[U-Boot] [PATCH] imx: imx7d: fix ahb clock mux 1
The clock parent of the AHB root clock when using mux option 1 is the SYS PLL 270MHz clock. This is specified in Table 5-11 Clock Root Table of the i.MX 7Dual Applications Processor Reference Manual.
While it could be a documentation error, the 270MHz parent is also mentioned in the boot ROM configuration in Table 6-28: The clock is by default at 135MHz due to a POST_PODF value of 1 (=> divider of 2).
Signed-off-by: Stefan Agner stefan@agner.ch --- I sent a similar fix to the LKML which has been merged some days ago: https://lkml.org/lkml/2016/4/28/767
-- Stefan
arch/arm/cpu/armv7/mx7/clock_slice.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/mx7/clock_slice.c b/arch/arm/cpu/armv7/mx7/clock_slice.c index ad5d504..1665df9 100644 --- a/arch/arm/cpu/armv7/mx7/clock_slice.c +++ b/arch/arm/cpu/armv7/mx7/clock_slice.c @@ -55,7 +55,7 @@ static struct clk_root_map root_array[] = { PLL_ENET_MAIN_250M_CLK, PLL_AUDIO_MAIN_CLK} }, {AHB_CLK_ROOT, CCM_AHB_CHANNEL, - {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_DRAM_MAIN_533M_CLK, + {OSC_24M_CLK, PLL_SYS_PFD2_270M_CLK, PLL_DRAM_MAIN_533M_CLK, PLL_SYS_PFD0_392M_CLK, PLL_ENET_MAIN_125M_CLK, PLL_USB_MAIN_480M_CLK, PLL_AUDIO_MAIN_CLK, PLL_VIDEO_MAIN_CLK} },
Thanks for porting this to U-Boot, too.
-- Stefan
PLL_SYS_PFD0_392M_CLK, PLL_ENET_MAIN_125M_CLK, PLL_USB_MAIN_480M_CLK, PLL_AUDIO_MAIN_CLK, PLL_VIDEO_MAIN_CLK} },{OSC_24M_CLK, PLL_SYS_PFD2_270M_CLK, PLL_DRAM_MAIN_533M_CLK,
Applied to -next, thanks !
Best regards, Stefano Babic
Stefan Agner
Stefano Babic
