[U-Boot] [PATCH V2 1/3] watchdog: designware: Migrate CONFIG_DESIGNWARE_WATCHDOG to Kconfig
Migrate CONFIG_DESIGNWARE_WATCHDOG to Kconfig and update the headers accordingly, no functional change. The S10 enables the WDT only in SPL, but does not enable it in U-Boot itself, hence disable it in the config again.
Signed-off-by: Marek Vasut marex@denx.de Cc: Chin Liang See chin.liang.see@intel.com Cc: Dalon Westergreen dwesterg@gmail.com Cc: Dinh Nguyen dinguyen@kernel.org Cc: Jagan Teki jagan@amarulasolutions.com Cc: Ley Foon Tan ley.foon.tan@intel.com Cc: Philipp Tomisch philipp.tomisch@theobroma-systems.com Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Cc: Tien Fong Chee tien.fong.chee@intel.com --- V2: Use non-DM watchdog in SPL on S10 --- configs/socfpga_stratix10_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 1 + drivers/watchdog/Kconfig | 7 +++++++ include/configs/socfpga_common.h | 3 --- include/configs/socfpga_stratix10_socdk.h | 6 ++++-- scripts/config_whitelist.txt | 1 - 6 files changed, 13 insertions(+), 6 deletions(-)
diff --git a/configs/socfpga_stratix10_defconfig b/configs/socfpga_stratix10_defconfig index ad83f50032..462082b67b 100644 --- a/configs/socfpga_stratix10_defconfig +++ b/configs/socfpga_stratix10_defconfig @@ -56,3 +56,4 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y +CONFIG_DESIGNWARE_WATCHDOG=y diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index 96f806ab5f..03c43fa8b9 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -91,3 +91,4 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_DESIGNWARE_WATCHDOG=y diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index a66a9bcbe2..6fd9b0a177 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -36,6 +36,13 @@ config ULP_WATCHDOG help Say Y here to enable i.MX7ULP watchdog driver.
+config DESIGNWARE_WATCHDOG + bool "Designware watchdog timer support" + select HW_WATCHDOG + help + Enable this to support Designware Watchdog Timer IP, present e.g. + on Altera SoCFPGA SoCs. + config WDT bool "Enable driver model for watchdog timer drivers" depends on DM diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index b11fe021a7..32b9131be0 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -104,12 +104,9 @@ /* * L4 Watchdog */ -#ifdef CONFIG_HW_WATCHDOG -#define CONFIG_DESIGNWARE_WATCHDOG #define CONFIG_DW_WDT_BASE SOCFPGA_L4WD0_ADDRESS #define CONFIG_DW_WDT_CLOCK_KHZ 25000 #define CONFIG_WATCHDOG_TIMEOUT_MSECS 30000 -#endif
/* * MMC Driver diff --git a/include/configs/socfpga_stratix10_socdk.h b/include/configs/socfpga_stratix10_socdk.h index 7b55dd14da..353e08f982 100644 --- a/include/configs/socfpga_stratix10_socdk.h +++ b/include/configs/socfpga_stratix10_socdk.h @@ -162,14 +162,16 @@ unsigned int cm_get_qspi_controller_clk_hz(void); */ #ifdef CONFIG_SPL_BUILD #define CONFIG_HW_WATCHDOG -#define CONFIG_DESIGNWARE_WATCHDOG +#else +#undef CONFIG_HW_WATCHDOG +#undef CONFIG_DESIGNWARE_WATCHDOG +#endif #define CONFIG_DW_WDT_BASE SOCFPGA_L4WD0_ADDRESS #ifndef __ASSEMBLY__ unsigned int cm_get_l4_sys_free_clk_hz(void); #define CONFIG_DW_WDT_CLOCK_KHZ (cm_get_l4_sys_free_clk_hz() / 1000) #endif #define CONFIG_WATCHDOG_TIMEOUT_MSECS 3000 -#endif
/* * SPL memory layout diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index b18eab1707..839eda8c0f 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -320,7 +320,6 @@ CONFIG_DEFAULT_IMMR CONFIG_DEF_HWCONFIG CONFIG_DELAY_ENVIRONMENT CONFIG_DESIGNWARE_ETH -CONFIG_DESIGNWARE_WATCHDOG CONFIG_DEVELOP CONFIG_DEVICE_TREE_LIST CONFIG_DFU_ALT
Convert the designware watchdog timer driver to DM and add DT probing support. Perform minor coding style clean up, like drop superfluous braces. There ought to be no functional change.
