[GIT PULL] Pull request: u-boot-imx u-boot-imx-20200310
Hi Tom,
please pull (fixes) from u-boot-imx, thanks !
The following changes since commit 9f976bac2b4a81a13de8124a896a198cbeabb634:
Merge https://gitlab.denx.de/u-boot/custodians/u-boot-x86 (2020-03-05 07:51:12 -0500)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-20200310
for you to fetch changes up to 9f656fbee3b433ae1e9daf5d92d46bbdcc9551eb:
mx6slevk: Convert to DM_ETH (2020-03-10 10:59:08 +0100)
---------------------------------------------------------------- Fixes for 2020.04 -----------------
- DM : mx6sabresd - mx6ul_14x14_evk: fix video - mx8qxp; fix console for booting - sync DTS with kernel (imx6sx) - drop obsolete woodburn (mx35)
Travis: https://travis-ci.org/sbabic/u-boot-imx/builds/660550811
---------------------------------------------------------------- Alifer Moraes (2): mx6sabresd: Convert ethernet to driver model arm: dts: imx8mq-evk: add phy-reset-gpios for fec1
Anatolij Gustschin (1): imx: mx6ul_14x14_evk: configure for 24bpp display
Baruch Siach (1): mx6cuboxi: don't disable fdt relocation
Fabio Estevam (7): imx8qxp_mek: Fix the console command line string mx7dsabresd: Add myself as maintainer imx8qxp_mek: Add myself as maintainer ARM: dts: imx6sx: Sync with kernel 5.4.16 ARM: dts: imx6sx-sdb: Sync with kernel 5.4.16 mx6sxsabresd: Enable DM_PCI mx7dsabresd: Boot in non secure by default
Frieder Schrempf (1): imx8mm/mn: Add missing root clock entry for ARM core clock
Giulio Benetti (2): configs: imxrt1050-evk: enable D/I cache serial_lpuart: make clock failure less verbose
Heiko Schocher (1): imx6, aristainetos2c: add da9063 pmic setup
Igor Opaniuk (1): ARM: dts: imx8mm-verdin: dm-spl for pinctrl_usdhc1 node
Max Krummenacher (1): ARM: dts: imx8mm-verdin: drop rgmii_rxc_dly/txc_dly
Oliver Graute (3): imx: Makefile: added missing ahab.o imx: imx8qm_rom7720: added missing USDHC Base address defines imx: imx8qm: enable relocation of fdt and initrd
Pedro Jardim (2): mx6sabreauto: Convert to DM_ETH mx6slevk: Convert to DM_ETH
Stefano Babic (1): imx: remove woodburn board
arch/arm/Kconfig | 10 ---- arch/arm/dts/imx6sx-pinfunc.h | 6 +- arch/arm/dts/imx6sx-sdb-u-boot.dtsi | 16 ------ arch/arm/dts/imx6sx-sdb.dts | 35 ++++++++--- arch/arm/dts/imx6sx-sdb.dtsi | 284 +++++++++++++++++++++++++++++++++++++++++++++++++++++++----------------------------------- arch/arm/dts/imx6sx.dtsi | 507 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++----------------------------------------------------------------- arch/arm/dts/imx6ul-14x14-evk-u-boot.dtsi | 2 +- arch/arm/dts/imx8mm-verdin-u-boot.dtsi | 4 ++ arch/arm/dts/imx8mm-verdin.dts | 2 - arch/arm/dts/imx8mq-evk.dts | 2 + arch/arm/mach-imx/imx8/Makefile | 1 + arch/arm/mach-imx/imx8m/clock_slice.c | 5 ++ board/aristainetos/aristainetos.c | 56 ++++++++++++++++++ board/freescale/imx8mq_evk/imx8mq_evk.c | 18 ------ board/freescale/imx8qxp_mek/MAINTAINERS | 1 + board/freescale/mx6sabreauto/mx6sabreauto.c | 42 -------------- board/freescale/mx6sabresd/mx6sabresd.c | 36 ------------ board/freescale/mx6slevk/mx6slevk.c | 