[U-Boot-Users] [PATCH 1/2] PPC4xx: Cosmetic changes
Signed-off-by: Larry Johnson lrj@acm.org ---
common/miiphyutil.c | 141 ++++++++++++++++++++++++-------------------------- cpu/ppc4xx/miiphy.c | 58 +++++++-------------- include/miiphy.h | 92 +++++++++++++++------------------ 3 files changed, 130 insertions(+), 161 deletions(-)
diff --git a/common/miiphyutil.c b/common/miiphyutil.c index c69501f..58ebc5e 100644 --- a/common/miiphyutil.c +++ b/common/miiphyutil.c @@ -49,10 +49,10 @@ struct mii_dev { struct list_head link; char *name; - int (* read)(char *devname, unsigned char addr, - unsigned char reg, unsigned short *value); - int (* write)(char *devname, unsigned char addr, - unsigned char reg, unsigned short value); + int (*read) (char *devname, unsigned char addr, + unsigned char reg, unsigned short *value); + int (*write) (char *devname, unsigned char addr, + unsigned char reg, unsigned short value); };
static struct list_head mii_devs; @@ -62,21 +62,21 @@ static struct mii_dev *current_mii; * * Initialize global data. Need to be called before any other miiphy routine. */ -void miiphy_init() +void miiphy_init () { - INIT_LIST_HEAD(&mii_devs); - current_mii = NULL; + INIT_LIST_HEAD (&mii_devs); + current_mii = NULL; }
/***************************************************************************** * * Register read and write MII access routines for the device <name>. */ -void miiphy_register(char *name, - int (* read)(char *devname, unsigned char addr, - unsigned char reg, unsigned short *value), - int (* write)(char *devname, unsigned char addr, - unsigned char reg, unsigned short value)) +void miiphy_register (char *name, + int (*read) (char *devname, unsigned char addr, + unsigned char reg, unsigned short *value), + int (*write) (char *devname, unsigned char addr, + unsigned char reg, unsigned short value)) { struct list_head *entry; struct mii_dev *new_dev; @@ -84,63 +84,64 @@ void miiphy_register(char *name, unsigned int name_len;
/* check if we have unique name */ - list_for_each(entry, &mii_devs) { - miidev = list_entry(entry, struct mii_dev, link); - if (strcmp(miidev->name, name) == 0) { - printf("miiphy_register: non unique device name '%s'\n", - name); + list_for_each (entry, &mii_devs) { + miidev = list_entry (entry, struct mii_dev, link); + if (strcmp (miidev->name, name) == 0) { + printf ("miiphy_register: non unique device name " + "'%s'\n", name); return; } }
/* allocate memory */ - name_len = strlen(name); - new_dev = (struct mii_dev *)malloc(sizeof(struct mii_dev) + name_len + 1); + name_len = strlen (name); + new_dev = + (struct mii_dev *)malloc (sizeof (struct mii_dev) + name_len + 1);
- if(new_dev == NULL) { - printf("miiphy_register: cannot allocate memory for '%s'\n", - name); + if (new_dev == NULL) { + printf ("miiphy_register: cannot allocate memory for '%s'\n", + name); return; } - memset(new_dev, 0, sizeof(struct mii_dev) + name_len); + memset (new_dev, 0, sizeof (struct mii_dev) + name_len);
/* initalize mii_dev struct fields */ - INIT_LIST_HEAD(&new_dev->link); + INIT_LIST_HEAD (&new_dev->link); new_dev->read = read; new_dev->write = write; new_dev->name = (char *)(new_dev + 1); - strncpy(new_dev->name, name, name_len); + strncpy (new_dev->name, name, name_len); new_dev->name[name_len] = '\0';