Signed-off-by: Marek Vasut marex@denx.de Cc: Chin Liang See chin.liang.see@intel.com Cc: Dalon Westergreen dwesterg@gmail.com Cc: Dinh Nguyen dinguyen@kernel.org Cc: Jagan Teki jagan@amarulasolutions.com Cc: Ley Foon Tan ley.foon.tan@intel.com Cc: Philipp Tomisch philipp.tomisch@theobroma-systems.com Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Cc: Tien Fong Chee tien.fong.chee@intel.com --- V2: - Support both DM and non-DM probing - Fix watchdog stop handling by setting CR bit --- configs/socfpga_stratix10_defconfig | 2 + configs/socfpga_vining_fpga_defconfig | 1 + drivers/watchdog/Kconfig | 2 +- drivers/watchdog/designware_wdt.c | 122 ++++++++++++++++++---- include/configs/socfpga_stratix10_socdk.h | 1 + 5 files changed, 104 insertions(+), 24 deletions(-)
diff --git a/configs/socfpga_stratix10_defconfig b/configs/socfpga_stratix10_defconfig index 462082b67b..752fa545bd 100644 --- a/configs/socfpga_stratix10_defconfig +++ b/configs/socfpga_stratix10_defconfig @@ -57,3 +57,5 @@ CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y CONFIG_DESIGNWARE_WATCHDOG=y +CONFIG_WDT=y +# CONFIG_SPL_WDT is not set diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index 03c43fa8b9..def7a3eca7 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -91,4 +91,5 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_WDT=y CONFIG_DESIGNWARE_WATCHDOG=y diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index 6fd9b0a177..bfb91af947 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -38,7 +38,7 @@ config ULP_WATCHDOG
config DESIGNWARE_WATCHDOG bool "Designware watchdog timer support" - select HW_WATCHDOG + select HW_WATCHDOG if !WDT help Enable this to support Designware Watchdog Timer IP, present e.g. on Altera SoCFPGA SoCs. diff --git a/drivers/watchdog/designware_wdt.c b/drivers/watchdog/designware_wdt.c index c668567c66..a7b735979a 100644 --- a/drivers/watchdog/designware_wdt.c +++ b/drivers/watchdog/designware_wdt.c @@ -4,7 +4,8 @@ */
#include <common.h> -#include <watchdog.h> +#include <dm.h> +#include <wdt.h> #include <asm/io.h> #include <asm/utils.h>
@@ -17,46 +18,51 @@ #define DW_WDT_CR_RMOD_VAL 0x00 #define DW_WDT_CRR_RESTART_VAL 0x76
+struct designware_wdt_priv { + void __iomem *base; +}; + /* * Set the watchdog time interval. * Counter is 32 bit. */ -static int designware_wdt_settimeout(unsigned int timeout) +static int designware_wdt_settimeout(void __iomem *base, unsigned int clk_khz, + unsigned int timeout) { signed int i;
/* calculate the timeout range value */ - i = (log_2_n_round_up(timeout * CONFIG_DW_WDT_CLOCK_KHZ)) - 16; - if (i > 15) - i = 15; - if (i < 0) - i = 0; + i = log_2_n_round_up(timeout * clk_khz) - 16; + i = clamp(i, 0, 15); + + writel(i | (i << 4), base + DW_WDT_TORR);
- writel((i | (i << 4)), (CONFIG_DW_WDT_BASE + DW_WDT_TORR)); return 0; }
-static void designware_wdt_enable(void) +static void designware_wdt_enable(void __iomem *base) { - writel(((DW_WDT_CR_RMOD_VAL << DW_WDT_CR_RMOD_OFFSET) | - (0x1 << DW_WDT_CR_EN_OFFSET)), - (CONFIG_DW_WDT_BASE + DW_WDT_CR)); + writel((DW_WDT_CR_RMOD_VAL << DW_WDT_CR_RMOD_OFFSET) | + BIT(DW_WDT_CR_EN_OFFSET), + base + DW_WDT_CR); }
-static unsigned int designware_wdt_is_enabled(void) +static unsigned int designware_wdt_is_enabled(void __iomem *base) { - unsigned long val; - val = readl((CONFIG_DW_WDT_BASE + DW_WDT_CR)); - return val & 0x1; + return readl(base + DW_WDT_CR) & BIT(0); }
-#if defined(CONFIG_HW_WATCHDOG) -void hw_watchdog_reset(void) +static void designware_wdt_reset_common(void __iomem *base) { - if (designware_wdt_is_enabled()) + if (designware_wdt_is_enabled(base)) /* restart the watchdog counter */ - writel(DW_WDT_CRR_RESTART_VAL, - (CONFIG_DW_WDT_BASE + DW_WDT_CRR)); + writel(DW_WDT_CRR_RESTART_VAL, base + DW_WDT_CRR); +} + +#if !CONFIG_IS_ENABLED(WDT) +void hw_watchdog_reset(void) +{ + designware_wdt_reset_common((void __iomem *)CONFIG_DW_WDT_BASE); }
