[PATCH v1 0/8] arm: dts: imx: sync device trees with upstream linux kernel part 1
This series synchronises them imx device trees with the upstream Linux kernel (v6.0-rc1). I split it into two parts. This is part 1.
It also fixes a few issues as discussed during/after the pre-mature application of my first series [1].
I am not touching kontron-sl-mx6ul as Frieder already took care of those [2].
Feedback welcome. Thanks!
[1] https://patchwork.ozlabs.org/project/uboot/cover/20220721132748.1052244-1-ma... [2] https://patchwork.ozlabs.org/project/uboot/cover/20220823142917.306176-1-fri...
Marcel Ziswiler (8): vf610: synchronise device tree with linux imxrt1020: fix lpuart issue in common u-boot device tree imxrt1050: synchronise device tree with linux imx8ulp: synchronise device tree with linux imx8mq: synchronise device tree with linux imx8mp: synchronise device tree with linux imx8mn: synchronise device tree with linux imx8mm: synchronise device tree with linux
arch/arm/dts/imx8mm-beacon-baseboard.dtsi | 4 +- arch/arm/dts/imx8mm-evk.dtsi | 43 ++ arch/arm/dts/imx8mm-icore-mx8mm.dtsi | 12 +- arch/arm/dts/imx8mm-mx8menlo.dts | 4 +- arch/arm/dts/imx8mm-u-boot.dtsi | 2 +- arch/arm/dts/imx8mm-venice-gw700x.dtsi | 24 +- arch/arm/dts/imx8mm-venice-gw7901.dts | 8 +- arch/arm/dts/imx8mm-venice-gw7902.dts | 10 +- arch/arm/dts/imx8mm-venice-gw7903.dts | 6 +- arch/arm/dts/imx8mm-verdin.dtsi | 10 +- arch/arm/dts/imx8mn-beacon-baseboard.dtsi | 4 +- arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi | 2 +- .../dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi | 2 +- arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi | 2 +- arch/arm/dts/imx8mn-evk.dtsi | 45 +- .../dts/imx8mn-var-som-symphony-u-boot.dtsi | 2 +- arch/arm/dts/imx8mn-var-som-symphony.dts | 6 +- arch/arm/dts/imx8mn-venice-gw7902.dts | 8 +- arch/arm/dts/imx8mn-venice-u-boot.dtsi | 2 +- arch/arm/dts/imx8mn.dtsi | 13 +- arch/arm/dts/imx8mp-dhcom-pdk2.dts | 27 +- arch/arm/dts/imx8mp-dhcom-som.dtsi | 20 +- arch/arm/dts/imx8mp-evk.dts | 126 ++-- arch/arm/dts/imx8mp-phyboard-pollux-rdk.dts | 48 +- arch/arm/dts/imx8mp-u-boot.dtsi | 2 +- arch/arm/dts/imx8mp-venice-gw74xx.dts | 116 ++-- arch/arm/dts/imx8mp-verdin.dtsi | 14 +- arch/arm/dts/imx8mp.dtsi | 33 +- arch/arm/dts/imx8mq-evk.dts | 43 ++ arch/arm/dts/imx8mq-u-boot.dtsi | 10 +- arch/arm/dts/imx8mq.dtsi | 15 +- arch/arm/dts/imx8ulp-evk-u-boot.dtsi | 6 +- arch/arm/dts/imx8ulp-evk.dts | 191 +----- arch/arm/dts/imx8ulp-pinfunc.h | 4 +- arch/arm/dts/imx8ulp.dtsi | 564 +++++------------- arch/arm/dts/imxrt1020-evk-u-boot.dtsi | 7 +- arch/arm/dts/imxrt1020-evk.dts | 1 - arch/arm/dts/imxrt1050-evk-u-boot.dtsi | 25 +- arch/arm/dts/imxrt1050-evk.dts | 257 +------- arch/arm/dts/imxrt1050-pinfunc.h | 2 +- arch/arm/dts/imxrt1050.dtsi | 168 +++--- arch/arm/dts/vf610-pinfunc.h | 2 +- include/dt-bindings/clock/imx8mp-clock.h | 13 +- include/dt-bindings/clock/imx8ulp-clock.h | 49 +- include/dt-bindings/clock/imxrt1050-clock.h | 9 +- include/dt-bindings/interconnect/imx8mm.h | 50 ++ include/dt-bindings/interconnect/imx8mn.h | 41 ++ include/dt-bindings/power/imx8mp-power.h | 15 +- include/dt-bindings/power/imx8ulp-power.h | 26 + include/dt-bindings/reset/imx8mp-reset.h | 50 ++ include/dt-bindings/reset/imx8mq-reset.h | 61 +- include/dt-bindings/reset/imx8ulp-pcc-reset.h | 59 ++ 52 files changed, 1007 insertions(+), 1256 deletions(-) create mode 100644 include/dt-bindings/interconnect/imx8mm.h create mode 100644 include/dt-bindings/interconnect/imx8mn.h create mode 100644 include/dt-bindings/power/imx8ulp-power.h create mode 100644 include/dt-bindings/reset/imx8mp-reset.h create mode 100644 include/dt-bindings/reset/imx8ulp-pcc-reset.h
Synchronise device tree with linux v6.0-rc1 plus the recent DDR pinmux addition still being in-flight.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com ---
arch/arm/dts/vf610-pinfunc.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/vf610-pinfunc.h b/arch/arm/dts/vf610-pinfunc.h index 740276431aa..b7b7322a2d1 100644 --- a/arch/arm/dts/vf610-pinfunc.h +++ b/arch/arm/dts/vf610-pinfunc.h @@ -802,7 +802,6 @@ #define VF610_PAD_PTE28__EWM_OUT 0x214 0x000 ALT7 0x0 #define VF610_PAD_PTA7__GPIO_134 0x218 0x000 ALT0 0x0 #define VF610_PAD_PTA7__VIU_PIX_CLK 0x218 0x3AC ALT1 0x1 - #define VF610_PAD_DDR_RESETB 0x21c 0x000 ALT0 0x0 #define VF610_PAD_DDR_A15__DDR_A_15 0x220 0x000 ALT0 0x0 #define VF610_PAD_DDR_A14__DDR_A_14 0x224 0x000 ALT0 0x0 @@ -853,4 +852,5 @@ #define VF610_PAD_DDR_ODT0__DDR_ODT_1 0x2d8 0x000 ALT0 0x0 #define VF610_PAD_DDR_DDRBYTE1__DDR_DDRBYTE1 0x2dc 0x000 ALT0 0x0 #define VF610_PAD_DDR_DDRBYTE2__DDR_DDRBYTE2 0x2e0 0x000 ALT0 0x0 + #endif
Fix lpuart issue in common U-Boot device tree.
arch/arm/dts/imxrt1020-evk-u-boot.dtsi | 7 ++++--- arch/arm/dts/imxrt1020-evk.dts | 1 - 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/imxrt1020-evk-u-boot.dtsi b/arch/arm/dts/imxrt1020-evk-u-boot.dtsi index 9e1b074d2e7..7cab486f5fa 100644 --- a/arch/arm/dts/imxrt1020-evk-u-boot.dtsi +++ b/arch/arm/dts/imxrt1020-evk-u-boot.dtsi @@ -67,9 +67,6 @@
imxrt1020-evk { u-boot,dm-spl; - pinctrl_lpuart1: lpuart1grp { - u-boot,dm-spl; - };
pinctrl_semc: semcgrp { u-boot,dm-spl; @@ -81,6 +78,10 @@ }; };
+&pinctrl_lpuart1 { + u-boot,dm-spl; +}; + &usdhc1 { u-boot,dm-spl; }; diff --git a/arch/arm/dts/imxrt1020-evk.dts b/arch/arm/dts/imxrt1020-evk.dts index 22ae5ed7359..d4d1de4ea84 100644 --- a/arch/arm/dts/imxrt1020-evk.dts +++ b/arch/arm/dts/imxrt1020-evk.dts @@ -6,7 +6,6 @@
/dts-v1/; #include "imxrt1020.dtsi" -#include "imxrt1020-evk-u-boot.dtsi" #include "imxrt1020-pinfunc.h"
Synchronise device tree with linux v6.0-rc1.
arch/arm/dts/imxrt1050-evk-u-boot.dtsi | 25 +- arch/arm/dts/imxrt1050-evk.dts | 257 +++----------------- arch/arm/dts/imxrt1050-pinfunc.h | 2 +- arch/arm/dts/imxrt1050.dtsi | 168 ++++++------- include/dt-bindings/clock/imxrt1050-clock.h | 9 +- 5 files changed, 118 insertions(+), 343 deletions(-)
diff --git a/arch/arm/dts/imxrt1050-evk-u-boot.dtsi b/arch/arm/dts/imxrt1050-evk-u-boot.dtsi index 617cece448a..0da24965b67 100644 --- a/arch/arm/dts/imxrt1050-evk-u-boot.dtsi +++ b/arch/arm/dts/imxrt1050-evk-u-boot.dtsi @@ -50,7 +50,7 @@ u-boot,dm-spl; };
-&gpt1 { +&gpt { u-boot,dm-spl; };
@@ -58,33 +58,26 @@ u-boot,dm-spl; };
-&semc { - u-boot,dm-spl; - - bank1: bank@0 { - u-boot,dm-spl; - }; -}; - &iomuxc { u-boot,dm-spl;
imxrt1050-evk { u-boot,dm-spl; - pinctrl_lpuart1: lpuart1grp { - u-boot,dm-spl; - };
pinctrl_semc: semcgrp { u-boot,dm-spl; }; - - pinctrl_usdhc0: usdhc0grp { - u-boot,dm-spl; - }; }; };
+&pinctrl_lpuart1 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc0 { + u-boot,dm-spl; +}; + &usdhc1 { u-boot,dm-spl; }; diff --git a/arch/arm/dts/imxrt1050-evk.dts b/arch/arm/dts/imxrt1050-evk.dts index fb2da3adfcf..6a9c10decf5 100644 --- a/arch/arm/dts/imxrt1050-evk.dts +++ b/arch/arm/dts/imxrt1050-evk.dts @@ -1,4 +1,4 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Copyright (C) 2019 * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com @@ -6,7 +6,6 @@
/dts-v1/; #include "imxrt1050.dtsi" -#include "imxrt1050-evk-u-boot.dtsi" #include "imxrt1050-pinfunc.h"
/ { @@ -14,210 +13,52 @@ compatible = "fsl,imxrt1050-evk", "fsl,imxrt1050";
chosen { - bootargs = "root=/dev/ram"; - stdout-path = "serial0:115200n8"; - tick-timer = &gpt1; + stdout-path = &lpuart1; };
- memory { + aliases { + gpio0 = &gpio1; + gpio1 = &gpio2; + gpio2 = &gpio3; + gpio3 = &gpio4; + gpio4 = &gpio5; + mmc0 = &usdhc1; + serial0 = &lpuart1; + }; + + memory@80000000 { device_type = "memory"; reg = <0x80000000 0x2000000>; }; };
-&lpuart1 { /* console */ +&lpuart1 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_lpuart1>; status = "okay"; };
-&semc { - /* - * Memory configuration from sdram datasheet IS42S16160J-6BLI - */ - fsl,sdram-mux = /bits/ 8 <MUX_A8_SDRAM_A8 - MUX_CSX0_SDRAM_CS1 - 0 - 0 - 0 - 0>; - fsl,sdram-control = /bits/ 8 <MEM_WIDTH_16BITS - BL_8 - COL_9BITS - CL_3>; - fsl,sdram-timing = /bits/ 8 <0x2 - 0x2 - 0x9 - 0x1 - 0x5 - 0x6 - - 0x20 - 0x09 - 0x01 - 0x00 - - 0x04 - 0x0A - 0x21 - 0x50>; - - bank1: bank@0 { - fsl,base-address = <0x80000000>; - fsl,memory-size = <MEM_SIZE_32M>; - }; -}; - &iomuxc { pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_lpuart1>; - - imxrt1050-evk { - pinctrl_lpuart1: lpuart1grp { - fsl,pins = < - MXRT1050_IOMUXC_GPIO_AD_B0_12_LPUART1_TXD - 0xf1 - MXRT1050_IOMUXC_GPIO_AD_B0_13_LPUART1_RXD - 0xf1 - >; - }; - - pinctrl_semc: semcgrp { - fsl,pins = < - MXRT1050_IOMUXC_GPIO_EMC_00_SEMC_DA00 - 0xf1 /* SEMC_D0 */ - MXRT1050_IOMUXC_GPIO_EMC_01_SEMC_DA01 - 0xf1 /* SEMC_D1 */ - MXRT1050_IOMUXC_GPIO_EMC_02_SEMC_DA02 - 0xf1 /* SEMC_D2 */ - MXRT1050_IOMUXC_GPIO_EMC_03_SEMC_DA03 - 0xf1 /* SEMC_D3 */ - MXRT1050_IOMUXC_GPIO_EMC_04_SEMC_DA04 - 0xf1 /* SEMC_D4 */ - MXRT1050_IOMUXC_GPIO_EMC_05_SEMC_DA05 - 0xf1 /* SEMC_D5 */ - MXRT1050_IOMUXC_GPIO_EMC_06_SEMC_DA06 - 0xf1 /* SEMC_D6 */ - MXRT1050_IOMUXC_GPIO_EMC_07_SEMC_DA07 - 0xf1 /* SEMC_D7 */ - MXRT1050_IOMUXC_GPIO_EMC_08_SEMC_DM00 - 0xf1 /* SEMC_DM0 */ - MXRT1050_IOMUXC_GPIO_EMC_09_SEMC_ADDR00 - 0xf1 /* SEMC_A0 */ - MXRT1050_IOMUXC_GPIO_EMC_10_SEMC_ADDR01 - 0xf1 /* SEMC_A1 */ - MXRT1050_IOMUXC_GPIO_EMC_11_SEMC_ADDR02 - 0xf1 /* SEMC_A2 */ - MXRT1050_IOMUXC_GPIO_EMC_12_SEMC_ADDR03 - 0xf1 /* SEMC_A3 */ - MXRT1050_IOMUXC_GPIO_EMC_13_SEMC_ADDR04 - 0xf1 /* SEMC_A4 */ - MXRT1050_IOMUXC_GPIO_EMC_14_SEMC_ADDR05 - 0xf1 /* SEMC_A5 */ - MXRT1050_IOMUXC_GPIO_EMC_15_SEMC_ADDR06 - 0xf1 /* SEMC_A6 */ - MXRT1050_IOMUXC_GPIO_EMC_16_SEMC_ADDR07 - 0xf1 /* SEMC_A7 */ - MXRT1050_IOMUXC_GPIO_EMC_17_SEMC_ADDR08 - 0xf1 /* SEMC_A8 */ - MXRT1050_IOMUXC_GPIO_EMC_18_SEMC_ADDR09 - 0xf1 /* SEMC_A9 */ - MXRT1050_IOMUXC_GPIO_EMC_19_SEMC_ADDR11 - 0xf1 /* SEMC_A11 */ - MXRT1050_IOMUXC_GPIO_EMC_20_SEMC_ADDR12 - 0xf1 /* SEMC_A12 */ - MXRT1050_IOMUXC_GPIO_EMC_21_SEMC_BA0 - 0xf1 /* SEMC_BA0 */ - MXRT1050_IOMUXC_GPIO_EMC_22_SEMC_BA1 - 0xf1 /* SEMC_BA1 */ - MXRT1050_IOMUXC_GPIO_EMC_23_SEMC_ADDR10 - 0xf1 /* SEMC_A10 */ - MXRT1050_IOMUXC_GPIO_EMC_24_SEMC_CAS - 0xf1 /* SEMC_CAS */ - MXRT1050_IOMUXC_GPIO_EMC_25_SEMC_RAS - 0xf1 /* SEMC_RAS */ - MXRT1050_IOMUXC_GPIO_EMC_26_SEMC_CLK - 0xf1 /* SEMC_CLK */ - MXRT1050_IOMUXC_GPIO_EMC_27_SEMC_CKE - 0xf1 /* SEMC_CKE */ - MXRT1050_IOMUXC_GPIO_EMC_28_SEMC_WE - 0xf1 /* SEMC_WE */ - MXRT1050_IOMUXC_GPIO_EMC_29_SEMC_CS0 - 0xf1 /* SEMC_CS0 */ - MXRT1050_IOMUXC_GPIO_EMC_30_SEMC_DA08 - 0xf1 /* SEMC_D8 */ - MXRT1050_IOMUXC_GPIO_EMC_31_SEMC_DA09 - 0xf1 /* SEMC_D9 */ - MXRT1050_IOMUXC_GPIO_EMC_32_SEMC_DA10 - 0xf1 /* SEMC_D10 */ - MXRT1050_IOMUXC_GPIO_EMC_33_SEMC_DA11 - 0xf1 /* SEMC_D11 */ - MXRT1050_IOMUXC_GPIO_EMC_34_SEMC_DA12 - 0xf1 /* SEMC_D12 */ - MXRT1050_IOMUXC_GPIO_EMC_35_SEMC_DA13 - 0xf1 /* SEMC_D13 */ - MXRT1050_IOMUXC_GPIO_EMC_36_SEMC_DA14 - 0xf1 /* SEMC_D14 */ - MXRT1050_IOMUXC_GPIO_EMC_37_SEMC_DA15 - 0xf1 /* SEMC_D15 */ - MXRT1050_IOMUXC_GPIO_EMC_38_SEMC_DM01 - 0xf1 /* SEMC_DM1 */ - MXRT1050_IOMUXC_GPIO_EMC_39_SEMC_DQS - (IMX_PAD_SION | 0xf1) /* SEMC_DQS */ - >; - }; - - pinctrl_usdhc0: usdhc0grp { - fsl,pins = < - MXRT1050_IOMUXC_GPIO_B1_12_USDHC1_CD_B - 0x1B000 - MXRT1050_IOMUXC_GPIO_B1_14_USDHC1_VSELECT - 0xB069 - MXRT1050_IOMUXC_GPIO_SD_B0_00_USDHC1_CMD - 0x17061 - MXRT1050_IOMUXC_GPIO_SD_B0_01_USDHC1_CLK - 0x17061 - MXRT1050_IOMUXC_GPIO_SD_B0_05_USDHC1_DATA3 - 0x17061 - MXRT1050_IOMUXC_GPIO_SD_B0_04_USDHC1_DATA2 - 0x17061 - MXRT1050_IOMUXC_GPIO_SD_B0_03_USDHC1_DATA1 - 0x17061 - MXRT1050_IOMUXC_GPIO_SD_B0_02_USDHC1_DATA0 - 0x17061 - >; - }; - - pinctrl_lcdif: lcdifgrp { - fsl,pins = < - MXRT1050_IOMUXC_GPIO_B0_00_LCD_CLK 0x1b0b1 - MXRT1050_IOMUXC_GPIO_B0_01_LCD_ENABLE 0x1b0b1 - MXRT1050_IOMUXC_GPIO_B0_02_LCD_HSYNC 0x1b0b1 - MXRT1050_IOMUXC_GPIO_B0_03_LCD_VSYNC 0x1b0b1 - MXRT1050_IOMUXC_GPIO_B0_04_LCD_DATA00 0x1b0b1 - MXRT1050_IOMUXC_GPIO_B0_05_LCD_DATA01 0x1b0b1 - MXRT1050_IOMUXC_GPIO_B0_06_LCD_DATA02 0x1b0b1 - MXRT1050_IOMUXC_GPIO_B0_07_LCD_DATA03 0x1b0b1 - MXRT1050_IOMUXC_GPIO_B0_08_LCD_DATA04 0x1b0b1 - MXRT1050_IOMUXC_GPIO_B0_09_LCD_DATA05 0x1b0b1 - MXRT1050_IOMUXC_GPIO_B0_10_LCD_DATA06 0x1b0b1 - MXRT1050_IOMUXC_GPIO_B0_11_LCD_DATA07 0x1b0b1 - MXRT1050_IOMUXC_GPIO_B0_12_LCD_DATA08 0x1b0b1 - MXRT1050_IOMUXC_GPIO_B0_13_LCD_DATA09 0x1b0b1 - MXRT1050_IOMUXC_GPIO_B0_14_LCD_DATA10 0x1b0b1 - MXRT1050_IOMUXC_GPIO_B0_15_LCD_DATA11 0x1b0b1 - MXRT1050_IOMUXC_GPIO_B1_01_LCD_DATA13 0x1b0b1 - MXRT1050_IOMUXC_GPIO_B1_02_LCD_DATA14 0x1b0b1 - MXRT1050_IOMUXC_GPIO_B1_03_LCD_DATA15 0x1b0b1 - MXRT1050_IOMUXC_GPIO_B1_15_GPIO2_IO31 0x0b069 - MXRT1050_IOMUXC_GPIO_AD_B0_02_GPIO1_IO02 0x0b069 - >; - }; + pinctrl_lpuart1: lpuart1grp { + fsl,pins = < + MXRT1050_IOMUXC_GPIO_AD_B0_12_LPUART1_TXD 0xf1 + MXRT1050_IOMUXC_GPIO_AD_B0_13_LPUART1_RXD 0xf1 + >; }; -};
-&gpt1 { - status = "okay"; + pinctrl_usdhc0: usdhc0grp { + fsl,pins = < + MXRT1050_IOMUXC_GPIO_B1_12_USDHC1_CD_B 0x1B000 + MXRT1050_IOMUXC_GPIO_B1_14_USDHC1_VSELECT 0xB069 + MXRT1050_IOMUXC_GPIO_SD_B0_00_USDHC1_CMD 0x17061 + MXRT1050_IOMUXC_GPIO_SD_B0_01_USDHC1_CLK 0x17061 + MXRT1050_IOMUXC_GPIO_SD_B0_05_USDHC1_DATA3 0x17061 + MXRT1050_IOMUXC_GPIO_SD_B0_04_USDHC1_DATA2 0x17061 + MXRT1050_IOMUXC_GPIO_SD_B0_03_USDHC1_DATA1 0x17061 + MXRT1050_IOMUXC_GPIO_SD_B0_02_USDHC1_DATA0 0x17061 + >; + }; };
