[U-Boot] [RFC] command/cache: Add flush_cache command
When we need the copied code/data in the main memory, we can flush the cache now. It uses the existing function flush_cache. Syntax is
flush_cache <addr> <size>
The addr and size are given in hexadecimal. Like memory command, there is no sanity check for the parameters.
Signed-off-by: York Sun yorksun@freescale.com --- common/cmd_cache.c | 30 ++++++++++++++++++++++++++++++ 1 file changed, 30 insertions(+)
diff --git a/common/cmd_cache.c b/common/cmd_cache.c index 5512f92..93b7337 100644 --- a/common/cmd_cache.c +++ b/common/cmd_cache.c @@ -94,6 +94,29 @@ int do_dcache(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 0; }
+void __weak flush_cache(ulong addr, ulong size) +{ + puts("No arch specific flush_cache available!\n"); + /* please define arch specific flush_cache */ +} + +int do_flush_cache(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + ulong addr, size; + + switch (argc) { + case 3: + addr = simple_strtoul(argv[1], NULL, 16); + size = simple_strtoul(argv[2], NULL, 16); + flush_cache(addr, size); + break; + default: + return cmd_usage(cmdtp); + } + return 0; + +} + static int parse_argv(const char *s) { if (strcmp(s, "flush") == 0) @@ -120,3 +143,10 @@ U_BOOT_CMD( "[on, off, flush]\n" " - enable, disable, or flush data (writethrough) cache" ); + +U_BOOT_CMD( + flush_cache, 3, 0, do_flush_cache, + "flush cache for a range", + "<addr> <size>\n" + " - flush cache for specificed range" +);
Hi York,
- puts("No arch specific flush_cache available!\n");
- /* please define arch specific flush_cache */
- ulong addr, size;
- switch (argc) {
- case 3:
break;
- default:
+U_BOOT_CMD(
- flush_cache, 3, 0, do_flush_cache,
- "flush cache for a range",
- "<addr> <size>\n"
- " - flush cache for specificed range"
What's the point of this command exactly? I can see the point of range flushes (and invalidates) in the code for drivers that use DMA, but as a shell command, I fail to see the interest of it.
Amicalement,
I am actually expecting this question. We have a situation that an application is copied by u-boot to its destination in memory. The code needs to be "seen" in the main memory. Without flushing cache, it is only visible to cores.
York
range
as a
It's the same purpose as the cache flushing that happens in bootm, except for code loading that happens outside bootm.
-Scott
Hi Scott,
On Tue, 19 Mar 2013 18:32:39 -0500, Scott Wood scottwood@freescale.com wrote:
range
as a
-Scott
I do understand what it does, but I still don't get why it should be done, since precisely payload control transfer happens through bootm and the like which already properly flush cache.
Also, AFAIK U-Boot on multiple cores runs on a single core (possibly started from a smaller adjunct core) and will load and execute its payload on that same single core; the payload might enable and run additional cores if it so decides, but I don't know that U-Boot would start another main core. Still, I may have missed something.
Anyway:
Is there an ARM multi-core target in U-Boot where U-Boot runs on one core but its payload shall be started on another, "un-booted", core, and which experiences issues due to the first core not flushing cache? If no existing target needs this, then this patch is useless. If there exists such a target and issue, then the right fix is not a shell command, it is a programmatic flush before the other core is enabled, so that it always sees correct RAM.
Maybe this is some code that might come in handy for some future target not in U-Boot yes which will have the first core start a payload on another core? Then the previous argument applies (the fix should not be a shell command, it should be in source code), plus, the patch is dead code until and unless said target is also added in a single series.
Amicalement,
Dear Albert,
Full agrement.
Agreed again. As is, the patch was only adding dead code, as there are no users of the feature.
<nitpick> Also, it was added unconditionally which is a strict no-no as it just adds code-bloat to everyone, without benefit. </nitpick>
Agreed! Thanks.
On 03/20/2013 09:58:36 AM, Wolfgang Denk wrote:
Dear Albert,
bootm and
It doesn't always happen through bootm. Standalone apps use the "go" command.
Full agrement.
flushing
useless. If
shell
enabled,
It's a user command! How can it be dead code? I don't know of a way to include a human user in a patchset...
Only for boards which select CONFIG_CMD_CACHE... not sure how fine-grained it makes sense to make it.
