[PATCH v2 0/2] ARM: at91: Allow running SPL with DTB append
Hello,
a few months ago I submitted a small series allowing to run SPL with DTB append. Indeed according to the linker BSS section was all the time separated for SPL but the symbol SPL_SEPARATE_BSS was only enabled on some boards.
In this v2 the changes are: - add reviewed-by Stefan Roese sr@denx.de - modify a new defconfig sama5d3_xplained_nandflash_defconfig
Thanks,
Gregory
Gregory CLEMENT (2): ARM: at91: Enable SPL_SEPARATE_BSS by default configs: atmel: cleanup CONFIG_SPL_SEPARATE_BSS
arch/arm/Kconfig | 1 + configs/gardena-smart-gateway-at91sam_defconfig | 1 - configs/sama5d27_som1_ek_mmc1_defconfig | 1 - configs/sama5d27_som1_ek_mmc_defconfig | 1 - configs/sama5d27_som1_ek_qspiflash_defconfig | 1 - configs/sama5d27_wlsom1_ek_mmc_defconfig | 1 - configs/sama5d27_wlsom1_ek_qspiflash_defconfig | 1 - configs/sama5d2_icp_mmc_defconfig | 1 - configs/sama5d2_xplained_emmc_defconfig | 1 - configs/sama5d2_xplained_mmc_defconfig | 1 - configs/sama5d2_xplained_qspiflash_defconfig | 1 - configs/sama5d3_xplained_mmc_defconfig | 1 - configs/sama5d3xek_mmc_defconfig | 1 - configs/sama5d4_xplained_mmc_defconfig | 1 - configs/sama5d4ek_mmc_defconfig | 1 - 15 files changed, 1 insertion(+), 14 deletions(-)
According to the linker script for both armv7 and arm926ejs based SoC, BSS section was all the time separated for SPL but this symbol was only enabled on some boards. However, it is necessary to have it enabled for OF_SEPARATE configuration where DTB is appended to u-boot with DTB.
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Gregory CLEMENT gregory.clement@bootlin.com --- arch/arm/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 21df1c415f..3ba7e338b6 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -532,6 +532,7 @@ choice config ARCH_AT91 bool "Atmel AT91" select SPL_BOARD_INIT if SPL && !TARGET_SMARTWEB + select SPL_SEPARATE_BSS if SPL
config TARGET_EDB93XX bool "Support edb93xx"
Now that CONFIG_SPL_SEPARATE_BSS is selected for all the AT91 based boards, cleanups the defconfigs by removing it.
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Gregory CLEMENT gregory.clement@bootlin.com --- configs/gardena-smart-gateway-at91sam_defconfig | 1 - configs/sama5d27_som1_ek_mmc1_defconfig | 1 - configs/sama5d27_som1_ek_mmc_defconfig | 1 - configs/sama5d27_som1_ek_qspiflash_defconfig | 1 - configs/sama5d27_wlsom1_ek_mmc_defconfig | 1 - configs/sama5d27_wlsom1_ek_qspiflash_defconfig | 1 - configs/sama5d2_icp_mmc_defconfig | 1 - configs/sama5d2_xplained_emmc_defconfig | 1 - configs/sama5d2_xplained_mmc_defconfig | 1 - configs/sama5d2_xplained_qspiflash_defconfig | 1 - configs/sama5d3_xplained_mmc_defconfig | 1 - configs/sama5d3xek_mmc_defconfig | 1 - configs/sama5d4_xplained_mmc_defconfig | 1 - configs/sama5d4ek_mmc_defconfig | 1 - 14 files changed, 14 deletions(-)
diff --git a/configs/gardena-smart-gateway-at91sam_defconfig b/configs/gardena-smart-gateway-at91sam_defconfig index 79d1cb9a96..8f536734e6 100644 --- a/configs/gardena-smart-gateway-at91sam_defconfig +++ b/configs/gardena-smart-gateway-at91sam_defconfig @@ -26,7 +26,6 @@ CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(boots CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_SEPARATE_BSS=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/sama5d27_som1_ek_mmc1_defconfig b/configs/sama5d27_som1_ek_mmc1_defconfig index a750ec9e18..417a41980e 100644 --- a/configs/sama5d27_som1_ek_mmc1_defconfig +++ b/configs/sama5d27_som1_ek_mmc1_defconfig @@ -29,7 +29,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk1p2 rw rootwait" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set diff --git a/configs/sama5d27_som1_ek_mmc_defconfig b/configs/sama5d27_som1_ek_mmc_defconfig index 3f22fde026..7aaf2a5c3c 100644 --- a/configs/sama5d27_som1_ek_mmc_defconfig +++ b/configs/sama5d27_som1_ek_mmc_defconfig @@ -30,7 +30,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set diff --git a/configs/sama5d27_som1_ek_qspiflash_defconfig b/configs/sama5d27_som1_ek_qspiflash_defconfig index 2c8ae8d004..726d884983 100644 --- a/configs/sama5d27_som1_ek_qspiflash_defconfig +++ b/configs/sama5d27_som1_ek_qspiflash_defconfig @@ -30,7 +30,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set diff --git a/configs/sama5d27_wlsom1_ek_mmc_defconfig b/configs/sama5d27_wlsom1_ek_mmc_defconfig index a5fb4f514e..d19089c2e5 100644 --- a/configs/sama5d27_wlsom1_ek_mmc_defconfig +++ b/configs/sama5d27_wlsom1_ek_mmc_defconfig @@ -28,7 +28,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DISPLAY_PRINT=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_AT91_MCK_BYPASS=y diff --git a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig index 92decb4b85..6edfdf5e0a 100644 --- a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig +++ b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig @@ -29,7 +29,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DISPLAY_PRINT=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_SPI_LOAD=y diff --git a/configs/sama5d2_icp_mmc_defconfig b/configs/sama5d2_icp_mmc_defconfig index dd15441798..0560f6ea19 100644 --- a/configs/sama5d2_icp_mmc_defconfig +++ b/configs/sama5d2_icp_mmc_defconfig @@ -26,7 +26,6 @@ CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DISPLAY_PRINT=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_RAM_SUPPORT=y diff --git a/configs/sama5d2_xplained_emmc_defconfig b/configs/sama5d2_xplained_emmc_defconfig index 75d68a76e4..b75af59960 100644 --- a/configs/sama5d2_xplained_emmc_defconfig +++ b/configs/sama5d2_xplained_emmc_defconfig @@ -28,7 +28,6 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait" # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set diff --git a/configs/sama5d2_xplained_mmc_defconfig b/configs/sama5d2_xplained_mmc_defconfig index 779e91a52a..1e8664fe2d 100644 --- a/configs/sama5d2_xplained_mmc_defconfig +++ b/configs/sama5d2_xplained_mmc_defconfig @@ -30,7 +30,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk1p2 rw rootwait" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set diff --git a/configs/sama5d2_xplained_qspiflash_defconfig b/configs/sama5d2_xplained_qspiflash_defconfig index 9b5645667d..4f08ba91eb 100644 --- a/configs/sama5d2_xplained_qspiflash_defconfig +++ b/configs/sama5d2_xplained_qspiflash_defconfig @@ -30,7 +30,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p1 rw rootwait" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set diff --git a/configs/sama5d3_xplained_mmc_defconfig b/configs/sama5d3_xplained_mmc_defconfig index 76e981dabf..2a08e2bd6e 100644 --- a/configs/sama5d3_xplained_mmc_defconfig +++ b/configs/sama5d3_xplained_mmc_defconfig @@ -28,7 +28,6 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait" # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index d7f2ebeffd..3a2d5148d3 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -30,7 +30,6 @@ CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwai # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set diff --git a/configs/sama5d4_xplained_mmc_defconfig b/configs/sama5d4_xplained_mmc_defconfig index eaee73ec99..02531f5c2a 100644 --- a/configs/sama5d4_xplained_mmc_defconfig +++ b/configs/sama5d4_xplained_mmc_defconfig @@ -29,7 +29,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index c1c64dd322..4a19911dc8 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -30,7 +30,6 @@ CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwai # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set
On 05.06.2020 11:43, Gregory CLEMENT wrote:
Hello,
Thanks,
Gregory
-- 2.26.2
Applied to u-boot-atmel/master, Thanks!
Eugen.Hristev@microchip.com
Gregory CLEMENT