- debug("miiphy_register: added '%s', read=0x%08lx, write=0x%08lx\n", - new_dev->name, new_dev->read, new_dev->write); + debug ("miiphy_register: added '%s', read=0x%08lx, write=0x%08lx\n", + new_dev->name, new_dev->read, new_dev->write);
/* add it to the list */ - list_add_tail(&new_dev->link, &mii_devs); + list_add_tail (&new_dev->link, &mii_devs);
if (!current_mii) current_mii = new_dev; }
-int miiphy_set_current_dev(char *devname) +int miiphy_set_current_dev (char *devname) { struct list_head *entry; struct mii_dev *dev;
- list_for_each(entry, &mii_devs) { - dev = list_entry(entry, struct mii_dev, link); + list_for_each (entry, &mii_devs) { + dev = list_entry (entry, struct mii_dev, link);
- if (strcmp(devname, dev->name) == 0) { + if (strcmp (devname, dev->name) == 0) { current_mii = dev; return 0; } }
- printf("No such device: %s\n", devname); + printf ("No such device: %s\n", devname); return 1; }
-char *miiphy_get_current_dev() +char *miiphy_get_current_dev () { if (current_mii) return current_mii->name; @@ -156,8 +157,8 @@ char *miiphy_get_current_dev() * Returns: * 0 on success */ -int miiphy_read(char *devname, unsigned char addr, unsigned char reg, - unsigned short *value) +int miiphy_read (char *devname, unsigned char addr, unsigned char reg, + unsigned short *value) { struct list_head *entry; struct mii_dev *dev; @@ -165,22 +166,22 @@ int miiphy_read(char *devname, unsigned char addr, unsigned char reg, int read_ret = 0;
if (!devname) { - printf("NULL device name!\n"); + printf ("NULL device name!\n"); return 1; }
- if (strcmp(devname, dev->name) == 0) { + if (strcmp (devname, dev->name) == 0) { found_dev = 1; - read_ret = dev->read(devname, addr, reg, value); + read_ret = dev->read (devname, addr, reg, value); break; } }
if (found_dev == 0) - printf("No such device: %s\n", devname); + printf ("No such device: %s\n", devname);
return ((found_dev) ? read_ret : 1); } @@ -193,8 +194,8 @@ int miiphy_read(char *devname, unsigned char addr, unsigned char reg, * Returns: * 0 on success */ -int miiphy_write(char *devname, unsigned char addr, unsigned char reg, - unsigned short value) +int miiphy_write (char *devname, unsigned char addr, unsigned char reg, + unsigned short value) { struct list_head *entry; struct mii_dev *dev; @@ -202,22 +203,22 @@ int miiphy_write(char *devname, unsigned char addr, unsigned char reg, int write_ret = 0;
- if (strcmp(devname, dev->name) == 0) { + if (strcmp (devname, dev->name) == 0) { found_dev = 1; - write_ret = dev->write(devname, addr, reg, value); + write_ret = dev->write (devname, addr, reg, value); break; } }
return ((found_dev) ? write_ret : 1); } @@ -226,23 +227,22 @@ int miiphy_write(char *devname, unsigned char addr, unsigned char reg, * * Print out list of registered MII capable devices. */ -void miiphy_listdev(void) +void miiphy_listdev (void) { struct list_head *entry; struct mii_dev *dev;
- puts("MII devices: "); - list_for_each(entry, &mii_devs) { - dev = list_entry(entry, struct mii_dev, link); - printf("'%s' ", dev->name); + puts ("MII devices: "); + list_for_each (entry, &mii_devs) { + dev = list_entry (entry, struct mii_dev, link); + printf ("'%s' ", dev->name); } - puts("\n"); + puts ("\n");
if (current_mii) - printf("Current device: '%s'\n", current_mii->name); + printf ("Current device: '%s'\n", current_mii->name); }