-Scott
Hi Scott,
On Wed, 20 Mar 2013 11:43:15 -0500, Scott Wood scottwood@freescale.com wrote:
Dear Albert,
Hence my "and the like".
Full agrement.
flushing
useless. If
shell
enabled,
But as I stated, you can, and should, include at least one board that will need this command. So far, apparently, no board needs it.
As a command, and useful at most to a few boards, it should have its own option so that only the board(s) that will need it will have the command list entry and associated code.
-Scott
Amicalement,
On 03/20/2013 12:38:13 PM, Albert ARIBAUD wrote:
Hi Scott,
Dear Albert,
should be
"go"
command.
But a cache flush does not happen with "go", and cannot (unless you flush the entirety of all relevant caches, which is not always easy and requires more platform-specific code) because it only knows the entry point, not the start/end of the image.
there
way
Where does this appearance come from? It's relevant on any PPC target where icache and dcache are not mutually coherent, which is most of them. The odds of getting bitten by the lack of flushing may differ among different targets, but it exists
What specifically would you be looking to be added? Again, it's a user command. The user is a human, not a piece of code. Should we rip out every command that isn't referred to by a board's default environment or some other in-tree reference? I could drop a lot of useful NAND commands that way...
-Scott
Dear Albert,
bootm and
So, to try and be a bit more verbose about this, for U-Boot applications which use 'go', we still need to ensure cache coherence, which is why bootm does a cache flush, we need some way to flush in this case.
And in this case you aren't better served by say bootelf ?
Assuming that no, it's not, we have a real example where we need this. So please make sure to update the README with the new command CONFIG_CMD_CACHE sets.
Full agrement.
flushing
useless. If
a shell
enabled,
Can you hightlight what exactly causes the world today to go off and fail? Is the hello_world example app sufficient in this case or do we need something much larger?
Dear Albert,
should be
bootm and
It's also an issue with using the "cpu <n> release" command.
That wouldn't handle the "cpu release" case. In any case, "go" exists and is currently the recommended way to launch a standalone application in doc/README.standalone.
A user inside Freescale is running standalone performance test apps, using both "go" and "cpu <n> release" (since the test needs to run on all CPUs). They are seeing cache problems running on a T4240 if they don't have this flush. This flush is architecturally required between modifying/loading code and running it.
-Scott
Dear Albert,
should be
bootm and
Hadn't seen that command before, where is it?
OK, so this does sound like a real need / use for it, and if we added the granularity of CONFIG_CMD_CACHE_FLUSH or similar, it would be reasonable to turn it on to a large number of boards for a small space savings (so lets not). My next concern is that this needs build testing (and some inspection) on say ARM where we have a weak flush_cache already. But perhaps the right answer is to say it doesn't make sense to add CONFIG_CMD_CACHE on an architecture which doesn't already provide flush_cache, so drop the weak one from this patch.
Dear Albert,
should be
bootm and
why
common/cmd_mp.c
and
do we
flush_cache() is already called from generic code, so we should be ok just dropping the weak function.
-Scott
Dear Scott Wood,
common/cmd_mp.c
This depends on CONFIG_MP, which is undocumented. Can you please add / have added documentation for this config option? Thanks.
Dear Tom Rini,
Not really. Only a tiny fraction of users will ever run any standalone applications, so please let's save the memory footprint for the overwhelming majority of users who do not need that.
On Thu, Mar 21, 2013 at 06:39:31AM +0100, Wolfgang Denk wrote:
Dear Tom Rini,
Well, can we run into this problem on ARM (v7 or v8) systems as well?
Dear Tom,
Probably.
But I wonder what the exact usage szenario is that will trigger the problem. If I understand correctly, this can only happen when you perform a (manual) memory copy (either between different locations in RAM, or from parallel NOR flash to RAM) of the code you are going to run.
As far as I understand all other ways to load any such code (over the network or from storage devices) already make sure to run flush_cache() after any such load operation.
Scott: is my understanding correct that you only need this because you are performing such memory copy ops manually? From where / to where are you copying, and why?
Thinking about alternatives:
- eventually we should discourage the use of "go"; it may be conveniend when you know what you are doing, but if it's casuing such problems we might be better off recommending to use proper IH_TYPE_STANDALONE legacy images in combination with the bootm command instead.
- Also, instead of adding a new command, this could probably be scripted; I guess this should be roughly equivalent?
setenv flush_cache 'dc off;ic off;dc on;ic on'
On 03/21/2013 08:37:32 AM, Wolfgang Denk wrote:
Dear Tom,
standalone
well?