&usdhc1 { @@ -226,42 +67,6 @@ pinctrl-1 = <&pinctrl_usdhc0>; pinctrl-2 = <&pinctrl_usdhc0>; pinctrl-3 = <&pinctrl_usdhc0>; - status = "okay"; - cd-gpios = <&gpio2 28 GPIO_ACTIVE_LOW>; -}; - -&lcdif { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_lcdif>; - display = <&display0>; - status = "okay"; - - display0: display0 { - bits-per-pixel = <16>; - bus-width = <16>; - - display-timings { - timing0: timing0 { - clock-frequency = <9300000>; - hactive = <480>; - vactive = <272>; - hback-porch = <4>; - hfront-porch = <8>; - vback-porch = <4>; - vfront-porch = <8>; - hsync-len = <41>; - vsync-len = <10>; - de-active = <1>; - pixelclk-active = <0>; - hsync-active = <0>; - vsync-active = <0>; - }; - }; - }; -}; - -&usbotg1 { - dr_mode = "host"; status = "okay"; }; diff --git a/arch/arm/dts/imxrt1050-pinfunc.h b/arch/arm/dts/imxrt1050-pinfunc.h index a29031ab3de..22c14a3262a 100644 --- a/arch/arm/dts/imxrt1050-pinfunc.h +++ b/arch/arm/dts/imxrt1050-pinfunc.h @@ -1,4 +1,4 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ /* * Copyright (C) 2019 * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com diff --git a/arch/arm/dts/imxrt1050.dtsi b/arch/arm/dts/imxrt1050.dtsi index 09f4712af68..03e6a858a7b 100644 --- a/arch/arm/dts/imxrt1050.dtsi +++ b/arch/arm/dts/imxrt1050.dtsi @@ -1,4 +1,4 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Copyright (C) 2019 * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com @@ -8,53 +8,37 @@ #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/clock/imxrt1050-clock.h> #include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/memory/imxrt-sdram.h>
/ { #address-cells = <1>; #size-cells = <1>;
- aliases { - display0 = &lcdif; - gpio0 = &gpio1; - gpio1 = &gpio2; - gpio2 = &gpio3; - gpio3 = &gpio4; - gpio4 = &gpio5; - mmc0 = &usdhc1; - serial0 = &lpuart1; - usbphy0 = &usbphy1; - }; - clocks { osc: osc { - compatible = "fsl,imx-osc", "fixed-clock"; + compatible = "fixed-clock"; #clock-cells = <0>; clock-frequency = <24000000>; }; - };
- soc { - semc: semc@402f0000 { - compatible = "fsl,imxrt-semc"; - reg = <0x402f0000 0x4000>; - clocks = <&clks IMXRT1050_CLK_SEMC>; - pinctrl-0 = <&pinctrl_semc>; - pinctrl-names = "default"; - status = "okay"; + osc3M: osc3M { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <3000000>; }; + };
+ soc { lpuart1: serial@40184000 { - compatible = "fsl,imxrt-lpuart"; + compatible = "fsl,imxrt1050-lpuart", "fsl,imx7ulp-lpuart"; reg = <0x40184000 0x4000>; - interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <20>; clocks = <&clks IMXRT1050_CLK_LPUART1>; - clock-names = "per"; + clock-names = "ipg"; status = "disabled"; };
- iomuxc: iomuxc@401f8000 { - compatible = "fsl,imxrt-iomuxc"; + iomuxc: pinctrl@401f8000 { + compatible = "fsl,imxrt1050-iomuxc"; reg = <0x401f8000 0x4000>; fsl,mux_mask = <0x7>; }; @@ -64,31 +48,61 @@ reg = <0x400d8000 0x4000>; };
- clks: ccm@400fc000 { + clks: clock-controller@400fc000 { compatible = "fsl,imxrt1050-ccm"; reg = <0x400fc000 0x4000>; - interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <95>, <96>; + clocks = <&osc>; + clock-names = "osc"; #clock-cells = <1>; - }; - - usdhc1: usdhc@402c0000 { - compatible = "fsl,imxrt-usdhc"; - reg = <0x402c0000 0x10000>; - interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMXRT1050_CLK_USDHC1>; - clock-names = "per"; + assigned-clocks = <&clks IMXRT1050_CLK_PLL1_BYPASS>, + <&clks IMXRT1050_CLK_PLL1_BYPASS>, + <&clks IMXRT1050_CLK_PLL2_BYPASS>, + <&clks IMXRT1050_CLK_PLL3_BYPASS>, + <&clks IMXRT1050_CLK_PLL3_PFD1_664_62M>, + <&clks IMXRT1050_CLK_PLL2_PFD2_396M>; + assigned-clock-parents = <&clks IMXRT1050_CLK_PLL1_REF_SEL>, + <&clks IMXRT1050_CLK_PLL1_ARM>, + <&clks IMXRT1050_CLK_PLL2_SYS>, + <&clks IMXRT1050_CLK_PLL3_USB_OTG>, + <&clks IMXRT1050_CLK_PLL3_USB_OTG>, + <&clks IMXRT1050_CLK_PLL2_SYS>; + }; + + edma1: dma-controller@400e8000 { + #dma-cells = <2>; + compatible = "fsl,imx7ulp-edma"; + reg = <0x400e8000 0x4000>, + <0x400ec000 0x4000>; + dma-channels = <32>; + interrupts = <0>, <1>, <2>, <3>, <4>, <5>, <6>, <7>, <8>, + <9>, <10>, <11>, <12>, <13>, <14>, <15>, <16>; + clock-names = "dma", "dmamux0"; + clocks = <&clks IMXRT1050_CLK_DMA>, + <&clks IMXRT1050_CLK_DMA_MUX>; + }; + + usdhc1: mmc@402c0000 { + compatible = "fsl,imxrt1050-usdhc", "fsl,imx6sl-usdhc"; + reg = <0x402c0000 0x4000>; + interrupts = <110>; + clocks = <&clks IMXRT1050_CLK_IPG_PDOF>, + <&clks IMXRT1050_CLK_OSC>, + <&clks IMXRT1050_CLK_USDHC1>; + clock-names = "ipg", "ahb", "per"; bus-width = <4>; + fsl,wp-controller; + no-1-8-v; + max-frequency = <4000000>; fsl,tuning-start-tap = <20>; - fsl,tuning-step= <2>; + fsl,tuning-step = <2>; status = "disabled"; };
gpio1: gpio@401b8000 { - compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; + compatible = "fsl,imxrt1050-gpio", "fsl,imx35-gpio"; reg = <0x401b8000 0x4000>; - interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <80>, <81>; gpio-controller; #gpio-cells = <2>; interrupt-controller; @@ -96,10 +110,9 @@ };
gpio2: gpio@401bc000 { - compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; + compatible = "fsl,imxrt1050-gpio", "fsl,imx35-gpio"; reg = <0x401bc000 0x4000>; - interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <82>, <83>; gpio-controller; #gpio-cells = <2>; interrupt-controller; @@ -107,10 +120,9 @@ };
gpio3: gpio@401c0000 { - compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; + compatible = "fsl,imxrt1050-gpio", "fsl,imx35-gpio"; reg = <0x401c0000 0x4000>; - interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <84>, <85>; gpio-controller; #gpio-cells = <2>; interrupt-controller; @@ -118,10 +130,9 @@ };
gpio4: gpio@401c4000 { - compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; + compatible = "fsl,imxrt1050-gpio", "fsl,imx35-gpio"; reg = <0x401c4000 0x4000>; - interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <86>, <87>; gpio-controller; #gpio-cells = <2>; interrupt-controller; @@ -129,60 +140,21 @@ };
gpio5: gpio@400c0000 { - compatible = "fsl,imxrt-gpio", "fsl,imx35-gpio"; + compatible = "fsl,imxrt1050-gpio", "fsl,imx35-gpio"; reg = <0x400c0000 0x4000>; - interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <88>, <89>; gpio-controller; #gpio-cells = <2>; interrupt-controller; #interrupt-cells = <2>; };
- lcdif: lcdif@402b8000 { - compatible = "fsl,imxrt-lcdif"; - reg = <0x402b8000 0x4000>; - interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMXRT1050_CLK_LCDIF_PIX>, - <&clks IMXRT1050_CLK_LCDIF_APB>; - clock-names = "pix", "axi"; - assigned-clocks = <&clks IMXRT1050_CLK_LCDIF_SEL>; - assigned-clock-parents = <&clks IMXRT1050_CLK_PLL5_VIDEO>; - status = "disabled"; - }; - - gpt1: gpt1@401ec000 { - compatible = "fsl,imxrt-gpt"; + gpt: timer@401ec000 { + compatible = "fsl,imxrt1050-gpt", "fsl,imx6dl-gpt", "fsl,imx6sl-gpt"; reg = <0x401ec000 0x4000>; interrupts = <100>; - clocks = <&osc>; - status = "disabled"; - }; - - usbphy1: usbphy@400d9000 { - compatible = "fsl,imxrt-usbphy"; - reg = <0x400d9000 0x1000>; - interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; - }; - - usbmisc: usbmisc@402e0800 { - #index-cells = <1>; - compatible = "fsl,imxrt-usbmisc"; - reg = <0x402e0800 0x200>; - clocks = <&clks IMXRT1050_CLK_USBOH3>; - }; - - usbotg1: usb@402e0000 { - compatible = "fsl,imxrt-usb", "fsl,imx27-usb"; - reg = <0x402e0000 0x200>; - interrupts = <GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMXRT1050_CLK_USBOH3>; - fsl,usbphy = <&usbphy1>; - fsl,usbmisc = <&usbmisc 0>; - ahb-burst-config = <0x0>; - tx-burst-size-dword = <0x10>; - rx-burst-size-dword = <0x10>; - status = "disabled"; + clocks = <&osc3M>; + clock-names = "per"; }; }; }; diff --git a/include/dt-bindings/clock/imxrt1050-clock.h b/include/dt-bindings/clock/imxrt1050-clock.h index f74dbbcf937..93bef0832d1 100644 --- a/include/dt-bindings/clock/imxrt1050-clock.h +++ b/include/dt-bindings/clock/imxrt1050-clock.h @@ -1,4 +1,4 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ /* * Copyright(C) 2019 * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com @@ -62,6 +62,11 @@ #define IMXRT1050_CLK_PLL7_USB_HOST 53 #define IMXRT1050_CLK_LCDIF_PIX 54 #define IMXRT1050_CLK_USBOH3 55 -#define IMXRT1050_CLK_END 56 +#define IMXRT1050_CLK_IPG_PDOF 56 +#define IMXRT1050_CLK_PER_CLK_SEL 57 +#define IMXRT1050_CLK_PER_PDOF 58 +#define IMXRT1050_CLK_DMA 59 +#define IMXRT1050_CLK_DMA_MUX 60 +#define IMXRT1050_CLK_END 61
#endif /* __DT_BINDINGS_CLOCK_IMXRT1050_H */
Hi Marcel,
Thanks for working on this.
-&semc {
MUX_CSX0_SDRAM_CS1
0
0
0
0>;
Shouldn't this go to imxrt1050-evk-u-boot.dts?
This node is responsible for describing the DDR timings. Removing it will cause boot regression.
I don't have access to this platform. Adding Jesse and Giulio.
On 8/26/22 06:49, Fabio Estevam wrote:
Hi Marcel,
-&semc {
MUX_CSX0_SDRAM_CS1
0
0
0
0>;
Yes it will. Linux doesn't have LCD or dram yet, it should be moved into imxrt1050-evk-u-boot.dtsi. If needed I can sync it as well as test.
Thanks, Jesse
Hi Fabio and Jesse
Hi Marcel,
Sorry, that I did not spot that one. I can update this and send out a v2 with that fixed shortly, don't worry. But if you can then test it that would be great. Thanks!
Thanks, Jesse
Cheers
Marcel
arch/arm/dts/imx8ulp-evk-u-boot.dtsi | 6 +- arch/arm/dts/imx8ulp-evk.dts | 191 +----- arch/arm/dts/imx8ulp-pinfunc.h | 4 +- arch/arm/dts/imx8ulp.dtsi | 564 +++++------------- include/dt-bindings/clock/imx8ulp-clock.h | 49 +- include/dt-bindings/power/imx8ulp-power.h | 26 + include/dt-bindings/reset/imx8ulp-pcc-reset.h | 59 ++ 7 files changed, 269 insertions(+), 630 deletions(-) create mode 100644 include/dt-bindings/power/imx8ulp-power.h create mode 100644 include/dt-bindings/reset/imx8ulp-pcc-reset.h
diff --git a/arch/arm/dts/imx8ulp-evk-u-boot.dtsi b/arch/arm/dts/imx8ulp-evk-u-boot.dtsi index 7c1dab2acfc..2743521f415 100644 --- a/arch/arm/dts/imx8ulp-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8ulp-evk-u-boot.dtsi @@ -3,7 +3,7 @@ * Copyright 2021 NXP */
-&{/soc@0} { +&soc { u-boot,dm-spl; };
@@ -23,10 +23,6 @@ u-boot,dm-spl; };
-&s400_mu { - u-boot,dm-spl; -}; - &lpuart5 { u-boot,dm-spl; }; diff --git a/arch/arm/dts/imx8ulp-evk.dts b/arch/arm/dts/imx8ulp-evk.dts index da09ff48ff8..33e84c4e9ed 100644 --- a/arch/arm/dts/imx8ulp-evk.dts +++ b/arch/arm/dts/imx8ulp-evk.dts @@ -1,4 +1,4 @@ -// SPDX-License-Identifier: (GPL-2.0 OR MIT) +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Copyright 2021 NXP */ @@ -8,17 +8,16 @@ #include "imx8ulp.dtsi"
/ { - model = "FSL i.MX8ULP EVK"; + model = "NXP i.MX8ULP EVK"; compatible = "fsl,imx8ulp-evk", "fsl,imx8ulp";
chosen { stdout-path = &lpuart5; - bootargs = "console=ttyLP1,115200 earlycon"; };
- usdhc2_pwrseq: usdhc2_pwrseq { - compatible = "mmc-pwrseq-simple"; - reset-gpios = <&pcal6408 2 GPIO_ACTIVE_LOW>; + memory@80000000 { + device_type = "memory"; + reg = <0x0 0x80000000 0 0x80000000>; }; };
@@ -30,24 +29,25 @@ status = "okay"; };
+&usdhc0 { + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&pinctrl_usdhc0>; + pinctrl-1 = <&pinctrl_usdhc0>; + non-removable; + bus-width = <8>; + status = "okay"; +}; + &iomuxc1 { pinctrl_lpuart5: lpuart5grp { fsl,pins = < - MX8ULP_PAD_PTF14__LPUART5_TX 0x03 - MX8ULP_PAD_PTF15__LPUART5_RX 0x03 - >; - }; - - pinctrl_lpi2c7: lpi2c7grp { - fsl,pins = < - MX8ULP_PAD_PTE12__LPI2C7_SCL 0x27 - MX8ULP_PAD_PTE13__LPI2C7_SDA 0x27 + MX8ULP_PAD_PTF14__LPUART5_TX 0x3 + MX8ULP_PAD_PTF15__LPUART5_RX 0x3 >; };
pinctrl_usdhc0: usdhc0grp { fsl,pins = < - MX8ULP_PAD_PTD0__SDHC0_RESET_B 0x43 MX8ULP_PAD_PTD1__SDHC0_CMD 0x43 MX8ULP_PAD_PTD2__SDHC0_CLK 0x10042 MX8ULP_PAD_PTD10__SDHC0_D0 0x43 @@ -61,163 +61,4 @@ MX8ULP_PAD_PTD11__SDHC0_DQS 0x10042 >; }; - - pinctrl_usdhc2_pte: usdhc2ptegrp { - fsl,pins = < - MX8ULP_PAD_PTE1__SDHC2_D0 0x43 - MX8ULP_PAD_PTE0__SDHC2_D1 0x43 - MX8ULP_PAD_PTE5__SDHC2_D2 0x43 - MX8ULP_PAD_PTE4__SDHC2_D3 0x43 - MX8ULP_PAD_PTE2__SDHC2_CLK 0x10042 - MX8ULP_PAD_PTE3__SDHC2_CMD 0x43 - MX8ULP_PAD_PTE7__PTE7 0x10003 - >; - }; - - pinctrl_fec: fecgrp { - fsl,pins = < - MX8ULP_PAD_PTE14__ENET0_MDIO 0x43 - MX8ULP_PAD_PTE15__ENET0_MDC 0x43 - MX8ULP_PAD_PTE18__ENET0_CRS_DV 0x43 - MX8ULP_PAD_PTE17__ENET0_RXER 0x43 - MX8ULP_PAD_PTF1__ENET0_RXD0 0x43 - MX8ULP_PAD_PTE20__ENET0_RXD1 0x43 - MX8ULP_PAD_PTE16__ENET0_TXEN 0x43 - MX8ULP_PAD_PTE23__ENET0_TXD0 0x43 - MX8ULP_PAD_PTE22__ENET0_TXD1 0x43 - MX8ULP_PAD_PTE19__ENET0_REFCLK 0x10043 - MX8ULP_PAD_PTF10__ENET0_1588_CLKIN 0x10043 - >; - }; - - pinctrl_usbotg0_id: otg0idgrp { - fsl,pins = < - MX8ULP_PAD_PTF2__USB0_ID 0x10003 - >; - }; - - pinctrl_usbotg1_id: otg1idgrp { - fsl,pins = < - MX8ULP_PAD_PTD23__USB1_ID 0x10003 - >; - }; -}; - -&usdhc0 { - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc0>; - pinctrl-1 = <&pinctrl_usdhc0>; - pinctrl-2 = <&pinctrl_usdhc0>; - bus-width = <8>; - non-removable; - status = "okay"; -}; - -&usdhc2 { - pinctrl-names = "default", "state_100mhz", "state_200mhz", "sleep"; - pinctrl-0 = <&pinctrl_usdhc2_pte>; - pinctrl-1 = <&pinctrl_usdhc2_pte>; - pinctrl-2 = <&pinctrl_usdhc2_pte>; - pinctrl-3 = <&pinctrl_usdhc2_pte>; - mmc-pwrseq = <&usdhc2_pwrseq>; - max-frequency = <100000000>; - bus-width = <4>; - keep-power-in-suspend; - non-removable; - wakeup-source; - status = "okay"; - - wifi_wake_host { - compatible = "nxp,wifi-wake-host"; - interrupt-parent = <&gpioe>; - interrupts = <7 IRQ_TYPE_LEVEL_LOW>; - interrupt-names = "host-wake"; - }; -}; - -&lpi2c7 { - #address-cells = <1>; - #size-cells = <0>; - clock-frequency = <100000>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_lpi2c7>; - status = "okay"; - - pcal6408: gpio@21 { - compatible = "ti,tca6408"; - reg = <0x21>; - gpio-controller; - #gpio-cells = <2>; - }; -}; - -&flexspi0 { - status = "okay"; - - flash0: atxp032@0 { - reg = <0>; - #address-cells = <1>; - #size-cells = <1>; - compatible = "jedec,spi-nor"; - spi-max-frequency = <66000000>; - }; -}; - -&flexspi2 { - status = "okay"; - - flash1: mt35xu512aba@0 { - reg = <0>; - #address-cells = <1>; - #size-cells = <1>; - compatible = "jedec,spi-nor"; - spi-max-frequency = <29000000>; - spi-nor,ddr-quad-read-dummy = <8>; - }; -}; - -&fec { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_fec>; - phy-mode = "rmii"; - phy-handle = <ðphy>; - status = "okay"; - - phy-reset-gpios = <&pcal6408 4 GPIO_ACTIVE_LOW>; - - mdio { - #address-cells = <1>; - #size-cells = <0>; - - ethphy: ethernet-phy@1 { - reg = <1>; - micrel,led-mode = <1>; - }; - }; -}; - -&usbotg0 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usbotg0_id>; - srp-disable; - hnp-disable; - adp-disable; - status = "okay"; -}; - -&usbphy0 { - fsl,tx-d-cal = <88>; -}; - -&usbotg1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usbotg1_id>; - srp-disable; - hnp-disable; - adp-disable; - status = "okay"; -}; - -&usbphy1 { - fsl,tx-d-cal = <88>; }; diff --git a/arch/arm/dts/imx8ulp-pinfunc.h b/arch/arm/dts/imx8ulp-pinfunc.h index c21c3b644e5..b204ac79b44 100644 --- a/arch/arm/dts/imx8ulp-pinfunc.h +++ b/arch/arm/dts/imx8ulp-pinfunc.h @@ -1,6 +1,6 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ +/* SPDX-License-Identifier: GPL-2.0+ OR MIT */ /* - * Copyright 2020 NXP + * Copyright 2021 NXP */
