[U-Boot] [PATCH v3 0/7] AE350 SMP support RISC-V
Changes in v3: Patch 1 - Rename plic_init() as enable_ipi() - Remove PLIC_BASE_GET() from enable_ipi() Patch 2 - Add a space before (PLMT) Patch 6 - Fix some mis-alignments - Recovery isa string of CPU1
Changes in v2: - Drop patch1 and replace by simple-bus driver - Rename nds_plic as andes_plic - Move initialize plic to PLIC_BASE_GET() and called automatically - Rename nds_plmt as andes_plmt - Recovery dts isa string
Rick Chen (7): riscv: Add a SYSCON driver for Andestech's PLIC riscv: Add a SYSCON driver for Andestech's PLMT riscv: ae350: disable ATCPIT100 timer riscv: ax25: Add platform-specific Kconfig options riscv: ax25: Andes specific cache shall only support in M-mode riscv: dts: ae350 support SMP riscv: ae350: enable SMP
arch/riscv/Kconfig | 18 ++++++ arch/riscv/cpu/ax25/Kconfig | 7 +++ arch/riscv/dts/ae350_32.dts | 81 +++++++++++++++++++------- arch/riscv/dts/ae350_64.dts | 81 +++++++++++++++++++------- arch/riscv/include/asm/global_data.h | 6 ++ arch/riscv/include/asm/syscon.h | 3 +- arch/riscv/lib/Makefile | 2 + arch/riscv/lib/andes_plic.c | 110 +++++++++++++++++++++++++++++++++++ arch/riscv/lib/andes_plmt.c | 53 +++++++++++++++++ board/AndesTech/ax25-ae350/Kconfig | 1 + configs/ae350_rv32_defconfig | 1 - configs/ae350_rv64_defconfig | 1 - 12 files changed, 317 insertions(+), 47 deletions(-) create mode 100644 arch/riscv/lib/andes_plic.c create mode 100644 arch/riscv/lib/andes_plmt.c
The Platform-Level Interrupt Controller (PLIC) block holds memory-mapped claim and pending registers associated with software interrupt. It is required for handling IPI.
Signed-off-by: Rick Chen rick@andestech.com Cc: Greentime Hu greentime@andestech.com --- V3: - Rename plic_init() as enable_ipi(). - Declase as static. - Remove PLIC_BASE_GET() from enable_ipi().
arch/riscv/Kconfig | 9 +++ arch/riscv/include/asm/global_data.h | 3 + arch/riscv/include/asm/syscon.h | 2 +- arch/riscv/lib/Makefile | 1 + arch/riscv/lib/andes_plic.c | 110 +++++++++++++++++++++++++++++++++++ 5 files changed, 124 insertions(+), 1 deletion(-) create mode 100644 arch/riscv/lib/andes_plic.c
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index 3a4470d..511768b 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -109,6 +109,15 @@ config SIFIVE_CLINT The SiFive CLINT block holds memory-mapped control and status registers associated with software and timer interrupts.
