[U-Boot] [PATCH 0/9] ARM: uniphier: UniPhier changes for v2017.03-rc1
Mostly cleanups of SoC init code.
Masahiro Yamada (9): ARM: uniphier: remove unneeded argument of uniphier_ld20_pll_init() ARM: uniphier: split out UMC clock enable ARM: uniphier: refactor MEMCONF init code ARM: uniphier: refactor SBC init code ARM: uniphier: refactor Support Card init code ARM: uniphier: make BCU init into void function ARM: uniphier: refactor board_init() ARM: uniphier: refactor spl_init_board() ARM: uniphier: move SBC and Support Card init code to U-Boot proper
arch/arm/mach-uniphier/Makefile | 10 +- arch/arm/mach-uniphier/bcu/bcu-ld4.c | 4 +- arch/arm/mach-uniphier/bcu/bcu-sld3.c | 4 +- arch/arm/mach-uniphier/board_init.c | 237 +++++++++++++-------- arch/arm/mach-uniphier/clk/Makefile | 18 +- .../clk/{early-clk-ld11.c => clk-dram-ld11.c} | 8 +- .../clk/{early-clk-ld20.c => clk-dram-ld20.c} | 8 +- .../clk/{early-clk-pro5.c => clk-dram-pro5.c} | 9 +- .../clk/{early-clk-pxs2.c => clk-dram-pxs2.c} | 14 +- .../clk/{early-clk-ld4.c => clk-dram-sld3.c} | 9 +- arch/arm/mach-uniphier/clk/clk-early-ld11.c | 21 ++ arch/arm/mach-uniphier/clk/clk-early-sld3.c | 30 +++ arch/arm/mach-uniphier/clk/dpll-pro5.c | 6 + arch/arm/mach-uniphier/clk/dpll-pxs2.c | 6 + arch/arm/mach-uniphier/clk/pll-ld20.c | 4 +- arch/arm/mach-uniphier/dram/Makefile | 2 + arch/arm/mach-uniphier/dram/umc-pro5.c | 12 ++ arch/arm/mach-uniphier/dram/umc-sld3.c | 6 + arch/arm/mach-uniphier/init.h | 56 ++--- arch/arm/mach-uniphier/init/Makefile | 15 -- arch/arm/mach-uniphier/init/init-ld11.c | 63 ------ arch/arm/mach-uniphier/init/init-ld20.c | 62 ------ arch/arm/mach-uniphier/init/init-ld4.c | 59 ----- arch/arm/mach-uniphier/init/init-pro4.c | 56 ----- arch/arm/mach-uniphier/init/init-pro5.c | 42 ---- arch/arm/mach-uniphier/init/init-pxs2.c | 50 ----- arch/arm/mach-uniphier/init/init-sld3.c | 49 ----- arch/arm/mach-uniphier/init/init-sld8.c | 59 ----- arch/arm/mach-uniphier/init/init.c | 71 ------ arch/arm/mach-uniphier/memconf.c | 163 ++++++++++++++ arch/arm/mach-uniphier/memconf/Makefile | 9 - arch/arm/mach-uniphier/memconf/memconf-pxs2.c | 68 ------ arch/arm/mach-uniphier/memconf/memconf-sld3.c | 60 ------ arch/arm/mach-uniphier/memconf/memconf.c | 107 ---------- arch/arm/mach-uniphier/micro-support-card.c | 7 +- arch/arm/mach-uniphier/micro-support-card.h | 5 - arch/arm/mach-uniphier/sbc/Makefile | 17 +- arch/arm/mach-uniphier/sbc/sbc-admulti.c | 53 ----- arch/arm/mach-uniphier/sbc/sbc-ld11.c | 25 +++ arch/arm/mach-uniphier/sbc/sbc-ld4.c | 6 +- arch/arm/mach-uniphier/sbc/sbc-pxs2.c | 6 +- .../arm/mach-uniphier/sbc/{sbc-savepin.c => sbc.c} | 36 +++- arch/arm/mach-uniphier/spl_board_init.c | 185 ++++++++++++++++ 43 files changed, 713 insertions(+), 1024 deletions(-) rename arch/arm/mach-uniphier/clk/{early-clk-ld11.c => clk-dram-ld11.c} (74%) rename arch/arm/mach-uniphier/clk/{early-clk-ld20.c => clk-dram-ld20.c} (78%) rename arch/arm/mach-uniphier/clk/{early-clk-pro5.c => clk-dram-pro5.c} (76%) rename arch/arm/mach-uniphier/clk/{early-clk-pxs2.c => clk-dram-pxs2.c} (70%) rename arch/arm/mach-uniphier/clk/{early-clk-ld4.c => clk-dram-sld3.c} (69%) create mode 100644 arch/arm/mach-uniphier/clk/clk-early-ld11.c create mode 100644 arch/arm/mach-uniphier/clk/clk-early-sld3.c create mode 100644 arch/arm/mach-uniphier/clk/dpll-pro5.c create mode 100644 arch/arm/mach-uniphier/clk/dpll-pxs2.c create mode 100644 arch/arm/mach-uniphier/dram/umc-pro5.c create mode 100644 arch/arm/mach-uniphier/dram/umc-sld3.c delete mode 100644 arch/arm/mach-uniphier/init/Makefile delete mode 100644 arch/arm/mach-uniphier/init/init-ld11.c delete mode 100644 arch/arm/mach-uniphier/init/init-ld20.c delete mode 100644 arch/arm/mach-uniphier/init/init-ld4.c delete mode 100644 arch/arm/mach-uniphier/init/init-pro4.c delete mode 100644 arch/arm/mach-uniphier/init/init-pro5.c delete mode 100644 arch/arm/mach-uniphier/init/init-pxs2.c delete mode 100644 arch/arm/mach-uniphier/init/init-sld3.c delete mode 100644 arch/arm/mach-uniphier/init/init-sld8.c delete mode 100644 arch/arm/mach-uniphier/init/init.c create mode 100644 arch/arm/mach-uniphier/memconf.c delete mode 100644 arch/arm/mach-uniphier/memconf/Makefile delete mode 100644 arch/arm/mach-uniphier/memconf/memconf-pxs2.c delete mode 100644 arch/arm/mach-uniphier/memconf/memconf-sld3.c delete mode 100644 arch/arm/mach-uniphier/memconf/memconf.c delete mode 100644 arch/arm/mach-uniphier/sbc/sbc-admulti.c create mode 100644 arch/arm/mach-uniphier/sbc/sbc-ld11.c rename arch/arm/mach-uniphier/sbc/{sbc-savepin.c => sbc.c} (58%) create mode 100644 arch/arm/mach-uniphier/spl_board_init.c
At first, we thought the LD20 PLL setting would be board dependent, but this argument turned out unneeded after all.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/mach-uniphier/board_init.c | 8 +------- arch/arm/mach-uniphier/clk/pll-ld20.c | 4 +--- arch/arm/mach-uniphier/init.h | 2 +- 3 files changed, 3 insertions(+), 11 deletions(-)
diff --git a/arch/arm/mach-uniphier/board_init.c b/arch/arm/mach-uniphier/board_init.c index 8c7864c..4cab7fe 100644 --- a/arch/arm/mach-uniphier/board_init.c +++ b/arch/arm/mach-uniphier/board_init.c @@ -58,14 +58,8 @@ static void uniphier_nand_pin_init(bool cs2)
int board_init(void) { - const struct uniphier_board_data *bd; - led_puts("U0");
- bd = uniphier_get_board_param(); - if (!bd) - return -ENODEV; - switch (uniphier_get_soc_type()) { #if defined(CONFIG_ARCH_UNIPHIER_SLD3) case SOC_UNIPHIER_SLD3: @@ -147,7 +141,7 @@ int board_init(void) sg_set_pinsel(153, 14, 8, 4); /* XIRQ4 -> XIRQ4 */ sg_set_iectrl(153); led_puts("U1"); - uniphier_ld20_pll_init(bd); + uniphier_ld20_pll_init(); uniphier_ld20_clk_init(); cci500_init(2); break; diff --git a/arch/arm/mach-uniphier/clk/pll-ld20.c b/arch/arm/mach-uniphier/clk/pll-ld20.c index 8ad6883..121a369 100644 --- a/arch/arm/mach-uniphier/clk/pll-ld20.c +++ b/arch/arm/mach-uniphier/clk/pll-ld20.c @@ -11,7 +11,7 @@ #include "../sc64-regs.h" #include "pll.h"
-int uniphier_ld20_pll_init(const struct uniphier_board_data *bd) +void uniphier_ld20_pll_init(void) { uniphier_ld20_sscpll_init(SC_CPLLCTRL, UNIPHIER_PLL_FREQ_DEFAULT, 0, 4); /* do nothing for SPLL */ @@ -36,6 +36,4 @@ int uniphier_ld20_pll_init(const struct uniphier_board_data *bd)
uniphier_ld20_dspll_init(SC_VPLL8KCTRL); uniphier_ld20_dspll_init(SC_A2PLLCTRL); - - return 0; } diff --git a/arch/arm/mach-uniphier/init.h b/arch/arm/mach-uniphier/init.h index f3f9e54..af74dd8 100644 --- a/arch/arm/mach-uniphier/init.h +++ b/arch/arm/mach-uniphier/init.h @@ -105,7 +105,7 @@ void uniphier_sld3_pll_init(void); void uniphier_ld4_pll_init(void); void uniphier_pro4_pll_init(void); void uniphier_ld11_pll_init(void); -int uniphier_ld20_pll_init(const struct uniphier_board_data *bd); +void uniphier_ld20_pll_init(void);
void uniphier_ld4_clk_init(void); void uniphier_pro4_clk_init(void);
The clock enable bits for UMC are more SoC-specific than for the other hardware blocks. Separate the UMC clocks and the other clocks for better code reuse across SoCs.
arch/arm/mach-uniphier/clk/Makefile | 18 ++++++------- .../clk/{early-clk-ld11.c => clk-dram-ld11.c} | 8 +----- .../clk/{early-clk-ld20.c => clk-dram-ld20.c} | 8 +----- .../clk/{early-clk-pro5.c => clk-dram-pro5.c} | 9 ++----- .../clk/{early-clk-pxs2.c => clk-dram-pxs2.c} | 14 +--------- .../clk/{early-clk-ld4.c => clk-dram-sld3.c} | 9 ++----- arch/arm/mach-uniphier/clk/clk-early-ld11.c | 21 +++++++++++++++ arch/arm/mach-uniphier/clk/clk-early-sld3.c | 30 ++++++++++++++++++++++ arch/arm/mach-uniphier/init.h | 13 ++++++---- arch/arm/mach-uniphier/init/init-ld11.c | 3 ++- arch/arm/mach-uniphier/init/init-ld20.c | 3 ++- arch/arm/mach-uniphier/init/init-ld4.c | 3 ++- arch/arm/mach-uniphier/init/init-pro4.c | 3 ++- arch/arm/mach-uniphier/init/init-pro5.c | 3 ++- arch/arm/mach-uniphier/init/init-pxs2.c | 3 ++- arch/arm/mach-uniphier/init/init-sld3.c | 3 ++- arch/arm/mach-uniphier/init/init-sld8.c | 3 ++- 17 files changed, 91 insertions(+), 63 deletions(-) rename arch/arm/mach-uniphier/clk/{early-clk-ld11.c => clk-dram-ld11.c} (74%) rename arch/arm/mach-uniphier/clk/{early-clk-ld20.c => clk-dram-ld20.c} (78%) rename arch/arm/mach-uniphier/clk/{early-clk-pro5.c => clk-dram-pro5.c} (76%) rename arch/arm/mach-uniphier/clk/{early-clk-pxs2.c => clk-dram-pxs2.c} (70%) rename arch/arm/mach-uniphier/clk/{early-clk-ld4.c => clk-dram-sld3.c} (69%) create mode 100644 arch/arm/mach-uniphier/clk/clk-early-ld11.c create mode 100644 arch/arm/mach-uniphier/clk/clk-early-sld3.c
diff --git a/arch/arm/mach-uniphier/clk/Makefile b/arch/arm/mach-uniphier/clk/Makefile index 95f433e..765660f 100644 --- a/arch/arm/mach-uniphier/clk/Makefile +++ b/arch/arm/mach-uniphier/clk/Makefile @@ -4,15 +4,15 @@
ifdef CONFIG_SPL_BUILD
-obj-$(CONFIG_ARCH_UNIPHIER_SLD3) += early-clk-ld4.o dpll-sld3.o -obj-$(CONFIG_ARCH_UNIPHIER_LD4) += early-clk-ld4.o dpll-ld4.o -obj-$(CONFIG_ARCH_UNIPHIER_PRO4) += early-clk-ld4.o dpll-pro4.o -obj-$(CONFIG_ARCH_UNIPHIER_SLD8) += early-clk-ld4.o dpll-sld8.o -obj-$(CONFIG_ARCH_UNIPHIER_PRO5) += early-clk-pro5.o -obj-$(CONFIG_ARCH_UNIPHIER_PXS2) += early-clk-pxs2.o -obj-$(CONFIG_ARCH_UNIPHIER_LD6B) += early-clk-pxs2.o -obj-$(CONFIG_ARCH_UNIPHIER_LD11) += early-clk-ld11.o dpll-ld11.o -obj-$(CONFIG_ARCH_UNIPHIER_LD20) += early-clk-ld20.o dpll-ld20.o +obj-$(CONFIG_ARCH_UNIPHIER_SLD3) += clk-early-sld3.o clk-dram-sld3.o dpll-sld3.o +obj-$(CONFIG_ARCH_UNIPHIER_LD4) += clk-early-sld3.o clk-dram-sld3.o dpll-ld4.o +obj-$(CONFIG_ARCH_UNIPHIER_PRO4) += clk-early-sld3.o clk-dram-sld3.o dpll-pro4.o +obj-$(CONFIG_ARCH_UNIPHIER_SLD8) += clk-early-sld3.o clk-dram-sld3.o dpll-sld8.o +obj-$(CONFIG_ARCH_UNIPHIER_PRO5) += clk-early-sld3.o clk-dram-pro5.o +obj-$(CONFIG_ARCH_UNIPHIER_PXS2) += clk-early-sld3.o clk-dram-pxs2.o +obj-$(CONFIG_ARCH_UNIPHIER_LD6B) += clk-early-sld3.o clk-dram-pxs2.o +obj-$(CONFIG_ARCH_UNIPHIER_LD11) += clk-early-ld11.o clk-dram-ld11.o dpll-ld11.o +obj-$(CONFIG_ARCH_UNIPHIER_LD20) += clk-early-ld11.o clk-dram-ld20.o dpll-ld20.o
else
diff --git a/arch/arm/mach-uniphier/clk/early-clk-ld11.c b/arch/arm/mach-uniphier/clk/clk-dram-ld11.c similarity index 74% rename from arch/arm/mach-uniphier/clk/early-clk-ld11.c rename to arch/arm/mach-uniphier/clk/clk-dram-ld11.c index c94d83c..95bd9e6 100644 --- a/arch/arm/mach-uniphier/clk/early-clk-ld11.c +++ b/arch/arm/mach-uniphier/clk/clk-dram-ld11.c @@ -10,7 +10,7 @@ #include "../init.h" #include "../sc64-regs.h"
