[U-Boot] [PATCH v2] ARC: Improve relocation fix-ups
We used to have the one and only linker script for all ARC boards and so we relied on a particular order of symbols there.
Because of that we used __ivt_end as the marker of the end of all the code which won't be true any longer if we move .ivt section to any other place. That said we'd better check for each section separately.
A couple of other improvements: 1. There's no point to include the marker of section end in interested range because its address is beyond the section, i.e. we should compare with "<" but not "<=".
2. .ivt section for ARCv2 cores is just an array of 32-bit ints and they are not swapped even on little-endia cores while in case of ARCompact cores .ivt contains valid code so swapping is required.
3. Just in case add check for ARC600 which is also ARCompact and its .ivt is normal code.
Signed-off-by: Alexey Brodkin abrodkin@synopsys.com ---
Changes v1 -> v2:
* Fixed build failure for ARcompact, see https://travis-ci.org/abrodkin/u-boot/jobs/385682085
arch/arc/lib/relocate.c | 76 +++++++++++++++++++++++++++++------------ 1 file changed, 54 insertions(+), 22 deletions(-)
diff --git a/arch/arc/lib/relocate.c b/arch/arc/lib/relocate.c index a3b7428d8519..4ffba84eeb3e 100644 --- a/arch/arc/lib/relocate.c +++ b/arch/arc/lib/relocate.c @@ -8,7 +8,9 @@ #include <asm-generic/sections.h>
extern ulong __image_copy_start; +extern ulong __ivt_start; extern ulong __ivt_end; +extern ulong __text_end;
DECLARE_GLOBAL_DATA_PTR;
@@ -48,7 +50,7 @@ int do_elf_reloc_fixups(void) debug("Section .rela.dyn is located at %08x-%08x\n", (unsigned int)re_src, (unsigned int)re_end);
- Elf32_Addr *offset_ptr_rom, *last_offset = NULL; + Elf32_Addr *offset_ptr_rom; Elf32_Addr *offset_ptr_ram;
do { @@ -57,15 +59,28 @@ int do_elf_reloc_fixups(void)
/* Check that the location of the relocation is in .text */ if (offset_ptr_rom >= (Elf32_Addr *)&__image_copy_start && - offset_ptr_rom > last_offset) { - unsigned int val; + offset_ptr_rom < (Elf32_Addr *)&__image_copy_end) { + unsigned int val, do_swap = 0; /* Switch to the in-RAM version */ offset_ptr_ram = (Elf32_Addr *)((ulong)offset_ptr_rom + gd->reloc_off);
- debug("Patching value @ %08x (relocated to %08x)\n", +#ifdef __LITTLE_ENDIAN__ + /* If location in ".text" section swap value */ + if (((u32)offset_ptr_rom >= (u32)&__text_start && + (u32)offset_ptr_rom <= (u32)&__text_end) +#if defined(__ARC700__) || defined(__ARC600__) + || ((u32)offset_ptr_rom >= (u32)&__ivt_start && + (u32)offset_ptr_rom <= (u32)&__ivt_end) +#endif + ) + do_swap = 1; +#endif + + debug("Patching value @ %08x (relocated to %08x)%s\n", (unsigned int)offset_ptr_rom, - (unsigned int)offset_ptr_ram); + (unsigned int)offset_ptr_ram, + do_swap ? ", middle-endian encoded" : "");
/* * Use "memcpy" because target location might be @@ -75,28 +90,45 @@ int do_elf_reloc_fixups(void) */ memcpy(&val, offset_ptr_ram, sizeof(int));
-#ifdef __LITTLE_ENDIAN__ - /* If location in ".text" section swap value */ - if ((unsigned int)offset_ptr_rom < - (unsigned int)&__ivt_end) + if (do_swap) val = (val << 16) | (val >> 16); -#endif
/* Check that the target points into executable */ - if (val >= (unsigned int)&__image_copy_start && val <= - (unsigned int)&__image_copy_end) { - val += gd->reloc_off; -#ifdef __LITTLE_ENDIAN__ - /* If location in ".text" section swap value */ - if ((unsigned int)offset_ptr_rom < - (unsigned int)&__ivt_end) - val = (val << 16) | (val >> 16); -#endif - memcpy(offset_ptr_ram, &val, sizeof(int)); + if (val < (unsigned int)&__image_copy_start || + val > (unsigned int)&__image_copy_end) { + /* TODO: Use panic() instead of debug() + * + * For some reason GCC might generate + * fake relocation even for LD/SC of constant + * inderectly. See an example below: + * ----------------------->8-------------------- + * static int setup_mon_len(void) + * { + * gd->mon_len = (ulong)&__bss_end - CONFIG_SYS_MONITOR_BASE; + * return 0; + * } + * ----------------------->8-------------------- + * + * And that's what we get in the binary: + * ----------------------->8-------------------- + * 10005cb4 <setup_mon_len>: + * 10005cb4: 193c 3f80 0003 2f80 st 0x32f80,[r25,60] + * 10005cb8: R_ARC_RELATIVE *ABS*-0x10000000 + * 10005cbc: 7fe0 j_s.d [blink] + * 10005cbe: 700c mov_s r0,0 + * ----------------------->8-------------------- + */ + debug("Relocation target %08x points outside of image\n", + val); } - } - last_offset = offset_ptr_rom;
+ val += gd->reloc_off; + + if (do_swap) + val = (val << 16) | (val >> 16); + + memcpy(offset_ptr_ram, &val, sizeof(int)); + } } while (++re_src < re_end);
Alexey Brodkin