+config ANDES_PLIC + bool + depends on RISCV_MMODE + select REGMAP + select SYSCON + help + The Andes PLIC block holds memory-mapped claim and pending registers + associated with software interrupt. + config RISCV_RDTIME bool default y if RISCV_SMODE diff --git a/arch/riscv/include/asm/global_data.h b/arch/riscv/include/asm/global_data.h index 80e3165..b867910 100644 --- a/arch/riscv/include/asm/global_data.h +++ b/arch/riscv/include/asm/global_data.h @@ -18,6 +18,9 @@ struct arch_global_data { #ifdef CONFIG_SIFIVE_CLINT void __iomem *clint; /* clint base address */ #endif +#ifdef CONFIG_ANDES_PLIC + void __iomem *plic; /* plic base address */ +#endif #ifdef CONFIG_SMP struct ipi_data ipi[CONFIG_NR_CPUS]; #endif diff --git a/arch/riscv/include/asm/syscon.h b/arch/riscv/include/asm/syscon.h index d311ee6..c1b4b86 100644 --- a/arch/riscv/include/asm/syscon.h +++ b/arch/riscv/include/asm/syscon.h @@ -9,11 +9,11 @@ /* * System controllers in a RISC-V system * - * So far only SiFive's Core Local Interruptor (CLINT) is defined. */ enum { RISCV_NONE, RISCV_SYSCON_CLINT, /* Core Local Interruptor (CLINT) */ + RISCV_SYSCON_PLIC, /* Platform Level Interrupt Controller (PLIC) */ };
#endif /* _ASM_SYSCON_H */ diff --git a/arch/riscv/lib/Makefile b/arch/riscv/lib/Makefile index 35dbf64..1bf554b 100644 --- a/arch/riscv/lib/Makefile +++ b/arch/riscv/lib/Makefile @@ -11,6 +11,7 @@ obj-$(CONFIG_CMD_GO) += boot.o obj-y += cache.o obj-$(CONFIG_RISCV_RDTIME) += rdtime.o obj-$(CONFIG_SIFIVE_CLINT) += sifive_clint.o +obj-$(CONFIG_ANDES_PLIC) += andes_plic.o obj-y += interrupts.o obj-y += reset.o obj-$(CONFIG_SBI_IPI) += sbi_ipi.o diff --git a/arch/riscv/lib/andes_plic.c b/arch/riscv/lib/andes_plic.c new file mode 100644 index 0000000..67ab561 --- /dev/null +++ b/arch/riscv/lib/andes_plic.c @@ -0,0 +1,110 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019, Rick Chen rick@andestech.com + * + * U-Boot syscon driver for Andes's Platform Level Interrupt Controller (PLIC). + * The PLIC block holds memory-mapped claim and pending registers + * associated with software interrupt. + */ + +#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/lists.h> +#include <dm/uclass-internal.h> +#include <regmap.h> +#include <syscon.h> +#include <asm/io.h> +#include <asm/syscon.h> +#include <cpu.h> + +/* pending register */ +#define PENDING_REG(base, hart) ((ulong)(base) + 0x1000 + (hart) * 8) +/* enable register */ +#define ENABLE_REG(base, hart) ((ulong)(base) + 0x2000 + (hart) * 0x80) +/* claim register */ +#define CLAIM_REG(base, hart) ((ulong)(base) + 0x200004 + (hart) * 0x1000) + +#define ENABLE_HART_IPI (0x80808080) +#define SEND_IPI_TO_HART(hart) (0x80>>hart) + +DECLARE_GLOBAL_DATA_PTR; +static int init_plic(void); + +#define PLIC_BASE_GET(void) \ + do { \ + long *ret; \ + \ + if (!gd->arch.plic) { \ + ret = syscon_get_first_range(RISCV_SYSCON_PLIC); \ + if (IS_ERR(ret)) \ + return PTR_ERR(ret); \ + gd->arch.plic = ret; \ + init_plic(); \ + } \ + } while (0) + +static int enable_ipi(int harts) +{ + int i; + int en = ENABLE_HART_IPI; + + for (i = 0; i < harts ;i++) + { + en = en >> i; + writel(en, (void __iomem *)ENABLE_REG(gd->arch.plic, i)); + } + + return 0; +} + +static int init_plic(void) +{ + struct udevice *dev; + int ret; + + ret = uclass_find_first_device(UCLASS_CPU, &dev); + if (ret) + return ret; + + if (ret == 0 && dev != NULL) { + ret = cpu_get_count(dev); + enable_ipi(ret); + return 0; + } + + return -ENODEV; +} + +int riscv_send_ipi(int hart) +{ + PLIC_BASE_GET(); + + writel(SEND_IPI_TO_HART(hart), (void __iomem *)PENDING_REG(gd->arch.plic, gd->arch.boot_hart)); + + return 0; +} + +int riscv_clear_ipi(int hart) +{ + u32 source_id; + + PLIC_BASE_GET(); + + source_id = readl((void __iomem *)CLAIM_REG(gd->arch.plic, hart)); + writel(source_id, (void __iomem *)CLAIM_REG(gd->arch.plic, hart)); + + return 0; +} + +static const struct udevice_id andes_plic_ids[] = { + { .compatible = "riscv,plic1", .data = RISCV_SYSCON_PLIC }, + { } +}; + +U_BOOT_DRIVER(nds_plic) = { + .name = "andes_plic", + .id = UCLASS_SYSCON, + .of_match = andes_plic_ids, + .flags = DM_FLAG_PRE_RELOC, +};
V3:
Hi Rick,
V3:
Take a look at patman [1], it makes it really easy to handle different versions of a patch series. :)
[1]: https://github.com/u-boot/u-boot/blob/master/tools/patman/README
+config ANDES_PLIC
- bool
- depends on RISCV_MMODE
- select REGMAP
- select SYSCON
- help
- void __iomem *plic; /* plic base address */
- System controllers in a RISC-V system
nit: can you also drop the empty comment line above?
