[PATCH v3 0/2] clk: ccf: fix enable_count mismatch
As described in [1], enable_count is incremented by 2 when ccf_clk_enable() is called. This series of patch fixed this issue and added a testcase for that.
[1]: https://lore.kernel.org/all/SEZPR06MB695927A6DEEEF8489A06897396A7A@SEZPR06MB...
Signed-off-by: Yang Xiwen forbidden405@outlook.com --- Changes in v3: - move i2v_root in front of devm clocks. So that clk_test driver needs a minimum modification - squash patch 1, 3 and 4. -- Suggested by Sean - rewrite commit log for clarity. - Link to v2: https://lore.kernel.org/r/20231111-enable_count-v2-0-20e3728600b5@outlook.co...
Changes in v2: - add missing SoB in patch 1/4, no functional change - Link to v1: https://lore.kernel.org/r/20231111-enable_count-v1-0-509f400a99cb@outlook.co...
--- Yang Xiwen (2): clk: get correct ops for clk_enable() and clk_disable() test: dm: clk_ccf: test ccf_clk_ops
arch/sandbox/dts/test.dts | 4 +++- arch/sandbox/include/asm/clk.h | 1 + drivers/clk/clk-uclass.c | 2 ++ drivers/clk/clk_sandbox_ccf.c | 1 + drivers/clk/clk_sandbox_test.c | 1 + test/dm/clk_ccf.c | 14 +++++++++++--- 6 files changed, 19 insertions(+), 4 deletions(-) --- base-commit: 3b913c148249a2b9d12ff25517ec311646e83bee change-id: 20231111-enable_count-ad5001326815
assign clk_dev_ops(clkp->dev) to ops to ensure correct clk operations are called on clocks.
This fixes the incorrect enable_count issue as described in [1].
Reviewed-by: Sean Anderson seanga2@gmail.com Signed-off-by: Yang Xiwen forbidden405@outlook.com --- drivers/clk/clk-uclass.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/clk/clk-uclass.c b/drivers/clk/clk-uclass.c index 3b5e3f9c86..3e9d68feb3 100644 --- a/drivers/clk/clk-uclass.c +++ b/drivers/clk/clk-uclass.c @@ -640,6 +640,7 @@ int clk_enable(struct clk *clk) if (CONFIG_IS_ENABLED(CLK_CCF)) { /* Take id 0 as a non-valid clk, such as dummy */ if (clk->id && !clk_get_by_id(clk->id, &clkp)) { + ops = clk_dev_ops(clkp->dev); if (clkp->enable_count) { clkp->enable_count++; return 0; @@ -699,6 +700,7 @@ int clk_disable(struct clk *clk)
if (CONFIG_IS_ENABLED(CLK_CCF)) { if (clk->id && !clk_get_by_id(clk->id, &clkp)) { + ops = clk_dev_ops(clkp->dev); if (clkp->flags & CLK_IS_CRITICAL) return 0;
Assign ccf_clk_ops to .ops of clk_ccf driver so that it can act as an clk provider. Also add "#clock-cells=<1>" to its device tree node.
Add "i2c_root" to clk_test in the device tree and driver for testing.
Get "i2c_root" clock in CCF unit tests and add tests for it.
Signed-off-by: Yang Xiwen forbidden405@outlook.com --- arch/sandbox/dts/test.dts | 4 +++- arch/sandbox/include/asm/clk.h | 1 + drivers/clk/clk_sandbox_ccf.c | 1 + drivers/clk/clk_sandbox_test.c | 1 + test/dm/clk_ccf.c | 14 +++++++++++--- 5 files changed, 17 insertions(+), 4 deletions(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index c7197795ef..a3a865d65c 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -631,9 +631,10 @@ clocks = <&clk_fixed>, <&clk_sandbox 1>, <&clk_sandbox 0>, + <&ccf 11>, <&clk_sandbox 3>, <&clk_sandbox 2>; - clock-names = "fixed", "i2c", "spi", "uart2", "uart1"; + clock-names = "fixed", "i2c", "spi", "i2c_root", "uart2", "uart1"; };
clk-test2 { @@ -654,6 +655,7 @@
ccf: clk-ccf { compatible = "sandbox,clk-ccf"; + #clock-cells = <1>; };
