[U-Boot] [PATCH] spi: Add support SH Queued SPI driver
This patch adds a driver for Renesas SoC's Queued SPI bus. This supports with 8 bits per transfer to use with SPI flash.
Signed-off-by: Kouei Abe kouei.abe.cp@renesas.com Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- drivers/spi/Makefile | 1 + drivers/spi/sh_qspi.c | 204 ++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/spi/sh_qspi.h | 56 ++++++++++++++ 3 files changed, 261 insertions(+) create mode 100644 drivers/spi/sh_qspi.c create mode 100644 drivers/spi/sh_qspi.h
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 019132e..f71c089 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -33,6 +33,7 @@ COBJS-$(CONFIG_OC_TINY_SPI) += oc_tiny_spi.o COBJS-$(CONFIG_OMAP3_SPI) += omap3_spi.o COBJS-$(CONFIG_SOFT_SPI) += soft_spi.o COBJS-$(CONFIG_SH_SPI) += sh_spi.o +COBJS-$(CONFIG_SH_QSPI) += sh_qspi.o COBJS-$(CONFIG_FSL_ESPI) += fsl_espi.o COBJS-$(CONFIG_FDT_SPI) += fdt_spi.o COBJS-$(CONFIG_TEGRA20_SFLASH) += tegra20_sflash.o diff --git a/drivers/spi/sh_qspi.c b/drivers/spi/sh_qspi.c new file mode 100644 index 0000000..82bb49f --- /dev/null +++ b/drivers/spi/sh_qspi.c @@ -0,0 +1,204 @@ +/* + * drivers/spi/sh_qspi.c + * SH QSPI driver + * + * Copyright (C) 2013 Renesas Electronics Corporation + * Copyright (C) 2013 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <malloc.h> +#include <spi.h> +#include <asm/io.h> +#include "sh_qspi.h" + +static void sh_qspi_writeb(unsigned char data, unsigned char *reg) +{ + writeb(data, reg); +} + +static void sh_qspi_writew(unsigned short data, unsigned short *reg) +{ + writew(data, reg); +} + +static void sh_qspi_writel(unsigned long data, unsigned long *reg) +{ + writel(data, reg); +} + +static unsigned char sh_qspi_readb(unsigned char *reg) +{ + return readb(reg); +} + +static unsigned short sh_qspi_readw(unsigned short *reg) +{ + return readw(reg); +} + +void spi_init(void) +{ +} + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct sh_qspi *ss; + + if (!spi_cs_is_valid(bus, cs)) + return NULL; + + ss = spi_alloc_slave(struct sh_qspi, bus, cs); + if (!ss) + return NULL; + + ss->regs = (struct sh_qspi_regs *)CONFIG_SH_QSPI_BASE; + + /* QSPI initialize */ + sh_qspi_writeb(0x08, &ss->regs->spcr); + sh_qspi_writeb(0x00, &ss->regs->sslp); + sh_qspi_writeb(0x06, &ss->regs->sppcr); + sh_qspi_writeb(0x01, &ss->regs->spbr); + sh_qspi_writeb(0x00, &ss->regs->spdcr); + sh_qspi_writeb(0x00, &ss->regs->spckd); + sh_qspi_writeb(0x00, &ss->regs->sslnd); + sh_qspi_writeb(0x00, &ss->regs->spnd); + sh_qspi_writew(0xe084, &ss->regs->spcmd0); + sh_qspi_writew(0x8084, &ss->regs->spcmd0); + sh_qspi_writeb(0xc0, &ss->regs->spbfcr); + sh_qspi_writeb(0x00, &ss->regs->spbfcr); + sh_qspi_writeb(0x00, &ss->regs->spscr); + sh_qspi_writeb(0x48, &ss->regs->spcr); + + return &ss->slave; +} + +void spi_free_slave(struct spi_slave *slave) +{ + struct sh_qspi *spi = to_sh_qspi(slave); + + free(spi); +} + +int spi_claim_bus(struct spi_slave *slave) +{ + return 0; +} + +void spi_release_bus(struct spi_slave *slave) +{ +} + +static int sh_qspi_xfer(struct sh_qspi *ss, unsigned char *tdata, + unsigned char *rdata, unsigned long flags) +{ + while (!(sh_qspi_readb(&ss->regs->spsr) & SH_QSPI_SPTEF)) { + if (ctrlc()) + return 1; + udelay(10); + } + + sh_qspi_writeb(*tdata, (unsigned char *)(&ss->regs->spdr)); + + while ((sh_qspi_readw(&ss->regs->spbdcr) != 0x01)) { + int i = 100; + + if (ctrlc()) + return 1; + while (i--) + ; + } + + while (!