#ifndef __DTS_IMX8ULP_PINFUNC_H diff --git a/arch/arm/dts/imx8ulp.dtsi b/arch/arm/dts/imx8ulp.dtsi index d3b16bd2feb..60c1b018bf0 100644 --- a/arch/arm/dts/imx8ulp.dtsi +++ b/arch/arm/dts/imx8ulp.dtsi @@ -1,4 +1,4 @@ -// SPDX-License-Identifier: (GPL-2.0 OR MIT) +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Copyright 2021 NXP */ @@ -6,6 +6,8 @@ #include <dt-bindings/clock/imx8ulp-clock.h> #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/power/imx8ulp-power.h> + #include "imx8ulp-pinfunc.h"
/ { @@ -17,46 +19,25 @@ gpio0 = &gpiod; gpio1 = &gpioe; gpio2 = &gpiof; - serial0 = &lpuart5; mmc0 = &usdhc0; mmc1 = &usdhc1; mmc2 = &usdhc2; - spi0 = &flexspi0; - spi2 = &flexspi2; - ethernet0 = &fec; - i2c7 = &lpi2c7; - usbphy0 = &usbphy0; - usb0 = &usbotg0; - usbphy1 = &usbphy1; - usb1 = &usbotg1; + serial0 = &lpuart4; + serial1 = &lpuart5; + serial2 = &lpuart6; + serial3 = &lpuart7; };
- cpus: cpus { + cpus { #address-cells = <2>; #size-cells = <0>;
- idle-states { - entry-method = "psci"; - - CPU_SLEEP: cpu-sleep { - compatible = "arm,idle-state"; - arm,psci-suspend-param = <0x0010033>; - local-timer-stop; - entry-latency-us = <1000>; - exit-latency-us = <700>; - min-residency-us = <2700>; - wakeup-latency-us = <1500>; - }; - }; - - /* We have 1 clusters with 4 Cortex-A35 cores */ A35_0: cpu@0 { device_type = "cpu"; compatible = "arm,cortex-a35"; reg = <0x0 0x0>; enable-method = "psci"; next-level-cache = <&A35_L2>; - clocks = <&cgc1 IMX8ULP_CLK_A35_DIV>; };
A35_1: cpu@1 { @@ -65,7 +46,6 @@ reg = <0x0 0x1>; enable-method = "psci"; next-level-cache = <&A35_L2>; - clocks = <&cgc1 IMX8ULP_CLK_A35_DIV>; };
A35_L2: l2-cache0 { @@ -73,37 +53,6 @@ }; };
- a35_opp_table: opp-table { - compatible = "operating-points-v2"; - opp-shared; - - opp-504000000 { - opp-hz = /bits/ 64 <504000000>; - opp-microvolt = <800000>; - clock-latency-ns = <150000>; - }; - - opp-744000000 { - opp-hz = /bits/ 64 <744000000>; - opp-microvolt = <900000>; - clock-latency-ns = <150000>; - }; - - opp-1008000000 { - opp-hz = /bits/ 64 <1008000000>; - opp-microvolt = <1000000>; - clock-latency-ns = <150000>; - opp-suspend; - }; - }; - - s400_mu: mu@27020000 { - u-boot,dm-spl; - compatible = "fsl,imx8ulp-mu"; - reg = <0 0x27020000 0 0x10000>; - status = "okay"; - }; - gic: interrupt-controller@2d400000 { compatible = "arm,gic-v3"; reg = <0x0 0x2d400000 0 0x10000>, /* GIC Dist */ @@ -154,7 +103,7 @@ #clock-cells = <0>; };
- sram@0x2201f000 { + sram@2201f000 { compatible = "mmio-sram"; reg = <0x0 0x2201f000 0x0 0x1000>;
@@ -162,10 +111,9 @@ #size-cells = <1>; ranges = <0 0x0 0x2201f000 0x1000>;
- /* TODO: split or unify */ - scmi_pd: scmi_pd@0 { + scmi_buf: scmi-buf@0 { compatible = "arm,scmi-shmem"; - reg = <0x0 0x200>; + reg = <0x0 0x400>; }; };
@@ -175,42 +123,25 @@ arm,smc-id = <0xc20000fe>; #address-cells = <1>; #size-cells = <0>; - shmem = <&scmi_pd>; + shmem = <&scmi_buf>;
scmi_devpd: protocol@11 { reg = <0x11>; #power-domain-cells = <1>; };
- scmi_perf: protocol@13 { - reg = <0x13>; + scmi_sensor: protocol@15 { + reg = <0x15>; + #thermal-sensor-cells = <1>; }; }; };
- soc@0 { + soc: soc@0 { compatible = "simple-bus"; #address-cells = <1>; #size-cells = <1>; - ranges = <0x0 0x0 0x0 0x80000000>; - - per_bridge0: bus@28000000 { - compatible = "simple-bus"; - reg = <0x28000000 0x800000>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - - flexspi0: flexspi@28039000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "nxp,imx8ulp-fspi"; - reg = <0x28039000 0x10000>, - <0x04000000 0x7ffffff>; - reg-names = "fspi_base", "fspi_mmap"; - status = "disabled"; - }; - }; + ranges = <0x0 0x0 0x0 0x40000000>;
per_bridge3: bus@29000000 { compatible = "simple-bus"; @@ -219,119 +150,13 @@ #size-cells = <1>; ranges;
- edma1: dma-controller@29010000 { - compatible = "fsl,imx8ulp-edma"; - reg = <0x29010000 0x10000>, - <0x29020000 0x10000>, <0x29030000 0x10000>, - <0x29040000 0x10000>, <0x29050000 0x10000>, - <0x29060000 0x10000>, <0x29070000 0x10000>, - <0x29080000 0x10000>, <0x29090000 0x10000>, - <0x290a0000 0x10000>, <0x290b0000 0x10000>, - <0x290c0000 0x10000>, <0x290d0000 0x10000>, - <0x290e0000 0x10000>, <0x290f0000 0x10000>, - <0x29100000 0x10000>, <0x29110000 0x10000>, - <0x29120000 0x10000>, <0x29130000 0x10000>, - <0x29140000 0x10000>, <0x29150000 0x10000>, - <0x29160000 0x10000>, <0x29170000 0x10000>, - <0x29180000 0x10000>, <0x29190000 0x10000>, - <0x291a0000 0x10000>, <0x291b0000 0x10000>, - <0x291c0000 0x10000>, <0x291d0000 0x10000>, - <0x291e0000 0x10000>, <0x291f0000 0x10000>, - <0x29200000 0x10000>, <0x29210000 0x10000>; - #dma-cells = <3>; - dma-channels = <32>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "edma1-chan0-tx", "edma1-chan1-tx", - "edma1-chan2-tx", "edma1-chan3-tx", - "edma1-chan4-tx", "edma1-chan5-tx", - "edma1-chan6-tx", "edma1-chan7-tx", - "edma1-chan8-tx", "edma1-chan9-tx", - "edma1-chan10-tx", "edma1-chan11-tx", - "edma1-chan12-tx", "edma1-chan13-tx", - "edma1-chan14-tx", "edma1-chan15-tx", - "edma1-chan16-tx", "edma1-chan17-tx", - "edma1-chan18-tx", "edma1-chan19-tx", - "edma1-chan20-tx", "edma1-chan21-tx", - "edma1-chan22-tx", "edma1-chan23-tx", - "edma1-chan24-tx", "edma1-chan25-tx", - "edma1-chan26-tx", "edma1-chan27-tx", - "edma1-chan28-tx", "edma1-chan29-tx", - "edma1-chan30-tx", "edma1-chan31-tx"; - clocks = <&pcc3 IMX8ULP_CLK_DMA1_MP>, - <&pcc3 IMX8ULP_CLK_DMA1_CH0>, <&pcc3 IMX8ULP_CLK_DMA1_CH1>, - <&pcc3 IMX8ULP_CLK_DMA1_CH2>, <&pcc3 IMX8ULP_CLK_DMA1_CH3>, - <&pcc3 IMX8ULP_CLK_DMA1_CH4>, <&pcc3 IMX8ULP_CLK_DMA1_CH5>, - <&pcc3 IMX8ULP_CLK_DMA1_CH6>, <&pcc3 IMX8ULP_CLK_DMA1_CH7>, - <&pcc3 IMX8ULP_CLK_DMA1_CH8>, <&pcc3 IMX8ULP_CLK_DMA1_CH9>, - <&pcc3 IMX8ULP_CLK_DMA1_CH10>, <&pcc3 IMX8ULP_CLK_DMA1_CH11>, - <&pcc3 IMX8ULP_CLK_DMA1_CH12>, <&pcc3 IMX8ULP_CLK_DMA1_CH13>, - <&pcc3 IMX8ULP_CLK_DMA1_CH14>, <&pcc3 IMX8ULP_CLK_DMA1_CH15>, - <&pcc3 IMX8ULP_CLK_DMA1_CH16>, <&pcc3 IMX8ULP_CLK_DMA1_CH17>, - <&pcc3 IMX8ULP_CLK_DMA1_CH18>, <&pcc3 IMX8ULP_CLK_DMA1_CH19>, - <&pcc3 IMX8ULP_CLK_DMA1_CH20>, <&pcc3 IMX8ULP_CLK_DMA1_CH21>, - <&pcc3 IMX8ULP_CLK_DMA1_CH22>, <&pcc3 IMX8ULP_CLK_DMA1_CH23>, - <&pcc3 IMX8ULP_CLK_DMA1_CH24>, <&pcc3 IMX8ULP_CLK_DMA1_CH25>, - <&pcc3 IMX8ULP_CLK_DMA1_CH26>, <&pcc3 IMX8ULP_CLK_DMA1_CH27>, - <&pcc3 IMX8ULP_CLK_DMA1_CH28>, <&pcc3 IMX8ULP_CLK_DMA1_CH29>, - <&pcc3 IMX8ULP_CLK_DMA1_CH30>, <&pcc3 IMX8ULP_CLK_DMA1_CH31>; - clock-names = "edma-mp-clk", - "edma1-chan0-clk", "edma1-chan1-clk", - "edma1-chan2-clk", "edma1-chan3-clk", - "edma1-chan4-clk", "edma1-chan5-clk", - "edma1-chan6-clk", "edma1-chan7-clk", - "edma1-chan8-clk", "edma1-chan9-clk", - "edma1-chan10-clk", "edma1-chan11-clk", - "edma1-chan12-clk", "edma1-chan13-clk", - "edma1-chan14-clk", "edma1-chan15-clk", - "edma1-chan16-clk", "edma1-chan17-clk", - "edma1-chan18-clk", "edma1-chan19-clk", - "edma1-chan20-clk", "edma1-chan21-clk", - "edma1-chan22-clk", "edma1-chan23-clk", - "edma1-chan24-clk", "edma1-chan25-clk", - "edma1-chan26-clk", "edma1-chan27-clk", - "edma1-chan28-clk", "edma1-chan29-clk", - "edma1-chan30-clk", "edma1-chan31-clk"; - status = "okay"; - }; - wdog3: watchdog@292a0000 { compatible = "fsl,imx8ulp-wdt", "fsl,imx7ulp-wdt"; reg = <0x292a0000 0x10000>; interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>; clocks = <&pcc3 IMX8ULP_CLK_WDOG3>; assigned-clocks = <&pcc3 IMX8ULP_CLK_WDOG3>; - assigned-clocks-parents = <&cgc1 IMX8ULP_CLK_SOSC_DIV2>; + assigned-clock-parents = <&cgc1 IMX8ULP_CLK_SOSC_DIV2>; timeout-sec = <40>; };
@@ -356,6 +181,33 @@ clocks = <&pcc3 IMX8ULP_CLK_TPM5>, <&pcc3 IMX8ULP_CLK_TPM5>; clock-names = "ipg", "per"; + status = "disabled"; + }; + + lpi2c4: i2c@29370000 { + compatible = "fsl,imx8ulp-lpi2c", "fsl,imx7ulp-lpi2c"; + reg = <0x29370000 0x10000>; + interrupts = <GIC_SPI 92 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&pcc3 IMX8ULP_CLK_LPI2C4>, + <&pcc3 IMX8ULP_CLK_LPI2C4>; + clock-names = "per", "ipg"; + assigned-clocks = <&pcc3 IMX8ULP_CLK_LPI2C4>; + assigned-clock-parents = <&cgc1 IMX8ULP_CLK_XBAR_DIVBUS>; + assigned-clock-rates = <48000000>; + status = "disabled"; + }; + + lpi2c5: i2c@29380000 { + compatible = "fsl,imx8ulp-lpi2c", "fsl,imx7ulp-lpi2c"; + reg = <0x29380000 0x10000>; + interrupts = <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&pcc3 IMX8ULP_CLK_LPI2C5>, + <&pcc3 IMX8ULP_CLK_LPI2C5>; + clock-names = "per", "ipg"; + assigned-clocks = <&pcc3 IMX8ULP_CLK_LPI2C5>; + assigned-clock-parents = <&cgc1 IMX8ULP_CLK_XBAR_DIVBUS>; + assigned-clock-rates = <48000000>; + status = "disabled"; };
lpuart4: serial@29390000 { @@ -370,10 +222,41 @@ lpuart5: serial@293a0000 { compatible = "fsl,imx8ulp-lpuart", "fsl,imx7ulp-lpuart"; reg = <0x293a0000 0x1000>; + interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; clocks = <&pcc3 IMX8ULP_CLK_LPUART5>; clock-names = "ipg"; status = "disabled"; }; + + lpspi4: spi@293b0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx8ulp-spi", "fsl,imx7ulp-spi"; + reg = <0x293b0000 0x10000>; + interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&pcc3 IMX8ULP_CLK_LPSPI4>, + <&pcc3 IMX8ULP_CLK_LPSPI4>; + clock-names = "per", "ipg"; + assigned-clocks = <&pcc3 IMX8ULP_CLK_LPSPI4>; + assigned-clock-parents = <&cgc1 IMX8ULP_CLK_XBAR_DIVBUS>; + assigned-clock-rates = <16000000>; + status = "disabled"; + }; + + lpspi5: spi@293c0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx8ulp-spi", "fsl,imx7ulp-spi"; + reg = <0x293c0000 0x10000>; + interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&pcc3 IMX8ULP_CLK_LPSPI5>, + <&pcc3 IMX8ULP_CLK_LPSPI5>; + clock-names = "per", "ipg"; + assigned-clocks = <&pcc3 IMX8ULP_CLK_LPSPI5>; + assigned-clock-parents = <&cgc1 IMX8ULP_CLK_XBAR_DIVBUS>; + assigned-clock-rates = <16000000>; + status = "disabled"; + }; };
per_bridge4: bus@29800000 { @@ -389,75 +272,81 @@ #clock-cells = <1>; };
- lpi2c6: lpi2c6@29840000 { + lpi2c6: i2c@29840000 { compatible = "fsl,imx8ulp-lpi2c", "fsl,imx7ulp-lpi2c"; reg = <0x29840000 0x10000>; interrupts = <GIC_SPI 94 IRQ_TYPE_LEVEL_HIGH>; clocks = <&pcc4 IMX8ULP_CLK_LPI2C6>, <&pcc4 IMX8ULP_CLK_LPI2C6>; clock-names = "per", "ipg"; + assigned-clocks = <&pcc4 IMX8ULP_CLK_LPI2C6>; + assigned-clock-parents = <&cgc1 IMX8ULP_CLK_XBAR_DIVBUS>; + assigned-clock-rates = <48000000>; status = "disabled"; };
- lpi2c7: lpi2c7@29850000 { + lpi2c7: i2c@29850000 { compatible = "fsl,imx8ulp-lpi2c", "fsl,imx7ulp-lpi2c"; reg = <0x29850000 0x10000>; interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>; clocks = <&pcc4 IMX8ULP_CLK_LPI2C7>, <&pcc4 IMX8ULP_CLK_LPI2C7>; clock-names = "per", "ipg"; + assigned-clocks = <&pcc4 IMX8ULP_CLK_LPI2C7>; + assigned-clock-parents = <&cgc1 IMX8ULP_CLK_XBAR_DIVBUS>; + assigned-clock-rates = <48000000>; status = "disabled"; };
- flexspi2: flexspi@29810000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "nxp,imx8ulp-fspi"; - reg = <0x29810000 0x10000>, - <0x60000000 0xfffffff>; - reg-names = "fspi_base", "fspi_mmap"; + lpuart6: serial@29860000 { + compatible = "fsl,imx8ulp-lpuart", "fsl,imx7ulp-lpuart"; + reg = <0x29860000 0x1000>; + interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&pcc4 IMX8ULP_CLK_LPUART6>; + clock-names = "ipg"; status = "disabled"; };
- flexspi2_nand: flexspi2_nand@29810000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx8-fspi-nand"; - reg = <0x29810000 0x10000>, <0x60000000 0x10000000>; - reg-names = "FlexSPI", "FlexSPI-memory"; + lpuart7: serial@29870000 { + compatible = "fsl,imx8ulp-lpuart", "fsl,imx7ulp-lpuart"; + reg = <0x29870000 0x1000>; + interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&pcc4 IMX8ULP_CLK_LPUART7>; + clock-names = "ipg"; status = "disabled"; };
iomuxc1: pinctrl@298c0000 { compatible = "fsl,imx8ulp-iomuxc1"; reg = <0x298c0000 0x10000>; - fsl,mux_mask = <0xf00>; };
usdhc0: mmc@298d0000 { - compatible = "fsl,imx8ulp-usdhc", "fsl,imx7ulp-usdhc"; + compatible = "fsl,imx8ulp-usdhc", "fsl,imx8mm-usdhc"; reg = <0x298d0000 0x10000>; interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cgc1 IMX8ULP_CLK_DUMMY>, - <&cgc1 IMX8ULP_CLK_DUMMY>, + clocks = <&cgc1 IMX8ULP_CLK_XBAR_DIVBUS>, + <&cgc1 IMX8ULP_CLK_XBAR_AD_DIVPLAT>, <&pcc4 IMX8ULP_CLK_USDHC0>; clock-names = "ipg", "ahb", "per"; + power-domains = <&scmi_devpd IMX8ULP_PD_USDHC0>; fsl,tuning-start-tap = <20>; - fsl,tuning-step= <2>; + fsl,tuning-step = <2>; bus-width = <4>; status = "disabled"; };