- So far only SiFive's Core Local Interruptor (CLINT) is defined.
- RISCV_SYSCON_PLIC, /* Platform Level Interrupt Controller (PLIC) */
- Copyright (C) 2019, Rick Chen rick@andestech.com
- U-Boot syscon driver for Andes's Platform Level Interrupt Controller (PLIC).
- The PLIC block holds memory-mapped claim and pending registers
- associated with software interrupt.
- do { \
long *ret; \
if (IS_ERR(ret)) \
init_plic(); \
- } while (0)
- int i;
- int en = ENABLE_HART_IPI;
- for (i = 0; i < harts ;i++)
en = en >> i;
- struct udevice *dev;
- int ret;
- ret = uclass_find_first_device(UCLASS_CPU, &dev);
- if (ret)
return ret;
- if (ret == 0 && dev != NULL) {
You should check first, if cpu_get_count() has returned an error before using its return value.
enable_ipi(ret);
- return -ENODEV;
- PLIC_BASE_GET();
- writel(SEND_IPI_TO_HART(hart), (void __iomem *)PENDING_REG(gd->arch.plic, gd->arch.boot_hart));
- u32 source_id;
- PLIC_BASE_GET();
- source_id = readl((void __iomem *)CLAIM_REG(gd->arch.plic, hart));
- writel(source_id, (void __iomem *)CLAIM_REG(gd->arch.plic, hart));
- { .compatible = "riscv,plic1", .data = RISCV_SYSCON_PLIC },
Would a compatible string of "andes,plic1" be more suitable?
nit: andes_plic
- .name = "andes_plic",
- .id = UCLASS_SYSCON,
- .of_match = andes_plic_ids,
- .flags = DM_FLAG_PRE_RELOC,
There are a couple of checkpatch issues in this patch. I have copied the relevant ones below.
CHECK: spaces preferred around that '>>' (ctx:VxV) #135: FILE: arch/riscv/lib/andes_plic.c:29: +#define SEND_IPI_TO_HART(hart) (0x80>>hart)
ERROR: that open brace { should be on the previous line #158: FILE: arch/riscv/lib/andes_plic.c:52: + for (i = 0; i < harts ;i++) + {
ERROR: space required after that ';' (ctx:WxV) #158: FILE: arch/riscv/lib/andes_plic.c:52: + for (i = 0; i < harts ;i++)
CHECK: Comparison to NULL could be written "dev" #176: FILE: arch/riscv/lib/andes_plic.c:70: + if (ret == 0 && dev != NULL) {
WARNING: line over 80 characters #189: FILE: arch/riscv/lib/andes_plic.c:83: + writel(SEND_IPI_TO_HART(hart), (void __iomem *)PENDING_REG(gd-
Thanks, Lukas
Hi Lukas,
On Mon, Apr 1, 2019 at 5:08 PM Auer, Lukas lukas.auer@aisec.fraunhofer.de wrote:
Hi Rick,
V3:
+config ANDES_PLIC
bool
select REGMAP
select SYSCON
help
do { \
long *ret; \
if (IS_ERR(ret)) \
init_plic(); \
} while (0)
int i;
en = en >> i;
int ret;
if (ret)
return ret;
enable_ipi(ret);
return -ENODEV;
PLIC_BASE_GET();
u32 source_id;
PLIC_BASE_GET();
nit: andes_plic
Thanks for the checking the issues by yourself. I was under the impression that patman checks will be performed in the travis, but looks it isn't.