(sh_qspi_readb(&ss->regs->spsr) & SH_QSPI_SPRFF)) { + if (ctrlc()) + return 1; + udelay(10); + } + + *rdata = sh_qspi_readb((unsigned char *)(&ss->regs->spdr)); + + return 0; +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, + void *din, unsigned long flags) +{ + struct sh_qspi *ss = to_sh_qspi(slave); + unsigned int nbyte; + int ret = 0; + unsigned char *tdata, *rdata, dtdata = 0, drdata; + + if (dout == NULL && din == NULL) { + if (flags & SPI_XFER_END) + sh_qspi_writeb(0x08, &ss->regs->spcr); + return 0; + } + + if (bitlen % 8) { + printf("spi_xfer: bitlen is not 8bit alined %d", bitlen); + return 1; + } + + nbyte = bitlen / 8; + + if (flags & SPI_XFER_BEGIN) { + sh_qspi_writeb(0x08, &ss->regs->spcr); + + sh_qspi_writew(0xe084, &ss->regs->spcmd0); + + if (flags & SPI_XFER_END) + sh_qspi_writel(nbyte, &ss->regs->spbmul0); + else + sh_qspi_writel(0x100000, &ss->regs->spbmul0); + + sh_qspi_writeb(0xc0, &ss->regs->spbfcr); + sh_qspi_writeb(0x00, &ss->regs->spbfcr); + sh_qspi_writeb(0x00, &ss->regs->spscr); + sh_qspi_writeb(0x48, &ss->regs->spcr); + } + + if (dout != NULL) + tdata = (unsigned char *)dout; + else + tdata = &dtdata; + + if (din != NULL) + rdata = din; + else + rdata = &drdata; + + while (nbyte > 0) { + ret = sh_qspi_xfer(ss, tdata, rdata, flags); + if (ret) + break; + + if (dout != NULL) + tdata++; + + if (din != NULL) + rdata++; + + nbyte--; + } + + if (flags & SPI_XFER_END) + sh_qspi_writeb(0x08, &ss->regs->spcr); + + return ret; +} + +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return 1; +} + +void spi_cs_activate(struct spi_slave *slave) +{ +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ +} diff --git a/drivers/spi/sh_qspi.h b/drivers/spi/sh_qspi.h new file mode 100644 index 0000000..9898259 --- /dev/null +++ b/drivers/spi/sh_qspi.h @@ -0,0 +1,56 @@ +/* + * drivers/spi/sh_qspi.h + * SH QSPI driver definition + * + * Copyright (C) 2013 Renesas Electronics Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __SH_QSPI_H__ +#define __SH_QSPI_H__ + +#include <spi.h> + +struct sh_qspi_regs { + unsigned char spcr; + unsigned char sslp; + unsigned char sppcr; + unsigned char spsr; + unsigned long spdr; + unsigned char spscr; + unsigned char spssr; + unsigned char spbr; + unsigned char spdcr; + unsigned char spckd; + unsigned char sslnd; + unsigned char spnd; + unsigned char dummy0; + unsigned short spcmd0; + unsigned short spcmd1; + unsigned short spcmd2; + unsigned short spcmd3; + unsigned char spbfcr; + unsigned char dummy1; + unsigned short spbdcr; + unsigned long spbmul0; + unsigned long spbmul1; + unsigned long spbmul2; + unsigned long spbmul3; +}; + +/* SPSR */ +#define SH_QSPI_SPRFF 0x80 +#define SH_QSPI_SPTEF 0x20 + +struct sh_qspi { + struct spi_slave slave; + struct sh_qspi_regs *regs; +}; + +static inline struct sh_qspi *to_sh_qspi(struct spi_slave *slave) +{ + return container_of(slave, struct sh_qspi, slave); +} + +#endif
[snip]
- drivers/spi/sh_qspi.c
- SH QSPI driver
[snip]
Since "QSPI" also means "Quad SPI", can you please do "SH QSPI (Queued SPI) driver" here and in the header, so it's clear what Q this is?
- /* QSPI initialize */
- sh_qspi_writeb(0x08, &ss->regs->spcr);
Can you please #define all of these magic numbers?
Thanks.
Thank you for your review.
2013/7/31 Tom Rini trini@ti.com:
[snip]
- SH QSPI driver
[snip]
OK, I will fix this.
OK, I will fix this too.
Thanks.
Best regards, Nobuhiro
Nobuhiro Iwamatsu