usdhc1: mmc@298e0000 { - compatible = "fsl,imx8ulp-usdhc", "fsl,imx7ulp-usdhc"; + compatible = "fsl,imx8ulp-usdhc", "fsl,imx8mm-usdhc"; reg = <0x298e0000 0x10000>; interrupts = <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cgc1 IMX8ULP_CLK_DUMMY>, - <&cgc1 IMX8ULP_CLK_DUMMY>, + clocks = <&cgc1 IMX8ULP_CLK_XBAR_DIVBUS>, + <&cgc1 IMX8ULP_CLK_NIC_PER_DIVPLAT>, <&pcc4 IMX8ULP_CLK_USDHC1>; clock-names = "ipg", "ahb", "per"; + power-domains = <&scmi_devpd IMX8ULP_PD_USDHC1>; fsl,tuning-start-tap = <20>; - fsl,tuning-step= <2>; + fsl,tuning-step = <2>; bus-width = <4>; status = "disabled"; }; @@ -470,117 +359,40 @@ <&cgc1 IMX8ULP_CLK_NIC_PER_DIVPLAT>, <&pcc4 IMX8ULP_CLK_USDHC2>; clock-names = "ipg", "ahb", "per"; - assigned-clocks = <&cgc1 IMX8ULP_CLK_SPLL3_PFD2>, <&pcc4 IMX8ULP_CLK_USDHC2>; - assigned-clock-parents = <0>, <&cgc1 IMX8ULP_CLK_SPLL3_PFD2_DIV1>; - assigned-clock-rates = <396000000>, <396000000>; + power-domains = <&scmi_devpd IMX8ULP_PD_USDHC2_USB1>; fsl,tuning-start-tap = <20>; - fsl,tuning-step= <2>; + fsl,tuning-step = <2>; bus-width = <4>; status = "disabled"; }; - - usbotg0: usb@29900000 { - compatible = "fsl,imx8ulp-usb", "fsl,imx7ulp-usb", - "fsl,imx27-usb"; - reg = <0x29900000 0x200>; - interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&pcc4 IMX8ULP_CLK_USB0>; - fsl,usbphy = <&usbphy0>; - fsl,usbmisc = <&usbmisc0 0>; - ahb-burst-config = <0x0>; - tx-burst-size-dword = <0x8>; - rx-burst-size-dword = <0x8>; - status = "disabled"; - }; - - usbmisc0: usbmisc@29900200 { - #index-cells = <1>; - compatible = "fsl,imx8ulp-usbmisc", "fsl,imx7ulp-usbmisc", - "fsl,imx6q-usbmisc"; - reg = <0x29900200 0x200>; - }; - - usbphy0: usbphy@29910000 { - compatible = "fsl,imx8ulp-usbphy", - "fsl,imx7ulp-usbphy", "fsl,imx23-usbphy"; - reg = <0x29910000 0x1000>; - interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&pcc4 IMX8ULP_CLK_USB0_PHY>; - }; - - usbotg1: usb@29920000 { - compatible = "fsl,imx8ulp-usb", "fsl,imx7ulp-usb", - "fsl,imx27-usb"; - reg = <0x29920000 0x200>; - interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&pcc4 IMX8ULP_CLK_USB1>; - fsl,usbphy = <&usbphy1>; - fsl,usbmisc = <&usbmisc1 0>; - ahb-burst-config = <0x0>; - tx-burst-size-dword = <0x8>; - rx-burst-size-dword = <0x8>; - status = "disabled"; - }; - - usbmisc1: usbmisc@29920200 { - #index-cells = <1>; - compatible = "fsl,imx8ulp-usbmisc", "fsl,imx7ulp-usbmisc", - "fsl,imx6q-usbmisc"; - reg = <0x29920200 0x200>; - }; - - usbphy1: usbphy@29930000 { - compatible = "fsl,imx8ulp-usbphy", - "fsl,imx7ulp-usbphy", "fsl,imx23-usbphy"; - reg = <0x29930000 0x1000>; - interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&pcc4 IMX8ULP_CLK_USB1_PHY>; - }; - - fec: ethernet@29950000 { - compatible = "fsl,imx8ulp-fec", "fsl,imx6sx-fec"; - reg = <0x29950000 0x10000>; - interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&pcc4 IMX8ULP_CLK_ENET>, - <&pcc4 IMX8ULP_CLK_ENET>, - <&cgc1 IMX8ULP_CLK_ENETSTAMP_SEL>, - <&pcc4 IMX8ULP_CLK_ENET>, - <&pcc4 IMX8ULP_CLK_ENET>; - clock-names = "ipg", "ahb", "ptp", - "enet_clk_ref", "enet_out"; - fsl,num-tx-queues = <3>; - fsl,num-rx-queues = <3>; - status = "disabled"; - }; - };
- gpioe: gpio@2d000000 { - compatible = "fsl,imx7ulp-gpio", "fsl,vf610-gpio"; - reg = <0x2d000080 0x1000 0x2d000040 0x40>; - gpio-controller; - #gpio-cells = <2>; - interrupts = <GIC_SPI 129 IRQ_TYPE_LEVEL_HIGH>; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pcc4 IMX8ULP_CLK_RGPIOE>, - <&pcc4 IMX8ULP_CLK_PCTLE>; - clock-names = "gpio", "port"; - gpio-ranges = <&iomuxc1 0 32 24>; + gpioe: gpio@2d000080 { + compatible = "fsl,imx8ulp-gpio", "fsl,imx7ulp-gpio"; + reg = <0x2d000080 0x1000>, <0x2d000040 0x40>; + gpio-controller; + #gpio-cells = <2>; + interrupts = <GIC_SPI 129 IRQ_TYPE_LEVEL_HIGH>; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pcc4 IMX8ULP_CLK_RGPIOE>, + <&pcc4 IMX8ULP_CLK_PCTLE>; + clock-names = "gpio", "port"; + gpio-ranges = <&iomuxc1 0 32 24>; };
- gpiof: gpio@2d010000 { - compatible = "fsl,imx7ulp-gpio", "fsl,vf610-gpio"; - reg = <0x2d010080 0x1000 0x2d010040 0x40>; - gpio-controller; - #gpio-cells = <2>; - interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pcc4 IMX8ULP_CLK_RGPIOF>, - <&pcc4 IMX8ULP_CLK_PCTLF>; - clock-names = "gpio", "port"; - gpio-ranges = <&iomuxc1 0 64 24>; + gpiof: gpio@2d010080 { + compatible = "fsl,imx8ulp-gpio", "fsl,imx7ulp-gpio"; + reg = <0x2d010080 0x1000>, <0x2d010040 0x40>; + gpio-controller; + #gpio-cells = <2>; + interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pcc4 IMX8ULP_CLK_RGPIOF>, + <&pcc4 IMX8ULP_CLK_PCTLF>; + clock-names = "gpio", "port"; + gpio-ranges = <&iomuxc1 0 64 32>; };
per_bridge5: bus@2d800000 { @@ -590,112 +402,6 @@ #size-cells = <1>; ranges;
- edma2: dma-controller@2d800000 { - compatible = "fsl,imx8ulp-edma"; - reg = <0x2d800000 0x10000>, - <0x2d810000 0x10000>, <0x2d820000 0x10000>, - <0x2d830000 0x10000>, <0x2d840000 0x10000>, - <0x2d850000 0x10000>, <0x2d860000 0x10000>, - <0x2d870000 0x10000>, <0x2d880000 0x10000>, - <0x2d890000 0x10000>, <0x2d8a0000 0x10000>, - <0x2d8b0000 0x10000>, <0x2d8c0000 0x10000>, - <0x2d8d0000 0x10000>, <0x2d8e0000 0x10000>, - <0x2d8f0000 0x10000>, <0x2d900000 0x10000>, - <0x2d910000 0x10000>, <0x2d920000 0x10000>, - <0x2d930000 0x10000>, <0x2d940000 0x10000>, - <0x2d950000 0x10000>, <0x2d960000 0x10000>, - <0x2d970000 0x10000>, <0x2d980000 0x10000>, - <0x2d990000 0x10000>, <0x2d9a0000 0x10000>, - <0x2d9b0000 0x10000>, <0x2d9c0000 0x10000>, - <0x2d9d0000 0x10000>, <0x2d9e0000 0x10000>, - <0x2d9f0000 0x10000>, <0x2da00000 0x10000>; - #dma-cells = <3>; - dma-channels = <32>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "edma2-chan0-tx", "edma2-chan1-tx", - "edma2-chan2-tx", "edma2-chan3-tx", - "edma2-chan4-tx", "edma2-chan5-tx", - "edma2-chan6-tx", "edma2-chan7-tx", - "edma2-chan8-tx", "edma2-chan9-tx", - "edma2-chan10-tx", "edma2-chan11-tx", - "edma2-chan12-tx", "edma2-chan13-tx", - "edma2-chan14-tx", "edma2-chan15-tx", - "edma2-chan16-tx", "edma2-chan17-tx", - "edma2-chan18-tx", "edma2-chan19-tx", - "edma2-chan20-tx", "edma2-chan21-tx", - "edma2-chan22-tx", "edma2-chan23-tx", - "edma2-chan24-tx", "edma2-chan25-tx", - "edma2-chan26-tx", "edma2-chan27-tx", - "edma2-chan28-tx", "edma2-chan29-tx", - "edma2-chan30-tx", "edma2-chan31-tx"; - clocks = <&pcc5 IMX8ULP_CLK_DMA2_MP>, - <&pcc5 IMX8ULP_CLK_DMA2_CH0>, <&pcc5 IMX8ULP_CLK_DMA2_CH1>, - <&pcc5 IMX8ULP_CLK_DMA2_CH2>, <&pcc5 IMX8ULP_CLK_DMA2_CH3>, - <&pcc5 IMX8ULP_CLK_DMA2_CH4>, <&pcc5 IMX8ULP_CLK_DMA2_CH5>, - <&pcc5 IMX8ULP_CLK_DMA2_CH6>, <&pcc5 IMX8ULP_CLK_DMA2_CH7>, - <&pcc5 IMX8ULP_CLK_DMA2_CH8>, <&pcc5 IMX8ULP_CLK_DMA2_CH9>, - <&pcc5 IMX8ULP_CLK_DMA2_CH10>, <&pcc5 IMX8ULP_CLK_DMA2_CH11>, - <&pcc5 IMX8ULP_CLK_DMA2_CH12>, <&pcc5 IMX8ULP_CLK_DMA2_CH13>, - <&pcc5 IMX8ULP_CLK_DMA2_CH14>, <&pcc5 IMX8ULP_CLK_DMA2_CH15>, - <&pcc5 IMX8ULP_CLK_DMA2_CH16>, <&pcc5 IMX8ULP_CLK_DMA2_CH17>, - <&pcc5 IMX8ULP_CLK_DMA2_CH18>, <&pcc5 IMX8ULP_CLK_DMA2_CH19>, - <&pcc5 IMX8ULP_CLK_DMA2_CH20>, <&pcc5 IMX8ULP_CLK_DMA2_CH21>, - <&pcc5 IMX8ULP_CLK_DMA2_CH22>, <&pcc5 IMX8ULP_CLK_DMA2_CH23>, - <&pcc5 IMX8ULP_CLK_DMA2_CH24>, <&pcc5 IMX8ULP_CLK_DMA2_CH25>, - <&pcc5 IMX8ULP_CLK_DMA2_CH26>, <&pcc5 IMX8ULP_CLK_DMA2_CH27>, - <&pcc5 IMX8ULP_CLK_DMA2_CH28>, <&pcc5 IMX8ULP_CLK_DMA2_CH29>, - <&pcc5 IMX8ULP_CLK_DMA2_CH30>, <&pcc5 IMX8ULP_CLK_DMA2_CH31>; - clock-names = "edma-mp-clk", - "edma2-chan0-clk", "edma2-chan1-clk", - "edma2-chan2-clk", "edma2-chan3-clk", - "edma2-chan4-clk", "edma2-chan5-clk", - "edma2-chan6-clk", "edma2-chan7-clk", - "edma2-chan8-clk", "edma2-chan9-clk", - "edma2-chan10-clk", "edma2-chan11-clk", - "edma2-chan12-clk", "edma2-chan13-clk", - "edma2-chan14-clk", "edma2-chan15-clk", - "edma2-chan16-clk", "edma2-chan17-clk", - "edma2-chan18-clk", "edma2-chan19-clk", - "edma2-chan20-clk", "edma2-chan21-clk", - "edma2-chan22-clk", "edma2-chan23-clk", - "edma2-chan24-clk", "edma2-chan25-clk", - "edma2-chan26-clk", "edma2-chan27-clk", - "edma2-chan28-clk", "edma2-chan29-clk", - "edma2-chan30-clk", "edma2-chan31-clk"; - status = "okay"; - }; - cgc2: clock-controller@2da60000 { compatible = "fsl,imx8ulp-cgc2"; reg = <0x2da60000 0x10000>; @@ -711,9 +417,9 @@ }; };
- gpiod: gpio@2e200000 { - compatible = "fsl,imx7ulp-gpio", "fsl,vf610-gpio"; - reg = <0x2e200080 0x1000 0x2e200040 0x40>; + gpiod: gpio@2e200080 { + compatible = "fsl,imx8ulp-gpio", "fsl,imx7ulp-gpio"; + reg = <0x2e200080 0x1000>, <0x2e200040 0x40>; gpio-controller; #gpio-cells = <2>; interrupts = <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; diff --git a/include/dt-bindings/clock/imx8ulp-clock.h b/include/dt-bindings/clock/imx8ulp-clock.h index 49166a18300..827404fadf5 100644 --- a/include/dt-bindings/clock/imx8ulp-clock.h +++ b/include/dt-bindings/clock/imx8ulp-clock.h @@ -1,16 +1,14 @@ -/* SPDX-License-Identifier: GPL-2.0 */ +/* SPDX-License-Identifier: GPL-2.0+ OR MIT */ /* - * Copyright 2020 NXP + * Copyright 2021 NXP */
#ifndef __DT_BINDINGS_CLOCK_IMX8ULP_H #define __DT_BINDINGS_CLOCK_IMX8ULP_H
#define IMX8ULP_CLK_DUMMY 0 -#define IMX8ULP_CLK_ROSC 1 -#define IMX8ULP_CLK_FROSC 2 -#define IMX8ULP_CLK_LPOSC 3 -#define IMX8ULP_CLK_SOSC 4 + +/* CGC1 */ #define IMX8ULP_CLK_SPLL2 5 #define IMX8ULP_CLK_SPLL3 6 #define IMX8ULP_CLK_A35_SEL 7 @@ -57,14 +55,15 @@ #define IMX8ULP_CLK_FROSC_DIV1_GATE 48 #define IMX8ULP_CLK_FROSC_DIV2_GATE 49 #define IMX8ULP_CLK_FROSC_DIV3_GATE 50 -#define IMX8ULP_CLK_ENETSTAMP_SEL 51 -#define IMX8ULP_CLK_SAI4_SEL 52 -#define IMX8ULP_CLK_SAI5_SEL 53 -#define IMX8ULP_CLK_AUD_CLK1 54 -#define IMX8ULP_CLK_ARM 55 +#define IMX8ULP_CLK_SAI4_SEL 51 +#define IMX8ULP_CLK_SAI5_SEL 52 +#define IMX8ULP_CLK_AUD_CLK1 53 +#define IMX8ULP_CLK_ARM 54 +#define IMX8ULP_CLK_ENET_TS_SEL 55
#define IMX8ULP_CLK_CGC1_END 56
+/* CGC2 */ #define IMX8ULP_CLK_PLL4_PRE_SEL 0 #define IMX8ULP_CLK_PLL4 1 #define IMX8ULP_CLK_PLL4_VCODIV 2 @@ -110,8 +109,12 @@ #define IMX8ULP_CLK_SAI6_SEL 42 #define IMX8ULP_CLK_SAI7_SEL 43 #define IMX8ULP_CLK_SPDIF_SEL 44 +#define IMX8ULP_CLK_HIFI_SEL 45 +#define IMX8ULP_CLK_HIFI_DIVCORE 46 +#define IMX8ULP_CLK_HIFI_DIVPLAT 47 +#define IMX8ULP_CLK_DSI_PHY_REF 48
-#define IMX8ULP_CLK_CGC2_END 45 +#define IMX8ULP_CLK_CGC2_END 49
/* PCC3 */ #define IMX8ULP_CLK_WDOG3 0 @@ -160,9 +163,12 @@ #define IMX8ULP_CLK_DMA1_CH29 43 #define IMX8ULP_CLK_DMA1_CH30 44 #define IMX8ULP_CLK_DMA1_CH31 45 +#define IMX8ULP_CLK_MU3_A 46 +#define IMX8ULP_CLK_MU0_B 47
-#define IMX8ULP_CLK_PCC3_END 46 +#define IMX8ULP_CLK_PCC3_END 48
+/* PCC4 */ #define IMX8ULP_CLK_FLEXSPI2 0 #define IMX8ULP_CLK_TPM6 1 #define IMX8ULP_CLK_TPM7 2 @@ -189,24 +195,25 @@
#define IMX8ULP_CLK_PCC4_END 23
+/* PCC5 */ #define IMX8ULP_CLK_TPM8 0 #define IMX8ULP_CLK_SAI6 1 #define IMX8ULP_CLK_SAI7 2 #define IMX8ULP_CLK_SPDIF 3 -#define IMX8ULP_CLK_ISI 4 +#define IMX8ULP_CLK_ISI 4 #define IMX8ULP_CLK_CSI_REGS 5 #define IMX8ULP_CLK_PCTLD 6 -#define IMX8ULP_CLK_CSI 7 -#define IMX8ULP_CLK_DSI 8 +#define IMX8ULP_CLK_CSI 7 +#define IMX8ULP_CLK_DSI 8 #define IMX8ULP_CLK_WDOG5 9 #define IMX8ULP_CLK_EPDC 10 -#define IMX8ULP_CLK_PXP 11 +#define IMX8ULP_CLK_PXP 11 #define IMX8ULP_CLK_SFA2 12 #define IMX8ULP_CLK_GPU2D 13 #define IMX8ULP_CLK_GPU3D 14 #define IMX8ULP_CLK_DC_NANO 15 #define IMX8ULP_CLK_CSI_CLK_UI 16 -#define IMX8ULP_CLK_CSI_CLK_ESC 17 +#define IMX8ULP_CLK_CSI_CLK_ESC 17 #define IMX8ULP_CLK_RGPIOD 18 #define IMX8ULP_CLK_DMA2_MP 19 #define IMX8ULP_CLK_DMA2_CH0 20 @@ -241,7 +248,11 @@ #define IMX8ULP_CLK_DMA2_CH29 49 #define IMX8ULP_CLK_DMA2_CH30 50 #define IMX8ULP_CLK_DMA2_CH31 51 +#define IMX8ULP_CLK_MU2_B 52 +#define IMX8ULP_CLK_MU3_B 53 +#define IMX8ULP_CLK_AVD_SIM 54 +#define IMX8ULP_CLK_DSI_TX_ESC 55
-#define IMX8ULP_CLK_PCC5_END 52 +#define IMX8ULP_CLK_PCC5_END 56
#endif diff --git a/include/dt-bindings/power/imx8ulp-power.h b/include/dt-bindings/power/imx8ulp-power.h new file mode 100644 index 00000000000..a556b2e96df --- /dev/null +++ b/include/dt-bindings/power/imx8ulp-power.h @@ -0,0 +1,26 @@ +/* SPDX-License-Identifier: (GPL-2.0 OR MIT) */ +/* + * Copyright 2021 NXP + */ + +#ifndef __DT_BINDINGS_IMX8ULP_POWER_H__ +#define __DT_BINDINGS_IMX8ULP_POWER_H__ + +#define IMX8ULP_PD_DMA1 0 +#define IMX8ULP_PD_FLEXSPI2 1 +#define IMX8ULP_PD_USB0 2 +#define IMX8ULP_PD_USDHC0 3 +#define IMX8ULP_PD_USDHC1 4 +#define IMX8ULP_PD_USDHC2_USB1 5 +#define IMX8ULP_PD_DCNANO 6 +#define IMX8ULP_PD_EPDC 7 +#define IMX8ULP_PD_DMA2 8 +#define IMX8ULP_PD_GPU2D 9 +#define IMX8ULP_PD_GPU3D 10 +#define IMX8ULP_PD_HIFI4 11 +#define IMX8ULP_PD_ISI 12 +#define IMX8ULP_PD_MIPI_CSI 13 +#define IMX8ULP_PD_MIPI_DSI 14 +#define IMX8ULP_PD_PXP 15 + +#endif diff --git a/include/dt-bindings/reset/imx8ulp-pcc-reset.h b/include/dt-bindings/reset/imx8ulp-pcc-reset.h new file mode 100644 index 00000000000..e99a4735c3c --- /dev/null +++ b/include/dt-bindings/reset/imx8ulp-pcc-reset.h @@ -0,0 +1,59 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ +/* + * Copyright 2021 NXP + */ + +#ifndef DT_BINDING_PCC_RESET_IMX8ULP_H +#define DT_BINDING_PCC_RESET_IMX8ULP_H + +/* PCC3 */ +#define PCC3_WDOG3_SWRST 0 +#define PCC3_WDOG4_SWRST 1 +#define PCC3_LPIT1_SWRST 2 +#define PCC3_TPM4_SWRST 3 +#define PCC3_TPM5_SWRST 4 +#define PCC3_FLEXIO1_SWRST 5 +#define PCC3_I3C2_SWRST 6 +#define PCC3_LPI2C4_SWRST 7 +#define PCC3_LPI2C5_SWRST 8 +#define PCC3_LPUART4_SWRST 9 +#define PCC3_LPUART5_SWRST 10 +#define PCC3_LPSPI4_SWRST 11 +#define PCC3_LPSPI5_SWRST 12 + +/* PCC4 */ +#define PCC4_FLEXSPI2_SWRST 0 +#define PCC4_TPM6_SWRST 1 +#define PCC4_TPM7_SWRST 2 +#define PCC4_LPI2C6_SWRST 3 +#define PCC4_LPI2C7_SWRST 4 +#define PCC4_LPUART6_SWRST 5 +#define PCC4_LPUART7_SWRST 6 +#define PCC4_SAI4_SWRST 7 +#define PCC4_SAI5_SWRST 8 +#define PCC4_USDHC0_SWRST 9 +#define PCC4_USDHC1_SWRST 10 +#define PCC4_USDHC2_SWRST 11 +#define PCC4_USB0_SWRST 12 +#define PCC4_USB0_PHY_SWRST 13 +#define PCC4_USB1_SWRST 14 +#define PCC4_USB1_PHY_SWRST 15 +#define PCC4_ENET_SWRST 16 + +/* PCC5 */ +#define PCC5_TPM8_SWRST 0 +#define PCC5_SAI6_SWRST 1 +#define PCC5_SAI7_SWRST 2 +#define PCC5_SPDIF_SWRST 3 +#define PCC5_ISI_SWRST 4 +#define PCC5_CSI_REGS_SWRST 5 +#define PCC5_CSI_SWRST 6 +#define PCC5_DSI_SWRST 7 +#define PCC5_WDOG5_SWRST 8 +#define PCC5_EPDC_SWRST 9 +#define PCC5_PXP_SWRST 10 +#define PCC5_GPU2D_SWRST 11 +#define PCC5_GPU3D_SWRST 12 +#define PCC5_DC_NANO_SWRST 13 + +#endif /*DT_BINDING_RESET_IMX8ULP_H */
arch/arm/dts/imx8mq-evk.dts | 43 +++++++++++++++++ arch/arm/dts/imx8mq-u-boot.dtsi | 10 ++-- arch/arm/dts/imx8mq.dtsi | 15 +++--- include/dt-bindings/reset/imx8mq-reset.h | 61 +++++++++++++----------- 4 files changed, 88 insertions(+), 41 deletions(-)
