Hi Wolfgang,
Have you tested USB host functionality on a mx53loco with a Freescale MC34708 PMIC ?
I can succesfully detect a USB pen drive on a mx53loco board with a Dialog PMIC, but not on the FSL PMIC version.
I am going to debug this, but just wondering if you have already seen this issue.
Thanks,
Fabio Estevam
On 05/02/2012 08:48 PM, Fabio Estevam wrote:
Hi Wolfgang,
I have a i.MX53 quick start board, which is named in U-Boot and Linux mx53[_]loco. And yes, USB is working.
I need to check, what PMIC my board uses.
See above.
Wolfgang.
Am 02/05/2012 20:48, schrieb Fabio Estevam:
Hi Wolfgang,
No, I tested on a board with the Dialog PMIC, and it worked flawlessy. Maybe someone else tesetd with a newer board..
Best regards, Stefano Babic
I have both boards here.
On a mx53loco with Dialog PMIC:
MX53LOCO U-Boot > usb start (Re)start USB... USB: Register 10011 NbrPorts 1 USB EHCI 1.00 scanning bus for devices... 2 USB Device(s) found scanning bus for storage devices... 1 Storage Device(s) found scanning bus for ethernet devices... 0 Ethernet Device(s) found
On a mx53loco with FSL PMIC:
MX53LOCO U-Boot > usb start (Re)start USB... USB: Register 10011 NbrPorts 1 USB EHCI 1.00 scanning bus for devices... cannot reset port 1!? 1 USB Device(s) found scanning bus for storage devices... 0 Storage Device(s) found scanning bus for ethernet devices... 0 Ethernet Device(s) found
I still have not figured out why it cannot reset the USB port in this case.
Hi Stefano and Wolfgang,
Hi Wolfgang,
I managed to get USB working in the mx53loco board with FSL PMIC.
I needed to turn on VUSB regulator output of mc34708.
Will submit the patches after my initial Dialog PMIC series get applied.
Regards,
Fabio Estevam
Hi Wolfgang,
Ok, this explains why it did not work !
Clear.
Fabio Estevam
Stefano Babic
stefano babic
Wolfgang Grandegger