-int uniphier_ld11_early_clk_init(const struct uniphier_board_data *bd) +void uniphier_ld11_dram_clk_init(void) { u32 tmp;
@@ -20,13 +20,7 @@ int uniphier_ld11_early_clk_init(const struct uniphier_board_data *bd) writel(tmp, SC_RSTCTRL7);
/* provide clocks */ - tmp = readl(SC_CLKCTRL4); - tmp |= SC_CLKCTRL4_PERI; - writel(tmp, SC_CLKCTRL4); - tmp = readl(SC_CLKCTRL7); tmp |= SC_CLKCTRL7_UMC31 | SC_CLKCTRL7_UMC30; writel(tmp, SC_CLKCTRL7); - - return 0; } diff --git a/arch/arm/mach-uniphier/clk/early-clk-ld20.c b/arch/arm/mach-uniphier/clk/clk-dram-ld20.c similarity index 78% rename from arch/arm/mach-uniphier/clk/early-clk-ld20.c rename to arch/arm/mach-uniphier/clk/clk-dram-ld20.c index 5201a55..2b1bf32 100644 --- a/arch/arm/mach-uniphier/clk/early-clk-ld20.c +++ b/arch/arm/mach-uniphier/clk/clk-dram-ld20.c @@ -9,7 +9,7 @@ #include "../init.h" #include "../sc64-regs.h"
-int uniphier_ld20_early_clk_init(const struct uniphier_board_data *bd) +void uniphier_ld20_dram_clk_init(void) { u32 tmp;
@@ -21,14 +21,8 @@ int uniphier_ld20_early_clk_init(const struct uniphier_board_data *bd) writel(tmp, SC_RSTCTRL7);
/* provide clocks */ - tmp = readl(SC_CLKCTRL4); - tmp |= SC_CLKCTRL4_PERI; - writel(tmp, SC_CLKCTRL4); - tmp = readl(SC_CLKCTRL7); tmp |= SC_CLKCTRL7_UMCSB | SC_CLKCTRL7_UMC32 | SC_CLKCTRL7_UMC31 | SC_CLKCTRL7_UMC30; writel(tmp, SC_CLKCTRL7); - - return 0; } diff --git a/arch/arm/mach-uniphier/clk/early-clk-pro5.c b/arch/arm/mach-uniphier/clk/clk-dram-pro5.c similarity index 76% rename from arch/arm/mach-uniphier/clk/early-clk-pro5.c rename to arch/arm/mach-uniphier/clk/clk-dram-pro5.c index c41a8ea..b8410d2 100644 --- a/arch/arm/mach-uniphier/clk/early-clk-pro5.c +++ b/arch/arm/mach-uniphier/clk/clk-dram-pro5.c @@ -9,7 +9,7 @@ #include "../init.h" #include "../sc-regs.h"
-int uniphier_pro5_early_clk_init(const struct uniphier_board_data *bd) +void uniphier_pro5_dram_clk_init(void) { u32 tmp;
@@ -24,17 +24,12 @@ int uniphier_pro5_early_clk_init(const struct uniphier_board_data *bd) SC_RSTCTRL4_NRST_UMCA1 | SC_RSTCTRL4_NRST_UMCA0 | SC_RSTCTRL4_NRST_UMC31 | SC_RSTCTRL4_NRST_UMC30; writel(tmp, SC_RSTCTRL4); - readl(SC_RSTCTRL); /* dummy read */ + readl(SC_RSTCTRL4); /* dummy read */
/* provide clocks */ - tmp = readl(SC_CLKCTRL); - tmp |= SC_CLKCTRL_CEN_SBC | SC_CLKCTRL_CEN_PERI; - writel(tmp, SC_CLKCTRL); tmp = readl(SC_CLKCTRL4); tmp |= SC_CLKCTRL4_CEN_UMCSB | SC_CLKCTRL4_CEN_UMC1 | SC_CLKCTRL4_CEN_UMC0; writel(tmp, SC_CLKCTRL4); readl(SC_CLKCTRL4); /* dummy read */ - - return 0; } diff --git a/arch/arm/mach-uniphier/clk/early-clk-pxs2.c b/arch/arm/mach-uniphier/clk/clk-dram-pxs2.c similarity index 70% rename from arch/arm/mach-uniphier/clk/early-clk-pxs2.c rename to arch/arm/mach-uniphier/clk/clk-dram-pxs2.c index 665ecd5..8d26971 100644 --- a/arch/arm/mach-uniphier/clk/early-clk-pxs2.c +++ b/arch/arm/mach-uniphier/clk/clk-dram-pxs2.c @@ -11,17 +11,11 @@ #include "../init.h" #include "../sc-regs.h"
-int uniphier_pxs2_early_clk_init(const struct uniphier_board_data *bd) +void uniphier_pxs2_dram_clk_init(void) { u32 tmp;
/* deassert reset */ - if (spl_boot_device() != BOOT_DEVICE_NAND) { - tmp = readl(SC_RSTCTRL); - tmp &= ~SC_RSTCTRL_NRST_NAND; - writel(tmp, SC_RSTCTRL); - }; - tmp = readl(SC_RSTCTRL4); tmp |= SC_RSTCTRL4_NRST_UMCSB | SC_RSTCTRL4_NRST_UMCA2 | SC_RSTCTRL4_NRST_UMCA1 | SC_RSTCTRL4_NRST_UMCA0 | @@ -31,15 +25,9 @@ int uniphier_pxs2_early_clk_init(const struct uniphier_board_data *bd) readl(SC_RSTCTRL4); /* dummy read */
/* provide clocks */ - tmp = readl(SC_CLKCTRL); - tmp |= SC_CLKCTRL_CEN_SBC | SC_CLKCTRL_CEN_PERI; - writel(tmp, SC_CLKCTRL); - tmp = readl(SC_CLKCTRL4); tmp |= SC_CLKCTRL4_CEN_UMCSB | SC_CLKCTRL4_CEN_UMC2 | SC_CLKCTRL4_CEN_UMC1 | SC_CLKCTRL4_CEN_UMC0; writel(tmp, SC_CLKCTRL4); readl(SC_CLKCTRL4); /* dummy read */ - - return 0; } diff --git a/arch/arm/mach-uniphier/clk/early-clk-ld4.c b/arch/arm/mach-uniphier/clk/clk-dram-sld3.c similarity index 69% rename from arch/arm/mach-uniphier/clk/early-clk-ld4.c rename to arch/arm/mach-uniphier/clk/clk-dram-sld3.c index b6e8b64..2781038 100644 --- a/arch/arm/mach-uniphier/clk/early-clk-ld4.c +++ b/arch/arm/mach-uniphier/clk/clk-dram-sld3.c @@ -11,24 +11,19 @@ #include "../init.h" #include "../sc-regs.h"
-int uniphier_ld4_early_clk_init(const struct uniphier_board_data *bd) +void uniphier_sld3_dram_clk_init(void) { u32 tmp;
/* deassert reset */ tmp = readl(SC_RSTCTRL); - tmp |= SC_RSTCTRL_NRST_UMC1 | SC_RSTCTRL_NRST_UMC0; - if (spl_boot_device() != BOOT_DEVICE_NAND) - tmp &= ~SC_RSTCTRL_NRST_NAND; writel(tmp, SC_RSTCTRL); readl(SC_RSTCTRL); /* dummy read */
/* provide clocks */ tmp = readl(SC_CLKCTRL); - tmp |= SC_CLKCTRL_CEN_UMC | SC_CLKCTRL_CEN_SBC | SC_CLKCTRL_CEN_PERI; + tmp |= SC_CLKCTRL_CEN_UMC; writel(tmp, SC_CLKCTRL); readl(SC_CLKCTRL); /* dummy read */ - - return 0; } diff --git a/arch/arm/mach-uniphier/clk/clk-early-ld11.c b/arch/arm/mach-uniphier/clk/clk-early-ld11.c new file mode 100644 index 0000000..783889f --- /dev/null +++ b/arch/arm/mach-uniphier/clk/clk-early-ld11.c @@ -0,0 +1,21 @@ +/* + * Copyright (C) 2016 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <linux/io.h> + +#include "../init.h" +#include "../sc64-regs.h" + +void uniphier_ld11_early_clk_init(void) +{ + u32 tmp; + + /* provide clocks */ + tmp = readl(SC_CLKCTRL4); + tmp |= SC_CLKCTRL4_PERI; + writel(tmp, SC_CLKCTRL4); +} diff --git a/arch/arm/mach-uniphier/clk/clk-early-sld3.c b/arch/arm/mach-uniphier/clk/clk-early-sld3.c new file mode 100644 index 0000000..00aa7ee --- /dev/null +++ b/arch/arm/mach-uniphier/clk/clk-early-sld3.c @@ -0,0 +1,30 @@ +/* + * Copyright (C) 2011-2015 Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <spl.h> +#include <linux/io.h> + +#include "../init.h" +#include "../sc-regs.h" + +void uniphier_sld3_early_clk_init(void) +{ + u32 tmp; + + /* deassert reset */ + if (spl_boot_device() != BOOT_DEVICE_NAND) { + tmp = readl(SC_RSTCTRL); + tmp &= ~SC_RSTCTRL_NRST_NAND; + writel(tmp, SC_RSTCTRL); + }; + + /* provide clocks */ + tmp = readl(SC_CLKCTRL); + tmp |= SC_CLKCTRL_CEN_SBC | SC_CLKCTRL_CEN_PERI; + writel(tmp, SC_CLKCTRL); + readl(SC_CLKCTRL); /* dummy read */ +} diff --git a/arch/arm/mach-uniphier/init.h b/arch/arm/mach-uniphier/init.h index af74dd8..327fa8b 100644 --- a/arch/arm/mach-uniphier/init.h +++ b/arch/arm/mach-uniphier/init.h @@ -88,11 +88,14 @@ int uniphier_sld8_dpll_init(const struct uniphier_board_data *bd); int uniphier_ld11_dpll_init(const struct uniphier_board_data *bd); int uniphier_ld20_dpll_init(const struct uniphier_board_data *bd);
-int uniphier_ld4_early_clk_init(const struct uniphier_board_data *bd); -int uniphier_pro5_early_clk_init(const struct uniphier_board_data *bd); -int uniphier_pxs2_early_clk_init(const struct uniphier_board_data *bd); -int uniphier_ld11_early_clk_init(const struct uniphier_board_data *bd); -int uniphier_ld20_early_clk_init(const struct uniphier_board_data *bd); +void uniphier_sld3_early_clk_init(void); +void uniphier_ld11_early_clk_init(void); + +void uniphier_sld3_dram_clk_init(void); +void uniphier_pro5_dram_clk_init(void); +void uniphier_pxs2_dram_clk_init(void); +void uniphier_ld11_dram_clk_init(void); +void uniphier_ld20_dram_clk_init(void);
int uniphier_ld4_umc_init(const struct uniphier_board_data *bd); int uniphier_pro4_umc_init(const struct uniphier_board_data *bd); diff --git a/arch/arm/mach-uniphier/init/init-ld11.c b/arch/arm/mach-uniphier/init/init-ld11.c index fdb2838..9d43a13 100644 --- a/arch/arm/mach-uniphier/init/init-ld11.c +++ b/arch/arm/mach-uniphier/init/init-ld11.c @@ -29,7 +29,8 @@ int uniphier_ld11_init(const struct uniphier_board_data *bd)
led_puts("L1");
- uniphier_ld11_early_clk_init(bd); + uniphier_ld11_early_clk_init(); + uniphier_ld11_dram_clk_init();
led_puts("L2");
diff --git a/arch/arm/mach-uniphier/init/init-ld20.c b/arch/arm/mach-uniphier/init/init-ld20.c index 37b860a..6702430 100644 --- a/arch/arm/mach-uniphier/init/init-ld20.c +++ b/arch/arm/mach-uniphier/init/init-ld20.c @@ -30,7 +30,8 @@ int uniphier_ld20_init(const struct uniphier_board_data *bd)
led_puts("L1");
- uniphier_ld20_early_clk_init(bd); + uniphier_ld11_early_clk_init(); + uniphier_ld20_dram_clk_init();
led_puts("L2");
diff --git a/arch/arm/mach-uniphier/init/init-ld4.c b/arch/arm/mach-uniphier/init/init-ld4.c index 2f4c60d..5f4880c 100644 --- a/arch/arm/mach-uniphier/init/init-ld4.c +++ b/arch/arm/mach-uniphier/init/init-ld4.c @@ -31,7 +31,8 @@ int uniphier_ld4_init(const struct uniphier_board_data *bd)
led_puts("L1");
- uniphier_ld4_early_clk_init(bd); + uniphier_sld3_early_clk_init(); + uniphier_sld3_dram_clk_init();
led_puts("L2");
diff --git a/arch/arm/mach-uniphier/init/init-pro4.c b/arch/arm/mach-uniphier/init/init-pro4.c index 2825150..e57eb86 100644 --- a/arch/arm/mach-uniphier/init/init-pro4.c +++ b/arch/arm/mach-uniphier/init/init-pro4.c @@ -28,7 +28,8 @@ int uniphier_pro4_init(const struct uniphier_board_data *bd)
led_puts("L1");
led_puts("L2");
diff --git a/arch/arm/mach-uniphier/init/init-pro5.c b/arch/arm/mach-uniphier/init/init-pro5.c index c809ae7..ea53dcf 100644 --- a/arch/arm/mach-uniphier/init/init-pro5.c +++ b/arch/arm/mach-uniphier/init/init-pro5.c @@ -24,7 +24,8 @@ int uniphier_pro5_init(const struct uniphier_board_data *bd)
led_puts("L1");
- uniphier_pro5_early_clk_init(bd); + uniphier_sld3_early_clk_init(); + uniphier_pro5_dram_clk_init();
led_puts("L2");
diff --git a/arch/arm/mach-uniphier/init/init-pxs2.c b/arch/arm/mach-uniphier/init/init-pxs2.c index 5e07db1..7cdf4bd 100644 --- a/arch/arm/mach-uniphier/init/init-pxs2.c +++ b/arch/arm/mach-uniphier/init/init-pxs2.c @@ -28,7 +28,8 @@ int uniphier_pxs2_init(const struct uniphier_board_data *bd)
led_puts("L1");
- uniphier_pxs2_early_clk_init(bd); + uniphier_sld3_early_clk_init(); + uniphier_pxs2_dram_clk_init();
led_puts("L2");
diff --git a/arch/arm/mach-uniphier/init/init-sld3.c b/arch/arm/mach-uniphier/init/init-sld3.c index ee3245c..a2e9cc7 100644 --- a/arch/arm/mach-uniphier/init/init-sld3.c +++ b/arch/arm/mach-uniphier/init/init-sld3.c @@ -31,7 +31,8 @@ int uniphier_sld3_init(const struct uniphier_board_data *bd)
led_puts("L1");
led_puts("L2");
diff --git a/arch/arm/mach-uniphier/init/init-sld8.c b/arch/arm/mach-uniphier/init/init-sld8.c index 82d036b..07fccb1 100644 --- a/arch/arm/mach-uniphier/init/init-sld8.c +++ b/arch/arm/mach-uniphier/init/init-sld8.c @@ -31,7 +31,8 @@ int uniphier_sld8_init(const struct uniphier_board_data *bd)
led_puts("L1");
led_puts("L2");
Currently, memconf-sld3.c and memconf-pxs2.c duplicate the code.
