[U-Boot] [PATCH] Dual-license IBM code contributions
It was brought to our attention that U-Boot contains code derived from the IBM OpenBIOS source code originally provided with some of the older PowerPC 4xx development boards. As a result, the original license of this code has been carried in the various files for a number of years in the U-Boot project.
IBM is dual-licensing the IBM code contributions already present in U-Boot under either the terms of the GNU General Public License version 2, or the original code license already present.
Signed-off-by: Josh Boyer jwboyer@linux.vnet.ibm.com
diff --git a/board/cray/L1/init.S b/board/cray/L1/init.S index 4b6b3f4..d700ea7 100644 --- a/board/cray/L1/init.S +++ b/board/cray/L1/init.S @@ -1,5 +1,9 @@ /*------------------------------------------------------------------------------+ */ /* */ +/* This source code is dual-licensed. You may use it under the terms */ +/* of the GNU General Public License version 2, or under the license */ +/* below. */ +/* */ /* This source code has been made available to you by IBM on an AS-IS */ /* basis. Anyone receiving this source is licensed under IBM */ /* copyrights to use it in any way he or she deems fit, including */ diff --git a/board/csb272/init.S b/board/csb272/init.S index ab371f2..1cfef37 100644 --- a/board/csb272/init.S +++ b/board/csb272/init.S @@ -1,4 +1,6 @@ /****************************************************************************** + * This source code is dual-licensed. You may use it under the terms of the + * GNU General Public License version 2, or under the license below. * * This source code has been made available to you by IBM on an AS-IS * basis. Anyone receiving this source is licensed under IBM diff --git a/board/csb472/init.S b/board/csb472/init.S index 4b6958a..2cf8afc 100644 --- a/board/csb472/init.S +++ b/board/csb472/init.S @@ -1,4 +1,6 @@ /****************************************************************************** + * This source code is dual-licensed. You may use it under the terms of the + * GNU General Public License version 2, or under the license below. * * This source code has been made available to you by IBM on an AS-IS * basis. Anyone receiving this source is licensed under IBM diff --git a/board/eric/init.S b/board/eric/init.S index 2304cc7..4820dd0 100644 --- a/board/eric/init.S +++ b/board/eric/init.S @@ -1,5 +1,9 @@ /*------------------------------------------------------------------------------+ */ /* */ +/* This source code is dual-licensed. You may use it under the terms */ +/* of the GNU General Public License version 2, or under the license */ +/* below. */ +/* */ /* This source code has been made available to you by IBM on an AS-IS */ /* basis. Anyone receiving this source is licensed under IBM */ /* copyrights to use it in any way he or she deems fit, including */ diff --git a/board/esd/pci405/writeibm.S b/board/esd/pci405/writeibm.S index 9f5c35b..4e319c1 100644 --- a/board/esd/pci405/writeibm.S +++ b/board/esd/pci405/writeibm.S @@ -1,5 +1,9 @@ /*------------------------------------------------------------------------------+ */ /* */ +/* This source code is dual-licensed. You may use it under the terms */ +/* of the GNU General Public License version 2, or under the license */ +/* below. */ +/* */ /* This source code has been made available to you by IBM on an AS-IS */ /* basis. Anyone receiving this source is licensed under IBM */ /* copyrights to use it in any way he or she deems fit, including */ diff --git a/board/exbitgen/init.S b/board/exbitgen/init.S index 760835a..cb54874 100644 --- a/board/exbitgen/init.S +++ b/board/exbitgen/init.S @@ -1,4 +1,6 @@ /*----------------------------------------------------------------------+ + * This source code is dual-licensed. You may use it under the terms of + * the GNU General Public License version 2, or under the license below. * * This source code has been made available to you by IBM on an AS-IS * basis. Anyone receiving this source is licensed under IBM diff --git a/board/jse/init.S b/board/jse/init.S index c564ed3..7b932b2 100644 --- a/board/jse/init.S +++ b/board/jse/init.S @@ -1,5 +1,9 @@ /*------------------------------------------------------------------------+ */ /* */ +/* This source code is dual-licensed. You may use it under the terms */ +/* of the GNU General Public License version 2, or under the license */ +/* below. */ +/* */ /* This source code has been made available to you by IBM on an AS-IS */ /* basis. Anyone receiving this source is licensed under IBM */ /* copyrights to use it in any way he or she deems fit, including */ diff --git a/board/mpl/common/pci.c b/board/mpl/common/pci.c index bfd6428..e0ba620 