860qds board file to configure these crosspoint switches based on the SerDes1 and SerDes2 protocol 4) Add VSC3316 and VSC3308 Mux entries for all possible crosspoint connections on b4860qds board
B4860 has FMANv3 so the External PHYs are accessible using dedicated MDIO blocks at addresse 0x4fc0000 0x4fd0000. B4860 has only SGMII, no RGMII, single FMAN.
Slot and PHYs details on B4860QDS ----------------------------------- - Two on board SGMII PHYs connected through serdes1 via crossbar - Two slots available via AMC2PEX connector through serdes2 - Slot1 (PCIe/ SGMII riser/ XAUI) connected to serdes2 lanes 0,1,2,3 - Slot2 (PCIe/ SGMII Riser/ XAUI) connected to serdes2 lanes 4,5,6,7 via crossbar
Cross bar is a Vitesse switch on B4860 QDS which is connected to serdes on one side(input) and the PHYs(output) on the other side. So this device needs to be configured to get the right serdes lanes go to the right PHYs and slots. Cross bar configurations done based on the RCW.
Currently the below mentioned are tested and supported: 1. sgmii5 and sgmii6 are connected to onboard PHYs srds1_prtcl=0x2A 2. sgmii 1, sgmiii2, sgmii3, sgmii4 via SGMII riser card on Slot#1 srds2_prtcl=0x18
Signed-off-by: York Sun yorksun@freescale.com Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com Signed-off-by: Shaveta Leekha shaveta@freescale.com Signed-off-by: Priyanka Jain Priyanka.Jain@freescale.com Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com Signed-off-by: Roy Zang tie-fei.zang@freescale.com Signed-off-by: Sandeep Singh Sandeep@freescale.com --- board/freescale/b4860qds/Makefile | 54 ++ board/freescale/b4860qds/b4860qds.c | 444 ++++++++++++ board/freescale/b4860qds/b4860qds.h | 26 + board/freescale/b4860qds/b4860qds_crossbar_con.h | 58 ++ board/freescale/b4860qds/b4860qds_qixis.h | 47 ++ board/freescale/b4860qds/ddr.c | 190 +++++ board/freescale/b4860qds/eth_b4860qds.c | 287 ++++++++ board/freescale/b4860qds/law.c | 44 ++ board/freescale/b4860qds/pci.c | 39 ++ board/freescale/b4860qds/tlb.c | 122 ++++ boards.cfg | 2 + doc/README.b4860qds | 20 + include/configs/B4860QDS.h | 812 ++++++++++++++++++++++ 13 files changed, 2145 insertions(+) create mode 100644 board/freescale/b4860qds/Makefile create mode 100644 board/freescale/b4860qds/b4860qds.c create mode 100644 board/freescale/b4860qds/b4860qds.h create mode 100644 board/freescale/b4860qds/b4860qds_crossbar_con.h create mode 100644 board/freescale/b4860qds/b4860qds_qixis.h create mode 100644 board/freescale/b4860qds/ddr.c create mode 100644 board/freescale/b4860qds/eth_b4860qds.c create mode 100644 board/freescale/b4860qds/law.c create mode 100644 board/freescale/b4860qds/pci.c create mode 100644 board/freescale/b4860qds/tlb.c create mode 100644 doc/README.b4860qds create mode 100644 include/configs/B4860QDS.h
diff --git a/board/freescale/b4860qds/Makefile b/board/freescale/b4860qds/Makefile new file mode 100644 index 0000000..06018f4 --- /dev/null +++ b/board/freescale/b4860qds/Makefile @@ -0,0 +1,54 @@ +# +# Copyright 2012 Freescale Semiconductor, Inc. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += $(BOARD).o +COBJS-y += ddr.o +COBJS-$(CONFIG_B4860QDS)+= eth_b4860qds.o +COBJS-$(CONFIG_PCI) += pci.o +COBJS-y += law.o +COBJS-y += tlb.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS)) + +clean: + rm -f $(OBJS) $(SOBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/freescale/b4860qds/b4860qds.c b/board/freescale/b4860qds/b4860qds.c new file mode 100644 index 0000000..91e0d34 --- /dev/null +++ b/board/freescale/b4860qds/b4860qds.c @@ -0,0 +1,444 @@ +/* + * Copyright 2011-2012 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <i2c.h> +#include <netdev.h> +#include <linux/compiler.h> +#include <asm/mmu.h> +#include <asm/processor.h> +#include <asm/cache.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_law.h> +#include <asm/fsl_serdes.h> +#include <asm/fsl_portals.h> +#include <asm/fsl_liodn.h> +#include <fm_eth.h> + +#include "../common/qixis.h" +#include "../common/vsc3316_3308.h" +#include "b4860qds.h" +#include "b4860qds_qixis.h" +#include "b4860qds_crossbar_con.h" + +#define CLK_MUX_SEL_MASK 0x4 +#define ETH_PHY_CLK_OUT 0x4 + +DECLARE_GLOBAL_DATA_PTR; + +int checkboard(void) +{ + u8 sw; + struct cpu_type *cpu = gd->cpu; + ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; + unsigned int i; + static const char *const freq[] = {"100", "125", "156.25", "161.13", + "122.88", "122.88", "122.88"}; + int clock; + + printf("Board: %sDS, ", cpu->name); + printf("Sys ID: 0x%02x, Sys Ver: 0x%02x\nFPGA Rev: 0x%02x, ", + QIXIS_READ(id), QIXIS_READ(arch), QIXIS_READ(scver)); + + printf("FPGA Ver: "); + for (i = 16; i < 34; i++) { + QIXIS_WRITE(tagdata, i); + printf("%c", QIXIS_READ(tagdata)); + } + + sw = QIXIS_READ(brdcfg[0]); + sw = (sw & QIXIS_LBMAP_MASK) >> QIXIS_LBMAP_SHIFT; + + printf(", "); + if (sw < 0x8) + printf("vBank: %d\n", sw); + else if (sw >= 0x8 && sw <= 0xE) + puts("NAND\n"); + else + printf("invalid setting of SW%u\n", QIXIS_LBMAP_SWITCH); + + /* Display the RCW, so that no one gets confused as to what RCW + * we're actually using for this boot. + */ + puts("Reset Configuration Word (RCW):"); + for (i = 0; i < ARRAY_SIZE(gur->rcwsr); i++) { + u32 rcw = in_be32(&gur->rcwsr[i]); + + if ((i % 4) == 0) + printf("\n %08x:", i * 4); + printf(" %08x", rcw); + } + puts("\n"); + + /* + * Display the actual SERDES reference clocks as configured by the + * dip switches on the board. Note that the SWx registers could + * technically be set to force the reference clocks to match the + * values that the SERDES expects (or vice versa). For now, however, + * we just display both values and hope the user notices when they + * don't match. + */ + puts("SERDES Reference Clocks: "); + sw = QIXIS_READ(brdcfg[2]); + clock = (sw >> 5) & 7; + printf("Bank1=%sMHz ", freq[clock]); + sw = QIXIS_READ(brdcfg[4]); + clock = (sw >> 6) & 3; + printf("Bank2=%sMHz\n", freq[clock]); + + return 0; +} + +int select_i2c_ch_pca(u8 ch) +{ + int ret; + + /* Selecting proper channel via PCA*/ + ret = i2c_write(I2C_MUX_PCA_ADDR, 0x0, 1, &ch, 1); + if (ret) { + printf("PCA: failed to select proper channel.\n"); + return ret; + } + + return 0; +} + +int configure_vsc3316_3308(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + unsigned int num_vsc16_con, num_vsc08_con; + u32 serdes1_prtcl, serdes2_prtcl; + int ret; + + serdes1_prtcl = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS1_PRTCL; + if (!serdes1_prtcl) { + printf("SERDES1 is not enabled\n"); + return 0; + } + serdes1_prtcl >>= FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT; + debug("Using SERDES1 Protocol: 0x%x:\n", serdes1_prtcl); + + serdes2_prtcl = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS2_PRTCL; + if (!serdes2_prtcl) { + printf("SERDES2 is not enabled\n"); + return 0; + } + serdes2_prtcl >>= FSL_CORENET2_RCWSR4_SRDS2_PRTCL_SHIFT; + debug("Using SERDES2 Protocol: 0x%x:\n", serdes2_prtcl); + + switch (serdes1_prtcl) { + case 0x2a: + /* + * Configuration: + * SERDES: 1 + * Lanes: A,B: SGMII + * Lanes: C,D,E,F,G,H: CPRI + */ + debug("Configuring crossbar to use onboard SGMII PHYs:" + "srds_prctl:%x\n", serdes1_prtcl); + num_vsc16_con = NUM_CON_VSC3316; + /* Configure VSC3316 crossbar switch */ + ret = select_i2c_ch_pca(I2C_CH_VSC3316); + if (!ret) { + ret = vsc3316_config(VSC3316_TX_ADDRESS, + vsc16_tx_sgmii, num_vsc16_con); + if (ret) + return ret; + ret = vsc3316_config(VSC3316_RX_ADDRESS, + vsc16_rx_sgmii, num_vsc16_con); + if (ret) + return ret; + } else { + return ret; + } + break; + + + case 0x3E: /* AMC */ + num_vsc16_con = NUM_CON_VSC3316; + /* Configure VSC3316 crossbar switch */ + ret = select_i2c_ch_pca(I2C_CH_VSC3316); + if (!ret) { + ret = vsc3316_config(VSC3316_TX_ADDRESS, + vsc16_tx_amc, num_vsc16_con); + if (ret) + return ret; + ret = vsc3316_config(VSC3316_RX_ADDRESS, + vsc16_rx_amc, num_vsc16_con); + if (ret) + return ret; + } else { + return ret; + } + break; + default: + printf("WARNING:VSC crossbars programming not supported for:%x" + " SerDes1 Protocol.