There are 3 patterns in terms of MEMCONF init: - DRAM 2 channels: LD4, sLD8, Pro4, Pro5, LD11 - DRAM 3 channels: sLD3 - DRAM 3 channels (Ch2 is disable by MEMCONF[21]): Pxs2, LD20
All of them can be moved into a single file by a little more refactoring.
arch/arm/mach-uniphier/Makefile | 3 +- arch/arm/mach-uniphier/init.h | 6 +- arch/arm/mach-uniphier/init/init-ld11.c | 2 +- arch/arm/mach-uniphier/init/init-ld20.c | 3 +- arch/arm/mach-uniphier/init/init-ld4.c | 2 +- arch/arm/mach-uniphier/init/init-pro4.c | 2 +- arch/arm/mach-uniphier/init/init-pro5.c | 2 +- arch/arm/mach-uniphier/init/init-pxs2.c | 3 +- arch/arm/mach-uniphier/init/init-sld3.c | 3 +- arch/arm/mach-uniphier/init/init-sld8.c | 2 +- arch/arm/mach-uniphier/memconf.c | 163 ++++++++++++++++++++++++++ arch/arm/mach-uniphier/memconf/Makefile | 9 -- arch/arm/mach-uniphier/memconf/memconf-pxs2.c | 68 ----------- arch/arm/mach-uniphier/memconf/memconf-sld3.c | 60 ---------- arch/arm/mach-uniphier/memconf/memconf.c | 107 ----------------- 15 files changed, 176 insertions(+), 259 deletions(-) create mode 100644 arch/arm/mach-uniphier/memconf.c delete mode 100644 arch/arm/mach-uniphier/memconf/Makefile delete mode 100644 arch/arm/mach-uniphier/memconf/memconf-pxs2.c delete mode 100644 arch/arm/mach-uniphier/memconf/memconf-sld3.c delete mode 100644 arch/arm/mach-uniphier/memconf/memconf.c
diff --git a/arch/arm/mach-uniphier/Makefile b/arch/arm/mach-uniphier/Makefile index ae78548..98b42a0 100644 --- a/arch/arm/mach-uniphier/Makefile +++ b/arch/arm/mach-uniphier/Makefile @@ -4,7 +4,8 @@
-obj-y += init/ bcu/ memconf/ +obj-y += memconf.o +obj-y += init/ bcu/ obj-$(CONFIG_MICRO_SUPPORT_CARD) += sbc/
else diff --git a/arch/arm/mach-uniphier/init.h b/arch/arm/mach-uniphier/init.h index 327fa8b..0708aa0 100644 --- a/arch/arm/mach-uniphier/init.h +++ b/arch/arm/mach-uniphier/init.h @@ -77,9 +77,9 @@ static inline int uniphier_pxs2_sbc_init(const struct uniphier_board_data *bd) int uniphier_sld3_bcu_init(const struct uniphier_board_data *bd); int uniphier_ld4_bcu_init(const struct uniphier_board_data *bd);
-int memconf_init(const struct uniphier_board_data *bd); -int uniphier_sld3_memconf_init(const struct uniphier_board_data *bd); -int uniphier_pxs2_memconf_init(const struct uniphier_board_data *bd); +int uniphier_memconf_2ch_init(const struct uniphier_board_data *bd); +int uniphier_memconf_3ch_no_disbit_init(const struct uniphier_board_data *bd); +int uniphier_memconf_3ch_init(const struct uniphier_board_data *bd);
int uniphier_sld3_dpll_init(const struct uniphier_board_data *bd); int uniphier_ld4_dpll_init(const struct uniphier_board_data *bd); diff --git a/arch/arm/mach-uniphier/init/init-ld11.c b/arch/arm/mach-uniphier/init/init-ld11.c index 9d43a13..93b2162 100644 --- a/arch/arm/mach-uniphier/init/init-ld11.c +++ b/arch/arm/mach-uniphier/init/init-ld11.c @@ -25,7 +25,7 @@ int uniphier_ld11_init(const struct uniphier_board_data *bd)
led_puts("L0");
- memconf_init(bd); + uniphier_memconf_2ch_init(bd);
led_puts("L1");
diff --git a/arch/arm/mach-uniphier/init/init-ld20.c b/arch/arm/mach-uniphier/init/init-ld20.c index 6702430..de39b9a 100644 --- a/arch/arm/mach-uniphier/init/init-ld20.c +++ b/arch/arm/mach-uniphier/init/init-ld20.c @@ -25,8 +25,7 @@ int uniphier_ld20_init(const struct uniphier_board_data *bd)
led_puts("L0");
- memconf_init(bd); - uniphier_pxs2_memconf_init(bd); + uniphier_memconf_3ch_init(bd);
led_puts("L1");
diff --git a/arch/arm/mach-uniphier/init/init-ld4.c b/arch/arm/mach-uniphier/init/init-ld4.c index 5f4880c..caf02a5 100644 --- a/arch/arm/mach-uniphier/init/init-ld4.c +++ b/arch/arm/mach-uniphier/init/init-ld4.c @@ -27,7 +27,7 @@ int uniphier_ld4_init(const struct uniphier_board_data *bd)
led_puts("L0");
led_puts("L1");
diff --git a/arch/arm/mach-uniphier/init/init-pro4.c b/arch/arm/mach-uniphier/init/init-pro4.c index e57eb86..32d09bb 100644 --- a/arch/arm/mach-uniphier/init/init-pro4.c +++ b/arch/arm/mach-uniphier/init/init-pro4.c @@ -24,7 +24,7 @@ int uniphier_pro4_init(const struct uniphier_board_data *bd)
led_puts("L0");
led_puts("L1");
diff --git a/arch/arm/mach-uniphier/init/init-pro5.c b/arch/arm/mach-uniphier/init/init-pro5.c index ea53dcf..3fc09a4 100644 --- a/arch/arm/mach-uniphier/init/init-pro5.c +++ b/arch/arm/mach-uniphier/init/init-pro5.c @@ -20,7 +20,7 @@ int uniphier_pro5_init(const struct uniphier_board_data *bd)
led_puts("L0");
led_puts("L1");
diff --git a/arch/arm/mach-uniphier/init/init-pxs2.c b/arch/arm/mach-uniphier/init/init-pxs2.c index 7cdf4bd..38e37e4 100644 --- a/arch/arm/mach-uniphier/init/init-pxs2.c +++ b/arch/arm/mach-uniphier/init/init-pxs2.c @@ -23,8 +23,7 @@ int uniphier_pxs2_init(const struct uniphier_board_data *bd)
led_puts("L0");
led_puts("L1");
diff --git a/arch/arm/mach-uniphier/init/init-sld3.c b/arch/arm/mach-uniphier/init/init-sld3.c index a2e9cc7..9dc51bf 100644 --- a/arch/arm/mach-uniphier/init/init-sld3.c +++ b/arch/arm/mach-uniphier/init/init-sld3.c @@ -26,8 +26,7 @@ int uniphier_sld3_init(const struct uniphier_board_data *bd)
led_puts("L0");
- memconf_init(bd); - uniphier_sld3_memconf_init(bd); + uniphier_memconf_3ch_no_disbit_init(bd);
led_puts("L1");
diff --git a/arch/arm/mach-uniphier/init/init-sld8.c b/arch/arm/mach-uniphier/init/init-sld8.c index 07fccb1..8e8d62b 100644 --- a/arch/arm/mach-uniphier/init/init-sld8.c +++ b/arch/arm/mach-uniphier/init/init-sld8.c @@ -27,7 +27,7 @@ int uniphier_sld8_init(const struct uniphier_board_data *bd)
led_puts("L0");
led_puts("L1");
diff --git a/arch/arm/mach-uniphier/memconf.c b/arch/arm/mach-uniphier/memconf.c new file mode 100644 index 0000000..205ccf1 --- /dev/null +++ b/arch/arm/mach-uniphier/memconf.c @@ -0,0 +1,163 @@ +/* + * Copyright (C) 2011-2015 Panasonic Corporation + * Copyright (C) 2016 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <linux/err.h> +#include <linux/io.h> +#include <linux/sizes.h> + +#include "sg-regs.h" +#include "init.h" + +static int __uniphier_memconf_init(const struct uniphier_board_data *bd, + int have_ch2, int have_ch2_disable_bit) +{ + u32 val = 0; + unsigned long size_per_word; + + /* set up ch0 */ + switch (bd->dram_ch[0].width) { + case 16: + val |= SG_MEMCONF_CH0_NUM_1; + size_per_word = bd->dram_ch[0].size; + break; + case 32: + val |= SG_MEMCONF_CH0_NUM_2; + size_per_word = bd->dram_ch[0].size >> 1; + break; + default: + pr_err("error: unsupported DRAM ch0 width\n"); + return -EINVAL; + } + + switch (size_per_word) { + case SZ_64M: + val |= SG_MEMCONF_CH0_SZ_64M; + break; + case SZ_128M: + val |= SG_MEMCONF_CH0_SZ_128M; + break; + case SZ_256M: + val |= SG_MEMCONF_CH0_SZ_256M; + break; + case SZ_512M: + val |= SG_MEMCONF_CH0_SZ_512M; + break; + case SZ_1G: + val |= SG_MEMCONF_CH0_SZ_1G; + break; + default: + pr_err("error: unsupported DRAM ch0 size\n"); + return -EINVAL; + } + + /* set up ch1 */ + switch (bd->dram_ch[1].width) { + case 16: + val |= SG_MEMCONF_CH1_NUM_1; + size_per_word = bd->dram_ch[1].size; + break; + case 32: + val |= SG_MEMCONF_CH1_NUM_2; + size_per_word = bd->dram_ch[1].size >> 1; + break; + default: + pr_err("error: unsupported DRAM ch1 width\n"); + return -EINVAL; + } + + switch (size_per_word) { + case SZ_64M: + val |= SG_MEMCONF_CH1_SZ_64M; + break; + case SZ_128M: + val |= SG_MEMCONF_CH1_SZ_128M; + break; + case SZ_256M: + val |= SG_MEMCONF_CH1_SZ_256M; + break; + case SZ_512M: + val |= SG_MEMCONF_CH1_SZ_512M; + break; + case SZ_1G: + val |= SG_MEMCONF_CH1_SZ_1G; + break; + default: + pr_err("error: unsupported DRAM ch1 size\n"); + return -EINVAL; + } + + /* is sparse mem? */ + if (bd->dram_ch[0].base + bd->dram_ch[0].size < bd->dram_ch[1].base) + val |= SG_MEMCONF_SPARSEMEM; + + if (!have_ch2) + goto out; + + if (!bd->dram_ch[2].size) { + if (have_ch2_disable_bit) + val |= SG_MEMCONF_CH2_DISABLE; + goto out; + } + + /* set up ch2 */ + switch (bd->dram_ch[2].width) { + case 16: + val |= SG_MEMCONF_CH2_NUM_1; + size_per_word = bd->dram_ch[2].size; + break; + case 32: + val |= SG_MEMCONF_CH2_NUM_2; + size_per_word = bd->dram_ch[2].size >> 1; + break; + default: + pr_err("error: unsupported DRAM ch2 width\n"); + return -EINVAL; + } + + switch (size_per_word) { + case SZ_64M: + val |= SG_MEMCONF_CH2_SZ_64M; + break; + case SZ_128M: + val |= SG_MEMCONF_CH2_SZ_128M; + break; + case SZ_256M: + val |= SG_MEMCONF_CH2_SZ_256M; + break; + case SZ_512M: + val |= SG_MEMCONF_CH2_SZ_512M; + break; + case SZ_1G: + val |= SG_MEMCONF_CH2_SZ_1G; + break; + default: + pr_err("error: unsupported DRAM ch2 size\n"); + return -EINVAL; + } + +out: + writel(val, SG_MEMCONF); + + return 0; +} + +int uniphier_memconf_2ch_init(const struct uniphier_board_data *bd) +{ + return __uniphier_memconf_init(bd, 0, 0); +} + +int uniphier_memconf_3ch_no_disbit_init(const struct uniphier_board_data *bd) +{ + return __uniphier_memconf_init(bd, 1, 0); +} + +int uniphier_memconf_3ch_init(const struct uniphier_board_data *bd) +{ + return __uniphier_memconf_init(bd, 1, 1); +} diff --git a/arch/arm/mach-uniphier/memconf/Makefile b/arch/arm/mach-uniphier/memconf/Makefile deleted file mode 100644 index 6ed1419..0000000 --- a/arch/arm/mach-uniphier/memconf/Makefile +++ /dev/null @@ -1,9 +0,0 @@ -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y += memconf.o -obj-$(CONFIG_ARCH_UNIPHIER_SLD3) += memconf-sld3.o -obj-$(CONFIG_ARCH_UNIPHIER_PXS2) += memconf-pxs2.o -obj-$(CONFIG_ARCH_UNIPHIER_LD6B) += memconf-pxs2.o -obj-$(CONFIG_ARCH_UNIPHIER_LD20) += memconf-pxs2.o diff --git a/arch/arm/mach-uniphier/memconf/memconf-pxs2.c b/arch/arm/mach-uniphier/memconf/memconf-pxs2.c deleted file mode 100644 index e98eb48..0000000 --- a/arch/arm/mach-uniphier/memconf/memconf-pxs2.c +++ /dev/null @@ -1,68 +0,0 @@ -/* - * Copyright (C) 2015 Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <linux/err.h> -#include <linux/io.h> -#include <linux/sizes.h> - -#include "../init.h" -#include "../sg-regs.h" - -int uniphier_pxs2_memconf_init(const struct uniphier_board_data *bd) -{ - u32 tmp; - unsigned long size_per_word; - - tmp = readl(SG_MEMCONF); - - tmp &= ~(SG_MEMCONF_CH2_SZ_MASK | SG_MEMCONF_CH2_NUM_MASK); - - switch (bd->dram_ch[2].width) { - case 16: - tmp |= SG_MEMCONF_CH2_NUM_1; - size_per_word = bd->dram_ch[2].size; - break; - case 32: - tmp |= SG_MEMCONF_CH2_NUM_2; - size_per_word = bd->dram_ch[2].size >> 1; - break; - default: - pr_err("error: unsupported DRAM Ch2 width\n"); - return -EINVAL; - } - - /* Set DDR size */ - switch (size_per_word) { - case SZ_64M: - tmp |= SG_MEMCONF_CH2_SZ_64M; - break; - case SZ_128M: - tmp |= SG_MEMCONF_CH2_SZ_128M; - break; - case SZ_256M: - tmp |= SG_MEMCONF_CH2_SZ_256M; - break; - case SZ_512M: - tmp |= SG_MEMCONF_CH2_SZ_512M; - break; - case SZ_1G: - tmp |= SG_MEMCONF_CH2_SZ_1G; - break; - default: - pr_err("error: unsupported DRAM Ch2 size\n"); - return -EINVAL; - } - - if (size_per_word) - tmp &= ~SG_MEMCONF_CH2_DISABLE; - else - tmp |= SG_MEMCONF_CH2_DISABLE; - - writel(tmp, SG_MEMCONF); - - return 0; -} diff --git a/arch/arm/mach-uniphier/memconf/memconf-sld3.c b/arch/arm/mach-uniphier/memconf/memconf-sld3.c deleted file mode 100644 index 948f82c..0000000 --- a/arch/arm/mach-uniphier/memconf/memconf-sld3.c +++ /dev/null @@ -1,60 +0,0 @@ -/* - * Copyright (C) 2015 Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <linux/err.h> -#include <linux/io.h> -#include <linux/sizes.h> - -#include "../init.h" -#include "../sg-regs.h" - -int uniphier_sld3_memconf_init(const struct uniphier_board_data *bd) -{ - u32 tmp; - unsigned long size_per_word; - - tmp = readl(SG_MEMCONF); - - tmp &= ~(SG_MEMCONF_CH2_SZ_MASK | SG_MEMCONF_CH2_NUM_MASK); - - switch (bd->dram_ch[2].width) { - case 16: - tmp |= SG_MEMCONF_CH2_NUM_1; - size_per_word = bd->dram_ch[2].size; - break; - case 32: - tmp |= SG_MEMCONF_CH2_NUM_2; - size_per_word = bd->dram_ch[2].size >> 1; - break; - default: - pr_err("error: unsupported DRAM Ch2 width\n"); - return -EINVAL; - } - - /* Set DDR size */ - switch (size_per_word) { - case SZ_64M: - tmp |= SG_MEMCONF_CH2_SZ_64M; - break; - case SZ_128M: - tmp |= SG_MEMCONF_CH2_SZ_128M; - break; - case SZ_256M: - tmp |= SG_MEMCONF_CH2_SZ_256M; - break; - case SZ_512M: - tmp |= SG_MEMCONF_CH2_SZ_512M; - break; - default: - pr_err("error: unsupported DRAM Ch2 size\n"); - return -EINVAL; - } - - writel(tmp, SG_MEMCONF); - - return 0; -} diff --git a/arch/arm/mach-uniphier/memconf/memconf.c b/arch/arm/mach-uniphier/memconf/memconf.c deleted file mode 100644 index e607ac9..0000000 --- a/arch/arm/mach-uniphier/memconf/memconf.c +++ /dev/null @@ -1,107 +0,0 @@ -/* - * Copyright (C) 2011-2015 Panasonic Corporation - * Copyright (C) 2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <linux/err.h> -#include <linux/io.h> -#include <linux/sizes.h> - -#include "../init.h" -#include "../sg-regs.h" - -int memconf_init(const struct uniphier_board_data *bd) -{ - u32 tmp; - unsigned long size_per_word; - - tmp = readl(SG_MEMCONF); - - tmp &= ~(SG_MEMCONF_CH0_SZ_MASK | SG_MEMCONF_CH0_NUM_MASK); - - switch (bd->dram_ch[0].width) { - case 16: - tmp |= SG_MEMCONF_CH0_NUM_1; - size_per_word = bd->dram_ch[0].size; - break; - case 32: - tmp |= SG_MEMCONF_CH0_NUM_2; - size_per_word = bd->dram_ch[0].size >> 1; - break; - default: - pr_err("error: unsupported DRAM Ch0 width\n"); - return -EINVAL; - } - - /* Set DDR size */ - switch (size_per_word) { - case SZ_64M: - tmp |= SG_MEMCONF_CH0_SZ_64M; - break; - case SZ_128M: - tmp |= SG_MEMCONF_CH0_SZ_128M; - break; - case SZ_256M: - tmp |= SG_MEMCONF_CH0_SZ_256M; - break; - case SZ_512M: - tmp |= SG_MEMCONF_CH0_SZ_512M; - break; - case SZ_1G: - tmp |= SG_MEMCONF_CH0_SZ_1G; - break; - default: - pr_err("error: unsupported DRAM Ch0 size\n"); - return -EINVAL; - } - - tmp &= ~(SG_MEMCONF_CH1_SZ_MASK | SG_MEMCONF_CH1_NUM_MASK); - - switch (bd->dram_ch[1].width) { - case 16: - tmp |= SG_MEMCONF_CH1_NUM_1; - size_per_word = bd->dram_ch[1].size; - break; - case 32: - tmp |= SG_MEMCONF_CH1_NUM_2; - size_per_word = bd->dram_ch[1].size >> 1; - break; - default: - pr_err("error: unsupported DRAM Ch1 width\n"); - return -EINVAL; - } - - switch (size_per_word) { - case SZ_64M: - tmp |= SG_MEMCONF_CH1_SZ_64M; - break; - case SZ_128M: - tmp |= SG_MEMCONF_CH1_SZ_128M; - break; - case SZ_256M: - tmp |= SG_MEMCONF_CH1_SZ_256M; - break; - case SZ_512M: - tmp |= SG_MEMCONF_CH1_SZ_512M; - break; - case SZ_1G: - tmp |= SG_MEMCONF_CH1_SZ_1G; - break; - default: - pr_err("error: unsupported DRAM Ch1 size\n"); - return -EINVAL; - } - - if (bd->dram_ch[0].base + bd->dram_ch[0].size < bd->dram_ch[1].base) - tmp |= SG_MEMCONF_SPARSEMEM; - else - tmp &= ~SG_MEMCONF_SPARSEMEM; - - writel(tmp, SG_MEMCONF); - - return 0; -}
Merge sbc-admulti.c and sbc-savepin.c into a single file to avoid code duplication.