efi-media { diff --git a/arch/sandbox/include/asm/clk.h b/arch/sandbox/include/asm/clk.h index df7156fe31..1daf2e7ac7 100644 --- a/arch/sandbox/include/asm/clk.h +++ b/arch/sandbox/include/asm/clk.h @@ -39,6 +39,7 @@ enum sandbox_clk_test_id { SANDBOX_CLK_TEST_ID_FIXED, SANDBOX_CLK_TEST_ID_SPI, SANDBOX_CLK_TEST_ID_I2C, + SANDBOX_CLK_TEST_ID_I2C_ROOT, SANDBOX_CLK_TEST_ID_DEVM1, SANDBOX_CLK_TEST_ID_DEVM2, SANDBOX_CLK_TEST_ID_DEVM_NULL, diff --git a/drivers/clk/clk_sandbox_ccf.c b/drivers/clk/clk_sandbox_ccf.c index fedcdd4044..38184e27aa 100644 --- a/drivers/clk/clk_sandbox_ccf.c +++ b/drivers/clk/clk_sandbox_ccf.c @@ -284,6 +284,7 @@ static int sandbox_clk_ccf_probe(struct udevice *dev) U_BOOT_DRIVER(sandbox_clk_ccf) = { .name = "sandbox_clk_ccf", .id = UCLASS_CLK, + .ops = &ccf_clk_ops, .probe = sandbox_clk_ccf_probe, .of_match = sandbox_clk_ccf_test_ids, }; diff --git a/drivers/clk/clk_sandbox_test.c b/drivers/clk/clk_sandbox_test.c index 5807a454f3..c695b69321 100644 --- a/drivers/clk/clk_sandbox_test.c +++ b/drivers/clk/clk_sandbox_test.c @@ -15,6 +15,7 @@ static const char * const sandbox_clk_test_names[] = { [SANDBOX_CLK_TEST_ID_FIXED] = "fixed", [SANDBOX_CLK_TEST_ID_SPI] = "spi", [SANDBOX_CLK_TEST_ID_I2C] = "i2c", + [SANDBOX_CLK_TEST_ID_I2C_ROOT] = "i2c_root", };
int sandbox_clk_test_get(struct udevice *dev) diff --git a/test/dm/clk_ccf.c b/test/dm/clk_ccf.c index e4ebb93cda..b8be6d6572 100644 --- a/test/dm/clk_ccf.c +++ b/test/dm/clk_ccf.c @@ -18,8 +18,8 @@ /* Tests for Common Clock Framework driver */ static int dm_test_clk_ccf(struct unit_test_state *uts) { - struct clk *clk, *pclk; - struct udevice *dev; + struct clk *clk, *pclk, clk_ccf; + struct udevice *dev, *test_dev; long long rate; int ret; #if CONFIG_IS_ENABLED(CLK_CCF) @@ -29,6 +29,7 @@ static int dm_test_clk_ccf(struct unit_test_state *uts)
/* Get the device using the clk device */ ut_assertok(uclass_get_device_by_name(UCLASS_CLK, "clk-ccf", &dev)); + ut_assertok(uclass_get_device_by_name(UCLASS_MISC, "clk-test", &test_dev));
/* Test for clk_get_by_id() */ ret = clk_get_by_id(SANDBOX_CLK_ECSPI_ROOT, &clk); @@ -110,11 +111,18 @@ static int dm_test_clk_ccf(struct unit_test_state *uts)
#if CONFIG_IS_ENABLED(CLK_CCF) /* Test clk tree enable/disable */ + + ret = clk_get_by_index(test_dev, SANDBOX_CLK_TEST_ID_I2C_ROOT, &clk_ccf); + ut_assertok(ret); + ut_asserteq_str("clk-ccf", clk_ccf.dev->name); + ut_asserteq(clk_ccf.id, SANDBOX_CLK_I2C_ROOT); + ret = clk_get_by_id(SANDBOX_CLK_I2C_ROOT, &clk); ut_assertok(ret); ut_asserteq_str("i2c_root", clk->dev->name); + ut_asserteq(clk->id, SANDBOX_CLK_I2C_ROOT);
- ret = clk_enable(clk); + ret = clk_enable(&clk_ccf); ut_assertok(ret);
ret = sandbox_clk_enable_count(clk);
clk-test2 {
@@ -654,6 +655,7 @@
#clock-cells = <1>;
efi-media {
- SANDBOX_CLK_TEST_ID_I2C_ROOT, SANDBOX_CLK_TEST_ID_DEVM1, SANDBOX_CLK_TEST_ID_DEVM2, SANDBOX_CLK_TEST_ID_DEVM_NULL,
- .ops = &ccf_clk_ops, .probe = sandbox_clk_ccf_probe, .of_match = sandbox_clk_ccf_test_ids, };
- struct clk *clk, *pclk, clk_ccf;
- struct udevice *dev, *test_dev; long long rate; int ret; #if CONFIG_IS_ENABLED(CLK_CCF)
- ret = clk_get_by_index(test_dev, SANDBOX_CLK_TEST_ID_I2C_ROOT, &clk_ccf);
- ut_assertok(ret);
- ut_asserteq_str("clk-ccf", clk_ccf.dev->name);
- ut_asserteq(clk_ccf.id, SANDBOX_CLK_I2C_ROOT);
- ret = clk_get_by_id(SANDBOX_CLK_I2C_ROOT, &clk); ut_assertok(ret); ut_asserteq_str("i2c_root", clk->dev->name);
- ut_asserteq(clk->id, SANDBOX_CLK_I2C_ROOT);
Applied, thanks!
[2/2] test: dm: clk_ccf: test ccf_clk_ops https://source.denx.de/u-boot/custodians/u-boot-clk/-/commit/d30618243990
Sean Anderson