\n", serdes1_prtcl); + return -1; + } + + switch (serdes2_prtcl) { + case 0x9E: + case 0x9A: + num_vsc08_con = NUM_CON_VSC3308; + /* Configure VSC3308 crossbar switch */ + ret = select_i2c_ch_pca(I2C_CH_VSC3308); + if (!ret) { + ret = vsc3308_config(VSC3308_TX_ADDRESS, + vsc08_tx_amc, num_vsc08_con); + if (ret) + return ret; + ret = vsc3308_config(VSC3308_RX_ADDRESS, + vsc08_rx_amc, num_vsc08_con); + if (ret) + return ret; + } else { + return ret; + } + break; + case 0x4E: + num_vsc08_con = NUM_CON_VSC3308; + /* Configure VSC3308 crossbar switch */ + ret = select_i2c_ch_pca(I2C_CH_VSC3308); + if (!ret) { + ret = vsc3308_config(VSC3308_TX_ADDRESS, + vsc08_tx_sfp, num_vsc08_con); + if (ret) + return ret; + ret = vsc3308_config(VSC3308_RX_ADDRESS, + vsc08_rx_sfp, num_vsc08_con); + if (ret) + return ret; + } else { + return ret; + } + break; + default: + printf("WARNING:VSC crossbars programming not supported for: %x" + " SerDes2 Protocol.\n", serdes2_prtcl); + return -1; + } + + return 0; +} + +int board_early_init_r(void) +{ + const unsigned int flashbase = CONFIG_SYS_FLASH_BASE; + const u8 flash_esel = find_tlb_idx((void *)flashbase, 1); + + /* + * Remap Boot flash + PROMJET region to caching-inhibited + * so that flash can be erased properly. + */ + + /* Flush d-cache and invalidate i-cache of any FLASH data */ + flush_dcache(); + invalidate_icache(); + + /* invalidate existing TLB entry for flash + promjet */ + disable_tlb(flash_esel); + + set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, flash_esel, BOOKE_PAGESZ_256M, 1); + + set_liodns(); +#ifdef CONFIG_SYS_DPAA_QBMAN + setup_portals(); +#endif + + /* Configure VSC3316 and VSC3308 crossbar switches */ + if (configure_vsc3316_3308()) + printf("VSC:failed to configure VSC3316/3308.\n"); + else + printf("VSC:VSC3316/3308 successfully configured.\n"); + + select_i2c_ch_pca(I2C_CH_DEFAULT); + + return 0; +} + +unsigned long get_board_sys_clk(void) +{ + u8 sysclk_conf = QIXIS_READ(brdcfg[1]); + + switch (sysclk_conf & 0x0F) { + case QIXIS_SYSCLK_83: + return 83333333; + case QIXIS_SYSCLK_100: + return 100000000; + case QIXIS_SYSCLK_125: + return 125000000; + case QIXIS_SYSCLK_133: + return 133333333; + case QIXIS_SYSCLK_150: + return 150000000; + case QIXIS_SYSCLK_160: + return 160000000; + case QIXIS_SYSCLK_166: + return 166666666; + } + return 66666666; +} + +unsigned long get_board_ddr_clk(void) +{ + u8 ddrclk_conf = QIXIS_READ(brdcfg[1]); + + switch ((ddrclk_conf & 0x30) >> 4) { + case QIXIS_DDRCLK_100: + return 100000000; + case QIXIS_DDRCLK_125: + return 125000000; + case QIXIS_DDRCLK_133: + return 133333333; + } + return 66666666; +} + +static int serdes_refclock(u8 sw, u8 sdclk) +{ + unsigned int clock; + u32 ret = -1; + u8 brdcfg4; + + if (sdclk == 1) { + brdcfg4 = QIXIS_READ(brdcfg[4]); + if ((brdcfg4 & CLK_MUX_SEL_MASK) == ETH_PHY_CLK_OUT) + return SRDS_PLLCR0_RFCK_SEL_125; + else + clock = (sw >> 5) & 7; + } else + clock = (sw >> 6) & 3; + + switch (clock) { + case 0: + ret = SRDS_PLLCR0_RFCK_SEL_100; + break; + case 1: + ret = SRDS_PLLCR0_RFCK_SEL_125; + break; + case 2: + ret = SRDS_PLLCR0_RFCK_SEL_156_25; + break; + case 3: + ret = SRDS_PLLCR0_RFCK_SEL_161_13; + break; + case 4: + case 5: + case 6: + ret = SRDS_PLLCR0_RFCK_SEL_122_88; + break; + default: + ret = -1; + break; + } + + return ret; +} + +static const char *serdes_clock_to_string(u32 clock) +{ + switch (clock) { + case SRDS_PLLCR0_RFCK_SEL_100: + return "100"; + case SRDS_PLLCR0_RFCK_SEL_125: + return "125"; + case SRDS_PLLCR0_RFCK_SEL_156_25: + return "156.25"; + case SRDS_PLLCR0_RFCK_SEL_161_13: + return "161.13"; + default: + return "122.88"; + } +} + +#define NUM_SRDS_BANKS 2 + +int misc_init_r(void) +{ + u8 sw; + serdes_corenet_t *srds_regs = + (void *)CONFIG_SYS_FSL_CORENET_SERDES_ADDR; + u32 actual[NUM_SRDS_BANKS]; + unsigned int i; + int clock; + + sw = QIXIS_READ(brdcfg[2]); + clock = serdes_refclock(sw, 1); + if (clock >= 0) + actual[0] = clock; + else + printf("Warning: SDREFCLK1 switch setting is unsupported\n"); + + sw = QIXIS_READ(brdcfg[4]); + clock = serdes_refclock(sw, 2); + if (clock >= 0) + actual[1] = clock; + else + printf("Warning: SDREFCLK2 switch setting unsupported\n"); + + for (i = 0; i < NUM_SRDS_BANKS; i++) { + u32 pllcr0 = srds_regs->bank[i].pllcr0; + u32 expected = pllcr0 & SRDS_PLLCR0_RFCK_SEL_MASK; + if (expected != actual[i]) { + printf("Warning: SERDES bank %u expects reference clock" + " %sMHz, but actual is %sMHz\n", i + 1, + serdes_clock_to_string(expected), + serdes_clock_to_string(actual[i])); + } + } + + return 0; +} + +void ft_board_setup(void *blob, bd_t *bd) +{ + phys_addr_t base; + phys_size_t size; + + ft_cpu_setup(blob, bd); + + base = getenv_bootm_low(); + size = getenv_bootm_size(); + + fdt_fixup_memory(blob, (u64)base, (u64)size); + +#ifdef CONFIG_PCI + pci_of_setup(blob, bd); +#endif + + fdt_fixup_liodn(blob); + +#ifdef CONFIG_HAS_FSL_DR_USB + fdt_fixup_dr_usb(blob, bd); +#endif + +#ifdef CONFIG_SYS_DPAA_FMAN + fdt_fixup_fman_ethernet(blob); + fdt_fixup_board_enet(blob); +#endif +} diff --git a/board/freescale/b4860qds/b4860qds.h b/board/freescale/b4860qds/b4860qds.h new file mode 100644 index 0000000..f290f3c --- /dev/null +++ b/board/freescale/b4860qds/b4860qds.h @@ -0,0 +1,26 @@ +/* + * Copyright 2011-2012 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CORENET_DS_H__ +#define __CORENET_DS_H__ + +void fdt_fixup_board_enet(void *blob); +void pci_of_setup(void *blob, bd_t *bd); + +#endif diff --git a/board/freescale/b4860qds/b4860qds_crossbar_con.h b/board/freescale/b4860qds/b4860qds_crossbar_con.h new file mode 100644 index 0000000..f23929b --- /dev/null +++ b/board/freescale/b4860qds/b4860qds_crossbar_con.h @@ -0,0 +1,58 @@ +/* + * Copyright 2012 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CROSSBAR_CONNECTIONS_H__ +#define __CROSSBAR_CONNECTIONS_H__ + +#define NUM_CON_VSC3316 8 +#define NUM_CON_VSC3308 4 + +static const int8_t vsc16_tx_amc[8][2] = { {15, 3}, {0, 2}, {7, 4}, {9, 10}, + {5, 11}, {4, 5}, {2, 6}, {12, 9} }; + +static const int8_t vsc16_tx_sfp[8][2] = { {15, 8}, {0, 0}, {7, 7}, {9, 1}, + {5, 15}, {4, 14}, {2, 12}, {12, 13} }; + +static const int8_t vsc16_tx_sgmii[8][2] = { {2, 14}, {12, 15}, {-1, -1}, + {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1} }; + +static const int8_t vsc16_tx_aurora[8][2] = { {2, 13}, {12, 12}, {-1, -1}, + {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1} }; + +static const int8_t vsc16_rx_amc[8][2] = { {3, 15}, {2, 1}, {4, 8}, {10, 9}, + {11, 11}, {5, 10}, {6, 3}, {9, 12} }; + +static const int8_t vsc16_rx_sfp[8][2] = { {0, 15}, {8, 1}, {1, 8}, {7, 9}, + {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1} }; + +static const int8_t vsc16_rx_sgmii[8][2] = { {14, 3}, {15, 12}, {-1, -1}, + {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1} }; + +static const int8_t vsc16_rx_aurora[8][2] = { {12, 3}, {13, 12}, {-1, -1}, + {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1} }; + +static const int8_t vsc08_tx_amc[4][2] = { {2, 2}, {3, 