arch/arm/mach-uniphier/init.h | 27 ++++++----- arch/arm/mach-uniphier/init/init-ld11.c | 6 +-- arch/arm/mach-uniphier/init/init-ld20.c | 6 +-- arch/arm/mach-uniphier/init/init-ld4.c | 3 +- arch/arm/mach-uniphier/init/init-pro4.c | 2 +- arch/arm/mach-uniphier/init/init-pro5.c | 2 +- arch/arm/mach-uniphier/init/init-pxs2.c | 3 +- arch/arm/mach-uniphier/init/init-sld3.c | 2 +- arch/arm/mach-uniphier/init/init-sld8.c | 3 +- arch/arm/mach-uniphier/sbc/Makefile | 17 ++++--- arch/arm/mach-uniphier/sbc/sbc-admulti.c | 53 ---------------------- arch/arm/mach-uniphier/sbc/sbc-ld11.c | 25 ++++++++++ arch/arm/mach-uniphier/sbc/sbc-ld4.c | 6 +-- arch/arm/mach-uniphier/sbc/sbc-pxs2.c | 6 +-- .../arm/mach-uniphier/sbc/{sbc-savepin.c => sbc.c} | 36 ++++++++++++--- 15 files changed, 89 insertions(+), 108 deletions(-) delete mode 100644 arch/arm/mach-uniphier/sbc/sbc-admulti.c create mode 100644 arch/arm/mach-uniphier/sbc/sbc-ld11.c rename arch/arm/mach-uniphier/sbc/{sbc-savepin.c => sbc.c} (58%)
diff --git a/arch/arm/mach-uniphier/init.h b/arch/arm/mach-uniphier/init.h index 0708aa0..78c2eee 100644 --- a/arch/arm/mach-uniphier/init.h +++ b/arch/arm/mach-uniphier/init.h @@ -46,31 +46,30 @@ int uniphier_ld11_init(const struct uniphier_board_data *bd); int uniphier_ld20_init(const struct uniphier_board_data *bd);
#if defined(CONFIG_MICRO_SUPPORT_CARD) -int uniphier_sbc_init_admulti(const struct uniphier_board_data *bd); -int uniphier_sbc_init_savepin(const struct uniphier_board_data *bd); -int uniphier_ld4_sbc_init(const struct uniphier_board_data *bd); -int uniphier_pxs2_sbc_init(const struct uniphier_board_data *bd); +void uniphier_sbc_init_admulti(void); +void uniphier_sbc_init_savepin(void); +void uniphier_ld4_sbc_init(void); +void uniphier_pxs2_sbc_init(void); +void uniphier_ld11_sbc_init(void); #else -static inline int uniphier_sbc_init_admulti( - const struct uniphier_board_data *bd) +static inline void uniphier_sbc_init_admulti(void) { - return 0; }
-static inline int uniphier_sbc_init_savepin( - const struct uniphier_board_data *bd) +static inline void uniphier_sbc_init_savepin(void) { - return 0; }
-static inline int uniphier_ld4_sbc_init(const struct uniphier_board_data *bd) +static inline void uniphier_ld4_sbc_init(void) { - return 0; }
-static inline int uniphier_pxs2_sbc_init(const struct uniphier_board_data *bd) +static inline void uniphier_pxs2_sbc_init(void) +{ +} + +static inline void uniphier_ld11_sbc_init(void) { - return 0; } #endif
diff --git a/arch/arm/mach-uniphier/init/init-ld11.c b/arch/arm/mach-uniphier/init/init-ld11.c index 93b2162..64fe000 100644 --- a/arch/arm/mach-uniphier/init/init-ld11.c +++ b/arch/arm/mach-uniphier/init/init-ld11.c @@ -13,11 +13,7 @@
int uniphier_ld11_init(const struct uniphier_board_data *bd) { - uniphier_sbc_init_savepin(bd); - uniphier_pxs2_sbc_init(bd); - /* pins for NAND and System Bus are multiplexed */ - if (spl_boot_device() != BOOT_DEVICE_NAND) - uniphier_pin_init("system_bus_grp"); + uniphier_ld11_sbc_init();
support_card_reset();
diff --git a/arch/arm/mach-uniphier/init/init-ld20.c b/arch/arm/mach-uniphier/init/init-ld20.c index de39b9a..ec4563b 100644 --- a/arch/arm/mach-uniphier/init/init-ld20.c +++ b/arch/arm/mach-uniphier/init/init-ld20.c @@ -13,11 +13,7 @@
int uniphier_ld20_init(const struct uniphier_board_data *bd) { - uniphier_sbc_init_savepin(bd); - uniphier_pxs2_sbc_init(bd); - /* pins for NAND and System Bus are multiplexed */ - if (spl_boot_device() != BOOT_DEVICE_NAND) - uniphier_pin_init("system_bus_grp"); + uniphier_ld11_sbc_init();
diff --git a/arch/arm/mach-uniphier/init/init-ld4.c b/arch/arm/mach-uniphier/init/init-ld4.c index caf02a5..a56fb7f 100644 --- a/arch/arm/mach-uniphier/init/init-ld4.c +++ b/arch/arm/mach-uniphier/init/init-ld4.c @@ -16,8 +16,7 @@ int uniphier_ld4_init(const struct uniphier_board_data *bd) { uniphier_ld4_bcu_init(bd);
- uniphier_sbc_init_savepin(bd); - uniphier_ld4_sbc_init(bd); + uniphier_ld4_sbc_init();
diff --git a/arch/arm/mach-uniphier/init/init-pro4.c b/arch/arm/mach-uniphier/init/init-pro4.c index 32d09bb..8e2ebc7 100644 --- a/arch/arm/mach-uniphier/init/init-pro4.c +++ b/arch/arm/mach-uniphier/init/init-pro4.c @@ -14,7 +14,7 @@
int uniphier_pro4_init(const struct uniphier_board_data *bd) { - uniphier_sbc_init_savepin(bd); + uniphier_sbc_init_savepin();
diff --git a/arch/arm/mach-uniphier/init/init-pro5.c b/arch/arm/mach-uniphier/init/init-pro5.c index 3fc09a4..37c62ef 100644 --- a/arch/arm/mach-uniphier/init/init-pro5.c +++ b/arch/arm/mach-uniphier/init/init-pro5.c @@ -12,7 +12,7 @@
int uniphier_pro5_init(const struct uniphier_board_data *bd) { - uniphier_sbc_init_savepin(bd); + uniphier_sbc_init_savepin();
diff --git a/arch/arm/mach-uniphier/init/init-pxs2.c b/arch/arm/mach-uniphier/init/init-pxs2.c index 38e37e4..d080b9b 100644 --- a/arch/arm/mach-uniphier/init/init-pxs2.c +++ b/arch/arm/mach-uniphier/init/init-pxs2.c @@ -14,8 +14,7 @@ int uniphier_pxs2_init(const struct uniphier_board_data *bd) { int ret;
- uniphier_sbc_init_savepin(bd); - uniphier_pxs2_sbc_init(bd); + uniphier_pxs2_sbc_init();
diff --git a/arch/arm/mach-uniphier/init/init-sld3.c b/arch/arm/mach-uniphier/init/init-sld3.c index 9dc51bf..0b8d6c5 100644 --- a/arch/arm/mach-uniphier/init/init-sld3.c +++ b/arch/arm/mach-uniphier/init/init-sld3.c @@ -16,7 +16,7 @@ int uniphier_sld3_init(const struct uniphier_board_data *bd) { uniphier_sld3_bcu_init(bd);
- uniphier_sbc_init_admulti(bd); + uniphier_sbc_init_admulti();
diff --git a/arch/arm/mach-uniphier/init/init-sld8.c b/arch/arm/mach-uniphier/init/init-sld8.c index 8e8d62b..075ac27 100644 --- a/arch/arm/mach-uniphier/init/init-sld8.c +++ b/arch/arm/mach-uniphier/init/init-sld8.c @@ -16,8 +16,7 @@ int uniphier_sld8_init(const struct uniphier_board_data *bd) { uniphier_ld4_bcu_init(bd);
diff --git a/arch/arm/mach-uniphier/sbc/Makefile b/arch/arm/mach-uniphier/sbc/Makefile index ec3c22c..b85b1fe 100644 --- a/arch/arm/mach-uniphier/sbc/Makefile +++ b/arch/arm/mach-uniphier/sbc/Makefile @@ -2,12 +2,11 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-$(CONFIG_ARCH_UNIPHIER_SLD3) += sbc-admulti.o -obj-$(CONFIG_ARCH_UNIPHIER_LD4) += sbc-savepin.o sbc-ld4.o -obj-$(CONFIG_ARCH_UNIPHIER_PRO4) += sbc-savepin.o -obj-$(CONFIG_ARCH_UNIPHIER_SLD8) += sbc-savepin.o sbc-ld4.o -obj-$(CONFIG_ARCH_UNIPHIER_PRO5) += sbc-savepin.o -obj-$(CONFIG_ARCH_UNIPHIER_PXS2) += sbc-savepin.o sbc-pxs2.o -obj-$(CONFIG_ARCH_UNIPHIER_LD6B) += sbc-savepin.o sbc-pxs2.o -obj-$(CONFIG_ARCH_UNIPHIER_LD11) += sbc-savepin.o sbc-pxs2.o -obj-$(CONFIG_ARCH_UNIPHIER_LD20) += sbc-savepin.o sbc-pxs2.o +obj-y += sbc.o + +obj-$(CONFIG_ARCH_UNIPHIER_LD4) += sbc-ld4.o +obj-$(CONFIG_ARCH_UNIPHIER_SLD8) += sbc-ld4.o +obj-$(CONFIG_ARCH_UNIPHIER_PXS2) += sbc-pxs2.o +obj-$(CONFIG_ARCH_UNIPHIER_LD6B) += sbc-pxs2.o +obj-$(CONFIG_ARCH_UNIPHIER_LD11) += sbc-ld11.o +obj-$(CONFIG_ARCH_UNIPHIER_LD20) += sbc-ld11.o diff --git a/arch/arm/mach-uniphier/sbc/sbc-admulti.c b/arch/arm/mach-uniphier/sbc/sbc-admulti.c deleted file mode 100644 index 05108dd..0000000 --- a/arch/arm/mach-uniphier/sbc/sbc-admulti.c +++ /dev/null @@ -1,53 +0,0 @@ -/* - * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <linux/io.h> - -#include "../init.h" -#include "../sg-regs.h" -#include "sbc-regs.h" - -#define SBCTRL0_ADMULTIPLX_PERI_VALUE 0x33120000 -#define SBCTRL1_ADMULTIPLX_PERI_VALUE 0x03005500 -#define SBCTRL2_ADMULTIPLX_PERI_VALUE 0x14000020 - -#define SBCTRL0_ADMULTIPLX_MEM_VALUE 0x33120000 -#define SBCTRL1_ADMULTIPLX_MEM_VALUE 0x03005500 -#define SBCTRL2_ADMULTIPLX_MEM_VALUE 0x14000010 - -int uniphier_sbc_init_admulti(const struct uniphier_board_data *bd) -{ - /* - * Only CS1 is connected to support card. - * BKSZ[1:0] should be set to "01". - */ - writel(SBCTRL0_ADMULTIPLX_MEM_VALUE, SBCTRL10); - writel(SBCTRL1_ADMULTIPLX_MEM_VALUE, SBCTRL11); - writel(SBCTRL2_ADMULTIPLX_MEM_VALUE, SBCTRL12); - - if (boot_is_swapped()) { - /* - * Boot Swap On: boot from external NOR/SRAM - * 0x42000000-0x43ffffff is a mirror of 0x40000000-0x41ffffff. - * - * 0x40000000-0x41efffff, 0x42000000-0x43efffff: memory bank - * 0x41f00000-0x41ffffff, 0x43f00000-0x43ffffff: peripherals - */ - writel(0x0000bc01, SBBASE0); - } else { - /* - * Boot Swap Off: boot from mask ROM - * 0x40000000-0x41ffffff: mask ROM - * 0x42000000-0x43efffff: memory bank (31MB) - * 0x43f00000-0x43ffffff: peripherals (1MB) - */ - writel(0x0000be01, SBBASE0); /* dummy */ - writel(0x0200be01, SBBASE1); - } - - return 0; -} diff --git a/arch/arm/mach-uniphier/sbc/sbc-ld11.c b/arch/arm/mach-uniphier/sbc/sbc-ld11.c new file mode 100644 index 0000000..41adc94 --- /dev/null +++ b/arch/arm/mach-uniphier/sbc/sbc-ld11.c @@ -0,0 +1,25 @@ +/* + * Copyright (C) 2015-2016 Masahiro Yamada yamada.masahiro@socionext.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <spl.h> +#include <linux/io.h> + +#include "../init.h" +#include "sbc-regs.h" + +void uniphier_ld11_sbc_init(void) +{ + uniphier_sbc_init_savepin(); + + /* necessary for ROM boot ?? */ + /* system bus output enable */ + writel(0x17, PC0CTRL); + + /* pins for NAND and System Bus are multiplexed */ + if (spl_boot_device() != BOOT_DEVICE_NAND) + uniphier_pin_init("system_bus_grp"); +} diff --git a/arch/arm/mach-uniphier/sbc/sbc-ld4.c b/arch/arm/mach-uniphier/sbc/sbc-ld4.c index 12bee79..7520e2a 100644 --- a/arch/arm/mach-uniphier/sbc/sbc-ld4.c +++ b/arch/arm/mach-uniphier/sbc/sbc-ld4.c @@ -9,14 +9,14 @@ #include "../init.h" #include "sbc-regs.h"
-int uniphier_ld4_sbc_init(const struct uniphier_board_data *bd) +void uniphier_ld4_sbc_init(void) { u32 tmp;
+ uniphier_sbc_init_savepin(); + /* system bus output enable */ tmp = readl(PC0CTRL); tmp &= 0xfffffcff; writel(tmp, PC0CTRL); - - return 0; } diff --git a/arch/arm/mach-uniphier/sbc/sbc-pxs2.c b/arch/arm/mach-uniphier/sbc/sbc-pxs2.c index acbf4c5..677a974 100644 --- a/arch/arm/mach-uniphier/sbc/sbc-pxs2.c +++ b/arch/arm/mach-uniphier/sbc/sbc-pxs2.c @@ -9,11 +9,11 @@ #include "../init.h" #include "sbc-regs.h"
-int uniphier_pxs2_sbc_init(const struct uniphier_board_data *bd) +void uniphier_pxs2_sbc_init(void) { + uniphier_sbc_init_savepin(); + /* necessary for ROM boot ?? */ /* system bus output enable */ writel(0x17, PC0CTRL); - - return 0; } diff --git a/arch/arm/mach-uniphier/sbc/sbc-savepin.c b/arch/arm/mach-uniphier/sbc/sbc.c similarity index 58% rename from arch/arm/mach-uniphier/sbc/sbc-savepin.c rename to arch/arm/mach-uniphier/sbc/sbc.c index 41e9796..b43d933 100644 --- a/arch/arm/mach-uniphier/sbc/sbc-savepin.c +++ b/arch/arm/mach-uniphier/sbc/sbc.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2011-2016 Masahiro Yamada yamada.masahiro@socionext.com + * Copyright (C) 2011-2015 Masahiro Yamada yamada.masahiro@socionext.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -9,6 +9,14 @@ #include "../init.h" #include "sbc-regs.h"
+#define SBCTRL0_ADMULTIPLX_PERI_VALUE 0x33120000 +#define SBCTRL1_ADMULTIPLX_PERI_VALUE 0x03005500 +#define SBCTRL2_ADMULTIPLX_PERI_VALUE 0x14000020 + +#define SBCTRL0_ADMULTIPLX_MEM_VALUE 0x33120000 +#define SBCTRL1_ADMULTIPLX_MEM_VALUE 0x03005500 +#define SBCTRL2_ADMULTIPLX_MEM_VALUE 0x14000010 + /* slower but LED works */ #define SBCTRL0_SAVEPIN_PERI_VALUE 0x55450000 #define SBCTRL1_SAVEPIN_PERI_VALUE 0x07168d00 @@ -22,16 +30,22 @@ #define SBCTRL2_SAVEPIN_MEM_VALUE 0x34000009 #define SBCTRL4_SAVEPIN_MEM_VALUE 0x02110210
-int uniphier_sbc_init_savepin(const struct uniphier_board_data *bd) +static void __uniphier_sbc_init(int savepin) { /* * Only CS1 is connected to support card. * BKSZ[1:0] should be set to "01". */ - writel(SBCTRL0_SAVEPIN_PERI_VALUE, SBCTRL10); - writel(SBCTRL1_SAVEPIN_PERI_VALUE, SBCTRL11); - writel(SBCTRL2_SAVEPIN_PERI_VALUE, SBCTRL12); - writel(SBCTRL4_SAVEPIN_PERI_VALUE, SBCTRL14); + if (savepin) { + writel(SBCTRL0_SAVEPIN_PERI_VALUE, SBCTRL10); + writel(SBCTRL1_SAVEPIN_PERI_VALUE, SBCTRL11); + writel(SBCTRL2_SAVEPIN_PERI_VALUE, SBCTRL12); + writel(SBCTRL4_SAVEPIN_PERI_VALUE, SBCTRL14); + } else { + writel(SBCTRL0_ADMULTIPLX_MEM_VALUE, SBCTRL10); + writel(SBCTRL1_ADMULTIPLX_MEM_VALUE, SBCTRL11); + writel(SBCTRL2_ADMULTIPLX_MEM_VALUE, SBCTRL12); + }
if (boot_is_swapped()) { /* @@ -52,6 +66,14 @@ int uniphier_sbc_init_savepin(const struct uniphier_board_data *bd) writel(0x0000be01, SBBASE0); /* dummy */ writel(0x0200be01, SBBASE1); } +}
- return 0; +void uniphier_sbc_init_admulti(void) +{ + __uniphier_sbc_init(0); +} + +void uniphier_sbc_init_savepin(void) +{ + __uniphier_sbc_init(1); }
Splitting reset assertion (support_card_reset) and deassertion (support_card_init) is not adding much value any more. Handle all the initialization of Support Card in support_card_init(), then remove support_card_reset().
