[U-Boot] [PATCH V2 1/2] test/py: fix off-by-one error in spawn matching code
A regex match object's .end() value is already the index after the match, not the index of the last character in the match, so there's no need to add 1 to point past the match.
Signed-off-by: Stephen Warren swarren@nvidia.com --- v2: New patch. --- test/py/u_boot_spawn.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/test/py/u_boot_spawn.py b/test/py/u_boot_spawn.py index 4b9e81af3efb..3d9cde5ee0d0 100644 --- a/test/py/u_boot_spawn.py +++ b/test/py/u_boot_spawn.py @@ -142,7 +142,7 @@ class Spawn(object): earliest_pi = pi if earliest_m: pos = earliest_m.start() - posafter = earliest_m.end() + 1 + posafter = earliest_m.end() self.before = self.buf[:pos] self.after = self.buf[pos:posafter] self.buf = self.buf[posafter:]
The existing regex simply ensures that the captured version string doesn't go past the end of a line. We really want to grab as much as possible. Do this by explicitly including a ) character at the end of the regex to match the last character of the version test.
Signed-off-by: Stephen Warren swarren@nvidia.com --- v2: Also remove some now-redundant code. The signon regex now never matches the text ", Build: ...", so there's no need for explicit code to chop it out. --- test/py/u_boot_console_base.py | 11 +++-------- 1 file changed, 3 insertions(+), 8 deletions(-)
diff --git a/test/py/u_boot_console_base.py b/test/py/u_boot_console_base.py index cc5427335177..7e1e9d430ffa 100644 --- a/test/py/u_boot_console_base.py +++ b/test/py/u_boot_console_base.py @@ -17,8 +17,8 @@ import sys import u_boot_spawn
# Regexes for text we expect U-Boot to send to the console. -pattern_u_boot_spl_signon = re.compile('(U-Boot SPL \d{4}\.\d{2}-[^\r\n]*)') -pattern_u_boot_main_signon = re.compile('(U-Boot \d{4}\.\d{2}-[^\r\n]*)') +pattern_u_boot_spl_signon = re.compile('(U-Boot SPL \d{4}\.\d{2}[^\r\n]*\))') +pattern_u_boot_main_signon = re.compile('(U-Boot \d{4}\.\d{2}[^\r\n]*\))') pattern_stop_autoboot_prompt = re.compile('Hit any key to stop autoboot: ') pattern_unknown_command = re.compile('Unknown command '.*' - try 'help'') pattern_error_notification = re.compile('## Error: ') @@ -312,12 +312,7 @@ class ConsoleBase(object): if m != 0: raise Exception('Bad pattern found on console: ' + self.bad_pattern_ids[m - 1]) - signon = self.p.after - build_idx = signon.find(', Build:') - if build_idx == -1: - self.u_boot_version_string = signon - else: - self.u_boot_version_string = signon[:build_idx] + self.u_boot_version_string = self.p.after while True: m = self.p.expect([self.prompt_escaped, pattern_stop_autoboot_prompt] + self.bad_patterns)
Acked-by: Simon Glass sjg@chromium.org Tested on sandbox: Tested-by: Simon Glass sjg@chromium.org
Applied to u-boot-dm, thanks!
v2: New patch.
v2: New patch.
Stephen Warren