diff --git a/arch/arm/dts/imx8mq-evk.dts b/arch/arm/dts/imx8mq-evk.dts index 99fed35168e..82387b9cb80 100644 --- a/arch/arm/dts/imx8mq-evk.dts +++ b/arch/arm/dts/imx8mq-evk.dts @@ -71,12 +71,36 @@ linux,autosuspend-period = <125>; };
+ audio_codec_bt_sco: audio-codec-bt-sco { + compatible = "linux,bt-sco"; + #sound-dai-cells = <1>; + }; + wm8524: audio-codec { #sound-dai-cells = <0>; compatible = "wlf,wm8524"; wlf,mute-gpios = <&gpio1 8 GPIO_ACTIVE_LOW>; };
+ sound-bt-sco { + compatible = "simple-audio-card"; + simple-audio-card,name = "bt-sco-audio"; + simple-audio-card,format = "dsp_a"; + simple-audio-card,bitclock-inversion; + simple-audio-card,frame-master = <&btcpu>; + simple-audio-card,bitclock-master = <&btcpu>; + + btcpu: simple-audio-card,cpu { + sound-dai = <&sai3>; + dai-tdm-slot-num = <2>; + dai-tdm-slot-width = <16>; + }; + + simple-audio-card,codec { + sound-dai = <&audio_codec_bt_sco 1>; + }; + }; + sound-wm8524 { compatible = "simple-audio-card"; simple-audio-card,name = "wm8524-audio"; @@ -386,6 +410,16 @@ status = "okay"; };
+&sai3 { + #sound-dai-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sai3>; + assigned-clocks = <&clk IMX8MQ_CLK_SAI3>; + assigned-clock-parents = <&clk IMX8MQ_AUDIO_PLL1_OUT>; + assigned-clock-rates = <24576000>; + status = "okay"; +}; + &snvs_pwrkey { status = "okay"; }; @@ -548,6 +582,15 @@ >; };
+ pinctrl_sai3: sai3grp { + fsl,pins = < + MX8MQ_IOMUXC_SAI3_TXFS_SAI3_TX_SYNC 0xd6 + MX8MQ_IOMUXC_SAI3_TXC_SAI3_TX_BCLK 0xd6 + MX8MQ_IOMUXC_SAI3_TXD_SAI3_TX_DATA0 0xd6 + MX8MQ_IOMUXC_SAI3_RXD_SAI3_RX_DATA0 0xd6 + >; + }; + pinctrl_spdif1: spdif1grp { fsl,pins = < MX8MQ_IOMUXC_SPDIF_TX_SPDIF1_OUT 0xd6 diff --git a/arch/arm/dts/imx8mq-u-boot.dtsi b/arch/arm/dts/imx8mq-u-boot.dtsi index e8b5f83706e..e6448ab8ad3 100644 --- a/arch/arm/dts/imx8mq-u-boot.dtsi +++ b/arch/arm/dts/imx8mq-u-boot.dtsi @@ -10,23 +10,23 @@
-&{/soc@0/bus@30000000} { +&aips1 { u-boot,dm-spl; };
-&{/soc@0/bus@30400000} { +&aips2 { u-boot,dm-spl; };
-&{/soc@0/bus@30800000} { +&aips3 { u-boot,dm-spl; };
-&{/soc@0/bus@32c00000} { +&aips4 { u-boot,dm-spl; };
diff --git a/arch/arm/dts/imx8mq.dtsi b/arch/arm/dts/imx8mq.dtsi index 49eadb081b1..e9f0cdd10ab 100644 --- a/arch/arm/dts/imx8mq.dtsi +++ b/arch/arm/dts/imx8mq.dtsi @@ -94,7 +94,7 @@ clk_ext4: clock-ext4 { compatible = "fixed-clock"; #clock-cells = <0>; - clock-frequency= <133000000>; + clock-frequency = <133000000>; clock-output-names = "clk_ext4"; };
@@ -320,7 +320,7 @@ arm,no-tick-in-suspend; };
- soc@0 { + soc: soc@0 { compatible = "fsl,imx8mq-soc", "simple-bus"; #address-cells = <1>; #size-cells = <1>; @@ -329,7 +329,7 @@ nvmem-cells = <&imx8mq_uid>; nvmem-cell-names = "soc_unique_id";
- bus@30000000 { /* AIPS1 */ + aips1: bus@30000000 { /* AIPS1 */ compatible = "fsl,aips-bus", "simple-bus"; reg = <0x30000000 0x400000>; #address-cells = <1>; @@ -507,7 +507,7 @@ <0x00030005 0x00000053>, <0x00030006 0x0000005f>, <0x00030007 0x00000071>; - #thermal-sensor-cells = <1>; + #thermal-sensor-cells = <1>; };
wdog1: watchdog@30280000 { @@ -784,7 +784,7 @@ }; };
- bus@30400000 { /* AIPS2 */ + aips2: bus@30400000 { /* AIPS2 */ compatible = "fsl,aips-bus", "simple-bus"; reg = <0x30400000 0x400000>; #address-cells = <1>; @@ -844,7 +844,7 @@ }; };
- bus@30800000 { /* AIPS3 */ + aips3: bus@30800000 { /* AIPS3 */ compatible = "fsl,aips-bus", "simple-bus"; reg = <0x30800000 0x400000>; #address-cells = <1>; @@ -1018,6 +1018,7 @@ compatible = "fsl,sec-v4.0-job-ring"; reg = <0x1000 0x1000>; interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; };
sec_jr1: jr@2000 { @@ -1369,7 +1370,7 @@ }; };
- bus@32c00000 { /* AIPS4 */ + aips4: bus@32c00000 { /* AIPS4 */ compatible = "fsl,aips-bus", "simple-bus"; reg = <0x32c00000 0x400000>; #address-cells = <1>; diff --git a/include/dt-bindings/reset/imx8mq-reset.h b/include/dt-bindings/reset/imx8mq-reset.h index 9a301082d36..705870693ec 100755 --- a/include/dt-bindings/reset/imx8mq-reset.h +++ b/include/dt-bindings/reset/imx8mq-reset.h @@ -28,37 +28,40 @@ #define IMX8MQ_RESET_A53_L2RESET 17 #define IMX8MQ_RESET_SW_NON_SCLR_M4C_RST 18 #define IMX8MQ_RESET_OTG1_PHY_RESET 19 -#define IMX8MQ_RESET_OTG2_PHY_RESET 20 -#define IMX8MQ_RESET_MIPI_DSI_RESET_BYTE_N 21 -#define IMX8MQ_RESET_MIPI_DSI_RESET_N 22 -#define IMX8MQ_RESET_MIPI_DSI_DPI_RESET_N 23 -#define IMX8MQ_RESET_MIPI_DSI_ESC_RESET_N 24 -#define IMX8MQ_RESET_MIPI_DSI_PCLK_RESET_N 25 -#define IMX8MQ_RESET_PCIEPHY 26 -#define IMX8MQ_RESET_PCIEPHY_PERST 27 -#define IMX8MQ_RESET_PCIE_CTRL_APPS_EN 28 -#define IMX8MQ_RESET_PCIE_CTRL_APPS_TURNOFF 29 -#define IMX8MQ_RESET_HDMI_PHY_APB_RESET 30 /* i.MX8MM does NOT support */ +#define IMX8MQ_RESET_OTG2_PHY_RESET 20 /* i.MX8MN does NOT support */ +#define IMX8MQ_RESET_MIPI_DSI_RESET_BYTE_N 21 /* i.MX8MN does NOT support */ +#define IMX8MQ_RESET_MIPI_DSI_RESET_N 22 /* i.MX8MN does NOT support */ +#define IMX8MQ_RESET_MIPI_DSI_DPI_RESET_N 23 /* i.MX8MN does NOT support */ +#define IMX8MQ_RESET_MIPI_DSI_ESC_RESET_N 24 /* i.MX8MN does NOT support */ +#define IMX8MQ_RESET_MIPI_DSI_PCLK_RESET_N 25 /* i.MX8MN does NOT support */ +#define IMX8MQ_RESET_PCIEPHY 26 /* i.MX8MN does NOT support */ +#define IMX8MQ_RESET_PCIEPHY_PERST 27 /* i.MX8MN does NOT support */ +#define IMX8MQ_RESET_PCIE_CTRL_APPS_EN 28 /* i.MX8MN does NOT support */ +#define IMX8MQ_RESET_PCIE_CTRL_APPS_TURNOFF 29 /* i.MX8MN does NOT support */ +#define IMX8MQ_RESET_HDMI_PHY_APB_RESET 30 /* i.MX8MM/i.MX8MN does NOT support */ #define IMX8MQ_RESET_DISP_RESET 31 #define IMX8MQ_RESET_GPU_RESET 32 -#define IMX8MQ_RESET_VPU_RESET 33 -#define IMX8MQ_RESET_PCIEPHY2 34 /* i.MX8MM does NOT support */ -#define IMX8MQ_RESET_PCIEPHY2_PERST 35 /* i.MX8MM does NOT support */ -#define IMX8MQ_RESET_PCIE2_CTRL_APPS_EN 36 /* i.MX8MM does NOT support */ -#define IMX8MQ_RESET_PCIE2_CTRL_APPS_TURNOFF 37 /* i.MX8MM does NOT support */ -#define IMX8MQ_RESET_MIPI_CSI1_CORE_RESET 38 /* i.MX8MM does NOT support */ -#define IMX8MQ_RESET_MIPI_CSI1_PHY_REF_RESET 39 /* i.MX8MM does NOT support */ -#define IMX8MQ_RESET_MIPI_CSI1_ESC_RESET 40 /* i.MX8MM does NOT support */ -#define IMX8MQ_RESET_MIPI_CSI2_CORE_RESET 41 /* i.MX8MM does NOT support */ -#define IMX8MQ_RESET_MIPI_CSI2_PHY_REF_RESET 42 /* i.MX8MM does NOT support */ -#define IMX8MQ_RESET_MIPI_CSI2_ESC_RESET 43 /* i.MX8MM does NOT support */ -#define IMX8MQ_RESET_DDRC1_PRST 44 -#define IMX8MQ_RESET_DDRC1_CORE_RESET 45 -#define IMX8MQ_RESET_DDRC1_PHY_RESET 46 -#define IMX8MQ_RESET_DDRC2_PRST 47 /* i.MX8MM does NOT support */ -#define IMX8MQ_RESET_DDRC2_CORE_RESET 48 /* i.MX8MM does NOT support */ -#define IMX8MQ_RESET_DDRC2_PHY_RESET 49 /* i.MX8MM does NOT support */ +#define IMX8MQ_RESET_VPU_RESET 33 /* i.MX8MN does NOT support */ +#define IMX8MQ_RESET_PCIEPHY2 34 /* i.MX8MM/i.MX8MN does NOT support */ +#define IMX8MQ_RESET_PCIEPHY2_PERST 35 /* i.MX8MM/i.MX8MN does NOT support */ +#define IMX8MQ_RESET_PCIE2_CTRL_APPS_EN 36 /* i.MX8MM/i.MX8MN does NOT support */ +#define IMX8MQ_RESET_PCIE2_CTRL_APPS_TURNOFF 37 /* i.MX8MM/i.MX8MN does NOT support */ +#define IMX8MQ_RESET_MIPI_CSI1_CORE_RESET 38 /* i.MX8MM/i.MX8MN does NOT support */ +#define IMX8MQ_RESET_MIPI_CSI1_PHY_REF_RESET 39 /* i.MX8MM/i.MX8MN does NOT support */ +#define IMX8MQ_RESET_MIPI_CSI1_ESC_RESET 40 /* i.MX8MM/i.MX8MN does NOT support */ +#define IMX8MQ_RESET_MIPI_CSI2_CORE_RESET 41 /* i.MX8MM/i.MX8MN does NOT support */ +#define IMX8MQ_RESET_MIPI_CSI2_PHY_REF_RESET 42 /* i.MX8MM/i.MX8MN does NOT support */ +#define IMX8MQ_RESET_MIPI_CSI2_ESC_RESET 43 /* i.MX8MM/i.MX8MN does NOT support */ +#define IMX8MQ_RESET_DDRC1_PRST 44 /* i.MX8MN does NOT support */ +#define IMX8MQ_RESET_DDRC1_CORE_RESET 45 /* i.MX8MN does NOT support */ +#define IMX8MQ_RESET_DDRC1_PHY_RESET 46 /* i.MX8MN does NOT support */ +#define IMX8MQ_RESET_DDRC2_PRST 47 /* i.MX8MM/i.MX8MN does NOT support */ +#define IMX8MQ_RESET_DDRC2_CORE_RESET 48 /* i.MX8MM/i.MX8MN does NOT support */ +#define IMX8MQ_RESET_DDRC2_PHY_RESET 49 /* i.MX8MM/i.MX8MN does NOT support */ +#define IMX8MQ_RESET_SW_M4C_RST 50 +#define IMX8MQ_RESET_SW_M4P_RST 51 +#define IMX8MQ_RESET_M4_ENABLE 52
-#define IMX8MQ_RESET_NUM 50 +#define IMX8MQ_RESET_NUM 53
#endif
Synchronise device tree with linux v6.0-rc1.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com ---
arch/arm/dts/imx8mp-dhcom-pdk2.dts | 27 +++-- arch/arm/dts/imx8mp-dhcom-som.dtsi | 20 +--- arch/arm/dts/imx8mp-evk.dts | 126 +++++++++++--------- arch/arm/dts/imx8mp-phyboard-pollux-rdk.dts | 48 ++++---- arch/arm/dts/imx8mp-u-boot.dtsi | 2 +- arch/arm/dts/imx8mp-venice-gw74xx.dts | 116 +++++++++--------- arch/arm/dts/imx8mp-verdin.dtsi | 14 ++- arch/arm/dts/imx8mp.dtsi | 33 ++++- include/dt-bindings/clock/imx8mp-clock.h | 13 +- include/dt-bindings/power/imx8mp-power.h | 15 ++- include/dt-bindings/reset/imx8mp-reset.h | 50 ++++++++ 11 files changed, 284 insertions(+), 180 deletions(-) create mode 100644 include/dt-bindings/reset/imx8mp-reset.h
diff --git a/arch/arm/dts/imx8mp-dhcom-pdk2.dts b/arch/arm/dts/imx8mp-dhcom-pdk2.dts index e95abfb3e89..2ca2ede2e94 100644 --- a/arch/arm/dts/imx8mp-dhcom-pdk2.dts +++ b/arch/arm/dts/imx8mp-dhcom-pdk2.dts @@ -19,7 +19,6 @@ };
gpio-keys { - #size-cells = <0>; compatible = "gpio-keys";
button-0 { @@ -62,7 +61,7 @@ led { compatible = "gpio-leds";
- led-5 { + led-0 { color = <LED_COLOR_ID_GREEN>; default-state = "off"; function = LED_FUNCTION_INDICATOR; @@ -71,7 +70,7 @@ pinctrl-names = "default"; };
- led-6 { + led-1 { color = <LED_COLOR_ID_GREEN>; default-state = "off"; function = LED_FUNCTION_INDICATOR; @@ -80,7 +79,7 @@ pinctrl-names = "default"; };
- led-7 { + led-2 { color = <LED_COLOR_ID_GREEN>; default-state = "off"; function = LED_FUNCTION_INDICATOR; @@ -89,7 +88,7 @@ pinctrl-names = "default"; };
- led-8 { + led-3 { color = <LED_COLOR_ID_GREEN>; default-state = "off"; function = LED_FUNCTION_INDICATOR; @@ -118,10 +117,11 @@ mdio { ethphypdk: ethernet-phy@7 { /* KSZ 9021 */ compatible = "ethernet-phy-ieee802.3-c22"; - interrupt-parent = <&gpio4>; - interrupts = <3 IRQ_TYPE_LEVEL_LOW>; pinctrl-0 = <&pinctrl_ethphy1>; pinctrl-names = "default"; + interrupt-parent = <&gpio4>; + interrupts = <3 IRQ_TYPE_LEVEL_LOW>; + max-speed = <100>; reg = <7>; reset-assert-us = <1000>; reset-deassert-us = <1000>; @@ -138,7 +138,6 @@ txd2-skew-ps = <0>; txd3-skew-ps = <0>; txen-skew-ps = <0>; - max-speed = <100>; }; }; }; @@ -150,3 +149,15 @@ &usb3_1 { fsl,over-current-active-low; }; + +&iomuxc { + /* + * GPIO_A,B,C,D are connected to buttons. + * GPIO_E,F,H,I are connected to LEDs. + * GPIO_M is connected to CLKOUT2. + */ + pinctrl-0 = <&pinctrl_hog_base + &pinctrl_dhcom_g &pinctrl_dhcom_j + &pinctrl_dhcom_k &pinctrl_dhcom_l + &pinctrl_dhcom_int>; +}; diff --git a/arch/arm/dts/imx8mp-dhcom-som.dtsi b/arch/arm/dts/imx8mp-dhcom-som.dtsi index 63cc6c92c41..a616eb37800 100644 --- a/arch/arm/dts/imx8mp-dhcom-som.dtsi +++ b/arch/arm/dts/imx8mp-dhcom-som.dtsi @@ -1,4 +1,4 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +// SPDX-License-Identifier: GPL-2.0 /* * Copyright (C) 2021-2022 Marek Vasut marex@denx.de */ @@ -224,10 +224,6 @@ };
&i2c3 { - /* - * iMX8MP 1P33A Errata ERR007805 - * I2C is limited to 384 kHz due to SoC bug. - */ clock-frequency = <100000>; pinctrl-names = "default", "gpio"; pinctrl-0 = <&pinctrl_i2c3>; @@ -393,10 +389,6 @@ };
&i2c4 { - /* - * iMX8MP 1P33A Errata ERR007805 - * I2C is limited to 384 kHz due to SoC bug. - */ clock-frequency = <100000>; pinctrl-names = "default", "gpio"; pinctrl-0 = <&pinctrl_i2c4>; @@ -407,10 +399,6 @@ };
&i2c5 { /* HDMI EDID bus */ - /* - * iMX8MP 1P33A Errata ERR007805 - * I2C is limited to 384 kHz due to SoC bug. - */ clock-frequency = <100000>; pinctrl-names = "default", "gpio"; pinctrl-0 = <&pinctrl_i2c5>; @@ -802,8 +790,8 @@
pinctrl_i2c5: dhcom-i2c5-grp { fsl,pins = < - MX8MP_IOMUXC_HDMI_DDC_SCL__HDMIMIX_HDMI_SCL 0x40000084 - MX8MP_IOMUXC_HDMI_DDC_SDA__HDMIMIX_HDMI_SDA 0x40000084 + MX8MP_IOMUXC_HDMI_DDC_SCL__I2C5_SCL 0x40000084 + MX8MP_IOMUXC_HDMI_DDC_SDA__I2C5_SDA 0x40000084 >; };
@@ -830,7 +818,7 @@ pinctrl_rtc: dhcom-rtc-grp { fsl,pins = < /* RTC_#INT Interrupt */ - MX8MP_IOMUXC_SPDIF_EXT_CLK__GPIO5_IO05 0x400001c6 + MX8MP_IOMUXC_SPDIF_EXT_CLK__GPIO5_IO05 0x40000080 >; };
diff --git a/arch/arm/dts/imx8mp-evk.dts b/arch/arm/dts/imx8mp-evk.dts index 4c3ac4214a2..f6b017ab5f5 100644 --- a/arch/arm/dts/imx8mp-evk.dts +++ b/arch/arm/dts/imx8mp-evk.dts @@ -67,18 +67,20 @@ }; };
-&flexcan1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_flexcan1>; - xceiver-supply = <®_can1_stby>; - status = "okay"; +&A53_0 { + cpu-supply = <®_arm>; };
-&flexcan2 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_flexcan2>; - xceiver-supply = <®_can2_stby>; - status = "disabled";/* can2 pin conflict with pdm */ +&A53_1 { + cpu-supply = <®_arm>; +}; + +&A53_2 { + cpu-supply = <®_arm>; +}; + +&A53_3 { + cpu-supply = <®_arm>; };
&eqos { @@ -197,6 +199,20 @@ }; };
+&flexcan1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_flexcan1>; + xceiver-supply = <®_can1_stby>; + status = "okay"; +}; + +&flexcan2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_flexcan2>; + xceiver-supply = <®_can2_stby>; + status = "disabled";/* can2 pin conflict with pdm */ +}; + &i2c1 { clock-frequency = <400000>; pinctrl-names = "default"; @@ -221,7 +237,7 @@ regulator-ramp-delay = <3125>; };