31 ---------- board/freescale/mx7dsabresd/MAINTAINERS | 1 + board/woodburn/Kconfig | 25 -------- board/woodburn/MAINTAINERS | 12 ---- board/woodburn/Makefile | 8 --- board/woodburn/imximage.cfg | 4 -- board/woodburn/lowlevel_init.S | 24 -------- board/woodburn/woodburn.c | 251 ------------------------------------------------------------------------------- configs/aristainetos2c_defconfig | 3 + configs/imxrt1050-evk_defconfig | 2 - configs/mx6sabreauto_defconfig | 5 ++ configs/mx6sabresd_defconfig | 5 ++ configs/mx6slevk_defconfig | 3 + configs/mx6sxsabresd_defconfig | 1 + configs/mx7dsabresd_defconfig | 1 - configs/mx7dsabresd_qspi_defconfig | 1 - configs/woodburn_defconfig | 51 ---------------- configs/woodburn_sd_defconfig | 63 -------------------- drivers/serial/serial_lpuart.c | 2 +- include/configs/imx8qm_rom7720.h | 7 ++- include/configs/imx8qxp_mek.h | 6 +- include/configs/mx6cuboxi.h | 1 - include/configs/mx6sabreauto.h | 8 --- include/configs/mx6sabresd.h | 9 --- include/configs/mx6slevk.h | 7 --- include/configs/woodburn.h | 18 ------ include/configs/woodburn_common.h | 195 -------------------------------------------------------------- include/configs/woodburn_sd.h | 30 ---------- include/dt-bindings/clock/imx6sx-clock.h | 13 +++-- 46 files changed, 606 insertions(+), 1208 deletions(-) delete mode 100644 arch/arm/dts/imx6sx-sdb-u-boot.dtsi delete mode 100644 board/woodburn/Kconfig delete mode 100644 board/woodburn/MAINTAINERS delete mode 100644 board/woodburn/Makefile delete mode 100644 board/woodburn/imximage.cfg delete mode 100644 board/woodburn/lowlevel_init.S delete mode 100644 board/woodburn/woodburn.c delete mode 100644 configs/woodburn_defconfig delete mode 100644 configs/woodburn_sd_defconfig delete mode 100644 include/configs/woodburn.h delete mode 100644 include/configs/woodburn_common.h delete mode 100644 include/configs/woodburn_sd.h
Best regards, Stefano
Hi Stefano,
On Tue, Mar 10, 2020 at 12:43 PM Stefano Babic sbabic@denx.de wrote:
Hi Tom,
It seems that Anatolij's fix is still missing: https://patchwork.ozlabs.org/patch/1239043/
It is needed for booting i.MX8/8X.
Thanks
On Tue, Mar 10, 2020 at 01:37:33PM -0300, Fabio Estevam wrote:
Hi Stefano,
Hi Tom,
I probably messed things up here then. With https://patchwork.ozlabs.org/patch/1239143/ and https://patchwork.ozlabs.org/patch/1239144/ is there not a different fix needed for i.MX8 now, or were there two issues here that I confused?
My understanding is that these two issues are meson related and we still need the one for i.MX8QXP to boot.
Regards,
Fabio Estevam
To be clear, we don't just need a flag added to some i.MX8 drivers like in the Meson case?
no, currently a flag is not required in i.MX8 drivers.
-- Anatolij
OK, my fault. I see the patch already has Simon's RB so I'll pick it up directly. Sorry for the confusion!
Hi Stefano,
Hi Tom,
there were two different issues, so patch 1239043 is still needed to boot on i.MX8X.
-- Anatolij
On Tue, Mar 10, 2020 at 04:43:20PM +0100, Stefano Babic wrote:
Hi Tom,
Anatolij Gustschin
Fabio Estevam
Stefano Babic