3}, {7, 4}, {1, 5} }; + +static const int8_t vsc08_tx_sfp[4][2] = { {2, 6}, {3, 7}, {7, 1}, {1, 0} }; + +static const int8_t vsc08_rx_amc[4][2] = { {2, 3}, {3, 4}, {4, 7}, {5, 1} }; + +static const int8_t vsc08_rx_sfp[4][2] = { {6, 3}, {7, 4}, {1, 7}, {0, 1} }; + +#endif diff --git a/board/freescale/b4860qds/b4860qds_qixis.h b/board/freescale/b4860qds/b4860qds_qixis.h new file mode 100644 index 0000000..175810d --- /dev/null +++ b/board/freescale/b4860qds/b4860qds_qixis.h @@ -0,0 +1,47 @@ +/* + * Copyright 2012 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __B4860QDS_QIXIS_H__ +#define __B4860QDS_QIXIS_H__ + +/* Definitions of QIXIS Registers for B4860QDS */ + +/* BRDCFG4[4:7]] select EC1 and EC2 as a pair */ +#define BRDCFG4_EMISEL_MASK 0xE0 +#define BRDCFG4_EMISEL_SHIFT 5 + +/* SYSCLK */ +#define QIXIS_SYSCLK_66 0x0 +#define QIXIS_SYSCLK_83 0x1 +#define QIXIS_SYSCLK_100 0x2 +#define QIXIS_SYSCLK_125 0x3 +#define QIXIS_SYSCLK_133 0x4 +#define QIXIS_SYSCLK_150 0x5 +#define QIXIS_SYSCLK_160 0x6 +#define QIXIS_SYSCLK_166 0x7 + +/* DDRCLK */ +#define QIXIS_DDRCLK_66 0x0 +#define QIXIS_DDRCLK_100 0x1 +#define QIXIS_DDRCLK_125 0x2 +#define QIXIS_DDRCLK_133 0x3 + +#define QIXIS_SRDS1CLK_122 0x5a +#define QIXIS_SRDS1CLK_125 0x5e +#endif diff --git a/board/freescale/b4860qds/ddr.c b/board/freescale/b4860qds/ddr.c new file mode 100644 index 0000000..dd4c0f6 --- /dev/null +++ b/board/freescale/b4860qds/ddr.c @@ -0,0 +1,190 @@ +/* + * Copyright 2011-2012 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * Version 2 or later as published by the Free Software Foundation. + */ + +#include <common.h> +#include <i2c.h> +#include <hwconfig.h> +#include <asm/mmu.h> +#include <asm/fsl_ddr_sdram.h> +#include <asm/fsl_ddr_dimm_params.h> +#include <asm/fsl_law.h> + +DECLARE_GLOBAL_DATA_PTR; + +dimm_params_t ddr_raw_timing = { + .n_ranks = 2, + .rank_density = 2147483648u, + .capacity = 4294967296u, + .primary_sdram_width = 64, + .ec_sdram_width = 8, + .registered_dimm = 0, + .mirrored_dimm = 1, + .n_row_addr = 15, + .n_col_addr = 10, + .n_banks_per_sdram_device = 8, + .edc_config = 2, /* ECC */ + .burst_lengths_bitmask = 0x0c, + + .tCKmin_X_ps = 1071, + .caslat_X = 0x2fe << 4, /* 5,6,7,8,9,10,11,13 */ + .tAA_ps = 13910, + .tWR_ps = 15000, + .tRCD_ps = 13910, + .tRRD_ps = 6000, + .tRP_ps = 13910, + .tRAS_ps = 34000, + .tRC_ps = 48910, + .tRFC_ps = 260000, + .tWTR_ps = 7500, + .tRTP_ps = 7500, + .refresh_rate_ps = 7800000, + .tFAW_ps = 35000, +}; + +int fsl_ddr_get_dimm_params(dimm_params_t *pdimm, + unsigned int controller_number, + unsigned int dimm_number) +{ + const char dimm_model[] = "RAW timing DDR"; + + if ((controller_number == 0) && (dimm_number == 0)) { + memcpy(pdimm, &ddr_raw_timing, sizeof(dimm_params_t)); + memset(pdimm->mpart, 0, sizeof(pdimm->mpart)); + memcpy(pdimm->mpart, dimm_model, sizeof(dimm_model) - 1); + } + + return 0; +} + +struct board_specific_parameters { + u32 n_ranks; + u32 datarate_mhz_high; + u32 clk_adjust; + u32 wrlvl_start; + u32 wrlvl_ctl_2; + u32 wrlvl_ctl_3; + u32 cpo; + u32 write_data_delay; + u32 force_2T; +}; + +/* + * This table contains all valid speeds we want to override with board + * specific parameters. datarate_mhz_high values need to be in ascending order + * for each n_ranks group. + */ +static const struct board_specific_parameters udimm0[] = { + /* + * memory controller 0 + * num| hi| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T + * ranks| mhz|adjst| start | ctl2 | ctl3 | |delay | + */ + {2, 1350, 4, 7, 0x09080807, 0x07060607, 0xff, 2, 0}, + {2, 1666, 4, 7, 0x09080806, 0x06050607, 0xff, 2, 0}, + {2, 1900, 3, 7, 0x08070706, 0x06040507, 0xff, 2, 0}, + {1, 1350, 4, 7, 0x09080807, 0x07060607, 0xff, 2, 0}, + {1, 1700, 4, 7, 0x09080806, 0x06050607, 0xff, 2, 0}, + {1, 1900, 3, 7, 0x08070706, 0x06040507, 0xff, 2, 0}, + {} +}; + +static const struct board_specific_parameters *udimms[] = { + udimm0, +}; + +void fsl_ddr_board_options(memctl_options_t *popts, + dimm_params_t *pdimm, + unsigned int ctrl_num) +{ + const struct board_specific_parameters *pbsp, *pbsp_highest = NULL; + ulong ddr_freq; + + if (ctrl_num > 2) { + printf("Not supported controller number %d\n", ctrl_num); + return; + } + if (!pdimm->n_ranks) + return; + + pbsp = udimms[0]; + + + /* Get clk_adjust, cpo, write_data_delay,2T, according to the board ddr + * freqency and n_banks specified in board_specific_parameters table. + */ + ddr_freq = get_ddr_freq(0) / 1000000; + while (pbsp->datarate_mhz_high) { + if (pbsp->n_ranks == pdimm->n_ranks) { + if (ddr_freq <= pbsp->datarate_mhz_high) { + popts->cpo_override = pbsp->cpo; + popts->write_data_delay = + pbsp->write_data_delay; + popts->clk_adjust = pbsp->clk_adjust; + popts->wrlvl_start = pbsp->wrlvl_start; + popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; + popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; + popts->twoT_en = pbsp->force_2T; + goto found; + } + pbsp_highest = pbsp; + } + pbsp++; + } + + if (pbsp_highest) { + printf("Error: board specific timing not found " + "for data rate %lu MT/s\n" + "Trying to use the highest speed (%u) parameters\n", + ddr_freq, pbsp_highest->datarate_mhz_high); + popts->cpo_override = pbsp_highest->cpo; + popts->write_data_delay = pbsp_highest->write_data_delay; + popts->clk_adjust = pbsp_highest->clk_adjust; + popts->wrlvl_start = pbsp_highest->wrlvl_start; + popts->twoT_en = pbsp_highest->force_2T; + } else { + panic("DIMM is not supported by this board"); + } +found: + /* + * Factors to consider for half-strength driver enable: + * - number of DIMMs installed + */ + popts->half_strength_driver_enable = 0; + /* + * Write leveling override + */ + popts->wrlvl_override = 1; + popts->wrlvl_sample = 0xf; + + /* + * Rtt and Rtt_WR override + */ + popts->rtt_override = 0; + + /* Enable ZQ calibration */ + popts->zq_en = 1; + + /* DHC_EN =1, ODT = 75 Ohm */ + popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_75ohm); + popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_75ohm); +} + +phys_size_t initdram(int board_type) +{ + phys_size_t dram_size; + + puts("Initializing....using SPD\n"); + + dram_size = fsl_ddr_sdram(); + + dram_size = setup_ddr_tlbs(dram_size / 0x100000); + dram_size *= 0x100000; + + puts(" DDR: "); + return dram_size; +} diff --git a/board/freescale/b4860qds/eth_b4860qds.c b/board/freescale/b4860qds/eth_b4860qds.c new file mode 100644 index 0000000..d87cb15 --- /dev/null +++ b/board/freescale/b4860qds/eth_b4860qds.c @@ -0,0 +1,287 @@ +/* + * Copyright 2012 Freescale Semiconductor, Inc. + * Author: Sandeep Kumar Singh sandeep@freescale.