Rick, please use patman, as Lukas suggested, to help your custodian work!
Regards, Bin
The platform-Level Machine Timer (PLMT) block holds memory-mapped mtime register associated with timer tick.
This driver implements the riscv_get_time() which is required by the generic RISC-V timer driver.
Signed-off-by: Rick Chen rick@andestech.com Cc: Greentime Hu greentime@andestech.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- V3: - Add a space before (PLMT).
arch/riscv/Kconfig | 9 ++++++ arch/riscv/include/asm/global_data.h | 3 ++ arch/riscv/include/asm/syscon.h | 1 + arch/riscv/lib/Makefile | 1 + arch/riscv/lib/andes_plmt.c | 53 ++++++++++++++++++++++++++++++++++++ 5 files changed, 67 insertions(+) create mode 100644 arch/riscv/lib/andes_plmt.c
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index 511768b..ae8ff7b 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -118,6 +118,15 @@ config ANDES_PLIC The Andes PLIC block holds memory-mapped claim and pending registers associated with software interrupt.
+config ANDES_PLMT + bool + depends on RISCV_MMODE + select REGMAP + select SYSCON + help + The Andes PLMT block holds memory-mapped mtime register + associated with timer tick. + config RISCV_RDTIME bool default y if RISCV_SMODE diff --git a/arch/riscv/include/asm/global_data.h b/arch/riscv/include/asm/global_data.h index b867910..dffcd45 100644 --- a/arch/riscv/include/asm/global_data.h +++ b/arch/riscv/include/asm/global_data.h @@ -21,6 +21,9 @@ struct arch_global_data { #ifdef CONFIG_ANDES_PLIC void __iomem *plic; /* plic base address */ #endif +#ifdef CONFIG_ANDES_PLMT + void __iomem *plmt; /* plmt base address */ +#endif #ifdef CONFIG_SMP struct ipi_data ipi[CONFIG_NR_CPUS]; #endif diff --git a/arch/riscv/include/asm/syscon.h b/arch/riscv/include/asm/syscon.h index c1b4b86..6e12574 100644 --- a/arch/riscv/include/asm/syscon.h +++ b/arch/riscv/include/asm/syscon.h @@ -14,6 +14,7 @@ enum { RISCV_NONE, RISCV_SYSCON_CLINT, /* Core Local Interruptor (CLINT) */ RISCV_SYSCON_PLIC, /* Platform Level Interrupt Controller (PLIC) */ + RISCV_SYSCON_PLMT, /* Platform Level Machine Timer (PLMT) */ };
#endif /* _ASM_SYSCON_H */ diff --git a/arch/riscv/lib/Makefile b/arch/riscv/lib/Makefile index 1bf554b..1c332db 100644 --- a/arch/riscv/lib/Makefile +++ b/arch/riscv/lib/Makefile @@ -12,6 +12,7 @@ obj-y += cache.o obj-$(CONFIG_RISCV_RDTIME) += rdtime.o obj-$(CONFIG_SIFIVE_CLINT) += sifive_clint.o obj-$(CONFIG_ANDES_PLIC) += andes_plic.o +obj-$(CONFIG_ANDES_PLMT) += andes_plmt.o obj-y += interrupts.o obj-y += reset.o obj-$(CONFIG_SBI_IPI) += sbi_ipi.o diff --git a/arch/riscv/lib/andes_plmt.c b/arch/riscv/lib/andes_plmt.c new file mode 100644 index 0000000..12d7e0e --- /dev/null +++ b/arch/riscv/lib/andes_plmt.c @@ -0,0 +1,53 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019, Rick Chen rick@andestech.com + * + * U-Boot syscon driver for Andes's Platform Level Machine Timer (PLMT). + * The PLMT block holds memory-mapped mtime register + * associated with timer tick. + */ + +#include <common.h> +#include <dm.h> +#include <regmap.h> +#include <syscon.h> +#include <asm/io.h> +#include <asm/syscon.h> + +/* mtime register */ +#define MTIME_REG(base) ((ulong)(base)) + +DECLARE_GLOBAL_DATA_PTR; + +#define PLMT_BASE_GET(void) \ + do { \ + long *ret; \ + \ + if (!gd->arch.plmt) { \ + ret = syscon_get_first_range(RISCV_SYSCON_PLMT); \ + if (IS_ERR(ret)) \ + return PTR_ERR(ret); \ + gd->arch.plmt = ret; \ + } \ + } while (0) + +int riscv_get_time(u64 *time) +{ + PLMT_BASE_GET(); + + *time = readq((void __iomem *)MTIME_REG(gd->arch.plmt)); + + return 0; +} + +static const struct udevice_id nds_plmt_ids[] = { + { .compatible = "riscv,plmt0", .data = RISCV_SYSCON_PLMT }, + { } +}; + +U_BOOT_DRIVER(nds_plmt) = { + .name = "nds_plmt", + .id = UCLASS_SYSCON, + .of_match = nds_plmt_ids, + .flags = DM_FLAG_PRE_RELOC, +};
Hi Rick,
V3:
+config ANDES_PLMT
- bool
- select REGMAP
- select SYSCON
- help
- void __iomem *plmt; /* plmt base address */
- RISCV_SYSCON_PLMT, /* Platform Level Machine Timer (PLMT) */
- U-Boot syscon driver for Andes's Platform Level Machine Timer (PLMT).
- The PLMT block holds memory-mapped mtime register
- associated with timer tick.
- do { \
long *ret; \
if (IS_ERR(ret)) \
- } while (0)
- PLMT_BASE_GET();
- *time = readq((void __iomem *)MTIME_REG(gd->arch.plmt));
- { .compatible = "riscv,plmt0", .data = RISCV_SYSCON_PLMT },
Would a compatible string of "andes,plmt0" be more suitable?
- .name = "nds_plmt",
nit: andes_plmt
Thanks, Lukas
- .of_match = nds_plmt_ids,
Hi Lukas
Auer, Lukas lukas.auer@aisec.fraunhofer.de 於 2019年4月1日 週一 下午5:09寫道:
Hi Rick,
V3:
+config ANDES_PLMT
bool
select REGMAP
select SYSCON
help
do { \
long *ret; \
if (IS_ERR(ret)) \
} while (0)
PLMT_BASE_GET();
.name = "nds_plmt",
nit: andes_plmt
OK I will rename it.
Thanks Rick
Thanks, Lukas
Disable ATCPIT100 SoC timer and replace by PLMT.
Signed-off-by: Rick Chen rick@andestech.com Cc: Greentime Hu greentime@andestech.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- configs/ae350_rv32_defconfig | 1 - configs/ae350_rv64_defconfig | 1 - 2 files changed, 2 deletions(-)
diff --git a/configs/ae350_rv32_defconfig b/configs/ae350_rv32_defconfig index 5837b48..e13c7de 100644 --- a/configs/ae350_rv32_defconfig +++ b/configs/ae350_rv32_defconfig @@ -33,4 +33,3 @@ CONFIG_BAUDRATE=38400 CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_ATCSPI200_SPI=y -CONFIG_ATCPIT100_TIMER=y diff --git a/configs/ae350_rv64_defconfig b/configs/ae350_rv64_defconfig index b250d3f..a41f918 100644 --- a/configs/ae350_rv64_defconfig +++ b/configs/ae350_rv64_defconfig @@ -34,4 +34,3 @@ CONFIG_BAUDRATE=38400 CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_ATCSPI200_SPI=y -CONFIG_ATCPIT100_TIMER=y
Hi Rick,
This may break bisectability, since the board won't have a working timer until the next patch. You may consider squashing them.
Other than that.
Reviewed-by: Lukas Auer lukas.auer@aisec.fraunhofer.de
Thanks, Lukas
Hi Lukas
Auer, Lukas lukas.auer@aisec.fraunhofer.de 於 2019年4月1日 週一 下午5:13寫道:
Hi Rick,
OK I will combine them as one.
Thanks Rick
Other than that.
Thanks, Lukas
Add ax25 RISC-V platform-specific Kconfig options, to include CPU and timer drivers.