- /***************************************************************************** * * Read the OUI, manufacture's model number, and revision number. @@ -254,9 +254,7 @@ void miiphy_listdev(void) * Returns: * 0 on success */ -int miiphy_info (char *devname, - unsigned char addr, - unsigned int *oui, +int miiphy_info (char *devname, unsigned char addr, unsigned int *oui, unsigned char *model, unsigned char *rev) { unsigned int reg = 0; @@ -288,13 +286,12 @@ int miiphy_info (char *devname, #ifdef DEBUG printf ("PHY_PHYIDR[1,2] @ 0x%x = 0x%08x\n", addr, reg); #endif - *oui = ( reg >> 10); - *model = (unsigned char) ((reg >> 4) & 0x0000003F); - *rev = (unsigned char) ( reg & 0x0000000F); + *oui = (reg >> 10); + *model = (unsigned char)((reg >> 4) & 0x0000003F); + *rev = (unsigned char)(reg & 0x0000000F); return (0); }
- /***************************************************************************** * * Reset the PHY. @@ -345,7 +342,6 @@ int miiphy_reset (char *devname, unsigned char addr) return (0); }
- /***************************************************************************** * * Determine the ethernet speed (10/100). @@ -359,7 +355,8 @@ int miiphy_speed (char *devname, unsigned char addr) printf ("PHY 1000BT Status read failed\n"); } else { if (reg != 0xFFFF) { - if ((reg & (PHY_1000BTSR_1000FD | PHY_1000BTSR_1000HD)) !=0) { + if ((reg & (PHY_1000BTSR_1000FD | PHY_1000BTSR_1000HD)) + != 0) { return (_1000BASET); } } @@ -393,7 +390,6 @@ int miiphy_speed (char *devname, unsigned char addr)
- /***************************************************************************** * * Determine full/half duplex. @@ -406,9 +402,9 @@ int miiphy_duplex (char *devname, unsigned char addr) if (miiphy_read (devname, addr, PHY_1000BTSR, ®)) { printf ("PHY 1000BT Status read failed\n"); } else { - if ( (reg != 0xFFFF) && - (reg & (PHY_1000BTSR_1000FD | PHY_1000BTSR_1000HD)) ) { - if ((reg & PHY_1000BTSR_1000FD) !=0) { + if ((reg != 0xFFFF) && + (reg & (PHY_1000BTSR_1000FD | PHY_1000BTSR_1000HD))) { + if ((reg & PHY_1000BTSR_1000FD) != 0) { return (FULL); } else { return (HALF); @@ -455,7 +451,7 @@ int miiphy_link (char *devname, unsigned char addr) unsigned short reg;
/* dummy read; needed to latch some phys */ - (void)miiphy_read(devname, addr, PHY_BMSR, ®); + (void)miiphy_read (devname, addr, PHY_BMSR, ®); if (miiphy_read (devname, addr, PHY_BMSR, ®)) { puts ("PHY_BMSR read failed, assuming no link\n"); return (0); @@ -469,5 +465,4 @@ int miiphy_link (char *devname, unsigned char addr) } } #endif - #endif /* CONFIG_MII */ diff --git a/cpu/ppc4xx/miiphy.c b/cpu/ppc4xx/miiphy.c index 6b98025..2fa1b57 100644 --- a/cpu/ppc4xx/miiphy.c +++ b/cpu/ppc4xx/miiphy.c @@ -27,19 +27,6 @@ | | Author: Mark Wisner | - | Change Activity- - | - | Date Description of Change BY - | --------- --------------------- --- - | 05-May-99 Created MKW - | 01-Jul-99 Changed clock setting of sta_reg from 66Mhz to 50Mhz to - | better match OPB speed. Also modified delay times. JWB - | 29-Jul-99 Added Full duplex support MKW - | 24-Aug-99 Removed printf from dp83843_duplex() JWB - | 19-Jul-00 Ported to esd cpci405 sr - | 23-Dec-03 Ported from miiphy.c to 440GX Travis Sawyer TBS - | travis.sawyer@sandburst.com - | +-----------------------------------------------------------------------------*/
#include <common.h> @@ -60,7 +47,6 @@ void miiphy_dump (char *devname, unsigned char addr) unsigned long i; unsigned short data;
- for (i = 0; i < 0x1A; i++) { if (miiphy_read (devname, addr, i, &data)) { printf ("read error for reg %lx\n", i); @@ -75,7 +61,6 @@ void miiphy_dump (char *devname, unsigned char addr) } /* end for loop */ } /* end dump */
