[RFT][PATCH v1 0/2] Fix CONFIG_SYS_UBOOT_START default value
This series fixes a regression introduced by d3e97b53c1f2 ("spl: fix entry_point equal to load_addr") which breaks some board boot (at least STM32MP15 in basic configuration)
If CONFIG_SYS_UBOOT_START is not set, it's set to CONFIG_SYS_TEXT_BASE by default. This allows also to clean include/configs board files in which CONFIG_SYS_UBOOT_START is already set to CONFIG_SYS_TEXT_BASE.
Patrice Chotard (2): Makefile: Fix CONFIG_SYS_UBOOT_START default value treewide: Remove CONFIG_SYS_UBOOT_START from configs board files
Makefile | 2 +- include/configs/gardena-smart-gateway-at91sam.h | 1 - include/configs/ls1046a_common.h | 1 - include/configs/mccmon6.h | 1 - include/configs/microblaze-generic.h | 2 -- include/configs/mt7623.h | 1 - include/configs/mt7629.h | 1 - include/configs/mt8518.h | 1 - include/configs/omap3_cairo.h | 1 - include/configs/pumpkin.h | 1 - include/configs/tegra-common.h | 1 - include/configs/x600.h | 1 - include/configs/xilinx_zynqmp_r5.h | 2 -- include/configs/zynq-common.h | 2 -- 14 files changed, 1 insertion(+), 17 deletions(-)
This patches restores boot on boards which rely on CONFIG_SYS_UBOOT_START equal to CONFIG_SYS_TEXT_BASE when using SPL
Fixes: d3e97b53c1f2 ("spl: fix entry_point equal to load_addr")
Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index 0ee0c70102..d679459305 100644 --- a/Makefile +++ b/Makefile @@ -1265,7 +1265,7 @@ u-boot.ldr.hex u-boot.ldr.srec: u-boot.ldr FORCE # from the SPL U-Boot version. # ifndef CONFIG_SYS_UBOOT_START -CONFIG_SYS_UBOOT_START := 0 +CONFIG_SYS_UBOOT_START := $(CONFIG_SYS_TEXT_BASE) endif
# Boards with more complex image requirements can provide an .its source file
Signed-off-by: Patrice Chotard patrice.chotard@st.com Reviewed-by: Simon Glass sjg@chromium.org
As previous CONFIG_SYS_UBOOT_START is now set by default to CONFIG_SYS_TEXT_BASE when not defined, CONFIG_SYS_UBOOT_START can be removed from include/configs board files.
include/configs/gardena-smart-gateway-at91sam.h | 1 - include/configs/ls1046a_common.h | 1 - include/configs/mccmon6.h | 1 - include/configs/microblaze-generic.h | 2 -- include/configs/mt7623.h | 1 - include/configs/mt7629.h | 1 - include/configs/mt8518.h | 1 - include/configs/omap3_cairo.h | 1 - include/configs/pumpkin.h | 1 - include/configs/tegra-common.h | 1 - include/configs/x600.h | 1 - include/configs/xilinx_zynqmp_r5.h | 2 -- include/configs/zynq-common.h | 2 -- 13 files changed, 16 deletions(-)
diff --git a/include/configs/gardena-smart-gateway-at91sam.h b/include/configs/gardena-smart-gateway-at91sam.h index 482e4714b1..f5ee65cb8a 100644 --- a/include/configs/gardena-smart-gateway-at91sam.h +++ b/include/configs/gardena-smart-gateway-at91sam.h @@ -64,7 +64,6 @@ #define CONFIG_SPL_NAND_RAW_ONLY #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_U_BOOT_SIZE 0xa0000 -#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE
diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index cc8f4c0210..6543cfd868 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -98,7 +98,6 @@ CONFIG_SPL_BSS_MAX_SIZE) #define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 #define CONFIG_SYS_MONITOR_LEN 0x100000 -#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #endif
