[U-Boot] [PATCH v2] iomux-v3: Add support for mx6sl LVE bit
On mx6sl there is a LVE (Low Voltage Enable) bit in the IOMUXC_SW_PAD_CTL register that can enable or disable low voltage on the pad.
LVE is bit 22 of IOMUXC_SW_PAD_CTL register, but in order to make the calculation easier we can define it as a flag in bit 1, since this bit is unused.
Add support for it.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v1: - Use bit 1, which is unused.
arch/arm/imx-common/iomux-v3.c | 8 ++++++++ arch/arm/include/asm/imx-common/iomux-v3.h | 5 +++++ 2 files changed, 13 insertions(+)
diff --git a/arch/arm/imx-common/iomux-v3.c b/arch/arm/imx-common/iomux-v3.c index b59b802..6e46ea8 100644 --- a/arch/arm/imx-common/iomux-v3.c +++ b/arch/arm/imx-common/iomux-v3.c @@ -30,6 +30,14 @@ void imx_iomux_v3_setup_pad(iomux_v3_cfg_t pad) (pad & MUX_PAD_CTRL_OFS_MASK) >> MUX_PAD_CTRL_OFS_SHIFT; u32 pad_ctrl = (pad & MUX_PAD_CTRL_MASK) >> MUX_PAD_CTRL_SHIFT;
+#if defined CONFIG_MX6SL + /* Check whether LVE bit needs to be set */ + if (pad_ctrl & PAD_CTL_LVE) { + pad_ctrl &= ~PAD_CTL_LVE; + pad_ctrl |= PAD_CTL_LVE_BIT; + } +#endif + if (mux_ctrl_ofs) __raw_writel(mux_mode, base + mux_ctrl_ofs);
diff --git a/arch/arm/include/asm/imx-common/iomux-v3.h b/arch/arm/include/asm/imx-common/iomux-v3.h index dec11a1..cca920b 100644 --- a/arch/arm/include/asm/imx-common/iomux-v3.h +++ b/arch/arm/include/asm/imx-common/iomux-v3.h @@ -111,6 +111,11 @@ typedef u64 iomux_v3_cfg_t; #define PAD_CTL_DSE_40ohm (6 << 3) #define PAD_CTL_DSE_34ohm (7 << 3)
+#if defined CONFIG_MX6SL +#define PAD_CTL_LVE (1 << 1) +#define PAD_CTL_LVE_BIT (1 << 22) +#endif + #elif defined(CONFIG_VF610)
#define PAD_MUX_MODE_SHIFT 20
On Tue, Apr 29, 2014 at 10:15 AM, Fabio Estevam fabio.estevam@freescale.com wrote:
Add support for it.
Tested-by: Otavio Salvador otavio@ossystems.com.br
Add support for it.
Best regards, Stefano Babic
Fabio Estevam
Otavio Salvador
Stefano Babic