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* This file is based on board/freescale/corenet_ds/eth_superhydra.c */ + +/* + * This file handles the board muxing between the Fman Ethernet MACs and + * the RGMII/SGMII/XGMII PHYs on a Freescale B4860 "Centaur". The SGMII + * PHYs are the two on-board 1Gb ports. There are no RGMII PHY on board. + * The 10Gb XGMII PHY is provided via the XAUI riser card. There is only + * one Fman device on B4860. The SERDES configuration is used to determine + * where the SGMII and XAUI cards exist, and also which Fman MACs are routed + * to which PHYs. So for a given Fman MAC, there is one and only PHY it + * connects to. MACs cannot be routed to PHYs dynamically. This configuration + * is done at boot time by reading SERDES protocol from RCW. + */ + +#include <common.h> +#include <netdev.h> +#include <asm/fsl_serdes.h> +#include <fm_eth.h> +#include <fsl_mdio.h> +#include <malloc.h> +#include <fdt_support.h> +#include <asm/fsl_dtsec.h> + +#include "../common/ngpixis.h" +#include "../common/fman.h" +#include "../common/qixis.h" +#include "b4860qds_qixis.h" + +#define EMI_NONE 0xFFFFFFFF + +#ifdef CONFIG_FMAN_ENET + +/* + * Mapping of all 16 SERDES lanes to board slots. A value n(>0) will mean that + * lane at index is mapped to slot number n. A value of '0' will mean + * that the mapping must be determined dynamically, or that the lane maps to + * something other than a board slot + */ +static u8 lane_to_slot[] = { + 0, 0, 0, 0, + 0, 0, 0, 0, + 1, 1, 1, 1, + 0, 0, 0, 0 +}; + +/* + * This function initializes the lane_to_slot[] array. It reads RCW to check + * if Serdes2{E,F,G,H} is configured as slot 2 or as SFP and initializes + * lane_to_slot[] accordingly + */ +static void initialize_lane_to_slot(void) +{ + unsigned int serdes2_prtcl; + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + serdes2_prtcl = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS2_PRTCL; + serdes2_prtcl >>= FSL_CORENET2_RCWSR4_SRDS2_PRTCL_SHIFT; + debug("Initializing lane to slot: Serdes2 protocol: %x\n", + serdes2_prtcl); + + switch (serdes2_prtcl) { + case 0x18: + /* + * Configuration: + * SERDES: 2 + * Lanes: A,B,C,D: SGMII + * Lanes: E,F: Aur + * Lanes: G,H: SRIO + */ + case 0x91: + /* + * Configuration: + * SERDES: 2 + * Lanes: A,B: SGMII + * Lanes: C,D: SRIO2 + * Lanes: E,F,G,H: XAUI2 + */ + case 0x93: + /* + * Configuration: + * SERDES: 2 + * Lanes: A,B,C,D: SGMII + * Lanes: E,F,G,H: XAUI2 + */ + case 0x98: + /* + * Configuration: + * SERDES: 2 + * Lanes: A,B,C,D: XAUI2 + * Lanes: E,F,G,H: XAUI2 + */ + case 0x9a: + /* + * Configuration: + * SERDES: 2 + * Lanes: A,B: PCI + * Lanes: C,D: SGMII + * Lanes: E,F,G,H: XAUI2 + */ + case 0x9e: + /* + * Configuration: + * SERDES: 2 + * Lanes: A,B,C,D: PCI + * Lanes: E,F,G,H: XAUI2 + */ + case 0xc2: + /* + * Configuration: + * SERDES: 2 + * Lanes: A,B: SGMII + * Lanes: C,D: SRIO2 + * Lanes: E,F,G,H: XAUI2 + */ + lane_to_slot[12] = 2; + lane_to_slot[13] = lane_to_slot[12]; + lane_to_slot[14] = lane_to_slot[12]; + lane_to_slot[15] = lane_to_slot[12]; + break; + + default: + printf("Fman: Unsupported SerDes2 Protocol 0x%02x\n", + serdes2_prtcl); + break; + } + return; +} + +#endif /* #ifdef CONFIG_FMAN_ENET */ + +int board_eth_init(bd_t *bis) +{ +#ifdef CONFIG_FMAN_ENET + struct memac_mdio_info memac_mdio_info; + struct memac_mdio_info tg_memac_mdio_info; + unsigned int i; + unsigned int serdes1_prtcl, serdes2_prtcl; + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + serdes1_prtcl = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS1_PRTCL; + if (!serdes1_prtcl) { + printf("SERDES1 is not enabled\n"); + return 0; + } + serdes1_prtcl >>= FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT; + debug("Using SERDES1 Protocol: 0x%x:\n", serdes1_prtcl); + + serdes2_prtcl = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS2_PRTCL; + if (!serdes2_prtcl) { + printf("SERDES2 is not enabled\n"); + return 0; + } + serdes2_prtcl >>= FSL_CORENET2_RCWSR4_SRDS2_PRTCL_SHIFT; + debug("Using SERDES2 Protocol: 0x%x:\n", serdes2_prtcl); + + printf("Initializing Fman\n"); + + initialize_lane_to_slot(); + + memac_mdio_info.regs = + (struct memac_mdio_controller *)CONFIG_SYS_FM1_DTSEC_MDIO_ADDR; + memac_mdio_info.name = DEFAULT_FM_MDIO_NAME; + + /* Register the real 1G MDIO bus */ + fm_memac_mdio_init(bis, &memac_mdio_info); + + tg_memac_mdio_info.regs = + (struct memac_mdio_controller *)CONFIG_SYS_FM1_TGEC_MDIO_ADDR; + tg_memac_mdio_info.name = DEFAULT_FM_TGEC_MDIO_NAME; + + /* Register the real 10G MDIO bus */ + fm_memac_mdio_init(bis, &tg_memac_mdio_info); + + /* + * Program the two on board DTSEC PHY addresses assuming that they are + * all SGMII. RGMII is not supported on this board. Setting SGMII 5 and + * 6 to on board SGMII phys + */ + fm_info_set_phy_address(FM1_DTSEC5, CONFIG_SYS_FM1_DTSEC5_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC6, CONFIG_SYS_FM1_DTSEC6_PHY_ADDR); + + switch (serdes1_prtcl) { + case 0x2a: + /* Serdes 1: A-B SGMII, Configuring DTSEC 5 and 6 */ + debug("Setting phy addresses for FM1_DTSEC5: %x and" + "FM1_DTSEC6: %x\n", CONFIG_SYS_FM1_DTSEC5_PHY_ADDR, + CONFIG_SYS_FM1_DTSEC6_PHY_ADDR); + /* Fixing Serdes clock by programming FPGA register */ + QIXIS_WRITE(brdcfg[4], QIXIS_SRDS1CLK_125); + fm_info_set_phy_address(FM1_DTSEC5, + CONFIG_SYS_FM1_DTSEC5_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC6, + CONFIG_SYS_FM1_DTSEC6_PHY_ADDR); + break; + default: + printf("Fman: Unsupported SerDes1 Protocol 0x%02x\n", + serdes1_prtcl); + break; + } + switch (serdes2_prtcl) { + case 0x18: + debug("Setting phy addresses on SGMII Riser card for" + "FM1_DTSEC1: %x\n", + CONFIG_SYS_FM1_DTSEC1_RISER_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC1, + CONFIG_SYS_FM1_DTSEC1_RISER_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC2, + CONFIG_SYS_FM1_DTSEC2_RISER_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC3, + CONFIG_SYS_FM1_DTSEC3_RISER_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC4, + CONFIG_SYS_FM1_DTSEC4_RISER_PHY_ADDR); + break; + + default: + printf("Fman: Unsupported SerDes2 Protocol 0x%02x\n", + serdes2_prtcl); + break; + } + + for (i = FM1_DTSEC1; i < FM1_DTSEC1 + CONFIG_SYS_NUM_FM1_DTSEC; i++) { + int idx = i - FM1_DTSEC1; + + switch (fm_info_get_enet_if(i)) { + case PHY_INTERFACE_MODE_SGMII: + fm_info_set_mdio(i, + miiphy_get_dev_by_name(DEFAULT_FM_MDIO_NAME)); + break; + case PHY_INTERFACE_MODE_NONE: + fm_info_set_phy_address(i, 0); + break; + default: + printf("Fman1: DTSEC%u set to unknown interface %i\n", + idx + 1, fm_info_get_enet_if(i)); + fm_info_set_phy_address(i, 0); + break; + } + } + + cpu_eth_init(bis); +#endif + + return pci_eth_init(bis); +} + +/* + * tbd:Fixup function not doing any fixup right now. + */ + +void fdt_fixup_board_enet(void *fdt) +{ + int i, idx; + + for (i = FM1_DTSEC1; i < FM1_DTSEC1 + CONFIG_SYS_NUM_FM1_DTSEC; i++) { + idx = i - FM1_DTSEC1; + switch (fm_info_get_enet_if(i)) { + case PHY_INTERFACE_MODE_SGMII: + break; + default: + break; + } + } +} diff --git a/board/freescale/b4860qds/law.c b/board/freescale/b4860qds/law.c new file mode 100644 index 0000000..bfdd3f5 --- /dev/null +++ b/board/freescale/b4860qds/law.c @@ -0,0 +1,44 @@ +/* + * Copyright 2011-2012 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_law.h> +#include <asm/mmu.h> + +struct law_entry law_table[] = { + SET_LAW(CONFIG_SYS_FLASH_BASE_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_IFC), +#ifdef CONFIG_SYS_BMAN_MEM_PHYS + SET_LAW(CONFIG_SYS_BMAN_MEM_PHYS, LAW_SIZE_32M, LAW_TRGT_IF_BMAN), +#endif +#ifdef CONFIG_SYS_QMAN_MEM_PHYS + SET_LAW(CONFIG_SYS_QMAN_MEM_PHYS, LAW_SIZE_32M, LAW_TRGT_IF_QMAN), +#endif + SET_LAW(QIXIS_BASE_PHYS, LAW_SIZE_4K, LAW_TRGT_IF_IFC), +#ifdef CONFIG_SYS_DCSRBAR_PHYS + SET_LAW(CONFIG_SYS_DCSRBAR_PHYS, LAW_SIZE_4M, LAW_TRGT_IF_DCSR), +#endif +#ifdef CONFIG_SYS_NAND_BASE_PHYS + SET_LAW(CONFIG_SYS_NAND_BASE_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_IFC), +#endif +}; + +int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/freescale/b4860qds/pci.c b/board/freescale/b4860qds/pci.c new file mode 100644 index 0000000..b130d13 --- /dev/null +++ b/board/freescale/b4860qds/pci.c @@ -0,0 +1,39 @@ +/* + * Copyright 2011-2012 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <pci.h> +#include <asm/fsl_pci.h> +#include <libfdt.h> +#include <fdt_support.h> +#include <asm/fsl_serdes.h> + +void pci_init_board(void) +{ + fsl_pcie_init_board(0); +} + +void pci_of_setup(void *blob, bd_t *bd) +{ + FT_FSL_PCI_SETUP; +} diff --git a/board/freescale/b4860qds/tlb.c b/board/freescale/b4860qds/tlb.c new file mode 100644 index 0000000..7c5d8e0 --- /dev/null +++ b/board/freescale/b4860qds/tlb.c @@ -0,0 +1,122 @@ +/* + * Copyright 2011-2012 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/mmu.h> + +struct fsl_e_tlb_entry tlb_table[] = { + /* TLB 0 - for temp stack in cache */ + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, + CONFIG_SYS_INIT_RAM_ADDR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 4 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 8 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 12 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + + /* TLB 1 */ + /* *I*** - Covers boot page */ +#if defined(CONFIG_SYS_RAMBOOT) && defined(CONFIG_SYS_INIT_L3_ADDR) + /* + * *I*G - L3SRAM. When L3 is used as 1M SRAM, the address of the + * SRAM is at 0xfff00000, it covered the 0xfffff000. + */ + SET_TLB_ENTRY(1, CONFIG_SYS_INIT_L3_ADDR, CONFIG_SYS_INIT_L3_ADDR, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 0, BOOKE_PAGESZ_1M, 1), +#else + SET_TLB_ENTRY(1, 0xfffff000, 0xfffff000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 0, BOOKE_PAGESZ_4K, 1), +#endif + + /* *I*G* - CCSRBAR */ + SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 1, BOOKE_PAGESZ_16M, 1), + + /* *I*G* - Flash, localbus */ + /* This will be changed to *I*G* after relocation to RAM. */ + SET_TLB_ENTRY(1, CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE_PHYS, + MAS3_SX|MAS3_SR, MAS2_W|MAS2_G, + 0, 2, BOOKE_PAGESZ_256M, 1), + + /* *I*G* - PCI */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_MEM_VIRT, CONFIG_SYS_PCIE1_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 3, BOOKE_PAGESZ_256M, 1), + + /* *I*G* - PCI I/O */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_IO_VIRT, CONFIG_SYS_PCIE1_IO_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 4, BOOKE_PAGESZ_64K, 1), + + /* Bman/Qman */ +#ifdef CONFIG_SYS_BMAN_MEM_PHYS + SET_TLB_ENTRY(1, CONFIG_SYS_BMAN_MEM_BASE, CONFIG_SYS_BMAN_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 5, BOOKE_PAGESZ_16M, 1), + SET_TLB_ENTRY(1, CONFIG_SYS_BMAN_MEM_BASE + 0x01000000, + CONFIG_SYS_BMAN_MEM_PHYS + 0x01000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 6, BOOKE_PAGESZ_16M, 1), +#endif +#ifdef CONFIG_SYS_QMAN_MEM_PHYS + SET_TLB_ENTRY(1, CONFIG_SYS_QMAN_MEM_BASE, CONFIG_SYS_QMAN_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 7, BOOKE_PAGESZ_16M, 1), + SET_TLB_ENTRY(1, CONFIG_SYS_QMAN_MEM_BASE + 0x01000000, + CONFIG_SYS_QMAN_MEM_PHYS + 0x01000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 8, BOOKE_PAGESZ_16M, 1), +#endif +#ifdef CONFIG_SYS_DCSRBAR_PHYS + SET_TLB_ENTRY(1, CONFIG_SYS_DCSRBAR, CONFIG_SYS_DCSRBAR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 9, BOOKE_PAGESZ_4M, 1), +#endif +#ifdef CONFIG_SYS_NAND_BASE + /* + * *I*G - NAND + * entry 14 and 15 has been used hard coded, they will be disabled + * in cpu_init_f, so we use entry 16 for nand. + */ + SET_TLB_ENTRY(1, CONFIG_SYS_NAND_BASE, CONFIG_SYS_NAND_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 10, BOOKE_PAGESZ_1M, 1), +#endif + SET_TLB_ENTRY(1, QIXIS_BASE, QIXIS_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 11, BOOKE_PAGESZ_4K, 1), + +}; + +int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/boards.cfg b/boards.cfg index 06b0ec3..b0b1edf 100644 --- a/boards.cfg +++ b/boards.cfg @@ -834,6 +834,8 @@ stxssa_4M powerpc mpc85xx stxssa stx T4240QDS powerpc mpc85xx t4qds freescale T4240QDS_SDCARD powerpc mpc85xx t4qds freescale - T4240QDS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 T4240QDS_SPIFLASH powerpc mpc85xx t4qds freescale - T4240QDS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 +B4860QDS powerpc mpc85xx b4860qds freescale +B4860QDS_NAND powerpc mpc85xx b4860qds freescale - B4860QDS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 TQM8540 powerpc mpc85xx tqm85xx tqc - TQM85xx:MPC8540,TQM8540=y,HOSTNAME=tqm8540,BOARDNAME="TQM8540" TQM8541 powerpc mpc85xx tqm85xx tqc - TQM85xx:MPC8541,TQM8541=y,HOSTNAME=tqm8541,BOARDNAME="TQM8541" TQM8548 powerpc mpc85xx tqm85xx tqc - TQM85xx:MPC8548,TQM8548=y,HOSTNAME=tqm8548,BOARDNAME="TQM8548" diff --git a/doc/README.b4860qds b/doc/README.b4860qds new file mode 100644 index 0000000..2929592 --- /dev/null +++ b/doc/README.b4860qds @@ -0,0 +1,20 @@ +Overview +-------- +The B4860QDS is a Freescale reference board that hosts the B4860 SoC (and variants). + +Memory map +---------- +The addresses in brackets are physical addresses. + +0x0_0000_0000 (0x0_0000_0000) - 0x0_7fff_ffff 2GB DDR (more than 2GB is initialized but not mapped under with TLB) +0x0_8000_0000 (0xc_0000_0000) - 0x0_8fff_ffff 512MB PCIE memory +0x0_f000_0000 (0xf_0000_0000) - 0x0_f03f_ffff 4MB DCSR +0x0_f400_0000 (0xf_f400_0000) - 0x0_f5ff_ffff 32MB BMan +0x0_f600_0000 (0xf_f500_0000) - 0x0_f7ff_ffff 32MB QMan +0x0_f800_0000 (0xf_f800_0000) - 0x0_f800_ffff 64KB PCIE IO +0x0_e000_0000 (0xf_e000_0000) - 0x0_efff_ffff 256MB NOR flash +0x0_fe00_0000 (0xf_fe00_0000) - 0x0_feff_ffff 16MB CCSR +0x0_ffdf_0000 (0xf_ffdf_0000) - 0x0_ffdf_03ff 4KB QIXIS +0x0_ffff_f000 (0x0_7fff_fff0) - 0x0_ffff_ffff 4KB Boot page translation for secondary cores + +The physical address of the last (boot page translation) varies with the actual DDR size. diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h new file mode 100644 index 0000000..64b46b2 --- /dev/null +++ b/include/configs/B4860QDS.h @@ -0,0 +1,812 @@ +/* + * Copyright 2011-2012 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * B4860 QDS board configuration file + */ +#define CONFIG_B4860QDS +#define CONFIG_PHYS_64BIT +#define CONFIG_PPC_B4860 + +#ifdef CONFIG_RAMBOOT_PBL +#define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE +#define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc +#endif + +/* High Level Configuration Options */ +#define CONFIG_BOOKE +#define CONFIG_E6500 +#define CONFIG_E500 /* BOOKE e500 family */ +#define CONFIG_E500MC /* BOOKE e500mc family */ +#define CONFIG_SYS_BOOK3E_HV /* Category E.HV supported */ +#define CONFIG_MPC85xx /* MPC85xx/PQ3 platform */ +#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ +#define CONFIG_MP /* support multiple processors */ + +#ifndef CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_TEXT_BASE 0xeff80000 +#endif + +#ifndef CONFIG_RESET_VECTOR_ADDRESS +#define CONFIG_RESET_VECTOR_ADDRESS 0xeffffffc +#endif + +#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ +#define CONFIG_SYS_NUM_CPC CONFIG_NUM_DDR_CONTROLLERS +#define CONFIG_FSL_IFC /* Enable IFC Support */ +#define CONFIG_PCI /* Enable PCI/PCIE */ +#define CONFIG_PCIE1 /* PCIE controler 1 */ +#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ +#define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */ + +#define CONFIG_SYS_SRIO +#define CONFIG_SRIO1 /* SRIO port 1 */ +#define CONFIG_SRIO2 /* SRIO port 2 */ + +#define CONFIG_FSL_LAW /* Use common FSL init code */ + +/* I2C bus multiplexer */ +#define I2C_MUX_PCA_ADDR 0x77 + +/* VSC Crossbar switches */ +#define CONFIG_VSC_CROSSBAR +#define I2C_CH_DEFAULT 0x8 +#define I2C_CH_VSC3316 0xc +#define I2C_CH_VSC3308 0xd + +#define VSC3316_TX_ADDRESS 0x70 +#define VSC3316_RX_ADDRESS 0x71 +#define VSC3308_TX_ADDRESS 0x02 +#define VSC3308_RX_ADDRESS 0x03 + +#define CONFIG_ENV_OVERWRITE + +#ifdef CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_IS_NOWHERE +#else +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE +#endif + +#ifndef