- /***********************************************************/ /* (Re)start autonegotiation */ /***********************************************************/ @@ -102,7 +87,6 @@ int phy_setup_aneg (char *devname, unsigned char addr) return 0; }
- /***********************************************************/ /* read a phy reg and return the value with a rc */ /***********************************************************/ @@ -145,21 +129,20 @@ unsigned int miiphy_getemac_offset (void) #endif }
- -int emac4xx_miiphy_read (char *devname, unsigned char addr, - unsigned char reg, unsigned short *value) +int emac4xx_miiphy_read (char *devname, unsigned char addr, unsigned char reg, + unsigned short *value) { unsigned long sta_reg; /* STA scratch area */ unsigned long i; unsigned long emac_reg;
- emac_reg = miiphy_getemac_offset (); /* see if it is ready for 1000 nsec */ i = 0;
/* see if it is ready for sec */ - while ((in32 (EMAC_STACR + emac_reg) & EMAC_STACR_OC) == EMAC_STACR_OC_MASK) { + while ((in32 (EMAC_STACR + emac_reg) & EMAC_STACR_OC) == + EMAC_STACR_OC_MASK) { udelay (7); if (i > 5) { #ifdef ET_DEBUG @@ -175,10 +158,10 @@ int emac4xx_miiphy_read (char *devname, unsigned char addr, /* set clock (50Mhz) and read flags */ #if defined(CONFIG_440GX) || defined(CONFIG_440SPE) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) -#if defined(CONFIG_IBM_EMAC4_V4) /* EMAC4 V4 changed bit setting */ - sta_reg = (sta_reg & ~EMAC_STACR_OP_MASK) | EMAC_STACR_READ; +#if defined(CONFIG_IBM_EMAC4_V4) /* EMAC4 V4 changed bit setting */ + sta_reg = (sta_reg & ~EMAC_STACR_OP_MASK) | EMAC_STACR_READ; #else - sta_reg |= EMAC_STACR_READ; + sta_reg |= EMAC_STACR_READ; #endif #else sta_reg = (sta_reg | EMAC_STACR_READ) & ~EMAC_STACR_CLK_100MHZ; @@ -198,7 +181,7 @@ int emac4xx_miiphy_read (char *devname, unsigned char addr,
sta_reg = in32 (EMAC_STACR + emac_reg); #ifdef ET_DEBUG - printf ("a21: read : EMAC_STACR=0x%0x\n", sta_reg); /* test-only */ + printf ("a21: read : EMAC_STACR=0x%0x\n", sta_reg); /* test-only */ #endif i = 0; while ((sta_reg & EMAC_STACR_OC) == EMAC_STACR_OC_MASK) { @@ -216,19 +199,17 @@ int emac4xx_miiphy_read (char *devname, unsigned char addr, return -1; }
- *value = *(short *) (&sta_reg); + *value = *(short *)(&sta_reg); return 0;
- } /* phy_read */
- /***********************************************************/ /* write a phy reg and return the value with a rc */ /***********************************************************/
-int emac4xx_miiphy_write (char *devname, unsigned char addr, - unsigned char reg, unsigned short value) +int emac4xx_miiphy_write (char *devname, unsigned char addr, unsigned char reg, + unsigned short value) { unsigned long sta_reg; /* STA scratch area */ unsigned long i; @@ -238,7 +219,8 @@ int emac4xx_miiphy_write (char *devname, unsigned char addr, /* see if it is ready for 1000 nsec */ i = 0;
