[PATCH v4] mx7ulp: Add support for Embedded Artists COM board
The Embedded Artists COM board is based on NXP i.MX7ULP.
It has a BD70528 PMIC from Rohm with discrete DCDC powering option and improved current observability (compared to the existing NXP i.MX7ULP EVK).
Add the initial support for the board.
Signed-off-by: Fabio Estevam festevam@gmail.com --- Changes since v3: - Rebased against the latest u-boot-imx tree.
arch/arm/dts/Makefile | 3 +- arch/arm/dts/imx7ulp-com.dts | 90 ++++++++++++++++++++++ arch/arm/mach-imx/mx7ulp/Kconfig | 6 ++ board/ea/mx7ulp_com/Kconfig | 12 +++ board/ea/mx7ulp_com/MAINTAINERS | 6 ++ board/ea/mx7ulp_com/Makefile | 6 ++ board/ea/mx7ulp_com/imximage.cfg | 128 +++++++++++++++++++++++++++++++ board/ea/mx7ulp_com/mx7ulp_com.c | 48 ++++++++++++ configs/mx7ulp_com_defconfig | 61 +++++++++++++++ include/configs/mx7ulp_com.h | 103 +++++++++++++++++++++++++ 10 files changed, 462 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imx7ulp-com.dts create mode 100644 board/ea/mx7ulp_com/Kconfig create mode 100644 board/ea/mx7ulp_com/MAINTAINERS create mode 100644 board/ea/mx7ulp_com/Makefile create mode 100644 board/ea/mx7ulp_com/imximage.cfg create mode 100644 board/ea/mx7ulp_com/mx7ulp_com.c create mode 100644 configs/mx7ulp_com_defconfig create mode 100644 include/configs/mx7ulp_com.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d8846df1bd..9a92de71eb 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -657,7 +657,8 @@ dtb-$(CONFIG_MX7) += imx7d-sdb.dtb \ imx7d-pico-hobbit.dtb
-dtb-$(CONFIG_ARCH_MX7ULP) += imx7ulp-evk.dtb +dtb-$(CONFIG_ARCH_MX7ULP) += imx7ulp-com.dtb \ + imx7ulp-evk.dtb
dtb-$(CONFIG_ARCH_IMX8) += \ fsl-imx8qm-apalis.dtb \ diff --git a/arch/arm/dts/imx7ulp-com.dts b/arch/arm/dts/imx7ulp-com.dts new file mode 100644 index 0000000000..c01e03dd06 --- /dev/null +++ b/arch/arm/dts/imx7ulp-com.dts @@ -0,0 +1,90 @@ +// SPDX-License-Identifier: GPL-2.0 +// +// Copyright 2019 NXP +// Author: Fabio Estevam fabio.estevam@nxp.com + +/dts-v1/; + +#include "imx7ulp.dtsi" + +/ { + model = "Embedded Artists i.MX7ULP COM"; + compatible = "ea,imx7ulp-com", "fsl,imx7ulp"; + + chosen { + stdout-path = &lpuart4; + }; + + memory { + device_type = "memory"; + reg = <0x60000000 0x8000000>; + }; +}; + +&lpuart4 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lpuart4>; + status = "okay"; +}; + +&usbotg1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbotg1_id>; + srp-disable; + hnp-disable; + adp-disable; + status = "okay"; +}; + +&usbphy1 { + fsl,tx-d-cal = <88>; +}; + +&usdhc0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc0>; + non-removable; + bus-width = <8>; + no-1-8-v; + status = "okay"; +}; + +&iomuxc1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog_1>; + + pinctrl_hog_1: hoggrp-1 { + fsl,pins = < + IMX7ULP_PAD_PTC1__PTC1 0x20000 + >; + }; + + pinctrl_lpuart4: lpuart4grp { + fsl,pins = < + IMX7ULP_PAD_PTC3__LPUART4_RX 0x3 + IMX7ULP_PAD_PTC2__LPUART4_TX 0x3 + >; + }; + + pinctrl_usdhc0: usdhc0grp { + fsl,pins = < + IMX7ULP_PAD_PTD1__SDHC0_CMD 0x43 + IMX7ULP_PAD_PTD2__SDHC0_CLK 0x10042 + IMX7ULP_PAD_PTD3__SDHC0_D7 0x43 + IMX7ULP_PAD_PTD4__SDHC0_D6 0x43 + IMX7ULP_PAD_PTD5__SDHC0_D5 0x43 + IMX7ULP_PAD_PTD6__SDHC0_D4 0x43 + IMX7ULP_PAD_PTD7__SDHC0_D3 0x43 + IMX7ULP_PAD_PTD8__SDHC0_D2 0x43 + IMX7ULP_PAD_PTD9__SDHC0_D1 0x43 + IMX7ULP_PAD_PTD10__SDHC0_D0 0x43 + IMX7ULP_PAD_PTD11__SDHC0_DQS 0x42 + >; + }; + + pinctrl_usbotg1_id: otg1idgrp { + fsl,pins = < + IMX7ULP_PAD_PTC13__USB0_ID 0x10003 + >; + }; +}; diff --git a/arch/arm/mach-imx/mx7ulp/Kconfig b/arch/arm/mach-imx/mx7ulp/Kconfig index 138c58363f..6680f856c5 100644 --- a/arch/arm/mach-imx/mx7ulp/Kconfig +++ b/arch/arm/mach-imx/mx7ulp/Kconfig @@ -15,6 +15,11 @@ choice prompt "MX7ULP board select" optional
