[PATCH 1/1] doc: dfu: add DFU to HTML documentation
Add the device firmware update functions to the generated HTML documentation.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/api/dfu.rst | 7 +++++++ doc/api/index.rst | 1 + include/dfu.h | 40 ++++++++++++++++++++-------------------- 3 files changed, 28 insertions(+), 20 deletions(-) create mode 100644 doc/api/dfu.rst
diff --git a/doc/api/dfu.rst b/doc/api/dfu.rst new file mode 100644 index 0000000000..5bd9e292a5 --- /dev/null +++ b/doc/api/dfu.rst @@ -0,0 +1,7 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Device firmware update +====================== + +.. kernel-doc:: include/dfu.h + :internal: diff --git a/doc/api/index.rst b/doc/api/index.rst index 2578abd40e..fd3b5bdc82 100644 --- a/doc/api/index.rst +++ b/doc/api/index.rst @@ -6,6 +6,7 @@ U-Boot API documentation .. toctree:: :maxdepth: 2
+ dfu efi linker_lists serial diff --git a/include/dfu.h b/include/dfu.h index 2f0e335ec0..00e1543944 100644 --- a/include/dfu.h +++ b/include/dfu.h @@ -188,23 +188,23 @@ int dfu_write(struct dfu_entity *de, void *buf, int size, int blk_seq_num); int dfu_flush(struct dfu_entity *de, void *buf, int size, int blk_seq_num);
/** - * dfu_initiated_callback - weak callback called on DFU transaction start + * dfu_initiated_callback() - weak callback called on DFU transaction start * * It is a callback function called by DFU stack when a DFU transaction is * initiated. This function allows to manage some board specific behavior on * DFU targets. * - * @param dfu - pointer to the dfu_entity, which should be initialized + * @dfu: pointer to the dfu_entity, which should be initialized * */ void dfu_initiated_callback(struct dfu_entity *dfu); /** - * dfu_flush_callback - weak callback called at the end of the DFU write + * dfu_flush_callback() - weak callback called at the end of the DFU write * * It is a callback function called by DFU stack after DFU manifestation. * This function allows to manage some board specific behavior on DFU targets * - * @param dfu - pointer to the dfu_entity, which should be flushed + * @dfu: pointer to the dfu_entity, which should be flushed * */ void dfu_flush_callback(struct dfu_entity *dfu); @@ -218,9 +218,9 @@ void dfu_transaction_cleanup(struct dfu_entity *dfu); */ extern struct dfu_entity *dfu_defer_flush; /** - * dfu_get_defer_flush - get current value of dfu_defer_flush pointer + * dfu_get_defer_flush() - get current value of dfu_defer_flush pointer * - * @return - value of the dfu_defer_flush pointer + * Return: value of the dfu_defer_flush pointer */ static inline struct dfu_entity *dfu_get_defer_flush(void) { @@ -228,9 +228,9 @@ static inline struct dfu_entity *dfu_get_defer_flush(void) }
/** - * dfu_set_defer_flush - set the dfu_defer_flush pointer + * dfu_set_defer_flush() - set the dfu_defer_flush pointer * - * @param dfu - pointer to the dfu_entity, which should be written + * @dfu: pointer to the dfu_entity, which should be written */ static inline void dfu_set_defer_flush(struct dfu_entity *dfu) { @@ -238,16 +238,16 @@ static inline void dfu_set_defer_flush(struct dfu_entity *dfu) }
/** - * dfu_write_from_mem_addr - write data from memory to DFU managed medium + * dfu_write_from_mem_addr() - write data from memory to DFU managed medium * * This function adds support for writing data starting from fixed memory * address (like $loadaddr) to dfu managed medium (e.g. NAND, MMC, file system) * - * @param dfu - dfu entity to which we want to store data - * @param buf - fixed memory addres from where data starts - * @param size - number of bytes to write + * @dfu: dfu entity to which we want to store data + * @buf: fixed memory addres from where data starts + * @size: number of bytes to write * - * @return - 0 on success, other value on failure + * Return: 0 on success, other value on failure */ int dfu_write_from_mem_addr(struct dfu_entity *dfu, void *buf, int size);
@@ -324,17 +324,17 @@ static inline int dfu_fill_entity_virt(struct dfu_entity *dfu, char *devstr, #endif