/* NAND SPL */ diff --git a/include/configs/mccmon6.h b/include/configs/mccmon6.h index 045a9f7bdf..0aee1e1cf6 100644 --- a/include/configs/mccmon6.h +++ b/include/configs/mccmon6.h @@ -12,7 +12,6 @@ #define CONFIG_SPL_LIBCOMMON_SUPPORT #include "imx6_spl.h"
-#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_UBOOT_BASE (CONFIG_SYS_FLASH_BASE + 0x80000) #define CONFIG_SYS_SPL_ARGS_ADDR 0x18000000
diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index 385b30c99b..8ca0e83c78 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -173,8 +173,6 @@ /* Just for sure that there is a space for stack */ #define CONFIG_SPL_STACK_SIZE 0x100
-#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE - #define CONFIG_SPL_MAX_FOOTPRINT (CONFIG_SYS_INIT_RAM_SIZE - \ CONFIG_SYS_INIT_RAM_ADDR - \ CONFIG_SYS_MALLOC_F_LEN - \ diff --git a/include/configs/mt7623.h b/include/configs/mt7623.h index e5182aeea8..faab0913fc 100644 --- a/include/configs/mt7623.h +++ b/include/configs/mt7623.h @@ -31,7 +31,6 @@ #define CONFIG_ENV_OVERWRITE
/* Preloader -> Uboot */ -#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE + SZ_2M - \ GENERATED_GBL_DATA_SIZE)
diff --git a/include/configs/mt7629.h b/include/configs/mt7629.h index 4aef894c6e..6a6c2f2414 100644 --- a/include/configs/mt7629.h +++ b/include/configs/mt7629.h @@ -40,7 +40,6 @@ #define CONFIG_SYS_UBOOT_BASE (CONFIG_SPI_ADDR + CONFIG_SPL_PAD_TO)
/* SPL -> Uboot */ -#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE + SZ_2M - \ GENERATED_GBL_DATA_SIZE)
diff --git a/include/configs/mt8518.h b/include/configs/mt8518.h index a7fe83a605..514722be99 100644 --- a/include/configs/mt8518.h +++ b/include/configs/mt8518.h @@ -29,7 +29,6 @@ #define CONFIG_SYS_BOOTM_LEN SZ_64M
/* Uboot definition */ -#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE + \ SZ_2M - \ GENERATED_GBL_DATA_SIZE) diff --git a/include/configs/omap3_cairo.h b/include/configs/omap3_cairo.h index 1b1a56d7cd..c76c81ddd5 100644 --- a/include/configs/omap3_cairo.h +++ b/include/configs/omap3_cairo.h @@ -26,7 +26,6 @@ * other needs. We use this rather than the inherited defines from * ti_armv7_common.h for backwards compatibility. */ -#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SPL_BSS_START_ADDR 0x80000000 #define CONFIG_SPL_BSS_MAX_SIZE (512 << 10) /* 512 KB */ #define CONFIG_SYS_SPL_MALLOC_START 0x80208000 diff --git a/include/configs/pumpkin.h b/include/configs/pumpkin.h index 35e28be950..9c52cae41d 100644 --- a/include/configs/pumpkin.h +++ b/include/configs/pumpkin.h @@ -23,7 +23,6 @@ #define CONFIG_SYS_NS16550_COM1 0x11005000 #define CONFIG_SYS_NS16550_CLK 26000000
diff --git a/include/configs/tegra-common.h b/include/configs/tegra-common.h index b4da1f8428..f2cdd9c019 100644 --- a/include/configs/tegra-common.h +++ b/include/configs/tegra-common.h @@ -61,7 +61,6 @@ #define PHYS_SDRAM_1 NV_PA_SDRC_CS0 #define PHYS_SDRAM_1_SIZE 0x20000000 /* 512M */
-#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1