100644 --- a/board/mpl/common/pci.c +++ b/board/mpl/common/pci.c @@ -1,4 +1,6 @@ /*-----------------------------------------------------------------------------+ +| This source code is dual-licensed. You may use it under the terms of +| the GNU General Public License version 2, or under the license below. | | This source code has been made available to you by IBM on an AS-IS | basis. Anyone receiving this source is licensed under IBM diff --git a/board/mpl/mip405/init.S b/board/mpl/mip405/init.S index f00a871..19d9220 100644 --- a/board/mpl/mip405/init.S +++ b/board/mpl/mip405/init.S @@ -1,4 +1,6 @@ /*------------------------------------------------------------------------------+ + * This source code is dual-licensed. You may use it under the terms of + * the GNU General Public License version 2, or under the license below. * * This source code has been made available to you by IBM on an AS-IS * basis. Anyone receiving this source is licensed under IBM diff --git a/board/mpl/pip405/init.S b/board/mpl/pip405/init.S index 8384325..61f37d7 100644 --- a/board/mpl/pip405/init.S +++ b/board/mpl/pip405/init.S @@ -1,4 +1,6 @@ /*------------------------------------------------------------------------------+ + * This source code is dual-licensed. You may use it under the terms of + * the GNU General Public License version 2, or under the license below. * * This source code has been made available to you by IBM on an AS-IS * basis. Anyone receiving this source is licensed under IBM diff --git a/board/sc3/init.S b/board/sc3/init.S index e7b3c83..f97a5ea 100644 --- a/board/sc3/init.S +++ b/board/sc3/init.S @@ -4,6 +4,9 @@ * (www.eurodsn.de). It's based on the original IBM source code, so * this follows: * + * This source code is dual-licensed. You may use it under the terms of the + * GNU General Public License version 2, or under the license below. + * * This source code has been made available to you by IBM on an AS-IS * basis. Anyone receiving this source is licensed under IBM * copyrights to use it in any way he or she deems fit, including diff --git a/board/w7o/init.S b/board/w7o/init.S index 2fd84ba..902c631 100644 --- a/board/w7o/init.S +++ b/board/w7o/init.S @@ -1,4 +1,6 @@ /****************************************************************************** + * This source code is dual-licensed. You may use it under the terms of the + * GNU General Public License version 2, or under the license below. * * This source code has been made available to you by IBM on an AS-IS * basis. Anyone receiving this source is licensed under IBM diff --git a/cpu/i386/serial.c b/cpu/i386/serial.c index 8b5f8fa..e7025a3 100644 --- a/cpu/i386/serial.c +++ b/cpu/i386/serial.c @@ -26,6 +26,9 @@ /*------------------------------------------------------------------------------+ */
/* + * This source code is dual-licensed. You may use it under the terms of the + * GNU General Public License version 2, or under the license below. + * * This source code has been made available to you by IBM on an AS-IS * basis. Anyone receiving this source is licensed under IBM * copyrights to use it in any way he or she deems fit, including diff --git a/cpu/ixp/npe/miiphy.c b/cpu/ixp/npe/miiphy.c index 20fee2d..b208c51 100644 --- a/cpu/ixp/npe/miiphy.c +++ b/cpu/ixp/npe/miiphy.c @@ -1,4 +1,6 @@ /*-----------------------------------------------------------------------------+ + | This source code is dual-licensed. You may use it under the terms of the + | GNU General Public License version 2, or under the license below. | | This source code has been made available to you by IBM on an AS-IS | basis. Anyone receiving this source is licensed under IBM diff --git a/cpu/ppc4xx/4xx_pci.c b/cpu/ppc4xx/4xx_pci.c index 4b5d636..5d7d59c 100644 --- a/cpu/ppc4xx/4xx_pci.c +++ b/cpu/ppc4xx/4xx_pci.c @@ -1,4 +1,6 @@ /*-----------------------------------------------------------------------------+ + * This source code is dual-licensed. You may use it under the terms of + * the GNU General Public license version 2, or under the license below. * * This source code has been made available to you by IBM on an AS-IS * basis. Anyone receiving this source is licensed under IBM diff --git a/cpu/ppc4xx/4xx_uart.c b/cpu/ppc4xx/4xx_uart.c index c106ac2..0780624 100644 --- a/cpu/ppc4xx/4xx_uart.c +++ b/cpu/ppc4xx/4xx_uart.c @@ -22,6 +22,9 @@ */