Also, detect_num_flash_banks() can have a static qualifier.
arch/arm/mach-uniphier/init/init-ld11.c | 2 -- arch/arm/mach-uniphier/init/init-ld20.c | 2 -- arch/arm/mach-uniphier/init/init-ld4.c | 4 +--- arch/arm/mach-uniphier/init/init-pro4.c | 4 +--- arch/arm/mach-uniphier/init/init-pro5.c | 2 -- arch/arm/mach-uniphier/init/init-pxs2.c | 2 -- arch/arm/mach-uniphier/init/init-sld3.c | 4 +--- arch/arm/mach-uniphier/init/init-sld8.c | 4 +--- arch/arm/mach-uniphier/micro-support-card.c | 7 ++++--- arch/arm/mach-uniphier/micro-support-card.h | 5 ----- 10 files changed, 8 insertions(+), 28 deletions(-)
diff --git a/arch/arm/mach-uniphier/init/init-ld11.c b/arch/arm/mach-uniphier/init/init-ld11.c index 64fe000..e19dc5b 100644 --- a/arch/arm/mach-uniphier/init/init-ld11.c +++ b/arch/arm/mach-uniphier/init/init-ld11.c @@ -15,8 +15,6 @@ int uniphier_ld11_init(const struct uniphier_board_data *bd) { uniphier_ld11_sbc_init();
- support_card_reset(); - support_card_init();
led_puts("L0"); diff --git a/arch/arm/mach-uniphier/init/init-ld20.c b/arch/arm/mach-uniphier/init/init-ld20.c index ec4563b..e056d5d 100644 --- a/arch/arm/mach-uniphier/init/init-ld20.c +++ b/arch/arm/mach-uniphier/init/init-ld20.c @@ -15,8 +15,6 @@ int uniphier_ld20_init(const struct uniphier_board_data *bd) { uniphier_ld11_sbc_init();
led_puts("L0"); diff --git a/arch/arm/mach-uniphier/init/init-ld4.c b/arch/arm/mach-uniphier/init/init-ld4.c index a56fb7f..a5b9493 100644 --- a/arch/arm/mach-uniphier/init/init-ld4.c +++ b/arch/arm/mach-uniphier/init/init-ld4.c @@ -18,12 +18,10 @@ int uniphier_ld4_init(const struct uniphier_board_data *bd)
- support_card_reset(); + support_card_init();
uniphier_ld4_dpll_init(bd);
- support_card_init(); - led_puts("L0");
uniphier_memconf_2ch_init(bd); diff --git a/arch/arm/mach-uniphier/init/init-pro4.c b/arch/arm/mach-uniphier/init/init-pro4.c index 8e2ebc7..c277071 100644 --- a/arch/arm/mach-uniphier/init/init-pro4.c +++ b/arch/arm/mach-uniphier/init/init-pro4.c @@ -16,12 +16,10 @@ int uniphier_pro4_init(const struct uniphier_board_data *bd) { uniphier_sbc_init_savepin();
uniphier_pro4_dpll_init(bd);
uniphier_memconf_2ch_init(bd); diff --git a/arch/arm/mach-uniphier/init/init-pro5.c b/arch/arm/mach-uniphier/init/init-pro5.c index 37c62ef..4e7041b 100644 --- a/arch/arm/mach-uniphier/init/init-pro5.c +++ b/arch/arm/mach-uniphier/init/init-pro5.c @@ -14,8 +14,6 @@ int uniphier_pro5_init(const struct uniphier_board_data *bd) { uniphier_sbc_init_savepin();
led_puts("L0"); diff --git a/arch/arm/mach-uniphier/init/init-pxs2.c b/arch/arm/mach-uniphier/init/init-pxs2.c index d080b9b..f7d5b48 100644 --- a/arch/arm/mach-uniphier/init/init-pxs2.c +++ b/arch/arm/mach-uniphier/init/init-pxs2.c @@ -16,8 +16,6 @@ int uniphier_pxs2_init(const struct uniphier_board_data *bd)
led_puts("L0"); diff --git a/arch/arm/mach-uniphier/init/init-sld3.c b/arch/arm/mach-uniphier/init/init-sld3.c index 0b8d6c5..50d9eaf 100644 --- a/arch/arm/mach-uniphier/init/init-sld3.c +++ b/arch/arm/mach-uniphier/init/init-sld3.c @@ -18,12 +18,10 @@ int uniphier_sld3_init(const struct uniphier_board_data *bd)
uniphier_sld3_dpll_init(bd);
uniphier_memconf_3ch_no_disbit_init(bd); diff --git a/arch/arm/mach-uniphier/init/init-sld8.c b/arch/arm/mach-uniphier/init/init-sld8.c index 075ac27..8da2843 100644 --- a/arch/arm/mach-uniphier/init/init-sld8.c +++ b/arch/arm/mach-uniphier/init/init-sld8.c @@ -18,12 +18,10 @@ int uniphier_sld8_init(const struct uniphier_board_data *bd)
uniphier_sld8_dpll_init(bd);
uniphier_memconf_2ch_init(bd); diff --git a/arch/arm/mach-uniphier/micro-support-card.c b/arch/arm/mach-uniphier/micro-support-card.c index e53bcdf..80c5d97 100644 --- a/arch/arm/mach-uniphier/micro-support-card.c +++ b/arch/arm/mach-uniphier/micro-support-card.c @@ -25,12 +25,12 @@ * bit[0]: LAN, I2C, LED * bit[1]: UART */ -void support_card_reset_deassert(void) +static void support_card_reset_deassert(void) { writel(0x00010000, MICRO_SUPPORT_CARD_RESET); }
-void support_card_reset(void) +static void support_card_reset(void) { writel(0x00020003, MICRO_SUPPORT_CARD_RESET); } @@ -57,6 +57,7 @@ int checkboard(void)
void support_card_init(void) { + support_card_reset(); /* * After power on, we need to keep the LAN controller in reset state * for a while. (200 usec) @@ -157,7 +158,7 @@ static void detect_num_flash_banks(void) debug("number of flash banks: %d\n", cfi_flash_num_flash_banks); } #else /* CONFIG_SYS_NO_FLASH */ -void detect_num_flash_banks(void) +static void detect_num_flash_banks(void) { }; #endif /* CONFIG_SYS_NO_FLASH */ diff --git a/arch/arm/mach-uniphier/micro-support-card.h b/arch/arm/mach-uniphier/micro-support-card.h index 4dae603..90990ba 100644 --- a/arch/arm/mach-uniphier/micro-support-card.h +++ b/arch/arm/mach-uniphier/micro-support-card.h @@ -10,15 +10,10 @@ #define MICRO_SUPPORT_CARD_H
#if defined(CONFIG_MICRO_SUPPORT_CARD) -void support_card_reset(void); void support_card_init(void); void support_card_late_init(void); void led_puts(const char *s); #else -static inline void support_card_reset(void) -{ -} - static inline void support_card_init(void) { }
These functions never fail, so no need to return a value.
arch/arm/mach-uniphier/bcu/bcu-ld4.c | 4 +--- arch/arm/mach-uniphier/bcu/bcu-sld3.c | 4 +--- arch/arm/mach-uniphier/init.h | 4 ++-- 3 files changed, 4 insertions(+), 8 deletions(-)
diff --git a/arch/arm/mach-uniphier/bcu/bcu-ld4.c b/arch/arm/mach-uniphier/bcu/bcu-ld4.c index eeab802..ca70480 100644 --- a/arch/arm/mach-uniphier/bcu/bcu-ld4.c +++ b/arch/arm/mach-uniphier/bcu/bcu-ld4.c @@ -11,7 +11,7 @@
#define ch(x) ((x) >= 32 ? 0 : (x) < 0 ? 0x11111111 : 0x11111111 << (x))
-int uniphier_ld4_bcu_init(const struct uniphier_board_data *bd) +void uniphier_ld4_bcu_init(const struct uniphier_board_data *bd) { int shift;
@@ -30,6 +30,4 @@ int uniphier_ld4_bcu_init(const struct uniphier_board_data *bd)
shift -= 32; writel(ch(shift), BCIPPCCHR4); /* 0xc0000000-0xdfffffff */ - - return 0; } diff --git a/arch/arm/mach-uniphier/bcu/bcu-sld3.c b/arch/arm/mach-uniphier/bcu/bcu-sld3.c index 493e6d5..4e92076 100644 --- a/arch/arm/mach-uniphier/bcu/bcu-sld3.c +++ b/arch/arm/mach-uniphier/bcu/bcu-sld3.c @@ -11,7 +11,7 @@
-int uniphier_sld3_bcu_init(const struct uniphier_board_data *bd) +void uniphier_sld3_bcu_init(const struct uniphier_board_data *bd) { int shift;
@@ -34,6 +34,4 @@ int uniphier_sld3_bcu_init(const struct uniphier_board_data *bd)
shift -= 32; writel(ch(shift), BCIPPCCHR4); /* 0xc0000000-0xdfffffff */ - - return 0; } diff --git a/arch/arm/mach-uniphier/init.h b/arch/arm/mach-uniphier/init.h index 78c2eee..18393e5 100644 --- a/arch/arm/mach-uniphier/init.h +++ b/arch/arm/mach-uniphier/init.h @@ -73,8 +73,8 @@ static inline void uniphier_ld11_sbc_init(void) } #endif
-int uniphier_sld3_bcu_init(const struct uniphier_board_data *bd); -int uniphier_ld4_bcu_init(const struct uniphier_board_data *bd); +void uniphier_sld3_bcu_init(const struct uniphier_board_data *bd); +void uniphier_ld4_bcu_init(const struct uniphier_board_data *bd);
int uniphier_memconf_2ch_init(const struct uniphier_board_data *bd); int uniphier_memconf_3ch_no_disbit_init(const struct uniphier_board_data *bd);
The code here is cluttered due to the switch statement. Introduce a table of callbacks to clean up the initialization code across SoCs.
