I want to have ram memory above 4G on a freescale p4080 board since I want to test that 36-bits physical addressing is working, my board has two 2G dimm mounted.
The standard 32-bits u-boot on the board says that it can only handle memory less than 4G.
I have managed to flashed a 36-bits u-boot to the board and now I realized that the 36-bits u-boot
put the two gigs memory below 4G.
Is it possible to change something in u-boot so it put one of the memory device above 4G?
I think a better solution for me would be to replace the two memory devices with two 4 gigs devices.
Does u-boot support larger devices?
Maybe it's only to put the larger memory in and everything works.
/Leif
Leif Sörman Software Engineer R&D OSE Labs Core Enea Skalholtsgatan 9, Box 1033, SE-164 21 Kista, Sweden Direct: +46 8 5071 4218 Mobile: +46 70 971 4218 leif.sorman@enea.com www.enea.com
This message, including attachments, is CONFIDENTIAL. It may also be privileged or otherwise protected by law. If you received this email by mistake please let us know by reply and then delete it from your system; you should not copy it or disclose its contents to anyone.
We've tested up to 8GB on a P4080DS.
The purpose of a 36-bit U-Boot is so that you can have more than 2GB of RAM. I/O devices are placed above 4GB.
Not really. U-Boot's internal design has quite a few dependencies on having memory starting at address 0. Also, getting the Linux kernel to boot at an address other than 0 is difficult.
Also, even if you have 8GB of memory, it's hard to get Linux to allocate memory above the 4GB range.
Yes, I agree.
Yes. The latest upstream U-Boot supports 4GB DDR and maybe even 8GB DDR.
It should.
You really should not include messages like these when you send email to a public mailing list.
Leif Sörman
Timur Tabi