CONFIG_SYS_NO_FLASH +#if defined(CONFIG_SPIFLASH) +#define CONFIG_SYS_EXTRA_ENV_RELOC +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SPI_BUS 0 +#define CONFIG_ENV_SPI_CS 0 +#define CONFIG_ENV_SPI_MAX_HZ 10000000 +#define CONFIG_ENV_SPI_MODE 0 +#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ +#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ +#define CONFIG_ENV_SECT_SIZE 0x10000 +#elif defined(CONFIG_SDCARD) +#define CONFIG_SYS_EXTRA_ENV_RELOC +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_OFFSET (512 * 1097) +#elif defined(CONFIG_NAND) +#define CONFIG_SYS_EXTRA_ENV_RELOC +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE +#define CONFIG_ENV_OFFSET (5 * CONFIG_SYS_NAND_BLOCK_SIZE) +#else +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ +#endif +#else /* CONFIG_SYS_NO_FLASH */ +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ +#endif + +#ifndef __ASSEMBLY__ +unsigned long get_board_sys_clk(void); +unsigned long get_board_ddr_clk(void); +#endif +#define CONFIG_SYS_CLK_FREQ get_board_sys_clk() /* sysclk for MPC85xx */ +#define CONFIG_DDR_CLK_FREQ get_board_ddr_clk() + +/* + * These can be toggled for performance analysis, otherwise use default. + */ +#define CONFIG_SYS_CACHE_STASHING +#define CONFIG_BTB /* toggle branch predition */ +#define CONFIG_DDR_ECC +#ifdef CONFIG_DDR_ECC +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER +#define CONFIG_MEM_INIT_VALUE 0xdeadbeef +#endif + +#define CONFIG_ENABLE_36BIT_PHYS + +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_ADDR_MAP +#define CONFIG_SYS_NUM_ADDR_MAP 64 /* number of TLB1 entries */ +#endif + +#if 0 +#define CONFIG_POST CONFIG_SYS_POST_MEMORY /* test POST memory test */ +#endif +#define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0x00400000 +#define CONFIG_SYS_ALT_MEMTEST +#define CONFIG_PANIC_HANG /* do not reset board on panic */ + +/* + * Config the L3 Cache as L3 SRAM + */ +#define CONFIG_SYS_INIT_L3_ADDR CONFIG_RAMBOOT_TEXT_BASE + +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_DCSRBAR 0xf0000000 +#define CONFIG_SYS_DCSRBAR_PHYS 0xf00000000ull +#endif + +/* EEPROM */ +#define CONFIG_SYS_I2C_EEPROM_NXID +#define CONFIG_SYS_EEPROM_BUS_NUM 0 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x57 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 + +/* + * DDR Setup + */ +#define CONFIG_VERY_BIG_RAM +#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE + +/* CONFIG_NUM_DDR_CONTROLLERS is defined in include/asm/config_mpc85xx.h */ +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +#define CONFIG_CHIP_SELECTS_PER_CTRL (4 * CONFIG_DIMM_SLOTS_PER_CTLR) + +#define CONFIG_DDR_SPD +#define CONFIG_SYS_DDR_RAW_TIMING +#define CONFIG_FSL_DDR3 + +#define CONFIG_SYS_SPD_BUS_NUM 0 +#define SPD_EEPROM_ADDRESS1 0x51 +#define SPD_EEPROM_ADDRESS2 0x53 + +#define SPD_EEPROM_ADDRESS SPD_EEPROM_ADDRESS1 +#define CONFIG_SYS_SDRAM_SIZE 2048 /* for fixed parameter use */ + +/* + * IFC Definitions + */ +#define CONFIG_SYS_FLASH_BASE 0xe0000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_FLASH_BASE_PHYS (0xf00000000ull | CONFIG_SYS_FLASH_BASE) +#else +#define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE +#endif + +#define CONFIG_SYS_NOR0_CSPR_EXT (0xf) +#define CONFIG_SYS_NOR0_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS \ + + 0x8000000) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR1_CSPR_EXT (0xf) +#define CONFIG_SYS_NOR1_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR_AMASK IFC_AMASK(128*1024*1024) +/* NOR Flash Timing Params */ +#define CONFIG_SYS_NOR_CSOR CSOR_NOR_ADM_SHIFT(4) +#define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x01) | \ + FTIM0_NOR_TEADC(0x01) | \ + FTIM0_NOR_TEAHC(0x20)) +#define CONFIG_SYS_NOR_FTIM1 (FTIM1_NOR_TACO(0x35) | \ + FTIM1_NOR_TRAD_NOR(0x1A) |\ + FTIM1_NOR_TSEQRAD_NOR(0x13)) +#define CONFIG_SYS_NOR_FTIM2 (FTIM2_NOR_TCS(0x01) | \ + FTIM2_NOR_TCH(0x0E) | \ + FTIM2_NOR_TWPH(0x0E) | \ + FTIM2_NOR_TWP(0x1c)) +#define CONFIG_SYS_NOR_FTIM3 0x0 + +#define CONFIG_SYS_FLASH_QUIET_TEST +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ + +#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS \ + + 0x8000000, CONFIG_SYS_FLASH_BASE_PHYS} + +#define CONFIG_FSL_QIXIS /* use common QIXIS code */ +#define CONFIG_FSL_QIXIS_V2 +#define QIXIS_BASE 0xffdf0000 +#ifdef CONFIG_PHYS_64BIT +#define QIXIS_BASE_PHYS (0xf00000000ull | QIXIS_BASE) +#else +#define QIXIS_BASE_PHYS QIXIS_BASE +#endif +#define QIXIS_LBMAP_SWITCH 0x01 +#define QIXIS_LBMAP_MASK 0x0f +#define QIXIS_LBMAP_SHIFT 0 +#define QIXIS_LBMAP_DFLTBANK 0x01 +#define QIXIS_LBMAP_ALTBANK 0x07 +#define QIXIS_RST_FRCE_PRST 0x01 +#define QIXIS_RCFG_CTL_UNLOCK 0x00 +#define QIXIS_RCFG_CTL_LOCK 0x10 +#define QIXIS_RCFG_CTL_WATCHDOG_ENBLE 0x08 + +#define CONFIG_SYS_CSPR3_EXT (0xf) +#define CONFIG_SYS_CSPR3 (CSPR_PHYS_ADDR(QIXIS_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 \ + | CSPR_MSEL_GPCM \ + | CSPR_V) +#define CONFIG_SYS_AMASK3 IFC_AMASK(64*1024) +#define CONFIG_SYS_CSOR3 0x0 +/* QIXIS Timing parameters for IFC CS3 */ +#define CONFIG_SYS_CS3_FTIM0 (FTIM0_GPCM_TACSE(0x0e) | \ + FTIM0_GPCM_TEADC(0x0e) | \ + FTIM0_GPCM_TEAHC(0x0e)) +#define CONFIG_SYS_CS3_FTIM1 (FTIM1_GPCM_TACO(0x0e) | \ + FTIM1_GPCM_TRAD(0x1f)) +#define CONFIG_SYS_CS3_FTIM2 (FTIM2_GPCM_TCS(0x0e) | \ + FTIM2_GPCM_TCH(0x0) | \ + FTIM2_GPCM_TWP(0x1f)) +#define CONFIG_SYS_CS3_FTIM3 0x0 + +/* NAND Flash on IFC */ +#define CONFIG_NAND_FSL_IFC +#define CONFIG_SYS_NAND_BASE 0xff800000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_NAND_BASE_PHYS (0xf00000000ull | CONFIG_SYS_NAND_BASE) +#else +#define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE +#endif + +#define CONFIG_SYS_NAND_CSPR_EXT (0xf) +#define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 /* Port Size = 8 bit */ \ + | CSPR_MSEL_NAND /* MSEL = NAND */ \ + | CSPR_V) +#define CONFIG_SYS_NAND_AMASK IFC_AMASK(64*1024) + +#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ + | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ + | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \ + | CSOR_NAND_RAL_3 /* RAL = 2Byes */ \ + | CSOR_NAND_PGS_2K /* Page Size = 2K */ \ + | CSOR_NAND_SPRZ_64/* Spare size = 64 */ \ + | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/ + +#define CONFIG_SYS_NAND_ONFI_DETECTION + +/* ONFI NAND Flash mode0 Timing Params */ +#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07) | \ + FTIM0_NAND_TWP(0x18) | \ + FTIM0_NAND_TWCHT(0x07) | \ + FTIM0_NAND_TWH(0x0a)) +#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x32) | \ + FTIM1_NAND_TWBE(0x39) | \ + FTIM1_NAND_TRR(0x0e) | \ + FTIM1_NAND_TRP(0x18)) +#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0x0f) | \ + FTIM2_NAND_TREH(0x0a) | \ + FTIM2_NAND_TWHRE(0x1e)) +#define CONFIG_SYS_NAND_FTIM3 0x0 + +#define CONFIG_SYS_NAND_DDR_LAW 11 + +#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_MTD_NAND_VERIFY_WRITE +#define CONFIG_CMD_NAND + +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) + +#if defined(CONFIG_NAND) +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3 +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK2 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NOR_FTIM3 +#else +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK2 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NAND_FTIM3 +#endif +#define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NOR1_CSPR_EXT +#define CONFIG_SYS_CSPR1 CONFIG_SYS_NOR1_CSPR +#define CONFIG_SYS_AMASK1 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR1 