/* + * This source code is dual-licensed. You may use it under the terms of the + * GNU General Public License version 2, or under the license below. + * * This source code has been made available to you by IBM on an AS-IS * basis. Anyone receiving this source is licensed under IBM * copyrights to use it in any way he or she deems fit, including diff --git a/cpu/ppc4xx/miiphy.c b/cpu/ppc4xx/miiphy.c index 01710e7..6a92bf8 100644 --- a/cpu/ppc4xx/miiphy.c +++ b/cpu/ppc4xx/miiphy.c @@ -1,4 +1,6 @@ /*-----------------------------------------------------------------------------+ + | This source code is dual-licensed. You may use it under the terms of the + | GNU General Public License version 2, or under the license below. | | This source code has been made available to you by IBM on an AS-IS | basis. Anyone receiving this source is licensed under IBM diff --git a/cpu/ppc4xx/start.S b/cpu/ppc4xx/start.S index 60756c3..f967d84 100644 --- a/cpu/ppc4xx/start.S +++ b/cpu/ppc4xx/start.S @@ -25,6 +25,8 @@ * MA 02111-1307 USA */ /*------------------------------------------------------------------------------+ + * This source code is dual-licensed. You may use it under the terms of the + * GNU General Public License version 2, or under the license below. * * This source code has been made available to you by IBM on an AS-IS * basis. Anyone receiving this source is licensed under IBM diff --git a/drivers/net/4xx_enet.c b/drivers/net/4xx_enet.c index c020048..329eef0 100644 --- a/drivers/net/4xx_enet.c +++ b/drivers/net/4xx_enet.c @@ -1,4 +1,6 @@ /*-----------------------------------------------------------------------------+ + * This source code is dual-licensed. You may use it under the terms of the + * GNU General Public License version 2, or under the license below. * * This source code has been made available to you by IBM on an AS-IS * basis. Anyone receiving this source is licensed under IBM diff --git a/include/405_mal.h b/include/405_mal.h index 1415cbe..1ca9429 100644 --- a/include/405_mal.h +++ b/include/405_mal.h @@ -1,5 +1,7 @@ /* include/mal.h, openbios_walnut, walnut_bios 8/6/99 08:48:40 */ /*----------------------------------------------------------------------------+ +| This source code is dual-licensed. You may use it under the terms of the +| GNU General Public License version 2, or under the license below. | | This source code has been made available to you by IBM on an AS-IS | basis. Anyone receiving this source is licensed under IBM diff --git a/include/miiphy.h b/include/miiphy.h index 32f0a61..fa33ec7 100644 --- a/include/miiphy.h +++ b/include/miiphy.h @@ -1,4 +1,6 @@ /*----------------------------------------------------------------------------+ +| This source code is dual-licensed. You may use it under the terms of the +| GNU General Public License version 2, or under the license below. | | This source code has been made available to you by IBM on an AS-IS | basis. Anyone receiving this source is licensed under IBM diff --git a/include/ppc405.h b/include/ppc405.h index a17dd35..55649e4 100644 --- a/include/ppc405.h +++ b/include/ppc405.h @@ -1,4 +1,6 @@ /*----------------------------------------------------------------------------+ +| This source code is dual-licensed. You may use it under the terms of the +| GNU General Public License version 2, or under the license below. | | This source code has been made available to you by IBM on an AS-IS | basis. Anyone receiving this source is licensed under IBM diff --git a/include/ppc440.h b/include/ppc440.h index e6dc740..7f34fda 100644 --- a/include/ppc440.h +++ b/include/ppc440.h @@ -1,4 +1,6 @@ /*----------------------------------------------------------------------------+ +| This source code is dual-licensed. You may use it under the terms of the +| GNU General Public License version 2, or under the license below. | | This source code has been made available to you by IBM on an AS-IS | basis. Anyone receiving this source is licensed under IBM diff --git a/include/ppc4xx.h b/include/ppc4xx.h index 55ff323..a9954aa 100644 --- a/include/ppc4xx.h +++ b/include/ppc4xx.h @@ -1,4 +1,6 @@ /*----------------------------------------------------------------------------+ +| This source code is dual-licensed. You may use it under the terms of +| the GNU General Public License version 2, or under the license below. | | This source code has been made available to you by IBM on an AS-IS | basis. Anyone receiving this source is licensed under IBM diff --git a/include/ppc4xx_enet.h b/include/ppc4xx_enet.h index 3e10883..7588e93 100644 --- a/include/ppc4xx_enet.h +++ b/include/ppc4xx_enet.h @@ -1,4 +1,6 @@ /*----------------------------------------------------------------------------+ +| This source code is dual-licensed. You may use it under the terms of the +| GNU General Public License version 2, or under the license below. | | This source code has been made available to you by IBM on an AS-IS | basis. Anyone receiving this source is licensed under IBM
Dear Josh Boyer,
Applied, thanks.
Josh Boyer