arch/arm/mach-uniphier/board_init.c | 219 +++++++++++++++++++++++------------- 1 file changed, 140 insertions(+), 79 deletions(-)
diff --git a/arch/arm/mach-uniphier/board_init.c b/arch/arm/mach-uniphier/board_init.c index 4cab7fe..77f1fb0 100644 --- a/arch/arm/mach-uniphier/board_init.c +++ b/arch/arm/mach-uniphier/board_init.c @@ -48,116 +48,177 @@ static void uniphier_setup_xirq(void) writel(tmp, 0x55000090); }
-static void uniphier_nand_pin_init(bool cs2) +#ifdef CONFIG_ARCH_UNIPHIER_LD11 +static void uniphier_ld11_misc_init(void) { -#ifdef CONFIG_NAND_DENALI - if (uniphier_pin_init(cs2 ? "nand2cs_grp" : "nand_grp")) - pr_err("failed to init NAND pins\n"); -#endif + sg_set_pinsel(149, 14, 8, 4); /* XIRQ0 -> XIRQ0 */ + sg_set_iectrl(149); + sg_set_pinsel(153, 14, 8, 4); /* XIRQ4 -> XIRQ4 */ + sg_set_iectrl(153); } +#endif
-int board_init(void) +#ifdef CONFIG_ARCH_UNIPHIER_LD20 +static void uniphier_ld20_misc_init(void) { - led_puts("U0"); + sg_set_pinsel(149, 14, 8, 4); /* XIRQ0 -> XIRQ0 */ + sg_set_iectrl(149); + sg_set_pinsel(153, 14, 8, 4); /* XIRQ4 -> XIRQ4 */ + sg_set_iectrl(153); + + /* ES1 errata: increase VDD09 supply to suppress VBO noise */ + if (uniphier_get_soc_revision() == 1) { + writel(0x00000003, 0x6184e004); + writel(0x00000100, 0x6184e040); + writel(0x0000b500, 0x6184e024); + writel(0x00000001, 0x6184e000); + } + + cci500_init(2); +} +#endif + +struct uniphier_initdata { + enum uniphier_soc_id soc_id; + bool nand_2cs; + void (*pll_init)(void); + void (*clk_init)(void); + void (*misc_init)(void); +};
- switch (uniphier_get_soc_type()) { +struct uniphier_initdata uniphier_initdata[] = { #if defined(CONFIG_ARCH_UNIPHIER_SLD3) - case SOC_UNIPHIER_SLD3: - uniphier_nand_pin_init(true); - led_puts("U1"); - uniphier_sld3_pll_init(); - uniphier_ld4_clk_init(); - break; + { + .soc_id = SOC_UNIPHIER_SLD3, + .nand_2cs = true, + .pll_init = uniphier_sld3_pll_init, + .clk_init = uniphier_ld4_clk_init, + }, #endif #if defined(CONFIG_ARCH_UNIPHIER_LD4) - case SOC_UNIPHIER_LD4: - uniphier_nand_pin_init(true); - led_puts("U1"); - uniphier_ld4_pll_init(); - uniphier_ld4_clk_init(); - break; + { + .soc_id = SOC_UNIPHIER_LD4, + .nand_2cs = true, + .pll_init = uniphier_ld4_pll_init, + .clk_init = uniphier_ld4_clk_init, + }, #endif #if defined(CONFIG_ARCH_UNIPHIER_PRO4) - case SOC_UNIPHIER_PRO4: - uniphier_nand_pin_init(false); - led_puts("U1"); - uniphier_pro4_pll_init(); - uniphier_pro4_clk_init(); - break; + { + .soc_id = SOC_UNIPHIER_PRO4, + .nand_2cs = false, + .pll_init = uniphier_pro4_pll_init, + .clk_init = uniphier_pro4_clk_init, + }, #endif #if defined(CONFIG_ARCH_UNIPHIER_SLD8) - case SOC_UNIPHIER_SLD8: - uniphier_nand_pin_init(true); - led_puts("U1"); - uniphier_ld4_pll_init(); - uniphier_ld4_clk_init(); - break; + { + .soc_id = SOC_UNIPHIER_SLD8, + .nand_2cs = true, + .pll_init = uniphier_ld4_pll_init, + .clk_init = uniphier_ld4_clk_init, + }, #endif #if defined(CONFIG_ARCH_UNIPHIER_PRO5) - case SOC_UNIPHIER_PRO5: - uniphier_nand_pin_init(true); - led_puts("U1"); - uniphier_pro5_clk_init(); - break; + { + .soc_id = SOC_UNIPHIER_PRO5, + .nand_2cs = true, + .clk_init = uniphier_pro5_clk_init, + }, #endif #if defined(CONFIG_ARCH_UNIPHIER_PXS2) - case SOC_UNIPHIER_PXS2: - uniphier_nand_pin_init(true); - led_puts("U1"); - uniphier_pxs2_clk_init(); - break; + { + .soc_id = SOC_UNIPHIER_PXS2, + .nand_2cs = true, + .clk_init = uniphier_pxs2_clk_init, + }, #endif #if defined(CONFIG_ARCH_UNIPHIER_LD6B) - case SOC_UNIPHIER_LD6B: - uniphier_nand_pin_init(true); - led_puts("U1"); - uniphier_pxs2_clk_init(); - break; + { + .soc_id = SOC_UNIPHIER_LD6B, + .nand_2cs = true, + .clk_init = uniphier_pxs2_clk_init, + }, #endif #if defined(CONFIG_ARCH_UNIPHIER_LD11) - case SOC_UNIPHIER_LD11: - uniphier_nand_pin_init(false); - sg_set_pinsel(149, 14, 8, 4); /* XIRQ0 -> XIRQ0 */ - sg_set_iectrl(149); - sg_set_pinsel(153, 14, 8, 4); /* XIRQ4 -> XIRQ4 */ - sg_set_iectrl(153); - led_puts("U1"); - uniphier_ld11_pll_init(); - uniphier_ld11_clk_init(); - break; + { + .soc_id = SOC_UNIPHIER_LD11, + .nand_2cs = false, + .pll_init = uniphier_ld11_pll_init, + .clk_init = uniphier_ld11_clk_init, + .misc_init = uniphier_ld11_misc_init, + }, #endif #if defined(CONFIG_ARCH_UNIPHIER_LD20) - case SOC_UNIPHIER_LD20: - /* ES1 errata: increase VDD09 supply to suppress VBO noise */ - if (uniphier_get_soc_revision() == 1) { - writel(0x00000003, 0x6184e004); - writel(0x00000100, 0x6184e040); - writel(0x0000b500, 0x6184e024); - writel(0x00000001, 0x6184e000); - } - uniphier_nand_pin_init(false); - sg_set_pinsel(149, 14, 8, 4); /* XIRQ0 -> XIRQ0 */ - sg_set_iectrl(149); - sg_set_pinsel(153, 14, 8, 4); /* XIRQ4 -> XIRQ4 */ - sg_set_iectrl(153); - led_puts("U1"); - uniphier_ld20_pll_init(); - uniphier_ld20_clk_init(); - cci500_init(2); - break; + { + .soc_id = SOC_UNIPHIER_LD20, + .nand_2cs = false, + .pll_init = uniphier_ld20_pll_init, + .clk_init = uniphier_ld20_clk_init, + .misc_init = uniphier_ld20_misc_init, + }, #endif - default: - break; +}; + +static struct uniphier_initdata *uniphier_get_initdata( + enum uniphier_soc_id soc_id) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(uniphier_initdata); i++) { + if (uniphier_initdata[i].soc_id == soc_id) + return &uniphier_initdata[i]; }
- uniphier_setup_xirq(); + return NULL; +} + +int board_init(void) +{ + struct uniphier_initdata *initdata; + enum uniphier_soc_id soc_id; + int ret; + + led_puts("U0"); + + soc_id = uniphier_get_soc_type(); + initdata = uniphier_get_initdata(soc_id); + if (!initdata) { + pr_err("unsupported board\n"); + return -EINVAL; + } + + if (IS_ENABLED(CONFIG_NAND_DENALI)) { + ret = uniphier_pin_init(initdata->nand_2cs ? + "nand2cs_grp" : "nand_grp"); + if (ret) + pr_err("failed to init NAND pins\n"); + } + + led_puts("U1"); + + if (initdata->pll_init) + initdata->pll_init();
led_puts("U2");
- support_card_late_init(); + initdata->clk_init();
led_puts("U3");
+ if (initdata->misc_init) + initdata->misc_init(); + + led_puts("U4"); + + uniphier_setup_xirq(); + + led_puts("U5"); + + support_card_late_init(); + + led_puts("U6"); + #ifdef CONFIG_ARM64 uniphier_smp_kick_all_cpus(); #endif
Merge init-*.c into a single file using a table of callbacks because the initialization flow is almost common among SoCs.
arch/arm/mach-uniphier/Makefile | 3 +- arch/arm/mach-uniphier/clk/Makefile | 6 +- arch/arm/mach-uniphier/clk/dpll-pro5.c | 6 + arch/arm/mach-uniphier/clk/dpll-pxs2.c | 6 + arch/arm/mach-uniphier/dram/Makefile | 2 + arch/arm/mach-uniphier/dram/umc-pro5.c | 12 ++ arch/arm/mach-uniphier/dram/umc-sld3.c | 6 + arch/arm/mach-uniphier/init.h | 4 + arch/arm/mach-uniphier/init/Makefile | 15 --- arch/arm/mach-uniphier/init/init-ld11.c | 58 --------- arch/arm/mach-uniphier/init/init-ld20.c | 56 --------- arch/arm/mach-uniphier/init/init-ld4.c | 57 --------- arch/arm/mach-uniphier/init/init-pro4.c | 55 --------- arch/arm/mach-uniphier/init/init-pro5.c | 41 ------- arch/arm/mach-uniphier/init/init-pxs2.c | 47 ------- arch/arm/mach-uniphier/init/init-sld3.c | 47 ------- arch/arm/mach-uniphier/init/init-sld8.c | 57 --------- arch/arm/mach-uniphier/init/init.c | 71 ----------- arch/arm/mach-uniphier/spl_board_init.c | 209 ++++++++++++++++++++++++++++++++ 19 files changed, 250 insertions(+), 508 deletions(-) create mode 100644 arch/arm/mach-uniphier/clk/dpll-pro5.c create mode 100644 arch/arm/mach-uniphier/clk/dpll-pxs2.c create mode 100644 arch/arm/mach-uniphier/dram/umc-pro5.c create mode 100644 arch/arm/mach-uniphier/dram/umc-sld3.c delete mode 100644 arch/arm/mach-uniphier/init/Makefile delete mode 100644 arch/arm/mach-uniphier/init/init-ld11.c delete mode 100644 arch/arm/mach-uniphier/init/init-ld20.c delete mode 100644 arch/arm/mach-uniphier/init/init-ld4.c delete mode 100644 arch/arm/mach-uniphier/init/init-pro4.c delete mode 100644 arch/arm/mach-uniphier/init/init-pro5.c delete mode 100644 arch/arm/mach-uniphier/init/init-pxs2.c delete mode 100644 arch/arm/mach-uniphier/init/init-sld3.c delete mode 100644 arch/arm/mach-uniphier/init/init-sld8.c delete mode 100644 arch/arm/mach-uniphier/init/init.c create mode 100644 arch/arm/mach-uniphier/spl_board_init.c
diff --git a/arch/arm/mach-uniphier/Makefile b/arch/arm/mach-uniphier/Makefile index 98b42a0..7f1abd0 100644 --- a/arch/arm/mach-uniphier/Makefile +++ b/arch/arm/mach-uniphier/Makefile @@ -4,8 +4,9 @@
+obj-y += spl_board_init.o obj-y += memconf.o -obj-y += init/ bcu/ +obj-y += bcu/ obj-$(CONFIG_MICRO_SUPPORT_CARD) += sbc/
else diff --git a/arch/arm/mach-uniphier/clk/Makefile b/arch/arm/mach-uniphier/clk/Makefile index 765660f..eff8383 100644 --- a/arch/arm/mach-uniphier/clk/Makefile +++ b/arch/arm/mach-uniphier/clk/Makefile @@ -8,9 +8,9 @@ obj-$(CONFIG_ARCH_UNIPHIER_SLD3) += clk-early-sld3.o clk-dram-sld3.o dpll-sld3.o obj-$(CONFIG_ARCH_UNIPHIER_LD4) += clk-early-sld3.o clk-dram-sld3.o dpll-ld4.o obj-$(CONFIG_ARCH_UNIPHIER_PRO4) += clk-early-sld3.o clk-dram-sld3.o dpll-pro4.o obj-$(CONFIG_ARCH_UNIPHIER_SLD8) += clk-early-sld3.o clk-dram-sld3.o dpll-sld8.o -obj-$(CONFIG_ARCH_UNIPHIER_PRO5) += clk-early-sld3.o clk-dram-pro5.o -obj-$(CONFIG_ARCH_UNIPHIER_PXS2) += clk-early-sld3.o clk-dram-pxs2.o -obj-$(CONFIG_ARCH_UNIPHIER_LD6B) += clk-early-sld3.o clk-dram-pxs2.o +obj-$(CONFIG_ARCH_UNIPHIER_PRO5) += clk-early-sld3.o clk-dram-pro5.o dpll-pro5.o +obj-$(CONFIG_ARCH_UNIPHIER_PXS2) += clk-early-sld3.o clk-dram-pxs2.o dpll-pxs2.o +obj-$(CONFIG_ARCH_UNIPHIER_LD6B) += clk-early-sld3.o clk-dram-pxs2.o dpll-pxs2.o obj-$(CONFIG_ARCH_UNIPHIER_LD11) += clk-early-ld11.o clk-dram-ld11.o dpll-ld11.o obj-$(CONFIG_ARCH_UNIPHIER_LD20) += clk-early-ld11.o clk-dram-ld20.o dpll-ld20.o
diff --git a/arch/arm/mach-uniphier/clk/dpll-pro5.c b/arch/arm/mach-uniphier/clk/dpll-pro5.c new file mode 100644 index 0000000..d3a42c7 --- /dev/null +++ b/arch/arm/mach-uniphier/clk/dpll-pro5.c @@ -0,0 +1,6 @@ +#include "../init.h" + +int uniphier_pro5_dpll_init(const struct uniphier_board_data *bd) +{ + return 0; +} diff --git a/arch/arm/mach-uniphier/clk/dpll-pxs2.c b/arch/arm/mach-uniphier/clk/dpll-pxs2.c new file mode 100644 index 0000000..328ebf6 --- /dev/null +++ b/arch/arm/mach-uniphier/clk/dpll-pxs2.c @@ -0,0 +1,6 @@ +#include "../init.h" + +int uniphier_pxs2_dpll_init(const struct uniphier_board_data *bd) +{ + return 0; +} diff --git a/arch/arm/mach-uniphier/dram/Makefile b/arch/arm/mach-uniphier/dram/Makefile index 5b9d892..2ce6199 100644 --- a/arch/arm/mach-uniphier/dram/Makefile +++ b/arch/arm/mach-uniphier/dram/Makefile @@ -4,12 +4,14 @@
+obj-$(CONFIG_ARCH_UNIPHIER_SLD3) += umc-sld3.o obj-$(CONFIG_ARCH_UNIPHIER_LD4) += umc-ld4.o \ ddrphy-training.o ddrphy-ld4.o obj-$(CONFIG_ARCH_UNIPHIER_PRO4) += umc-pro4.o \ ddrphy-training.o ddrphy-ld4.o obj-$(CONFIG_ARCH_UNIPHIER_SLD8) += umc-sld8.o \ ddrphy-training.o ddrphy-ld4.o +obj-$(CONFIG_ARCH_UNIPHIER_PRO5) += umc-pro5.o obj-$(CONFIG_ARCH_UNIPHIER_PXS2) += umc-pxs2.o obj-$(CONFIG_ARCH_UNIPHIER_LD6B) += umc-pxs2.o obj-$(CONFIG_ARCH_UNIPHIER_LD11) += umc-ld11.o diff --git a/arch/arm/mach-uniphier/dram/umc-pro5.c b/arch/arm/mach-uniphier/dram/umc-pro5.c new file mode 100644 index 0000000..4f34d1f --- /dev/null +++ b/arch/arm/mach-uniphier/dram/umc-pro5.c @@ -0,0 +1,12 @@ +/* + * Copyright (C) 2016 Socionext Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include "../init.h" + +int uniphier_pro5_umc_init(const struct uniphier_board_data *bd) +{ + return 0; +} diff --git a/arch/arm/mach-uniphier/dram/umc-sld3.c b/arch/arm/mach-uniphier/dram/umc-sld3.c new file mode 100644 index 0000000..99249eb --- /dev/null +++ b/arch/arm/mach-uniphier/dram/umc-sld3.c @@ -0,0 +1,6 @@ +#include "../init.h" + +int uniphier_sld3_umc_init(const struct uniphier_board_data *bd) +{ + return 0; +} diff --git a/arch/arm/mach-uniphier/init.h b/arch/arm/mach-uniphier/init.h index 18393e5..2f9dc39 100644 --- a/arch/arm/mach-uniphier/init.h +++ b/arch/arm/mach-uniphier/init.h @@ -84,6 +84,8 @@ int uniphier_sld3_dpll_init(const struct uniphier_board_data *bd); int uniphier_ld4_dpll_init(const struct uniphier_board_data *bd); int uniphier_pro4_dpll_init(const struct uniphier_board_data *bd); int uniphier_sld8_dpll_init(const struct uniphier_board_data *bd); +int uniphier_pro5_dpll_init(const struct uniphier_board_data *bd); +int uniphier_pxs2_dpll_init(const struct uniphier_board_data *bd); int uniphier_ld11_dpll_init(const struct uniphier_board_data *bd); int uniphier_ld20_dpll_init(const struct uniphier_board_data *bd);
@@ -96,9 +98,11 @@ void uniphier_pxs2_dram_clk_init(void); void uniphier_ld11_dram_clk_init(void); void uniphier_ld20_dram_clk_init(void);
