[U-Boot] [PATCH 1/1] colibri_imx7: migrate usb to driver model
Migrate USB to Driver Model (CONFIG_DM_USB=y).
Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com --- arch/arm/dts/imx7-colibri-emmc.dts | 37 +++++++++++++++++++++++++ arch/arm/dts/imx7-colibri-rawnand.dts | 40 +++++++++++++++++++++++++++ configs/colibri_imx7_defconfig | 1 + configs/colibri_imx7_emmc_defconfig | 1 + 4 files changed, 79 insertions(+)
diff --git a/arch/arm/dts/imx7-colibri-emmc.dts b/arch/arm/dts/imx7-colibri-emmc.dts index efd600091d..a9f272a65e 100644 --- a/arch/arm/dts/imx7-colibri-emmc.dts +++ b/arch/arm/dts/imx7-colibri-emmc.dts @@ -13,11 +13,30 @@ aliases { mmc0 = &usdhc3; mmc1 = &usdhc1; + usb0 = &usbotg1; /* required for ums */ };
chosen { stdout-path = &uart1; }; + + reg_5v0: regulator-5v0 { + compatible = "regulator-fixed"; + regulator-name = "5V"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + reg_usbh_vbus: regulator-usbh-vbus { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbh_reg>; + regulator-name = "VCC_USB[1-4]"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio4 7 GPIO_ACTIVE_LOW>; + vin-supply = <®_5v0>; + }; };
&usdhc3 { @@ -44,4 +63,22 @@ MX7D_PAD_SD3_STROBE__SD3_STROBE 0x19 >; }; + + pinctrl_usbh_reg: gpio-usbh-vbus { + fsl,pins = < + MX7D_PAD_UART3_CTS_B__GPIO4_IO7 0x14 + >; + }; +}; + +&usbotg2 { + dr_mode = "host"; + vbus-supply = <®_usbh_vbus>; + status = "okay"; +}; + +&usbotg1 { + dr_mode = "host"; + vbus-supply = <®_usbh_vbus>; + status = "okay"; }; diff --git a/arch/arm/dts/imx7-colibri-rawnand.dts b/arch/arm/dts/imx7-colibri-rawnand.dts index 4eb86fb011..e48e750a57 100644 --- a/arch/arm/dts/imx7-colibri-rawnand.dts +++ b/arch/arm/dts/imx7-colibri-rawnand.dts @@ -13,6 +13,28 @@ chosen { stdout-path = &uart1; }; + + aliases { + usb0 = &usbotg1; /* required for ums */ + }; + + reg_5v0: regulator-5v0 { + compatible = "regulator-fixed"; + regulator-name = "5V"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + reg_usbh_vbus: regulator-usbh-vbus { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbh_reg>; + regulator-name = "VCC_USB[1-4]"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio4 7 GPIO_ACTIVE_LOW>; + vin-supply = <®_5v0>; + }; };
&gpmi { @@ -43,4 +65,22 @@ MX7D_PAD_SD3_DATA7__NAND_DATA07 0x71 >; }; + + pinctrl_usbh_reg: gpio-usbh-vbus { + fsl,pins = < + MX7D_PAD_UART3_CTS_B__GPIO4_IO7 0x14 + >; + }; +}; + +&usbotg2 { + dr_mode = "host"; + vbus-supply = <®_usbh_vbus>; + status = "okay"; +}; + +&usbotg1 { + dr_mode = "host"; + vbus-supply = <®_usbh_vbus>; + status = "okay"; }; diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index 7a52361a2a..43af825d5c 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -62,6 +62,7 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7=y CONFIG_DM_PMIC=y CONFIG_PMIC_RN5T567=y +CONFIG_DM_USB=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_GADGET=y diff --git a/configs/colibri_imx7_emmc_defconfig b/configs/colibri_imx7_emmc_defconfig index 5e2a204a88..beec2704c5 100644 --- a/configs/colibri_imx7_emmc_defconfig +++ b/configs/colibri_imx7_emmc_defconfig @@ -64,3 +64,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_VIDEO=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_DM_USB=y
Hi Igor
Just some minor nitpicks below.
Tested-by: Marcel Ziswiler marcel.ziswiler@toradex.com
diff --git a/arch/arm/dts/imx7-colibri-emmc.dts b/arch/arm/dts/imx7- colibri-emmc.dts index efd600091d..a9f272a65e 100644 --- a/arch/arm/dts/imx7-colibri-emmc.dts +++ b/arch/arm/dts/imx7-colibri-emmc.dts @@ -13,11 +13,30 @@ aliases { mmc0 = &usdhc3; mmc1 = &usdhc1;
- pinctrl_usbh_reg: gpio-usbh-vbus {
fsl,pins = <
+&usbotg2 {
- dr_mode = "host";
- vbus-supply = <®_usbh_vbus>;
- status = "okay";
+&usbotg1 {
- dr_mode = "host";
That is actually not quite correct for Colibri. On Colibri the turning on of the USB host power is actually done purely in hardware based on the cable detect pin. You may also see this when looking at e.g. the Colibri iMX6 device tree.
- status = "okay";
- aliases {
- reg_5v0: regulator-5v0 {
- reg_usbh_vbus: regulator-usbh-vbus {
fsl,pins = <
+&usbotg2 {
- dr_mode = "host";
- status = "okay";
+&usbotg1 {
- dr_mode = "host";
Also drop the above as previously mentioned.
- status = "okay";
Cheers
Marcel
Igor Opaniuk
Marcel Ziswiler
