[PATCH] arm64: zynqmp: Update rproc node
remoteproc node should be updated to be aligned with the latest dt-schema.
Signed-off-by: Michal Simek michal.simek@amd.com ---
Once we push all dts to Linux we can change to OF_UPSTREAM but till that time we need to keep DTSes in sync. --- arch/arm/dts/zynqmp.dtsi | 67 +++++++++++++++++-- include/dt-bindings/power/xlnx-zynqmp-power.h | 17 ++--- 2 files changed, 68 insertions(+), 16 deletions(-)
diff --git a/arch/arm/dts/zynqmp.dtsi b/arch/arm/dts/zynqmp.dtsi index 53a606c340a4..34f592c1a85f 100644 --- a/arch/arm/dts/zynqmp.dtsi +++ b/arch/arm/dts/zynqmp.dtsi @@ -314,19 +314,76 @@ ranges; };
- remoteproc { + rproc_lockstep: remoteproc@ffe00000 { compatible = "xlnx,zynqmp-r5fss"; xlnx,cluster-mode = <1>; + xlnx,tcm-mode = <1>;
- r5f-0 { + #address-cells = <2>; + #size-cells = <2>; + + ranges = <0x0 0x0 0x0 0xffe00000 0x0 0x10000>, + <0x0 0x20000 0x0 0xffe20000 0x0 0x10000>, + <0x0 0x10000 0x0 0xffe10000 0x0 0x10000>, + <0x0 0x30000 0x0 0xffe30000 0x0 0x10000>; + + r5f@0 { + compatible = "xlnx,zynqmp-r5f"; + reg = <0x0 0x0 0x0 0x10000>, + <0x0 0x20000 0x0 0x10000>, + <0x0 0x10000 0x0 0x10000>, + <0x0 0x30000 0x0 0x10000>; + reg-names = "atcm0", "btcm0", "atcm1", "btcm1"; + power-domains = <&zynqmp_firmware PD_RPU_0>, + <&zynqmp_firmware PD_R5_0_ATCM>, + <&zynqmp_firmware PD_R5_0_BTCM>, + <&zynqmp_firmware PD_R5_1_ATCM>, + <&zynqmp_firmware PD_R5_1_BTCM>; + memory-region = <&rproc_0_fw_image>; + }; + + r5f@1 { + compatible = "xlnx,zynqmp-r5f"; + reg = <0x1 0x0 0x0 0x10000>, <0x1 0x20000 0x0 0x10000>; + reg-names = "atcm0", "btcm0"; + power-domains = <&zynqmp_firmware PD_RPU_1>, + <&zynqmp_firmware PD_R5_1_ATCM>, + <&zynqmp_firmware PD_R5_1_BTCM>; + memory-region = <&rproc_1_fw_image>; + }; + }; + + rproc_split: remoteproc-split@ffe00000 { + status = "disabled"; + compatible = "xlnx,zynqmp-r5fss"; + xlnx,cluster-mode = <0>; + xlnx,tcm-mode = <0>; + + #address-cells = <2>; + #size-cells = <2>; + + ranges = <0x0 0x0 0x0 0xffe00000 0x0 0x10000>, + <0x0 0x20000 0x0 0xffe20000 0x0 0x10000>, + <0x1 0x0 0x0 0xffe90000 0x0 0x10000>, + <0x1 0x20000 0x0 0xffeb0000 0x0 0x10000>; + + r5f@0 { compatible = "xlnx,zynqmp-r5f"; - power-domains = <&zynqmp_firmware PD_RPU_0>; + reg = <0x0 0x0 0x0 0x10000>, <0x0 0x20000 0x0 0x10000>; + reg-names = "atcm0", "btcm0"; + power-domains = <&zynqmp_firmware PD_RPU_0>, + <&zynqmp_firmware PD_R5_0_ATCM>, + <&zynqmp_firmware PD_R5_0_BTCM>; memory-region = <&rproc_0_fw_image>; };
- r5f-1 { + r5f@1 { compatible = "xlnx,zynqmp-r5f"; - power-domains = <&zynqmp_firmware PD_RPU_1>; + reg = <0x1 0x0 0x0 0x10000>, <0x1 0x20000 0x0 0x10000>; + reg-names = "atcm0", "btcm0"; + power-domains = <&zynqmp_firmware PD_RPU_1>, + <&zynqmp_firmware PD_R5_1_ATCM>, + <&zynqmp_firmware PD_R5_1_BTCM>; memory-region = <&rproc_1_fw_image>; }; }; diff --git a/include/dt-bindings/power/xlnx-zynqmp-power.h b/include/dt-bindings/power/xlnx-zynqmp-power.h index e7eb0960480a..618024cbb20d 100644 --- a/include/dt-bindings/power/xlnx-zynqmp-power.h +++ b/include/dt-bindings/power/xlnx-zynqmp-power.h @@ -6,16 +6,12 @@ #ifndef _DT_BINDINGS_ZYNQMP_POWER_H #define _DT_BINDINGS_ZYNQMP_POWER_H
-#define PD_RPU_0 6 -#define PD_RPU_1 7 -#define PD_OCM_BANK_0 11 -#define PD_OCM_BANK_1 12 -#define PD_OCM_BANK_2 13 -#define PD_OCM_BANK_3 14 -#define PD_TCM_BANK_0 15 -#define PD_TCM_BANK_1 16 -#define PD_TCM_BANK_2 17 -#define PD_TCM_BANK_3 18 +#define PD_RPU_0 7 +#define PD_RPU_1 8 +#define PD_R5_0_ATCM 15 +#define PD_R5_0_BTCM 16 +#define PD_R5_1_ATCM 17 +#define PD_R5_1_BTCM 18 #define PD_USB_0 22 #define PD_USB_1 23 #define PD_TTC_0 24 @@ -45,6 +41,5 @@ #define PD_CAN_1 48 #define PD_GPU 58 #define PD_PCIE 59 -#define PD_PL 69
#endif
- remoteproc {
- rproc_lockstep: remoteproc@ffe00000 { compatible = "xlnx,zynqmp-r5fss"; xlnx,cluster-mode = <1>;
r5f-0 {
#size-cells = <2>;
r5f@0 {
r5f@1 {
- rproc_split: remoteproc-split@ffe00000 {
#size-cells = <2>;
};<&zynqmp_firmware PD_R5_0_BTCM>; memory-region = <&rproc_0_fw_image>;
r5f-1 {
}; };<&zynqmp_firmware PD_R5_1_BTCM>; memory-region = <&rproc_1_fw_image>;
This last change looks unrelated. Other than that looks good to me.
Thanks.
#endif
- remoteproc {
r5f-0 {
#size-cells = <2>;
r5f@0 {
r5f@1 {
#size-cells = <2>;
r5f-1 {
You are using new PD_R5_1_ATCM, etc that's why also this part is needed.
That removing PD_PL is unrelated. I can split it but not sure if it is worth of separate patch but can be done for sure.
Thanks, Michal
Reviewed-by: Tanmay Shah tanmay.shah@amd.com
- remoteproc {
r5f-0 {
#size-cells = <2>;
r5f@0 {
r5f@1 {
#size-cells = <2>;
r5f-1 {
Yeah I meant removing PD_PL. I am okay to include in this patch as well.
Thanks, Michal
- remoteproc {
r5f-0 {
#size-cells = <2>;
r5f@0 {
r5f@1 {
#size-cells = <2>;
r5f-1 {
#endif
Applied. M
Michal Simek
Tanmay Shah
