[PATCH v2] efi_loader: initialize return values in efi_uninstall_multiple_protocol_interfaces_int()
If the va_list we got handed over contains no protocols we must return EFI_SUCCESS. However in that case the current code just returns an uninitialized value. Fix that by setting the return value in the variable definition
Addresses-Coverity: CID 376195: ("Uninitialized variables (UNINIT)") Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- changes since v1: - return EFI_SUCCESS instead of EFI_INVALID_PARAMETER
lib/efi_loader/efi_boottime.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index a56021559bbf..f52d086d17bf 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -2754,7 +2754,7 @@ efi_uninstall_multiple_protocol_interfaces_int(efi_handle_t handle, { const efi_guid_t *protocol; void *protocol_interface; - efi_status_t ret; + efi_status_t ret = EFI_SUCCESS; size_t i = 0; efi_va_list argptr_copy;
@@ -2765,7 +2765,7 @@ efi_uninstall_multiple_protocol_interfaces_int(efi_handle_t handle, for (;;) { protocol = efi_va_arg(argptr, efi_guid_t*); if (!protocol) - break; + goto out; protocol_interface = efi_va_arg(argptr, void*); ret = efi_uninstall_protocol(handle, protocol, protocol_interface);
changes since v1:
- efi_status_t ret;
- efi_status_t ret = EFI_SUCCESS;
OK
break;
goto out;
You may reach this point after actually uninstalling protocols. You have to check if the last protocol is uninstalled. Please, drop this change.
Best regards
Heinrich
Hi Heinrich
changes since v1:
efi_status_t ret;
OK
break;
goto out;
Yes good catch. Let me send a v3
Thanks /Ilias
Best regards
Heinrich
Ilias Apalodimas