Signed-off-by: Rick Chen rick@andestech.com Cc: Greentime Hu greentime@andestech.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- arch/riscv/cpu/ax25/Kconfig | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/riscv/cpu/ax25/Kconfig b/arch/riscv/cpu/ax25/Kconfig index e9dbca2..68bd4e9 100644 --- a/arch/riscv/cpu/ax25/Kconfig +++ b/arch/riscv/cpu/ax25/Kconfig @@ -1,5 +1,11 @@ config RISCV_NDS bool + select ARCH_EARLY_INIT_R + imply CPU + imply CPU_RISCV + imply RISCV_TIMER + imply ANDES_PLIC if RISCV_MMODE + imply ANDES_PLMT if RISCV_MMODE help Run U-Boot on AndeStar V5 platforms and use some specific features which are provided by Andes Technology AndeStar V5 families.
Limit the cache configuration only can be supported in M mode. It can not be manipulated in S mode.
Signed-off-by: Rick Chen rick@andestech.com Cc: Greentime Hu greentime@andestech.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- arch/riscv/cpu/ax25/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/riscv/cpu/ax25/Kconfig b/arch/riscv/cpu/ax25/Kconfig index 68bd4e9..6b4b92e 100644 --- a/arch/riscv/cpu/ax25/Kconfig +++ b/arch/riscv/cpu/ax25/Kconfig @@ -14,6 +14,7 @@ if RISCV_NDS
config RISCV_NDS_CACHE bool "AndeStar V5 families specific cache support" + depends on RISCV_MMODE help Provide Andes Technology AndeStar V5 families specific cache support.
Signed-off-by: Rick Chen rick@andestech.com Cc: Greentime Hu greentime@andestech.com --- V3: - Fix some mis-alignments. - Recovery isa string of CPU1.
arch/riscv/dts/ae350_32.dts | 81 +++++++++++++++++++++++++++++++++------------ arch/riscv/dts/ae350_64.dts | 81 +++++++++++++++++++++++++++++++++------------ 2 files changed, 118 insertions(+), 44 deletions(-)
diff --git a/arch/riscv/dts/ae350_32.dts b/arch/riscv/dts/ae350_32.dts index 0679827..2ec01a5 100644 --- a/arch/riscv/dts/ae350_32.dts +++ b/arch/riscv/dts/ae350_32.dts @@ -26,16 +26,49 @@ status = "okay"; compatible = "riscv"; riscv,isa = "rv32imafdc"; + riscv,priv-major = <1>; + riscv,priv-minor = <10>; mmu-type = "riscv,sv32"; clock-frequency = <60000000>; + i-cache-size = <0x8000>; + i-cache-line-size = <32>; d-cache-size = <0x8000>; d-cache-line-size = <32>; + next-level-cache = <&L2>; CPU0_intc: interrupt-controller { #interrupt-cells = <1>; interrupt-controller; compatible = "riscv,cpu-intc"; }; }; + CPU1: cpu@1 { + device_type = "cpu"; + reg = <1>; + status = "okay"; + compatible = "riscv"; + riscv,isa = "rv32imafdc"; + riscv,priv-major = <1>; + riscv,priv-minor = <10>; + mmu-type = "riscv,sv32"; + clock-frequency = <60000000>; + i-cache-size = <0x8000>; + i-cache-line-size = <32>; + d-cache-size = <0x8000>; + d-cache-line-size = <32>; + next-level-cache = <&L2>; + CPU1_intc: interrupt-controller { + #interrupt-cells = <1>; + interrupt-controller; + compatible = "riscv,cpu-intc"; + }; + }; + + L2: l2-cache@e0500000 { + compatible = "cache"; + cache-level = <2>; + cache-size = <0x40000>; + reg = <0x0 0xe0500000 0x0 0x40000>; + }; };
memory@0 { @@ -46,32 +79,32 @@ soc { #address-cells = <1>; #size-cells = <1>; - compatible = "andestech,riscv-ae350-soc"; + compatible = "simple-bus"; ranges;