Probably.
Yes, the person who is seeing this problem is copying code from flash to RAM.
A lot of places seem to have it, but it seems not everywhere. I'm not aware of such a flush for NAND reads.
We could instead try to make sure everything, including commands like "cp" and "mm", flush cache when they're done. This approach is more user friendly, though it has a higher risk of missing some code path.
As above it's from flash (I assume NOR) to RAM. The "why" is to be able to run the code from RAM. :-P
That or bootelf, sure. I think there still should be some way to do it manually, though. bootm/bootelf probably wouldn't work for this use case because it involves releasing other cores after the image is copied/flushed, but before u-boot gives up control on the boot core.
This assumes that we support those cache operations, that they affect all relevant caches (on 85xx it only flushes L1, but at least on newer chips L2 is relevant as well), and that there are no errata or architectural limitations to running with caches off.
-Scott
Dear Scott,
In message 1363890157.31522.14@snotra you wrote:
As above it's from flash (I assume NOR) to RAM. The "why" is to be =20 able to run the code from RAM. :-P
* Why don't you run it form flash?
* Why do you insist on using the "go" command (instead of "bootm" with a IH_TYPE_STANDALONE image?
The "releasing other cores" would then be a sub-command in the bootm sequence?
Indeed.
On 03/21/2013 02:25:10 PM, Wolfgang Denk wrote:
Dear Scott,
=20
- Why don't you run it form flash?
Presumably because it's slow. As indicated elsewhere in the thread, these are performance tests.
- Why do you insist on using the "go" command (instead of "bootm" with a IH_TYPE_STANDALONE image?
Presumably because of the need to release other cores first.
do it
Perhaps it could be, or the application could be altered to release secondary cores through the spin table. I don't think that excuses a situation where some ways of putting a blob of bytes into RAM flush the cache (to the extent the architecture requires it for the blob of bytes to be executable) and others don't, and there's no way to do it manually. Would you remove the "go" command entirely? I think that would be a mistake.
-Scott
Hi Scott,
AFAIU there is.
I do not see why you are talking about removing the "go" command. In the 'worst' scenario (from an effort perspective), it would have to be do a flush and possibly cache disable before branching to the payload; in the 'best' scenario, it needs not be modified at all.
-Scott
Amicalement,
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
On 03/22/2013 02:30 AM, Albert ARIBAUD wrote:
Hi Scott,
AFAIU there is.
It seems like we're going around and around with one point not being addressed. When using 'go', how do you know the size to flush? And since Scott is talking about performance testing apps, the cache should not be disabled (unless we expect all standalone apps to enable the cache, in which case we need to provide something in the jump table to make that easy and document this change).
- -- Tom
Dear Tom,
I also wonder about this. To me it appears much easier to use a IH_TYPE_STANDALONE image, which 1) provides the needed size information and 2) can be used with bootm, so the required additional steps (flush caches, release CPU) can be handled in bootm subcommands.
On 03/22/2013 10:03 AM, Wolfgang Denk wrote:
Dear Tom,
But that then circles us back to Scott's other point of "go" is broken then and it is the recommended way to start standalone applications.
Now, if we want to change things and say that no, you can't just run totally raw binaries reliably with "go" but instead need to throw some form of header on top of them, how portable, really, is mkimage? We've just made that a required part of the work-flow for anyone doing development that's not producing ELF or something else already boot*'able. That might be a rather large pool I suspect.
Scott, part of the problem here is that we have multiple cores, yes? Say core0 is the one that read things in from NOR to DDR, core1 is the one that will be running things. How about we make flush_cache depend on CONFIG_MP || CONFIG_CMD_CACHE_FLUSH ? It's a likely required often thing for CONFIG_MP systems and anyone else that needs it can opt-in.
- -- Tom
Hi Tom,
Dear Tom,
I am not sure I understand how exactly go is broken, or how the bootm proposal from Wolfgang circles back to a brokennness of 'go'. I am not even sure of the exact scenario. How many cores are we dealing with here, and what does each core do in sequence?
That's one possible scenario but I would like more detail before we look for a solution.
Amicalement,
Dear Tom,
Multiple CPUs may make it more likely to see problems on some hardware, but architecturally on PPC the flush is required even with a single CPU. Icache fetches won't snoop the dcache.