#define CONFIG_SYS_BOOTMAPSZ (256 << 20) /* 256M */ diff --git a/include/configs/x600.h b/include/configs/x600.h index 63092b24a5..8b6caae7be 100644 --- a/include/configs/x600.h +++ b/include/configs/x600.h @@ -27,7 +27,6 @@ #define CONFIG_SYS_SPL_LEN CONFIG_SPL_PAD_TO #define CONFIG_SYS_UBOOT_BASE (CONFIG_SYS_FLASH_BASE + \ CONFIG_SYS_SPL_LEN) -#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_MONITOR_LEN 0x60000
diff --git a/include/configs/xilinx_zynqmp_r5.h b/include/configs/xilinx_zynqmp_r5.h index 38d952d0c0..155d7fe883 100644 --- a/include/configs/xilinx_zynqmp_r5.h +++ b/include/configs/xilinx_zynqmp_r5.h @@ -35,8 +35,6 @@ /* Extend size of kernel image for uncompression */ #define CONFIG_SYS_BOOTM_LEN (60 * 1024 * 1024)
-#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE - #define CONFIG_SKIP_LOWLEVEL_INIT
/* 0x0 - 0x40 is used for placing exception vectors */ diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 274cc19112..189ca81bbe 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -274,6 +274,4 @@
#define CONFIG_SPL_LOAD_FIT_ADDRESS 0x10000000
-#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE - #endif /* __CONFIG_ZYNQ_COMMON_H */
On Fri, 6 Dec 2019 15:01:49 +0100 Patrice Chotard patrice.chotard@st.com wrote:
diff --git a/include/configs/gardena-smart-gateway-at91sam.h b/include/configs/gardena-smart-gateway-at91sam.h index 482e4714b1..f5ee65cb8a 100644 --- a/include/configs/gardena-smart-gateway-at91sam.h +++ b/include/configs/gardena-smart-gateway-at91sam.h @@ -64,7 +64,6 @@ #define CONFIG_SPL_NAND_RAW_ONLY #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_U_BOOT_SIZE 0xa0000 -#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index cc8f4c0210..6543cfd868 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -98,7 +98,6 @@ CONFIG_SPL_BSS_MAX_SIZE) #define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 #define CONFIG_SYS_MONITOR_LEN 0x100000 -#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #endif
- SZ_2M - \ GENERATED_GBL_DATA_SIZE)
diff --git a/include/configs/mt7629.h b/include/configs/mt7629.h index 4aef894c6e..6a6c2f2414 100644 --- a/include/configs/mt7629.h +++ b/include/configs/mt7629.h @@ -40,7 +40,6 @@ #define CONFIG_SYS_UBOOT_BASE (CONFIG_SPI_ADDR + CONFIG_SPL_PAD_TO) /* SPL -> Uboot */ -#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE
- other needs. We use this rather than the inherited defines from
- ti_armv7_common.h for backwards compatibility.
#define CONFIG_SYS_BOOTMAPSZ (256 << 20) /* 256M */ diff --git a/include/configs/x600.h b/include/configs/x600.h index 63092b24a5..8b6caae7be 100644 --- a/include/configs/x600.h +++ b/include/configs/x600.h @@ -27,7 +27,6 @@ #define CONFIG_SYS_SPL_LEN CONFIG_SPL_PAD_TO #define CONFIG_SYS_UBOOT_BASE (CONFIG_SYS_FLASH_BASE + \ CONFIG_SYS_SPL_LEN) -#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_MONITOR_LEN 0x60000 diff --git a/include/configs/xilinx_zynqmp_r5.h b/include/configs/xilinx_zynqmp_r5.h index 38d952d0c0..155d7fe883 100644 --- a/include/configs/xilinx_zynqmp_r5.h +++ b/include/configs/xilinx_zynqmp_r5.h @@ -35,8 +35,6 @@ /* Extend size of kernel image for uncompression */ #define CONFIG_SYS_BOOTM_LEN (60 * 1024 * 1024)
Acked-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Signed-off-by: Patrice Chotard patrice.chotard@st.com Acked-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
Patrice Chotard