- plic0: interrupt-controller@e4000000 { - compatible = "riscv,plic0"; - #address-cells = <1>; - #interrupt-cells = <1>; - interrupt-controller; - reg = <0xe4000000 0x2000000>; - riscv,ndev=<71>; - interrupts-extended = <&CPU0_intc 11 &CPU0_intc 9>; - }; + plic0: interrupt-controller@e4000000 { + compatible = "riscv,plic0"; + #address-cells = <1>; + #interrupt-cells = <1>; + interrupt-controller; + reg = <0xe4000000 0x2000000>; + riscv,ndev=<71>; + interrupts-extended = <&CPU0_intc 11 &CPU0_intc 9 &CPU1_intc 11 &CPU1_intc 9>; + };
- plic1: interrupt-controller@e6400000 { - compatible = "riscv,plic1"; - #address-cells = <1>; - #interrupt-cells = <1>; - interrupt-controller; - reg = <0xe6400000 0x400000>; - riscv,ndev=<1>; - interrupts-extended = <&CPU0_intc 3>; - }; + plic1: interrupt-controller@e6400000 { + compatible = "riscv,plic1"; + #address-cells = <1>; + #interrupt-cells = <1>; + interrupt-controller; + reg = <0xe6400000 0x400000>; + riscv,ndev=<2>; + interrupts-extended = <&CPU0_intc 3 &CPU1_intc 3>; + };
- plmt0@e6000000 { - compatible = "riscv,plmt0"; - interrupts-extended = <&CPU0_intc 7>; + plmt0@e6000000 { + compatible = "riscv,plmt0"; + interrupts-extended = <&CPU0_intc 7 &CPU1_intc 7>; reg = <0xe6000000 0x100000>; }; }; @@ -146,6 +179,10 @@ interrupt-parent = <&plic0>; };
+ pmu { + compatible = "riscv,base-pmu"; + }; + virtio_mmio@fe007000 { interrupts = <0x17 0x4>; interrupt-parent = <0x2>; diff --git a/arch/riscv/dts/ae350_64.dts b/arch/riscv/dts/ae350_64.dts index e48c298..cde5cde 100644 --- a/arch/riscv/dts/ae350_64.dts +++ b/arch/riscv/dts/ae350_64.dts @@ -26,16 +26,49 @@ status = "okay"; compatible = "riscv"; riscv,isa = "rv64imafdc"; + riscv,priv-major = <1>; + riscv,priv-minor = <10>; mmu-type = "riscv,sv39"; clock-frequency = <60000000>; + i-cache-size = <0x8000>; + i-cache-line-size = <32>; d-cache-size = <0x8000>; d-cache-line-size = <32>; + next-level-cache = <&L2>; CPU0_intc: interrupt-controller { #interrupt-cells = <1>; interrupt-controller; compatible = "riscv,cpu-intc"; }; }; + CPU1: cpu@1 { + device_type = "cpu"; + reg = <1>; + status = "okay"; + compatible = "riscv"; + riscv,isa = "rv64imafdc"; + riscv,priv-major = <1>; + riscv,priv-minor = <10>; + mmu-type = "riscv,sv39"; + clock-frequency = <60000000>; + i-cache-size = <0x8000>; + i-cache-line-size = <32>; + d-cache-size = <0x8000>; + d-cache-line-size = <32>; + next-level-cache = <&L2>; + CPU1_intc: interrupt-controller { + #interrupt-cells = <1>; + interrupt-controller; + compatible = "riscv,cpu-intc"; + }; + }; + + L2: l2-cache@e0500000 { + compatible = "cache"; + cache-level = <2>; + cache-size = <0x40000>; + reg = <0x0 0xe0500000 0x0 0x40000>; + }; };
memory@0 { @@ -46,32 +79,32 @@ soc { #address-cells = <2>; #size-cells = <2>; - compatible = "andestech,riscv-ae350-soc"; + compatible = "simple-bus"; ranges;
