[PATCH] Disable timer check in file loading
The u-boot efi console service registers a timer to poll the keyboard input in every 50ns. In the efi block io service, this timer is evaluated on each block read, and since the timer interval is much less than the time needed to reading out a block (32kB) from the disk, the keyboard polling is therefore in the wake of each block read.
Unfortunately USB keyboard spends too much time in polling. In my test usb_kbd_poll_for_event costs 40ms in usb_kbd_testc() to test if a character is in the queue. In combination with the number of blocks to be read from the disk, the extra amound of time delayed could be around 30 seconds to load linux and initrd.
For that matters, the timer check is disabled in file loading to speed it up. The consequence would be losing the keystroke during the time file is loading, but that is acceptable IMHO.
Downstream bug reference: https://bugzilla.suse.com/show_bug.cgi?id=1171222
Signed-off-by: Michael Chang mchang@suse.com --- lib/efi_loader/efi_disk.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index 307d5d759b..d090110b06 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -15,6 +15,7 @@ #include <log.h> #include <part.h> #include <malloc.h> +#include <watchdog.h>
struct efi_system_partition efi_system_partition;
@@ -103,8 +104,7 @@ static efi_status_t efi_disk_rw_blocks(struct efi_block_io *this, else n = blk_dwrite(desc, lba, blocks, buffer);
- /* We don't do interrupts, so check for timers cooperatively */ - efi_timer_check(); + WATCHDOG_RESET();
EFI_PRINT("n=%lx blocks=%x\n", n, blocks);
The event is triggered every 5000 ns not 50 ns. See lib/efi_loader/efi_console.c:1309. The SetTimer() parameter is in multiples of 100 ns. UEFI spec 2.9 has this sentence: "TimerRelative: The event is to be signaled in TriggerTime 100ns units."
I can't imagine that Linux is that slow. Why is U-Boot so slow? Please, try to fix that code.
Disabling would mean that programs like iPXE cannot react to keyboard input to interrupt a file transfer.
Best regards
Heinrich
WATCHDOG_RESET();
Indeed the value is mistakenly taken. Thanks to pointing this out and will correct that in followed version.
Well I'm by no means a usb expert who is able to troubleshooting this myself so disabling the timer check is all I can do to mitigate the problem firstly.
I certainly agree to investigate into usb_kbd_testc to understand what's happening under the hood, but please bear with me if that takes longer than expected to provide a solution/expaination along the way. For that I would have to seek for help internally from the company.
Ok. fair enough.
Thanks a lot for review.
Regards, Michael
Best regards
Heinrich
WATCHDOG_RESET();
Michael Chang
