[U-Boot] Uboot send pull request
Hi Tom,
Please pull the following patch from u-boot-riscv into your tree. Thanks!
The following changes since commit 81cf7c8d45935a295991fe2cd1df286f0f47511f:
Merge git://git.denx.de/u-boot-ubi (2018-03-25 12:02:13 -0400)
git://git.denx.de/u-boot-riscv.git
for you to fetch changes up to d58717e42559189a226ea800173147399c8edef9:
riscv: ae250: Support DT provided by the board at runtime (2018-03-30 13:13:56 +0800)
---------------------------------------------------------------- Rick Chen (20): riscv: checkpatch: Fix Macro argument reuse riscv: checkpatch: Fix use of volatile riscv: checkpatch: Fix alignment should match open parenthesis riscv: checkpatch: Fix missing a blank line after declarations riscv: checkpatch: Fix static const char * array declarations riscv: bootm: Support to boot riscv-linux riscv: bootm: Remove ATAGS tools: mkimage: Support RISC-V arch doc: ae250: Describe riscv-linux booting via u-boot mmc: ftsdc010: Support High-Speed mode riscv: dts: AE250 support sd High-Speed mode nds32: dts: AG101P support sd High-Speed mode mmc: ftsdc010: Drop non-dm code board: Drop ftsdc010 non-dm code Drop CONFIG_FTSDC010_BASE Drop CONFIG_FTSDC010_NUMBER mmc: ftsdc010: Migrate CONFIG_FTSDC010_SDIO to Kconfig mmc: ftsdc010: Merge nds32_mmc to ftsdc010 configs: Drop CONFIG_MMC_NDS32 riscv: ae250: Support DT provided by the board at runtime
arch/nds32/dts/ag101p.dts | 1 + arch/nds32/include/asm/arch-ae3xx/ae3xx.h | 2 - arch/nds32/include/asm/arch-ag101/ag101.h | 2 - arch/nds32/include/asm/arch-ag102/ag102.h | 2 - arch/riscv/cpu/nx25/start.S | 2 + arch/riscv/dts/ae250.dts | 1 + arch/riscv/include/asm/bootm.h | 49 ------------------------ arch/riscv/include/asm/encoding.h | 16 +++++--- arch/riscv/include/asm/global_data.h | 2 +- arch/riscv/include/asm/io.h | 23 +++++------- arch/riscv/include/asm/posix_types.h | 12 ++++-- arch/riscv/include/asm/ptrace.h | 9 ++--- arch/riscv/include/asm/setup.h | 10 +++-- arch/riscv/include/asm/string.h | 12 ++++-- arch/riscv/lib/bootm.c | 185 +++--------------------------------------------------------------------------------------- arch/riscv/lib/interrupts.c | 2 +- board/AndesTech/adp-ae3xx/adp-ae3xx.c | 11 ------ board/AndesTech/adp-ag101p/adp-ag101p.c | 11 ------ board/AndesTech/nx25-ae250/nx25-ae250.c | 14 +++---- common/image.c | 1 + configs/adp-ae3xx_defconfig | 2 +- configs/adp-ag101p_defconfig | 2 +- configs/nx25-ae250_defconfig | 3 +- doc/README.ae250 | 148 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++--- drivers/mmc/Kconfig | 14 +++---- drivers/mmc/Makefile | 1 - drivers/mmc/ftsdc010_mci.c | 219 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++---------------------------------------------- drivers/mmc/ftsdc010_mci.h | 15 -------- drivers/mmc/nds32_mmc.c | 136 ------------------------------------------------------------------ include/configs/adp-ae3xx.h | 6 --- include/configs/adp-ag101p.h | 6 --- include/configs/nx25-ae250.h | 18 ++------- scripts/config_whitelist.txt | 4 -- 33 files changed, 347 insertions(+), 594 deletions(-) delete mode 100644 drivers/mmc/nds32_mmc.c
On Fri, Mar 30, 2018 at 03:05:25PM +0800, uboot@andestech.com wrote:
Hi Tom,
uboot@andestech.com