- plic0: interrupt-controller@e4000000 { - compatible = "riscv,plic0"; - #address-cells = <2>; - #interrupt-cells = <2>; - interrupt-controller; - reg = <0x0 0xe4000000 0x0 0x2000000>; - riscv,ndev=<71>; - interrupts-extended = <&CPU0_intc 11 &CPU0_intc 9>; - }; + plic0: interrupt-controller@e4000000 { + compatible = "riscv,plic0"; + #address-cells = <2>; + #interrupt-cells = <2>; + interrupt-controller; + reg = <0x0 0xe4000000 0x0 0x2000000>; + riscv,ndev=<71>; + interrupts-extended = <&CPU0_intc 11 &CPU0_intc 9 &CPU1_intc 11 &CPU1_intc 9>; + };
- plic1: interrupt-controller@e6400000 { - compatible = "riscv,plic1"; - #address-cells = <2>; - #interrupt-cells = <2>; - interrupt-controller; - reg = <0x0 0xe6400000 0x0 0x400000>; - riscv,ndev=<1>; - interrupts-extended = <&CPU0_intc 3>; - }; + plic1: interrupt-controller@e6400000 { + compatible = "riscv,plic1"; + #address-cells = <2>; + #interrupt-cells = <2>; + interrupt-controller; + reg = <0x0 0xe6400000 0x0 0x400000>; + riscv,ndev=<2>; + interrupts-extended = <&CPU0_intc 3 &CPU1_intc 3>; + };
- plmt0@e6000000 { - compatible = "riscv,plmt0"; - interrupts-extended = <&CPU0_intc 7>; + plmt0@e6000000 { + compatible = "riscv,plmt0"; + interrupts-extended = <&CPU0_intc 7 &CPU1_intc 7>; reg = <0x0 0xe6000000 0x0 0x100000>; }; }; @@ -146,6 +179,10 @@ interrupt-parent = <&plic0>; };
V3:
V3:
Signed-off-by: Rick Chen rick@andestech.com Cc: Greentime Hu greentime@andestech.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- board/AndesTech/ax25-ae350/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/AndesTech/ax25-ae350/Kconfig b/board/AndesTech/ax25-ae350/Kconfig index 44cb302..5e682b6 100644 --- a/board/AndesTech/ax25-ae350/Kconfig +++ b/board/AndesTech/ax25-ae350/Kconfig @@ -24,5 +24,6 @@ config ENV_OFFSET config BOARD_SPECIFIC_OPTIONS # dummy def_bool y select RISCV_NDS + imply SMP
endif
Hi Rick,
Patch 2
Patch 6
Changes in v2:
Looks good to me. Are you going to send PR to Tom to include SMP series in v2019.04?
Regards, Bin
Hi Bin
Bin Meng bmeng.cn@gmail.com 於 2019年4月1日 週一 下午5:01寫道:
Hi Rick,
Patch 2
Patch 6
Changes in v2:
Thanks for your review. But there seem have some suggestions from Lukas to be fixed. After that I will send PR to Tom ASAP.
Thanks Rick
Regards, Bin
Hi Bin and Lukas
Rick Chen rickchen36@gmail.com 於 2019年4月2日 週二 上午9:22寫道:
Hi Bin
Hi Rick,
Patch 2
Patch 6
Changes in v2:
I have send V4 and Lukas have reviewed it. When I try to sync to master, I found that there seem have CONFIG_DEFAULT_DEVICE_TREE failures issue in u-boot.git master. Troy have reported it actually. But u-boot-riscv.git is fine. So I am not sure if I shall sync to master now. Or I shall wait until it has been fixed.
Rick
Thanks Rick
Regards, Bin
Hi Rick,
On Wed, Apr 3, 2019 at 9:37 AM Rick Chen rickchen36@gmail.com wrote:
Hi Bin and Lukas
Hi Bin
Hi Rick,
Patch 2
Patch 6
Changes in v2:
The CONFIG_DEFAULT_DEVICE_TREE fix was reviewed by Lukas and me. I suppose it's good to send PR now?
Regards, Bin
Hi Bin
Bin Meng bmeng.cn@gmail.com 於 2019年4月4日 週四 下午9:49寫道:
Hi Rick,
Hi Bin and Lukas
Hi Bin
Hi Rick,
Patch 2
Patch 6
Changes in v2:
Yes I was on Ching-Ming festival last week. After re-sync to master and travis verification. I will send a PR right away.
Thanks Rick
Regards, Bin
Andes
Auer, Lukas
Bin Meng
Rick Chen