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NOR_FTIM3 + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE + +#if defined(CONFIG_RAMBOOT_PBL) +#define CONFIG_SYS_RAMBOOT +#endif + +#define CONFIG_BOARD_EARLY_INIT_R +#define CONFIG_MISC_INIT_R + +#define CONFIG_HWCONFIG + +/* define to use L1 as initial stack */ +#define CONFIG_L1_INIT_RAM +#define CONFIG_SYS_INIT_RAM_LOCK +#define CONFIG_SYS_INIT_RAM_ADDR 0xfdd00000 /* Initial L1 address */ +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0xf +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW 0xfe0ec000 +/* The assembler doesn't like typecast */ +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS \ + ((CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH * 1ull << 32) | \ + CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW) +#else +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS 0xfe0ec000 /* Initial L1 address */ +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0 +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW CONFIG_SYS_INIT_RAM_ADDR_PHYS +#endif +#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 + +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +#define CONFIG_SYS_MONITOR_LEN (512 * 1024) +#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) + +/* Serial Port - controlled on board with jumper J8 + * open - index 2 + * shorted - index 1 + */ +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) + +#define CONFIG_SYS_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200} + +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x11C500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x11C600) +#define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) +#define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600) +#define CONFIG_SERIAL_MULTI /* Enable both serial ports */ +#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */ + + +/* Use the HUSH parser */ +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT +#define CONFIG_OF_BOARD_SETUP +#define CONFIG_OF_STDOUT_VIA_ALIAS + +/* new uImage format support */ +#define CONFIG_FIT +#define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ + +/* I2C */ +#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ +#define CONFIG_HARD_I2C /* I2C with hardware support */ +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_I2C_CMD_TREE +#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed in Hz */ +#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_OFFSET 0x118000 +#define CONFIG_SYS_I2C2_OFFSET 0x119000 + +/* + * RTC configuration + */ +#define RTC +#define CONFIG_RTC_DS3231 1 +#define CONFIG_SYS_I2C_RTC_ADDR 0x68 + +/* + * RapidIO + */ +#define CONFIG_SYS_SRIO1_MEM_VIRT 0xa0000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_SRIO1_MEM_PHYS 0xc20000000ull +#else +#define CONFIG_SYS_SRIO1_MEM_PHYS 0xa0000000 +#endif +#define CONFIG_SYS_SRIO1_MEM_SIZE 0x10000000 /* 256M */ + +#define CONFIG_SYS_SRIO2_MEM_VIRT 0xb0000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_SRIO2_MEM_PHYS 0xc30000000ull +#else +#define CONFIG_SYS_SRIO2_MEM_PHYS 0xb0000000 +#endif +#define CONFIG_SYS_SRIO2_MEM_SIZE 0x10000000 /* 256M */ + +/* + * for slave u-boot IMAGE instored in master memory space, + * PHYS must be aligned based on the SIZE + */ +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_PHYS 0xfef080000ull +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS1 0xfff80000ull +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_SIZE 0x80000 /* 512K */ +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS2 0x3fff80000ull +/* + * for slave UCODE and ENV instored in master memory space, + * PHYS must be aligned based on the SIZE + */ +#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_PHYS 0xfef040000ull +#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_BUS 0x3ffe00000ull +#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_SIZE 0x40000 /* 256K */ + +/* slave core release by master*/ +#define CONFIG_SRIO_PCIE_BOOT_BRR_OFFSET 0xe00e4 +#define CONFIG_SRIO_PCIE_BOOT_RELEASE_MASK 0x00000001 /* release core 0 */ + +/* + * SRIO_PCIE_BOOT - SLAVE + */ +#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE +#define CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR 0xFFE00000 +#define CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR_PHYS \ + (0x300000000ull | CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR) +#endif + +/* + * eSPI - Enhanced SPI + */ +#define CONFIG_FSL_ESPI +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_SST +#define CONFIG_CMD_SF +#define CONFIG_SF_DEFAULT_SPEED 10000000 +#define CONFIG_SF_DEFAULT_MODE 0 + +/* + * General PCI + * Memory space is mapped 1-1, but I/O space must start from 0. + */ + +/* controller 1, direct to uli, tgtid 3, Base address 20000 */ +#define CONFIG_SYS_PCIE1_MEM_VIRT 0x80000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE1_MEM_PHYS 0xc00000000ull +#else +#define CONFIG_SYS_PCIE1_MEM_BUS 0x80000000 +#define CONFIG_SYS_PCIE1_MEM_PHYS 0x80000000 +#endif +#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE1_IO_VIRT 0xf8000000 +#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PCIE1_IO_PHYS 0xff8000000ull +#else +#define CONFIG_SYS_PCIE1_IO_PHYS 0xf8000000 +#endif +#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ + +/* Qman/Bman */ +#ifndef CONFIG_NOBQFMAN +#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ +#define CONFIG_SYS_BMAN_NUM_PORTALS 25 +#define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull +#else +#define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE +#endif +#define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_QMAN_NUM_PORTALS 25 +#define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull +#else +#define CONFIG_SYS_QMAN_MEM_PHYS CONFIG_SYS_QMAN_MEM_BASE +#endif +#define CONFIG_SYS_QMAN_MEM_SIZE 0x02000000 + +#define CONFIG_SYS_DPAA_FMAN + +/* Default address of microcode for the Linux Fman driver */ +#if defined(CONFIG_SPIFLASH) +/* + * env is stored at 0x100000, sector size is 0x10000, ucode is stored after + * env, so we got 0x110000. + */ +#define CONFIG_SYS_QE_FW_IN_SPIFLASH +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 +#elif defined(CONFIG_SDCARD) +/* + * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is + * about 545KB (1089 blocks), Env is stored after the image, and the env size is + * 0x2000 (16 blocks), 8 + 1089 + 16 = 1113, enlarge it to 1130. + */ +#define CONFIG_SYS_QE_FMAN_FW_IN_MMC +#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1130) +#elif defined(CONFIG_NAND) +#define CONFIG_SYS_QE_FMAN_FW_IN_NAND +#define CONFIG_SYS_QE_FMAN_FW_ADDR (6 * CONFIG_SYS_NAND_BLOCK_SIZE) +#else +#define CONFIG_SYS_QE_FMAN_FW_IN_NOR +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF40000 +#endif +#define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 +#define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) +#endif /* CONFIG_NOBQFMAN */ + +#ifdef CONFIG_SYS_DPAA_FMAN +#define CONFIG_FMAN_ENET +#define CONFIG_PHYLIB_10G +#define CONFIG_PHY_VITESSE +#define CONFIG_PHY_TERANETICS +#define SGMII_CARD_PORT1_PHY_ADDR 0x1C +#define SGMII_CARD_PORT2_PHY_ADDR 0x10 +#define SGMII_CARD_PORT3_PHY_ADDR 0x1E +#define SGMII_CARD_PORT4_PHY_ADDR 0x11 +#endif + +#ifdef CONFIG_PCI +#define CONFIG_NET_MULTI +#define CONFIG_PCI_PNP /* do pci plug-and-play */ +#define CONFIG_E1000 + +#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ +#define CONFIG_DOS_PARTITION +#endif /* CONFIG_PCI */ + +#ifdef CONFIG_FMAN_ENET +#define CONFIG_SYS_FM1_DTSEC5_PHY_ADDR 0x10 +#define