[U-Boot] [PATCH v3 1/2] imx: Introduce a header for the imx cpu versions
Instead of duplicating the CPU definitions at mx5 and mx6 sys_proto.h header files, introduce a common header to centralize such definitions.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/include/asm/arch-imx/cpu.h | 12 ++++++++++++ arch/arm/include/asm/arch-mx5/sys_proto.h | 7 +------ arch/arm/include/asm/arch-mx6/sys_proto.h | 8 +------- 3 files changed, 14 insertions(+), 13 deletions(-) create mode 100644 arch/arm/include/asm/arch-imx/cpu.h
diff --git a/arch/arm/include/asm/arch-imx/cpu.h b/arch/arm/include/asm/arch-imx/cpu.h new file mode 100644 index 0000000..8c725e2 --- /dev/null +++ b/arch/arm/include/asm/arch-imx/cpu.h @@ -0,0 +1,12 @@ +/* + * (C) Copyright 2014 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#define MXC_CPU_MX51 0x51 +#define MXC_CPU_MX53 0x53 +#define MXC_CPU_MX6SL 0x60 +#define MXC_CPU_MX6DL 0x61 +#define MXC_CPU_MX6SOLO 0x62 +#define MXC_CPU_MX6Q 0x63 diff --git a/arch/arm/include/asm/arch-mx5/sys_proto.h b/arch/arm/include/asm/arch-mx5/sys_proto.h index 9949ad1..ac7705b 100644 --- a/arch/arm/include/asm/arch-mx5/sys_proto.h +++ b/arch/arm/include/asm/arch-mx5/sys_proto.h @@ -8,12 +8,7 @@ #ifndef _SYS_PROTO_H_ #define _SYS_PROTO_H_
-#define MXC_CPU_MX51 0x51 -#define MXC_CPU_MX53 0x53 -#define MXC_CPU_MX6SL 0x60 -#define MXC_CPU_MX6DL 0x61 -#define MXC_CPU_MX6SOLO 0x62 -#define MXC_CPU_MX6Q 0x63 +#include "../arch-imx/cpu.h"
#define is_soc_rev(rev) ((get_cpu_rev() & 0xFF) - rev) u32 get_cpu_rev(void); diff --git a/arch/arm/include/asm/arch-mx6/sys_proto.h b/arch/arm/include/asm/arch-mx6/sys_proto.h index 17125a6..38851a1 100644 --- a/arch/arm/include/asm/arch-mx6/sys_proto.h +++ b/arch/arm/include/asm/arch-mx6/sys_proto.h @@ -9,13 +9,7 @@ #define _SYS_PROTO_H_
#include <asm/imx-common/regs-common.h> - -#define MXC_CPU_MX51 0x51 -#define MXC_CPU_MX53 0x53 -#define MXC_CPU_MX6SL 0x60 -#define MXC_CPU_MX6DL 0x61 -#define MXC_CPU_MX6SOLO 0x62 -#define MXC_CPU_MX6Q 0x63 +#include "../arch-imx/cpu.h"
Currently when we boot a mx6dual U-boot reports that it is a mx6quad.
Report it as MX6D instead:
CPU: Freescale i.MX6D rev1.2 at 792 MHz
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/armv7/mx6/soc.c | 14 +++++++++++--- arch/arm/imx-common/cpu.c | 2 ++ arch/arm/include/asm/arch-imx/cpu.h | 1 + 3 files changed, 14 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index 0208cba..9acd8c9 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -41,14 +41,19 @@ u32 get_cpu_rev(void)
if (type != MXC_CPU_MX6SL) { reg = readl(&anatop->digprog); + struct scu_regs *scu = (struct scu_regs *)SCU_BASE_ADDR; + u32 cfg = readl(&scu->config) & 3; type = ((reg >> 16) & 0xff); if (type == MXC_CPU_MX6DL) { - struct scu_regs *scu = (struct scu_regs *)SCU_BASE_ADDR; - u32 cfg = readl(&scu->config) & 3; - if (!cfg) type = MXC_CPU_MX6SOLO; } + + if (type == MXC_CPU_MX6Q) { + if (cfg == 1) + type = MXC_CPU_MX6D; + } + } reg &= 0xff; /* mx6 silicon revision */ return (type << 12) | (reg + 0x10); @@ -62,6 +67,9 @@ u32 __weak get_board_rev(void) if (type == MXC_CPU_MX6SOLO) cpurev = (MXC_CPU_MX6DL) << 12 | (cpurev & 0xFFF);
+ if (type == MXC_CPU_MX6D) + cpurev = (MXC_CPU_MX6Q) << 12 | (cpurev & 0xFFF); + return cpurev; } #endif diff --git a/arch/arm/imx-common/cpu.c b/arch/arm/imx-common/cpu.c index 9231649..a77c4de 100644 --- a/arch/arm/imx-common/cpu.c +++ b/arch/arm/imx-common/cpu.c @@ -106,6 +106,8 @@ const char *get_imx_type(u32 imxtype) switch (imxtype) { case MXC_CPU_MX6Q: return "6Q"; /* Quad-core version of the mx6 */ + case MXC_CPU_MX6D: + return "6D"; /* Dual-core version of the mx6 */ case MXC_CPU_MX6DL: return "6DL"; /* Dual Lite version of the mx6 */ case MXC_CPU_MX6SOLO: diff --git a/arch/arm/include/asm/arch-imx/cpu.h b/arch/arm/include/asm/arch-imx/cpu.h index 8c725e2..a35940e 100644 --- a/arch/arm/include/asm/arch-imx/cpu.h +++ b/arch/arm/include/asm/arch-imx/cpu.h @@ -10,3 +10,4 @@ #define MXC_CPU_MX6DL 0x61 #define MXC_CPU_MX6SOLO 0x62 #define MXC_CPU_MX6Q 0x63 +#define MXC_CPU_MX6D 0x64
Fabio Estevam
