[U-Boot] [PATCH 1/3] sunxi: Fix clock_twi_onoff for sun6i
The clock_sun6i.c implementation was not deasserting the reset for the regular i2c controllers, this commit fixes this.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- arch/arm/cpu/armv7/sunxi/clock_sun6i.c | 11 ++++++++--- 1 file changed, 8 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv7/sunxi/clock_sun6i.c b/arch/arm/cpu/armv7/sunxi/clock_sun6i.c index 700b605..4e1e1a4 100644 --- a/arch/arm/cpu/armv7/sunxi/clock_sun6i.c +++ b/arch/arm/cpu/armv7/sunxi/clock_sun6i.c @@ -100,13 +100,18 @@ int clock_twi_onoff(int port, int state) return 0; }
- /* set the apb clock gate for twi */ - if (state) + /* set the apb clock gate and reset for twi */ + if (state) { setbits_le32(&ccm->apb2_gate, CLK_GATE_OPEN << (APB2_GATE_TWI_SHIFT+port)); - else + setbits_le32(&ccm->apb2_reset_cfg, + 1 << (APB2_RESET_TWI_SHIFT + port)); + } else { + clrbits_le32(&ccm->apb2_reset_cfg, + 1 << (APB2_RESET_TWI_SHIFT + port)); clrbits_le32(&ccm->apb2_gate, CLK_GATE_OPEN << (APB2_GATE_TWI_SHIFT+port)); + }
return 0; }
clock_sun8i_a83.c did not contain a clock_twi_onoff implementation at all, this is fixed by moving the clock_sun6i.c implementation, which is correct for the a83 too, to a shared location.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- arch/arm/cpu/armv7/sunxi/clock.c | 35 ++++++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/sunxi/clock_sun6i.c | 31 ------------------------------ 2 files changed, 35 insertions(+), 31 deletions(-)
diff --git a/arch/arm/cpu/armv7/sunxi/clock.c b/arch/arm/cpu/armv7/sunxi/clock.c index 5cc5d25..0b8fc94 100644 --- a/arch/arm/cpu/armv7/sunxi/clock.c +++ b/arch/arm/cpu/armv7/sunxi/clock.c @@ -12,6 +12,7 @@ #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/gpio.h> +#include <asm/arch/prcm.h> #include <asm/arch/sys_proto.h>
__weak void clock_init_sec(void) @@ -28,3 +29,37 @@ int clock_init(void)
return 0; } + +/* These functions are shared between various SoCs so put them here. */ +#if defined CONFIG_SUNXI_GEN_SUN6I && !defined CONFIG_MACH_SUN9I +int clock_twi_onoff(int port, int state) +{ + struct sunxi_ccm_reg *const ccm = + (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + + if (port == 5) { + if (state) + prcm_apb0_enable( + PRCM_APB0_GATE_PIO | PRCM_APB0_GATE_I2C); + else + prcm_apb0_disable( + PRCM_APB0_GATE_PIO | PRCM_APB0_GATE_I2C); + return 0; + } + + /* set the apb clock gate and reset for twi */ + if (state) { + setbits_le32(&ccm->apb2_gate, + CLK_GATE_OPEN << (APB2_GATE_TWI_SHIFT + port)); + setbits_le32(&ccm->apb2_reset_cfg, + 1 << (APB2_RESET_TWI_SHIFT + port)); + } else { + clrbits_le32(&ccm->apb2_reset_cfg, + 1 << (APB2_RESET_TWI_SHIFT + port)); + clrbits_le32(&ccm->apb2_gate, + CLK_GATE_OPEN << (APB2_GATE_TWI_SHIFT + port)); + } + + return 0; +} +#endif diff --git a/arch/arm/cpu/armv7/sunxi/clock_sun6i.c b/arch/arm/cpu/armv7/sunxi/clock_sun6i.c index 4e1e1a4..15272c9 100644 --- a/arch/arm/cpu/armv7/sunxi/clock_sun6i.c +++ b/arch/arm/cpu/armv7/sunxi/clock_sun6i.c @@ -85,37 +85,6 @@ void clock_init_uart(void) #endif }
-int clock_twi_onoff(int port, int state) -{ - struct sunxi_ccm_reg *const ccm = - (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; - - if (port == 5) { - if (state) - prcm_apb0_enable( - PRCM_APB0_GATE_PIO | PRCM_APB0_GATE_I2C); - else - prcm_apb0_disable( - PRCM_APB0_GATE_PIO | PRCM_APB0_GATE_I2C); - return 0; - } - - /* set the apb clock gate and reset for twi */ - if (state) { - setbits_le32(&ccm->apb2_gate, - CLK_GATE_OPEN << (APB2_GATE_TWI_SHIFT+port)); - setbits_le32(&ccm->apb2_reset_cfg, - 1 << (APB2_RESET_TWI_SHIFT + port)); - } else { - clrbits_le32(&ccm->apb2_reset_cfg, - 1 << (APB2_RESET_TWI_SHIFT + port)); - clrbits_le32(&ccm->apb2_gate, - CLK_GATE_OPEN << (APB2_GATE_TWI_SHIFT+port)); - } - - return 0; -} - #ifdef CONFIG_SPL_BUILD void clock_set_pll1(unsigned int clk) {
Fix a copy and paste error which caused us to use the uart rather then the twi reset bits in clock_twi_onoff for sun9i.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- arch/arm/cpu/armv7/sunxi/clock_sun9i.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/sunxi/clock_sun9i.c b/arch/arm/cpu/armv7/sunxi/clock_sun9i.c index 27179ba..180634c 100644 --- a/arch/arm/cpu/armv7/sunxi/clock_sun9i.c +++ b/arch/arm/cpu/armv7/sunxi/clock_sun9i.c @@ -43,10 +43,10 @@ int clock_twi_onoff(int port, int state) setbits_le32(&ccm->apb1_gate, CLK_GATE_OPEN << (APB1_GATE_TWI_SHIFT + port)); setbits_le32(&ccm->apb1_reset_cfg, - 1 << (APB1_RESET_UART_SHIFT + port)); + 1 << (APB1_RESET_TWI_SHIFT + port)); } else { clrbits_le32(&ccm->apb1_reset_cfg, - 1 << (APB1_RESET_UART_SHIFT + port)); + 1 << (APB1_RESET_TWI_SHIFT + port)); clrbits_le32(&ccm->apb1_gate, CLK_GATE_OPEN << (APB1_GATE_TWI_SHIFT + port)); }
All 3 patches: Acked-by: Ian Campbell ijc@hellion.org.uk
- if (state)
- if (state) {
- else
- } else {
return 0; }
Hans de Goede
Ian Campbell
