[PATCH v2 0/2] fix auto-generated boot options
This series aims to get aligned to the EDK II reference implementation for auto-generated boot options, and tries to address the following issue. https://source.denx.de/u-boot/custodians/u-boot-efi/-/issues/13
This series is based on the efi-next-20231217 tag.
[Changelog] v1 -> v2 - fix make htmldocs error - fix bootmenu python test failure
Masahisa Kojima (2): efi_loader: auto-generate boot option for each blkio device efi_loader: auto-generate removable media boot option first
lib/efi_loader/efi_bootmgr.c | 121 +++++++++++++++++++++++++++-------- 1 file changed, 94 insertions(+), 27 deletions(-)
Current efibootmgr auto-generates the boot option for all disks and partitions installing EFI_SIMPLE_FILE_SYSTEM_PROTOCOL, while EDK II reference implementation auto-generates the boot option for all devices installing EFI_BLOCK_IO_PROTOCOL with eliminating logical partitions.
This commit modifies the efibootmgr to get aligned to EDK II.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- lib/efi_loader/efi_bootmgr.c | 94 +++++++++++++++++++++++++++--------- 1 file changed, 71 insertions(+), 23 deletions(-)
diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index 56d97f2382..747f75ee82 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -560,6 +560,50 @@ err: return ret; }
+/** + * try_load_from_media() - load file from media + * + * @file_path: file path + * @handle: pointer to handle for newly installed image + * + * If @file_path contains a file name, load the file. + * If @file_path does not have a file name, search the architecture-specific + * default file and load it. + * TODO: If the FilePathList[0] device does not support + * EFI_SIMPLE_FILE_SYSTEM_PROTOCOL but supports EFI_BLOCK_IO_PROTOCOL, + * call EFI_BOOT_SERVICES.ConnectController() + * TODO: FilePathList[0] device supports EFI_SIMPLE_FILE_SYSTEM_PROTOCOL + * not based on EFI_BLOCK_IO_PROTOCOL + * + * Return: status code + */ +static efi_status_t try_load_from_media(struct efi_device_path *file_path, + efi_handle_t *handle) +{ + efi_handle_t h; + efi_status_t ret = EFI_SUCCESS; + struct efi_device_path *rem, *dp = NULL; + struct efi_device_path *final_dp = file_path; + + h = efi_dp_find_obj(file_path, &efi_block_io_guid, &rem); + if (h) { + if (rem->type == DEVICE_PATH_TYPE_END) { + /* no file name present, try default file */ + ret = check_disk_has_default_file(h->dev, &dp); + if (ret != EFI_SUCCESS) + return ret; + + final_dp = dp; + } + } + + ret = EFI_CALL(efi_load_image(true, efi_root, final_dp, NULL, 0, handle)); + + efi_free_pool(dp); + + return ret; +} + /** * try_load_entry() - try to load image for boot option * @@ -594,7 +638,6 @@ static efi_status_t try_load_entry(u16 n, efi_handle_t *handle, }
if (lo.attributes & LOAD_OPTION_ACTIVE) { - struct efi_device_path *file_path; u32 attributes;
log_debug("trying to load "%ls" from %pD\n", lo.label, @@ -611,10 +654,7 @@ static efi_status_t try_load_entry(u16 n, efi_handle_t *handle, else ret = EFI_LOAD_ERROR; } else { - file_path = expand_media_path(lo.file_path); - ret = EFI_CALL(efi_load_image(true, efi_root, file_path, - NULL, 0, handle)); - efi_free_pool(file_path); + ret = try_load_from_media(lo.file_path, handle); } if (ret != EFI_SUCCESS) { log_warning("Loading %ls '%ls' failed\n", @@ -748,19 +788,19 @@ error: * efi_bootmgr_enumerate_boot_option() - enumerate the possible bootable media * * @opt: pointer to the media boot option structure - * @volume_handles: pointer to the efi handles + * @handles: pointer to the efi handles * @count: number of efi handle * Return: status code */ static efi_status_t efi_bootmgr_enumerate_boot_option(struct eficonfig_media_boot_option *opt, - efi_handle_t *volume_handles, - efi_status_t count) + efi_handle_t *handles, + efi_uintn_t *count) { - u32 i; + u32 i, num = 0; struct efi_handler *handler; efi_status_t ret = EFI_SUCCESS;
- for (i = 0; i < count; i++) { + for (i = 0; i < *count; i++) { u16 *p; u16 dev_name[BOOTMENU_DEVICE_NAME_MAX]; char *optional_data; @@ -768,8 +808,15 @@ static efi_status_t efi_bootmgr_enumerate_boot_option(struct eficonfig_media_boo char buf[BOOTMENU_DEVICE_NAME_MAX]; struct efi_device_path *device_path; struct efi_device_path *short_dp; + struct efi_block_io *blkio; + + ret = efi_search_protocol(handles[i], &efi_block_io_guid, &handler); + blkio = handler->protocol_interface;