- while ((in32 (EMAC_STACR + emac_reg) & EMAC_STACR_OC) == EMAC_STACR_OC_MASK) { + while ((in32 (EMAC_STACR + emac_reg) & EMAC_STACR_OC) == + EMAC_STACR_OC_MASK) { if (i > 5) return -1; udelay (7); @@ -249,10 +231,10 @@ int emac4xx_miiphy_write (char *devname, unsigned char addr, /* set clock (50Mhz) and read flags */ #if defined(CONFIG_440GX) || defined(CONFIG_440SPE) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) -#if defined(CONFIG_IBM_EMAC4_V4) /* EMAC4 V4 changed bit setting */ - sta_reg = (sta_reg & ~EMAC_STACR_OP_MASK) | EMAC_STACR_WRITE; +#if defined(CONFIG_IBM_EMAC4_V4) /* EMAC4 V4 changed bit setting */ + sta_reg = (sta_reg & ~EMAC_STACR_OP_MASK) | EMAC_STACR_WRITE; #else - sta_reg |= EMAC_STACR_WRITE; + sta_reg |= EMAC_STACR_WRITE; #endif #else sta_reg = (sta_reg | EMAC_STACR_WRITE) & ~EMAC_STACR_CLK_100MHZ; @@ -263,8 +245,8 @@ int emac4xx_miiphy_write (char *devname, unsigned char addr, !defined(CONFIG_440EPX) && !defined(CONFIG_440GRX) sta_reg = sta_reg | CONFIG_PHY_CLK_FREQ; /* Set clock frequency (PLB freq. dependend) */ #endif - sta_reg = sta_reg | ((unsigned long) addr << 5);/* Phy address */ - sta_reg = sta_reg | EMAC_STACR_OC_MASK; /* new IBM emac v4 */ + sta_reg = sta_reg | ((unsigned long)addr << 5); /* Phy address */ + sta_reg = sta_reg | EMAC_STACR_OC_MASK; /* new IBM emac v4 */ memcpy (&sta_reg, &value, 2); /* put in data */
out32 (EMAC_STACR + emac_reg, sta_reg); @@ -273,7 +255,7 @@ int emac4xx_miiphy_write (char *devname, unsigned char addr, i = 0; sta_reg = in32 (EMAC_STACR + emac_reg); #ifdef ET_DEBUG - printf ("a31: read : EMAC_STACR=0x%0x\n", sta_reg); /* test-only */ + printf ("a31: read : EMAC_STACR=0x%0x\n", sta_reg); /* test-only */ #endif while ((sta_reg & EMAC_STACR_OC) == EMAC_STACR_OC_MASK) { udelay (7); @@ -290,4 +272,4 @@ int emac4xx_miiphy_write (char *devname, unsigned char addr, return -1; return 0;
-} /* phy_write */ +} /* phy_write */ diff --git a/include/miiphy.h b/include/miiphy.h index 71716b0..42f2ad0 100644 --- a/include/miiphy.h +++ b/include/miiphy.h @@ -26,56 +26,48 @@ | | Author: Mark Wisner | -| Change Activity- -| -| Date Description of Change BY -| --------- --------------------- --- -| 04-May-99 Created MKW -| 07-Jul-99 Added full duplex support MKW -| 08-Sep-01 Tweaks gvb -| +----------------------------------------------------------------------------*/ #ifndef _miiphy_h_ #define _miiphy_h_
#include <net.h>
-int miiphy_read(char *devname, unsigned char addr, unsigned char reg, - unsigned short *value); -int miiphy_write(char *devname, unsigned char addr, unsigned char reg, - unsigned short value); -int miiphy_info(char *devname, unsigned char addr, unsigned int *oui, - unsigned char *model, unsigned char *rev); -int miiphy_reset(char *devname, unsigned char addr); -int miiphy_speed(char *devname, unsigned char addr); -int miiphy_duplex(char *devname, unsigned char addr); +int miiphy_read (char *devname, unsigned char addr, unsigned char reg, + unsigned short *value); +int miiphy_write (char *devname, unsigned char addr, unsigned char reg, + unsigned short value); +int miiphy_info (char *devname, unsigned char addr, unsigned int *oui, + unsigned char *model, unsigned char *rev); +int miiphy_reset (char *devname, unsigned char addr); +int miiphy_speed (char *devname, unsigned char addr); +int miiphy_duplex (char *devname, unsigned char addr); #ifdef CFG_FAULT_ECHO_LINK_DOWN -int miiphy_link(char *devname, unsigned char addr); +int miiphy_link (char *devname, unsigned char addr); #endif
-void miiphy_init(void); +void miiphy_init (void);
-void miiphy_register(char *devname, - int (* read)(char *devname, unsigned char addr, - unsigned char reg, unsigned short *value), - int (* write)(char *devname, unsigned char addr, - unsigned char reg, unsigned short value)); +void miiphy_register (char *devname, + int (*read) (char *devname, unsigned char addr, + unsigned char reg, unsigned short *value), + int (*write) (char *devname, unsigned char addr, + unsigned char reg, unsigned short value));
