[U-Boot] [PATCH 1/2] Blackfin: bf533-ezkit: update env location
The u-boot image has outgrown the current space and overflowed into the env sector. So move the env to the next available sector (we've already allocated the first few sectors anyways for u-boot).
Signed-off-by: Mike Frysinger vapier@gentoo.org --- include/configs/bf533-ezkit.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/include/configs/bf533-ezkit.h b/include/configs/bf533-ezkit.h index f896cb0..8342ec7 100644 --- a/include/configs/bf533-ezkit.h +++ b/include/configs/bf533-ezkit.h @@ -85,7 +85,7 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 3 #define CONFIG_SYS_MAX_FLASH_SECT 40 #define CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_ADDR 0x20020000 +#define CONFIG_ENV_ADDR 0x20030000 #define CONFIG_ENV_SECT_SIZE 0x10000 #define FLASH_TOT_SECT 40
The Linux kernel has changed the way it numbers serial ports, so update the default command line to match it.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- include/configs/bfin_adi_common.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/include/configs/bfin_adi_common.h b/include/configs/bfin_adi_common.h index 00bfc6e..0b87418 100644 --- a/include/configs/bfin_adi_common.h +++ b/include/configs/bfin_adi_common.h @@ -138,7 +138,7 @@ "uart" MK_STR(CONFIG_UART_CONSOLE) "," \ MK_STR(CONFIG_BAUDRATE) " " \ CONFIG_BOOTARGS_VIDEO \ - "console=ttyBF0," MK_STR(CONFIG_BAUDRATE) + "console=ttyBF" MK_STR(CONFIG_UART_CONSOLE) "," MK_STR(CONFIG_BAUDRATE) #if defined(CONFIG_CMD_NAND) # define NAND_ENV_SETTINGS \ "nandargs=set bootargs " CONFIG_BOOTARGS "\0" \
Mike Frysinger