- ret = efi_search_protocol(volume_handles[i], &efi_guid_device_path, &handler); + if (blkio->media->logical_partition) + continue; + + ret = efi_search_protocol(handles[i], &efi_guid_device_path, &handler); if (ret != EFI_SUCCESS) continue; ret = efi_protocol_open(handler, (void **)&device_path, @@ -777,7 +824,7 @@ static efi_status_t efi_bootmgr_enumerate_boot_option(struct eficonfig_media_boo if (ret != EFI_SUCCESS) continue;
- ret = efi_disk_get_device_name(volume_handles[i], buf, BOOTMENU_DEVICE_NAME_MAX); + ret = efi_disk_get_device_name(handles[i], buf, BOOTMENU_DEVICE_NAME_MAX); if (ret != EFI_SUCCESS) continue;
@@ -801,17 +848,20 @@ static efi_status_t efi_bootmgr_enumerate_boot_option(struct eficonfig_media_boo * to store guid, instead of realloc the load_option. */ lo.optional_data = "1234567"; - opt[i].size = efi_serialize_load_option(&lo, (u8 **)&opt[i].lo); - if (!opt[i].size) { + opt[num].size = efi_serialize_load_option(&lo, (u8 **)&opt[num].lo); + if (!opt[num].size) { ret = EFI_OUT_OF_RESOURCES; goto out; } /* set the guid */ - optional_data = (char *)opt[i].lo + (opt[i].size - u16_strsize(u"1234567")); + optional_data = (char *)opt[num].lo + (opt[num].size - u16_strsize(u"1234567")); memcpy(optional_data, &efi_guid_bootmenu_auto_generated, sizeof(efi_guid_t)); + num++; }
out: + *count = num; + return ret; }
@@ -1040,8 +1090,7 @@ efi_status_t efi_bootmgr_delete_boot_option(u16 boot_index) /** * efi_bootmgr_update_media_device_boot_option() - generate the media device boot option * - * This function enumerates all devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL - * and generate the bootmenu entries. + * This function enumerates all BlockIo devices and add the boot option for it. * This function also provide the BOOT#### variable maintenance for * the media device entries. * - Automatically create the BOOT#### variable for the newly detected device, @@ -1057,13 +1106,13 @@ efi_status_t efi_bootmgr_update_media_device_boot_option(void) u32 i; efi_status_t ret; efi_uintn_t count; - efi_handle_t *volume_handles = NULL; + efi_handle_t *handles = NULL; struct eficonfig_media_boot_option *opt = NULL;
ret = efi_locate_handle_buffer_int(BY_PROTOCOL, - &efi_simple_file_system_protocol_guid, + &efi_block_io_guid, NULL, &count, - (efi_handle_t **)&volume_handles); + (efi_handle_t **)&handles); if (ret != EFI_SUCCESS) goto out;
@@ -1073,8 +1122,7 @@ efi_status_t efi_bootmgr_update_media_device_boot_option(void) goto out; }
- /* enumerate all devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL */ - ret = efi_bootmgr_enumerate_boot_option(opt, volume_handles, count); + ret = efi_bootmgr_enumerate_boot_option(opt, handles, &count); if (ret != EFI_SUCCESS) goto out;
@@ -1122,7 +1170,7 @@ out: free(opt[i].lo); } free(opt); - efi_free_pool(volume_handles); + efi_free_pool(handles);
if (ret == EFI_NOT_FOUND) return EFI_SUCCESS;
Kojima-san
- try_load_entry() - try to load image for boot option
u32 attributes;
NULL, 0, handle));
} if (ret != EFI_SUCCESS) { log_warning("Loading %ls '%ls' failed\n",ret = try_load_from_media(lo.file_path, handle);
- efi_bootmgr_enumerate_boot_option() - enumerate the possible bootable media
- @opt: pointer to the media boot option structure
- @volume_handles: pointer to the efi handles
- @handles: pointer to the efi handles
- @count: number of efi handle
- Return: status code
efi_status_t count)
efi_uintn_t *count)
- u32 i;
- u32 i, num = 0; struct efi_handler *handler; efi_status_t ret = EFI_SUCCESS;
- for (i = 0; i < *count; i++) { u16 *p; u16 dev_name[BOOTMENU_DEVICE_NAME_MAX]; char *optional_data;
continue;
if (ret != EFI_SUCCESS) continue; ret = efi_protocol_open(handler, (void **)&device_path,ret = efi_search_protocol(handles[i], &efi_guid_device_path, &handler);
if (ret != EFI_SUCCESS) continue;ret = efi_disk_get_device_name(handles[i], buf, BOOTMENU_DEVICE_NAME_MAX);
if (!opt[i].size) {
I am a bit lost here. Why are we using 'num' instead of 'i'? The opt variable contains all media boot options with a block_io_protocol right? Aren't we going to copy the wrong load options in optional_data if we don't use 'i'?