-int miiphy_set_current_dev(char *devname); -char *miiphy_get_current_dev(void); +int miiphy_set_current_dev (char *devname); +char *miiphy_get_current_dev (void);
-void miiphy_listdev(void); +void miiphy_listdev (void);
#define BB_MII_DEVNAME "bbmii"
int bb_miiphy_read (char *devname, unsigned char addr, - unsigned char reg, unsigned short *value); + unsigned char reg, unsigned short *value); int bb_miiphy_write (char *devname, unsigned char addr, - unsigned char reg, unsigned short value); + unsigned char reg, unsigned short value);
/* phy seed setup */ #define AUTO 99 -#define _1000BASET 1000 +#define _1000BASET 1000 #define _100BASET 100 #define _10BASET 10 #define HALF 22 @@ -90,9 +82,9 @@ int bb_miiphy_write (char *devname, unsigned char addr, #define PHY_ANLPAR 0x05 #define PHY_ANER 0x06 #define PHY_ANNPTR 0x07 -#define PHY_ANLPNP 0x08 -#define PHY_1000BTCR 0x09 -#define PHY_1000BTSR 0x0A +#define PHY_ANLPNP 0x08 +#define PHY_1000BTCR 0x09 +#define PHY_1000BTSR 0x0A #define PHY_PHYSTS 0x10 #define PHY_MIPSCR 0x11 #define PHY_MIPGSR 0x12 @@ -115,10 +107,10 @@ int bb_miiphy_write (char *devname, unsigned char addr, #define PHY_BMCR_DPLX 0x0100 #define PHY_BMCR_COL_TST 0x0080
-#define PHY_BMCR_SPEED_MASK 0x2040 -#define PHY_BMCR_1000_MBPS 0x0040 -#define PHY_BMCR_100_MBPS 0x2000 -#define PHY_BMCR_10_MBPS 0x0000 +#define PHY_BMCR_SPEED_MASK 0x2040 +#define PHY_BMCR_1000_MBPS 0x0040 +#define PHY_BMCR_100_MBPS 0x2000 +#define PHY_BMCR_10_MBPS 0x0000
/* phy BMSR */ #define PHY_BMSR_100T4 0x8000 @@ -143,18 +135,18 @@ int bb_miiphy_write (char *devname, unsigned char addr, #define PHY_ANLPAR_TX 0x0080 #define PHY_ANLPAR_10FD 0x0040 #define PHY_ANLPAR_10 0x0020 -#define PHY_ANLPAR_100 0x0380 /* we can run at 100 */ - -#define PHY_ANLPAR_PSB_MASK 0x001f -#define PHY_ANLPAR_PSB_802_3 0x0001 -#define PHY_ANLPAR_PSB_802_9 0x0002 - -/* PHY_1000BTSR */ -#define PHY_1000BTSR_MSCF 0x8000 -#define PHY_1000BTSR_MSCR 0x4000 -#define PHY_1000BTSR_LRS 0x2000 -#define PHY_1000BTSR_RRS 0x1000 -#define PHY_1000BTSR_1000FD 0x0800 -#define PHY_1000BTSR_1000HD 0x0400 +#define PHY_ANLPAR_100 0x0380 /* we can run at 100 */ + +#define PHY_ANLPAR_PSB_MASK 0x001f +#define PHY_ANLPAR_PSB_802_3 0x0001 +#define PHY_ANLPAR_PSB_802_9 0x0002 + +/* phy 1000BTSR */ +#define PHY_1000BTSR_MSCF 0x8000 +#define PHY_1000BTSR_MSCR 0x4000 +#define PHY_1000BTSR_LRS 0x2000 +#define PHY_1000BTSR_RRS 0x1000 +#define PHY_1000BTSR_1000FD 0x0800 +#define PHY_1000BTSR_1000HD 0x0400
#endif
Hi Larry,
common/miiphyutil.c | 141++++++++++++++++++++++++-------------------------- cpu/ppc4xx/miiphy.c | 58 +++++++-------------- include/miiphy.h | 92 +++++++++++++++------------------ 3 files changed, 130 insertions(+), 161 deletions(-)
It is a little problematic, if you combine patches for a "common" networking file like common/miiphyutil.c and board/platform specific code in one patch. This is because one should get picked up by the networking custodian (Ben Warren) and the other by myself.
I see that both changes belong together, but you should nevertheless split them up into separate patches.
Same holds for the next patch of course too.
Best regards, Stefan
Larry Johnson
Stefan Roese