Can we have it depend on a new config symbol, so it's not bloating anyone's U-Boot who doesn't want it, and deal with improvements to recommended standalone app workflow as a separate issue? We're not talking about a huge amount of code here, just exposing functionality that U-Boot already has internally.
-Scott
Dear Tom,
Works for me.
- -- Tom
Dear Tom,
I'm not sosure about this It once was, yes, when IH_TYPE_STANDALONE did not exist yet. Later this changed.
Of course "go" has it's right to exist. For example, I use it regularly when I want to crash a system by jumping to a non-existent or unaligned address ;-)
But today, "bootm" for a IH_TYPE_STANDALONE image ppears to be a better way to start a standalone app.
I think it would be wrong here tobe so absolute - this or that, and nothing inbetween. The thing is, for well over a decase "go" has been working fine, and problems like this here hever never been much of an issue. And being able just to jump anywhere _is_ a necessary function, IMO.
How portable is mkimage? Well, pretty much, it seems - probably more than your options are to build a bare metal standalone image to run on the target hardware. Why exactly are you asking this?
How many of the total number of U-Boot users are actively using standalone apps?
And how many of these are actually experiencing the problems we're discussing here?
I'd be willing to bet a few beer that it's only a _tiny_ fraction.
Of course we should provide working solutions for each and every use case, but here I fear we're designing for a lot of overkill.
Hi Scott,
On Wed, 20 Mar 2013 14:36:05 -0500, Scott Wood scottwood@freescale.com wrote:
Dear Albert,
should be
bootm and
Still, why make it a shell command? Since this user needs a flush with "go" and "cpu release", then we should add a programmatic global cache flush in the "go" and "cpu release" commands.
-Scott
Amicalement,
On 03/20/2013 05:11:57 PM, Albert ARIBAUD wrote:
Hi Scott,
Dear Albert,
should be
through
bootm and
why
exists
application
a
and
do we
on
they
between
Why add any new commands? They could all be subcommands of bootm! :-)
Really, instead of adding one command, you want to modify *two* commands to do the same thing separately, which involves changing the syntax of both commands to accept memory range information?
-Scott
What is the purpose of limiting the memory range to be flushed? Is there a reason one might want to NOT flush certain data sitting in a dirty cache line out to memory before doing a go or boot command?
If you drive the operation as a "walk the cache" process rather than a "iterate over all SDRAM physical address space to cherry pick within a range" it wouldn't seem that slow. I mean, there's only so much cache memory.
Maybe I'm not well versed enough on the various architectures to understand how a cache walk is really done. So while the question really falls to someone who does know, I wanted to make sure it was at least asked.
-Mike
Because it would take a while to flush all of RAM?
There's no way to "walk the cache" on many chips, including ours. There are generally ways to flush the entire thing, but they are (more) hardware-specific than using the architected method of flushing a memory range, and sometimes these methods have errata associated with them.
-Scott
"Flushing all of RAM" is what trips me up. Fundamentally, that puts the cart in front of the horse. The goal isn't to flush all of RAM but rather to flush all of cache. Iterating over the small thing rather than the large would seem reasonably efficient.
But as you say, if there are architectures where that can't be done and you must pass GBs of physical address space (rather than KB of cache space) through some process then range limiting it does make sense.
I'm not trying to argue a point. I just want all angles to be considered.
Thanks for the enlightenment!
-Mike
Right, I was just responding to your question of, "What is the purpose of limiting the memory range to be flushed?"
Right. The range specified is a minimum to be flushed -- if a particular architecture finds it easier/quicker to flush everything instead, that's fine.
-Scott
So in your case, how do you find out the addresses of buffers to be flushed from command ? Just thinking how this can be used generically ?
Regards, Sricharan
I'm not sure what you're asking. How does the user know what address range to pass to the command? It's whatever covers the program they want to run.
-Scott
Hi Scott,
On Wed, 20 Mar 2013 17:35:51 -0500, Scott Wood scottwood@freescale.com wrote:
Hi Scott,
Dear Albert,
In message 20130320145927.2031b913@lilith you wrote: > > I do understand what it does, but I still don't get why it
should be
through
bootm and > the like which already properly flush cache.
why
exists
application
a
and
do we
on
they
between
I did not say "subcommand", I said "programmatic" -- precisely, I don't like the idea that a specific command or command form is needed to avoid a situation that can be avoided automatically.
There is no need to change any syntax.