/** - * dfu_tftp_write - Write TFTP data to DFU medium + * dfu_tftp_write() - write TFTP data to DFU medium * * This function is storing data received via TFTP on DFU supported medium. * - * @param dfu_entity_name - name of DFU entity to write - * @param addr - address of data buffer to write - * @param len - number of bytes - * @param interface - destination DFU medium (e.g. "mmc") - * @param devstring - instance number of destination DFU medium (e.g. "1") + * @dfu_entity_name: name of DFU entity to write + * @addr: address of data buffer to write + * @len: number of bytes + * @interface: destination DFU medium (e.g. "mmc") + * @devstring: instance number of destination DFU medium (e.g. "1") * - * @return 0 on success, otherwise error code + * Return: 0 on success, otherwise error code */ #if CONFIG_IS_ENABLED(DFU_TFTP) int dfu_tftp_write(char *dfu_entity_name, unsigned int addr, unsigned int len, -- 2.26.2
On Sat, 23 May 2020 12:01:08 +0200 Heinrich Schuchardt xypron.glpk@gmx.de wrote:
- :internal:
- dfu efi linker_lists serial
- dfu_initiated_callback - weak callback called on DFU transaction
start
- dfu_initiated_callback() - weak callback called on DFU
transaction start *
- It is a callback function called by DFU stack when a DFU
transaction is
- initiated. This function allows to manage some board specific
behavior on
- DFU targets.
- @param dfu - pointer to the dfu_entity, which should be
initialized
- @dfu: pointer to the dfu_entity, which should be
- dfu_flush_callback - weak callback called at the end of the DFU
write
- dfu_flush_callback() - weak callback called at the end of the DFU
write *
- It is a callback function called by DFU stack after DFU
manifestation.
- This function allows to manage some board specific behavior on
DFU targets *
- @param dfu - pointer to the dfu_entity, which should be flushed
- @dfu: pointer to the dfu_entity, which should be flushed
- dfu_get_defer_flush - get current value of dfu_defer_flush pointer
- dfu_get_defer_flush() - get current value of dfu_defer_flush
pointer *
- @return - value of the dfu_defer_flush pointer
- Return: value of the dfu_defer_flush pointer
- dfu_set_defer_flush - set the dfu_defer_flush pointer
- dfu_set_defer_flush() - set the dfu_defer_flush pointer
- @param dfu - pointer to the dfu_entity, which should be written
- @dfu: pointer to the dfu_entity, which should be written
- dfu_write_from_mem_addr - write data from memory to DFU managed
medium
- dfu_write_from_mem_addr() - write data from memory to DFU managed
medium *
- This function adds support for writing data starting from fixed
memory
- address (like $loadaddr) to dfu managed medium (e.g. NAND, MMC,
file system) *
- @param dfu - dfu entity to which we want to store data
- @param buf - fixed memory addres from where data starts
- @param size - number of bytes to write
- @dfu: dfu entity to which we want to store data
- @buf: fixed memory addres from where data starts
- @size: number of bytes to write
- @return - 0 on success, other value on failure
- Return: 0 on success, other value on failure
- dfu_tftp_write - Write TFTP data to DFU medium
- dfu_tftp_write() - write TFTP data to DFU medium
- This function is storing data received via TFTP on DFU supported
medium. *
- @param dfu_entity_name - name of DFU entity to write
- @param addr - address of data buffer to write
- @param len - number of bytes
- @param interface - destination DFU medium (e.g. "mmc")
- @param devstring - instance number of destination DFU medium
(e.g. "1")
- @dfu_entity_name: name of DFU entity to write
- @addr: address of data buffer to write
- @len: number of bytes
- @interface: destination DFU medium (e.g. "mmc")
- @devstring: instance number of destination DFU
medium (e.g. "1") *
- @return 0 on success, otherwise error code
- Return: 0 on success, otherwise error code
Acked-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de Acked-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