memcpy(optional_data, &efi_guid_bootmenu_auto_generated, sizeof(efi_guid_t));optional_data = (char *)opt[num].lo + (opt[num].size - u16_strsize(u"1234567"));
}num++;
out:
- *count = num;
- return ret;
Thanks /Ilias
Hi Ilias,
On Thu, 28 Dec 2023 at 22:14, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Kojima-san
struct efi_device_path *file_path; u32 attributes; log_debug("trying to load \"%ls\" from %pD\n", lo.label,
NULL, 0, handle));
efi_status_t count)
efi_uintn_t *count)
u32 i;
continue;
if (!opt[i].size) {
opt[] array is a container of valid boot options with a block_io_protocol to be auto-generated by efi bootmgr. handles[] array contains all block_io_protocol efi handles.
With this patch, we ignore the logical partition, opt[] array does not contain the boot options of logical partitions. So 'num' instead of 'i' is correct here.
Thanks, Masahisa Kojima
num++; }
out:
*count = num;
return ret;
Thanks /Ilias
- try_load_from_media() - load file from media
- @file_path: file path
- @handle: pointer to handle for newly installed image
Please, use the same description as in try_load_entry():
on return handle for the newly installed image
- If @file_path contains a file name, load the file.
- If @file_path does not have a file name, search the architecture-specific
- default file and load it.
- TODO: If the FilePathList[0] device does not support
- EFI_SIMPLE_FILE_SYSTEM_PROTOCOL but supports EFI_BLOCK_IO_PROTOCOL,
- call EFI_BOOT_SERVICES.ConnectController()
- TODO: FilePathList[0] device supports EFI_SIMPLE_FILE_SYSTEM_PROTOCOL
- not based on EFI_BLOCK_IO_PROTOCOL
%s/handle/handle_img/
or h_img
- efi_handle_t h;
%s/h/handle_blkdev/
or h_blkdev
- efi_status_t ret = EFI_SUCCESS;
- struct efi_device_path *rem, *dp = NULL;
- struct efi_device_path *final_dp = file_path;
- h = efi_dp_find_obj(file_path, &efi_block_io_guid, &rem);
- if (h) {
check_disk_has_default_file() does not only check for a default file path , i.e. EFI/BOOT/BOO<ARCH>.EFI, but will check for a given file path, if provided. In a later patch we should rename this function to something less misleading.
return ret;
final_dp = dp;
- ret = EFI_CALL(efi_load_image(true, efi_root, final_dp, NULL, 0, handle));
- efi_free_pool(dp);
- return ret;
u32 attributes;
NULL, 0, handle));
%s/efi_bootmgr_enumerate_boot_option/efi_bootmgr_enumerate_boot_options/
%s/efi/EFI/
"pointer to the efi handles" could be handles for anything.
%s/pointer to the efi handles/pointer to block device handles/
We should move the call to LocateBufferHandle into this function as the caller does not use handles.
On entry number of handles to block devices. On exit number of boot options.
efi_status_t count)
{efi_uintn_t *count)
- u32 i;
continue;
if (!opt[i].size) {
} /* set the guid */if (!opt[num].size) { ret = EFI_OUT_OF_RESOURCES; goto out;
num++;
out:
*count = num;
return ret; }
- efi_bootmgr_update_media_device_boot_option() - generate the media device boot option
- This function enumerates all devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL
- and generate the bootmenu entries.
- This function enumerates all BlockIo devices and add the boot option for it.
- This function also provide the BOOT#### variable maintenance for
- the media device entries.
This is the call that should be moved to efi_bootmgr_enumerate_boot_options().
- ret = gg(opt, volume_handles, count);
- ret = efi_bootmgr_enumerate_boot_option(opt, handles, &count);
%s/, handles//
- efi_free_pool(handles);
To be moved to efi_bootmgr_enumerate_boot_options().
Best regards
Heinrich
Hi Heinrich,
OK.
OK.
or h_img
efi_handle_t h;
%s/h/handle_blkdev/
OK.
or h_blkdev
if (h) {
OK. I will include a renaming patch in this series.
return ret;
final_dp = dp;
efi_free_pool(dp);
return ret;
NULL, 0, handle));
OK.