- BUCK2 { + reg_arm: BUCK2 { regulator-name = "BUCK2"; regulator-min-microvolt = <720000>; regulator-max-microvolt = <1025000>; @@ -395,41 +411,41 @@ &iomuxc { pinctrl_eqos: eqosgrp { fsl,pins = < - MX8MP_IOMUXC_ENET_MDC__ENET_QOS_MDC 0x3 - MX8MP_IOMUXC_ENET_MDIO__ENET_QOS_MDIO 0x3 - MX8MP_IOMUXC_ENET_RD0__ENET_QOS_RGMII_RD0 0x91 - MX8MP_IOMUXC_ENET_RD1__ENET_QOS_RGMII_RD1 0x91 - MX8MP_IOMUXC_ENET_RD2__ENET_QOS_RGMII_RD2 0x91 - MX8MP_IOMUXC_ENET_RD3__ENET_QOS_RGMII_RD3 0x91 - MX8MP_IOMUXC_ENET_RXC__CCM_ENET_QOS_CLOCK_GENERATE_RX_CLK 0x91 - MX8MP_IOMUXC_ENET_RX_CTL__ENET_QOS_RGMII_RX_CTL 0x91 - MX8MP_IOMUXC_ENET_TD0__ENET_QOS_RGMII_TD0 0x1f - MX8MP_IOMUXC_ENET_TD1__ENET_QOS_RGMII_TD1 0x1f - MX8MP_IOMUXC_ENET_TD2__ENET_QOS_RGMII_TD2 0x1f - MX8MP_IOMUXC_ENET_TD3__ENET_QOS_RGMII_TD3 0x1f - MX8MP_IOMUXC_ENET_TX_CTL__ENET_QOS_RGMII_TX_CTL 0x1f - MX8MP_IOMUXC_ENET_TXC__CCM_ENET_QOS_CLOCK_GENERATE_TX_CLK 0x1f - MX8MP_IOMUXC_SAI2_RXC__GPIO4_IO22 0x19 + MX8MP_IOMUXC_ENET_MDC__ENET_QOS_MDC 0x2 + MX8MP_IOMUXC_ENET_MDIO__ENET_QOS_MDIO 0x2 + MX8MP_IOMUXC_ENET_RD0__ENET_QOS_RGMII_RD0 0x90 + MX8MP_IOMUXC_ENET_RD1__ENET_QOS_RGMII_RD1 0x90 + MX8MP_IOMUXC_ENET_RD2__ENET_QOS_RGMII_RD2 0x90 + MX8MP_IOMUXC_ENET_RD3__ENET_QOS_RGMII_RD3 0x90 + MX8MP_IOMUXC_ENET_RXC__CCM_ENET_QOS_CLOCK_GENERATE_RX_CLK 0x90 + MX8MP_IOMUXC_ENET_RX_CTL__ENET_QOS_RGMII_RX_CTL 0x90 + MX8MP_IOMUXC_ENET_TD0__ENET_QOS_RGMII_TD0 0x16 + MX8MP_IOMUXC_ENET_TD1__ENET_QOS_RGMII_TD1 0x16 + MX8MP_IOMUXC_ENET_TD2__ENET_QOS_RGMII_TD2 0x16 + MX8MP_IOMUXC_ENET_TD3__ENET_QOS_RGMII_TD3 0x16 + MX8MP_IOMUXC_ENET_TX_CTL__ENET_QOS_RGMII_TX_CTL 0x16 + MX8MP_IOMUXC_ENET_TXC__CCM_ENET_QOS_CLOCK_GENERATE_TX_CLK 0x16 + MX8MP_IOMUXC_SAI2_RXC__GPIO4_IO22 0x10 >; };
pinctrl_fec: fecgrp { fsl,pins = < - MX8MP_IOMUXC_SAI1_RXD2__ENET1_MDC 0x3 - MX8MP_IOMUXC_SAI1_RXD3__ENET1_MDIO 0x3 - MX8MP_IOMUXC_SAI1_RXD4__ENET1_RGMII_RD0 0x91 - MX8MP_IOMUXC_SAI1_RXD5__ENET1_RGMII_RD1 0x91 - MX8MP_IOMUXC_SAI1_RXD6__ENET1_RGMII_RD2 0x91 - MX8MP_IOMUXC_SAI1_RXD7__ENET1_RGMII_RD3 0x91 - MX8MP_IOMUXC_SAI1_TXC__ENET1_RGMII_RXC 0x91 - MX8MP_IOMUXC_SAI1_TXFS__ENET1_RGMII_RX_CTL 0x91 - MX8MP_IOMUXC_SAI1_TXD0__ENET1_RGMII_TD0 0x1f - MX8MP_IOMUXC_SAI1_TXD1__ENET1_RGMII_TD1 0x1f - MX8MP_IOMUXC_SAI1_TXD2__ENET1_RGMII_TD2 0x1f - MX8MP_IOMUXC_SAI1_TXD3__ENET1_RGMII_TD3 0x1f - MX8MP_IOMUXC_SAI1_TXD4__ENET1_RGMII_TX_CTL 0x1f - MX8MP_IOMUXC_SAI1_TXD5__ENET1_RGMII_TXC 0x1f - MX8MP_IOMUXC_SAI1_RXD0__GPIO4_IO02 0x19 + MX8MP_IOMUXC_SAI1_RXD2__ENET1_MDC 0x2 + MX8MP_IOMUXC_SAI1_RXD3__ENET1_MDIO 0x2 + MX8MP_IOMUXC_SAI1_RXD4__ENET1_RGMII_RD0 0x90 + MX8MP_IOMUXC_SAI1_RXD5__ENET1_RGMII_RD1 0x90 + MX8MP_IOMUXC_SAI1_RXD6__ENET1_RGMII_RD2 0x90 + MX8MP_IOMUXC_SAI1_RXD7__ENET1_RGMII_RD3 0x90 + MX8MP_IOMUXC_SAI1_TXC__ENET1_RGMII_RXC 0x90 + MX8MP_IOMUXC_SAI1_TXFS__ENET1_RGMII_RX_CTL 0x90 + MX8MP_IOMUXC_SAI1_TXD0__ENET1_RGMII_TD0 0x16 + MX8MP_IOMUXC_SAI1_TXD1__ENET1_RGMII_TD1 0x16 + MX8MP_IOMUXC_SAI1_TXD2__ENET1_RGMII_TD2 0x16 + MX8MP_IOMUXC_SAI1_TXD3__ENET1_RGMII_TD3 0x16 + MX8MP_IOMUXC_SAI1_TXD4__ENET1_RGMII_TX_CTL 0x16 + MX8MP_IOMUXC_SAI1_TXD5__ENET1_RGMII_TXC 0x16 + MX8MP_IOMUXC_SAI1_RXD0__GPIO4_IO02 0x10 >; };
@@ -461,28 +477,28 @@
pinctrl_gpio_led: gpioledgrp { fsl,pins = < - MX8MP_IOMUXC_NAND_READY_B__GPIO3_IO16 0x19 + MX8MP_IOMUXC_NAND_READY_B__GPIO3_IO16 0x140 >; };
pinctrl_i2c1: i2c1grp { fsl,pins = < - MX8MP_IOMUXC_I2C1_SCL__I2C1_SCL 0x400001c3 - MX8MP_IOMUXC_I2C1_SDA__I2C1_SDA 0x400001c3 + MX8MP_IOMUXC_I2C1_SCL__I2C1_SCL 0x400001c2 + MX8MP_IOMUXC_I2C1_SDA__I2C1_SDA 0x400001c2 >; };
pinctrl_i2c3: i2c3grp { fsl,pins = < - MX8MP_IOMUXC_I2C3_SCL__I2C3_SCL 0x400001c3 - MX8MP_IOMUXC_I2C3_SDA__I2C3_SDA 0x400001c3 + MX8MP_IOMUXC_I2C3_SCL__I2C3_SCL 0x400001c2 + MX8MP_IOMUXC_I2C3_SDA__I2C3_SDA 0x400001c2 >; };
pinctrl_i2c5: i2c5grp { fsl,pins = < - MX8MP_IOMUXC_SPDIF_RX__I2C5_SDA 0x400001c3 - MX8MP_IOMUXC_SPDIF_TX__I2C5_SCL 0x400001c3 + MX8MP_IOMUXC_SPDIF_RX__I2C5_SDA 0x400001c2 + MX8MP_IOMUXC_SPDIF_TX__I2C5_SCL 0x400001c2 >; };
@@ -500,20 +516,20 @@
pinctrl_reg_usdhc2_vmmc: regusdhc2vmmcgrp { fsl,pins = < - MX8MP_IOMUXC_SD2_RESET_B__GPIO2_IO19 0x41 + MX8MP_IOMUXC_SD2_RESET_B__GPIO2_IO19 0x40 >; };
pinctrl_uart2: uart2grp { fsl,pins = < - MX8MP_IOMUXC_UART2_RXD__UART2_DCE_RX 0x49 - MX8MP_IOMUXC_UART2_TXD__UART2_DCE_TX 0x49 + MX8MP_IOMUXC_UART2_RXD__UART2_DCE_RX 0x140 + MX8MP_IOMUXC_UART2_TXD__UART2_DCE_TX 0x140 >; };
pinctrl_usb1_vbus: usb1grp { fsl,pins = < - MX8MP_IOMUXC_GPIO1_IO14__USB2_OTG_PWR 0x19 + MX8MP_IOMUXC_GPIO1_IO14__USB2_OTG_PWR 0x10 >; };
@@ -525,7 +541,7 @@ MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d0 MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d0 MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d0 - MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc1 + MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc0 >; };
@@ -537,7 +553,7 @@ MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d4 MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d4 MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d4 - MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc1 + MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc0 >; };
@@ -549,7 +565,7 @@ MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d6 MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d6 MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d6 - MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc1 + MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc0 >; };
diff --git a/arch/arm/dts/imx8mp-phyboard-pollux-rdk.dts b/arch/arm/dts/imx8mp-phyboard-pollux-rdk.dts index 984a6b9ded8..6aa720bafe2 100644 --- a/arch/arm/dts/imx8mp-phyboard-pollux-rdk.dts +++ b/arch/arm/dts/imx8mp-phyboard-pollux-rdk.dts @@ -116,48 +116,48 @@ &iomuxc { pinctrl_eqos: eqosgrp { fsl,pins = < - MX8MP_IOMUXC_ENET_MDC__ENET_QOS_MDC 0x3 - MX8MP_IOMUXC_ENET_MDIO__ENET_QOS_MDIO 0x3 - MX8MP_IOMUXC_ENET_RD0__ENET_QOS_RGMII_RD0 0x91 - MX8MP_IOMUXC_ENET_RD1__ENET_QOS_RGMII_RD1 0x91 - MX8MP_IOMUXC_ENET_RD2__ENET_QOS_RGMII_RD2 0x91 - MX8MP_IOMUXC_ENET_RD3__ENET_QOS_RGMII_RD3 0x91 - MX8MP_IOMUXC_ENET_RXC__CCM_ENET_QOS_CLOCK_GENERATE_RX_CLK 0x91 - MX8MP_IOMUXC_ENET_RX_CTL__ENET_QOS_RGMII_RX_CTL 0x91 - MX8MP_IOMUXC_ENET_TD0__ENET_QOS_RGMII_TD0 0x1f - MX8MP_IOMUXC_ENET_TD1__ENET_QOS_RGMII_TD1 0x1f - MX8MP_IOMUXC_ENET_TD2__ENET_QOS_RGMII_TD2 0x1f - MX8MP_IOMUXC_ENET_TD3__ENET_QOS_RGMII_TD3 0x1f - MX8MP_IOMUXC_ENET_TX_CTL__ENET_QOS_RGMII_TX_CTL 0x1f - MX8MP_IOMUXC_ENET_TXC__CCM_ENET_QOS_CLOCK_GENERATE_TX_CLK 0x1f + MX8MP_IOMUXC_ENET_MDC__ENET_QOS_MDC 0x2 + MX8MP_IOMUXC_ENET_MDIO__ENET_QOS_MDIO 0x2 + MX8MP_IOMUXC_ENET_RD0__ENET_QOS_RGMII_RD0 0x90 + MX8MP_IOMUXC_ENET_RD1__ENET_QOS_RGMII_RD1 0x90 + MX8MP_IOMUXC_ENET_RD2__ENET_QOS_RGMII_RD2 0x90 + MX8MP_IOMUXC_ENET_RD3__ENET_QOS_RGMII_RD3 0x90 + MX8MP_IOMUXC_ENET_RXC__CCM_ENET_QOS_CLOCK_GENERATE_RX_CLK 0x90 + MX8MP_IOMUXC_ENET_RX_CTL__ENET_QOS_RGMII_RX_CTL 0x90 + MX8MP_IOMUXC_ENET_TD0__ENET_QOS_RGMII_TD0 0x16 + MX8MP_IOMUXC_ENET_TD1__ENET_QOS_RGMII_TD1 0x16 + MX8MP_IOMUXC_ENET_TD2__ENET_QOS_RGMII_TD2 0x16 + MX8MP_IOMUXC_ENET_TD3__ENET_QOS_RGMII_TD3 0x16 + MX8MP_IOMUXC_ENET_TX_CTL__ENET_QOS_RGMII_TX_CTL 0x16 + MX8MP_IOMUXC_ENET_TXC__CCM_ENET_QOS_CLOCK_GENERATE_TX_CLK 0x16 MX8MP_IOMUXC_SAI1_MCLK__GPIO4_IO20 0x10 >; };
pinctrl_i2c2: i2c2grp { fsl,pins = < - MX8MP_IOMUXC_I2C2_SCL__I2C2_SCL 0x400001c3 - MX8MP_IOMUXC_I2C2_SDA__I2C2_SDA 0x400001c3 + MX8MP_IOMUXC_I2C2_SCL__I2C2_SCL 0x400001c2 + MX8MP_IOMUXC_I2C2_SDA__I2C2_SDA 0x400001c2 >; };
pinctrl_i2c2_gpio: i2c2gpiogrp { fsl,pins = < - MX8MP_IOMUXC_I2C2_SCL__GPIO5_IO16 0x1e3 - MX8MP_IOMUXC_I2C2_SDA__GPIO5_IO17 0x1e3 + MX8MP_IOMUXC_I2C2_SCL__GPIO5_IO16 0x1e2 + MX8MP_IOMUXC_I2C2_SDA__GPIO5_IO17 0x1e2 >; };
pinctrl_uart1: uart1grp { fsl,pins = < - MX8MP_IOMUXC_UART1_RXD__UART1_DCE_RX 0x49 - MX8MP_IOMUXC_UART1_TXD__UART1_DCE_TX 0x49 + MX8MP_IOMUXC_UART1_RXD__UART1_DCE_RX 0x40 + MX8MP_IOMUXC_UART1_TXD__UART1_DCE_TX 0x40 >; };
@@ -175,7 +175,7 @@ MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d0 MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d0 MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d0 - MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc1 + MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc0 >; };
@@ -187,7 +187,7 @@ MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d4 MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d4 MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d4 - MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc1 + MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc0 >; };
@@ -199,7 +199,7 @@ MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d6 MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d6 MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d6 - MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc1 + MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc0 >; }; }; diff --git a/arch/arm/dts/imx8mp-u-boot.dtsi b/arch/arm/dts/imx8mp-u-boot.dtsi index adb24cccc3b..ddced009903 100644 --- a/arch/arm/dts/imx8mp-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-u-boot.dtsi @@ -10,7 +10,7 @@ }; };
-&{/soc@0} { +&soc { u-boot,dm-pre-reloc; u-boot,dm-spl; }; diff --git a/arch/arm/dts/imx8mp-venice-gw74xx.dts b/arch/arm/dts/imx8mp-venice-gw74xx.dts index 101d3114760..521215520a0 100644 --- a/arch/arm/dts/imx8mp-venice-gw74xx.dts +++ b/arch/arm/dts/imx8mp-venice-gw74xx.dts @@ -622,15 +622,15 @@
pinctrl_hog: hoggrp { fsl,pins = < - MX8MP_IOMUXC_GPIO1_IO09__GPIO1_IO09 0x40000041 /* DIO0 */ - MX8MP_IOMUXC_GPIO1_IO11__GPIO1_IO11 0x40000041 /* DIO1 */ - MX8MP_IOMUXC_NAND_DQS__GPIO3_IO14 0x40000041 /* M2SKT_OFF# */ - MX8MP_IOMUXC_SD2_DATA2__GPIO2_IO17 0x40000159 /* PCIE1_WDIS# */ - MX8MP_IOMUXC_SD2_DATA3__GPIO2_IO18 0x40000159 /* PCIE2_WDIS# */ - MX8MP_IOMUXC_SD2_CMD__GPIO2_IO14 0x40000159 /* PCIE3_WDIS# */ - MX8MP_IOMUXC_NAND_DATA00__GPIO3_IO06 0x40000041 /* M2SKT_RST# */ - MX8MP_IOMUXC_SAI1_TXD6__GPIO4_IO18 0x40000159 /* M2SKT_WDIS# */ - MX8MP_IOMUXC_NAND_ALE__GPIO3_IO00 0x40000159 /* M2SKT_GDIS# */ + MX8MP_IOMUXC_GPIO1_IO09__GPIO1_IO09 0x40000040 /* DIO0 */ + MX8MP_IOMUXC_GPIO1_IO11__GPIO1_IO11 0x40000040 /* DIO1 */ + MX8MP_IOMUXC_NAND_DQS__GPIO3_IO14 0x40000040 /* M2SKT_OFF# */ + MX8MP_IOMUXC_SD2_DATA2__GPIO2_IO17 0x40000150 /* PCIE1_WDIS# */ + MX8MP_IOMUXC_SD2_DATA3__GPIO2_IO18 0x40000150 /* PCIE2_WDIS# */ + MX8MP_IOMUXC_SD2_CMD__GPIO2_IO14 0x40000150 /* PCIE3_WDIS# */ + MX8MP_IOMUXC_NAND_DATA00__GPIO3_IO06 0x40000040 /* M2SKT_RST# */ + MX8MP_IOMUXC_SAI1_TXD6__GPIO4_IO18 0x40000150 /* M2SKT_WDIS# */ + MX8MP_IOMUXC_NAND_ALE__GPIO3_IO00 0x40000150 /* M2SKT_GDIS# */ MX8MP_IOMUXC_SAI3_TXD__GPIO5_IO01 0x40000104 /* UART_TERM */ MX8MP_IOMUXC_SAI3_TXFS__GPIO4_IO31 0x40000104 /* UART_RS485 */ MX8MP_IOMUXC_SAI3_TXC__GPIO5_IO00 0x40000104 /* UART_HALF */ @@ -639,47 +639,47 @@
pinctrl_accel: accelgrp { fsl,pins = < - MX8MP_IOMUXC_GPIO1_IO07__GPIO1_IO07 0x159 + MX8MP_IOMUXC_GPIO1_IO07__GPIO1_IO07 0x150 >; };
pinctrl_eqos: eqosgrp { fsl,pins = < - MX8MP_IOMUXC_ENET_MDC__ENET_QOS_MDC 0x3 - MX8MP_IOMUXC_ENET_MDIO__ENET_QOS_MDIO 0x3 - MX8MP_IOMUXC_ENET_RD0__ENET_QOS_RGMII_RD0 0x91 - MX8MP_IOMUXC_ENET_RD1__ENET_QOS_RGMII_RD1 0x91 - MX8MP_IOMUXC_ENET_RD2__ENET_QOS_RGMII_RD2 0x91 - MX8MP_IOMUXC_ENET_RD3__ENET_QOS_RGMII_RD3 0x91 - MX8MP_IOMUXC_ENET_RXC__CCM_ENET_QOS_CLOCK_GENERATE_RX_CLK 0x91 - MX8MP_IOMUXC_ENET_RX_CTL__ENET_QOS_RGMII_RX_CTL 0x91 - MX8MP_IOMUXC_ENET_TD0__ENET_QOS_RGMII_TD0 0x1f - MX8MP_IOMUXC_ENET_TD1__ENET_QOS_RGMII_TD1 0x1f - MX8MP_IOMUXC_ENET_TD2__ENET_QOS_RGMII_TD2 0x1f - MX8MP_IOMUXC_ENET_TD3__ENET_QOS_RGMII_TD3 0x1f - MX8MP_IOMUXC_ENET_TX_CTL__ENET_QOS_RGMII_TX_CTL 0x1f - MX8MP_IOMUXC_ENET_TXC__CCM_ENET_QOS_CLOCK_GENERATE_TX_CLK 0x1f - MX8MP_IOMUXC_SAI3_RXD__GPIO4_IO30 0x141 /* RST# */ - MX8MP_IOMUXC_SAI3_RXFS__GPIO4_IO28 0x159 /* IRQ# */ + MX8MP_IOMUXC_ENET_MDC__ENET_QOS_MDC 0x2 + MX8MP_IOMUXC_ENET_MDIO__ENET_QOS_MDIO 0x2 + MX8MP_IOMUXC_ENET_RD0__ENET_QOS_RGMII_RD0 0x90 + MX8MP_IOMUXC_ENET_RD1__ENET_QOS_RGMII_RD1 0x90 + MX8MP_IOMUXC_ENET_RD2__ENET_QOS_RGMII_RD2 0x90 + MX8MP_IOMUXC_ENET_RD3__ENET_QOS_RGMII_RD3 0x90 + MX8MP_IOMUXC_ENET_RXC__CCM_ENET_QOS_CLOCK_GENERATE_RX_CLK 0x90 + MX8MP_IOMUXC_ENET_RX_CTL__ENET_QOS_RGMII_RX_CTL 0x90 + MX8MP_IOMUXC_ENET_TD0__ENET_QOS_RGMII_TD0 0x16 + MX8MP_IOMUXC_ENET_TD1__ENET_QOS_RGMII_TD1 0x16 + MX8MP_IOMUXC_ENET_TD2__ENET_QOS_RGMII_TD2 0x16 + MX8MP_IOMUXC_ENET_TD3__ENET_QOS_RGMII_TD3 0x16 + MX8MP_IOMUXC_ENET_TX_CTL__ENET_QOS_RGMII_TX_CTL 0x16 + MX8MP_IOMUXC_ENET_TXC__CCM_ENET_QOS_CLOCK_GENERATE_TX_CLK 0x16 + MX8MP_IOMUXC_SAI3_RXD__GPIO4_IO30 0x140 /* RST# */ + MX8MP_IOMUXC_SAI3_RXFS__GPIO4_IO28 0x150 /* IRQ# */ >; };
pinctrl_fec: fecgrp { fsl,pins = < - MX8MP_IOMUXC_SAI1_RXD4__ENET1_RGMII_RD0 0x91 - MX8MP_IOMUXC_SAI1_RXD5__ENET1_RGMII_RD1 0x91 - MX8MP_IOMUXC_SAI1_RXD6__ENET1_RGMII_RD2 0x91 - MX8MP_IOMUXC_SAI1_RXD7__ENET1_RGMII_RD3 0x91 - MX8MP_IOMUXC_SAI1_TXC__ENET1_RGMII_RXC 0x91 - MX8MP_IOMUXC_SAI1_TXFS__ENET1_RGMII_RX_CTL 0x91 - MX8MP_IOMUXC_SAI1_TXD0__ENET1_RGMII_TD0 0x1f - MX8MP_IOMUXC_SAI1_TXD1__ENET1_RGMII_TD1 0x1f - MX8MP_IOMUXC_SAI1_TXD2__ENET1_RGMII_TD2 0x1f - MX8MP_IOMUXC_SAI1_TXD3__ENET1_RGMII_TD3 0x1f - MX8MP_IOMUXC_SAI1_TXD4__ENET1_RGMII_TX_CTL 0x1f - MX8MP_IOMUXC_SAI1_TXD5__ENET1_RGMII_TXC 0x1f - MX8MP_IOMUXC_SAI1_RXFS__ENET1_1588_EVENT0_IN 0x141 - MX8MP_IOMUXC_SAI1_RXC__ENET1_1588_EVENT0_OUT 0x141 + MX8MP_IOMUXC_SAI1_RXD4__ENET1_RGMII_RD0 0x90 + MX8MP_IOMUXC_SAI1_RXD5__ENET1_RGMII_RD1 0x90 + MX8MP_IOMUXC_SAI1_RXD6__ENET1_RGMII_RD2 0x90 + MX8MP_IOMUXC_SAI1_RXD7__ENET1_RGMII_RD3 0x90 + MX8MP_IOMUXC_SAI1_TXC__ENET1_RGMII_RXC 0x90 + MX8MP_IOMUXC_SAI1_TXFS__ENET1_RGMII_RX_CTL 0x90 + MX8MP_IOMUXC_SAI1_TXD0__ENET1_RGMII_TD0 0x16 + MX8MP_IOMUXC_SAI1_TXD1__ENET1_RGMII_TD1 0x16 + MX8MP_IOMUXC_SAI1_TXD2__ENET1_RGMII_TD2 0x16 + MX8MP_IOMUXC_SAI1_TXD3__ENET1_RGMII_TD3 0x16 + MX8MP_IOMUXC_SAI1_TXD4__ENET1_RGMII_TX_CTL 0x16 + MX8MP_IOMUXC_SAI1_TXD5__ENET1_RGMII_TXC 0x16 + MX8MP_IOMUXC_SAI1_RXFS__ENET1_1588_EVENT0_IN 0x140 + MX8MP_IOMUXC_SAI1_RXC__ENET1_1588_EVENT0_OUT 0x140 >; };
@@ -692,61 +692,61 @@
pinctrl_gsc: gscgrp { fsl,pins = < - MX8MP_IOMUXC_SAI1_MCLK__GPIO4_IO20 0x159 + MX8MP_IOMUXC_SAI1_MCLK__GPIO4_IO20 0x150 >; };
pinctrl_i2c4: i2c4grp { fsl,pins = < - MX8MP_IOMUXC_I2C4_SCL__I2C4_SCL 0x400001c3 - MX8MP_IOMUXC_I2C4_SDA__I2C4_SDA 0x400001c3 + MX8MP_IOMUXC_I2C4_SCL__I2C4_SCL 0x400001c2 + MX8MP_IOMUXC_I2C4_SDA__I2C4_SDA 0x400001c2 >; };