-Scott
Amicalement,
On 03/21/2013 12:58:37 PM, Albert ARIBAUD wrote:
Hi Scott,
Hi Scott,
On 03/20/2013 09:58:36 AM, Wolfgang Denk wrote: >Dear Albert, > >In message 20130320145927.2031b913@lilith you wrote: >> >> I do understand what it does, but I still don't get why
it
should be
through
>bootm and >> the like which already properly flush cache.
use the
"go" command.
which is
why
case.
exists
application
know of
a
off
and
or
do we
apps,
run
on
they
between
with
cache
bootm subcommands are programmatic in normal use cases.
the
Then how would we know what range to flush?
-Scott
Dear Scott Wood,
Use a IH_TYPE_STANDALONE U-Boot image, and bootm?
Dear Albert,
bootm and
We have a user's case to release secondary cores to run user's application which is in main memory. The secondary cores don't necessarily share the cache with the core u-boot is running, depends on hardware implementation. Without flushing the cache, those cores don't have the correct code to fetch.
York
Dear York Sun,
Why would it be necessary to ever run this manually?
I feel you are just papering over bugs / shortcomings elsewhere in the code. Should we not rather fix the places where the cache flushes are missing in the code?
On 03/20/2013 09:51:03 AM, Wolfgang Denk wrote:
Dear York Sun,
the
there is
Possibly -- the alternative would be to have every command that modifies memory flush that region of cache afterward (cp, tftp, etc).
You could say the same thing about the existing cache command, though.
-Scott
I apologize for being so late with this question.
York Sun <yorksun <at> freescale.com> writes:
Are there symptoms for a specific system failure you can provide?
My problem is that when a stand alone application, which is copied from NOR flash to DDR, is started with the "go" command, it sometimes experiences a program check (illegal instruction) after a block of 32 zero bytes "appears" in memory.
I'm using a U-Boot for a custom Freescale P1022-based board, currently based on the old 2010.12 U-Boot as patched by Freescale in their SDK_V1_0_20110429_ltib.iso. Unfortunately, upgrading to a more recent version of U-Boot is not possible at this time, no more recent version is available from Freescale and I don't have the resources to verify all their patches apply correctly to a release directly from DENX.
I've used Codewarrior to observe the block of zeros in memory once the program check has happened, and I've verified that before the stand alone application begins execution, there are no zeros. Figuring it is likely that I have an error in my stand alone application code that corrupts the stack or writes based on an un-initialized pointer, I've tried using the CW watchpoint to catch where the zeros are written, but enabling the watchpoint seems to avoid the problem.
Based on later discussion on this thread, I've tried adding "flush_dcache(); invalidate_icache();" to cmd_boot.c:do_go(), just before control is passed to the stand alone app. Based on my ad hoc testing with this change, I don't get the program check exception.
I believe this result helps make the case that caching behavior is at the root of my problem, but since I was not able to isolate the actual cause of that problem, I can't be sure I've really got the solution.
(By the way, I would not leave the "flush_dcache(); invalidate_icache();" in do_go(), I merely found that for demonstrating a possible solution, this change easier than switching to a stand alone app that starts with bootm, or similar)
Any help or comments are very welcome.
Thanks, Jim
Signed-off-by: York Sun <yorksun <at> freescale.com>
const argv[])
return 0; }
- ulong addr, size;
- switch (argc) {
- case 3:
break;
- default:
+U_BOOT_CMD(
- "<addr> <size>\n"
the
there is
Generally you'd see code behaving in a way that is different than the instructions in memory (as seen by a load instruction) would suggest. Often it's obvious, such as an illegal instruction trap on on opcode that is valid, but it could be arbitrary depending on what the old contents of memory were (especially if there had been valid (but different) code there before).
Maybe the old contents of memory contained a dcbz? Or somehow confused a legimate dcbz to target the wrong address.
You can find the latest Freescale U-Boot at: http://git.freescale.com/git/cgit.cgi/ppc/sdk/u-boot.git/ git://git.freescale.com/ppc/sdk/u-boot.git
...though there's a good chance that you would not need anything from the SDK if you run the latest upstream U-Boot. You'd still need to apply your own patches for the custom board, of course.
It seems reasonably likely that this is the cause of your problem; in any case, the flush is architecturally required.
-Scott
participants (8)
Albert ARIBAUD
Jim Chargin
Michael Cashwell
Scott Wood
Sricharan R
York Sun
