[PATCH v2 0/2] ARM: dts: fix Ethernet and random MAC's on WeTek Hub/Play2
In submitting the original patches for WeTek Hub/Play2 I appear to have squashed an experimental change to place the u-boot.dtsi file on the common board dtsi, but this was incorrect and results in broken Ethernet. Patch 1 creates per-board u-boot.dtsi files to fix that. However, while the NIC is now probed correctly the current p200.c board file doesn't find the MAC in efuse and we get random MAC addresses. Patch 2 adds a fallback method for generating a MAC from the CPU serial.
Changes from v1: - Simplified p200.c changes - Drop patch 3
Christian Hewitt (2): ARM: dts: fix Ethernet on WeTek Hub/Play2 board: amlogic: add meson_generate_serial_ethaddr fallback to p200
...u-boot.dtsi => meson-gxbb-wetek-hub-u-boot.dtsi} | 0 arch/arm/dts/meson-gxbb-wetek-play2-u-boot.dtsi | 13 +++++++++++++ board/amlogic/p200/p200.c | 2 ++ 3 files changed, 15 insertions(+) rename arch/arm/dts/{meson-gxbb-wetek-u-boot.dtsi => meson-gxbb-wetek-hub-u-boot.dtsi} (100%) create mode 100644 arch/arm/dts/meson-gxbb-wetek-play2-u-boot.dtsi
Placing the snps,reset content needed for Ethernet to probe in a common uboot.dtsi results in the content not being used and broken Ethernet. Fix this by creating two board specific dtsi files with the right content.
Fixes: 67d5128df950 ("ARM: dts: add support for WeTek Hub and WeTek Play2") Signed-off-by: Christian Hewitt christianshewitt@gmail.com --- ...u-boot.dtsi => meson-gxbb-wetek-hub-u-boot.dtsi} | 0 arch/arm/dts/meson-gxbb-wetek-play2-u-boot.dtsi | 13 +++++++++++++ 2 files changed, 13 insertions(+) rename arch/arm/dts/{meson-gxbb-wetek-u-boot.dtsi => meson-gxbb-wetek-hub-u-boot.dtsi} (100%) create mode 100644 arch/arm/dts/meson-gxbb-wetek-play2-u-boot.dtsi
diff --git a/arch/arm/dts/meson-gxbb-wetek-u-boot.dtsi b/arch/arm/dts/meson-gxbb-wetek-hub-u-boot.dtsi similarity index 100% rename from arch/arm/dts/meson-gxbb-wetek-u-boot.dtsi rename to arch/arm/dts/meson-gxbb-wetek-hub-u-boot.dtsi diff --git a/arch/arm/dts/meson-gxbb-wetek-play2-u-boot.dtsi b/arch/arm/dts/meson-gxbb-wetek-play2-u-boot.dtsi new file mode 100644 index 00000000000..3743053eb9c --- /dev/null +++ b/arch/arm/dts/meson-gxbb-wetek-play2-u-boot.dtsi @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 BayLibre, SAS. + * Author: Neil Armstrong narmstrong@baylibre.com + */ + +#include "meson-gx-u-boot.dtsi" + +ðmac { + snps,reset-gpio = <&gpio GPIOZ_14 0>; + snps,reset-delays-us = <0 10000 1000000>; + snps,reset-active-low; +};
Add a fall-back method to generate ethaddr from CPU serial on p200 boards if the MAC cannot be read from efuse. This prevents random MAC addresses on the WeTek Hub/Play2 boards.
Signed-off-by: Christian Hewitt christianshewitt@gmail.com --- board/amlogic/p200/p200.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/amlogic/p200/p200.c b/board/amlogic/p200/p200.c index 7c432f9d281..3061f7a6b3c 100644 --- a/board/amlogic/p200/p200.c +++ b/board/amlogic/p200/p200.c @@ -30,6 +30,8 @@ int misc_init_r(void) mac_addr, EFUSE_MAC_SIZE); if (len == EFUSE_MAC_SIZE && is_valid_ethaddr(mac_addr)) eth_env_set_enetaddr("ethaddr", mac_addr); + else + meson_generate_serial_ethaddr(); }
if (!env_get("serial#")) {
Thanks, Applied to https://source.denx.de/u-boot/custodians/u-boot-amlogic (u-boot-amlogic)
[1/2] ARM: dts: fix Ethernet on WeTek Hub/Play2 https://source.denx.de/u-boot/custodians/u-boot-amlogic/-/commit/cac77418d6b... [2/2] board: amlogic: add meson_generate_serial_ethaddr fallback to p200 https://source.denx.de/u-boot/custodians/u-boot-amlogic/-/commit/65d5c367b00...
Christian Hewitt
Neil Armstrong