pinctrl_ksz: kszgrp { fsl,pins = < - MX8MP_IOMUXC_SAI3_RXC__GPIO4_IO29 0x159 /* IRQ# */ - MX8MP_IOMUXC_SAI3_MCLK__GPIO5_IO02 0x141 /* RST# */ + MX8MP_IOMUXC_SAI3_RXC__GPIO4_IO29 0x150 /* IRQ# */ + MX8MP_IOMUXC_SAI3_MCLK__GPIO5_IO02 0x140 /* RST# */ >; };
pinctrl_gpio_leds: ledgrp { fsl,pins = < - MX8MP_IOMUXC_SD2_DATA0__GPIO2_IO15 0x19 - MX8MP_IOMUXC_SD2_DATA1__GPIO2_IO16 0x19 + MX8MP_IOMUXC_SD2_DATA0__GPIO2_IO15 0x10 + MX8MP_IOMUXC_SD2_DATA1__GPIO2_IO16 0x10 >; };
pinctrl_pmic: pmicgrp { fsl,pins = < - MX8MP_IOMUXC_NAND_DATA01__GPIO3_IO07 0x141 + MX8MP_IOMUXC_NAND_DATA01__GPIO3_IO07 0x140 >; };
pinctrl_pps: ppsgrp { fsl,pins = < - MX8MP_IOMUXC_GPIO1_IO12__GPIO1_IO12 0x141 + MX8MP_IOMUXC_GPIO1_IO12__GPIO1_IO12 0x140 >; };
@@ -758,13 +758,13 @@
pinctrl_reg_usb2: regusb2grp { fsl,pins = < - MX8MP_IOMUXC_GPIO1_IO06__GPIO1_IO06 0x141 + MX8MP_IOMUXC_GPIO1_IO06__GPIO1_IO06 0x140 >; };
pinctrl_reg_wifi: regwifigrp { fsl,pins = < - MX8MP_IOMUXC_NAND_DATA03__GPIO3_IO09 0x119 + MX8MP_IOMUXC_NAND_DATA03__GPIO3_IO09 0x110 >; };
@@ -811,7 +811,7 @@
pinctrl_uart3_gpio: uart3gpiogrp { fsl,pins = < - MX8MP_IOMUXC_NAND_DATA02__GPIO3_IO08 0x119 + MX8MP_IOMUXC_NAND_DATA02__GPIO3_IO08 0x110 >; };
diff --git a/arch/arm/dts/imx8mp-verdin.dtsi b/arch/arm/dts/imx8mp-verdin.dtsi index 68100a17263..900eae8e448 100644 --- a/arch/arm/dts/imx8mp-verdin.dtsi +++ b/arch/arm/dts/imx8mp-verdin.dtsi @@ -49,7 +49,7 @@ pinctrl-names = "default"; pinctrl-0 = <&pinctrl_gpio_keys>;
- wakeup { + button-wakeup { debounce-interval = <10>; /* Verdin CTRL_WAKE1_MICO# (SODIMM 252) */ gpios = <&gpio4 0 GPIO_ACTIVE_LOW>; @@ -146,6 +146,14 @@ }; };
+&cpu_alert0 { + temperature = <95000>; +}; + +&cpu_crit0 { + temperature = <105000>; +}; + /* Verdin SPI_1 */ &ecspi1 { #address-cells = <1>; @@ -619,7 +627,7 @@ interrupts = <5 IRQ_TYPE_EDGE_FALLING>; reg = <0x4a>; /* Verdin GPIO_2 (SODIMM 208) */ - reset-gpios = <&gpio1 1 GPIO_ACTIVE_HIGH>; + reset-gpios = <&gpio1 1 GPIO_ACTIVE_LOW>; status = "disabled"; }; }; @@ -696,7 +704,7 @@ pinctrl-0 = <&pinctrl_gpio_9_dsi>, <&pinctrl_i2s_2_bclk_touch_reset>; reg = <0x4a>; /* Verdin I2S_2_BCLK (TOUCH_RESET#, SODIMM 42) */ - reset-gpios = <&gpio5 0 GPIO_ACTIVE_HIGH>; + reset-gpios = <&gpio5 0 GPIO_ACTIVE_LOW>; status = "disabled"; };
diff --git a/arch/arm/dts/imx8mp.dtsi b/arch/arm/dts/imx8mp.dtsi index d9542dfff83..fe178b7d063 100644 --- a/arch/arm/dts/imx8mp.dtsi +++ b/arch/arm/dts/imx8mp.dtsi @@ -195,7 +195,7 @@ clk_ext4: clock-ext4 { compatible = "fixed-clock"; #clock-cells = <0>; - clock-frequency= <133000000>; + clock-frequency = <133000000>; clock-output-names = "clk_ext4"; };
@@ -293,7 +293,7 @@ arm,no-tick-in-suspend; };
- soc@0 { + soc: soc@0 { compatible = "fsl,imx8mp-soc", "simple-bus"; #address-cells = <1>; #size-cells = <1>; @@ -595,7 +595,7 @@ pgc_ispdwp: power-domain@18 { #power-domain-cells = <0>; reg = <IMX8MP_POWER_DOMAIN_MEDIAMIX_ISPDWP>; - clocks = <&clk IMX8MP_CLK_MEDIA_ISP_DIV>; + clocks = <&clk IMX8MP_CLK_MEDIA_ISP_ROOT>; }; }; }; @@ -791,6 +791,7 @@ compatible = "fsl,sec-v4.0-job-ring"; reg = <0x1000 0x1000>; interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; };
sec_jr1: jr@2000 { @@ -903,7 +904,7 @@ <&clk IMX8MP_CLK_USDHC1_ROOT>; clock-names = "ipg", "ahb", "per"; fsl,tuning-start-tap = <20>; - fsl,tuning-step= <2>; + fsl,tuning-step = <2>; bus-width = <4>; status = "disabled"; }; @@ -917,7 +918,7 @@ <&clk IMX8MP_CLK_USDHC2_ROOT>; clock-names = "ipg", "ahb", "per"; fsl,tuning-start-tap = <20>; - fsl,tuning-step= <2>; + fsl,tuning-step = <2>; bus-width = <4>; status = "disabled"; }; @@ -931,7 +932,7 @@ <&clk IMX8MP_CLK_USDHC3_ROOT>; clock-names = "ipg", "ahb", "per"; fsl,tuning-start-tap = <20>; - fsl,tuning-step= <2>; + fsl,tuning-step = <2>; bus-width = <4>; status = "disabled"; }; @@ -1018,6 +1019,26 @@ }; };
+ noc: interconnect@32700000 { + compatible = "fsl,imx8mp-noc", "fsl,imx8m-noc"; + reg = <0x32700000 0x100000>; + clocks = <&clk IMX8MP_CLK_NOC>; + #interconnect-cells = <1>; + operating-points-v2 = <&noc_opp_table>; + + noc_opp_table: opp-table { + compatible = "operating-points-v2"; + + opp-200M { + opp-hz = /bits/ 64 <200000000>; + }; + + opp-1000M { + opp-hz = /bits/ 64 <1000000000>; + }; + }; + }; + aips4: bus@32c00000 { compatible = "fsl,aips-bus", "simple-bus"; reg = <0x32c00000 0x400000>; diff --git a/include/dt-bindings/clock/imx8mp-clock.h b/include/dt-bindings/clock/imx8mp-clock.h index e8d68fbb6e3..9d5cc2ddde8 100644 --- a/include/dt-bindings/clock/imx8mp-clock.h +++ b/include/dt-bindings/clock/imx8mp-clock.h @@ -117,7 +117,6 @@ #define IMX8MP_CLK_AUDIO_AHB 108 #define IMX8MP_CLK_MIPI_DSI_ESC_RX 109 #define IMX8MP_CLK_IPG_ROOT 110 -#define IMX8MP_CLK_IPG_AUDIO_ROOT 111 #define IMX8MP_CLK_DRAM_ALT 112 #define IMX8MP_CLK_DRAM_APB 113 #define IMX8MP_CLK_VPU_G1 114 @@ -125,7 +124,6 @@ #define IMX8MP_CLK_CAN1 116 #define IMX8MP_CLK_CAN2 117 #define IMX8MP_CLK_MEMREPAIR 118 -#define IMX8MP_CLK_PCIE_PHY 119 #define IMX8MP_CLK_PCIE_AUX 120 #define IMX8MP_CLK_I2C5 121 #define IMX8MP_CLK_I2C6 122 @@ -182,8 +180,6 @@ #define IMX8MP_CLK_MEDIA_CAM2_PIX 173 #define IMX8MP_CLK_MEDIA_LDB 174 #define IMX8MP_CLK_MEDIA_MIPI_CSI2_ESC 175 -#define IMX8MP_CLK_PCIE2_CTRL 176 -#define IMX8MP_CLK_PCIE2_PHY 177 #define IMX8MP_CLK_MEDIA_MIPI_TEST_BYTE 178 #define IMX8MP_CLK_ECSPI3 179 #define IMX8MP_CLK_PDM 180 @@ -321,8 +317,15 @@ #define IMX8MP_CLK_AUDIO_AXI 310 #define IMX8MP_CLK_HSIO_AXI 311 #define IMX8MP_CLK_MEDIA_ISP 312 +#define IMX8MP_CLK_MEDIA_DISP2_PIX 313 +#define IMX8MP_CLK_CLKOUT1_SEL 314 +#define IMX8MP_CLK_CLKOUT1_DIV 315 +#define IMX8MP_CLK_CLKOUT1 316 +#define IMX8MP_CLK_CLKOUT2_SEL 317 +#define IMX8MP_CLK_CLKOUT2_DIV 318 +#define IMX8MP_CLK_CLKOUT2 319
-#define IMX8MP_CLK_END 313 +#define IMX8MP_CLK_END 320
#define IMX8MP_CLK_AUDIOMIX_SAI1_IPG 0 #define IMX8MP_CLK_AUDIOMIX_SAI1_MCLK1 1 diff --git a/include/dt-bindings/power/imx8mp-power.h b/include/dt-bindings/power/imx8mp-power.h index 3f72bf7818f..7789bcca322 100644 --- a/include/dt-bindings/power/imx8mp-power.h +++ b/include/dt-bindings/power/imx8mp-power.h @@ -38,9 +38,16 @@ #define IMX8MP_MEDIABLK_PD_ISI 3 #define IMX8MP_MEDIABLK_PD_MIPI_CSI2_2 4 #define IMX8MP_MEDIABLK_PD_LCDIF_2 5 -#define IMX8MP_MEDIABLK_PD_ISP2 6 -#define IMX8MP_MEDIABLK_PD_ISP1 7 -#define IMX8MP_MEDIABLK_PD_DWE 8 -#define IMX8MP_MEDIABLK_PD_MIPI_DSI_2 9 +#define IMX8MP_MEDIABLK_PD_ISP 6 +#define IMX8MP_MEDIABLK_PD_DWE 7 +#define IMX8MP_MEDIABLK_PD_MIPI_DSI_2 8 + +#define IMX8MP_HDMIBLK_PD_IRQSTEER 0 +#define IMX8MP_HDMIBLK_PD_LCDIF 1 +#define IMX8MP_HDMIBLK_PD_PAI 2 +#define IMX8MP_HDMIBLK_PD_PVI 3 +#define IMX8MP_HDMIBLK_PD_TRNG 4 +#define IMX8MP_HDMIBLK_PD_HDMI_TX 5 +#define IMX8MP_HDMIBLK_PD_HDMI_TX_PHY 6
#endif diff --git a/include/dt-bindings/reset/imx8mp-reset.h b/include/dt-bindings/reset/imx8mp-reset.h new file mode 100644 index 00000000000..2e8c9104b66 --- /dev/null +++ b/include/dt-bindings/reset/imx8mp-reset.h @@ -0,0 +1,50 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ +/* + * Copyright 2020 NXP + */ + +#ifndef DT_BINDING_RESET_IMX8MP_H +#define DT_BINDING_RESET_IMX8MP_H + +#define IMX8MP_RESET_A53_CORE_POR_RESET0 0 +#define IMX8MP_RESET_A53_CORE_POR_RESET1 1 +#define IMX8MP_RESET_A53_CORE_POR_RESET2 2 +#define IMX8MP_RESET_A53_CORE_POR_RESET3 3 +#define IMX8MP_RESET_A53_CORE_RESET0 4 +#define IMX8MP_RESET_A53_CORE_RESET1 5 +#define IMX8MP_RESET_A53_CORE_RESET2 6 +#define IMX8MP_RESET_A53_CORE_RESET3 7 +#define IMX8MP_RESET_A53_DBG_RESET0 8 +#define IMX8MP_RESET_A53_DBG_RESET1 9 +#define IMX8MP_RESET_A53_DBG_RESET2 10 +#define IMX8MP_RESET_A53_DBG_RESET3 11 +#define IMX8MP_RESET_A53_ETM_RESET0 12 +#define IMX8MP_RESET_A53_ETM_RESET1 13 +#define IMX8MP_RESET_A53_ETM_RESET2 14 +#define IMX8MP_RESET_A53_ETM_RESET3 15 +#define IMX8MP_RESET_A53_SOC_DBG_RESET 16 +#define IMX8MP_RESET_A53_L2RESET 17 +#define IMX8MP_RESET_SW_NON_SCLR_M7C_RST 18 +#define IMX8MP_RESET_OTG1_PHY_RESET 19 +#define IMX8MP_RESET_OTG2_PHY_RESET 20 +#define IMX8MP_RESET_SUPERMIX_RESET 21 +#define IMX8MP_RESET_AUDIOMIX_RESET 22 +#define IMX8MP_RESET_MLMIX_RESET 23 +#define IMX8MP_RESET_PCIEPHY 24 +#define IMX8MP_RESET_PCIEPHY_PERST 25 +#define IMX8MP_RESET_PCIE_CTRL_APPS_EN 26 +#define IMX8MP_RESET_PCIE_CTRL_APPS_TURNOFF 27 +#define IMX8MP_RESET_HDMI_PHY_APB_RESET 28 +#define IMX8MP_RESET_MEDIA_RESET 29 +#define IMX8MP_RESET_GPU2D_RESET 30 +#define IMX8MP_RESET_GPU3D_RESET 31 +#define IMX8MP_RESET_GPU_RESET 32 +#define IMX8MP_RESET_VPU_RESET 33 +#define IMX8MP_RESET_VPU_G1_RESET 34 +#define IMX8MP_RESET_VPU_G2_RESET 35 +#define IMX8MP_RESET_VPUVC8KE_RESET 36 +#define IMX8MP_RESET_NOC_RESET 37 + +#define IMX8MP_RESET_NUM 38 + +#endif
arch/arm/dts/imx8mn-beacon-baseboard.dtsi | 4 +- arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi | 2 +- .../dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi | 2 +- arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi | 2 +- arch/arm/dts/imx8mn-evk.dtsi | 45 ++++++++++++++++++- .../dts/imx8mn-var-som-symphony-u-boot.dtsi | 2 +- arch/arm/dts/imx8mn-var-som-symphony.dts | 6 +-- arch/arm/dts/imx8mn-venice-gw7902.dts | 8 ++-- arch/arm/dts/imx8mn-venice-u-boot.dtsi | 2 +- arch/arm/dts/imx8mn.dtsi | 13 +++--- include/dt-bindings/interconnect/imx8mn.h | 41 +++++++++++++++++ 11 files changed, 106 insertions(+), 21 deletions(-) create mode 100644 include/dt-bindings/interconnect/imx8mn.h
diff --git a/arch/arm/dts/imx8mn-beacon-baseboard.dtsi b/arch/arm/dts/imx8mn-beacon-baseboard.dtsi index 02f37dcda7e..9e82069c941 100644 --- a/arch/arm/dts/imx8mn-beacon-baseboard.dtsi +++ b/arch/arm/dts/imx8mn-beacon-baseboard.dtsi @@ -146,7 +146,7 @@ };
&easrc { - fsl,asrc-rate = <48000>; + fsl,asrc-rate = <48000>; status = "okay"; };
@@ -182,7 +182,7 @@ &usbotg1 { vbus-supply = <®_usb_otg_vbus>; disable-over-current; - dr_mode="otg"; + dr_mode = "otg"; status = "okay"; };
diff --git a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi index 5f839524028..6d8ba4c39af 100644 --- a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi @@ -15,7 +15,7 @@ }; };
-&{/soc@0} { +&soc { u-boot,dm-pre-reloc; u-boot,dm-spl; }; diff --git a/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi b/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi index c4ae7ca4f31..8312b64bcc0 100644 --- a/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi +++ b/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi @@ -16,7 +16,7 @@ }; };
-&{/soc@0} { +&soc { u-boot,dm-pre-reloc; u-boot,dm-spl; }; diff --git a/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi b/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi index 78773c198e4..edd9b959d09 100644 --- a/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi @@ -21,7 +21,7 @@ }; };
-&{/soc@0} { +&soc { u-boot,dm-pre-reloc; u-boot,dm-spl; }; diff --git a/arch/arm/dts/imx8mn-evk.dtsi b/arch/arm/dts/imx8mn-evk.dtsi index d1f6cccfa00..261c3654007 100644 --- a/arch/arm/dts/imx8mn-evk.dtsi +++ b/arch/arm/dts/imx8mn-evk.dtsi @@ -47,6 +47,11 @@ linux,autosuspend-period = <125>; };
+ audio_codec_bt_sco: audio-codec-bt-sco { + compatible = "linux,bt-sco"; + #sound-dai-cells = <1>; + }; + wm8524: audio-codec { #sound-dai-cells = <0>; compatible = "wlf,wm8524"; @@ -57,6 +62,25 @@ clock-names = "mclk"; };
+ sound-bt-sco { + compatible = "simple-audio-card"; + simple-audio-card,name = "bt-sco-audio"; + simple-audio-card,format = "dsp_a"; + simple-audio-card,bitclock-inversion; + simple-audio-card,frame-master = <&btcpu>; + simple-audio-card,bitclock-master = <&btcpu>; + + btcpu: simple-audio-card,cpu { + sound-dai = <&sai2>; + dai-tdm-slot-num = <2>; + dai-tdm-slot-width = <16>; + }; + + simple-audio-card,codec { + sound-dai = <&audio_codec_bt_sco 1>; + }; + }; + sound-wm8524 { compatible = "fsl,imx-audio-wm8524"; model = "wm8524-audio"; @@ -78,7 +102,7 @@ };
@@ -183,6 +207,16 @@ }; };
+&sai2 { + #sound-dai-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sai2>; + assigned-clocks = <&clk IMX8MN_CLK_SAI2>; + assigned-clock-parents = <&clk IMX8MN_AUDIO_PLL1_OUT>; + assigned-clock-rates = <24576000>; + status = "okay"; +}; + &sai3 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_sai3>; @@ -354,6 +388,15 @@ >; };
+ pinctrl_sai2: sai2grp { + fsl,pins = < + MX8MN_IOMUXC_SAI2_TXC_SAI2_TX_BCLK 0xd6 + MX8MN_IOMUXC_SAI2_TXFS_SAI2_TX_SYNC 0xd6 + MX8MN_IOMUXC_SAI2_TXD0_SAI2_TX_DATA0 0xd6 + MX8MN_IOMUXC_SAI2_RXD0_SAI2_RX_DATA0 0xd6 + >; + }; + pinctrl_sai3: sai3grp { fsl,pins = < MX8MN_IOMUXC_SAI3_TXFS_SAI3_TX_SYNC 0xd6 diff --git a/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi b/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi index ed1ab10ded3..28fcb10e595 100644 --- a/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi @@ -15,7 +15,7 @@ }; };
-&{/soc@0} { +&soc { u-boot,dm-pre-reloc; u-boot,dm-spl; }; diff --git a/arch/arm/dts/imx8mn-var-som-symphony.dts b/arch/arm/dts/imx8mn-var-som-symphony.dts index f61c48776cf..3ed7021a487 100644 --- a/arch/arm/dts/imx8mn-var-som-symphony.dts +++ b/arch/arm/dts/imx8mn-var-som-symphony.dts @@ -26,19 +26,19 @@ gpio-keys { compatible = "gpio-keys";
- back { + key-back { label = "Back"; gpios = <&pca9534 1 GPIO_ACTIVE_LOW>; linux,code = <KEY_BACK>; };
- home { + key-home { label = "Home"; gpios = <&pca9534 2 GPIO_ACTIVE_LOW>; linux,code = <KEY_HOME>; };
- menu { + key-menu { label = "Menu"; gpios = <&pca9534 3 GPIO_ACTIVE_LOW>; linux,code = <KEY_MENU>; diff --git a/arch/arm/dts/imx8mn-venice-gw7902.dts b/arch/arm/dts/imx8mn-venice-gw7902.dts index 367a232675a..636f8602b97 100644 --- a/arch/arm/dts/imx8mn-venice-gw7902.dts +++ b/arch/arm/dts/imx8mn-venice-gw7902.dts @@ -39,13 +39,13 @@ gpio-keys { compatible = "gpio-keys";
- user-pb { + key-user-pb { label = "user_pb"; gpios = <&gpio 2 GPIO_ACTIVE_LOW>; linux,code = <BTN_0>; };
- user-pb1x { + key-user-pb1x { label = "user_pb1x"; linux,code = <BTN_1>; interrupt-parent = <&gsc>; @@ -59,14 +59,14 @@ interrupts = <1>; };