+config TARGET_MX7ULP_COM + bool "Support MX7ULP COM board" + select MX7ULP + select SYS_ARCH_TIMER + config TARGET_MX7ULP_EVK bool "Support mx7ulp EVK board" select MX7ULP @@ -22,6 +27,7 @@ config TARGET_MX7ULP_EVK
endchoice
+source "board/ea/mx7ulp_com/Kconfig" source "board/freescale/mx7ulp_evk/Kconfig"
endif diff --git a/board/ea/mx7ulp_com/Kconfig b/board/ea/mx7ulp_com/Kconfig new file mode 100644 index 0000000000..90883aced4 --- /dev/null +++ b/board/ea/mx7ulp_com/Kconfig @@ -0,0 +1,12 @@ +if TARGET_MX7ULP_COM + +config SYS_BOARD + default "mx7ulp_com" + +config SYS_VENDOR + default "ea" + +config SYS_CONFIG_NAME + default "mx7ulp_com" + +endif diff --git a/board/ea/mx7ulp_com/MAINTAINERS b/board/ea/mx7ulp_com/MAINTAINERS new file mode 100644 index 0000000000..3f69511b1a --- /dev/null +++ b/board/ea/mx7ulp_com/MAINTAINERS @@ -0,0 +1,6 @@ +MX7ULPCOM BOARD +M: Fabio Estevam festevam@gmail.com +S: Maintained +F: board/ea/mx7ulp_com/ +F: include/configs/mx7ulp_com.h +F: configs/mx7ulp_com_defconfig diff --git a/board/ea/mx7ulp_com/Makefile b/board/ea/mx7ulp_com/Makefile new file mode 100644 index 0000000000..b3b230b172 --- /dev/null +++ b/board/ea/mx7ulp_com/Makefile @@ -0,0 +1,6 @@ +# (C) Copyright 2016 Freescale Semiconductor, Inc. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := mx7ulp_com.o diff --git a/board/ea/mx7ulp_com/imximage.cfg b/board/ea/mx7ulp_com/imximage.cfg new file mode 100644 index 0000000000..bda4acfd91 --- /dev/null +++ b/board/ea/mx7ulp_com/imximage.cfg @@ -0,0 +1,128 @@ +/* + * Copyright (C) 2016 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +#define __ASSEMBLY__ +#include <config.h> + +/* image version */ + +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi/sd/nand/onenand, qspi/nor + */ + +BOOT_FROM sd + +#ifdef CONFIG_USE_IMXIMG_PLUGIN +/*PLUGIN plugin-binary-file IRAM_FREE_START_ADDR*/ +PLUGIN board/freescale/mx7ulp_evk/plugin.bin 0x2F020000 +#else + +#ifdef CONFIG_SECURE_BOOT +CSF CONFIG_CSF_SIZE +#endif +/* + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ +DATA 4 0x403f00dc 0x00000000 +DATA 4 0x403e0040 0x01000020 +DATA 4 0x403e0500 0x01000000 +DATA 4 0x403e050c 0x80808080 +DATA 4 0x403e0508 0x00160002 +DATA 4 0x403E0510 0x00000001 +DATA 4 0x403E0514 0x00000014 +DATA 4 0x403e0500 0x00000001 +CHECK_BITS_SET 4 0x403e0500 0x01000000 +DATA 4 0x403e050c 0x8080801B +CHECK_BITS_SET 4 0x403e050c 0x00000040 +DATA 4 0x403E0030 0x00000001 +DATA 4 0x403e0040 0x11000020 +DATA 4 0x403f00dc 0x42000000 + +DATA 4 0x40B300AC 0x40000000 + +DATA 4 0x40AD0128 0x00040000 +DATA 4 0x40AD00F8 0x00000000 +DATA 4 0x40AD00D8 0x00000180 +DATA 4 0x40AD0104 0x00000180 +DATA 4 0x40AD0108 0x00000180 +DATA 4 0x40AD0124 0x00010000 +DATA 4 0x40AD0080 0x0000018C +DATA 4 0x40AD0084 0x0000018C +DATA 4 0x40AD0088 0x0000018C +DATA 4 0x40AD008C 