CONFIG_SYS_FM1_DTSEC6_PHY_ADDR 0x11 +#define CONFIG_SYS_FM1_10GEC1_PHY_ADDR 4 + +#define CONFIG_SYS_FM1_DTSEC1_RISER_PHY_ADDR 0x1c +#define CONFIG_SYS_FM1_DTSEC2_RISER_PHY_ADDR 0x1d +#define CONFIG_SYS_FM1_DTSEC3_RISER_PHY_ADDR 0x1e +#define CONFIG_SYS_FM1_DTSEC4_RISER_PHY_ADDR 0x1f + +#define CONFIG_MII /* MII PHY management */ +#define CONFIG_ETHPRIME "FM1@DTSEC1" +#define CONFIG_PHY_GIGE /* Include GbE speed/duplex detection */ +#endif + +/* + * Environment + */ +#define CONFIG_LOADS_ECHO /* echo on for serial download */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_ELF +#define CONFIG_CMD_ERRATA +#define CONFIG_CMD_GREPENV +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_SETEXPR + +#ifdef CONFIG_PCI +#define CONFIG_CMD_PCI +#define CONFIG_CMD_NET +#endif + +/* +* USB +*/ +#define CONFIG_HAS_FSL_DR_USB + +#ifdef CONFIG_HAS_FSL_DR_USB +#define CONFIG_USB_EHCI + +#ifdef CONFIG_USB_EHCI +#define CONFIG_CMD_USB +#define CONFIG_USB_STORAGE +#define CONFIG_USB_EHCI_FSL +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET +#define CONFIG_CMD_EXT2 +#endif +#endif + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_CMDLINE_EDITING /* Command-line editing */ +#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#ifdef CONFIG_CMD_KGDB +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE/* Boot Argument Buffer Size */ +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks*/ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 64 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (64 << 20) /* Initial map for Linux*/ +#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */ + +#ifdef CONFIG_CMD_KGDB +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * Environment Configuration + */ +#define CONFIG_ROOTPATH "/opt/nfsroot" +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_UBOOTPATH "u-boot.bin" /* U-Boot image on TFTP server*/ + +/* default location for tftp and bootm */ +#define CONFIG_LOADADDR 1000000 + +#define CONFIG_BOOTDELAY 10 /* -1 disables auto-boot */ + +#define CONFIG_BAUDRATE 115200 + +#define __USB_PHY_TYPE ulpi + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:ctlr_intlv=cacheline," \ + "bank_intlv=cs0_cs1;" \ + "usb1:dr_mode=host,phy_type=" MK_STR(__USB_PHY_TYPE) "\0"\ + "netdev=eth0\0" \ + "uboot=" MK_STR(CONFIG_UBOOTPATH) "\0" \ + "ubootaddr=" MK_STR(CONFIG_SYS_TEXT_BASE) "\0" \ + "tftpflash=tftpboot $loadaddr $uboot && " \ + "protect off $ubootaddr +$filesize && " \ + "erase $ubootaddr +$filesize && " \ + "cp.b $loadaddr $ubootaddr $filesize && " \ + "protect on $ubootaddr +$filesize && " \ + "cmp.b $loadaddr $ubootaddr $filesize\0" \ + "consoledev=ttyS0\0" \ + "ramdiskaddr=2000000\0" \ + "ramdiskfile=b4860qds/ramdisk.uboot\0" \ + "fdtaddr=c00000\0" \ + "fdtfile=b4860qds/b4860qds.dtb\0" \ + "bdev=sda3\0" \ + "c=ffe\0" + +/* For emulation this causes u-boot to jump to the start of the proof point + app code automatically */ +#define CONFIG_PROOF_POINTS \ + "setenv bootargs root=/dev/$bdev rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "cpu 1 release 0x29000000 - - -;" \ + "cpu 2 release 0x29000000 - - -;" \ + "cpu 3 release 0x29000000 - - -;" \ + "cpu 4 release 0x29000000 - - -;" \ + "cpu 5 release 0x29000000 - - -;" \ + "cpu 6 release 0x29000000 - - -;" \ + "cpu 7 release 0x29000000 - - -;" \ + "go 0x29000000" + +#define CONFIG_HVBOOT \ + "setenv bootargs config-addr=0x60000000; " \ + "bootm 0x01000000 - 0x00f00000" + +#define CONFIG_ALU \ + "setenv bootargs root=/dev/$bdev rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "cpu 1 release 0x01000000 - - -;" \ + "cpu 2 release 0x01000000 - - -;" \ + "cpu 3 release 0x01000000 - - -;" \ + "cpu 4 release 0x01000000 - - -;" \ + "cpu 5 release 0x01000000 - - -;" \ + "cpu 6 release 0x01000000 - - -;" \ + "cpu 7 release 0x01000000 - - -;" \ + "go 0x01000000" + +#define CONFIG_LINUX \ + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "setenv ramdiskaddr 0x02000000;" \ + "setenv fdtaddr 0x00c00000;" \ + "setenv loadaddr 0x1000000;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr" + +#define CONFIG_HDBOOT \ + "setenv bootargs root=/dev/$bdev rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr - $fdtaddr" + +#define CONFIG_NFSBOOTCOMMAND \ + "setenv bootargs root=/dev/nfs rw " \ + "nfsroot=$serverip:$rootpath " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr - $fdtaddr" + +#define CONFIG_RAMBOOTCOMMAND \ + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $ramdiskaddr $ramdiskfile;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr" + +#define CONFIG_BOOTCOMMAND CONFIG_LINUX + +#ifdef CONFIG_SECURE_BOOT +#include <asm/fsl_secure_boot.h> +#endif + +#endif /* __CONFIG_H */
On Thu, Oct 11, 2012 at 12:13 PM, York Sun yorksun@freescale.com wrote:
B4860QDS is a high-performance computing evaluation, development and test platform supporting the B4860 QorIQ Power Architecture™ processor.
VSC3316 is 11.5Gbps 16x16 Asynchronous cross-point switch and VSC3308 is 11.5Gbps 8x8 Asynchronous cross-point switch, these crosspoint switches commute SerDes lanes to different destinations depending upon their programming in accordance with SerDes protocol
- Add defines for VSC3316/3308 crosspoint switches
- Add define for PCA-I2C bus multiplexer
- Add support in b4860qds board file to configure these crosspoint switches based on the SerDes1 and SerDes2 protocol
- Add VSC3316 and VSC3308 Mux entries for all possible crosspoint connections on b4860qds board
B4860 has FMANv3 so the External PHYs are accessible using dedicated MDIO blocks at addresse 0x4fc0000 0x4fd0000. B4860 has only SGMII, no RGMII, single FMAN.
Slot and PHYs details on B4860QDS
- Two on board SGMII PHYs connected through serdes1 via crossbar - Two slots available via AMC2PEX connector through serdes2 - Slot1 (PCIe/ SGMII riser/ XAUI) connected to serdes2 lanes 0,1,2,3 - Slot2 (PCIe/ SGMII Riser/ XAUI) connected to serdes2 lanes 4,5,6,7 via crossbar
Cross bar is a Vitesse switch on B4860 QDS which is connected to serdes on one side(input) and the PHYs(output) on the other side. So this device needs to be configured to get the right serdes lanes go to the right PHYs and slots. Cross bar configurations done based on the RCW.
Currently the below mentioned are tested and supported: 1. sgmii5 and sgmii6 are connected to onboard PHYs srds1_prtcl=0x2A 2. sgmii 1, sgmiii2, sgmii3, sgmii4 via SGMII riser card on Slot#1 srds2_prtcl=0x18
Signed-off-by: York Sun yorksun@freescale.com Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com Signed-off-by: Shaveta Leekha shaveta@freescale.com Signed-off-by: Priyanka Jain Priyanka.Jain@freescale.com Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com Signed-off-by: Roy Zang tie-fei.zang@freescale.com Signed-off-by: Sandeep Singh Sandeep@freescale.com
Please note that, due to compile issues brought on by not defining QIXIS_RST_CTL_RESET and other similar constants, the B4860QDS code cannot be applied to the tree. Internal review indicates that these features are implemented differently on B4QDS, and the code needs to be updated to reflect that.
Andy
The T4240QDS is a high-performance computing evaluation, development and test platform supporting the T4240 QorIQ Power Architecture™ processor.
+#define __USB_PHY_TYPE utmi
"hwconfig=fsl_ddr:ctlr_intlv=3way_4KB," \
"bank_intlv=auto;" \
"netdev=eth0\0" \
Please note that MK_STR() has been eliminated in the top of tree. Please use __stringify() in the future. I have fixed this patch, but future patches should use __stringify.
Andy
Andy Fleming
York Sun