+int uniphier_sld3_umc_init(const struct uniphier_board_data *bd); int uniphier_ld4_umc_init(const struct uniphier_board_data *bd); int uniphier_pro4_umc_init(const struct uniphier_board_data *bd); int uniphier_sld8_umc_init(const struct uniphier_board_data *bd); +int uniphier_pro5_umc_init(const struct uniphier_board_data *bd); int uniphier_pxs2_umc_init(const struct uniphier_board_data *bd); int uniphier_ld20_umc_init(const struct uniphier_board_data *bd); int uniphier_ld11_umc_init(const struct uniphier_board_data *bd); diff --git a/arch/arm/mach-uniphier/init/Makefile b/arch/arm/mach-uniphier/init/Makefile deleted file mode 100644 index dcaa445..0000000 --- a/arch/arm/mach-uniphier/init/Makefile +++ /dev/null @@ -1,15 +0,0 @@ -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y += init.o - -obj-$(CONFIG_ARCH_UNIPHIER_SLD3) += init-sld3.o -obj-$(CONFIG_ARCH_UNIPHIER_LD4) += init-ld4.o -obj-$(CONFIG_ARCH_UNIPHIER_PRO4) += init-pro4.o -obj-$(CONFIG_ARCH_UNIPHIER_SLD8) += init-sld8.o -obj-$(CONFIG_ARCH_UNIPHIER_PRO5) += init-pro5.o -obj-$(CONFIG_ARCH_UNIPHIER_PXS2) += init-pxs2.o -obj-$(CONFIG_ARCH_UNIPHIER_LD6B) += init-pxs2.o -obj-$(CONFIG_ARCH_UNIPHIER_LD11) += init-ld11.o -obj-$(CONFIG_ARCH_UNIPHIER_LD20) += init-ld20.o diff --git a/arch/arm/mach-uniphier/init/init-ld11.c b/arch/arm/mach-uniphier/init/init-ld11.c deleted file mode 100644 index e19dc5b..0000000 --- a/arch/arm/mach-uniphier/init/init-ld11.c +++ /dev/null @@ -1,58 +0,0 @@ -/* - * Copyright (C) 2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <spl.h> - -#include "../init.h" -#include "../micro-support-card.h" - -int uniphier_ld11_init(const struct uniphier_board_data *bd) -{ - uniphier_ld11_sbc_init(); - - support_card_init(); - - led_puts("L0"); - - uniphier_memconf_2ch_init(bd); - - led_puts("L1"); - - uniphier_ld11_early_clk_init(); - uniphier_ld11_dram_clk_init(); - - led_puts("L2"); - -#ifdef CONFIG_SPL_SERIAL_SUPPORT - preloader_console_init(); -#endif - - led_puts("L3"); - - uniphier_ld11_dpll_init(bd); - - led_puts("L4"); - - { - int res; - - res = uniphier_ld11_umc_init(bd); - if (res < 0) { - while (1) - ; - } - } - - led_puts("L5"); - - dcache_disable(); - - led_puts("L6"); - - return 0; -} diff --git a/arch/arm/mach-uniphier/init/init-ld20.c b/arch/arm/mach-uniphier/init/init-ld20.c deleted file mode 100644 index e056d5d..0000000 --- a/arch/arm/mach-uniphier/init/init-ld20.c +++ /dev/null @@ -1,56 +0,0 @@ -/* - * Copyright (C) 2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <spl.h> - -#include "../init.h" -#include "../micro-support-card.h" - -int uniphier_ld20_init(const struct uniphier_board_data *bd) -{ - uniphier_ld11_sbc_init(); - - support_card_init(); - - led_puts("L0"); - - uniphier_memconf_3ch_init(bd); - - led_puts("L1"); - - uniphier_ld11_early_clk_init(); - uniphier_ld20_dram_clk_init(); - - led_puts("L2"); - -#ifdef CONFIG_SPL_SERIAL_SUPPORT - preloader_console_init(); -#endif - - led_puts("L3"); - - uniphier_ld20_dpll_init(bd); - - led_puts("L4"); - - { - int res; - - res = uniphier_ld20_umc_init(bd); - if (res < 0) { - while (1) - ; - } - } - - led_puts("L5"); - - dcache_disable(); - - return 0; -} diff --git a/arch/arm/mach-uniphier/init/init-ld4.c b/arch/arm/mach-uniphier/init/init-ld4.c deleted file mode 100644 index a5b9493..0000000 --- a/arch/arm/mach-uniphier/init/init-ld4.c +++ /dev/null @@ -1,57 +0,0 @@ -/* - * Copyright (C) 2013-2015 Panasonic Corporation - * Copyright (C) 2015-2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <spl.h> - -#include "../init.h" -#include "../micro-support-card.h" - -int uniphier_ld4_init(const struct uniphier_board_data *bd) -{ - uniphier_ld4_bcu_init(bd); - - uniphier_ld4_sbc_init(); - - support_card_init(); - - uniphier_ld4_dpll_init(bd); - - led_puts("L0"); - - uniphier_memconf_2ch_init(bd); - - led_puts("L1"); - - uniphier_sld3_early_clk_init(); - uniphier_sld3_dram_clk_init(); - - led_puts("L2"); - - led_puts("L3"); - -#ifdef CONFIG_SPL_SERIAL_SUPPORT - preloader_console_init(); -#endif - - led_puts("L4"); - - { - int res; - - res = uniphier_ld4_umc_init(bd); - if (res < 0) { - while (1) - ; - } - } - - led_puts("L5"); - - return 0; -} diff --git a/arch/arm/mach-uniphier/init/init-pro4.c b/arch/arm/mach-uniphier/init/init-pro4.c deleted file mode 100644 index c277071..0000000 --- a/arch/arm/mach-uniphier/init/init-pro4.c +++ /dev/null @@ -1,55 +0,0 @@ -/* - * Copyright (C) 2013-2015 Panasonic Corporation - * Copyright (C) 2015-2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <spl.h> - -#include "../init.h" -#include "../micro-support-card.h" - -int uniphier_pro4_init(const struct uniphier_board_data *bd) -{ - uniphier_sbc_init_savepin(); - - support_card_init(); - - uniphier_pro4_dpll_init(bd); - - led_puts("L0"); - - uniphier_memconf_2ch_init(bd); - - led_puts("L1"); - - uniphier_sld3_early_clk_init(); - uniphier_sld3_dram_clk_init(); - - led_puts("L2"); - - led_puts("L3"); - -#ifdef CONFIG_SPL_SERIAL_SUPPORT - preloader_console_init(); -#endif - - led_puts("L4"); - - { - int res; - - res = uniphier_pro4_umc_init(bd); - if (res < 0) { - while (1) - ; - } - } - - led_puts("L5"); - - return 0; -} diff --git a/arch/arm/mach-uniphier/init/init-pro5.c b/arch/arm/mach-uniphier/init/init-pro5.c deleted file mode 100644 index 4e7041b..0000000 --- a/arch/arm/mach-uniphier/init/init-pro5.c +++ /dev/null @@ -1,41 +0,0 @@ -/* - * Copyright (C) 2015 Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <spl.h> - -#include "../init.h" -#include "../micro-support-card.h" - -int uniphier_pro5_init(const struct uniphier_board_data *bd) -{ - uniphier_sbc_init_savepin(); - - support_card_init(); - - led_puts("L0"); - - uniphier_memconf_2ch_init(bd); - - led_puts("L1"); - - uniphier_sld3_early_clk_init(); - uniphier_pro5_dram_clk_init(); - - led_puts("L2"); - - led_puts("L3"); - -#ifdef CONFIG_SPL_SERIAL_SUPPORT - preloader_console_init(); -#endif - - led_puts("L4"); - - led_puts("L5"); - - return 0; -} diff --git a/arch/arm/mach-uniphier/init/init-pxs2.c b/arch/arm/mach-uniphier/init/init-pxs2.c deleted file mode 100644 index f7d5b48..0000000 --- a/arch/arm/mach-uniphier/init/init-pxs2.c +++ /dev/null @@ -1,47 +0,0 @@ -/* - * Copyright (C) 2015 Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <spl.h> - -#include "../init.h" -#include "../micro-support-card.h" - -int uniphier_pxs2_init(const struct uniphier_board_data *bd) -{ - int ret; - - uniphier_pxs2_sbc_init(); - - support_card_init(); - - led_puts("L0"); - - uniphier_memconf_3ch_init(bd); - - led_puts("L1"); - - uniphier_sld3_early_clk_init(); - uniphier_pxs2_dram_clk_init(); - - led_puts("L2"); - - led_puts("L3"); - -#ifdef CONFIG_SPL_SERIAL_SUPPORT - preloader_console_init(); -#endif - - led_puts("L4"); - - ret = uniphier_pxs2_umc_init(bd); - if (ret) - return ret; - - led_puts("L5"); - - return 0; -} diff --git a/arch/arm/mach-uniphier/init/init-sld3.c b/arch/arm/mach-uniphier/init/init-sld3.c deleted file mode 100644 index 50d9eaf..0000000 --- a/arch/arm/mach-uniphier/init/init-sld3.c +++ /dev/null @@ -1,47 +0,0 @@ -/* - * Copyright (C) 2013-2015 Panasonic Corporation - * Copyright (C) 2015-2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <spl.h> - -#include "../init.h" -#include "../micro-support-card.h" - -int uniphier_sld3_init(const struct uniphier_board_data *bd) -{ - uniphier_sld3_bcu_init(bd); - - uniphier_sbc_init_admulti(); - - support_card_init(); - - uniphier_sld3_dpll_init(bd); - - led_puts("L0"); - - uniphier_memconf_3ch_no_disbit_init(bd); - - led_puts("L1"); - - uniphier_sld3_early_clk_init(); - uniphier_sld3_dram_clk_init(); - - led_puts("L2"); - - led_puts("L3"); - -#ifdef CONFIG_SPL_SERIAL_SUPPORT - preloader_console_init(); -#endif - - led_puts("L4"); - - led_puts("L5"); - - return 0; -} diff --git a/arch/arm/mach-uniphier/init/init-sld8.c b/arch/arm/mach-uniphier/init/init-sld8.c deleted file mode 100644 index 8da2843..0000000 --- a/arch/arm/mach-uniphier/init/init-sld8.c +++ /dev/null @@ -1,57 +0,0 @@ -/* - * Copyright (C) 2013-2015 Panasonic Corporation - * Copyright (C) 2015-2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <spl.h> - -#include "../init.h" -#include "../micro-support-card.h" - -int uniphier_sld8_init(const struct uniphier_board_data *bd) -{ - uniphier_ld4_bcu_init(bd); - - uniphier_ld4_sbc_init(); - - support_card_init(); - - uniphier_sld8_dpll_init(bd); - - led_puts("L0"); - - uniphier_memconf_2ch_init(bd); - - led_puts("L1"); - - uniphier_sld3_early_clk_init(); - uniphier_sld3_dram_clk_init(); - - led_puts("L2"); - - led_puts("L3"); - -#ifdef CONFIG_SPL_SERIAL_SUPPORT - preloader_console_init(); -#endif - - led_puts("L4"); - - { - int res; - - res = uniphier_sld8_umc_init(bd); - if (res < 0) { - while (1) - ; - } - } - - led_puts("L5"); - - return 0; -} diff --git a/arch/arm/mach-uniphier/init/init.c b/arch/arm/mach-uniphier/init/init.c deleted file mode 100644 index 77e5b99..0000000 --- a/arch/arm/mach-uniphier/init/init.c +++ /dev/null @@ -1,71 +0,0 @@ -/* - * Copyright (C) 2015 Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <debug_uart.h> -#include <spl.h> - -#include "../init.h" -#include "../soc-info.h" - -void spl_board_init(void) -{ - const struct uniphier_board_data *param; - -#ifdef CONFIG_DEBUG_UART - debug_uart_init(); -#endif - - param = uniphier_get_board_param(); - if (!param) - hang(); - - switch (uniphier_get_soc_type()) { -#if defined(CONFIG_ARCH_UNIPHIER_SLD3) - case SOC_UNIPHIER_SLD3: - uniphier_sld3_init(param); - break; -#endif -#if defined(CONFIG_ARCH_UNIPHIER_LD4) - case SOC_UNIPHIER_LD4: - uniphier_ld4_init(param); - break; -#endif -#if defined(CONFIG_ARCH_UNIPHIER_PRO4) - case SOC_UNIPHIER_PRO4: - uniphier_pro4_init(param); - break; -#endif -#if defined(CONFIG_ARCH_UNIPHIER_SLD8) - case SOC_UNIPHIER_SLD8: - uniphier_sld8_init(param); - break; -#endif -#if defined(CONFIG_ARCH_UNIPHIER_PRO5) - case SOC_UNIPHIER_PRO5: - uniphier_pro5_init(param); - break; -#endif -#if defined(CONFIG_ARCH_UNIPHIER_PXS2) || defined(CONFIG_ARCH_UNIPHIER_LD6B) - case SOC_UNIPHIER_PXS2: - case SOC_UNIPHIER_LD6B: - uniphier_pxs2_init(param); - break; -#endif -#if defined(CONFIG_ARCH_UNIPHIER_LD11) - case SOC_UNIPHIER_LD11: - uniphier_ld11_init(param); - break; -#endif -#if defined(CONFIG_ARCH_UNIPHIER_LD20) - case SOC_UNIPHIER_LD20: - uniphier_ld20_init(param); - break; -#endif - default: - break; - } -} diff --git a/arch/arm/mach-uniphier/spl_board_init.c b/arch/arm/mach-uniphier/spl_board_init.c new file mode 100644 index 0000000..d1e1ea7 --- /dev/null +++ b/arch/arm/mach-uniphier/spl_board_init.c @@ -0,0 +1,209 @@ +/* + * Copyright (C) 2015-2016 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <debug_uart.h> +#include <spl.h> + +#include "init.h" +#include "micro-support-card.h" +#include "soc-info.h" + +struct uniphier_spl_initdata { + enum uniphier_soc_id soc_id; + void (*bcu_init)(const struct uniphier_board_data *bd); + void (*early_clk_init)(void); + void (*sbc_init)(void); + int (*dpll_init)(const struct uniphier_board_data *bd); + int (*memconf_init)(const struct uniphier_board_data *bd); + void (*dram_clk_init)(void); + int (*umc_init)(const struct uniphier_board_data *bd); +}; + +static const struct uniphier_spl_initdata uniphier_spl_initdata[] = { +#if defined(CONFIG_ARCH_UNIPHIER_SLD3) + { + .soc_id = SOC_UNIPHIER_SLD3, + .bcu_init = uniphier_sld3_bcu_init, + .early_clk_init = uniphier_sld3_early_clk_init, + .sbc_init = uniphier_sbc_init_admulti, + .dpll_init = uniphier_sld3_dpll_init, + .memconf_init = uniphier_memconf_3ch_no_disbit_init, + .dram_clk_init = uniphier_sld3_dram_clk_init, + .umc_init = uniphier_sld3_umc_init, + }, +#endif +#if defined(CONFIG_ARCH_UNIPHIER_LD4) + { + .soc_id = SOC_UNIPHIER_LD4, + .bcu_init = uniphier_ld4_bcu_init, + .early_clk_init = uniphier_sld3_early_clk_init, + .sbc_init = uniphier_ld4_sbc_init, + .dpll_init = uniphier_ld4_dpll_init, + .memconf_init = uniphier_memconf_2ch_init, + .dram_clk_init = uniphier_sld3_dram_clk_init, + .umc_init = uniphier_ld4_umc_init, + }, +#endif +#if defined(CONFIG_ARCH_UNIPHIER_PRO4) + { + .soc_id = SOC_UNIPHIER_PRO4, + .early_clk_init = uniphier_sld3_early_clk_init, + .sbc_init = uniphier_sbc_init_savepin, + .dpll_init = uniphier_pro4_dpll_init, + .memconf_init = uniphier_memconf_2ch_init, + .dram_clk_init = uniphier_sld3_dram_clk_init, + .umc_init = uniphier_pro4_umc_init, + }, +#endif +#if defined(CONFIG_ARCH_UNIPHIER_SLD8) + { + .soc_id = SOC_UNIPHIER_SLD8, + .bcu_init = uniphier_ld4_bcu_init, + .early_clk_init = uniphier_sld3_early_clk_init, + .sbc_init = uniphier_ld4_sbc_init, + .dpll_init = uniphier_sld8_dpll_init, + .memconf_init = uniphier_memconf_2ch_init, + .dram_clk_init = uniphier_sld3_dram_clk_init, + .umc_init = uniphier_sld8_umc_init, + }, +#endif +#if defined(CONFIG_ARCH_UNIPHIER_PRO5) + { + .soc_id = SOC_UNIPHIER_PRO5, + .early_clk_init = uniphier_sld3_early_clk_init, + .sbc_init = uniphier_sbc_init_savepin, + .dpll_init = uniphier_pro5_dpll_init, + .memconf_init = uniphier_memconf_2ch_init, + .dram_clk_init = uniphier_pro5_dram_clk_init, + .umc_init = uniphier_pro5_umc_init, + }, +#endif +#if defined(CONFIG_ARCH_UNIPHIER_PXS2) + { + .soc_id = SOC_UNIPHIER_PXS2, + .early_clk_init = uniphier_sld3_early_clk_init, + .sbc_init = uniphier_pxs2_sbc_init, + .dpll_init = uniphier_pxs2_dpll_init, + .memconf_init = uniphier_memconf_3ch_init, + .dram_clk_init = uniphier_pxs2_dram_clk_init, + .umc_init = uniphier_pxs2_umc_init, + }, +#endif +#if defined(CONFIG_ARCH_UNIPHIER_LD6B) + { + .soc_id = SOC_UNIPHIER_LD6B, + .early_clk_init = uniphier_sld3_early_clk_init, + .sbc_init = uniphier_pxs2_sbc_init, + .dpll_init = uniphier_pxs2_dpll_init, + .memconf_init = uniphier_memconf_3ch_init, + .dram_clk_init = uniphier_pxs2_dram_clk_init, + .umc_init = uniphier_pxs2_umc_init, + }, +#endif +#if defined(CONFIG_ARCH_UNIPHIER_LD11) + { + .soc_id = SOC_UNIPHIER_LD11, + .early_clk_init = uniphier_ld11_early_clk_init, + .sbc_init = uniphier_ld11_sbc_init, + .dpll_init = uniphier_ld11_dpll_init, + .memconf_init = uniphier_memconf_2ch_init, + .dram_clk_init = uniphier_ld11_dram_clk_init, + .umc_init = uniphier_ld11_umc_init, + }, +#endif +#if defined(CONFIG_ARCH_UNIPHIER_LD20) + { + .soc_id = SOC_UNIPHIER_LD20, + .early_clk_init = uniphier_ld11_early_clk_init, + .sbc_init = uniphier_ld11_sbc_init, + .dpll_init = uniphier_ld20_dpll_init, + .memconf_init = uniphier_memconf_3ch_init, + .dram_clk_init = uniphier_ld20_dram_clk_init, + .umc_init = uniphier_ld20_umc_init, + }, +#endif +}; + +static const struct uniphier_spl_initdata *uniphier_get_spl_initdata( + enum uniphier_soc_id soc_id) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(uniphier_spl_initdata); i++) { + if (uniphier_spl_initdata[i].soc_id == soc_id) + return &uniphier_spl_initdata[i]; + } + + return NULL; +} + +void spl_board_init(void) +{ + const struct uniphier_board_data *bd; + const struct uniphier_spl_initdata *initdata; + enum uniphier_soc_id soc_id; + int ret; + +#ifdef CONFIG_DEBUG_UART + debug_uart_init(); +#endif + + bd = uniphier_get_board_param(); + if (!bd) + hang(); + + soc_id = uniphier_get_soc_type(); + initdata = uniphier_get_spl_initdata(soc_id); + if (!initdata) + hang(); + + if (initdata->bcu_init) + initdata->bcu_init(bd); + + initdata->sbc_init(); + + initdata->early_clk_init(); + + support_card_init(); + + led_puts("L0"); + +#ifdef CONFIG_SPL_SERIAL_SUPPORT + preloader_console_init(); +#endif + + led_puts("L1"); + + ret = initdata->dpll_init(bd); + if (ret) { + pr_err("failed to init DPLL\n"); + hang(); + } + + led_puts("L2"); + + ret = initdata->memconf_init(bd); + if (ret) { + pr_err("failed to init MEMCONF\n"); + hang(); + } + + led_puts("L3"); + + initdata->dram_clk_init(); + + led_puts("L4"); + + ret = initdata->umc_init(bd); + if (ret) { + pr_err("failed to init DRAM\n"); + hang(); + } + + led_puts("L5"); +}
Initialize SBC and Support Card in U-Boot proper instead of SPL.