- eeprom-wp { + key-eeprom-wp { label = "eeprom_wp"; linux,code = <BTN_3>; interrupt-parent = <&gsc>; interrupts = <2>; };
- tamper { + key-tamper { label = "tamper"; linux,code = <BTN_4>; interrupt-parent = <&gsc>; diff --git a/arch/arm/dts/imx8mn-venice-u-boot.dtsi b/arch/arm/dts/imx8mn-venice-u-boot.dtsi index 9fb38714523..1f4993cb670 100644 --- a/arch/arm/dts/imx8mn-venice-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-venice-u-boot.dtsi @@ -15,7 +15,7 @@ }; };
-&{/soc@0} { +&soc { u-boot,dm-pre-reloc; u-boot,dm-spl; }; diff --git a/arch/arm/dts/imx8mn.dtsi b/arch/arm/dts/imx8mn.dtsi index e41e1d56f98..0c71b740a31 100644 --- a/arch/arm/dts/imx8mn.dtsi +++ b/arch/arm/dts/imx8mn.dtsi @@ -212,7 +212,7 @@ clk_ext4: clock-ext4 { compatible = "fixed-clock"; #clock-cells = <0>; - clock-frequency= <133000000>; + clock-frequency = <133000000>; clock-output-names = "clk_ext4"; };
@@ -269,7 +269,7 @@ arm,no-tick-in-suspend; };
- soc@0 { + soc: soc@0 { compatible = "fsl,imx8mn-soc", "simple-bus"; #address-cells = <1>; #size-cells = <1>; @@ -422,7 +422,7 @@ "ctx2_rx", "ctx2_tx", "ctx3_rx", "ctx3_tx"; firmware-name = "imx/easrc/easrc-imx8mn.bin"; - fsl,asrc-rate = <8000>; + fsl,asrc-rate = <8000>; fsl,asrc-format = <2>; status = "disabled"; }; @@ -857,6 +857,7 @@ compatible = "fsl,sec-v4.0-job-ring"; reg = <0x1000 0x1000>; interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; };
sec_jr1: jr@2000 { @@ -941,7 +942,7 @@ <&clk IMX8MN_CLK_USDHC1_ROOT>; clock-names = "ipg", "ahb", "per"; fsl,tuning-start-tap = <20>; - fsl,tuning-step= <2>; + fsl,tuning-step = <2>; bus-width = <4>; status = "disabled"; }; @@ -955,7 +956,7 @@ <&clk IMX8MN_CLK_USDHC2_ROOT>; clock-names = "ipg", "ahb", "per"; fsl,tuning-start-tap = <20>; - fsl,tuning-step= <2>; + fsl,tuning-step = <2>; bus-width = <4>; status = "disabled"; }; @@ -969,7 +970,7 @@ <&clk IMX8MN_CLK_USDHC3_ROOT>; clock-names = "ipg", "ahb", "per"; fsl,tuning-start-tap = <20>; - fsl,tuning-step= <2>; + fsl,tuning-step = <2>; bus-width = <4>; status = "disabled"; }; diff --git a/include/dt-bindings/interconnect/imx8mn.h b/include/dt-bindings/interconnect/imx8mn.h new file mode 100644 index 00000000000..307b977100b --- /dev/null +++ b/include/dt-bindings/interconnect/imx8mn.h @@ -0,0 +1,41 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Interconnect framework driver for i.MX SoC + * + * Copyright (c) 2019-2020, NXP + */ + +#ifndef __DT_BINDINGS_INTERCONNECT_IMX8MN_H +#define __DT_BINDINGS_INTERCONNECT_IMX8MN_H + +#define IMX8MN_ICN_NOC 1 +#define IMX8MN_ICS_DRAM 2 +#define IMX8MN_ICS_OCRAM 3 +#define IMX8MN_ICM_A53 4 + +#define IMX8MN_ICM_GPU 5 +#define IMX8MN_ICN_GPU 6 + +#define IMX8MN_ICM_CSI1 7 +#define IMX8MN_ICM_CSI2 8 +#define IMX8MN_ICM_ISI 9 +#define IMX8MN_ICM_LCDIF 10 +#define IMX8MN_ICN_MIPI 11 + +#define IMX8MN_ICM_USB 12 + +#define IMX8MN_ICM_SDMA2 13 +#define IMX8MN_ICM_SDMA3 14 +#define IMX8MN_ICN_AUDIO 15 + +#define IMX8MN_ICN_ENET 16 +#define IMX8MN_ICM_ENET 17 + +#define IMX8MN_ICM_NAND 18 +#define IMX8MN_ICM_SDMA1 19 +#define IMX8MN_ICM_USDHC1 20 +#define IMX8MN_ICM_USDHC2 21 +#define IMX8MN_ICM_USDHC3 22 +#define IMX8MN_ICN_MAIN 23 + +#endif /* __DT_BINDINGS_INTERCONNECT_IMX8MN_H */
arch/arm/dts/imx8mm-beacon-baseboard.dtsi | 4 +- arch/arm/dts/imx8mm-evk.dtsi | 43 +++++++++++++++++++ arch/arm/dts/imx8mm-icore-mx8mm.dtsi | 12 +++--- arch/arm/dts/imx8mm-mx8menlo.dts | 4 +- arch/arm/dts/imx8mm-u-boot.dtsi | 2 +- arch/arm/dts/imx8mm-venice-gw700x.dtsi | 24 +++++------ arch/arm/dts/imx8mm-venice-gw7901.dts | 8 ++-- arch/arm/dts/imx8mm-venice-gw7902.dts | 10 ++--- arch/arm/dts/imx8mm-venice-gw7903.dts | 6 +-- arch/arm/dts/imx8mm-verdin.dtsi | 10 ++++- include/dt-bindings/interconnect/imx8mm.h | 50 +++++++++++++++++++++++ 11 files changed, 137 insertions(+), 36 deletions(-) create mode 100644 include/dt-bindings/interconnect/imx8mm.h
diff --git a/arch/arm/dts/imx8mm-beacon-baseboard.dtsi b/arch/arm/dts/imx8mm-beacon-baseboard.dtsi index f338a886d81..03266bd90a0 100644 --- a/arch/arm/dts/imx8mm-beacon-baseboard.dtsi +++ b/arch/arm/dts/imx8mm-beacon-baseboard.dtsi @@ -285,14 +285,14 @@ &usbotg1 { vbus-supply = <®_usbotg1>; disable-over-current; - dr_mode="otg"; + dr_mode = "otg"; status = "okay"; };
&usbotg2 { pinctrl-names = "default"; disable-over-current; - dr_mode="host"; + dr_mode = "host"; status = "okay"; };
diff --git a/arch/arm/dts/imx8mm-evk.dtsi b/arch/arm/dts/imx8mm-evk.dtsi index c42b966f7a6..7d6317d95b1 100644 --- a/arch/arm/dts/imx8mm-evk.dtsi +++ b/arch/arm/dts/imx8mm-evk.dtsi @@ -75,6 +75,11 @@ linux,autosuspend-period = <125>; };
+ audio_codec_bt_sco: audio-codec-bt-sco { + compatible = "linux,bt-sco"; + #sound-dai-cells = <1>; + }; + wm8524: audio-codec { #sound-dai-cells = <0>; compatible = "wlf,wm8524"; @@ -83,6 +88,25 @@ wlf,mute-gpios = <&gpio5 21 GPIO_ACTIVE_LOW>; };
+ sound-bt-sco { + compatible = "simple-audio-card"; + simple-audio-card,name = "bt-sco-audio"; + simple-audio-card,format = "dsp_a"; + simple-audio-card,bitclock-inversion; + simple-audio-card,frame-master = <&btcpu>; + simple-audio-card,bitclock-master = <&btcpu>; + + btcpu: simple-audio-card,cpu { + sound-dai = <&sai2>; + dai-tdm-slot-num = <2>; + dai-tdm-slot-width = <16>; + }; + + simple-audio-card,codec { + sound-dai = <&audio_codec_bt_sco 1>; + }; + }; + sound-wm8524 { compatible = "simple-audio-card"; simple-audio-card,name = "wm8524-audio"; @@ -346,6 +370,16 @@ status = "okay"; };
+&sai2 { + #sound-dai-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sai2>; + assigned-clocks = <&clk IMX8MM_CLK_SAI2>; + assigned-clock-parents = <&clk IMX8MM_AUDIO_PLL1_OUT>; + assigned-clock-rates = <24576000>; + status = "okay"; +}; + &sai3 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_sai3>; @@ -494,6 +528,15 @@ >; };
+ pinctrl_sai2: sai2grp { + fsl,pins = < + MX8MM_IOMUXC_SAI2_TXC_SAI2_TX_BCLK 0xd6 + MX8MM_IOMUXC_SAI2_TXFS_SAI2_TX_SYNC 0xd6 + MX8MM_IOMUXC_SAI2_TXD0_SAI2_TX_DATA0 0xd6 + MX8MM_IOMUXC_SAI2_RXD0_SAI2_RX_DATA0 0xd6 + >; + }; + pinctrl_sai3: sai3grp { fsl,pins = < MX8MM_IOMUXC_SAI3_TXFS_SAI3_TX_SYNC 0xd6 diff --git a/arch/arm/dts/imx8mm-icore-mx8mm.dtsi b/arch/arm/dts/imx8mm-icore-mx8mm.dtsi index b40148d728e..9e6170d9394 100644 --- a/arch/arm/dts/imx8mm-icore-mx8mm.dtsi +++ b/arch/arm/dts/imx8mm-icore-mx8mm.dtsi @@ -84,42 +84,42 @@ };
reg_buck1: buck1 { - regulator-min-microvolt = <400000>; + regulator-min-microvolt = <400000>; regulator-max-microvolt = <1800000>; regulator-always-on; regulator-boot-on; };
reg_buck2: buck2 { - regulator-min-microvolt = <400000>; + regulator-min-microvolt = <400000>; regulator-max-microvolt = <1800000>; regulator-always-on; regulator-boot-on; };
reg_buck3: buck3 { - regulator-min-microvolt = <400000>; + regulator-min-microvolt = <400000>; regulator-max-microvolt = <1800000>; regulator-always-on; regulator-boot-on; };
reg_buck4: buck4 { - regulator-min-microvolt = <400000>; + regulator-min-microvolt = <400000>; regulator-max-microvolt = <1800000>; regulator-always-on; regulator-boot-on; };
reg_buck5: buck5 { - regulator-min-microvolt = <400000>; + regulator-min-microvolt = <400000>; regulator-max-microvolt = <1800000>; regulator-always-on; regulator-boot-on; };
reg_buck6: buck6 { - regulator-min-microvolt = <400000>; + regulator-min-microvolt = <400000>; regulator-max-microvolt = <1800000>; regulator-always-on; regulator-boot-on; diff --git a/arch/arm/dts/imx8mm-mx8menlo.dts b/arch/arm/dts/imx8mm-mx8menlo.dts index 92eaf4ef456..c97f4e06ae5 100644 --- a/arch/arm/dts/imx8mm-mx8menlo.dts +++ b/arch/arm/dts/imx8mm-mx8menlo.dts @@ -20,13 +20,13 @@ pinctrl-names = "default"; pinctrl-0 = <&pinctrl_led>;
- user1 { + led-1 { label = "TestLed601"; gpios = <&gpio4 18 GPIO_ACTIVE_HIGH>; linux,default-trigger = "mmc0"; };
- user2 { + led-2 { label = "TestLed602"; gpios = <&gpio4 10 GPIO_ACTIVE_HIGH>; linux,default-trigger = "heartbeat"; diff --git a/arch/arm/dts/imx8mm-u-boot.dtsi b/arch/arm/dts/imx8mm-u-boot.dtsi index f792b421e89..05fd3e6aac1 100644 --- a/arch/arm/dts/imx8mm-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-u-boot.dtsi @@ -9,7 +9,7 @@ }; };
-&{/soc@0} { +&soc { u-boot,dm-pre-reloc; u-boot,dm-spl; }; diff --git a/arch/arm/dts/imx8mm-venice-gw700x.dtsi b/arch/arm/dts/imx8mm-venice-gw700x.dtsi index 00f86cada30..66a0d103c90 100644 --- a/arch/arm/dts/imx8mm-venice-gw700x.dtsi +++ b/arch/arm/dts/imx8mm-venice-gw700x.dtsi @@ -16,13 +16,13 @@ gpio-keys { compatible = "gpio-keys";
- user-pb1x { + key-user-pb1x { label = "user_pb1x"; linux,code = <BTN_1>; interrupt-parent = <&gsc>; @@ -36,14 +36,14 @@ interrupts = <1>; };
- tamper { + key-tamper { label = "tamper"; linux,code = <BTN_4>; interrupt-parent = <&gsc>; @@ -286,8 +286,8 @@ regulator-name = "buck1"; regulator-min-microvolt = <800000>; regulator-max-microvolt = <1000000>; - regulator-min-microamp = <3800000>; - regulator-max-microamp = <6800000>; + regulator-min-microamp = <3800000>; + regulator-max-microamp = <6800000>; regulator-boot-on; regulator-always-on; }; @@ -297,8 +297,8 @@ regulator-name = "buck2"; regulator-min-microvolt = <800000>; regulator-max-microvolt = <900000>; - regulator-min-microamp = <2200000>; - regulator-max-microamp = <5200000>; + regulator-min-microamp = <2200000>; + regulator-max-microamp = <5200000>; regulator-boot-on; regulator-always-on; }; @@ -308,8 +308,8 @@ regulator-name = "buck3"; regulator-min-microvolt = <800000>; regulator-max-microvolt = <1000000>; - regulator-min-microamp = <3800000>; - regulator-max-microamp = <6800000>; + regulator-min-microamp = <3800000>; + regulator-max-microamp = <6800000>; regulator-always-on; };
@@ -318,8 +318,8 @@ regulator-name = "buck4"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; - regulator-min-microamp = <2200000>; - regulator-max-microamp = <5200000>; + regulator-min-microamp = <2200000>; + regulator-max-microamp = <5200000>; regulator-boot-on; regulator-always-on; }; diff --git a/arch/arm/dts/imx8mm-venice-gw7901.dts b/arch/arm/dts/imx8mm-venice-gw7901.dts index 24737e89038..35fb929e7bc 100644 --- a/arch/arm/dts/imx8mm-venice-gw7901.dts +++ b/arch/arm/dts/imx8mm-venice-gw7901.dts @@ -38,13 +38,13 @@ gpio-keys { compatible = "gpio-keys";
- user-pb1x { + key-user-pb1x { label = "user_pb1x"; linux,code = <BTN_1>; interrupt-parent = <&gsc>; @@ -58,14 +58,14 @@ interrupts = <1>; };
- tamper { + key-tamper { label = "tamper"; linux,code = <BTN_4>; interrupt-parent = <&gsc>; diff --git a/arch/arm/dts/imx8mm-venice-gw7902.dts b/arch/arm/dts/imx8mm-venice-gw7902.dts index 407ab4592b4..6dc5eda2d25 100644 --- a/arch/arm/dts/imx8mm-venice-gw7902.dts +++ b/arch/arm/dts/imx8mm-venice-gw7902.dts @@ -42,13 +42,13 @@ gpio-keys { compatible = "gpio-keys";
- user-pb1x { + key-user-pb1x { label = "user_pb1x"; linux,code = <BTN_1>; interrupt-parent = <&gsc>; @@ -62,14 +62,14 @@ interrupts = <1>; };
- tamper { + key-tamper { label = "tamper"; linux,code = <BTN_4>; interrupt-parent = <&gsc>; @@ -651,7 +651,7 @@ pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart1>, <&pinctrl_uart1_gpio>; rts-gpios = <&gpio4 10 GPIO_ACTIVE_LOW>; - cts-gpios = <&gpio4 11 GPIO_ACTIVE_LOW>; + cts-gpios = <&gpio4 24 GPIO_ACTIVE_LOW>; uart-has-rtscts; status = "okay"; }; diff --git a/arch/arm/dts/imx8mm-venice-gw7903.dts b/arch/arm/dts/imx8mm-venice-gw7903.dts index a7dae9bd4c1..a65761a53f2 100644 --- a/arch/arm/dts/imx8mm-venice-gw7903.dts +++ b/arch/arm/dts/imx8mm-venice-gw7903.dts @@ -33,13 +33,13 @@ gpio-keys { compatible = "gpio-keys";
- user-pb1x { + key-user-pb1x { label = "user_pb1x"; linux,code = <BTN_1>; interrupt-parent = <&gsc>; @@ -53,7 +53,7 @@ interrupts = <1>; };
- eeprom-wp { + key-eeprom-wp { label = "eeprom_wp"; linux,code = <BTN_3>; interrupt-parent = <&gsc>; diff --git a/arch/arm/dts/imx8mm-verdin.dtsi b/arch/arm/dts/imx8mm-verdin.dtsi index eafa88d980b..d1b4582f44c 100644 --- a/arch/arm/dts/imx8mm-verdin.dtsi +++ b/arch/arm/dts/imx8mm-verdin.dtsi @@ -43,7 +43,7 @@ pinctrl-names = "default"; pinctrl-0 = <&pinctrl_gpio_keys>;
- wakeup { + key-wakeup { debounce-interval = <10>; /* Verdin CTRL_WAKE1_MICO# (SODIMM 252) */ gpios = <&gpio4 28 GPIO_ACTIVE_LOW>; @@ -154,6 +154,14 @@ cpu-supply = <®_vdd_arm>; };
+&cpu_alert0 { + temperature = <95000>; +}; + +&cpu_crit0 { + temperature = <105000>; +}; + &ddrc { operating-points-v2 = <&ddrc_opp_table>;
diff --git a/include/dt-bindings/interconnect/imx8mm.h b/include/dt-bindings/interconnect/imx8mm.h new file mode 100644 index 00000000000..8f10bb06cb5 --- /dev/null +++ b/include/dt-bindings/interconnect/imx8mm.h @@ -0,0 +1,50 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Interconnect framework driver for i.MX SoC + * + * Copyright (c) 2019, BayLibre + * Copyright (c) 2019-2020, NXP + * Author: Alexandre Bailon abailon@baylibre.com + */ + +#ifndef __DT_BINDINGS_INTERCONNECT_IMX8MM_H +#define __DT_BINDINGS_INTERCONNECT_IMX8MM_H + +#define IMX8MM_ICN_NOC 1 +#define IMX8MM_ICS_DRAM 2 +#define IMX8MM_ICS_OCRAM 3 +#define IMX8MM_ICM_A53 4 + +#define IMX8MM_ICM_VPU_H1 5 +#define IMX8MM_ICM_VPU_G1 6 +#define IMX8MM_ICM_VPU_G2 7 +#define IMX8MM_ICN_VIDEO 8 + +#define IMX8MM_ICM_GPU2D 9 +#define IMX8MM_ICM_GPU3D 10 +#define IMX8MM_ICN_GPU 11 + +#define IMX8MM_ICM_CSI 12 +#define IMX8MM_ICM_LCDIF 13 +#define IMX8MM_ICN_MIPI 14 + +#define IMX8MM_ICM_USB1 15 +#define IMX8MM_ICM_USB2 16 +#define IMX8MM_ICM_PCIE 17 +#define IMX8MM_ICN_HSIO 18 + +#define IMX8MM_ICM_SDMA2 19 +#define IMX8MM_ICM_SDMA3 20 +#define IMX8MM_ICN_AUDIO 21 + +#define IMX8MM_ICN_ENET 22 +#define IMX8MM_ICM_ENET 23 + +#define IMX8MM_ICN_MAIN 24 +#define IMX8MM_ICM_NAND 25 +#define IMX8MM_ICM_SDMA1 26 +#define IMX8MM_ICM_USDHC1 27 +#define IMX8MM_ICM_USDHC2 28 +#define IMX8MM_ICM_USDHC3 29 + +#endif /* __DT_BINDINGS_INTERCONNECT_IMX8MM_H */
Fabio Estevam
Jesse Taube
Marcel Ziswiler
Marcel Ziswiler