0x0000018C + +DATA 4 0x40AD0120 0x00010000 +DATA 4 0x40AD010C 0x00000180 +DATA 4 0x40AD0110 0x00000180 +DATA 4 0x40AD0114 0x00000180 +DATA 4 0x40AD0118 0x00000180 +DATA 4 0x40AD0090 0x00000180 +DATA 4 0x40AD0094 0x00000180 +DATA 4 0x40AD0098 0x00000180 +DATA 4 0x40AD009C 0x00000180 + +DATA 4 0x40AD00E0 0x00040000 +DATA 4 0x40AD00E4 0x00040000 + +DATA 4 0x40AB001C 0x00008000 +DATA 4 0x40AB085C 0x0D3900A0 +DATA 4 0x40AB0800 0xA1390003 +DATA 4 0x40AB0890 0x00400000 +DATA 4 0x40AB081C 0x33333333 +DATA 4 0x40AB0820 0x33333333 +DATA 4 0x40AB0824 0x33333333 +DATA 4 0x40AB0828 0x33333333 +DATA 4 0x40AB08C0 0x24922492 +DATA 4 0x40AB0848 0x3A3E3838 +DATA 4 0x40AB0850 0x28282C2A +DATA 4 0x40AB083C 0x20000000 +DATA 4 0x40AB0840 0x00000000 +DATA 4 0x40AB08B8 0x00000800 +DATA 4 0x40AB000C 0x292C40F5 +DATA 4 0x40AB0004 0x00020064 +DATA 4 0x40AB0010 0xB6AD0A83 +DATA 4 0x40AB0014 0x00C70093 +DATA 4 0x40AB0018 0x00211708 +DATA 4 0x40AB002C 0x0F9F26D2 +DATA 4 0x40AB0030 0x009F0E10 +DATA 4 0x40AB0038 0x00130556 +DATA 4 0x40AB0008 0x12272000 +DATA 4 0x40AB0040 0x0000003F +DATA 4 0x40AB0000 0xC3110000 +DATA 4 0x40AB001C 0x00008010 +DATA 4 0x40AB001C 0x00008018 +DATA 4 0x40AB001C 0x003F8030 +DATA 4 0x40AB001C 0xFF0A8030 +DATA 4 0x40AB001C 0x82018030 +DATA 4 0x40AB001C 0x06028030 +DATA 4 0x40AB001C 0x01038030 +DATA 4 0x40AB001C 0x003F8038 +DATA 4 0x40AB001C 0xFF0A8038 +DATA 4 0x40AB001C 0x82018038 +DATA 4 0x40AB001C 0x06028038 +DATA 4 0x40AB001C 0x01038038 +DATA 4 0x40AB083C 0xA0000000 +DATA 4 0x40AB083C 0xA0000000 +DATA 4 0x40AB0020 0x00001800 +DATA 4 0x40AB0800 0xA1310003 +DATA 4 0x40AB001C 0x00000000 +#endif diff --git a/board/ea/mx7ulp_com/mx7ulp_com.c b/board/ea/mx7ulp_com/mx7ulp_com.c new file mode 100644 index 0000000000..6fc1631bf7 --- /dev/null +++ b/board/ea/mx7ulp_com/mx7ulp_com.c @@ -0,0 +1,48 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Freescale Semiconductor, Inc. + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/mx7ulp-pins.h> +#include <asm/arch/iomux.h> +#include <asm/gpio.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_PUS_UP) + +int dram_init(void) +{ + gd->ram_size = imx_ddr_size(); + + return 0; +} + +static iomux_cfg_t const lpuart4_pads[] = { + MX7ULP_PAD_PTC3__LPUART4_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX7ULP_PAD_PTC2__LPUART4_TX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static void setup_iomux_uart(void) +{ + mx7ulp_iomux_setup_multiple_pads(lpuart4_pads, + ARRAY_SIZE(lpuart4_pads)); +} + +int board_early_init_f(void) +{ + setup_iomux_uart(); + + return 0; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + return 0; +} diff --git a/configs/mx7ulp_com_defconfig b/configs/mx7ulp_com_defconfig new file mode 100644 index 0000000000..68a720ae0c --- /dev/null +++ b/configs/mx7ulp_com_defconfig @@ -0,0 +1,61 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX7ULP=y +CONFIG_SYS_TEXT_BASE=0x67800000 +CONFIG_LDO_ENABLED_MODE=y +CONFIG_TARGET_MX7ULP_COM=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_IMX7ULP_LOWER_DDR_FREQUENCY=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/ea/mx7ulp_com/imximage.cfg" +CONFIG_DEFAULT_FDT_FILE="imx7ulp-com" +CONFIG_BOUNCE_BUFFER=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_READ=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx7ulp-com" +CONFIG_ENV_IS_IN_MMC=y +# CONFIG_NET is not set +CONFIG_DM=y +CONFIG_DM_GPIO=y +CONFIG_IMX_RGPIO2P=y +# CONFIG_MXC_GPIO is not set +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_IMX_LPI2C=y +CONFIG_DM_MMC=y +CONFIG_FSL_USDHC=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=40000000 +CONFIG_SPI_FLASH_ATMEL=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX7ULP=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y +CONFIG_FSL_LPUART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_QSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_CI_UDC=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_ULP_WATCHDOG=y diff --git a/include/configs/mx7ulp_com.h b/include/configs/mx7ulp_com.h new file mode 100644 index 0000000000..bccfea812d --- /dev/null +++ b/include/configs/mx7ulp_com.h @@ -0,0 +1,103 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2016 Freescale Semiconductor, Inc. + * + * Configuration settings for the Embedded Artists i.MX7ULP COM board. + */ + +#ifndef __MX7ULP_COM_CONFIG_H +#define __MX7ULP_COM_CONFIG_H + +#include <linux/sizes.h> +#include <asm/arch/imx-regs.h> + +#define CONFIG_BOARD_POSTCLK_INIT +#define CONFIG_SYS_BOOTM_LEN 0x1000000 + +#define SRC_BASE_ADDR CMC1_RBASE +#define IRAM_BASE_ADDR OCRAM_0_BASE +#define IOMUXC_BASE_ADDR IOMUXC1_RBASE + +/* + * Detect overlap between U-Boot image and environment area in build-time + * + * CONFIG_BOARD_SIZE_LIMIT = CONFIG_ENV_OFFSET - u-boot-dtb.imx offset + * CONFIG_BOARD_SIZE_LIMIT = 768k - 1k = 767k = 785408 + * + * Currently CONFIG_BOARD_SIZE_LIMIT does not handle expressions, so + * write the direct value here + */ +#define CONFIG_BOARD_SIZE_LIMIT 785408 +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_MMCROOT "/dev/mmcblk0p2" +#define CONFIG_SYS_MMC_IMG_LOAD_PART 1 + +/* Using ULP WDOG for reset */ +#define WDOG_BASE_ADDR WDG1_RBASE + +#define CONFIG_SYS_HZ_CLOCK 1000000 /* Fixed at 1MHz from TSTMR */ + +#define CONFIG_INITRD_TAG +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (8 * SZ_1M) + +/* UART */ +#define LPUART_BASE LPUART4_RBASE + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* Physical Memory Map */ + +#define PHYS_SDRAM 0x60000000 +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM + +#define CONFIG_LOADADDR 0x60800000 + +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + SZ_512M) + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "image=zImage\0" \ + "console=ttyLP0\0" \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "fdt_file=imx7ulp-com.dtb\0" \ + "fdt_addr=0x63000000\0" \ + "mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \ + "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \ + "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} " \ + "root=${mmcroot}\0" \ + "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if run loadfdt; then " \ + "bootz ${loadaddr} - ${fdt_addr}; " \ + "fi;\0" \ + +#define CONFIG_BOOTCOMMAND \ + "if run loadimage; then " \ + "run mmcboot; " \ + "fi; " \ + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE SZ_256K + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#if !CONFIG_IS_ENABLED(SYS_DCACHE_OFF) +#define CONFIG_CMD_CACHE +#endif + +#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#endif /* __CONFIG_H */
Fabio Estevam
