[U-Boot] [Patch V4 2/4] spi: fsl_qspi: Fix qspi_op_rdid memcpy issue
In current driver everytime we memcpy 4 bytes to the dest memory regardless of the remaining length. This patch adds checking the remaining length before memcpy. If the length is shorter than 4 bytes, memcpy the actual length of data to the dest memory.
Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V2-V4: - No change.
drivers/spi/fsl_qspi.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/spi/fsl_qspi.c b/drivers/spi/fsl_qspi.c index 9f23c10..4d58211 100644 --- a/drivers/spi/fsl_qspi.c +++ b/drivers/spi/fsl_qspi.c @@ -500,7 +500,10 @@ static void qspi_op_rdid(struct fsl_qspi_priv *priv, u32 *rxbuf, u32 len) if (rbsr_reg & QSPI_RBSR_RDBFL_MASK) { data = qspi_read32(priv->flags, ®s->rbdr[i]); data = qspi_endian_xchg(data); - memcpy(rxbuf, &data, 4); + if (size < 4) + memcpy(rxbuf, &data, size); + else + memcpy(rxbuf, &data, 4); rxbuf++; size -= 4; i++;
V2-V4:
- No change.
if (size < 4)
else
Doesn't the line "size -= 4" need a fix as well? I guess it runs OK for checking (size > 0), but it looks odd.
York
-----Original Message----- From: york sun Sent: Wednesday, January 20, 2016 2:47 AM To: Qianyu Gong qianyu.gong@nxp.com; u-boot@lists.denx.de Cc: Mingkai Hu mingkai.hu@nxp.com; jteki@openedev.com; Yao Yuan yao.yuan@nxp.com; R58495@freescale.com; Gong Qianyu Qianyu.Gong@freescale.com Subject: Re: [Patch V4 2/4] spi: fsl_qspi: Fix qspi_op_rdid memcpy issue
V2-V4:
- No change.
*rxbuf, u32 len)
if (size < 4)
else
York
I paste the related code. It checks (size > 0) in the while loop:
i = 0; size = len; while ((RX_BUFFER_SIZE >= size) && (size > 0)) { rbsr_reg = qspi_read32(priv->flags, ®s->rbsr); if (rbsr_reg & QSPI_RBSR_RDBFL_MASK) { data = qspi_read32(priv->flags, ®s->rbdr[i]); data = qspi_endian_xchg(data); if (size < 4) memcpy(rxbuf, &data, size); else memcpy(rxbuf, &data, 4); rxbuf++; size -= 4; i++; } }
Gong Qianyu
Qianyu Gong
york sun