void hw_watchdog_init(void) @@ -64,10 +70,80 @@ void hw_watchdog_init(void) /* reset to disable the watchdog */ hw_watchdog_reset(); /* set timer in miliseconds */ - designware_wdt_settimeout(CONFIG_WATCHDOG_TIMEOUT_MSECS); + designware_wdt_settimeout((void __iomem *)CONFIG_DW_WDT_BASE, + CONFIG_DW_WDT_CLOCK_KHZ, + CONFIG_WATCHDOG_TIMEOUT_MSECS); /* enable the watchdog */ - designware_wdt_enable(); + designware_wdt_enable((void __iomem *)CONFIG_DW_WDT_BASE); /* reset the watchdog */ hw_watchdog_reset(); } +#else +static int designware_wdt_reset(struct udevice *dev) +{ + struct designware_wdt_priv *priv = dev_get_priv(dev); + + designware_wdt_reset_common(priv->base); + + return 0; +} + +static int designware_wdt_stop(struct udevice *dev) +{ + struct designware_wdt_priv *priv = dev_get_priv(dev); + + designware_wdt_reset(dev); + writel(DW_WDT_CR_RMOD_VAL << DW_WDT_CR_RMOD_OFFSET, + priv->base + DW_WDT_CR); + + return 0; +} + +static int designware_wdt_start(struct udevice *dev, u64 timeout, ulong flags) +{ + struct designware_wdt_priv *priv = dev_get_priv(dev); + + designware_wdt_stop(dev); + + /* set timer in miliseconds */ + designware_wdt_settimeout(priv->base, CONFIG_DW_WDT_CLOCK_KHZ, timeout); + + designware_wdt_enable(priv->base); + + /* reset the watchdog */ + return designware_wdt_reset(dev); +} + +static int designware_wdt_probe(struct udevice *dev) +{ + struct designware_wdt_priv *priv = dev_get_priv(dev); + + priv->base = dev_remap_addr(dev); + if (!priv->base) + return -EINVAL; + + /* reset to disable the watchdog */ + return designware_wdt_stop(dev); +} + +static const struct wdt_ops designware_wdt_ops = { + .start = designware_wdt_start, + .reset = designware_wdt_reset, + .stop = designware_wdt_stop, +}; + +static const struct udevice_id designware_wdt_ids[] = { + { .compatible = "snps,dw-wdt"}, + {} +}; + +U_BOOT_DRIVER(designware_wdt) = { + .name = "designware_wdt", + .id = UCLASS_WDT, + .of_match = designware_wdt_ids, + .priv_auto_alloc_size = sizeof(struct designware_wdt_priv), + .probe = designware_wdt_probe, + .ops = &designware_wdt_ops, + .flags = DM_FLAG_PRE_RELOC, +}; #endif diff --git a/include/configs/socfpga_stratix10_socdk.h b/include/configs/socfpga_stratix10_socdk.h index 353e08f982..0c0c27000a 100644 --- a/include/configs/socfpga_stratix10_socdk.h +++ b/include/configs/socfpga_stratix10_socdk.h @@ -161,6 +161,7 @@ unsigned int cm_get_qspi_controller_clk_hz(void); * L4 Watchdog */ #ifdef CONFIG_SPL_BUILD +#undef CONFIG_WATCHDOG #define CONFIG_HW_WATCHDOG #else #undef CONFIG_HW_WATCHDOG
All watchdog DT nodes with compatible "snps,dw-wdt" need to add "u-boot,dm-pre-reloc;".
Same here. All socfpga defconfig files need to add CONFIG_WDT.
select HW_WATCHDOG
void __iomem *base;
- Set the watchdog time interval.
- Counter is 32 bit.
{ signed int i;
if (i > 15)
i = 15;
if (i < 0)
i = 0;
base + DW_WDT_CR);
unsigned long val;
return val & 0x1;
In my "arm: socfpga: Convert drivers from struct to defines" patch series, I have moved spl_early_init() to the beginning of spl_board_f(). So, DM framework is initialized in early stage, you should able to use DM for watchdog in SPL too. But, maybe need to add a wrapper function to probe watchdog device and start watchdog. Something like this:
uclass_get_device(UCLASS_WDT, 0, &dev); wdt_start(dev, CONFIG_WATCHDOG_TIMEOUT_MSECS, 0);
Still no fixing clear BIT(DW_WDT_CR_EN_OFFSET) in CR register to disable watchdog.
