[U-Boot] [PATCH v2 2/2] gpio: Add GPIO driver for Marvell SoC Armada100
This patch adds support for generic GPIO driver framework for Marvell SoC Armada100.
Signed-off-by: Ajay Bhargav ajay.bhargav@einfochips.com --- arch/arm/include/asm/arch-armada100/armada100.h | 4 + arch/arm/include/asm/arch-armada100/gpio.h | 95 +++++++++++++++++++++++ 2 files changed, 99 insertions(+), 0 deletions(-) create mode 100644 arch/arm/include/asm/arch-armada100/gpio.h
diff --git a/arch/arm/include/asm/arch-armada100/armada100.h b/arch/arm/include/asm/arch-armada100/armada100.h index d5d125a..aad3ed1 100644 --- a/arch/arm/include/asm/arch-armada100/armada100.h +++ b/arch/arm/include/asm/arch-armada100/armada100.h @@ -59,6 +59,10 @@ #define ARMD1_MPMU_BASE 0xD4050000 #define ARMD1_APMU_BASE 0xD4282800 #define ARMD1_CPU_BASE 0xD4282C00 +#define ARMD1_GPIO0_BASE 0xD4019000 +#define ARMD1_GPIO1_BASE 0xD4019004 +#define ARMD1_GPIO2_BASE 0xD4019008 +#define ARMD1_GPIO3_BASE 0xD4019100
/* * Main Power Management (MPMU) Registers diff --git a/arch/arm/include/asm/arch-armada100/gpio.h b/arch/arm/include/asm/arch-armada100/gpio.h new file mode 100644 index 0000000..0593b13 --- /dev/null +++ b/arch/arm/include/asm/arch-armada100/gpio.h @@ -0,0 +1,95 @@ +/* + * (C) Copyright 2011 + * eInfochips Ltd. <www.einfochips.com> + * Written-by: Ajay Bhargav ajay.bhargav@einfochips.com + * + * (C) Copyright 2010 + * Marvell Semiconductor <www.marvell.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _ASM_ARCH_GPIO_H +#define _ASM_ARCH_GPIO_H + +#include <asm/types.h> +#include <asm/arch/armada100.h> + +#define GPIO_TO_REG(gp) (gp >> 5) +#define GPIO_TO_BIT(gp) (1 << (gp & 0x1F)) +#define GPIO_VAL(gp, val) ((val >> (gp & 0x1F)) & 0x01) + +#define GPIO_SET 1 +#define GPIO_CLR 0 + +/* + * GPIO register map + * Refer Datasheet Appendix A.36 + */ +struct gpio_reg { + u32 gplr; /* Pin Level Register - 0x0000 */ + u32 pad0[2]; + u32 gpdr; /* Pin Direction Register - 0x000C */ + u32 pad1[2]; + u32 gpsr; /* Pin Output Set Register - 0x0018 */ + u32 pad2[2]; + u32 gpcr; /* Pin Output Clear Register - 0x0024 */ + u32 pad3[2]; + u32 grer; /* Rising-Edge Detect Enable Register - 0x0030 */ + u32 pad4[2]; + u32 gfer; /* Falling-Edge Detect Enable Register - 0x003C */ + u32 pad5[2]; + u32 gedr; /* Edge Detect Status Register - 0x0048 */ + u32 pad6[2]; + u32 gsdr; /* Bitwise Set of GPIO Direction Register - 0x0054 */ + u32 pad7[2]; + u32 gcdr; /* Bitwise Clear of GPIO Direction Register - 0x0060 */ + u32 pad8[2]; + u32 gsrer; /* Bitwise Set of Rising-Edge Detect Enable + Register - 0x006C */ + u32 pad9[2]; + u32 gcrer; /* Bitwise Clear of Rising-Edge Detect Enable + Register - 0x0078 */ + u32 pad10[2]; + u32 gsfer; /* Bitwise Set of Falling-Edge Detect Enable + Register - 0x0084 */ + u32 pad11[2]; + u32 gcfer; /* Bitwise Clear of Falling-Edge Detect Enable + Register - 0x0090 */ + u32 pad12[2]; + u32 apmask; /* Bitwise Mask of Edge Detect Register - 0x009C */ +}; + + +static inline struct gpio_reg *get_gpio_base(int bank) +{ + switch (bank) { + case 0: + return (struct gpio_reg *)ARMD1_GPIO0_BASE; + case 1: + return (struct gpio_reg *)ARMD1_GPIO1_BASE; + case 2: + return (struct gpio_reg *)ARMD1_GPIO2_BASE; + case 3: + return (struct gpio_reg *)ARMD1_GPIO3_BASE; + } + return 0; +} + +#endif /* _ASM_ARCH_GPIO_H */
Hi Ajay,
On Fri, Jul 22, 2011 at 3:16 PM, Ajay Bhargav ajay.bhargav@einfochips.com wrote:
- (C) Copyright 2011
- eInfochips Ltd. <www.einfochips.com>
- Written-by: Ajay Bhargav ajay.bhargav@einfochips.com
- (C) Copyright 2010
- Marvell Semiconductor <www.marvell.com>
- project.
- Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston,
- MA 02110-1301 USA
- GPIO register map
- Refer Datasheet Appendix A.36
+struct gpio_reg {
Why not put this structure into driver file? I think this register is not easy to change, and put this into arch .h would make the work duplicated, as each arch need to redefine the same structure again.
After put the structure into the driver file, you could simply return void* instead of gpio_reg*.
Best regards, Lei
Hi Lei,
Other architectures may/may not have the same structure. One can redefine structure based on this header file.
Thanks & Regards, Ajay Bhargav
On Fri, Jul 22, 2011 at 3:27 PM, Ajay Bhargav ajay.bhargav@einfochips.com wrote:
Hi Lei,
I think if have no such same structure, the gpio driver may need to be rewrite, since the meaning of the register may also change.
Best regards, Lei
Ajay Bhargav
Lei Wen