%s/efi/EFI/
OK.
But no_handles is required in the caller(efi_bootmgr_update_media_device_boot_option) to allocate an opt array. opt = calloc(count, sizeof(struct eficonfig_media_boot_option));
OK.
efi_status_t count)
u32 i;
continue;
if (!opt[i].size) {
num++; }
out:
*count = num;
return ret;
efi_handle_t *handles = NULL; struct eficonfig_media_boot_option *opt = NULL; ret = efi_locate_handle_buffer_int(BY_PROTOCOL,
no_handles(count) is required to allocate an opt array. So let me keep efi_locate_handle_buffer_int() call here.
%s/, handles//
Let me keep it as is.
Best regards
Heinrich
This commit auto-generates the boot option for removable block io devices followed by fixed block io devices. This is what EDK II reference implementation does.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- lib/efi_loader/efi_bootmgr.c | 35 +++++++++++++++++++++++++++-------- 1 file changed, 27 insertions(+), 8 deletions(-)
diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index 747f75ee82..a146428a65 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -584,7 +584,6 @@ static efi_status_t try_load_from_media(struct efi_device_path *file_path, efi_status_t ret = EFI_SUCCESS; struct efi_device_path *rem, *dp = NULL; struct efi_device_path *final_dp = file_path; - h = efi_dp_find_obj(file_path, &efi_block_io_guid, &rem); if (h) { if (rem->type == DEVICE_PATH_TYPE_END) { @@ -788,15 +787,19 @@ error: * efi_bootmgr_enumerate_boot_option() - enumerate the possible bootable media * * @opt: pointer to the media boot option structure + * @index: index of the opt array to store the boot option * @handles: pointer to the efi handles * @count: number of efi handle + * @removable: flag to parse removable only * Return: status code */ static efi_status_t efi_bootmgr_enumerate_boot_option(struct eficonfig_media_boot_option *opt, + efi_uintn_t index, efi_handle_t *handles, - efi_uintn_t *count) + efi_uintn_t *count, + bool removable) { - u32 i, num = 0; + u32 i, num = index; struct efi_handler *handler; efi_status_t ret = EFI_SUCCESS;
@@ -816,6 +819,9 @@ static efi_status_t efi_bootmgr_enumerate_boot_option(struct eficonfig_media_boo if (blkio->media->logical_partition) continue;
+ if (removable != (blkio->media->removable_media != 0)) + continue; + ret = efi_search_protocol(handles[i], &efi_guid_device_path, &handler); if (ret != EFI_SUCCESS) continue; @@ -857,6 +863,9 @@ static efi_status_t efi_bootmgr_enumerate_boot_option(struct eficonfig_media_boo optional_data = (char *)opt[num].lo + (opt[num].size - u16_strsize(u"1234567")); memcpy(optional_data, &efi_guid_bootmenu_auto_generated, sizeof(efi_guid_t)); num++; + + if (num >= *count) + break; }
out: @@ -1105,7 +1114,7 @@ efi_status_t efi_bootmgr_update_media_device_boot_option(void) { u32 i; efi_status_t ret; - efi_uintn_t count; + efi_uintn_t count, num, total; efi_handle_t *handles = NULL; struct eficonfig_media_boot_option *opt = NULL;
@@ -1122,22 +1131,32 @@ efi_status_t efi_bootmgr_update_media_device_boot_option(void) goto out; }
- ret = efi_bootmgr_enumerate_boot_option(opt, handles, &count); + /* parse removable block io followed by fixed block io */ + num = count; + ret = efi_bootmgr_enumerate_boot_option(opt, 0, handles, &num, true); if (ret != EFI_SUCCESS) goto out;
+ total = num; + num = count; + ret = efi_bootmgr_enumerate_boot_option(opt, total, handles, &num, false); + if (ret != EFI_SUCCESS) + goto out; + + total = num; + /* * System hardware configuration may vary depending on the user setup. * The boot option is automatically added by the bootmenu. * If the device is not attached to the system, the boot option needs * to be deleted. */ - ret = efi_bootmgr_delete_invalid_boot_option(opt, count); + ret = efi_bootmgr_delete_invalid_boot_option(opt, total); if (ret != EFI_SUCCESS) goto out;
/* add non-existent boot option */ - for (i = 0; i < count; i++) { + for (i = 0; i < total; i++) { u32 boot_index; u16 var_name[9];
@@ -1166,7 +1185,7 @@ efi_status_t efi_bootmgr_update_media_device_boot_option(void)
out: if (opt) { - for (i = 0; i < count; i++) + for (i = 0; i < total; i++) free(opt[i].lo); } free(opt);
Ilias Apalodimas
Masahisa Kojima