Need de-assert watchdog reset using reset framework function, reset_get_bulk().
if (!priv->base)
return -EINVAL;
.id = UCLASS_WDT,
- L4 Watchdog
2.23.0
Only those boards which actually use the WDT, right ? That is, these two boards below.
Only those two, since only those two boards enable the WDT, no ?
Except this driver is not used only on SoCFPGA. So the question is, with your conversion series, will there be boards left which use non-DM version of this WDT driver ?
I guess we an just write 0 to the CR register and get rid of RMOD_VAL altogether ?
Ah yes, and make it presumably optional.
Am 03.10.2019 um 14:59 schrieb Marek Vasut:
- select HW_WATCHDOG if !WDT help Enable this to support Designware Watchdog Timer IP, present e.g. on Altera SoCFPGA SoCs.
- void __iomem *base;
{ signed int i;
- if (i > 15)
i = 15;
- if (i < 0)
i = 0;
- i = log_2_n_round_up(timeout * clk_khz) - 16;
- i = clamp(i, 0, 15);
- writel(i | (i << 4), base + DW_WDT_TORR);
- writel((DW_WDT_CR_RMOD_VAL << DW_WDT_CR_RMOD_OFFSET) |
}base + DW_WDT_CR);
- return val & 0x1;
- return readl(base + DW_WDT_CR) & BIT(0); }
- if (designware_wdt_is_enabled(base)) /* restart the watchdog counter */
- designware_wdt_settimeout((void __iomem *)CONFIG_DW_WDT_BASE,
/* enable the watchdog */CONFIG_WATCHDOG_TIMEOUT_MSECS);
- designware_wdt_enable((void __iomem *)CONFIG_DW_WDT_BASE); /* reset the watchdog */ hw_watchdog_reset(); }
- struct designware_wdt_priv *priv = dev_get_priv(dev);
- designware_wdt_reset_common(priv->base);
- designware_wdt_reset(dev);
- writel(DW_WDT_CR_RMOD_VAL << DW_WDT_CR_RMOD_OFFSET,
- designware_wdt_stop(dev);
- /* set timer in miliseconds */
- designware_wdt_settimeout(priv->base, CONFIG_DW_WDT_CLOCK_KHZ, timeout);
- designware_wdt_enable(priv->base);
- /* reset the watchdog */
- return designware_wdt_reset(dev);
- priv->base = dev_remap_addr(dev);
- if (!priv->base)
return -EINVAL;
- /* reset to disable the watchdog */
- return designware_wdt_stop(dev);
- .start = designware_wdt_start,
- .reset = designware_wdt_reset,
- .stop = designware_wdt_stop,
- { .compatible = "snps,dw-wdt"},
- .name = "designware_wdt",
- .id = UCLASS_WDT,
- .of_match = designware_wdt_ids,
- .priv_auto_alloc_size = sizeof(struct designware_wdt_priv),
- .probe = designware_wdt_probe,
- .ops = &designware_wdt_ops,
- .flags = DM_FLAG_PRE_RELOC,
- L4 Watchdog
I somehow missed this series. Why is this line here?
Other than that: Reviewed-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com
On 11/7/19 8:30 PM, Simon Goldschmidt wrote: [...]
To avoid using DM watchdog in SPL on S10.
Hi Marek,
Please resend on top of master, would like to check it on rockchip.
Jagan.
On 12/27/19 8:53 AM, Jagan Teki wrote:
Hi Marek,
Done, please give it a try.
Add optional support for fetching watchdog clock rate from DT. This is optional as not all platforms using DW WDT support the clock framework yet.