We may run different firmware (ex. ARM Trusted Firmware) before U-Boot, and basic SoC initialization may be done there. In that case, SPL may not be used.
The motivation for preparing SBC and Support Card in SPL was to use LED for early debugging, but this is not mandatory to boot SoCs. With this commit, LED will be unavailable in SPL, but we can use a debug serial instead. So, this change will not be a big deal.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/mach-uniphier/Makefile | 6 +++--- arch/arm/mach-uniphier/board_init.c | 16 ++++++++++++++++ arch/arm/mach-uniphier/spl_board_init.c | 24 ------------------------ 3 files changed, 19 insertions(+), 27 deletions(-)
diff --git a/arch/arm/mach-uniphier/Makefile b/arch/arm/mach-uniphier/Makefile index 7f1abd0..ab2c6dc 100644 --- a/arch/arm/mach-uniphier/Makefile +++ b/arch/arm/mach-uniphier/Makefile @@ -7,7 +7,6 @@ ifdef CONFIG_SPL_BUILD obj-y += spl_board_init.o obj-y += memconf.o obj-y += bcu/ -obj-$(CONFIG_MICRO_SUPPORT_CARD) += sbc/
else
@@ -17,6 +16,9 @@ obj-y += board_init.o obj-$(CONFIG_BOARD_LATE_INIT) += board_late_init.o obj-y += reset.o
+obj-$(CONFIG_MICRO_SUPPORT_CARD) += sbc/ micro-support-card.o +obj-y += pinctrl-glue.o + endif
obj-y += boards.o @@ -24,9 +26,7 @@ obj-y += soc_info.o obj-y += boot-mode/ obj-y += clk/ obj-y += dram/ -obj-y += pinctrl-glue.o
-obj-$(CONFIG_MICRO_SUPPORT_CARD) += micro-support-card.o obj-$(CONFIG_DEBUG_UART_UNIPHIER) += debug-uart/
obj-$(CONFIG_CPU_V7) += arm32/ diff --git a/arch/arm/mach-uniphier/board_init.c b/arch/arm/mach-uniphier/board_init.c index 77f1fb0..3bd4cdd 100644 --- a/arch/arm/mach-uniphier/board_init.c +++ b/arch/arm/mach-uniphier/board_init.c @@ -81,6 +81,7 @@ static void uniphier_ld20_misc_init(void) struct uniphier_initdata { enum uniphier_soc_id soc_id; bool nand_2cs; + void (*sbc_init)(void); void (*pll_init)(void); void (*clk_init)(void); void (*misc_init)(void); @@ -91,6 +92,7 @@ struct uniphier_initdata uniphier_initdata[] = { { .soc_id = SOC_UNIPHIER_SLD3, .nand_2cs = true, + .sbc_init = uniphier_sbc_init_admulti, .pll_init = uniphier_sld3_pll_init, .clk_init = uniphier_ld4_clk_init, }, @@ -99,6 +101,7 @@ struct uniphier_initdata uniphier_initdata[] = { { .soc_id = SOC_UNIPHIER_LD4, .nand_2cs = true, + .sbc_init = uniphier_ld4_sbc_init, .pll_init = uniphier_ld4_pll_init, .clk_init = uniphier_ld4_clk_init, }, @@ -107,6 +110,7 @@ struct uniphier_initdata uniphier_initdata[] = { { .soc_id = SOC_UNIPHIER_PRO4, .nand_2cs = false, + .sbc_init = uniphier_sbc_init_savepin, .pll_init = uniphier_pro4_pll_init, .clk_init = uniphier_pro4_clk_init, }, @@ -115,6 +119,7 @@ struct uniphier_initdata uniphier_initdata[] = { { .soc_id = SOC_UNIPHIER_SLD8, .nand_2cs = true, + .sbc_init = uniphier_ld4_sbc_init, .pll_init = uniphier_ld4_pll_init, .clk_init = uniphier_ld4_clk_init, }, @@ -123,6 +128,7 @@ struct uniphier_initdata uniphier_initdata[] = { { .soc_id = SOC_UNIPHIER_PRO5, .nand_2cs = true, + .sbc_init = uniphier_sbc_init_savepin, .clk_init = uniphier_pro5_clk_init, }, #endif @@ -130,6 +136,7 @@ struct uniphier_initdata uniphier_initdata[] = { { .soc_id = SOC_UNIPHIER_PXS2, .nand_2cs = true, + .sbc_init = uniphier_pxs2_sbc_init, .clk_init = uniphier_pxs2_clk_init, }, #endif @@ -137,6 +144,7 @@ struct uniphier_initdata uniphier_initdata[] = { { .soc_id = SOC_UNIPHIER_LD6B, .nand_2cs = true, + .sbc_init = uniphier_pxs2_sbc_init, .clk_init = uniphier_pxs2_clk_init, }, #endif @@ -144,6 +152,7 @@ struct uniphier_initdata uniphier_initdata[] = { { .soc_id = SOC_UNIPHIER_LD11, .nand_2cs = false, + .sbc_init = uniphier_ld11_sbc_init, .pll_init = uniphier_ld11_pll_init, .clk_init = uniphier_ld11_clk_init, .misc_init = uniphier_ld11_misc_init, @@ -153,6 +162,7 @@ struct uniphier_initdata uniphier_initdata[] = { { .soc_id = SOC_UNIPHIER_LD20, .nand_2cs = false, + .sbc_init = uniphier_ld11_sbc_init, .pll_init = uniphier_ld20_pll_init, .clk_init = uniphier_ld20_clk_init, .misc_init = uniphier_ld20_misc_init, @@ -188,6 +198,12 @@ int board_init(void) return -EINVAL; }
+ initdata->sbc_init(); + + support_card_init(); + + led_puts("U0"); + if (IS_ENABLED(CONFIG_NAND_DENALI)) { ret = uniphier_pin_init(initdata->nand_2cs ? "nand2cs_grp" : "nand_grp"); diff --git a/arch/arm/mach-uniphier/spl_board_init.c b/arch/arm/mach-uniphier/spl_board_init.c index d1e1ea7..f4e1cb9 100644 --- a/arch/arm/mach-uniphier/spl_board_init.c +++ b/arch/arm/mach-uniphier/spl_board_init.c @@ -17,7 +17,6 @@ struct uniphier_spl_initdata { enum uniphier_soc_id soc_id; void (*bcu_init)(const struct uniphier_board_data *bd); void (*early_clk_init)(void); - void (*sbc_init)(void); int (*dpll_init)(const struct uniphier_board_data *bd); int (*memconf_init)(const struct uniphier_board_data *bd); void (*dram_clk_init)(void); @@ -30,7 +29,6 @@ static const struct uniphier_spl_initdata uniphier_spl_initdata[] = { .soc_id = SOC_UNIPHIER_SLD3, .bcu_init = uniphier_sld3_bcu_init, .early_clk_init = uniphier_sld3_early_clk_init, - .sbc_init = uniphier_sbc_init_admulti, .dpll_init = uniphier_sld3_dpll_init, .memconf_init = uniphier_memconf_3ch_no_disbit_init, .dram_clk_init = uniphier_sld3_dram_clk_init, @@ -42,7 +40,6 @@ static const struct uniphier_spl_initdata uniphier_spl_initdata[] = { .soc_id = SOC_UNIPHIER_LD4, .bcu_init = uniphier_ld4_bcu_init, .early_clk_init = uniphier_sld3_early_clk_init, - .sbc_init = uniphier_ld4_sbc_init, .dpll_init = uniphier_ld4_dpll_init, .memconf_init = uniphier_memconf_2ch_init, .dram_clk_init = uniphier_sld3_dram_clk_init, @@ -53,7 +50,6 @@ static const struct uniphier_spl_initdata uniphier_spl_initdata[] = { { .soc_id = SOC_UNIPHIER_PRO4, .early_clk_init = uniphier_sld3_early_clk_init, - .sbc_init = uniphier_sbc_init_savepin, .dpll_init = uniphier_pro4_dpll_init, .memconf_init = uniphier_memconf_2ch_init, .dram_clk_init = uniphier_sld3_dram_clk_init, @@ -65,7 +61,6 @@ static const struct uniphier_spl_initdata uniphier_spl_initdata[] = { .soc_id = SOC_UNIPHIER_SLD8, .bcu_init = uniphier_ld4_bcu_init, .early_clk_init = uniphier_sld3_early_clk_init, - .sbc_init = uniphier_ld4_sbc_init, .dpll_init = uniphier_sld8_dpll_init, .memconf_init = uniphier_memconf_2ch_init, .dram_clk_init = uniphier_sld3_dram_clk_init, @@ -76,7 +71,6 @@ static const struct uniphier_spl_initdata uniphier_spl_initdata[] = { { .soc_id = SOC_UNIPHIER_PRO5, .early_clk_init = uniphier_sld3_early_clk_init, - .sbc_init = uniphier_sbc_init_savepin, .dpll_init = uniphier_pro5_dpll_init, .memconf_init = uniphier_memconf_2ch_init, .dram_clk_init = uniphier_pro5_dram_clk_init, @@ -87,7 +81,6 @@ static const struct uniphier_spl_initdata uniphier_spl_initdata[] = { { .soc_id = SOC_UNIPHIER_PXS2, .early_clk_init = uniphier_sld3_early_clk_init, - .sbc_init = uniphier_pxs2_sbc_init, .dpll_init = uniphier_pxs2_dpll_init, .memconf_init = uniphier_memconf_3ch_init, .dram_clk_init = uniphier_pxs2_dram_clk_init, @@ -98,7 +91,6 @@ static const struct uniphier_spl_initdata uniphier_spl_initdata[] = { { .soc_id = SOC_UNIPHIER_LD6B, .early_clk_init = uniphier_sld3_early_clk_init, - .sbc_init = uniphier_pxs2_sbc_init, .dpll_init = uniphier_pxs2_dpll_init, .memconf_init = uniphier_memconf_3ch_init, .dram_clk_init = uniphier_pxs2_dram_clk_init, @@ -109,7 +101,6 @@ static const struct uniphier_spl_initdata uniphier_spl_initdata[] = { { .soc_id = SOC_UNIPHIER_LD11, .early_clk_init = uniphier_ld11_early_clk_init, - .sbc_init = uniphier_ld11_sbc_init, .dpll_init = uniphier_ld11_dpll_init, .memconf_init = uniphier_memconf_2ch_init, .dram_clk_init = uniphier_ld11_dram_clk_init, @@ -120,7 +111,6 @@ static const struct uniphier_spl_initdata uniphier_spl_initdata[] = { { .soc_id = SOC_UNIPHIER_LD20, .early_clk_init = uniphier_ld11_early_clk_init, - .sbc_init = uniphier_ld11_sbc_init, .dpll_init = uniphier_ld20_dpll_init, .memconf_init = uniphier_memconf_3ch_init, .dram_clk_init = uniphier_ld20_dram_clk_init, @@ -165,45 +155,31 @@ void spl_board_init(void) if (initdata->bcu_init) initdata->bcu_init(bd);
- initdata->sbc_init();
#ifdef CONFIG_SPL_SERIAL_SUPPORT preloader_console_init(); #endif
- led_puts("L1"); - ret = initdata->dpll_init(bd); if (ret) { pr_err("failed to init DPLL\n"); hang(); }
- led_puts("L2"); - ret = initdata->memconf_init(bd); if (ret) { pr_err("failed to init MEMCONF\n"); hang(); }
- led_puts("L3"); - initdata->dram_clk_init();
- led_puts("L4"); - ret = initdata->umc_init(bd); if (ret) { pr_err("failed to init DRAM\n"); hang(); } - - led_puts("L5"); }
2017-01-15 14:59 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Mostly cleanups of SoC init code.
Masahiro Yamada (9): ARM: uniphier: remove unneeded argument of uniphier_ld20_pll_init() ARM: uniphier: split out UMC clock enable ARM: uniphier: refactor MEMCONF init code ARM: uniphier: refactor SBC init code ARM: uniphier: refactor Support Card init code ARM: uniphier: make BCU init into void function ARM: uniphier: refactor board_init() ARM: uniphier: refactor spl_init_board() ARM: uniphier: move SBC and Support Card init code to U-Boot proper
Series, applied to u-boot-uniphier/master.
Masahiro Yamada