Signed-off-by: Marek Vasut marex@denx.de Cc: Chin Liang See chin.liang.see@intel.com Cc: Dalon Westergreen dwesterg@gmail.com Cc: Dinh Nguyen dinguyen@kernel.org Cc: Jagan Teki jagan@amarulasolutions.com Cc: Ley Foon Tan ley.foon.tan@intel.com Cc: Philipp Tomisch philipp.tomisch@theobroma-systems.com Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Cc: Tien Fong Chee tien.fong.chee@intel.com --- V2: - New patch --- drivers/watchdog/designware_wdt.c | 17 ++++++++++++++++- 1 file changed, 16 insertions(+), 1 deletion(-)
diff --git a/drivers/watchdog/designware_wdt.c b/drivers/watchdog/designware_wdt.c index a7b735979a..66621e8bb5 100644 --- a/drivers/watchdog/designware_wdt.c +++ b/drivers/watchdog/designware_wdt.c @@ -20,6 +20,7 @@
struct designware_wdt_priv { void __iomem *base; + unsigned int clk_khz; };
/* @@ -106,7 +107,7 @@ static int designware_wdt_start(struct udevice *dev, u64 timeout, ulong flags) designware_wdt_stop(dev);
/* set timer in miliseconds */ - designware_wdt_settimeout(priv->base, CONFIG_DW_WDT_CLOCK_KHZ, timeout); + designware_wdt_settimeout(priv->base, priv->clk_khz, timeout);
@@ -122,6 +123,20 @@ static int designware_wdt_probe(struct udevice *dev) if (!priv->base) return -EINVAL;
+#if CONFIG_IS_ENABLED(CLK) + struct clk clk; + + ret = clk_get_by_index(dev, 0, &clk); + if (ret) + return ret; + + priv->clk_khz = clk_get_rate(&clk); + if (!priv->clk_khz) + return -EINVAL; +#else + priv->clk_khz = CONFIG_DW_WDT_CLOCK_KHZ; +#endif + /* reset to disable the watchdog */ return designware_wdt_stop(dev); }
All socfpga deconfig files need to add CONFIG_DESIGNWARE_WATCHDOG too. socfpga_common.h is used by Gen5 and A10 platform.
Regards Ley Foon
diff --git a/configs/socfpga_stratix10_defconfig b/configs/socfpga_stratix10_defconfig index ad83f50032..462082b67b 100644 --- a/configs/socfpga_stratix10_defconfig +++ b/configs/socfpga_stratix10_defconfig CONFIG_DESIGNWARE_WATCHDOG @@ -56,3 +56,4 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y +CONFIG_DESIGNWARE_WATCHDOG=y diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index 96f806ab5f..03c43fa8b9 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -91,3 +91,4 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_DESIGNWARE_WATCHDOG=y diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index a66a9bcbe2..6fd9b0a177 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -36,6 +36,13 @@ config ULP_WATCHDOG help Say Y here to enable i.MX7ULP watchdog driver.
select HW_WATCHDOG
help
- L4 Watchdog
- MMC Driver
- SPL memory layout
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index b18eab1707..839eda8c0f 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -320,7 +320,6 @@ CONFIG_DEFAULT_IMMR CONFIG_DEF_HWCONFIG CONFIG_DELAY_ENVIRONMENT CONFIG_DESIGNWARE_ETH -CONFIG_DESIGNWARE_WATCHDOG CONFIG_DEVELOP CONFIG_DEVICE_TREE_LIST CONFIG_DFU_ALT -- 2.23.0
Only those which defined CONFIG_HW_WATCHDOG need to enable the CONFIG_DESIGNWARE_WATCHDOG, right ? (see below)
- L4 Watchdog
$ git grep socfpga_common.h include/configs/socfpga_arria10_socdk.h:#include <configs/socfpga_common.h> include/configs/socfpga_arria5_socdk.h:#include <configs/socfpga_common.h> include/configs/socfpga_cyclone5_socdk.h:#include <configs/socfpga_common.h> include/configs/socfpga_dbm_soc1.h:#include <configs/socfpga_common.h> include/configs/socfpga_de0_nano_soc.h:#include <configs/socfpga_common.h> include/configs/socfpga_de10_nano.h:#include <configs/socfpga_common.h> include/configs/socfpga_de1_soc.h:#include <configs/socfpga_common.h> include/configs/socfpga_is1.h:#include <configs/socfpga_common.h> include/configs/socfpga_mcvevk.h:#include <configs/socfpga_common.h> include/configs/socfpga_sockit.h:#include <configs/socfpga_common.h> include/configs/socfpga_socrates.h:#include <configs/socfpga_common.h> include/configs/socfpga_sr1500.h:#include <configs/socfpga_common.h> include/configs/socfpga_vining_fpga.h:#include <configs/socfpga_common.h>
These platforms include socfpga_common.h file, so their _defconfig need to update too.
- L4 Watchdog
They don't enable HW_WATCHDOG, so it doesn't ... or ?
- L4 Watchdog
Sorry, I see wrongly. I thought HW_WATCHDOG is defined in socfpga_common.h. Then no problem now.
Regards Ley Foon
- L4 Watchdog
-- Best regards, Marek Vasut
Sorry for the late reply.
Are we OK with this patch then ?
- bool "Designware watchdog timer support"
- help
- config WDT bool "Enable driver model for watchdog timer drivers" depends on DM
- L4 Watchdog
- MMC Driver
- SPL memory layout
Jagan Teki
Ley Foon Tan
Simon Goldschmidt
